    4. Beta Test js-controller 3.2.x auf GitHub
      lonsimbt @apollon77 last edited by
      @apollon77
      Pushsafer will immer noch nicht (s. meinen Post oben) . Ansonsten ist bislang alles unauffällig.
      Gruß Marco
      coyote apollon77 2 Replies Last reply Reply Quote 0
      • coyote
        coyote Most Active @lonsimbt last edited by coyote
        Gerade auch mal die letzte Version installiert. Sieht soweit gut aus.
        Muss/kann ich hier noch was machen oder ok so?
        root@debian:/opt/iobroker# npm i iobroker.js-controller@next
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        > iobroker.js-controller@3.2.6-0 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.10
        > iobroker.js-controller@3.2.6-0 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        object _design/system updated
        Renamed repository "default to "stable"
        Renamed repository "latest to "beta"
        > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
        > node scripts/postinstall
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN @material-ui/pickers@3.2.10 requires a peer of @material-ui/core@^4.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN @material-ui/pickers@3.2.10 requires a peer of react@^16.8.4 but none is installed. You must install peer dependencies yourself.
        npm WARN @material-ui/pickers@3.2.10 requires a peer of react-dom@^16.8.4 but none is installed. You must install peer dependencies yourself.
        npm WARN react-transition-group@4.4.1 requires a peer of react@>=16.6.0 but none is installed. You must install peer dependencies yourself.
        npm WARN react-transition-group@4.4.1 requires a peer of react-dom@>=16.6.0 but none is installed. You must install peer dependencies yourself.
        npm WARN rifm@0.7.0 requires a peer of react@>=16.8 but none is installed. You must install peer dependencies yourself.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        + iobroker.js-controller@3.2.6-0
        added 38 packages from 10 contributors, removed 29 packages, updated 44 packages and moved 1 package in 84.186s
        46 packages are looking for funding
          run `npm fund` for details
        mikeal created this issue in request/request
        open Request’s Past, Present and Future #3142
          apollon77 @Jan1 last edited by
          @jan1 denke geht nach Admin update 🙂 das ggf per cli
          lobomau 1 Reply Last reply Reply Quote 0
            apollon77 @lonsimbt last edited by
            @lonsimbt Auch nicht mit der Verison vom github?? zeig mal log von der
              apollon77 @coyote last edited by
              @coyote nee, alles ok
              • lobomau
                lobomau @apollon77 last edited by lobomau
                Edit: erledigt... upgrade... nicht update und ohne 0 🙂
                also:
                iobroker upgrade admin
                @apollon77 said in Beta Test js-controller 3.2.x auf GitHub:
                wie war hier der genaue Befehl?
                iobroker update admin.0
                ist es nicht 😉
                Anonsten kann ich keinen Adapter updaten über die GUI vom Admin.
                lobomau 1 Reply Last reply Reply Quote 1
                • lobomau
                  lobomau @lobomau last edited by
                  @apollon77 ich kann keine Updates machen... auch nicht mit Admin 4.2.1.
                    apollon77 @lobomau last edited by apollon77
                    @lobomau Zeig doch mal was in dem mouse over steht über dem update button 🙂 So schnell kann ich nicht lesen
                    • lobomau
                      @apollon77 aaahh... ich habe da gar nicht drauf geachtet, dass da was steht 🙂
                      Wurde ja schon vorher hier geschrieben wie ich sehe:
                      Das ist ja das Problem mit der "komischen" Version.
                        @lobomau Auch mal wirklich shift reload und so das wirklich das neueste JS im browser ist?
                          @apollon77
                          Sorry man sollte erst das Hirn einschalten...
                          Mit der pushsafer-Version vom github funktioniert wieder alles. Keine Fehler mehr im Log, Push-Nachrichten werden zugestellt.
                          Gruß Marco
                            @lobomau Hey, ja habe Grund gefunden ... wir schauen mal .. Wie gesagt aktuell gehen updates per Kommandozeile 😞
                            lobomau 2 Replies Last reply Reply Quote 1
                            • Feuersturm
                              Feuersturm @apollon77 last edited by
                              Gibt nachher folgendes:
                              • admin 4.2.1
                              • socketip 3.1.3
                              • web 3.2.3
                              Adapter konnten regulär über die Adminoberfläche eingespielt werden. Bisher keine Auffälligkeiten.
                              • lobomau
                                sehr schön. Habe erstmal alles über Kommandozeile geupdatet.
                                • O
                                  oFbEQnpoLKKl6mbY5e13 @lobomau last edited by
                                  Abgesehen von den
                                  has no existing object, this might lead to an error in future versions
                                  Meldungen der Adapter alexa2 (Fehler bereits gefunden) und sonos (issue erstellt) läuft der neue JS-Controller bisher einwandfrei.
                                  • lobomau
                                    @apollon77 muss ich wenn ich auf js-controller 3.1.6 zurückgehe auch den admin downgraden?
                                    3.1.6 läuft bereit, aber meine Admin Probleme bleiben bestehen.
                                    J apollon77 2 Replies Last reply Reply Quote 0
                                      Jan1 @lobomau last edited by
                                      @lobomau
                                      Nein, wobei Admin 3.1.6? Ist das der aktuelle aus dem default REPO? Ist ja welten hinter dem aktuellen aus beta.
                                      • lobomau
                                        lobomau @Jan1 last edited by
                                        @jan1 nee, admin ist gerade 4.2.1.
                                        JS ist 3.1.6.
                                          @lobomau
                                          Ok, ist noch früh 😉
                                          Den JS brauchst aber auuch nicht downgraden, da der läuft, außer die Unschönheit mit dem Adapter Update. Das kannst aber sehr einfach mit Klick oben auf das Fähnchen übergehen.
                                          • lobomau
                                            @jan1 mein System scheint da speziell (Proxmox Debian 10 Container). Da ging einiges nicht mehr (Adapter wurden nicht angezeigt, Updates der Adapter nicht möglich, einige Abstürze über Nacht (RAM und CPU bis 100%...). Ich habe einige Adapter ausgestellt und gestern sogar ein ganz frisches System erstellt.
                                            Nun bin ich wieder auf ein Backup vom 4. Januar.
                                            Bei Gegebenheit versuche ich es mal mit einem Testsystem wieder nachzustellen. Leider bin ich mit meiner 120 GB SSD auch etwas begrenzt für weitere Testcontainer.
                                            js-controller
                                            25
                                            287
                                            46127
