    4. RFlink (LOS GEHT ES ) Bestellung d.Hardware (20€) + 5€ Spende an Forum f.d. Adapter (crowdfunding like :-)
    • Lenny.CB
      Lenny.CB Most Active last edited by
      Stimmt… is wieder son "wald vor lauter bäumen" ding...
      Dank dir!
      Gesendet von meinem SM-G925F mit Tapatalk
        Sorry for bad news 😢
        Es gab eben ein update. Seitdem läuft RFlink gar nicht mehr:
        ! $ ./iobroker url "https://github.com/ioBroker/ioBroker.rflink/tarball/master" rflink
        install https://github.com/ioBroker/ioBroker.rflink/tarball/master
        npm install https://github.com/ioBroker/ioBroker.rflink/tarball/master --production --prefix "/opt/iobroker" (System call)
        npm
        WARN
        cannot run in wd ws@0.4.32 (node-gyp rebuild 2> builderror.log) || (exit 0) (wd=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/avrga-tester/node_modules/express-ws/node_modules/ws)
        node-pre-gyp
        ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.6/serialport-v4.0.6-node-v46-linux-arm64.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.6 and node@4.6.1 (node-v46 ABI) (falling back to source compile with node-gyp)
        ! gyp
        WARN
        EACCES
        user "root" does not have permission to access the dev dir "/root/.node-gyp/4.6.1"
        gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/.node-gyp"
        make: *** No rule to make target '../.node-gyp/4.6.1/include/node/common.gypi', needed by 'Makefile'. Stop.
        gyp
        ERR!
        build error
        gyp
        ERR! stack Error: make failed with exit code: 2gyp
        ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
        gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR!
        stack at ChildProcess.emit (events.js:172:7)gyp ERR!
        stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
        gyp ERR! System Linux 3.10.104-pine64
        gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport
        ! gyp ERR! node -v v4.6.1gyp ERR! node-gyp -v v3.4.0
        gyp ERR! not ok
        ! node-pre-gyp ERR! build error
        node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/build/Release' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
        node-pre-gyp ERR! stack at emitTwo (events.js:87:13)
        node-pre-gyp ERR! stack at ChildProcess.emit (events.js:172:7)
        node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:829:16)
        node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
        node-pre-gyp ERR! System Linux 3.10.104-pine64
        ! node-pre-gyp
        ERR! command
        "/usr/local/bin/node" "/opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp
        ERR! cwd
        /opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino/node_modules/serialportnode-pre-gyp
        ERR!
        node -v v4.6.1
        node-pre-gyp ERR!
        node-pre-gyp -v v0.6.31
        node-pre-gyp
        ERR! not ok
        gyp
        WARN
        EACCES
        user "root" does not have permission to access the dev dir "/root/.node-gyp/4.6.1"gyp
        WARN
        EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/.node-gyp"
        gyp
        ERR!
        build error
        gyp
        ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack at emitTwo (events.js:87:13)
        ! gyp
        ERR!
        stack at ChildProcess.emit (events.js:172:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
        gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release"
        gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport
        gyp ERR! not ok
        ! node-pre-gyp
        ERR! build error
        node-pre-gyp
        ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)node-pre-gyp
        node-pre-gyp
        ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/serialportnode-pre-gyp
        ERR!
        node -v v4.6.1
        node-pre-gyp ERR!
        node-pre-gyp -v v0.6.26node-pre-gyp ERR! not ok
        npm
        WARN optional dep failed, continuing avrgirl-arduino@1.10.0
        npm
        ERR! Linux 3.10.104-pine64npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/ioBroker/ioBroker.rflink/tarball/master" "--production" "--prefix" "/opt/iobroker"
        ! npm
        ERR!
        node v4.6.1npm ERR! npm v2.15.9
        ! npm ERR! code ELIFECYCLE
        npm ERR! serialport@2.1.2 install: node-pre-gyp install --fallback-to-build
        npm ERR! Exit status 1
        ! npm
        ERR! npm ERR! Failed at the serialport@2.1.2 install script 'node-pre-gyp install --fallback-to-build'.
        npm ERR! This is most likely a problem with the serialport package,
        npm ERR! not with npm itself.
        npm ERR! Tell the author that this fails on your system:
        npm ERR! node-pre-gyp install --fallback-to-build
        npm ERR! You can get information on how to open an issue for this project with:
        npm ERR! npm bugs serialport
        npm ERR! Or if that isn't available, you can get their info via:
        npm ERR!
        npm ERR! npm owner ls serialport
        npm
        ERR! There is likely additional logging output above.
        ! npm
        ERR!
        Please include the following file with any support request:npm ERR! /opt/npm-debug.log
        ! ERROR: host.ioBroker_Pine64 Cannot install https://github.com/ioBroker/ioBroker.rflink/tarball/master: 1
        ERROR: process exited with code 25</anonymous></anonymous>
        Rainer
        • lobomau
          lobomau last edited by
          @Homoran:
          Rainer `
          Ich hab auf 1.0.5 geupdatet, und funktioniert, Ampel auf grün und Werte von der Outdoor Bresser Temperatur Station werden übermittelt.
          Das ganze am Raspi3.
          • lobomau
            @Homoran:
            Dadurch ergibt sich jetzt eine Frage an Maxtox (nur Frage, keine Kritik!): Wie groß ist denn die Reichweite der eingebauten Transceiver? Die Sensoren sind jetzt ca. 5m entfernt, hier bekomme ich nur zu einem Kontakt, bei 6m zu keinem.
            Ich müsste dann um im Garten die Steckdosen zu schalten mitten im Garten einen Arduino montieren?
            Rainer `
            Bin da auch am Testen. Also wenn die Bresser Outdoor-Klima-Station 5-6m weit weg steht mit Doppleverglasung dazwischen geht es. Habe dann nochmal 10m weiter weg gestellt, dann ging es nicht mehr.
            Bzgl. Reichweite war ich vorher davon ausgegenagen, dass die Reichweite von 433 MHz nicht so gut ist wie von den Homematic-Teilen mit 868 Mhz. Aber Optimieren kann man immer mal versuchen…
              @lobomau:
              Ich hab auf 1.0.5 geupdatet, und funktioniert, Ampel auf grün und Werte `
              :oops: :oops: ich habe dann nochmal und nochmal das log von mir durchgelesen :idea: und jetzt läuft es auch.
              Das Update muss mal wieder über die Konsole als echter root durchgeführt werden.
              Weder upgrade über den admin noch Neuinstallation über Octocat oder upgrade/neuinstallation als User mit sudo haben funktioniert.
              Lediglich die Neuinstallation als root.
              Rainer
              • Bluefox
                Bluefox last edited by
                Falls Adapter innerhalb von "Connection timeout" kein Telegram bekommt, denkt Adapter, dass Arduino tot ist.
                  @Bluefox:
                  Falls Adapter innerhalb von "Connection timeout" kein Telegram bekommt, denkt Adapter, dass Arduino tot ist. `
                  kommt aber wirklich sofort wieder, wenn dann ein Telegramm kommt.
                  Rainer
                    knopers1 last edited by
                    ich habe mir vorerst selbst ein Arduino zugelegt, da Maxtox noch einige Zeit braucht die weiteren Geräte fertigzustellen….
                    Ich habe einen guten Empfänger gekauft und bekomme gleich vier Wetterstationen angezeigt. Meine Werterstation ist gute 20 meter weg von dem Arduino und sogar eine Etage höher.... Das beste ist, dass ich noch weitere drei Wetterstationen der Nachbarn sehen kann. Dies spricht nur für den guten Empfänger und deren Leistung, denn diese Wetterstationen sind bestimmt noch weiter weg als mein Gerät 🙂
                    Der Sender lässt noch auf sich warten.... 😞
                      Maxtox last edited by
                      @knopers1:
                      Ich habe einen guten Empfänger gekauft und bekomme gleich vier Wetterstationen angezeigt. Meine Werterstation ist gute 20 meter weg von dem Arduino und sogar eine Etage höher.... Das beste ist, dass ich noch weitere drei Wetterstationen der Machbarn sehen kann. Dies spricht nur für den guten Empfänger und deren Leistung, denn diese Wetterstationen sind bestimmt noch weiter weg als mein Gerät 🙂
                      Der Sender für lässt noch auf sich warten.... 😞 `
                      Welche Hardware hast du benutzt? Rxb12? RXB8?
                      Welche antenne?
                      Ich habe, 1:1 hardware von rflink benutzt…
                        ja, die Hardware habe ich bereits vor einigen Tagen verlinkt!
                        Es ist ein RXB6 433 Mhz Superheterodyne Funkempfänger für 5€. In China gibt es die Teile für 2,50€, da weis ich aber nicht, ob es die Rev. 2.0 ist, denn die Empfänger gab es auch als Rev. 08 und dort sollte man ein Kondi einlöten…
                        Meine Antenne ist nicht besonderes...Ich habe einfach eine Strippe an den Antennenanschluß angeschlossen, selbst die Länge stimmt nicht ...
                        Sorry für die Qualität der Fotos! :mrgreen:
                          EDIT: RXB6 433 Mhz Superheterodyne Funkempfänger
                          in der Bucht eingekauft!
                          http://www.ebay.de/itm/172297596527?_tr … EBIDX%3AIT
                            @knopers1:
                            http://www.ebay.de/itm/172297596527?_tr … EBIDX%3AIT `
                            Kondensatore sind in allen von mir ausgelieferten teilen drin… Antenne, aheb ich schon bemängelt 😞
                            habe jetzt mal rxb8 v2 und rxb 6 V2 bestellt...schauen wir mal onb es besser wird 🙂
                              @Maxtox,
                              mit RXB6 machst Du nichts falsch! Ich habe die Wetterstation weitere 5m nach draussen verfrachtet um die Außentemp. messen zu können. Der Adapter empfängt weiterhin regelmäßig die Daten. Bleibt auch die ganze Zeit aktiv (grüner Punkt).Unter Erreignisse in IObroker werden auch regelmäßig die Daten abgefragt.
                              Mit welchem Adapter bekomme ich jetzt die Daten in VIS intergriert ??? Ich würde gerne die Außentemperatur in die WEB-UI des VIS einbauen.
                              • Lenny.CB
                                @knopers1:
                                Mit welchem Adapter bekomme ich jetzt die Daten in VIS intergriert ??? Ich würde gerne die Außentemperatur in die WEB-UI des VIS einbauen. `
                                im VIS die Objekt-ID vom gewünschten Datenpunkt zuweisen.
                                  @Lenny, Geil… :mrgreen:
                                  kann Du das als Text einfügen, so das ich es importieren kann??? Das Widget finde ich bei mir nicht.
                                  Ich habe es vorerst so gelöst!
                                  Wenn ich es gewusst hätte dass meine Nachbarn unzählige Wetterstationen hier in der Umgebung betreiben, dann würde ich mir das Geld für meine eigene Sparen :mrgreen:
                                  • Lenny.CB
                                    @knopers1:
                                    kann Du das als Text einfügen, so das ich es importieren kann??? `
                                    ! [{"tpl":"tplRGtermometer","data":{"oid":"rflink.0.channels.RFTech_1.TEMP","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","min_value":"-30","max_value":"40","factor":"1","value_offset":"0","show_shadow":"true","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"control":false,"show_scale":true},"style":{"left":"664px","top":"138px","width":100,"height":400},"widgetSet":"rgraph"}]
                                    @knopers1:
                                    Das Widget finde ich bei mir nicht. `
                                    musste noch den Adapter "rgraph" installieren…
                                      leo013 last edited by
                                      So ich war auch schon etwas ungeduldig und habe einen vorhanden Mega 2560 mit dem Aurel-Transceiver-Modul
                                      verbunden. Die Antenne ist eine kleine Magnetfußantenne für 430 MHz (war noch im Fundus durch mein 2. Hobby 😉 )
                                      Ich kann ausser meiner Wetterstation WS3600 auch einen Temp./Feuchte-Sensor eines Nachbarn empfangen
                                      Und schnell mal mit den vorhanden Widgets gespielt
                                      Wolfgang
                                        Klasse :mrgreen:
                                        ich habe gerade eine Fernbedienung für schaltbare Steckdosen ausprobiert.
                                        In jeder Ecke des Hauses wird das Betätigen der Tasten erkannt.
                                        Es handelt sich um dieses Model hier:
                                        Leider fehlt mir noch das Sendermodul um es schalten zu können.
                                        Der Empfänger ist erster Klasse, jetzt muß nur noch der Sender stark genug sein, dann sind wir zu Hause… 😄
                                          sirtwist672 last edited by
                                          Hallo
                                          Ich habe eine Lieferung aus China bekommen und kann sagen daß diese
                                          Bewegungsmelder erkannt werden. Die haben selber keine Intelligenz sondern melden
                                          nur daß Sie ausgelöst wurden. Über Empfindlichkeit kann ich noch nichts sagen.
                                          Außerdem kann ich sagen daß diese Funksteckdosen von Pollin funktionieren. habe die aber
                                          auf Intertechno umgestellt (dip schalter). Dann sind 256 Adressen möglich.
                                          die Fernbedienung nutze ich nicht. Als Fernbedienung nutze ich die Intertechno ITS 150
                                            Klasse…
                                            Bewegungsmelder suche ich auch noch!
                                            Bei Ali kosten 3 Stück um die 22 $
                                            https://de.aliexpress.com/item/3pcs-Lot ... oryId=3008
                                            Du schreibst dass die Bewegungsmelder erkannt werden, heißt es auch dass man sie auch in VIS auswerten kann und gleichzeitig auch in die ansteuerung für die Steckdosen verwenden kann?
                                            698
                                            200357
