    4. Test Adapter fb-checkpresence v1.1.x
    • Fenriswolf
      Fenriswolf last edited by
      Ich habe immernoch sehr regelmäßig das Problem, das die Verbindung verloren geht.
      2021-01-11 17:04:17.805 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
      2021-01-11 17:06:00.798 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
      2021-01-11 17:06:00.799 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
      2021-01-11 17:07:44.017 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
      2021-01-11 17:07:44.018 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
      2021-01-11 17:09:26.365 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
      2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
      2021-01-11 17:11:09.171 - warn: fb-checkpresence.0 (4012) getMeshList: Retried 3 times but still failed -> {"message":"timeout of 10000ms exceeded","name":"Error","stack":"Error: timeout of 10000ms exceeded\n at createError (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/core/createError.js:16:15)\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/axios/lib/adapters/http.js:280:16)\n at Object.onceWrapper (events.js:420:28)\n at RedirectableRequest.emit (events.js:314:20)\n at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/follow-redirects/index.js:166:13)\n at listOnTimeout (internal/timers.js:554:17)\n at processTimers (internal/timers.js:497:7)","config":{"url":"http://192.168.99.1:49000/meshlist.lua?sid=3b926e141d88d2d7","method":"get","headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":10000,"responseType":"json","xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"cancelToken":{"promise":{}},"responseEncoding":"utf8"},"code":"ECONNABORTED"}
      2021-01-11 17:11:09.172 - error: fb-checkpresence.0 (4012) getMeshList: "Can not read meshlist {\"status\":200,\"result\":true,\"resultData\":{\"$\":{\"xmlns:u\":\"urn:dslforum-org:service:Hosts:1\"},\"NewX_AVM-DE_MeshListPath\":\"/meshlist.lua?sid=3b926e141d88d2d7\"},\"errNo\":0,\"errorMsg\":\"\"}"
      Was mich aber bei genauerer Betrachtung viel mehr verwirrt, ist der Punkt
      2021-01-11 17:09:26.366 - error: fb-checkpresence.0 (4012) getMeshList: ...... "urn:dslforum-org:service:Hosts:1\"},.........
      Was hat das DSL-Forum damit zu tun ??
      bis denne
      afuerhoff 2 Replies Last reply Reply Quote 0
      • afuerhoff
        afuerhoff Developer @Fenriswolf last edited by
        @Fenriswolf sagte in Test Adapter fb-checkpresence v1.1.x:
        dslforum-org
        Du kannst ja mal diese Url bei Dir eingeben: http://fritz.box:49000/tr64desc.xml
        Dann sollte als erstes diese Zeile kommen: <root xmlns="urn:dslforum-org:device-1-0">
        Das hat mit dem TR-064 Standard zu tun.
        Fenriswolf 1 Reply Last reply Reply Quote 0
        • Fenriswolf
          Fenriswolf @afuerhoff last edited by
          @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
          dslforum-org
          OK 😉 danke für die schnelle Antwort
          • afuerhoff
            @Fenriswolf
            Bzgl. Fehlermeldungen habe ich bei mir jetzt kaum noch welche. Evtl. hilft der neuste Adapterstand. Ist aber noch nicht auf Github hochgeladen.
            • Fenriswolf
              @Fenriswolf
              Habe bei mir jetzt mal die Intervallzeit bei den Haupteinstellungen hochgesetzt. Nachdem ich gesehen habe, das es nur für die Device-Suche ist und nicht für die Mitgliedererkennung.
              Hatte da wohl noch ein Problem in meinen eigenen Hirnwindungen.
              afuerhoff 1 Reply Last reply Reply Quote 0
              • afuerhoff
                Die Meshdaten werden nur wenn angehakt geladen und im gleichen Intervall aktulisiert wie die
                Fb-Devicedaten.
                • TG70
                  TG70 Forum Testing @afuerhoff last edited by
                  @afuerhoff said in Test Adapter fb-checkpresence v1.1.x:
                  @TG70
                  Du brauchst die Fritzbox Version 7.20 damit es schneller geht.
                  Also ich bin jetzt auf der Fritz! 7.23 ... Allerdings merke ich nichts davon, dass die Erkennung schneller geht.
                  Den Zustand "Offline" wird mir erst nach ca. 10 Minuten angezeigt? Wie lange dauert es bei euch mit der Erkennung der Zustände "Online" und "Offline"
                  • afuerhoff
                    afuerhoff Developer @TG70 last edited by afuerhoff
                    @TG70
                    Wie ist denn die Intervalleinstellung für Familienmitglieder?
                    EDIT: Bei mir dauert es mit der Version 7.21 (Intervall 10s) max. 20-30 s.
                    TG70 1 Reply Last reply Reply Quote 0
                    • afuerhoff
                      afuerhoff Developer last edited by
                      ich habe die Version 1.1.2 auf Github zum Testen veröffentlicht. Die Änderungen sind im ersten Beitrag beschrieben. Bitte gebt Rückmeldung, ob alles funktioniert.
                      ? Fenriswolf 2 Replies Last reply Reply Quote 0
                        A Former User @afuerhoff last edited by
                        @afuerhoff laeuft... 🙂
                        • TG70
                          @TG70
                          Steht bei mir auf 10s. Wie gesagt Offlie Zustand dauert bis 10 Minuten. Online geht schneller ca. <= 1 Min.
                          • Fenriswolf
                            Fenriswolf @afuerhoff last edited by Fenriswolf
                            habe jetzt folgende Eintragungen im Log:
                            2021-01-14 07:32:33.719 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LANBridge
                            2021-01-14 07:32:33.720 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                            2021-01-14 07:32:33.720 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:1
                            2021-01-14 07:32:33.721 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:2
                            2021-01-14 07:32:33.721 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                            2021-01-14 07:32:33.721 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:3
                            2021-01-14 07:32:33.722 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                            2021-01-14 07:32:33.722 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:4
                            2021-01-14 07:32:33.722 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.WAN:1
                            2021-01-14 07:32:33.723 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                            2021-01-14 07:32:33.723 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:5G:0
                            2021-01-14 07:32:33.723 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:2G:0
                            2021-01-14 07:32:33.724 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                            2021-01-14 07:32:33.724 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:5G:0
                            2021-01-14 07:32:33.725 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:2G:0
                            2021-01-14 07:32:33.725 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                            2021-01-14 07:43:11.613 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LANBridge
                            2021-01-14 07:43:11.614 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                            2021-01-14 07:43:11.615 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:1
                            2021-01-14 07:43:11.615 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                            2021-01-14 07:43:11.616 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:2
                            2021-01-14 07:43:11.616 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                            2021-01-14 07:43:11.616 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:3
                            2021-01-14 07:43:11.617 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                            2021-01-14 07:43:11.617 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:4
                            2021-01-14 07:43:11.618 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                            2021-01-14 07:43:11.618 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.WAN:1
                            2021-01-14 07:43:11.618 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:5G:0
                            2021-01-14 07:43:11.619 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                            2021-01-14 07:43:11.619 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:2G:0
                            2021-01-14 07:43:11.620 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:5G:0
                            2021-01-14 07:43:11.620 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
                            2021-01-14 07:43:11.620 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:2G:0
                            alle 11 Minuten
                            bis denne
                            sigi234 afuerhoff 2 Replies Last reply Reply Quote 0
                              sigi234 Forum Testing Most Active @Fenriswolf last edited by sigi234
                              @fenriswolf
                              Kann ich bestätigen.
                              Es werden auch keine Devices angelegt.
                              Wobei ich die Beta vom JS controller Installiert: 3.2.6-0 habe.
                              Dadurch kommen auch massenweise diese Warn:
                              fb-checkpresence.0	2021-01-14 10:35:15.977	warn	(5232) State "fb-checkpresence.0.fb-devices.fritz-box.AP:2G:0.link" has no existing object, this might lead to an error in future versions
                              fb-checkpresence.0	2021-01-14 10:35:15.976	warn	(5232) State "fb-checkpresence.0.fb-devices.fritz-box.AP:2G:0.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
                              fb-checkpresence.0	2021-01-14 10:35:15.976	warn	(5232) State "fb-checkpresence.0.fb-devices.fritz-box.AP:2G:0.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
                              • afuerhoff
                                @tg70 said in Test Adapter fb-checkpresence v1.1.x:
                                Hallo, hast Du das schon mit der neuen Version getestet. In der 1.1.1 war noch ein Bug bei 10s Einstellung.
                                • afuerhoff
                                  @fenriswolf said in Test Adapter fb-checkpresence v1.1.x:
                                  Da hat sich ein Fehler eingeschlichen. Korrigiere ich.
                                  • afuerhoff
                                    afuerhoff Developer @sigi234 last edited by
                                    @Fenriswolf @sigi234
                                    Ich habe ein Update hochgeladen. Bitte neu testen. Am Besten einmal die Objekte unter fb-devices löschen. Die sind falsch angelegt worden.
                                    sigi234 Fenriswolf 3 Replies Last reply Reply Quote 0
                                      sigi234 Forum Testing Most Active @afuerhoff last edited by
                                      Schaut wieder gut aus. Bis auf die Warn wegen Beta JS Controller.
                                      • afuerhoff
                                        @sigi234
                                        Welche Warnungen meinst du ? Die vom Post oben?
                                        Hast Du die Objekte einmal gelöscht?
                                          Ja
                                          Log:
                                          2021-01-14 21:51:08.500 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.name" has no existing object, this might lead to an error in future versions
                                          2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.link" has no existing object, this might lead to an error in future versions
                                          2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.rx_rcpi" has no existing object, this might lead to an error in future versions
                                          2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
                                          2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
                                          2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.type" has no existing object, this might lead to an error in future versions
                                          2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.name" has no existing object, this might lead to an error in future versions
                                          2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.link" has no existing object, this might lead to an error in future versions
                                          2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.rx_rcpi" has no existing object, this might lead to an error in future versions
                                          2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
                                          2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
                                          2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.type" has no existing object, this might lead to an error in future versions
                                          2021-01-14 21:51:08.503 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Buero.WLAN.name" has no existing object, this might lead to an error in future versions
                                          2021-01-14 21:51:08.503 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Buero.WLAN.link" has no existing object, this might lead to an error in future versions
                                          • afuerhoff
                                            @sigi234
                                            Kannst Du mal ein Bild der entsprechenden Objekte posten. CCU3 sollte z.B. als Device angelegt sein.
                                            avm fb-checkpresence fritzbox tr-064
                                            88
                                            947
                                            256179
