    4. JavaScript
    5. Energieanzeige (kWh) über HTML Tabelle - vis
    • I
      Idefix01 @Palm_Maniac last edited by
      @liv-in-sky
      Nachdem ich Javascript neu installieren musste habe ich folgende Fehlermeldung:
      javascript.0	2020-08-22 21:37:00.085	error	(11243) at listOnTimeout (internal/timers.js:549:17)
      javascript.0	2020-08-22 21:37:00.085	error	(11243) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
      javascript.0	2020-08-22 21:37:00.084	error	(11243) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
      javascript.0	2020-08-22 21:37:00.083	error	(11243) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
      javascript.0	2020-08-22 21:37:00.083	error	(11243) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1270:34)
      javascript.0	2020-08-22 21:37:00.083	error	(11243) at Object.<anonymous> (script.js.Keller.Energieanzeige:1271:2)
      javascript.0	2020-08-22 21:37:00.083	error	(11243) at writeHTML (script.js.Keller.Energieanzeige:782:27)
      javascript.0	2020-08-22 21:37:00.082	error	(11243) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:796:29)
      javascript.0	2020-08-22 21:37:00.082	error	(11243) at script.js.Keller.Energieanzeige:810:18
      javascript.0	2020-08-22 21:37:00.081	error	(11243) at sammleDaten (script.js.Keller.Energieanzeige:1472:91)
      javascript.0	2020-08-22 21:37:00.080	error	(11243) Error in callback: TypeError: Cannot read property 'toFixed' of null
      javascript.0	2020-08-22 21:36:39.546	info	(11243) script.js.Keller.Energieanzeige: registered 0 subscriptions and 2 schedules
      Im Script Log kommt:
      21:37:00.081	error	javascript.0 (11243) at sammleDaten (script.js.Keller.Energieanzeige:1472:91)
      21:37:00.082	error	javascript.0 (11243) at script.js.Keller.Energieanzeige:810:18
      21:37:00.083	error	javascript.0 (11243) at writeHTML (script.js.Keller.Energieanzeige:782:27)
      21:37:00.083	error	javascript.0 (11243) at Object.<anonymous> (script.js.Keller.Energieanzeige:1271:2)
      liv-in-sky 4 Replies Last reply Reply Quote 0
        liv-in-sky @Idefix01 last edited by liv-in-sky
        @Idefix01
        kann es sein, dass unter javascript.0.Tabelle_EnergieRechnung datenpunkte sind, die keinen state (wert,inhalt) haben ?
        evtl einfritz dect gerät ?
          @Idefix01 als beispiel - es muss überall ein wert sein - 0 ist auch ok
            @Idefix01
            das ist doch das selbe wie hier ??????
              @Idefix01
              sollen wir eine teamviewer oder anydesk session machen - geht schneller
              I 2 Replies Last reply Reply Quote -1
              • I
                Idefix01 @liv-in-sky last edited by
                @liv-in-sky
                danke für das angebot habe den fehler gefunden, habe die Objekte alle nochmal gelöscht und neu anlegen lassen, jetzt steht zumindest überall eine 0 drin
                • I
                  Idefix01 @Idefix01 last edited by
                  @liv-in-sky
                  Hallöchen, habe ein wenig Mist gemacht in meinen Bildern. Nun fehlt mir das Bild für Gesamt in dem Energieanzeige Vis.
                  Kann mir jemand sagen wie das heißen muss? Die Bilder für die Feräte habe ich nun schon wieder drin zumindest ein Bild für alle Geräte.
                  Habe jetzt überall das Bild hm-steckdose außer bei Gesamt da erscheint kein Bild.
                  //@liv-in-sky Januar 2020 Ver. 12.6.-13:00
                  const dpPrefix = "javascript."+ instance +".";
                  //HIER WIRD PFAD UND FILENAME DEFINIERT
                  const path = "/htmlenergy.html";                   //FIlenamen definieren
                  const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                  let   braucheEinFile=false;                          // bei true wird ein file geschrieben
                  let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                  let   braucheMaterialDesignWidget=true;             // bei true wird ein html-tabelle in einen dp geschrieben - MUSS ANGELEGT WERDEN !!!
                  let   braucheMaterialDesignWidgetTable=true;        // bei true wird ein html-tabelle in einen dp geschrieben - MUSS ANGELEGT WERDEN !!!
                  let dpVIS="javascript.0.Energieanzeige.Tabellen.Energie";         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                  let dpAnzahl="javascript.0.Energieanzeige.Tabellen.AnzahlEnergiemesser";  //WICHTIG datenpunkt erstellen vom typ "number" - bei 0 kein alarm und größer 0 die anzahl der schlechten batterien
                  let dpMaterialWidget="javascript.0.Energieanzeige.Tabellen.EnergyMaterialWidget";            // MATERIALDESIGN List Widget - datenpunkt: zeichenkette
                  let dpMaterialWidgetTable="javascript.0.Energieanzeige.Tabellen.EnergyMaterialWidgetTable";  // MATERIALDESIGN Table Widget - datenpunkt: zeichenkette
                  let pfadBilderMaterialWidget="/vis.0/Haussteuerung2/img/geraete/"  ;                     // PFAD zu den bildern, die in die vis geladen wurden
                  let htmlColorDeviceUeberschrift="#01DFD7" ;            //  Farbe der Geräte Marken  A0C2A0
                  let HTMLbrandSetting="b";                              // style der geräte marken:  möglich b fett; i kursiv; span normal
                  let mitMonatBeforeAnzeige=true;
                  let farbeFehlenderGeräte="#0489B1";                    //warnfarbe für momentan fehlende geräte F6CED8
                  const farbeSchalterON="Aqua";               // farbe des schalters für ON
                  const farbeSchalterOFF="LightSeaGreen";               // farbe des schalters für OFF
                  const farbeMDGesamtG="Aqua";                 // farbe für Material Desogn : "alle Geräte"
                  const farbeMDAlleVirtPow="DodgerBlue"//"LightSeaGreen"          // farbe für Material Desogn : "alle virtPoeer geräte"
                  const farbeMDEinspeisung="Chocolate";                 // farbe für Material Desogn : "Einspeisung"
                  //let mySchedule="  */10 * * * * * ";
                  let kwhPreis=0.2673;
                  // GERÄTE FREISCHALTUNG und SourceAnalytics
                  var pow=false;              var sourceAnalyPow=false;            // für Tasmota Geräte
                  var tuya=false;             var sourceAnalyTuya=false;
                  var hs100=false;            var sourceAnalyHS=false;        //tplink
                  var homematic=true;        var sourceAnalyHM=true;
                  var blitzwolf=false;        var sourceAnalyBlitz=false;
                  var teckin=false;           var sourceAnalyTeck=false;
                  var mihome=false;           var sourceAnalyMihome=false;                                                            //smart-plug
                  var homee=false;            var sourceAnalyHomee=false;
                  var gosundSP1x=false;       var sourceAnalyGo=false;
                  var shelly=false;            var sourceAnalyShelly=false;
                  var zigbee=false;           var sourceAnalyZigbee=false;
                  var fritzdect=false;         var sourceAnalyFritz=true;
                  var meross=false;             var sourceAnalyMeross=false;
                  var virtualPower=false;              //zeigt alle Virt. Power - geräte an
                  var virtualPowerGesamt=false;        // zeigt geamt von virt Power-geräte an
                  var gesamt=true;                                            // Spalte Gesamt am ende der tabelle
                  var symbolOK="✅";     // auch möglich: ="✅"
                  var symbolKO="❌";     //z.b. auch "<font color=\"red\"><b>X</b>" für ein rotes kreuz  oder : ="❌"  ⚪  ⚫ ⭕  🔴 🔵 ⏱ 💀 👍 👎 📑 💲 👀 🔹
                  var symbolWARN="⚠️";    // ="⚠️"
                  var externalOhneInfo=false;  //noch nicht integriert
                  var filterArrAusnahme=["Device SHEM-3#DC4F227646FB#1","Device SHEM-3#DC4F227646FB#1(2)","Device SHEM-3#DC4F227646FB#1(3)","controll-own.0.AAATEST.MyEinspeisungTest"];                    // für Einspeisung - benötigt common.name des devices (wie in der tabellen anzeige)
        // beispiel: var filterArrAusnahme=["Pow Room TV","MyEinspeisungTest"]; Einspeisung über virtPower geht nicht !!!!
                  var scaleWebseite="1";                       // webseitengröße ändern (kein einfluss auf VIS widget) - verkleinern z.b.25% : var scaleWebseite=".75";
                  //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 5
                  var htmlFeld1='Device';       var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
                  var htmlFeld2='Status';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                  var htmlFeld3='Amp';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                  var htmlFeld4='Volt';        var Feld4lAlign="center";                    // überschrift Tabellen Spalte4 und  Ausrichtung left,right or center
                  var htmlFeld5='Power';        var Feld5lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                  var htmlFeld6='Schalter';        var Feld6lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                  var htmlFeld7='';        var Feld7lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                  var htmlFeld8='';        var Feld8lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                  var htmlFeld9='';        var Feld9lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                  var htmlFeld10='';        var Feld10lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                  //ÜBERSCHRIFT ÜBER TABELLE
                  let   htmlUberschrift=true;                           // mit Überschrift über der tabelle
                  let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                  const htmlFeldUeber='Energy Devices';              // Überschrift und Signature
                  const htmlFarbUber="white";                         // Farbe der Überschrift
                  const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                  const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                  //MEHRERE TABELLEN NEBENEINANDER
                  let   mehrfachTabelle=1;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                  const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                  const htmlFarbTableColorUber="white";               // Überschrift in der tabelle - der einzelnen Spalten BDBDBD
                  //ÜBERSCHRIFT SPALTEN
                  const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                  const LinieUnterUeberschrift="2";                   // Linie nur unter Spaltenüberschrift -
                  const farbeLinieUnterUeberschrift="white";
                  const groesseUeberschrift=16;
                  const UeberschriftStyle="normal"                     // möglich "bold"
                  //GANZE TABELLE
                  let abstandZelle="1";
                  let farbeUngeradeZeilen="#1C1C1C"//"#1C1C1C";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                  let farbeGeradeZeilen="black"//"black";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                  let weite="auto";                                     //Weite der Tabelle
                  let zentriert=true;                                   //ganze tabelle zentriert
                  const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                  const htmlSchriftart="Ubuntu-Regular"     //"Jura-DemiBold"   //"RobotoCondensed-Bold"   //"Helvetica";
                  const htmlSchriftgroesse="14px";
                  //FELDER UND RAHMEN
                  let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                  const htmlFarbFelderschrift="#FFFFFF";                  // SchriftFarbe der Felder
                  const htmlFarbFelderschrift2="#FFFFFF";                 // SchriftFarbe der Felder für jede 2te Tabelle
                  const htmlFarbTableColorGradient1="black";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                  const htmlFarbTableColorGradient2="black";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                  const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                  let htmlRahmenLinien="cols";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                  const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                  // HIER NICHTS  ÄNDERN
                  let borderHelpBottum;
                  let borderHelpRight;
                  let htmlcenterHelp;
                  let htmlcenterHelp2;
                  if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                  if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                  if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                  if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                  zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                  zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                  const htmlZentriert='<center>'
                  const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                     "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                     " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                     " html {transform: scale("+scaleWebseite+");}"+
                                    // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                     " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                     " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                     "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                     " </style></head><body> <div>";
                  //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                  const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                        "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                  const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\" style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
                  const htmlTabUeber3="</tr>";
                  //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 5
                  var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td><td align="+Feld4lAlign+
                                    ">&ensp;"+htmlFeld4+"&ensp;</td><td  align="+Feld5lAlign+">&ensp;"+htmlFeld5+"&ensp;</td><td  align="+Feld6lAlign+">&ensp;"+htmlFeld6+"&ensp;</td><td  align="+Feld7lAlign+">&ensp;"+htmlFeld7+"&ensp;</td><td  align="+Feld8lAlign+">&ensp;"+htmlFeld8+
                                    "&ensp;</td><td  align="+Feld9lAlign+">&ensp;"+htmlFeld9+"&ensp;</td><td  align="+Feld10lAlign+">&ensp;"+htmlFeld10+"&ensp;</td>";
                  var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+
                                     "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld4+
                                     "&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld5+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld6+"&ensp;</td><td align="+Feld7lAlign+
                                     " style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld7+"&ensp;</td><td align="+Feld8lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld8+"&ensp;</td><td  align="+Feld9lAlign+">&ensp;"+htmlFeld9+"&ensp;</td><td  align="+Feld10lAlign+">&ensp;"+htmlFeld10+"&ensp;</td>";
                  let triggerBySonoffSwitch=false;
                  var anzahl;
                  var AkkuAlarm=[];
                  var htmlOut="";
                  var mix;
                  var counter;
                  var arrTrigger=[];
                  var rootCounter=false;
                  var val1; var val2; var val0; var val3; var val4; var val5; var val6; var val7; var val8; var val9;; var valStatus;
                  var json1; var json2; var json3; var json4; var json5; var json6; var json7;var json8; var json9; var json10;
                  var htmlTabUeber="";
                  var tagErinnern=false;
                  var monatErinnern=false;
                  var anzahlStellen=3;
                  var gesamtNow=0;
                  var gesamtMonth=0;
                  var gesamtMoneyTod=0;
                  var gesamtMoneyMon=0;
                  var gesamtMonthBefore=0;
                  var gesamtMonthMoneyBefore=0;
                  var filterArrAusnahmeHelp=[];
                  var lastID=""; let shellyNumber=1;//wegen shelly 2-port
                  var myJsonWidget=[];
                  var myJsonWidget2=[];
                  var valMarkeDevice="";
                  var valSwitchDevice;
                  mehrfachTabelle=1;
                  var fehlerMin=0;
                  function writeHTML(){
                  gesamtNow=0;
                  gesamtMonth=0;
                  gesamtMoneyTod=0;
                  gesamtMoneyMon=0;
                  var nameDevice="";
                  anzahl=0;
                  htmlOut="";
                  counter=-1;
                  htmlTabUeber="";
                  switch (mehrfachTabelle) {
                     case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                     case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                     case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2+htmlTabUeber2+htmlTabUeber3; break;
                     case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                  if (!UeberschriftSpalten) {htmlTabUeber=""}
                  //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                  //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2,val3,val4!!!------------------------------------------------------------
                  if (virtualPower){
                  counter=0
                        counter++//=0;
                        val0=""; val1=""; val2="";val3="";val4="";val5="";val6="";val7="";val8="";val9="";
                        tabelleBind();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">VirtualPower</"+HTMLbrandSetting+">"; val1=""; val2="";val3="";val4="";
                        val5="<font color=\""+htmlColorDeviceUeberschrift+"\">";
                        val6="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">kWh Now<"+HTMLbrandSetting+">";
                        val7="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">kWh Monat<"+HTMLbrandSetting+">";
                        val8="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Preis Now<"+HTMLbrandSetting+">";
                        val9="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Preis Monat<"+HTMLbrandSetting+">";
                        tabelleBind();
                      var arrVirtDev=(getState("virtualpowermeter.0.group_script.info").val).replace(/;$/,"").split(';');
                     for (var i=0;i<arrVirtDev.length;i++) {
                           anzahl++;
                            counter++;
                        var val0help=arrVirtDev[i].replace(/(.+)\..+$/,"$1");
                       val0=(getObject(val0help+".Script_Power").common.name).replace(/(.+)\..+/,"$1")
                        val1=true;
                         val2=" - "; val3=" - ";
                         val4=getState(val0help+".Script_Power").val+" W"
                         let val7_1=getState(arrVirtDev[i]).val;
                           val7_1 ? val5=(" <font color=\""+farbeSchalterON+"\"> ")+"ON</font>" : val5=(" <font color=\""+farbeSchalterOFF+"\"> ")+"OFF</font>";
                        var sourcerhelper=(val0help+".Script_Total").replace(/\./g,"__");
                             val6=" - "; val7=" - "; val8=" - "; val9=" - ";
                           valMarkeDevice="virtualpowermeterk"
                          valSwitchDevice=val7_1;
                             //log(val0)
                            if (virtualPower) {brechneEnergy(val0,getState(val0help+".Script_Power").val);
                          if (rootCounter){
                              sammleDaten();
                              berechneGesamt()
                                 zeigeVal1();
                       if (!filterArrAusnahme.includes(val0)) {
                         //  val0=val0.replace(/\.STATE/,"")
                           tabelleBind();
                          } else{let help=[val0,val1,val2,val3,val4,val5,val6,val7,val8,val9]; filterArrAusnahmeHelp.push(help);}
                  } //ende virtual
                   if (virtualPowerGesamt){
                  counter=0
                        counter++//=0;
                        tabelleBind();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">VirtualPower Gesamt</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                        val6="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">kWh Now<"+HTMLbrandSetting+"></font>";
                        val7="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">kWh Monat<"+HTMLbrandSetting+"></font>";
                        val8="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Preis Now<"+HTMLbrandSetting+"></font>";
                        val9="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Preis Monat<"+HTMLbrandSetting+"></font>";
                        tabelleBind();
                    // keine schleife nötig
                           anzahl++;
                            counter++;
                        val0="Gesamt"
                        val1=true;
                         val4= getState("virtualpowermeter.0.group_script.Virtual_Energy_Power_group_script").val+" W";
                         val5=" - ";
                         valMarkeDevice="infok"
                            if (virtualPowerGesamt) {brechneEnergy(val0,getState("virtualpowermeter.0.group_script.Virtual_Energy_Power_group_script").val);
                          if (rootCounter){
                              sammleDaten();
                          if(!virtualPower) berechneGesamt()} }
                          zeigeVal1();
                           tabelleBind();
                  } //ende virtual
                  if (pow){
                      counter=0
                        counter++//=0;
                        tabelleBind();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Tasmota</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                        val5="<font color=\""+htmlColorDeviceUeberschrift+"\"></font>";
                        tabelleBind();
                   $('sonoff.*.*.INFO.Module').each(function(id, i) {
                        if (getState(id).val=="Sonoff Pow" || getState(id).val=="Sonoff Pow R2" || getState(id).val=="Shelly 2.5") {
                           // log (id)
                           anzahl++;
                          var ida = id.split('.');
                            counter++;
                            val1=getState(id.replace("INFO.Module","alive")).val;
                            val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ;
                            val3=getState(id.replace("INFO.Module","ENERGY_Voltage")).val.toString()+" V";
                            if (getState(id).val=="Shelly 2.5") {
                             val4=(getState(id.replace("INFO.Module","ENERGY_ApparentPower_0")).val + getState(id.replace("INFO.Module","ENERGY_ApparentPower_1")).val).toString()+" W"
                             val2=(((getState(id.replace("INFO.Module","ENERGY_Current_0")).val)*1000)+((getState(id.replace("INFO.Module","ENERGY_Current_1")).val)*1000)).toString()+ " mA";
                             let val7_1=getState(id.replace("INFO.Module","POWER1")).val;
                            let val5_1;
                            let val8_1=getState(id.replace("INFO.Module","POWER2")).val;
                            val8_1 ? val5_1=(" <font color=\""+farbeSchalterON+"\"> ")+"ON</font>" : val5_1=(" <font color=\""+farbeSchalterOFF+"\"> ")+"OFF</font>";
                            val5 = val5 + " " + val5_1;
                            valMarkeDevice="sonoffk"
                         //  if (sourceAnalyPow) {brechneEnergy(val0,getState(id.replace("INFO.Module","ENERGY_Power")).val);
                             if (sourceAnalyPow) {brechneEnergy(val0,(getState(id.replace("INFO.Module","ENERGY_ApparentPower_0")).val + getState(id.replace("INFO.Module","ENERGY_ApparentPower_1")).val));
                          if (rootCounter){
                              sammleDaten()
                              berechneGesamt()
                            } else {
                            val4=getState(id.replace("INFO.Module","ENERGY_Power")).val.toString()+ " W"
                            val2=((getState(id.replace("INFO.Module","ENERGY_Current")).val)*1000).toString()+ " mA";
                            let val7_1=getState(id.replace("INFO.Module","POWER")).val;
                          if (rootCounter){
                              sammleDaten()
                              berechneGesamt()
                                }  // else von shelly 2.5
                        zeigeVal1();
                           tabelleBind();
                  } //ende fritzdect
                   if (teckin){
                  counter=0
                        counter++//=0;
                        tabelleBind();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Teckin</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                        tabelleBind();
                        if (getState(id).val=="Teckin") {
                           // log (id)
                           anzahl++;
                            counter++;
                            valMarkeDevice="techink"
                            if (sourceAnalyTeck) {brechneEnergy(val0,getState(id.replace("INFO.Module","ENERGY_Power")).val)
                          if (rootCounter){
                              sammleDaten();
                             berechneGesamt()
                        zeigeVal1();
                           tabelleBind();
                  } //ende fritzdect
                  if (blitzwolf){
                   counter=0
                       counter++//=0;
                       tabelleBind();
                       counter++//=0;
                       val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">BlitzWolf SHP</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                       tabelleBind();
                       if (getState(id).val=="BlitzWolf SHP"  || getState(id).val=="BlitzWolf SHP7" || getState(id).val=="BlitzWolf SHP8" || getState(id).val=="BlitzWolf SHP6") {
                          // log (id)
                          anzahl++;
                           counter++;
                           val2=getState(id.replace("INFO.Module","ENERGY_Current")).val.toFixed(2)+ " A";
                           let val5_1=getState(id.replace("INFO.Module","POWER")).val;
                           val5_1 ? val5=(" <font color=\""+farbeSchalterON+"\"> ")+"ON</font>" : val5=(" <font color=\""+farbeSchalterOFF+"\"> ")+"OFF</font>";
                           var val7_2; var val8_2;
                           if ( getState(id).val=="BlitzWolf SHP7") {
                           val7_1 ? val7_2=(" <font color=\""+farbeSchalterON+"\"> ")+"ON</font>" : val7_2=(" <font color=\""+farbeSchalterOFF+"\"> ")+"OFF</font>";
                           val8_1 ? val8_2=(" <font color=\""+farbeSchalterON+"\"> ")+"ON</font>" : val8_2=(" <font color=\""+farbeSchalterOFF+"\"> ")+"OFF</font>";
                           val5=val7_2+" "+val8_2;
                            valMarkeDevice="blitzwolfk"
                             if (sourceAnalyBlitz) {brechneEnergy(val0,getState(id.replace("INFO.Module","ENERGY_Power")).val)
                          if (rootCounter){
                              sammleDaten();
                           berechneGesamt()
                        zeigeVal1();
                           tabelleBind();
                  } //ende fritzdect
                   if (gosundSP1x){
                  counter=0
                        counter++//=0;
                        val0=val0=""; val1=""; val2="";val3="";val4="";val5="";val6="";val7="";val8="";val9="";
                        tabelleBind();
                        counter++//=0;
                       val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Gosund</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                        tabelleBind();
                        if (getState(id).val.includes("Gosund SP1") || getState(id).val.includes("SP11") || getState(id).val.includes("Gosund SP111") || getState(id).val.includes("SP112")) {
                           // log (id)
                           anzahl++;
                            counter++;
                            if (getState(id).val=="SP112") {
                             else{
                            val7_1 ? val5=(" <font color=\""+farbeSchalterON+"\"> ")+"ON</font>" : val5=(" <font color=\""+farbeSchalterOFF+"\"> ")+"OFF</font>";}
                            valMarkeDevice="gosundk"
                            if (sourceAnalyGo) {brechneEnergy(val0,getState(id.replace("INFO.Module","ENERGY_Power")).val)
                          if (rootCounter){
                              sammleDaten();
                              berechneGesamt()
                        zeigeVal1();
                           tabelleBind();
                  } //ende fritzdect
                   if (homee){
                  counter=0
                        counter++//=0;
                        tabelleBind();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Homee</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                        tabelleBind();
                   $("homee.*.*.CurrentEnergyUse*").each(function(id, i) {
                        var arrHomee=[]
                              $(ida[0]+"."+ida[1]+"."+ida[2]+".*" ).each(function(id, i) {
                                arrHomee.push(id)
                           anzahl++;
                            counter++;
                            val1=true;
                            //var val2_1;var val3_1;
                            for (var i=0;i<arrHomee.length;i++){if(arrHomee[i].includes("Current-"))  val2=(getState(arrHomee[i]).val)*1000 +" mA"}
                            for (var i=0;i<arrHomee.length;i++){if(arrHomee[i].includes("Voltage"))  val3=(getState(arrHomee[i]).val) +" V"}
                            val4=getState(id).val.toString()+" W";
                            var val4help=getState(id).val
                            var val5_1;
                            for (var i=0;i<arrHomee.length;i++){if(arrHomee[i].includes("OnOff"))  val5_1=getState(arrHomee[i]).val}
                             if (!val5_1) {val4="0 W"; val4help=0;/*val1=true*/}
                             valMarkeDevice="homeek"
                       //  val1=true
                                        if (sourceAnalyHomee) {brechneEnergy(val0,val4help) //Sonderfall da kein status am gerät sondern doppelbelegung
                          if (rootCounter){
                              sammleDaten();
                              berechneGesamt()
                        zeigeVal1();
                           tabelleBind();
                  } //ende fritzdect
                   if (shelly){
                  counter=0
                        counter++//=0;
                        tabelleBind();
                        tabelleAusbessern();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Shelly</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                        tabelleBind();
                  lastID="";
                   $('shelly.*.*.*.Power').each(function(id, i) {
                           anzahl++;
                            counter++;
                            val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ; //log(val0+"---" +lastID)
                            if (val0 == lastID) {lastID=val0; shellyNumber++; val0=val0+"("+shellyNumber.toString()+")"} else{lastID=val0; shellyNumber=1}
                            val1=getState(ida[0]+"."+ida[1]+"."+ida[2]+".online").val
                            if(existsState(id.replace("INFO.Module","ENERGY_Current"))) {
                            val2=((getState(id.replace("INFO.Module","ENERGY_Current")).val)).toString()+ " A"; }
                             if(existsState(id.replace("INFO.Module","ENERGY_Voltage"))) {
                            val3=getState(id.replace("INFO.Module","ENERGY_Voltage")).val.toString()+" V"; }
                            var val5_1;
                            if (existsState(id.replace("Power","Switch"))) {val5_1= getState(id.replace("Power","Switch")).val;
                               } else {val5_1= getState(ida[0]+"."+ida[1]+"."+ida[2]+".Relay0.Switch").val;  }
                            val5_1 ? val5=(" <font color=\""+farbeSchalterON+"\"> ")+"ON</font>" : val5=(" <font color=\""+farbeSchalterON+"\"> ")+"OFF</font>";
                             valMarkeDevice="shellyk"
                            if (sourceAnalyShelly) {brechneEnergy(val0,getState(id).val)
                               if (rootCounter){
                                   sammleDaten();
                              berechneGesamt()
                        zeigeVal1();
                           tabelleBind();
                  } //ende fritzdect
                   if (meross){
                  counter=0
                        counter++//=0;
                        tabelleBind();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Meross</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                        tabelleBind();
                   $('meross.*.*.0-power').each(function(id, i) {
                           anzahl++;
                            counter++;
                            val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ; //log(val0)
                            var val5_1= getState(id.replace("0-power","0")).val;
                             valMarkeDevice="merossk"
                            if (sourceAnalyMeross) {brechneEnergy(val0,getState(id).val)
                               if (rootCounter){
                                   sammleDaten();
                              berechneGesamt()
                        zeigeVal1();
                           tabelleBind();
                  } //ende fritzdect
                    if (fritzdect){
                  counter=0
                        counter++//=0;
                        tabelleBind();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">FritzDect</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                        tabelleBind();
                   $('fritzdect.*.*.power').each(function(id, i) {
                           anzahl++;
                            counter++;
                            val1=getState(id.replace("power","present")).val;
                            val2=" - ";
                            if (existsState(id.replace("power","voltage"))) {val3=Math.round(getState(id.replace("power","voltage")).val).toString()+" V";} else {val3=" - "};
                            if (existsState(id.replace("power","voltage"))) val2=((getState(id).val)/(Math.round(getState(id.replace("power","voltage")).val))*1000).toFixed(0)+" mA"
                            var val5_1= getState(id.replace("Power","Switch")).val;
                             valMarkeDevice="fritzk"
                             if (val0=="FritzDect-PC Stübchen") valMarkeDevice="pcstuebchen"
                             if (val0=="FritzDect-Sessel Leselampe") valMarkeDevice="sesselleselampe"
                            if (sourceAnalyFritz) {brechneEnergy(val0,getState(id).val)
                               if (rootCounter){
                                   sammleDaten();
                              berechneGesamt()
                        zeigeVal1();
                           tabelleBind();
                  } //ende fritzdect
                  if (zigbee){
                  counter=0
                        counter++//=0;
                        tabelleBind();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Zigbee</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                        tabelleBind();
                   $('zigbee.*.*.load_power').each(function(id, i) {
                           // log (id)
                           anzahl++;
                            counter++;
                            val1=getState(ida[0]+"."+ida[1]+"."+ida[2]+".available").val
                            var val5_1= getState(id.replace("load_power","state")).val;
                             valMarkeDevice="zigbeek"
                                        if (sourceAnalyZigbee) {brechneEnergy(val0,getState(id).val)
                               if (rootCounter){
                                   sammleDaten();
                              berechneGesamt()
                        zeigeVal1();
                           tabelleBind();
                  } //ende fritzdect
                   if (mihome){
                  counter=0
                        counter++//=0;
                        tabelleBind();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Mihome</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                        tabelleBind();
                   $('mihome.*.devices.*.load_power').each(function(id, i) {
                           // log (id)
                           anzahl++;
                            counter++;
                            val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]).common.name ; //log(val0)
                            val1=true;
                       valMarkeDevice="xiaomik"
                                                   if (sourceAnalyMihome) {brechneEnergy(val0,getState(id).val)
                          if (rootCounter){
                              sammleDaten();
                              berechneGesamt()
                        zeigeVal1();
                           tabelleBind();
                  } //ende fritzdect
                   if (hs100){
                  counter=0
                        counter++//=0;
                        tabelleBind();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">HS100</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                        tabelleBind();
                     //   counter=-1
                   $('hs100.*.*.totalNow').each(function(id, i) {
                           // log (id)
                           anzahl++;
                            counter++;
                            var valVersion=getState(id.replace("totalNow","hw_ver")).val;
                            var val1_1=Date.parse(getState(id.replace("totalNow","last_update")).val);
                            if (parseInt((new Date().getTime())) - val1_1 < 120000) {val1=true} else {val1=false;}  // log(val1.toString())
                            val0=getObject(id).common.name ;
                          // log("---------"+val0)
                            var val4_1=getState(id.replace("totalNow","power")).val.toString();
                            val4=val4_1.substr(0, 4) + " W";            //getState(id.replace("totalNow","power")).val + " W"     ;    // log (val4)       //.substring(0,4)
                            var val2_1=getState(id.replace("totalNow","current")).val.toString();
                            if(valVersion=="1.0")  {val2=val2_1.substr(0, 5) + " mA";} else {val2=val2_1+ " mA";}
                            var val3_1=getState(id.replace("totalNow","voltage")).val.toString();
                            val3=val3_1.substring(0, 3)+" V";
                            var val5_1= getState(id.replace("totalNow","state")).val;
                            val6=" - ";
                            val7=" - ";
                            val8=" - ";
                            val9=" - ";
                            valMarkeDevice="tplinkk"
                          if (sourceAnalyHS) {brechneEnergy(val0,parseFloat(getState(id.replace("totalNow","power")).val))
                          if (rootCounter){
                              sammleDaten();
                              berechneGesamt()
                        zeigeVal1();
                           tabelleBind();
                  } //ende fritzdect
                   if (homematic){
                  counter=0
                        counter++//=0;
                        tabelleBind();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Homematic</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                        tabelleBind();
                   $('hm-rpc.*.*.*.ENERGY_COUNTER').each(function(id, i) {
                               var arrFilt=[];
                            $(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]+".*").each(function(id, i) {   // kontrolliere ob OPERATING_VOLTAGE vorhanden
                                var idc = id.split('.');
                             arrFilt.push(idc[4])
                          if (arrFilt.includes("VOLTAGE")&& arrFilt.includes("POWER") && arrFilt.includes("CURRENT")) {
                           anzahl++;
                            var stateIdHM=ida[3].toString(); //log(stateIdHM+" -- " +id)
                            counter++;
                            val1=!getState(ida[0]+"."+ida[1]+"."+ida[2]+"."+"0"+".UNREACH").val   //getState(id.replace("ENERGY_COUNTER","STATE")).val;
                            val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ;  //val0=getObject(id).common.name ;
                            val4=getState(id.replace("ENERGY_COUNTER","POWER")).val+ " W"     ;     //log (val4)       //.substring(0,4)
                            if (arrFilt.includes("CURRENT")) {val2=getState(id.replace("ENERGY_COUNTER","CURRENT")).val.toFixed(0)+ " mA";} else {val2="-"}
                            if (arrFilt.includes("VOLTAGE")) {val3=getState(id.replace("ENERGY_COUNTER","VOLTAGE")).val.toFixed(0)+" V";}  else {val3="-"}
                            if (stateIdHM=="6") {
                                var val5_1=getState(ida[0]+"."+ida[1]+"."+ida[2]+"."+"2"+".STATE").val;
                                 if(val5_1) { val5=(" <font color=\""+farbeSchalterON+"\"> ")+"ON</font>"} else { val5=(" <font color=\""+farbeSchalterOFF+"\"> ")+"OFF</font>";}}
                                  else { //val5="-"}
                                       if (stateIdHM.match("2")) {var val5_1=getState(ida[0]+"."+ida[1]+"."+ida[2]+"."+"1"+".STATE").val ; val5_1 ? val5=(" <font color=\""+farbeSchalterON+"\"> ")+"ON" : val5=(" <font color=\""+farbeSchalterOFF+"\"> ")+"OFF";} else {val5="-"}}
                             valMarkeDevice="hm-steckdose"
                             if (val0=="Geschirrspüler") valMarkeDevice="geschirrspueler"
                             if (val0=="Waschmaschine") valMarkeDevice="waschmaschine"
                          if (sourceAnalyHM) {brechneEnergy(val0,getState(id.replace("ENERGY_COUNTER","POWER")).val)
                          if (rootCounter){
                          sammleDaten();
                              berechneGesamt()
                        zeigeVal1();
                           tabelleBind();
                  } //ende fritzdect
                   if (tuya){
                  counter=0
                        counter++//=0;
                        tabelleBind();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Tuya</"+HTMLbrandSetting+"></font>"; val1=""; val2="";val3="";val4="";
                        tabelleBind();
                   $('tuya.*.*').each(function(id, i) {
                    //  var arrFilt=[];
                    //   var idb;
                      var checker=false;
                      var checkCur=false;
                      var checkVol=false;
                      var checkPow=false;
                      var checkOnline=false;
                      var val5_1=false;  var val5_2=false;
                      //log(getObject(id).common.name)
                     if (getObject(id).common.name == "cur_power")  {checkCur=true; val4=getState(id).val.toString()+" W"; // log(val4.toString())
                              // log(id)
                            $(ida[0]+"."+ida[1]+"."+ida[2]+".*").each(function(id, i) {
                                if (getObject(id).common.name == "cur_voltage")  {checkVol=true; val3=getState(id).val.toString()+" V"; }//log(val3.toString())}
                                 if (getObject(id).common.name == "cur_current")  {checkPow=true; val2=getState(id).val.toString()+" mA"; }//log(val2.toString())}
                                  if (getObject(id).common.name.includes("online"))  {checkOnline=true; val1=getState(id).val; }//log(val1.toString())}
                                 val5_2=false;
                                  if (getObject(id).common.name ==("power"))  { val5_2=true; val5_1=getState(id).val; }//log(val5_1.toString())}
                     if (checkCur && checkPow && checkVol && checkOnline) checker=true;
                     if (checker) {
                  //log (id)
                           anzahl++;
                            var stateIdHM=ida[3]; //log(stateIdHM)
                            counter++;
                           if(val5_2) {if (val5_1)  {val5=(" <font color=\""+farbeSchalterON+"\"> ")+"ON</font>"} else { val5=(" <font color=\""+farbeSchalterOFF+"\"> ")+"OFF</font>";}}
                              else {if (val1) {val5=" - "} else { val5=(" <font color=\""+farbeSchalterOFF+"\"> ")+" - ";}}
                             valMarkeDevice="tuyak"
                             if (sourceAnalyTuya) {brechneEnergy(val0,val4)
                          if (rootCounter){
                              sammleDaten();
                              berechneGesamt()
                        zeigeVal1();
                           tabelleBind();
                  } //ende fritzdect
                  if (gesamt){
                      counter=0
                        counter++//=0;
                        tabelleBind();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">GESAMT</"+HTMLbrandSetting+"></font>";
                        val1="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">First Date</"+HTMLbrandSetting+"></font>";
                        val2="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">First Time</"+HTMLbrandSetting+"></font>";
                        val3="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">ct pro kWh<"+HTMLbrandSetting+"></font>";
                        val4="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Anzahl<"+HTMLbrandSetting+"></font>";
                        val5="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Update<"+HTMLbrandSetting+"></font>";
                        tabelleBind();
                        val0="alle Geräte";val1="";val2="";
                        if(rootCounter) val1=formatDate(getState(dpPrefix+"Tabelle_EnergieRechnung.Collection.FirstRun").val, "TT.MM.YY");
                        if(rootCounter) val2=formatDate(getState(dpPrefix+"Tabelle_EnergieRechnung.Collection.FirstRun").val, "SS:mm:ss");
                        val3=kwhPreis+" ct";
                        val4=anzahl.toString();
                        if (virtualPower && !virtualPowerGesamt)   val4=anzahl.toString();
                        if (!virtualPower && virtualPowerGesamt)   val4=anzahl.toString()+"++";
                        if (virtualPower && virtualPowerGesamt)   val4=(anzahl-1).toString();
                        val5=formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");;
                       let anzeigeNullerG=3; let anzeigeNullerG2=2;let anzeigeNullerG3=3; let anzeigeNullerG4=3;
                        if(gesamtMonth==0) anzeigeNullerG=0;
                        if(gesamtMonthBefore==0) anzeigeNullerG3=0
                        if(gesamtMonthMoneyBefore==0) anzeigeNullerG2=0;
                        if(gesamtNow==0) anzeigeNullerG4=0;
                        val6=(gesamtNow.toFixed(anzeigeNullerG4)+" kWh");
                        if (!mitMonatBeforeAnzeige) {val7=(gesamtMonth.toFixed(anzeigeNullerG)+" kWh");} else{val7=gesamtMonth.toFixed(anzeigeNullerG)+" ("+gesamtMonthBefore.toFixed(anzeigeNullerG3)+") kWh";}
                        val8=(gesamtMoneyTod.toFixed(2)+" €"); // log(val8)
                        if (!mitMonatBeforeAnzeige) {val9=(gesamtMoneyMon.toFixed(2)+" €");} else {val9=gesamtMoneyMon.toFixed(2)+" ("+gesamtMonthMoneyBefore.toFixed(anzeigeNullerG2)+") €";}
                         tabelleBind();
                     if ( braucheMaterialDesignWidgetTable || braucheMaterialDesignWidget ) {
                  let valkNow=val6.replace("kWh","");;
                  let valkM=val7.replace(" kWh","");;
                  let valEuNow=val8.replace(" €","");;
                  let valEuM=val9.replace(" €","");
                  let valMBefore=" - ";
                  let valKostenBefore=" - ";
                  if(mitMonatBeforeAnzeige){
                  //  valMBefore=getState(dpPrefix+"Tabelle_EnergieRechnung."+"Gesamt"+".MonBeforekWh").val
                  //  valKostenBefore=(Math.round((getState(dpPrefix+"Tabelle_EnergieRechnung."+"Gesamt"+".MonBeforekWh").val)*kwhPreis*100)/100).toString()
                    valMBefore=val7.replace(/.+\((.+)\).+/,"$1")
                    valKostenBefore=val9.replace(/.+\((.+)\).+/,"$1")
                    valkM=valkM.replace(/\(.+\)/,"");
                    valEuM=valEuM.replace(/\(.+\)/,"");
                  makeJsonWidget(val0+"</font>",symbolOK," - "," - "," - "," - ",valkNow,valkM,valEuNow,valEuM,"infok","",valMBefore,valKostenBefore)
                  if (filterArrAusnahmeHelp.length>0) {
                      counter=0
                        counter++//=0;
                        tabelleBind();
                        counter++//=0;
                        val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">EINSPEISUNG</"+HTMLbrandSetting+"></font>";
                        val1="";
                        val2="";
                        val3="";
                        val4="";
                        val5="";
                        tabelleBind();
                        for (var i=0; i<filterArrAusnahmeHelp.length;i++){
                             counter++
                                 val0=filterArrAusnahmeHelp[i][0] ;
                                 val1=filterArrAusnahmeHelp[i][1] ;
                                 val2=filterArrAusnahmeHelp[i][2] ;
                                 val3=filterArrAusnahmeHelp[i][3] ;
                                 val4=filterArrAusnahmeHelp[i][4] ;
                                 val5=filterArrAusnahmeHelp[i][5] ;
                                 val6=filterArrAusnahmeHelp[i][6] ;
                                 val7=filterArrAusnahmeHelp[i][7] ;
                                 val8=filterArrAusnahmeHelp[i][8] ;
                                 val9=filterArrAusnahmeHelp[i][9] ;
                              tabelleBind();
                  //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                        tabelleFinish();
                        if (virtualPower && virtualPowerGesamt)   anzahl=anzahl-1;
                            setState(dpAnzahl,anzahl);
                      rootCounter=true;
                       tagErinnern=false;    monatErinnern=false;
                  } // function ende
                  //MAIN:
                  schedule(' * * * * * ',  function () {
                   writeHTML();
                   if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                   writeHTML();
                     				 function tabelleBind(){
                           case 1:   if(counter%2==0){ htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+
        ">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+
        Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+
        Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td></tr>"; break;}
                           else                      { htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+
        ">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+
                                                               "&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+
                          case 2:  if(counter%2==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+
                                                     "&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>"; }
                                                else {htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td></tr>";} break;
                          case 3: if(counter%3==0 )  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>"; }
                                                else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td></tr>";}
                                                           } break;
                          case 4: if(counter%4==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>"; }
                                                    else {if(counter%2==1 )  { htmlOut = htmlOut+"<td  align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>";}
        else    {if(counter%2==1 && counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td></tr>";}
        else    {htmlOut  = htmlOut+"<td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td>&ensp;"+val1+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td><td align="+Feld9lAlign+">&ensp;"+val8+"&ensp;</td><td align="+Feld10lAlign+">&ensp;"+val9+"&ensp;</td>";}}
                                                           } break;
                       } //switch ende
                  function tabelleAusbessern() {
                           case 1:    break;
                           case 2:    mix=Math.abs(((counter+1)%2)-mehrfachTabelle);
                                      if(mix==1)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                      break;
                           case 3:    mix =Math.abs(((counter+1)%3)-mehrfachTabelle);
                                      if(mix==2)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                      break;
                           case 4:    mix=Math.abs(((counter+1)%4)-mehrfachTabelle);
                                      if(mix==3)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                      break; }
                  function tabelleFinish() {
                        // tabelle fertigstellen
                           case 1:    break;
                                      break;
                                      break;
                                      break; }
                                      var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                         var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                          if (!htmlSignature) htmlUnter="";
                             var htmlOutVIS="";
                              if (htmlUberschrift)
                                  { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                                } else {
                                 zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
                  // log("bin raus aus tabelleBind");
                             if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                   var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                   var htmlEnd="</table>"+htmlUnter+"</div></body>";
                   //mit oder ohne überschrift - zentriert oder links
                  htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                   //log(htmlOut);
                    if (braucheMaterialDesignWidget) {
                         setState(dpMaterialWidget,JSON.stringify(myJsonWidget2));
                         myJsonWidget2=[];
                  if (braucheMaterialDesignWidgetTable) {
                    setState(dpMaterialWidgetTable,JSON.stringify(myJsonWidget));
                       myJsonWidget=[];
                  function brechneEnergy( nameDevice,watt) {
                      let minArrData=0;
                      let monArrData=0;
                       let helpKwhMonth=0;
                      createDp(nameDevice);
                      if (rootCounter) {
                     //  log(typeof fehlerMin)
                      var minhelper=0;
                      var geamthelp=0;
                      var monhelper=0;
                      minArrData=getState(dpPrefix+"Tabelle_EnergieRechnung."+nameDevice+".todaykWh").val   //holt existierende min werte
                      if (val1) minArrData=minArrData+((parseFloat(watt))/60)/1000;
                      minArrData=(Math.round(minArrData*10000)/10000);
                      setState(dpPrefix+"Tabelle_EnergieRechnung."+nameDevice+".todaykWh",minArrData );
                      let helpKwhToday=(getState(dpPrefix+"Tabelle_EnergieRechnung.Collection."+nameDevice+".mins").val)+1
                      setState(dpPrefix+"Tabelle_EnergieRechnung.Collection."+nameDevice+".mins",helpKwhToday) // insgesamte minuten
                         if (tagErinnern && !monatErinnern ){
                       let monArrData=getState(dpPrefix+"Tabelle_EnergieRechnung."+nameDevice+".MonGeskWh").val     //.split(",");
                       monArrData=monArrData+minArrData
                       monArrData=(Math.round(monArrData*10000)/10000);
                        log("bin in Tag ende  "+monArrData)
                       setState(dpPrefix+"Tabelle_EnergieRechnung."+nameDevice+".MonGeskWh",monArrData ); //setzt monatsarray neu
                       setState(dpPrefix+"Tabelle_EnergieRechnung."+nameDevice+".todaykWh",0 );//reset tag
                       setState(dpPrefix+"Tabelle_EnergieRechnung.Collection."+nameDevice+".mins",0) // reset minuten pro tag
                       helpKwhMonth=(getState(dpPrefix+"Tabelle_EnergieRechnung.Collection."+nameDevice+".tage").val)+1 //setze tage dees monats
                       setState(dpPrefix+"Tabelle_EnergieRechnung.Collection."+nameDevice+".tage",helpKwhMonth) // insgesamte minuten
                     if (monatErinnern){
                         log("bin in monat ende "+monArrData );
                         setState(dpPrefix+"Tabelle_EnergieRechnung."+nameDevice+".MonBeforekWh", monArrData); //setze monatges auf monatbefore
                         setState(dpPrefix+"Tabelle_EnergieRechnung."+nameDevice+".MonGeskWh",0 ); //setzt monatsarray neu
                         setState(dpPrefix+"Tabelle_EnergieRechnung."+nameDevice+".todaykWh",0 );  //setzt tagessarray neu
                         setState(dpPrefix+"Tabelle_EnergieRechnung.Collection."+nameDevice+".tage",0)
                   //FÜR ANZREIGE
                     geamthelp=minArrData+(getState(dpPrefix+"Tabelle_EnergieRechnung."+nameDevice+".MonGeskWh").val);
                     setState(dpPrefix+"Tabelle_EnergieRechnung."+nameDevice+".monkWh", Math.round(geamthelp*1000)/1000);
                  function createDp(nameDevice){
                   createState(dpPrefix+"Tabelle_EnergieRechnung."+nameDevice+".todaykWh", 0,  { name: 'todaykWh Heute', desc: 'seit 00:00', type: 'number',   role: '',read: true, write: true });
                   createState(dpPrefix+"Tabelle_EnergieRechnung."+nameDevice+".monkWh", 0,  { name: 'Monat plus Minuten Anzeige', desc: 'monkWh Anzeige', type: 'number',   role: '',read: true, write: true  });
                   createState(dpPrefix+"Tabelle_EnergieRechnung."+nameDevice+".MonGeskWh", 0,  { name: 'Tage des Monats GESAMT', desc: 'seit 01.xx', type: 'number',   role: '',read: true, write: true  });
                   createState(dpPrefix+"Tabelle_EnergieRechnung."+nameDevice+".MonBeforekWh", 0,  { name: 'monkWh', desc: 'monkWh', type: 'number',   role: '',read: true, write: true  });
                   createState(dpPrefix+"Tabelle_EnergieRechnung.Collection."+nameDevice+".mins",0,   { name: 'daykWh', desc: 'daykWh', type: 'number',   role: '',read: true, write: true });
                   createState(dpPrefix+"Tabelle_EnergieRechnung.Collection."+nameDevice+".tage", 0,  { name: 'daykWh', desc: 'daykWh', type: 'number',   role: '',read: true, write: true });
                   createState(dpPrefix+"Tabelle_EnergieRechnung.Collection.FirstRun", parseFloat((new Date().getTime())),  { name: 'FirstRun', desc: 'FirstRun', type: 'number',   role: '',read: true, write: true });
                      schedule("0 0 * * *",  function () {
                     tagErinnern=true;
                     if ( formatDate(getDateObject((new Date().getTime())), "TT").toString() =="01" )
                          {monatErinnern=true; }  else{  monatErinnern=false;  }    });
                  function sammleDaten() {
                   //   log(gesamtMonth.toString())
                                   let anzeigeNuller=3; //log(getState(val0help+".Script_Power").val.toString())
                                   let anzahlStellen=3;
                                   let anzahlStellen2=3;
                               if((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".todaykWh").val).toFixed(3)=="0.000") anzeigeNuller=0;
                               if ((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".MonBeforekWh").val).toFixed(3)=="0.000") anzahlStellen=0;
                               if ((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".monkWh").val).toFixed(3)=="0.000")  anzahlStellen2=0;
                           //    if (!anzeigeNuller){
                              val6=(getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".todaykWh").val).toFixed(anzeigeNuller)+" kWh"
                              if (!mitMonatBeforeAnzeige) {val7=(getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".monkWh").val).toFixed(anzahlStellen2)+" kWh"}
                              else{val7=(getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".monkWh").val).toFixed(anzahlStellen2)+" ("+(getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".MonBeforekWh").val).toFixed(anzahlStellen)+") kWh"}
                              val8=(Math.round((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".todaykWh").val)*kwhPreis*100)/100).toString()+" €"
                               if (!mitMonatBeforeAnzeige) {val9=(Math.round((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".monkWh").val)*kwhPreis*100)/100).toString()+" €"}
                               else{val9=(Math.round((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".monkWh").val)*kwhPreis*100)/100).toString()+" ("+(Math.round((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".MonBeforekWh").val)*kwhPreis*100)/100).toString()+") €"}
                  if (val1) {valStatus=symbolOK } else {valStatus=symbolKO};
                  let val2help=" - "; let val22;
                  if (val2.indexOf("mA")>-1) { val22=parseFloat(val2.replace(" mA",""))/1000;     val2help=val22.toString();} else if (val2.indexOf("A")>-1) {val22=parseFloat(val2.replace(" A","")); val2help=val22.toString();}
                  let val411=val4.replace(" W","");
                  let val311=val3.replace(" V","");
                  let valkNow=val6.replace(" kWh","");
                    valMBefore=getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".MonBeforekWh").val
                    valKostenBefore=(Math.round((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".MonBeforekWh").val)*kwhPreis*100)/100).toString()
                  makeJsonWidget(val0,valStatus,val2help,val311,val411,val5,valkNow,valkM,valEuNow,valEuM,valMarkeDevice,"",valMBefore,valKostenBefore)}}
                   function zeigeVal1(){
                                  if (!val1) {
                                val1=symbolKO;
                                val4=(" <font color=\""+farbeFehlenderGeräte+"\"> ")+" --- </font>";
                                val2=(" <font color=\""+farbeFehlenderGeräte+"\"> ")+" --- </font>";
                                val3=(" <font color=\""+farbeFehlenderGeräte+"\"> ")+" --- </font>";
                                val5=(" <font color=\""+farbeFehlenderGeräte+"\"> ")+" --- </font>";
                                val6=("<i><font color=\""+farbeFehlenderGeräte+"\"> ")+val6+"</font></i>";
                                val7=("<i><font color=\""+farbeFehlenderGeräte+"\"> ")+val7+"</font></i>";
                                val0=("<i> <font color=\""+farbeFehlenderGeräte+"\"> ")+val0 +"</font></i>";
                                val8=("<i><font color=\""+farbeFehlenderGeräte+"\"> ")+val8+"</font></i>";
                                val9=("<i><font color=\""+farbeFehlenderGeräte+"\"> ")+val9+"</font></i>";}
                            else{
                               // log("true")
                                val1=symbolOK;
                      function berechneGesamt() {
                           // log(val0)
                          if (gesamt) {
                                       gesamtNow=gesamtNow+parseFloat(getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".todaykWh").val);
                                       gesamtMonth=gesamtMonth+parseFloat(getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".monkWh").val);
                                       gesamtMoneyTod=gesamtMoneyTod+(Math.round((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".todaykWh").val)*kwhPreis*100)/100);
                                       gesamtMoneyMon=gesamtMoneyMon+(Math.round((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".monkWh").val)*kwhPreis*100)/100);
                                       gesamtMonthBefore=gesamtMonthBefore+parseFloat(getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".MonBeforekWh").val);
                                       gesamtMonthMoneyBefore=gesamtMonthMoneyBefore+(Math.round((getState(dpPrefix+"Tabelle_EnergieRechnung."+val0+".MonBeforekWh").val)*kwhPreis*100)/100);
                            }} else {}
                  //MaterialDesign
                   function makeJsonWidget(vax1,vax2,vax3,vax4,vax5,vax6,vax7,vax8,vax9,vax10,vaxMarke,vaxBckGround,vaxMBefore,vaxKostenBefore) {
                     /* vax6=vax6.replace(/((ON|OFF))/g,"$1 "); log("---"+vax6) vax6=vax6.replace(/(OFF|ON).+? ((ON|OFF))/,"$3"); log("2222"+vax6)*/
                       vaxMarke=pfadBilderMaterialWidget+vaxMarke+".png"
                        let mycolor;
                        if (vax1.indexOf("Gesamt")>-1) vax1="<font color=\'"+farbeMDAlleVirtPow+"\'>"+" GESAMT VirtualPower"+"</font>";
                        if (vax1.indexOf("alle Geräte")>-1) vax1="<font color=\'"+farbeMDGesamtG+"\'>"+" GESAMT"+"</font>";
                      // log(vax1+ " und "+ vax2 +" und "+vax3 )
                     if ( braucheMaterialDesignWidgetTable) {
                  if (filterArrAusnahme.includes(val0)) {
                      vax1="<font color=\'"+farbeMDEinspeisung+"\'>"+vax1+"</font>";
                      vaxMarke=pfadBilderMaterialWidget+"inputk"+".png"
                      mycolor=farbeMDEinspeisung;
                     myJsonWidget.push({
                         Device : vax1,
                         marke :vaxMarke,
                         status: vax2,
                         Strom : vax3,
                         Spannung : vax4,
                         Schalter : vax5,
                         Power : vax6,
                         kWhNow : vax7,
                         kWhMonat  : vax8,
                         MonatZuvor : vaxMBefore,
                         PreisNow : vax9,
                         PreisMonat : vax10,
                         KostenMonatZuvor: vaxKostenBefore,
                  //	log(myJsonWidget)
                  vaxBckGround=""
                  let mysubText;
                   mysubText =     `<div>Strom: ${vax3} A</div>
                                     <div>Spannung: ${vax4} V</div>
                                     <div>Leistung: ${vax5} W</div>
                                     <div>&ensp; </div>
                                     <div>Heute: ${vax7} kWh</div>
                                     <div>Monat: ${vax8} kWh</div>
                                     <div>Vormonat: ${vaxMBefore} kWh</div>
                                     <div>&ensp; </div>
                                     <div>Heute: ${vax9} €</div>
                                     <div>Monat: ${vax10} €</div>
                                     <div>Vormonat: ${vaxKostenBefore} €</div>
                                     <div style="display: flex; flex: 1; text-align: left; align-items: center; position: relative;">
                                     ${vax6}</font></div>`;
                  } else {
                  mysubText =     `     <div style="color: ${farbeMDEinspeisung};  ">EINSPEISUNG Leistung: ${vax5} W</div>
                                       <div>&ensp; </div>
                                       <div>&ensp; </div>
                                       <div>Schalter: ${vax6}</font></div>`;
                                       vaxBckGround="#8A4B08";
                  //  // <div>Strom:${vax3}A Spannung: ${vax4}V Leistung: ${vax5}W</div>    //font-size: 80% ;
                  if (vax1.indexOf("GESAMT VirtualPower")>-1) {
                   mysubText =     ` <div>&ensp; </div>
                                     <div>&ensp; </div>
                                     <div>&ensp; </div>
                                     <div>&ensp; </div>
                                     <div>&ensp; </div>
                                     <div>Heute: ${vax9} € </div>
                                     <div>&ensp; </div>`;
                  if (vax1.indexOf("GESAMT")>-1) {
                                     <div>&ensp; </div>
                                     <div>&ensp; </div>
                                     <div>&ensp; </div>
                                     <div>&ensp; </div>
                    if (!filterArrAusnahme.includes(val0)) { if (vax2==symbolOK) {mycolor="green" } else {mycolor="red"};}
                   //  if (vax1.indexOf("GESAMT")>-1) {vaxMarke="infok";mycolor=farbeMDGesamtG;}
                    if (vax1.indexOf("GESAMT VirtualPower")>-1) {mycolor=farbeMDAlleVirtPow;vaxBckGround="#4682B4"}
                    if (vax1.indexOf("GESAMT</font>")>-1) {vaxMarke=pfadBilderMaterialWidget+"infok"+".png"; mycolor=farbeMDGesamtG;vaxBckGround="#1C716E"}  //Farbe Hintergrund Gesamt
                       myJsonWidget2.push({
                                 background : vaxBckGround,
                                 text: vax1,
                                 subText: mysubText,
                                 statusBarColor: mycolor,
                                 image: vaxMarke,
                                 imageColor: "",
                                 listType: "text",
                                 showValueLabel: false,
                                 Device : vax1,
                                 Status : vax2,
                                 Strom : vax3,
                                 Spannung : vax4,
                                 Power : vax5,
                                 Schalter : vax6,
                                 kWhNow : vax7,
                                 kWhMonat  : vax8,
                                 PreisNow : vax9,
                                 PreisMonat : vax10,
                                 marke : vaxMarke
                    @Idefix01 in zeile 1646 wird das bild für gesamt eingepflegt . das bild muss im richtigen pfad liegen und infok.png heißen
                    • I
                      @liv-in-sky
                      Vielen Dank perfekt, ...vor lauter Bäumen die Allee nicht gefunden 😊
                        Saschag last edited by
                        Morgen,
                        ich hoffe ich habe es in den 570 Beiträgen nicht überlesen 😉
                        Kann man beim VirtuellpowerMeter-Geräten den "Namen" in der Anhzeige(Widget anpassen?
                          liv-in-sky @Saschag last edited by
                          @saschag
                          @saschag ist echt lange her, dass ich mich damit näher beschäftigt habe - aber du mußt dein script verändern. denke mal die sicherste änderung wäre am ende, bevor geschrieben wird
                          würde es mal so probieren:
                          das ".replace() einfügen
                          text: vax1.replace(".STATE",""),
                            Saschag @liv-in-sky last edited by
                            @liv-in-sky said in Energieanzeige (kWh) über HTML Tabelle - vis:
                            perfekt! Danke
                              gerald123 @liv-in-sky last edited by
                              @liv-in-sky Hallo liv-in-sky,
                              Ich wollte mal fragen welches Skript die aktuelle Version ist, ich habe da den Überblick verloren.
                              Sg. Gerald
                                liv-in-sky @gerald123 last edited by
                                @gerald123 eigentlich immer im ersten post
                                mittlerweile wird aber der SourceAnalytix wieder richtig geplegt - daher weiß ich nicht , ob es sinn macht das script weiter zu nutzen ?? evtl mal informieren
                                G J 2 Replies Last reply Reply Quote 0
                                  @liv-in-sky Danke für die Info
                                    Jautze @liv-in-sky last edited by
                                    @liv-in-sky
                                    ist es möglich die Tabelle mit der Spalte Jahr zu erweitern und quasi die Monate dort aufzusummieren?
                                    Bzw. eine Spalte mit den Daten seit Laufzeitbeginn. Dann muss es am Jahresende nicht zurückgesetzt werden.
                                    Das wäre echt super.
                                    Danke und viele Grüße
                                    Marcel
                                      liv-in-sky @Jautze last edited by liv-in-sky
                                      @jautze
                                      hi - sorry - da werd ich nix mehr großes dran ändern 😞
                                      was ich gemacht habe - script im ersten post - ich habe dir einen datenpunkt angelegt, der speichert den gesamtverbrauch des monats (mit jahr) in einen datenpunkt im json-format
                                      datenpunkt findest du unter: javascript.0.Tabelle_EnergieRechnung.Collection.GesamtMonate
                                      damit könntest du dir mit einem json widget oder wenn du die daten verarbeitest eine übersicht basteln
                                        @liv-in-sky
                                        Super danke.
                                          mobilee last edited by
                                          @Oli der war nie weg - alle geräte sind der gesamtverbrauch
                                            liv-in-sky @mobilee last edited by
                                            @mobilee was willst du mir damit sagen
                                            javascript template
                                            37
                                            696
                                            130551
