    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      mtbsteve last edited by
      @tombox ich bekomme beim ändern von parametern (egal welche) in der Version 0.23 ständig Fehler:
      vw-connect.0	2021-01-14 14:23:51.378	error	(25033) failed set state targetSOC_pct
      vw-connect.0	2021-01-14 14:23:51.378	error	(25033) "code=401, message=Unauthorized"
      vw-connect.0	2021-01-14 14:23:51.377	error	(25033) 401
      vw-connect.0	2021-01-14 14:23:48.086	error	(25033) failed set state windowHeatingEnabled
      vw-connect.0	2021-01-14 14:23:48.086	error	(25033) "code=401, message=Unauthorized"
      vw-connect.0	2021-01-14 14:23:48.086	error	(25033) 401
      web.0	2021-01-14 14:23:45.349	info	(2015) ==>Connected system.user.admin from ::1
      web.0	2021-01-14 14:23:44.831	info	(2015) <==Disconnect system.user.admin from ::1 vis.0
      vw-connect.0	2021-01-14 14:23:43.411	error	(25033) failed set state targetTemperature_C
      vw-connect.0	2021-01-14 14:23:43.411	error	(25033) "code=401, message=Unauthorized"
      vw-connect.0	2021-01-14 14:23:43.410	error	(25033) 401
      vw-connect.0	2021-01-14 14:23:42.418	error	(25033) failed set state targetTemperature_C
      vw-connect.0	2021-01-14 14:23:42.418	error	(25033) "code=401, message=Unauthorized"
      vw-connect.0	2021-01-14 14:23:42.417	error	(25033) 401
      vw-connect.0	2021-01-14 14:23:42.397	error	(25033) failed set state targetTemperature_C
      vw-connect.0	2021-01-14 14:23:42.397	error	(25033) "code=401, message=Unauthorized"
      vw-connect.0	2021-01-14 14:23:42.396	error	(25033) 401
      vw-connect.0	2021-01-14 14:23:41.381	error	(25033) failed set state targetTemperature_C
      vw-connect.0	2021-01-14 14:23:41.380	error	(25033) "code=401, message=Unauthorized"
      vw-connect.0	2021-01-14 14:23:41.380	error	(25033) 401
      vw-connect.0	2021-01-14 14:23:41.306	error	(25033) failed set state targetTemperature_C
      vw-connect.0	2021-01-14 14:23:41.306	error	(25033) "code=401, message=Unauthorized"
      vw-connect.0	2021-01-14 14:23:41.305	error	(25033) 401
      vw-connect.0	2021-01-14 14:23:40.295	error	(25033) failed set state targetTemperature_C
      vw-connect.0	2021-01-14 14:23:40.295	error	(25033) "code=401, message=Unauthorized"
      vw-connect.0	2021-01-14 14:23:40.294	error	(25033) 401
      vw-connect.0	2021-01-14 14:23:37.954	error	(25033) failed set state targetTemperature_C
      vw-connect.0	2021-01-14 14:23:37.953	error	(25033) "code=401, message=Unauthorized"
      vw-connect.0	2021-01-14 14:23:37.952	error	(25033) 401
      vw-connect.0	2021-01-14 14:23:16.190	info	(25033) starting. Version 0.0.23 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.20.0, js-controller: 3.1.6
      In der VW ID app funktioniert es einwandfrei. In der Version 0.21 des Adapters konnte ich zumindest die Charging Parameter setzen. Any idea?
      Fahrzeug: ID3, Software 0564
      Danke!
        tombox @mtbsteve last edited by
        @mtbsteve Hast du via github oder normal iobroker 0.23 installiert?
          mtbsteve @tombox last edited by
          @tombox via github
            @mtbsteve Bitte nochmal probieren
              @tombox gerade die V0.23 neu über github installiert. Die Fehlermeldungen sind anders, das setzen von Parametern geht immer noch nicht:
              vw-connect.0	2021-01-14 16:12:26.437	info	(27115) starting. Version 0.0.23 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.20.0, js-controller: 3.1.6
              host.stephan-Aspire-A315-53	2021-01-14 16:12:25.186	info	instance system.adapter.vw-connect.0 started with pid 27115
              host.stephan-Aspire-A315-53	2021-01-14 16:11:55.176	info	Restart adapter system.adapter.vw-connect.0 because enabled
              host.stephan-Aspire-A315-53	2021-01-14 16:11:55.176	info	instance system.adapter.vw-connect.0 terminated with code 0 (NO_ERROR)
              host.stephan-Aspire-A315-53	2021-01-14 16:11:55.176	error	Caught by controller[1]: undefined
              host.stephan-Aspire-A315-53	2021-01-14 16:11:55.175	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
              vw-connect.0	2021-01-14 16:11:54.666	info	(27070) Terminated (NO_ERROR): Without reason
              vw-connect.0	2021-01-14 16:11:54.666	info	(27070) terminating
              vw-connect.0	2021-01-14 16:11:54.571	info	(27070) cleaned everything up...
              vw-connect.0	2021-01-14 16:11:54.571	error	(27070) unhandled promise rejection: undefined
              vw-connect.0	2021-01-14 16:11:54.571	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              vw-connect.0	2021-01-14 16:11:54.570	error	(27070) 400
              vw-connect.0	2021-01-14 16:11:54.341	error	(27070) failed set state targetTemperature_C
              vw-connect.0	2021-01-14 16:11:54.340	error	(27070) Refresh Token
              vw-connect.0	2021-01-14 16:11:54.340	error	(27070) "code=401, message=Unauthorized"
              vw-connect.0	2021-01-14 16:11:54.339	error	(27070) 401
              web.0	2021-01-14 16:11:34.654	info	(2015) <==Disconnect system.user.admin from ::1 vis.0
              web.0	2021-01-14 16:11:30.757	info	(2015) ==>Connected system.user.admin from ::1
              web.0	2021-01-14 16:11:30.318	info	(2015) <==Disconnect system.user.admin from ::1 vis.0
              web.0	2021-01-14 16:11:24.563	info	(2015) ==>Connected system.user.admin from ::1
              web.0	2021-01-14 16:11:23.744	info	(2015) <==Disconnect system.user.admin from ::1 vis.0
              vw-connect.0	2021-01-14 16:09:23.257	info	(27070) starting. Version 0.0.23 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.20.0, js-controller: 3.1.6
              host.stephan-Aspire-A315-53	2021-01-14 16:09:21.938	info	instance system.adapter.vw-connect.0 started with pid 27070
              host.stephan-Aspire-A315-53	2021-01-14 16:08:51.931	info	Restart adapter system.adapter.vw-connect.0 because enabled
                tombox @mtbsteve last edited by tombox
                @mtbsteve die chargeandpay einträge sind jetzt drin. Aktuelle session sollte unter:
                vw-connect.0.wecharge.homecharging.stations.xxxx... sein
                • Glasfaser
                  Glasfaser last edited by
                  @wszene said in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                  Ich bekomme jetzt verdammt viele Telegrams
                  Nimm das :
                   <variables>
                     <variable id="$ZBG[fEIeDUoMc{ekk0/">sperre</variable>
                   </variables>
                   <block type="variables_set" id="@r$S6|53Lf^0!A`830mY" x="38" y="38">
                     <field name="VAR" id="$ZBG[fEIeDUoMc{ekk0/">sperre</field>
                       <block type="logic_boolean" id="A(URtf8zPanx0N_tk}FI">
                       <block type="on" id="}ZWON=|p^MkmJ,t;Ap!s">
                         <field name="OID">0_userdata.0.1</field>
                           <block type="controls_if" id="w=%`ceyfS!J-,|8wzey=">
                               <block type="logic_operation" id="pY@4UwU%iWFRrT5*]o7G">
                                 <field name="OP">AND</field>
                                   <block type="logic_compare" id="GT{^i}l+r*[@AC~phuua">
                                     <field name="OP">GTE</field>
                                       <block type="on_source" id="2i}B._Ao**P{xtuc)0RI">
                                       <block type="math_number" id="8qi:NO(LFv@}rT%@j5%}">
                                         <field name="NUM">1</field>
                                   <block type="logic_compare" id="E-jEsb@oM@h7Z^xhuIMi">
                                     <field name="OP">EQ</field>
                                       <block type="variables_get" id="n3ZbxZpr~uaaW]Gubt.W">
                                       <block type="logic_boolean" id="zf)OZe*6~Oqnj^whmW;B">
                               <block type="variables_set" id="8oR4HfM?9T{va4@4QKDS">
                                   <block type="logic_boolean" id="oW9;zQH2T2:[#m]T[kVa">
                                   <block type="telegram" id="|){3Af,jNedzEwOJHER+">
                                     <field name="INSTANCE">.4</field>
                                     <field name="LOG"></field>
                                     <value name="MESSAGE">
                                       <shadow type="text" id="KKV2~AWrAtL]kgg*o(?$">
                                         <field name="TEXT">an</field>
                             <value name="IF1">
                               <block type="logic_operation" id=":)HRy=h%s-pB=GQDdA{B">
                                   <block type="logic_compare" id="*2=1[f8*{)J%mxg3Pzb|">
                                     <field name="OP">LT</field>
                                       <block type="on_source" id="RQ_auc-o-ZPNHl60k]^Y">
                                       <block type="math_number" id="6VM?nZ8jDgdtX~V@tBp=">
                                   <block type="logic_compare" id="x0)Cj$@EHlj7w*(6h1mF">
                                       <block type="variables_get" id="cp{E)9ngNElflcok06V!">
                                       <block type="logic_boolean" id=".P_eTp,k:VASHWHwX@!l">
                             <statement name="DO1">
                               <block type="variables_set" id="^9pP@/8Ws!Mpds3oa.Og">
                                   <block type="logic_boolean" id="Xrq9Ph8Q}S]]q_v54}4]">
                                   <block type="telegram" id="`vI[nCh/lt{IX4p/fIYg">
                                       <shadow type="text" id="~fM,TqT#){`|eAhf+Iwk">
                                         <field name="TEXT">aus</field>
                  Wszene 1 Reply Last reply Reply Quote 0
                  • Wszene
                    Wszene @Glasfaser last edited by
                    @glasfaser
                    Danke dir das sieht gut aus aber ich habe da mal noch eine Frage
                    Was ist Sperre?
                    Muss ich da noch etwas anlegen?
                    • Glasfaser
                      Glasfaser @Wszene last edited by
                      @wszene
                      Es wird eine Variable genutzt , Sie wird beim Triggern deines Datenpunktes bei true (Telegram Heizung an) einmalig gesetzt .
                      Bei dem wiederholten triggern was bei dir ist ,wird halt die Funktion nicht mehr ausgeführt (Telegram senden Heizung an) , da die Variable auf false gesetzt ist ......
                      du kannst es so importieren , es wird alles automatisch angelegt .
                        Datensammler @tombox last edited by
                        @tombox
                        vielen Dank für die Integration des SEAT-Portals!
                        Ich habe den Adapter von guthub installiert, Version 0.0.23
                        Funktioniert auch prinzipiell (für SEAT Mii electric) aber ich bekomme nach einger Zeit folgende Fehler:
                        vw-connect.1	2021-01-15 10:10:10.095	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.brand:{"val":"Seat","ack":true,"ts":1610701810074,"q":0,"from":"system.adapter.vw-connect.1","user":"system.use
                        vw-connect.1	2021-01-15 10:10:10.089	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.requestId:{"val":"MSG-IVWB2193-1610701808811-71805-SES","ack":true,"ts":1610701810071,"q":0,"from":"system.adap
                        vw-connect.1	2021-01-15 10:10:10.078	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.systemId:{"val":"XID_APP_SEAT","ack":true,"ts":1610701810069,"q":0,"from":"system.adapter.vw-connect.1","user":
                        vw-connect.1	2021-01-15 10:10:10.050	debug	(24236) {"vehicleDataDetail":{"systemId":"XID_APP_SEAT","requestId":"MSG-IVWB2193-1610701808811-71805-SES","brand":"Seat","country":"DE","vin":"XXXXXXXXXXXXXXXXXX","isConnect":true,"isConnectSorglosRea
                        vw-connect.1	2021-01-15 10:10:09.565	error	(24236) status update Failed
                        vw-connect.1	2021-01-15 10:10:09.564	error	(24236) 429
                        vw-connect.1	2021-01-15 10:10:08.945	debug	(24236) {"homeRegion":{"baseUri":{"systemId":"ICTO-10487","content":"https://mal-1a.prd.ece.vwg-connect.com/api"}}}
                        vw-connect.1	2021-01-15 10:10:08.892	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.preferredLanguage:{"val":"de","ack":true,"ts":1610701808428,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin
                        vw-connect.1	2021-01-15 10:10:08.889	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.phoneNumbers:{"val":[{"uuid":"xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx","type":"PHONE_CONTACT_TYPE:MOBILE_GENERAL","number":"+000000
                        vw-connect.1	2021-01-15 10:10:08.886	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.businessIdentifierValue:{"val":"0ibPp05UQA6sC7pPflbY5MHnz8B","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-conne
                        vw-connect.1	2021-01-15 10:10:08.883	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.businessIdentifierType:{"val":"BUSINESS_IDENTIFIER_TYPE:MBB_ID","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-co
                        vw-connect.1	2021-01-15 10:10:08.880	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.nickname:{"val":"Muckii","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc
                        vw-connect.1	2021-01-15 10:10:08.878	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.salutation:{"val":"SALUTATION:MRS","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.
                        vw-connect.1	2021-01-15 10:10:08.875	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.lastName:{"val":"XXXXXXXXXXX","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin
                        vw-connect.1	2021-01-15 10:10:08.872	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.firstName:{"val":"XXXXXX","ack":true,"ts":1610701808426,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","l
                        vw-connect.1	2021-01-15 10:10:08.605	debug	(24236) getHomeRegion
                        vw-connect.1	2021-01-15 10:10:08.601	debug	(24236) {"userVehicles":{"vehicle":["XXXXXXXXXXXXXXXXXX"]}}
                        vw-connect.1	2021-01-15 10:10:08.301	debug	(24236) "{\"firstName\":\"XXXXXX\",\"lastName\":\"XXXXXXXXXXX\",\"salutation\":\"SALUTATION:MRS\",\"nickname\":\"Muckii\",\"businessIdentifierType\":\"BUSINESS_IDENTIFIER_TYPE:MBB_ID\",\"businessIdent
                        vw-connect.1	2021-01-15 10:10:07.870	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.info.connection:{"val":true,"ack":true,"ts":1610701807866,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc":1610
                        vw-connect.1	2021-01-15 10:10:07.858	debug	(24236) getData
                        vw-connect.1	2021-01-15 10:10:07.856	debug	(24236) Login successful
                        vw-connect.1	2021-01-15 10:10:07.254	debug	(24236) Error: Invalid protocol: seatconnect:
                        vw-connect.1	2021-01-15 10:10:06.503	debug	(24236) {"date":"Fri, 15 Jan 2021 09:10:06 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en-US","expires":"0","loc
                        vw-connect.1	2021-01-15 10:10:06.503	debug	(24236) ""
                        vw-connect.1	2021-01-15 10:10:06.069	debug	(24236) parsePasswordForm
                        vw-connect.1	2021-01-15 10:10:05.562	debug	(24236) parseEmailForm
                        vw-connect.1	2021-01-15 10:10:04.606	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.info.connection:{"val":false,"ack":true,"ts":1610701804595,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc":161
                        vw-connect.1	2021-01-15 10:10:04.603	silly	(24236) States system redis pmessage system.adapter.vw-connect.1.logLevel/system.adapter.vw-connect.1.logLevel:{"val":"silly","ack":true,"ts":1610701804577,"q":0,"from":"system.adapter.vw-connect.1","
                        Es sind auch noch andere Meldungen, an die komme ich gerade aber nicht und werde diese posten, wenn diese nochmal auftauchen.
                        Die Daten werden dann auch scheinbar nicht aktualisiert.
                        Hast Du da einen Tip für mich?
                        @fuchs1978: läuft es bei Dir ohne Probleme?
                        D T 2 Replies Last reply Reply Quote 0
                          aba320 @tombox last edited by aba320
                          @tombox Hallo hab gestern spät abend nochmal auf 23 via git update durchgeführt. es kommen alle 54 Minuten die Fehlermeldungen:
                          vw-connect.0	2021-01-15 10:33:07.091	info	(5958) starting. Version 0.0.23 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.20.1, js-controller: 3.1.6
                          host.raspberrypiiobroker	2021-01-15 10:33:03.199	info	instance system.adapter.vw-connect.0 started with pid 5958
                          host.raspberrypiiobroker	2021-01-15 10:33:00.681	info	instance system.adapter.vw-connect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          vw-connect.0	2021-01-15 10:33:00.092	info	(23070) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          vw-connect.0	2021-01-15 10:33:00.090	info	(23070) terminating
                          vw-connect.0	2021-01-15 10:33:00.089	info	(23070) cleaned everything up...
                          vw-connect.0	2021-01-15 10:33:00.088	info	(23070) Got terminate signal TERMINATE_YOURSELF
                          host.raspberrypiiobroker	2021-01-15 10:33:00.079	info	stopInstance system.adapter.vw-connect.0 send kill signal
                          host.raspberrypiiobroker	2021-01-15 10:33:00.073	info	stopInstance system.adapter.vw-connect.0 (force=false, process=true)
                          host.raspberrypiiobroker	2021-01-15 10:32:29.739	info	Update repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                          host.raspberrypiiobroker	2021-01-15 10:30:20.788	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                          ical.1	2021-01-15 10:30:20.264	info	(3530) Terminated (NO_ERROR): Without reason
                          host.raspberrypiiobroker	2021-01-15 10:30:17.142	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.raspberrypiiobroker	2021-01-15 10:30:15.847	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          ical.1	2021-01-15 10:30:15.204	info	(3530) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                          ical.1	2021-01-15 10:30:14.690	info	(3530) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.20.1, js-controller: 3.1.6
                          host.raspberrypiiobroker	2021-01-15 10:30:12.334	info	instance system.adapter.ical.1 started with pid 3530
                          host.raspberrypiiobroker	2021-01-15 10:30:10.074	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                          host.raspberrypiiobroker	2021-01-15 10:30:08.091	info	instance system.adapter.dwd.1 started with pid 3514
                          host.raspberrypiiobroker	2021-01-15 10:30:04.066	info	instance system.adapter.dwd.0 started with pid 3353
                          host.raspberrypiiobroker	2021-01-15 10:30:00.041	info	instance system.adapter.daswetter.0 started with pid 3334
                          vw-connect.0	2021-01-15 10:29:34.142	error	(23070) Failed relogin
                          vw-connect.0	2021-01-15 10:29:34.141	error	(23070) Error: Invalid protocol: skodaconnect:
                          vw-connect.0	2021-01-15 10:29:34.139	error	(23070) Failed in first login step
                          vw-connect.0	2021-01-15 10:29:33.047	error	(23070) Relogin
                          vw-connect.0	2021-01-15 10:29:33.046	error	(23070) 400
                          vw-connect.0	2021-01-15 10:29:33.046	error	(23070) {"errorCode":"REQUEST_DATA_INVALID","description":"invalid brand or token audience"}
                          vw-connect.0	2021-01-15 10:29:33.035	error	(23070) VwToken
                          host.raspberrypiiobroker	2021-01-15 10:15:16.285	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                          host.raspberrypiiobroker	2021-01-15 10:15:12.761	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.raspberrypiiobroker	2021-01-15 10:15:09.351	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.raspberrypiiobroker	2021-01-15 10:15:08.135	info	instance system.adapter.daswetter.0 started with pid 22655
                          host.raspberrypiiobroker	2021-01-15 10:15:04.086	info	instance system.adapter.dwd.0 started with pid 22640
                          host.raspberrypiiobroker	2021-01-15 10:15:00.040	info	instance system.adapter.dwd.1 started with pid 22620
                          host.raspberrypiiobroker	2021-01-15 10:00:21.104	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                          ical.1	2021-01-15 10:00:20.584	info	(10006) Terminated (NO_ERROR): Without reason
                          host.raspberrypiiobroker	2021-01-15 10:00:15.932	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          ical.1	2021-01-15 10:00:15.531	info	(10006) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                          ical.1	2021-01-15 10:00:15.084	info	(10006) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.20.1, js-controller: 3.1.6
                          host.raspberrypiiobroker	2021-01-15 10:00:14.986	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.raspberrypiiobroker	2021-01-15 10:00:12.462	info	instance system.adapter.ical.1 started with pid 10006
                          host.raspberrypiiobroker	2021-01-15 10:00:08.856	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                          host.raspberrypiiobroker	2021-01-15 10:00:08.091	info	instance system.adapter.dwd.1 started with pid 9844
                          host.raspberrypiiobroker	2021-01-15 10:00:04.067	info	instance system.adapter.dwd.0 started with pid 9825
                          host.raspberrypiiobroker	2021-01-15 10:00:00.043	info	instance system.adapter.daswetter.0 started with pid 9810
                          mqtt.0	2021-01-15 09:52:57.972	info	(1355) Client [MqttClient] connection closed: closed
                          mqtt.0	2021-01-15 09:52:57.788	info	(1355) Client [MqttClient] connected with secret 1610700777784_5720
                          host.raspberrypiiobroker	2021-01-15 09:45:15.974	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                          host.raspberrypiiobroker	2021-01-15 09:45:12.952	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.raspberrypiiobroker	2021-01-15 09:45:10.869	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.raspberrypiiobroker	2021-01-15 09:45:08.131	info	instance system.adapter.daswetter.0 started with pid 29210
                          host.raspberrypiiobroker	2021-01-15 09:45:04.078	info	instance system.adapter.dwd.0 started with pid 29191
                          host.raspberrypiiobroker	2021-01-15 09:45:00.038	info	instance system.adapter.dwd.1 started with pid 29029
                          vw-connect.0	2021-01-15 09:35:34.117	error	(23070) Failed relogin
                          vw-connect.0	2021-01-15 09:35:34.115	error	(23070) Error: Invalid protocol: skodaconnect:
                          vw-connect.0	2021-01-15 09:35:34.114	error	(23070) Failed in first login step
                          vw-connect.0	2021-01-15 09:35:33.055	error	(23070) Relogin
                          vw-connect.0	2021-01-15 09:35:33.054	error	(23070) 400
                          vw-connect.0	2021-01-15 09:35:33.054	error	(23070) {"errorCode":"REQUEST_DATA_INVALID","description":"invalid brand or token audience"}
                          vw-connect.0	2021-01-15 09:35:33.046	error	(23070) VwToken
                          adaptereinstellungen wurden nicht geändert und sind:
                          Typ Skoda
                          Update 7 Minuten
                          Spin eingegeben
                          Update erzwingen 0
                          Fahrdaten alle und alle
                          auch schon bei vorgängerversionen kamen alle 54 Minuten Fehler aber es waren nur 2 Zeilen.
                          in objekten werden neben destination, position, remote, status nur die cyclic tripdata erstellt ,
                          wenn der adapter umgestellt wird kommen auch entsprechen die Lang oder kurz Tripwerte.
                            Datensammler @Datensammler last edited by
                            @datensammler said in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                            Ich kann meinen vorherigen Beitrag leider nicht bearbeiten, daher hier die Ergänzung der Fehlermeldungen:
                            host.iobroker	2021-01-15 12:30:23.154	info	instance system.adapter.vw-connect.1 terminated with code 0 (NO_ERROR)
                            vw-connect.1	2021-01-15 12:30:22.604	error	(24696) unhandled promise rejection: undefined
                            vw-connect.1	2021-01-15 12:30:22.603	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            vw-connect.1	2021-01-15 12:30:22.601	error	(24696) Error: Invalid protocol: seatconnect:
                            vw-connect.1	2021-01-15 12:30:22.601	error	(24696) Failed in first login step
                            vw-connect.1	2021-01-15 12:30:21.444	error	(24696) Relogin
                            vw-connect.1	2021-01-15 12:30:21.443	error	(24696) 400
                            vw-connect.1	2021-01-15 12:30:21.443	error	(24696) {"errorCode":"REQUEST_DATA_INVALID","description":"invalid brand or token audience"}
                            vw-connect.1	2021-01-15 12:30:21.438	error	(24696) VwToken
                            vw-connect.1	2021-01-15 11:36:22.913	error	(24696) status update Failed
                            vw-connect.1	2021-01-15 11:36:22.911	error	(24696) 429
                            host.iobroker	2021-01-15 11:36:15.075	info	instance system.adapter.vw-connect.1 started with pid 24696
                              tombox @Datensammler last edited by
                              @datensammler
                              Fehler 429 wurden zuviele Requests gesendet. Du musst das Auto einmal starten
                                @tombox funktioniert! Danke!!
                                • Tranquility76
                                  Tranquility76 last edited by
                                  vielleicht habe ich es bei der Länge des Threads überlesen - wurde schon mal was Richtung Wallbox VW ID Charger Connect/Pro versucht?
                                  Das Ding ist auch über die We Connect ID App mit eingebunden, müsste also auch über den Adapter hier erreichbar sein.
                                    tombox @Tranquility76 last edited by
                                    @tranquility76 probier mal die aktuellste version
                                      jhg @tombox last edited by
                                      @tombox Welche Funktionalitäten wurden denn für WeCharge implementiert?
                                      Ist das nur für das Laden zuhause gedacht.
                                      Verstehe es gerade nicht.
                                      T M 2 Replies Last reply Reply Quote 0
                                        tombox @jhg last edited by
                                        @jhg Alles was in der App We connect ID zum we charge angezeigt wird. die stop funktionalität wurde noch nicht eingebaut
                                          mtbsteve @jhg last edited by
                                          @jhg unter wecharge.chargeandpay findest du deine WeCharge Tarifdetails und die Ladehistorie an öffentlichen Stationen und unter wechagre.homecharging alle Elli Wallbox Parameter sowie die Ladehistorie an deiner Elli Box.
                                            jhg @mtbsteve last edited by
                                            @mtbsteve @tombox Danke euch beiden. Da ich bisher noch nicht mit WeCharge geladen habe, ist nichts ersichtlich.
                                            81.1k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            398
                                            3090
                                            1601047
