    4. Test Adapter fb-checkpresence v1.1.x
    • afuerhoff
      afuerhoff Developer @Dominik F. last edited by
      @Dominik-F
      Kein Problem
      • Fenriswolf
        Fenriswolf last edited by
        Ich habe immernoch sehr regelmäßig das Problem, das die Verbindung verloren geht.
        2021-01-11 17:04:17.805 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
        2021-01-11 17:06:00.798 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
        2021-01-11 17:06:00.799 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
        2021-01-11 17:07:44.017 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
        2021-01-11 17:07:44.018 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
        2021-01-11 17:09:26.365 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
        2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
        2021-01-11 17:11:09.171 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
        2021-01-11 17:11:09.172 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
        Was mich aber bei genauerer Betrachtung viel mehr verwirrt, ist der Punkt
        2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: ...... "urn:dslforum-org:service:Hosts:1\"},.........
        Was hat das DSL-Forum damit zu tun ??
        bis denne
        afuerhoff 2 Replies Last reply Reply Quote 0
        • afuerhoff
          afuerhoff Developer @Fenriswolf last edited by
          @Fenriswolf sagte in Test Adapter fb-checkpresence v1.1.x:
          dslforum-org
          Du kannst ja mal diese Url bei Dir eingeben: http://fritz.box:49000/tr64desc.xml
          Dann sollte als erstes diese Zeile kommen: <root xmlns="urn:dslforum-org:device-1-0">
          Das hat mit dem TR-064 Standard zu tun.
          Fenriswolf 1 Reply Last reply Reply Quote 0
          • Fenriswolf
            Fenriswolf @afuerhoff last edited by
            @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
            dslforum-org
            OK 😉 danke für die schnelle Antwort
            • afuerhoff
              @Fenriswolf
              Bzgl. Fehlermeldungen habe ich bei mir jetzt kaum noch welche. Evtl. hilft der neuste Adapterstand. Ist aber noch nicht auf Github hochgeladen.
              • Fenriswolf
                @Fenriswolf
                Habe bei mir jetzt mal die Intervallzeit bei den Haupteinstellungen hochgesetzt. Nachdem ich gesehen habe, das es nur für die Device-Suche ist und nicht für die Mitgliedererkennung.
                Hatte da wohl noch ein Problem in meinen eigenen Hirnwindungen.
                afuerhoff 1 Reply Last reply Reply Quote 0
                • afuerhoff
                  Die Meshdaten werden nur wenn angehakt geladen und im gleichen Intervall aktulisiert wie die
                  Fb-Devicedaten.
                  • TG70
                    TG70 Forum Testing @afuerhoff last edited by
                    @afuerhoff said in Test Adapter fb-checkpresence v1.1.x:
                    @TG70
                    Du brauchst die Fritzbox Version 7.20 damit es schneller geht.
                    Also ich bin jetzt auf der Fritz! 7.23 ... Allerdings merke ich nichts davon, dass die Erkennung schneller geht.
                    Den Zustand "Offline" wird mir erst nach ca. 10 Minuten angezeigt? Wie lange dauert es bei euch mit der Erkennung der Zustände "Online" und "Offline"
                    • afuerhoff
                      afuerhoff Developer @TG70 last edited by afuerhoff
                      @TG70
                      Wie ist denn die Intervalleinstellung für Familienmitglieder?
                      EDIT: Bei mir dauert es mit der Version 7.21 (Intervall 10s) max. 20-30 s.
                      TG70 1 Reply Last reply Reply Quote 0
                      • afuerhoff
                        afuerhoff Developer last edited by
                        ich habe die Version 1.1.2 auf Github zum Testen veröffentlicht. Die Änderungen sind im ersten Beitrag beschrieben. Bitte gebt Rückmeldung, ob alles funktioniert.
                        ? Fenriswolf 2 Replies Last reply Reply Quote 0
                          A Former User @afuerhoff last edited by
                          @afuerhoff laeuft... 🙂
                          • TG70
                            @TG70
                            Steht bei mir auf 10s. Wie gesagt Offlie Zustand dauert bis 10 Minuten. Online geht schneller ca. <= 1 Min.
                            • Fenriswolf
                              Fenriswolf @afuerhoff last edited by Fenriswolf
                              habe jetzt folgende Eintragungen im Log:
                              2021-01-14 07:32:33.719 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LANBridge
                              2021-01-14 07:32:33.720 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                              2021-01-14 07:32:33.720 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:1
                              2021-01-14 07:32:33.721 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:2
                              2021-01-14 07:32:33.721 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                              2021-01-14 07:32:33.721 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:3
                              2021-01-14 07:32:33.722 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                              2021-01-14 07:32:33.722 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:4
                              2021-01-14 07:32:33.722 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.WAN:1
                              2021-01-14 07:32:33.723 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                              2021-01-14 07:32:33.723 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:5G:0
                              2021-01-14 07:32:33.723 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:2G:0
                              2021-01-14 07:32:33.724 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                              2021-01-14 07:32:33.724 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:5G:0
                              2021-01-14 07:32:33.725 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:2G:0
                              2021-01-14 07:32:33.725 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                              2021-01-14 07:43:11.613 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LANBridge
                              2021-01-14 07:43:11.614 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                              2021-01-14 07:43:11.615 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:1
                              2021-01-14 07:43:11.615 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                              2021-01-14 07:43:11.616 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:2
                              2021-01-14 07:43:11.616 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                              2021-01-14 07:43:11.616 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:3
                              2021-01-14 07:43:11.617 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                              2021-01-14 07:43:11.617 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:4
                              2021-01-14 07:43:11.618 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                              2021-01-14 07:43:11.618 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.WAN:1
                              2021-01-14 07:43:11.618 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:5G:0
                              2021-01-14 07:43:11.619 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                              2021-01-14 07:43:11.619 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:2G:0
                              2021-01-14 07:43:11.620 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:5G:0
                              2021-01-14 07:43:11.620 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                              2021-01-14 07:43:11.620 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:2G:0
                              alle 11 Minuten
                              bis denne
                              sigi234 afuerhoff 2 Replies Last reply Reply Quote 0
                                sigi234 Forum Testing Most Active @Fenriswolf last edited by sigi234
                                @fenriswolf
                                Kann ich bestätigen.
                                Es werden auch keine Devices angelegt.
                                Wobei ich die Beta vom JS controller Installiert: 3.2.6-0 habe.
                                Dadurch kommen auch massenweise diese Warn:
                                fb-checkpresence.0	2021-01-14 10:35:15.977	warn	(5232) State "fb-checkpresence.0.fb-devices.fritz-box.AP:2G:0.link" has no existing object, this might lead to an error in future versions
                                fb-checkpresence.0	2021-01-14 10:35:15.976	warn	(5232) State "fb-checkpresence.0.fb-devices.fritz-box.AP:2G:0.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
                                fb-checkpresence.0	2021-01-14 10:35:15.976	warn	(5232) State "fb-checkpresence.0.fb-devices.fritz-box.AP:2G:0.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
                                • afuerhoff
                                  @tg70 said in Test Adapter fb-checkpresence v1.1.x:
                                  Hallo, hast Du das schon mit der neuen Version getestet. In der 1.1.1 war noch ein Bug bei 10s Einstellung.
                                  • afuerhoff
                                    @fenriswolf said in Test Adapter fb-checkpresence v1.1.x:
                                    Da hat sich ein Fehler eingeschlichen. Korrigiere ich.
                                    • afuerhoff
                                      afuerhoff Developer @sigi234 last edited by
                                      @Fenriswolf @sigi234
                                      Ich habe ein Update hochgeladen. Bitte neu testen. Am Besten einmal die Objekte unter fb-devices löschen. Die sind falsch angelegt worden.
                                      sigi234 Fenriswolf 3 Replies Last reply Reply Quote 0
                                        sigi234 Forum Testing Most Active @afuerhoff last edited by
                                        Schaut wieder gut aus. Bis auf die Warn wegen Beta JS Controller.
                                        • afuerhoff
                                          @sigi234
                                          Welche Warnungen meinst du ? Die vom Post oben?
                                          Hast Du die Objekte einmal gelöscht?
                                            Ja
                                            Log:
                                            2021-01-14 21:51:08.500 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.name" has no existing object, this might lead to an error in future versions
                                            2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.link" has no existing object, this might lead to an error in future versions
                                            2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.rx_rcpi" has no existing object, this might lead to an error in future versions
                                            2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
                                            2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
                                            2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.type" has no existing object, this might lead to an error in future versions
                                            2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.name" has no existing object, this might lead to an error in future versions
                                            2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.link" has no existing object, this might lead to an error in future versions
                                            2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.rx_rcpi" has no existing object, this might lead to an error in future versions
                                            2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
                                            2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
                                            2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.type" has no existing object, this might lead to an error in future versions
                                            2021-01-14 21:51:08.503 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Buero.WLAN.name" has no existing object, this might lead to an error in future versions
                                            2021-01-14 21:51:08.503 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Buero.WLAN.link" has no existing object, this might lead to an error in future versions
                                            avm fb-checkpresence fritzbox tr-064
                                            88
                                            947
                                            256179
