    5. Text zerlegen und neu zusammensetzen
      Rushmed Most Active @David G. last edited by
      @David-G Lannst du für alle Interessierten das jetzt finale Blockly posten?
      Das wäre sau nett!
      • David G.
        David G. @Rushmed last edited by David G.
        @Rushmed
        Wollte ich machen, wenn ich die Tabelle mit eingebaut habe. Hier aber schonmal der aktuelle Stand.
          <variables>
            <variable id="(m}dH@gw]g]CrCq4X:^O">Liste</variable>
            <variable id="^u_U-Az-`mhCz~(F_#oT">text</variable>
            <variable id="x(8OtWm-n$bsM}t4],DO">i</variable>
            <variable id="B=:MPlbZ]`U`oQR_H1ZO">obj</variable>
            <variable id="WND~1`M#LY[oSWchGJ;/">Titel</variable>
            <variable id="qkP}SP]Wsh}w_3jlwPM=">Sender</variable>
            <variable id="Cb`$KNa=.y/wQjyFtN6F">Zeit</variable>
            <variable id="=H4KnMf9.v,`_]uv_6#?">Bild</variable>
          </variables>
          <block type="on" id="ubL@LBF!,o_rkk4*V?$c" x="113" y="163">
            <field name="OID">0_userdata.0.code</field>
              <block type="variables_set" id="W?1q7FaV,*wmZaIkPQ*o">
                <field name="VAR" id="(m}dH@gw]g]CrCq4X:^O">Liste</field>
                  <block type="convert_json2object" id="-+dC_oJ;-(a!X+qq3ItL">
                      <block type="on_source" id="W9LY54G8%@AW$,Dv.c1;">
                  <block type="variables_set" id="*Gbs7`LVq2ggdi|-gk1#">
                    <field name="VAR" id="^u_U-Az-`mhCz~(F_#oT">text</field>
                      <block type="text" id="D2QaAKbM6V%.nH8G!WO8">
                        <field name="TEXT"></field>
                      <block type="controls_for" id="VAh4_5skpQ(-58)cTsN5">
                        <field name="VAR" id="x(8OtWm-n$bsM}t4],DO">i</field>
                        <value name="FROM">
                          <shadow type="math_number" id="UtEruMTPhi^T~g$#4=X%">
                            <field name="NUM">1</field>
                        <value name="TO">
                          <shadow type="math_number" id="SL!L;!$5LE6b.-i2{-x8">
                            <field name="NUM">10</field>
                          <block type="lists_length" id="IA8x7(aD91K?{^4e{t?p">
                              <block type="variables_get" id="Uw=RBKOt~o^7pvz5@?jp">
                        <value name="BY">
                          <shadow type="math_number" id="X?ku5(f{C?`POZ9}Ykn$">
                        <statement name="DO">
                          <block type="variables_set" id="?x8p%;#1!zl^M{*-WeD_">
                            <field name="VAR" id="B=:MPlbZ]`U`oQR_H1ZO">obj</field>
                              <block type="lists_getIndex" id="!p81u1HNh}swg_ZCMWGd">
                                  <block type="variables_get" id="3ETVK*E:VqCH}#kblamq">
                                <value name="AT">
                                  <block type="variables_get" id="4ZY9FTQA,JoJx!nEg^nc">
                              <block type="variables_set" id="j5Gdw_u6HAN7$Hwd1Sk,">
                                <field name="VAR" id="WND~1`M#LY[oSWchGJ;/">Titel</field>
                                  <block type="get_attr" id="V=ixw;0O?aW0sXtNbLyR">
                                    <value name="PATH">
                                      <shadow type="text" id="XE}T12XOKYB-U6A8etD(">
                                        <field name="TEXT">title</field>
                                    <value name="OBJECT">
                                      <block type="variables_get" id="Aqx9nyk[/uZhLuG|WKW]">
                                  <block type="variables_set" id="7n/:wb/R14Kz[S(YP^)z">
                                    <field name="VAR" id="qkP}SP]Wsh}w_3jlwPM=">Sender</field>
                                      <block type="get_attr" id="si%nmaEYZ8yF2`)aXAA[">
                                        <value name="PATH">
                                          <shadow type="text" id="Vv?R@/OzO]p40i%9sCnd">
                                            <field name="TEXT">station</field>
                                          <block type="variables_get" id="Dv389p@`@/Y3}]gx``_e">
                                      <block type="variables_set" id="aKy)HU06-POy;kU_BZb-">
                                        <field name="VAR" id="Cb`$KNa=.y/wQjyFtN6F">Zeit</field>
                                          <block type="get_attr" id="`wPRO=fu4+XJSLOOaSO0">
                                            <value name="PATH">
                                              <shadow type="text" id="%IZ(eKv9iMml(NI-f]5P">
                                                <field name="TEXT">time</field>
                                              <block type="variables_get" id="3Hno*M89!AaJIE6(3=33">
                                          <block type="variables_set" id="X)I9aAIj8q}#(,lBLoA8">
                                            <field name="VAR" id="=H4KnMf9.v,`_]uv_6#?">Bild</field>
                                              <block type="get_attr" id=";tsY?ta87G!Ip{x3uz#T">
                                                <value name="PATH">
                                                  <shadow type="text" id="HmVz%-OkrSIKER](18V:">
                                                    <field name="TEXT">imgUrl</field>
                                                  <block type="variables_get" id="Vq9etR=Lc?:t?%0IUjP9">
                                              <block type="variables_set" id=",AX3xaQpP,RI_FeH!Xx|">
                                                  <block type="text_join" id="oc7)%`;1Y7hZ,{LSK@n^">
                                                    <mutation items="8"></mutation>
                                                    <value name="ADD0">
                                                      <block type="variables_get" id="A]OKm4e`3x(zLzn6s(QN">
                                                    <value name="ADD1">
                                                      <block type="variables_get" id="fIhTLcQB}M=fC^B;!y[3">
                                                    <value name="ADD2">
                                                      <block type="text_newline" id="mZGUIN_q[1%Kvb:UML$s">
                                                        <field name="Type">\n</field>
                                                    <value name="ADD3">
                                                      <block type="variables_get" id=";1!SxOtb)P*,f@2txLG+">
                                                    <value name="ADD4">
                                                      <block type="text_newline" id="L2J)8?zZhqA12mo@#Di:">
                                                    <value name="ADD5">
                                                      <block type="variables_get" id="7r#.X6VO;Q,F#?pc,v0W">
                                                    <value name="ADD6">
                                                      <block type="text_newline" id="-s?OIWzO`zecbv=d{A6D">
                                                    <value name="ADD7">
                                                      <block type="variables_get" id="bJfAhLxPp7#nS|JLsb$2">
                          <block type="update" id="=iOOU)DZOb[YQgsxVq={">
                            <field name="OID">0_userdata.0.VIS.tvprogramm.2015</field>
                              <block type="variables_get" id="4R$*aP-tIeoXAU7-OHcp">
          paul53 @David G. last edited by
          @David-G sagte:
          "aktualisiere" gehört unter die Schleife.
          • David G.
            David G. @paul53 last edited by
            Ist verrutscht, man sollte nicht am Smartphone am Script weiterarbeiten 😅.
            Habs oben aktualisiert.
            • David G.
              Anbei das Script mit Tabelle.
              An die Tabelle setze ich mich nochmal in Ruhe, da sollte aber eh jeder ein wenig spielen, wie es ihm besser gefällt.
                <variables>
                  <variable id=",,-mG}Ve8pp=2QR3G0v$">Beschreibung</variable>
                </variables>
                  <field name="OID">tvspielfilm.0.json.raw.heute2015</field>
                              <value name="FROM">
                              <value name="TO">
                              <value name="BY">
                                      <value name="AT">
                                          <value name="PATH">
                                              <value name="PATH">
                                                  <value name="PATH">
                                                      <value name="PATH">
                                                    <block type="variables_set" id="86DEYVo??R/@i_!:f`H?">
                                                      <field name="VAR" id=",,-mG}Ve8pp=2QR3G0v$">Beschreibung</field>
                                                        <block type="get_attr" id="vr3`]9_k0Ke3+G;BPe0$">
                                                          <value name="PATH">
                                                            <shadow type="text" id="g}99n.xJZe2a;])BF`jI">
                                                              <field name="TEXT">description</field>
                                                            <block type="variables_get" id="C?}|MWY(:zJSY(62Q!L-">
                                                              <mutation items="14"></mutation>
                                                              <value name="ADD0">
                                                              <value name="ADD1">
        <block type="text" id="@UfRgRh#-n,^e{wnY,#$">
        <field name="TEXT">&lt;tr valign="top"&gt;&lt;th rowspan="2" ALIGN="LEFT" valign="top"&gt;</field>
                                                              <value name="ADD2">
        <block type="text" id="SmFyDO|0Dgd0$?eaA`Sg">
        <field name="TEXT"> &lt;img src="</field>
                                                              <value name="ADD3">
                                                              <value name="ADD4">
        <block type="text" id="V(@hQGqP#lM:3RU#|B.M">
        <field name="TEXT">" width="500px" valign="top"&gt;</field>
                                                              <value name="ADD5">
        <block type="text" id="QL$OjZdV(xM6KUL/dmLz">
        <field name="TEXT">&lt;/th&gt;&lt;th ALIGN="LEFT"&gt;&lt;font size="3"&gt;</field>
                                                              <value name="ADD6">
                                                              <value name="ADD7">
        <block type="text" id="gX^e$Yd~=w#@sewo9`#+">
        <field name="TEXT">&amp;nbsp;|&amp;nbsp;</field>
                                                              <value name="ADD8">
                                                              <value name="ADD9">
        <block type="text" id="!PY*^%g4j-ZU}v{?r%xr">
                                                              <value name="ADD10">
                                                              <value name="ADD11">
        <block type="text" id="cHmPNGVArXff^;r4UFx9">
        <field name="TEXT">&lt;/th&gt;&lt;/tr&gt;&lt;tr&gt;&lt;td ALIGN="LEFT"&gt;&lt;font size="2"&gt;</field>
                                                              <value name="ADD12">
        <block type="text_getSubstring" id="6N[/%V@1Q[0YvLVKJ?~=">
        <mutation at1="true" at2="true"></mutation>
        <field name="WHERE1">FROM_START</field>
        <field name="WHERE2">FROM_START</field>
        <value name="STRING">
        <block type="variables_get" id="JK9,5eYH6s8U9Jv-ZBcr">
        <value name="AT1">
        <block type="math_number" id="v-Z:lGRy$;zzt0LH{])|">
        <value name="AT2">
        <block type="math_number" id="?%hQ{jpe?6;.(D/`m7_8">
        <field name="NUM">300</field>
                                                              <value name="ADD13">
        <block type="text" id="P{0@!YzHS)23b;XH%g*4">
        <field name="TEXT">&lt;/tr&gt;</field>
                                    <block type="text_join" id=")4[foVL+;!xdhFv($WVn">
                                      <value name="ADD0">
                                        <block type="text" id="rqH.Tp+,./Gm@C8e99ZY">
                                          <field name="TEXT">&lt;table&gt;</field>
                                      <value name="ADD1">
                                      <value name="ADD2">
                                        <block type="text" id="3Nljk,tpV27x(#;V?7mB">
                                          <field name="TEXT">&lt;/table&gt;</field>
              Homoran dslraser 2 Replies Last reply Reply Quote 1
                Homoran Global Moderator Administrators @David G. last edited by
                @David-G sagte in Text zerlegen und neu zusammensetzen:
                ist das die "Tabelle" ?
                Bild Text
                Was ist denn mit dem ersten Eintrag passiert? 😂
                David G. 2 Replies Last reply Reply Quote 0
                • David G.
                  David G. @Homoran last edited by David G.
                  @Homoran
                  Jepp.
                  Ist noch aus meinem Testdatenpunkt.
                  Da habe ich einfach immer irgendwas abgeändert, um zu sehen was das Script macht um den TV-Movie-Adapter nicht immer anders einstellen zu müssen für eine Aktualisierung des Datenpunktes 😄
                  • David G.
                    @Homoran
                    In meiner Visualisierung habe ich noch die Möglichkeit, zwischen dem aktuellen und dem Programm von heute abend zu wechseln.
                    (Die Buttons werde ich noch was anpassen, gefällt mir noch nicht ganz.)
                    • dslraser
                      dslraser Forum Testing Most Active @David G. last edited by
                      erstmal Danke fürs teilen.
                      Funktioniert das bei Dir wirklich ?
                      Müssen im Adapter irgendwelche Sender eingetragen werden ?
                      javascript.0	2021-01-11 18:54:52.283	error	(26377) at processImmediate (internal/timers.js:461:21)
                      javascript.0	2021-01-11 18:54:52.283	error	(26377) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                      javascript.0	2021-01-11 18:54:52.282	error	(26377) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:472:25)
                      javascript.0	2021-01-11 18:54:52.282	error	(26377) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1070:38)
                      javascript.0	2021-01-11 18:54:52.282	error	(26377) at Object.<anonymous> (script.js.02_TV_System.TV-VISU:21:283)
                      javascript.0	2021-01-11 18:54:52.281	error	(26377) script.js.02_TV_System.TV-VISU: TypeError: Cannot read property 'slice' of undefined
                      • David G.
                        David G. @dslraser last edited by David G.
                        @dslraser
                        Klappt wunderbar.
                        Der Adapter hat zwar nicht soooo viele Sender integriert, funktioniert aber gut.
                        Für die Sender gibt es eine Black- bzw Whitelist.
                        In VIS bekommt man die Daten aber auch ohne das Script, steht im Thread vom Adapter beschrieben.
                        • dslraser
                          @David-G
                          ich bekomme die obige Fehlermeldung. Im Adapter habe ich weder bei Blackliste noch bei Whitelist was eingetragen
                          David G. paul53 2 Replies Last reply Reply Quote 0
                          • David G.
                            @dslraser
                            Glaube hatte den von Git installiert.
                              paul53 @dslraser last edited by
                              @dslraser sagte:
                              Enthält das JSON bei Dir keine "description" ?
                              • dslraser
                                dslraser Forum Testing Most Active @David G. last edited by dslraser
                                Ich hatte stable installiert...(nun von Git die 2.0.1)
                                Nun kommen zusätzliche/andere Datenpunkte und anderer Inhalt. Ich schaue nochmal ob es nun geht.
                                Edit: nun funktioniert es
                                • David G.
                                  @dslraser
                                  Wichtig ist es, für das Script die Datenpunkte von raw zu nehmen.
                                  Der HTML Datenpunkt kann in vis verwendet werden.
                                  • dslraser
                                    @David-G
                                    es lag daran
                                    • dslraser
                                      @David-G
                                      mein erster kurzer Test mit iQontrol
                                      (Bilder habe ich nur auf 100px)
                                      • David G.
                                        @dslraser
                                        Sehr cool, dass es bei dir auch klappt.
                                        • dirk1962
                                          dirk1962 last edited by
                                          Hallo @David-G, ich habe Dein Blockly für die html-Tabelle installiert und den Datenpunkt angelegt. Im log ist keine Fehlermeldung, aber der Datenpunkt wird nicht gefüllt. TV-Spielfilm V 2.0.1 ist installiert und in VIS wird auch alles korrekt angezeigt. Brauche die html-Tabelle für iQontrol.
                                          Hast Du eine Idee, was ich falsch mache?
                                          dslraser David G. 2 Replies Last reply Reply Quote 0
                                          • dslraser
                                            dslraser Forum Testing Most Active @dirk1962 last edited by dslraser
                                            @dirk1962
                                            ich weiß nicht ob es eine Rolle spielt, aber ich habe als DP Typ string angelegt.
                                            RAW DP
                                              "_id": "0_userdata.0.TV_Spielfim.TV_Spielfilm_2015",
                                              "type": "state",
                                              "common": {
                                                "name": "ab_2015",
                                                "role": "string",
                                                "type": "string",
                                                "read": true,
                                                "write": true,
                                                "desc": "Manuell erzeugt",
                                                "def": ""
                                              "native": {},
                                              "user": "system.user.admin",
                                              "ts": 1610386690717,
                                              "acl": {
                                                "object": 1636,
                                                "state": 1636,
                                                "owner": "system.user.admin",
                                            Läuft bei mir auch in iQontrol.
                                            3400
