    4. [SourceAnalytix 0.4.8-Final] Released !
    • Dutchman
      Dutchman Developer Most Active Administrators @Dutchman last edited by Dutchman
      Troubleshooting
      Before we start troubleshooting, it's important to understand how source analytix initialises as here errors may occur, see issue section.
      The following sequence will be handled :
      1. Start SourceAnalytix
      2. List all states activated for SourceAnalytix
      3. Initiate states, for each state :
      • Read current cumulatedReading
        (if present) and memory values from state
      • Check if unit can be handled {Issue 1}
      • Check if cost type is chosen {Issue 2}
      • Verify if valid price definition is present for cost type {Issue 3}
      • Check if previous init value > current cumulated value {Issue 4}
      • Check if valid known of previous device reset > current cumulated value {Issue 5}
      • Store all data to memory
      1. Initialise states for each state :
      • create state cumulativeReading (to store results of calculation, can also be used for W to kWh only) {Issue 6}
      • create states as chosen in state configuration {Issue 7}
      • start calculation
      1. On state change/update
      • Verify if information is correct
      • transform value to proper unit (unit of state to unit chosen in state configuration)
      • check if value input is correct ( current value > previousInit value) {See 7 At device reset Issue 8}
      • calculate {Issue 9}
      • For Watt : calculate Watt to kWh ,calculate cumulatedReading = currentReading + cumulatedReading
      • For other : calculate cumulatedReading = currentReading + previousDeviceReset (if present)
      1. At night (00.00)
      • List all SourceAnalytix enabled states
      • Reset start (Day/Week/Year/Month) values
      1. At device reset
      • Store current value as previousDeviceReset and previousInit value
        If the device wil be reset again (detected by previousInit value),
        currentReading + previousDeviceReset is stored as to previousDeviceReset.
      Issue 1 No unit defined for ....., cannot execute calculations
      Please select correct unit in state settings
      Issue 2 No cost type defined for ....., please Select Type of calculation at state setting
      Please selected wanted cost-type for to understand what amount should be used to handle calculations
      Issue 3 Selected Type ... does not exist in Price Definitions
      Now Price definitions are found for the chosen cost type, please verify your price setting (adapte config)
      Issue 4 Check settings for ..... ! Known init value : ..... > known cumulative value ..... cannot proceed
      The known init value > known cumulated values, this can be solved by removing or modifying these objects in the state raw object
      "valueAtDeviceInit": xxxx
      Issue 5 Check settings for ..... ! Known valueAtDeviceReset : ..... > known cumulative value ..... cannot procee
      valueAtDeviceReset": xxxx
      Issue 6 State for cumulativeReading is not created
      Initialisation of state did fail, see issue 1 to 5
      Issue 7 States for costs readings ae not created
      Type of calculation is not enabled in state settings
      Price-Definitions
      Issue 8 current value < previousInit
      A device reset is detected, see function 7
      Issue 9 My calculations are incorrect
      cumulativeReading-Reset
      1. Verify if the correct unit is chosen (of not selected, SA will try to autodetect)
      2. Verify if the cumulatedReading reflects the correct total value of your value reading, if not
      • Stop SA
      • Go to tab objects
      • Enter expert mode
      • Change the cumulatedReading
      • Exit expert mode
      • Ensure the start values are set correctly
      • Start SA
      1. Ensure the start values are set correctly
        SA handles calculations by cumulatedReading - known cumulatedReading at period start.<b/>
        These start values are defined at the state settings and should be < than currentReading
        Please ensure cumulativeReading >= DayStart >= WeekStart >= MonthStart >= QuarterStart >= YearStart
      2. Verify these values in state raw object :
      D K S 3 Replies Last reply Reply Quote 3
        deifel @Dutchman last edited by
        @dutchman
        Vielen Dank für diesen tollen Adapter!!
        Ich habe ihn mit Strom, Öl und Wasser am Laufen.
        Eine Frage / Problem habe ich:
        Beim Öltank habe ich den aktuellen Ölstand (Beispiel 6000 Liter). Hier wird mir jetzt der Verbrauch und auch die Kosten mit einem Minusvorzeichen angezeigt, da der Inhalt des Tanks ja abnimmt.
        Kann ich das irgendwo einstellen?
        Vielen Dank im Voraus
        Frank
        • Dutchman
          Dutchman Developer Most Active Administrators @deifel last edited by
          @deifel said in [SourceAnalytix 0.4.8-RC.1] Stable version announcement:
          Hmm nicht wirklich den du hast einen wert de abnimmt anstatt dazu, mit anderen Worten der - wert muss immer als verbrauch interpretiert werden Feuer die jetzige logic van SA.
          Kannst du die Messung nicht umdrehen in einen Verbrauchswert ?
            @dutchman
            Danke für Deine Antwort und schade, dass es hierfür keine Einstellmöglichkeit gibt.
            Der Wert kommt verschlüsselt über eine angezapfte Sonde an einem RS485 an und die Werte werden anhand einer Tabelle dann in einen Füllstand interpretiert.
            Der Aufwand war ganz schön groß, das einzurichten.
            Klar könnte ich jetzt mit weiteren Variablen arbeiten und vom maximalen Füllstand den aktuellen Wert abziehen, um wiederum den Verbrauch zu bekommen...
            Aber wenns einfacher gegangen wäre (einfach durch Umkehren am Adapter) wäre das natürlich klasse gewesen:)
            Trotzdem danke auch nochmals für die tolle Arbeit!
            • Dutchman
              Es wuerde gehen, aber wie gesagt dazu mss ich ne andere logic realisieren bitte git Issue erstellen.
              Ich wuerde solange vorschlagen um per script einen Datenpunkt zu erstellen und dan die Berechnung :
              Gesamt Volumen - Jetziges Volumen = Verbrauch und diesen mit SA loggen. Wie der tank gefüllt ist der stand 0 und damit
              At device reset
              • Dutchman
                0.4.8-alpha.10 (2021-01-14)
                • (Dutchman) Bugfix : Avoid loop if init value is set and > reading
                • (Dutchman) Bugfix : Throw error if value is NULL for troubleshooting instead of handling incorrect calculation
                M matze55 2 Replies Last reply Reply Quote 0
                  MartyBr @Dutchman last edited by
                  @dutchman
                  Ich habe gerade dein Alpha 10 eingespielt.
                  sourceanalytix.0	2021-01-14 14:12:29.982	error	(2129) [calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading [object Object] | stateDetails [object Object]
                  sourceanalytix.0	2021-01-14 14:12:22.632	error	(2129) [calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading [object Object] | stateDetails [object Object]
                  sourceanalytix.0	2021-01-14 14:12:19.036	error	(2129) [calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading [object Object] | stateDetails [object Object]
                  sourceanalytix.0	2021-01-14 14:12:15.343	error	(2129) [calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading [object Object] | stateDetails [object Object]
                  sourceanalytix.0	2021-01-14 14:12:12.385	error	(2129) [calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading [object Object] | stateDetails [object Object]
                  sourceanalytix.0	2021-01-14 14:12:08.934	error	(2129) [calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading [object Object] | stateDetails [object Object]
                  sourceanalytix.0	2021-01-14 14:11:58.666	error	(2129) [calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading [object Object] | stateDetails [object Object]
                  • Dutchman
                    Dutchman Developer Most Active Administrators @MartyBr last edited by
                    @martybr said in [SourceAnalytix 0.4.8-RC.1] Stable version announcement:
                    @dutchman
                    Ich habe gerade dein Alpha 10 eingespielt. ```
                    Danke, darauf hab ich gewartet bitte noch einmal von git dan stehen auf die werte drin anstatt object und kan ich den Fehler ausbügeln !
                    K M 2 Replies Last reply Reply Quote 0
                      Kueppert @Dutchman last edited by Kueppert
                      @dutchman ich hab die Alpha 11 gerade mal drüber gebügelt, außer folgender Fehlerchen hab ich vom Adapter selbst nix bekommen:
                      sourceanalytix.0	2021-01-14 14:42:00.623	warn	(14935) State "sourceanalytix.0.alias__0__Stromverbrauch__total__Serverschrank.currentYear.consumed.2021.05_currentYear" has no existing object, this might lead to an error in future versions
                      sourceanalytix.0	2021-01-14 14:41:47.017	warn	(14935) State "sourceanalytix.0.alias__0__Stromverbrauch__total__Serverschrank.currentYear.consumed.2021.05_currentYear" has no existing object, this might lead to an error in future versions
                      Aber bei der Installation hatte ich verdammt viele rote EInträge:
                      host.ioBroker2	2021-01-14 14:40:50.043	error	instance system.adapter.sourceanalytix.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      host.ioBroker2	2021-01-14 14:40:50.043	error	Caught by controller[655]: at process.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8477:45)
                      host.ioBroker2	2021-01-14 14:40:50.043	error	Caught by controller[655]: at exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8457:28)
                      host.ioBroker2	2021-01-14 14:40:50.043	error	Caught by controller[655]: at Sourceanalytix.registerNotification (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5677:24)
                      host.ioBroker2	2021-01-14 14:40:50.042	error	Caught by controller[655]: at Sourceanalytix.sendToHostAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1618:16)
                      host.ioBroker2	2021-01-14 14:40:50.042	error	Caught by controller[655]: at new Promise (<anonymous>)
                      host.ioBroker2	2021-01-14 14:40:50.042	error	Caught by controller[655]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1619:16
                      host.ioBroker2	2021-01-14 14:40:50.042	error	Caught by controller[655]: at Sourceanalytix.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5660:31)
                      host.ioBroker2	2021-01-14 14:40:50.042	error	Caught by controller[655]: at StateRedisClient.pushMessage (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:898:31)
                      host.ioBroker2	2021-01-14 14:40:50.042	error	Caught by controller[655]: at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:111:25)
                      host.ioBroker2	2021-01-14 14:40:50.042	error	Caught by controller[655]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:607:24)
                      host.ioBroker2	2021-01-14 14:40:50.042	error	Caught by controller[655]: Error: Connection is closed.
                      host.ioBroker2	2021-01-14 14:40:50.042	error	Caught by controller[655]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejec
                      host.ioBroker2	2021-01-14 14:40:50.042	error	Caught by controller[655]: at process.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8477:45)
                      host.ioBroker2	2021-01-14 14:40:50.042	error	Caught by controller[655]: at exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8457:28)
                      host.ioBroker2	2021-01-14 14:40:50.042	error	Caught by controller[655]: at Sourceanalytix.registerNotification (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5677:24)
                      host.ioBroker2	2021-01-14 14:40:50.041	error	Caught by controller[655]: at Sourceanalytix.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5660:31)
                      host.ioBroker2	2021-01-14 14:40:50.041	error	Caught by controller[655]: at StateRedisClient.pushMessage (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:898:31)
                      host.ioBroker2	2021-01-14 14:40:50.041	error	Caught by controller[655]: at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:111:25)
                      host.ioBroker2	2021-01-14 14:40:50.041	error	Caught by controller[655]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:607:24)
                      host.ioBroker2	2021-01-14 14:40:50.041	error	Caught by controller[655]: Error: Connection is closed.
                      host.ioBroker2	2021-01-14 14:40:50.041	error	Caught by controller[655]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejec
                      host.ioBroker2	2021-01-14 14:40:50.041	error	Caught by controller[655]: at process.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8477:45)
                      host.ioBroker2	2021-01-14 14:40:50.041	error	Caught by controller[655]: at exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8457:28)
                      host.ioBroker2	2021-01-14 14:40:50.041	error	Caught by controller[655]: at Sourceanalytix.registerNotification (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5677:24)
                      host.ioBroker2	2021-01-14 14:40:50.041	error	Caught by controller[655]: at Sourceanalytix.sendToHostAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1618:16)
                      host.ioBroker2	2021-01-14 14:40:50.041	error	Caught by controller[655]: at new Promise (<anonymous>)
                      host.ioBroker2	2021-01-14 14:40:50.041	error	Caught by controller[655]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1619:16
                      host.ioBroker2	2021-01-14 14:40:50.040	error	Caught by controller[655]: at Sourceanalytix.registerNotification (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5677:24)
                      host.ioBroker2	2021-01-14 14:40:50.040	error	Caught by controller[655]: at Sourceanalytix.sendToHostAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1618:16)
                      host.ioBroker2	2021-01-14 14:40:50.040	error	Caught by controller[655]: at new Promise (<anonymous>)
                      host.ioBroker2	2021-01-14 14:40:50.040	error	Caught by controller[655]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1619:16
                      host.ioBroker2	2021-01-14 14:40:50.040	error	Caught by controller[655]: at Sourceanalytix.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5660:31)
                      host.ioBroker2	2021-01-14 14:40:50.040	error	Caught by controller[655]: at StateRedisClient.pushMessage (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:898:31)
                      host.ioBroker2	2021-01-14 14:40:50.040	error	Caught by controller[655]: at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:111:25)
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[655]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:607:24)
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[655]: Error: Connection is closed.
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[655]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejec
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[655]: at process.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8477:45)
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[655]: at exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8457:28)
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[655]: at Sourceanalytix.registerNotification (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5677:24)
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[655]: ode_modules/iobroker.js-controller/lib/tools.js:1618:16)
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[654]: at Sourceanalytix.sendToHostAsync (/opt/iobroker/n
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[654]: at new Promise (<anonymous>)
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[654]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1619:16
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[654]: at Sourceanalytix.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5660:31)
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[654]: at StateRedisClient.pushMessage (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:898:31)
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[654]: at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:111:25)
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[654]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:607:24)
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[654]: Error: Connection is closed.
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[654]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejec
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[654]: at process.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8477:45)
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[654]: at exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8457:28)
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[654]: at Sourceanalytix.registerNotification (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5677:24)
                      host.ioBroker2	2021-01-14 14:40:50.039	error	Caught by controller[654]: at Sourceanalytix.sendToHostAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1618:16)
                      host.ioBroker2	2021-01-14 14:40:50.038	error	Caught by controller[654]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1619:16
                      host.ioBroker2	2021-01-14 14:40:50.038	error	Caught by controller[654]: at Sourceanalytix.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5660:31)
                      host.ioBroker2	2021-01-14 14:40:50.038	error	Caught by controller[654]: at StateRedisClient.pushMessage (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:898:31)
                      host.ioBroker2	2021-01-14 14:40:50.038	error	Caught by controller[654]: at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:111:25)
                      host.ioBroker2	2021-01-14 14:40:50.038	error	Caught by controller[654]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:607:24)
                      host.ioBroker2	2021-01-14 14:40:50.038	error	Caught by controller[654]: Error: Connection is closed.
                      host.ioBroker2	2021-01-14 14:40:50.038	error	Caught by controller[654]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejec
                      host.ioBroker2	2021-01-14 14:40:50.038	error	Caught by controller[654]: at process.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8477:45)
                      host.ioBroker2	2021-01-14 14:40:50.038	error	Caught by controller[654]: at exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8457:28)
                      host.ioBroker2	2021-01-14 14:40:50.038	error	Caught by controller[654]: at Sourceanalytix.registerNotification (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5677:24)
                      host.ioBroker2	2021-01-14 14:40:50.038	error	Caught by controller[654]: at Sourceanalytix.sendToHostAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1618:16)
                      host.ioBroker2	2021-01-14 14:40:50.038	error	Caught by controller[654]: at new Promise (<anonymous>)
                      host.ioBroker2	2021-01-14 14:40:50.037	error	Caught by controller[654]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejec
                      host.ioBroker2	2021-01-14 14:40:50.034	error	Caught by controller[654]: at process.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8477:45)
                      host.ioBroker2	2021-01-14 14:40:50.034	error	Caught by controller[654]: at exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8457:28)
                      host.ioBroker2	2021-01-14 14:40:50.034	error	Caught by controller[654]: at Sourceanalytix.registerNotification (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5677:24)
                      host.ioBroker2	2021-01-14 14:40:50.034	error	Caught by controller[654]: at Sourceanalytix.sendToHostAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1618:16)
                      host.ioBroker2	2021-01-14 14:40:50.034	error	Caught by controller[654]: at new Promise (<anonymous>)
                      host.ioBroker2	2021-01-14 14:40:50.034	error	Caught by controller[654]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1619:16
                      host.ioBroker2	2021-01-14 14:40:50.034	error	Caught by controller[654]: at Sourceanalytix.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5660:31)
                      host.ioBroker2	2021-01-14 14:40:50.034	error	Caught by controller[654]: at StateRedisClient.pushMessage (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:898:31)
                      host.ioBroker2	2021-01-14 14:40:50.034	error	Caught by controller[654]: at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:111:25)
                      host.ioBroker2	2021-01-14 14:40:50.034	error	Caught by controller[654]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:607:24)
                      host.ioBroker2	2021-01-14 14:40:50.034	error	Caught by controller[654]: Error: Connection is closed.
                      host.ioBroker2	2021-01-14 14:40:50.034	error	Caught by controller[654]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejec
                      host.ioBroker2	2021-01-14 14:40:50.033	error	Caught by controller[654]: at process.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8477:45)
                      host.ioBroker2	2021-01-14 14:40:50.033	error	Caught by controller[654]: at exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8457:28)
                      host.ioBroker2	2021-01-14 14:40:50.033	error	Caught by controller[654]: at Sourceanalytix.registerNotification (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5677:24)
                      host.ioBroker2	2021-01-14 14:40:50.033	error	Caught by controller[654]: at Sourceanalytix.sendToHostAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1618:16)
                      host.ioBroker2	2021-01-14 14:40:50.033	error	Caught by controller[654]: at new Promise (<anonymous>)
                      host.ioBroker2	2021-01-14 14:40:50.033	error	Caught by controller[654]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1619:16
                      host.ioBroker2	2021-01-14 14:40:50.033	error	Caught by controller[654]: at Sourceanalytix.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5660:31)
                      host.ioBroker2	2021-01-14 14:40:50.033	error	Caught by controller[654]: at StateRedisClient.pushMessage (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:898:31)
                      host.ioBroker2	2021-01-14 14:40:50.033	error	Caught by controller[654]: at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:111:25)
                      host.ioBroker2	2021-01-14 14:40:50.033	error	Caught by controller[654]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:607:24)
                      host.ioBroker2	2021-01-14 14:40:50.033	error	Caught by controller[654]: Error: Connection is closed.
                      host.ioBroker2	2021-01-14 14:40:50.033	error	Caught by controller[654]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejec
                      host.ioBroker2	2021-01-14 14:40:50.032	error	Caught by controller[654]: at exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8457:28)
                      host.ioBroker2	2021-01-14 14:40:50.032	error	Caught by controller[654]: at Sourceanalytix.registerNotification (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5677:24)
                      host.ioBroker2	2021-01-14 14:40:50.032	error	Caught by controller[654]: at Sourceanalytix.sendToHostAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1618:16)
                      host.ioBroker2	2021-01-14 14:40:50.032	error	Caught by controller[654]: at new Promise (<anonymous>)
                      host.ioBroker2	2021-01-14 14:40:50.032	error	Caught by controller[654]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1619:16
                      host.ioBroker2	2021-01-14 14:40:50.032	error	Caught by controller[654]: at Sourceanalytix.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5660:31)
                      host.ioBroker2	2021-01-14 14:40:50.032	error	Caught by controller[654]: at StateRedisClient.pushMessage (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:898:31)
                      host.ioBroker2	2021-01-14 14:40:50.032	error	Caught by controller[654]: at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:111:25)
                      host.ioBroker2	2021-01-14 14:40:50.032	error	Caught by controller[654]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:607:24)
                      host.ioBroker2	2021-01-14 14:40:50.032	error	Caught by controller[654]: Error: Connection is closed.
                      host.ioBroker2	2021-01-14 14:40:50.032	error	Caught by controller[654]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejec
                      host.ioBroker2	2021-01-14 14:40:50.031	error	Caught by controller[654]: at process.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8477:45)
                      host.ioBroker2	2021-01-14 14:40:50.031	error	Caught by controller[654]: at exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8457:28)
                      host.ioBroker2	2021-01-14 14:40:50.031	error	Caught by controller[654]: at Sourceanalytix.registerNotification (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5677:24)
                      host.ioBroker2	2021-01-14 14:40:50.031	error	Caught by controller[654]: at Sourceanalytix.sendToHostAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1618:16)
                      host.ioBroker2	2021-01-14 14:40:50.031	error	Caught by controller[654]: at new Promise (<anonymous>)
                      host.ioBroker2	2021-01-14 14:40:50.031	error	Caught by controller[654]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1619:16
                      host.ioBroker2	2021-01-14 14:40:50.031	error	Caught by controller[654]: at Sourceanalytix.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5660:31)
                      host.ioBroker2	2021-01-14 14:40:50.031	error	Caught by controller[654]: at StateRedisClient.pushMessage (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:898:31)
                      host.ioBroker2	2021-01-14 14:40:50.031	error	Caught by controller[654]: at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:111:25)
                      host.ioBroker2	2021-01-14 14:40:50.031	error	Caught by controller[654]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:607:24)
                      host.ioBroker2	2021-01-14 14:40:50.031	error	Caught by controller[654]: Error: Connection is closed.
                      host.ioBroker2	2021-01-14 14:40:50.031	error	Caught by controller[654]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejec
                      host.ioBroker2	2021-01-14 14:40:50.030	error	Caught by controller[654]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1619:16
                      host.ioBroker2	2021-01-14 14:40:50.030	error	Caught by controller[654]: at Sourceanalytix.sendToHost (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5660:31)
                      host.ioBroker2	2021-01-14 14:40:50.030	error	Caught by controller[654]: at StateRedisClient.pushMessage (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:898:31)
                      host.ioBroker2	2021-01-14 14:40:50.030	error	Caught by controller[654]: at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:111:25)
                      host.ioBroker2	2021-01-14 14:40:50.030	error	Caught by controller[654]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:607:24)
                      host.ioBroker2	2021-01-14 14:40:50.030	error	Caught by controller[654]: Error: Connection is closed.
                      host.ioBroker2	2021-01-14 14:40:50.030	error	Caught by controller[654]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejec
                      host.ioBroker2	2021-01-14 14:40:50.030	error	Caught by controller[654]: at process.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8477:45)
                      host.ioBroker2	2021-01-14 14:40:50.030	error	Caught by controller[654]: at exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8457:28)
                      host.ioBroker2	2021-01-14 14:40:50.030	error	Caught by controller[654]: at Sourceanalytix.registerNotification (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5677:24)
                      host.ioBroker2	2021-01-14 14:40:50.030	error	Caught by controller[654]: at Sourceanalytix.sendToHostAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1618:16)
                      host.ioBroker2	2021-01-14 14:40:50.030	error	Caught by controller[654]: at new Promise (<anonymous>)
                      Redis hab ich nicht...
                      Plopp...System down...ich starte es mal neu. AUslastung über 100%. Komm nirgends mehr dran ^^
                      Dutchman 2 Replies Last reply Reply Quote 0
                      • Dutchman
                        Dutchman Developer Most Active Administrators @Kueppert last edited by
                        @kueppert said in [SourceAnalytix 0.4.8-RC.1] Stable version announcement:
                        welcher js-controller ?
                          @dutchman der neue 3.2.6-0. Wollte gerade via Putty neu starten, nochmal schnell in die Weboberfläche geschaut. Nun starten alle Adapter gerade neu O.o
                          Auslastung gerade von 120% auf 85% runter gem. Proxmox.
                          • Dutchman
                            Das ist ein Fehler im 3.2-x nicht SA
                              @dutchman alles klar. Ich starte die Maschine jetzt mal neu. Scheint sich zwar alles beruhigt zu haben...aber dann schaue ich nochmal, was dann passiert ^^
                              Soll ich beim JS-Controller 3.2-Thread irgendwas posten?
                              • Dutchman
                                ja bitte log dort posten 🙂 ich kan im code von SA damit leider nix
                                  @dutchman oh man...hab dich mit Apollon verwechselt - bzw euch als eine Person gesehen bis gerade hahaha. Habs dort gepostet ^^
                                  NACHTRAG für alle, die ggf das gleiche Problem haben:
                                  https://forum.iobroker.net/topic/40725/beta-test-js-controller-3-2-x-auf-github/187?_=1610605750979
                                  • Dutchman
                                    sourceanalytix.0 2021-01-14 14:42:00.623 warn (14935) State "sourceanalytix.0.alias__0__Stromverbrauch__total__Serverschrank.currentYear.consumed.2021.05_currentYear" has no existing object, this might lead to an error in future versions sourceanalytix.0 2021-01-14 14:41:47.017 warn (14935) State "sourceanalytix.0.alias__0__Stromverbrauch__total__Serverschrank.currentYear.consumed.2021.05_currentYear" has no existing object, this might lead to an error in future versions
                                    Das sollte in der letzte git version des code (wird alpha 13) behoben sein
                                      @dutchman danke dir. Jetzt traue ich mich aber nicht mehr, nen Update zu machen 😄
                                      • Dutchman
                                        neh warte mal auf den neue JS-Controller beta wo die loop auch raus ist.... Fehler ist bereits gefunden hab mal schnell mit Ingo geschnackt.
                                          @dutchman
                                          Sorry die späte Antwort. Ich hatte eine Meetings laufen.
                                          Ich spiele jetzt mal die neue Version ein und berichte gleich.
                                            MartyBr @MartyBr last edited by
                                            @Dutchman
                                            Installation auf die 12-Version durchgeführt :
                                            sourceanalytix.0	2021-01-14 18:03:13.495	error	(4347) Troubleshoot Data alias.0.Verbrauch.Strom.HWR.Waschmaschine-ENERGY_COUNTER custom Data : {"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1610619988422,"common":{"name
                                            sourceanalytix.0	2021-01-14 18:03:13.495	error	(4347) Check settings for alias.0.Verbrauch.Strom.HWR.Waschmaschine-ENERGY_COUNTER ! Known valueAtDeviceReset : (84934.61192092283) > known cumulative value (66540.92233804846) cannot proceed
                                            Der Autor ist ein Homematic:
                                            2302
                                            1131421
