    4. Test Adapter fb-checkpresence v1.1.x
    • Fenriswolf
      Fenriswolf @afuerhoff last edited by Fenriswolf
      @afuerhoff said in Test Adapter fb-checkpresence v1.1.x:
      ich habe die Version 1.1.2 auf Github zum Testen veröffentlicht. Die Änderungen sind im ersten Beitrag beschrieben. Bitte gebt Rückmeldung, ob alles funktioniert.
      habe jetzt folgende Eintragungen im Log:
      2021-01-14 07:32:33.719 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LANBridge
      2021-01-14 07:32:33.720 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
      2021-01-14 07:32:33.720 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:1
      2021-01-14 07:32:33.721 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:2
      2021-01-14 07:32:33.721 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
      2021-01-14 07:32:33.721 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:3
      2021-01-14 07:32:33.722 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
      2021-01-14 07:32:33.722 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:4
      2021-01-14 07:32:33.722 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.WAN:1
      2021-01-14 07:32:33.723 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
      2021-01-14 07:32:33.723 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:5G:0
      2021-01-14 07:32:33.723 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:2G:0
      2021-01-14 07:32:33.724 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
      2021-01-14 07:32:33.724 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:5G:0
      2021-01-14 07:32:33.725 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:2G:0
      2021-01-14 07:32:33.725 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
      2021-01-14 07:43:11.613 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LANBridge
      2021-01-14 07:43:11.614 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
      2021-01-14 07:43:11.615 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:1
      2021-01-14 07:43:11.615 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
      2021-01-14 07:43:11.616 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:2
      2021-01-14 07:43:11.616 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
      2021-01-14 07:43:11.616 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:3
      2021-01-14 07:43:11.617 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
      2021-01-14 07:43:11.617 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.LAN:4
      2021-01-14 07:43:11.618 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
      2021-01-14 07:43:11.618 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.WAN:1
      2021-01-14 07:43:11.618 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:5G:0
      2021-01-14 07:43:11.619 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
      2021-01-14 07:43:11.619 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.GUEST:2G:0
      2021-01-14 07:43:11.620 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:5G:0
      2021-01-14 07:43:11.620 - warn: fb-checkpresence.0 (5072) createMeshObjects: {}
      2021-01-14 07:43:11.620 - info: fb-checkpresence.0 (5072) New interface found: fritz-box.AP:2G:0
      alle 11 Minuten
      bis denne
      sigi234 afuerhoff 2 Replies Last reply Reply Quote 0
        sigi234 Forum Testing Most Active @Fenriswolf last edited by sigi234
        @fenriswolf
        Kann ich bestätigen.
        Es werden auch keine Devices angelegt.
        Wobei ich die Beta vom JS controller Installiert: 3.2.6-0 habe.
        Dadurch kommen auch massenweise diese Warn:
        fb-checkpresence.0	2021-01-14 10:35:15.977	warn	(5232) State "fb-checkpresence.0.fb-devices.fritz-box.AP:2G:0.link" has no existing object, this might lead to an error in future versions
        fb-checkpresence.0	2021-01-14 10:35:15.976	warn	(5232) State "fb-checkpresence.0.fb-devices.fritz-box.AP:2G:0.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
        fb-checkpresence.0	2021-01-14 10:35:15.976	warn	(5232) State "fb-checkpresence.0.fb-devices.fritz-box.AP:2G:0.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
        • afuerhoff
          afuerhoff Developer @TG70 last edited by
          @tg70 said in Test Adapter fb-checkpresence v1.1.x:
          Steht bei mir auf 10s. Wie gesagt Offlie Zustand dauert bis 10 Minuten. Online geht schneller ca. <= 1 Min.
          Hallo, hast Du das schon mit der neuen Version getestet. In der 1.1.1 war noch ein Bug bei 10s Einstellung.
          • afuerhoff
            afuerhoff Developer @Fenriswolf last edited by
            @fenriswolf said in Test Adapter fb-checkpresence v1.1.x:
            Da hat sich ein Fehler eingeschlichen. Korrigiere ich.
            • afuerhoff
              afuerhoff Developer @sigi234 last edited by
              @Fenriswolf @sigi234
              Ich habe ein Update hochgeladen. Bitte neu testen. Am Besten einmal die Objekte unter fb-devices löschen. Die sind falsch angelegt worden.
              sigi234 Fenriswolf 3 Replies Last reply Reply Quote 0
                sigi234 Forum Testing Most Active @afuerhoff last edited by
                Schaut wieder gut aus. Bis auf die Warn wegen Beta JS Controller.
                afuerhoff 1 Reply Last reply Reply Quote 0
                • afuerhoff
                  @sigi234
                  Welche Warnungen meinst du ? Die vom Post oben?
                  Hast Du die Objekte einmal gelöscht?
                    Ja
                    Log:
                    2021-01-14 21:51:08.500 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.name" has no existing object, this might lead to an error in future versions
                    2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.link" has no existing object, this might lead to an error in future versions
                    2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.rx_rcpi" has no existing object, this might lead to an error in future versions
                    2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
                    2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
                    2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.type" has no existing object, this might lead to an error in future versions
                    2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.name" has no existing object, this might lead to an error in future versions
                    2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.link" has no existing object, this might lead to an error in future versions
                    2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.rx_rcpi" has no existing object, this might lead to an error in future versions
                    2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
                    2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
                    2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.type" has no existing object, this might lead to an error in future versions
                    2021-01-14 21:51:08.503 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Buero.WLAN.name" has no existing object, this might lead to an error in future versions
                    2021-01-14 21:51:08.503 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Buero.WLAN.link" has no existing object, this might lead to an error in future versions
                    • afuerhoff
                      @sigi234
                      Kannst Du mal ein Bild der entsprechenden Objekte posten. CCU3 sollte z.B. als Device angelegt sein.
                        sigi234 Forum Testing Most Active @afuerhoff last edited by sigi234
                        @sigi234
                        RAW Lan Name:
                          "from": "system.adapter.fb-checkpresence.0",
                          "user": "system.user.admin",
                          "ts": 1610657469997,
                          "common": {
                            "name": "fb-devices.CCU3.LAN.name",
                            "desc": "name of the interface",
                            "role": "value",
                            "type": "string",
                            "def": "",
                            "read": true,
                            "write": false
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "owner": "system.user.admin",
                            "state": 1636
                          "_id": "fb-checkpresence.0.fb-devices.CCU3.LAN.name",
                          "type": "state"
                        afuerhoff R 2 Replies Last reply Reply Quote 0
                        • afuerhoff
                          @sigi234
                          Da verstehe ich die Meldung vom JS-Controller nicht. Ist doch als Objekt angelegt.
                          • Fenriswolf
                            Werde ich morgen im Laufe des Tages testen und berichten.
                              @sigi234
                              Ja, ist bei andere Adapter auch so.
                              Neueste Meldung:
                              fb-checkpresence.0	2021-01-14 22:42:56.416	error	(8292) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
                              • afuerhoff
                                @sigi234
                                Kannst Du mal das Log vom Start an posten. Da kommen die Meldungen was alles unterstützt wird.
                                  @sigi234
                                  fb-checkpresence.0	2021-01-14 23:06:34.085	debug	(9028) loopFamily ends after 5,187158400 s
                                  fb-checkpresence.0	2021-01-14 23:06:33.426	debug	(9028) Handy-xxx: No history item before this day is available
                                  fb-checkpresence.0	2021-01-14 23:06:33.426	debug	(9028) history Handy-xxx cntHistory: 15421
                                  fb-checkpresence.0	2021-01-14 23:06:33.230	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                                  fb-checkpresence.0	2021-01-14 23:06:33.230	debug	(9028) history cntActualDay: 15422
                                  fb-checkpresence.0	2021-01-14 23:06:33.059	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                                  fb-checkpresence.0	2021-01-14 23:06:32.102	debug	(9028) Handy-Ilse: No history item before this day is available
                                  fb-checkpresence.0	2021-01-14 23:06:32.102	debug	(9028) history Handy-xxxx cntHistory: 15424
                                  fb-checkpresence.0	2021-01-14 23:06:31.869	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                                  fb-checkpresence.0	2021-01-14 23:06:31.869	debug	(9028) history cntActualDay: 15425
                                  fb-checkpresence.0	2021-01-14 23:06:31.622	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                                  fb-checkpresence.0	2021-01-14 23:06:30.784	debug	(9028) Handy-xxxxxx: No history item before this day is available
                                  fb-checkpresence.0	2021-01-14 23:06:30.783	debug	(9028) history Handy-xxxxxx cntHistory: 15422
                                  fb-checkpresence.0	2021-01-14 23:06:30.410	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                                  fb-checkpresence.0	2021-01-14 23:06:30.409	debug	(9028) history cntActualDay: 15423
                                  fb-checkpresence.0	2021-01-14 23:06:29.928	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                                  fb-checkpresence.0	2021-01-14 23:06:29.904	debug	(9028) getDeviceList: [{"Index":"1","IPAddress":"192.168.178.99","MACAddress":"xxxxxxxxxx","Active":"1","HostName":"CCU3","InterfaceType":"Ethernet","X_AVM-DE_Port":"1","X_AVM-DE_Speed":"1000",
                                  fb-checkpresence.0	2021-01-14 23:05:37.540	info	(9028) createFbDeviceObjects finished successfully
                                  fb-checkpresence.0	2021-01-14 23:05:36.457	debug	(9028) getDeviceList: [{"Index":"1","IPAddress":"192.168.178.99","MACAddress":"xxxxxxx","Active":"1","HostName":"CCU3","InterfaceType":"Ethernet","X_AVM-DE_Port":"1","X_AVM-DE_Speed":"1000",
                                  fb-checkpresence.0	2021-01-14 23:05:35.845	debug	(9028) system.adapter.admin.0: logging true
                                  fb-checkpresence.0	2021-01-14 23:05:35.693	info	(9028) createMemberObjects finished successfully
                                  fb-checkpresence.0	2021-01-14 23:05:35.688	debug	(9028) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                                  fb-checkpresence.0	2021-01-14 23:05:35.594	debug	(9028) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                                  fb-checkpresence.0	2021-01-14 23:05:35.461	debug	(9028) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                                  fb-checkpresence.0	2021-01-14 23:05:35.367	info	(9028) createGlobalObjects finished successfully
                                  fb-checkpresence.0	2021-01-14 23:05:35.159	debug	(9028) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
                                  fb-checkpresence.0	2021-01-14 23:05:35.152	info	(9028) service LANConfigSecurity1-X_AVM-DE_GetCurrentUser is supported
                                  fb-checkpresence.0	2021-01-14 23:05:35.148	info	(9028) service DeviceConfig1-Reboot is supported
                                  fb-checkpresence.0	2021-01-14 23:05:35.143	info	(9028) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
                                  fb-checkpresence.0	2021-01-14 23:05:35.139	info	(9028) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
                                  fb-checkpresence.0	2021-01-14 23:05:35.134	info	(9028) service DeviceInfo1-GetInfo is supported
                                  fb-checkpresence.0	2021-01-14 23:05:35.129	info	(9028) service WLANConfiguration3-GetSecurityKeys is supported
                                  fb-checkpresence.0	2021-01-14 23:05:35.124	info	(9028) service WLANConfiguration3-GetInfo is supported
                                  fb-checkpresence.0	2021-01-14 23:05:35.117	info	(9028) service WLANConfiguration3-SetEnable is supported
                                  fb-checkpresence.0	2021-01-14 23:05:35.112	info	(9028) service WANPPPConnection1-GetInfo is supported
                                  fb-checkpresence.0	2021-01-14 23:05:35.106	info	(9028) service DeviceInfo1-GetSecurityPort is supported
                                  fb-checkpresence.0	2021-01-14 23:05:35.101	info	(9028) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                                  fb-checkpresence.0	2021-01-14 23:05:35.096	info	(9028) service Hosts1-GetSpecificHostEntry is supported
                                  fb-checkpresence.0	2021-01-14 23:05:35.091	info	(9028) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                                  fb-checkpresence.0	2021-01-14 23:05:35.084	info	(9028) service Hosts1-X_AVM-DE_GetHostListPath is supported
                                  fb-checkpresence.0	2021-01-14 23:05:35.078	debug	(9028) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"220","Major":"148","Minor":"7","Patch":"20","Bui
                                  fb-checkpresence.0	2021-01-14 23:05:34.984	debug	(9028) configuratuion mesh info: true
                                  fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration fb-devices true
                                  fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration familymembers: [{"familymember":"Handy-xxxxxxxx-Privat","macaddress":"xxxxxxxxxx","ipaddress":"192.168.178.47","useip":true,"usename":true,"comment":"","enabled":true},{"famil
                                  fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration dateformat: <dd.mm.yyyy HH:MM>
                                  fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration history: <history.0>
                                  fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration user: <iobroker>
                                  fb-checkpresence.0	2021-01-14 23:05:34.982	info	(9028) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 2 Min. - interval members: 60 s
                                  fb-checkpresence.0	2021-01-14 23:05:34.975	info	(9028) starting. Version 1.1.2 in C:/Program Files/iobroker/Test/node_modules/iobroker.fb-checkpresence, node: v12.20.1, js-controller: 3.2.6-0
                                  fb-checkpresence.0	2021-01-14 23:05:34.828	debug	(9028) statesDB connected
                                  fb-checkpresence.0	2021-01-14 23:05:34.827	debug	(9028) States connected to redis: 127.0.0.1:9000
                                  fb-checkpresence.0	2021-01-14 23:05:34.820	debug	(9028) States create User PubSub Client
                                  fb-checkpresence.0	2021-01-14 23:05:34.819	debug	(9028) States create System PubSub Client
                                  fb-checkpresence.0	2021-01-14 23:05:34.814	debug	(9028) Redis States: Use Redis connection: 127.0.0.1:9000
                                  fb-checkpresence.0	2021-01-14 23:05:34.813	debug	(9028) objectDB connected
                                  fb-checkpresence.0	2021-01-14 23:05:34.810	debug	(9028) Objects connected to redis: 127.0.0.1:9013
                                  fb-checkpresence.0	2021-01-14 23:05:34.794	debug	(9028) Objects client initialize lua scripts
                                  fb-checkpresence.0	2021-01-14 23:05:34.793	debug	(9028) Objects create User PubSub Client
                                  fb-checkpresence.0	2021-01-14 23:05:34.793	debug	(9028) Objects create System PubSub Client
                                  fb-checkpresence.0	2021-01-14 23:05:34.792	debug	(9028) Objects client ready ... initialize now
                                  fb-checkpresence.0	2021-01-14 23:05:34.775	debug	(9028) Redis Objects: Use Redis connection: 127.0.0.1:9013
                                  fb-checkpresence.0	2021-01-14 23:05:30.727	info	(15940) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  fb-checkpresence.0	2021-01-14 23:05:30.727	info	(15940) terminating
                                  fb-checkpresence.0	2021-01-14 23:05:30.726	info	(15940) cleaned everything up ...
                                  fb-checkpresence.0	2021-01-14 23:05:30.726	info	(15940) Got terminate signal TERMINATE_YOURSELF
                                  • afuerhoff
                                    @sigi234 said in Test Adapter fb-checkpresence v1.1.x:
                                    Neueste Meldung:
                                    Kommt die Meldung regelmäßig? Es wäre hilfreich zu wissen welche anderen Meldungen davor oder danach kommen.
                                      Nein
                                      fb-checkpresence.0	2021-01-14 23:22:13.034	info	(15516) createFbDeviceObjects finished successfully
                                      fb-checkpresence.0	2021-01-14 23:22:10.412	info	(15516) createMemberObjects finished successfully
                                      fb-checkpresence.0	2021-01-14 23:22:10.021	info	(15516) createGlobalObjects finished successfully
                                      fb-checkpresence.0	2021-01-14 23:22:09.823	info	(15516) service LANConfigSecurity1-X_AVM-DE_GetCurrentUser is supported
                                      fb-checkpresence.0	2021-01-14 23:22:09.819	info	(15516) service DeviceConfig1-Reboot is supported
                                      fb-checkpresence.0	2021-01-14 23:22:09.814	info	(15516) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
                                      fb-checkpresence.0	2021-01-14 23:22:09.809	info	(15516) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
                                      fb-checkpresence.0	2021-01-14 23:22:09.805	info	(15516) service DeviceInfo1-GetInfo is supported
                                      fb-checkpresence.0	2021-01-14 23:22:09.800	info	(15516) service WLANConfiguration3-GetSecurityKeys is supported
                                      fb-checkpresence.0	2021-01-14 23:22:09.795	info	(15516) service WLANConfiguration3-GetInfo is supported
                                      fb-checkpresence.0	2021-01-14 23:22:09.789	info	(15516) service WLANConfiguration3-SetEnable is supported
                                      fb-checkpresence.0	2021-01-14 23:22:09.783	info	(15516) service WANPPPConnection1-GetInfo is supported
                                      fb-checkpresence.0	2021-01-14 23:22:09.777	info	(15516) service DeviceInfo1-GetSecurityPort is supported
                                      fb-checkpresence.0	2021-01-14 23:22:09.772	info	(15516) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                                      fb-checkpresence.0	2021-01-14 23:22:09.767	info	(15516) service Hosts1-GetSpecificHostEntry is supported
                                      fb-checkpresence.0	2021-01-14 23:22:09.763	info	(15516) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                                      fb-checkpresence.0	2021-01-14 23:22:09.757	info	(15516) service Hosts1-X_AVM-DE_GetHostListPath is supported
                                      fb-checkpresence.0	2021-01-14 23:22:09.677	info	(15516) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 2 Min. - interval members: 60 s
                                      fb-checkpresence.0	2021-01-14 23:22:09.671	info	(15516) starting. Version 1.1.2 in C:/Program Files/iobroker/Test/node_modules/iobroker.fb-checkpresence, node: v12.20.1, js-controller: 3.2.6-0
                                      host.Medion(Test)	2021-01-14 23:22:08.889	info	instance system.adapter.fb-checkpresence.0 started with pid 15516
                                      host.Medion(Test)	2021-01-14 23:22:06.454	info	instance system.adapter.fb-checkpresence.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      host.Medion(Test)	2021-01-14 23:22:05.792	info	stopInstance system.adapter.fb-checkpresence.0 send kill signal
                                      fb-checkpresence.0	2021-01-14 23:22:05.796	info	(13144) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      fb-checkpresence.0	2021-01-14 23:22:05.796	info	(13144) terminating
                                      fb-checkpresence.0	2021-01-14 23:22:05.795	info	(13144) cleaned everything up ...
                                      fb-checkpresence.0	2021-01-14 23:22:05.792	info	(13144) Got terminate signal TERMINATE_YOURSELF
                                      Jetzt schaut es wieder normal aus. Denke es hat was mit den JS Controller zu tun.
                                      • afuerhoff
                                        @sigi234
                                        Bitte mal beobachten.
                                        Hast Du schon mal den QR-Code vom Gäste Wlan testen können?
                                          @sigi234
                                          Gerade dabei, warte kurz.
                                          Keine Anzeige?
                                          • afuerhoff
                                            afuerhoff Developer @sigi234 last edited by afuerhoff
                                            @sigi234
                                            Hast Du mit dem Basic Bool SVG Widget gemacht?
                                            Hatte ich auch etwas nach gesucht
                                            avm fb-checkpresence fritzbox tr-064
                                            88
                                            947
                                            256205
