    4. tr-064.0 Cannot read property 's:Envelope' of undefined
    UNSOLVED tr-064.0 Cannot read property 's:Envelope' of undefined
    • nik82
      nik82 Most Active last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC
      Arbeitsspeicher: 16GB
      Festplattenart: SSD
      Betriebssystem: Windows10 Pro
      Node-Version: v12.20.1
      Nodejs-Version: v12.20.1
      NPM-Version: 6.14.10
      Installationsart: Iobroker Windows Setup
      CCU3: aktuelle RaspberryMatic mit 3.55.5.20201226
      TR-064 Adapter: v4.2.2
      bekomme mehrmals am Tag die Fehlermeldung "tr-064.0 (50556) uncaught exception: Cannot read property 's:Envelope' of undefined" beim tr-064 Adapter:
      2021-01-11 02:16:22.286 - error: tr-064.0 (50556) uncaught exception: Cannot read property 's:Envelope' of undefined
      2021-01-11 02:16:22.292 - error: tr-064.0 (50556) TypeError: Cannot read property 's:Envelope' of undefined
      at C:\iobroker\Iobroker4\node_modules\tr-O64\lib\Service.js:217:33
      at Parser. (C:\iobroker\Iobroker4\node_modules\xml2js\lib\parser.js:308:18)
      at Parser.emit (events.js:314:20)
      at Parser.EventEmitter.emit (domain.js:483:12)
      at SAXParser.onerror (C:\iobroker\Iobroker4\node_modules\xml2js\lib\parser.js:123:26)
      at emit (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:624:35)
      at error (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:653:5)
      at strictFail (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:677:7)
      at end (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:658:47)
      at SAXParser.write (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:975:14)
      2021-01-11 02:16:22.344 - error: host.IOBROKER(Iobroker) Caught by controller[0]: TypeError: Cannot read property 's:Envelope' of undefined
      2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at C:\iobroker\Iobroker4\node_modules\tr-O64\lib\Service.js:217:33
      2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at Parser. (C:\iobroker\Iobroker4\node_modules\xml2js\lib\parser.js:308:18)
      2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at Parser.emit (events.js:314:20)
      2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at Parser.EventEmitter.emit (domain.js:483:12)
      2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at SAXParser.onerror (C:\iobroker\Iobroker4\node_modules\xml2js\lib\parser.js:123:26)
      2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at emit (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:624:35)
      2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at error (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:653:5)
      2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at strictFail (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:677:7)
      2021-01-11 02:16:22.348 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at end (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:658:47)
      2021-01-11 02:16:22.348 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at SAXParser.write (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:975:14)
      2021-01-11 02:16:22.348 - error: host.IOBROKER(Iobroker) instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2021-01-11 02:16:22.348 - info: host.IOBROKER(Iobroker) Restart adapter system.adapter.tr-064.0 because enabled
      2021-01-11 02:16:52.386 - info: host.IOBROKER(Iobroker) instance system.adapter.tr-064.0 started with pid 38480
      2021-01-11 02:16:53.292 - info: tr-064.0 (38480) starting. Version 4.2.2 in C:/iobroker/Iobroker4/node_modules/iobroker.tr-064, node: v12.20.1, js-controller: 3.1.6
      Irgendjemand eine Idee an was das liegen kann?
      Danke im Voraus.
        Thomas Braun Most Active @nik82 last edited by
        @nik82 sagte in tr-064.0 Cannot read property 's:Envelope' of undefined:
        tr-O64
        Steht da wirklich tr-O64?
        Ich würde da eher tr-064 erwarten.
        nik82 1 Reply Last reply Reply Quote 0
        • nik82
          nik82 Most Active @Thomas Braun last edited by
          Krass, da steht wirklich ein O (Buchstabe) und keine 0 (Zahl) :
          Hab das jetzt mal umbenannt, das könnte doch schon der Fehler sein oder?
          • nik82
            nik82 Most Active @nik82 last edited by
            Nein, das geht nicht mit umbennen, dann findet er es nicht mehr:
            • nik82
              nik82 Most Active @nik82 last edited by nik82
              Falls es wen interessiert, im Github gehts weiter:
              Github Issue
              senvelope tr-064
