    4. JavaScript
    5. [Suche] Javascript das eine Tabelle im JSON ausgibt
      liv-in-sky @quorle last edited by
      @quorle
      sorry mußte mich um eigenes script kümmern.
      habe mal das hier gemacht:
      geändert habe ich
      • den selektor - da müßte deiner wieder rein
      • unten im blockly gibt es einen dp - da mußt du einen anlegen und im script anpassen
      • eine kleine funktion - damit wird das json erstellt, so wie es inventwo braucht
        die tabelle:
      der datenpunkt schaut dann bei mir so aus:
      [{"name":"KingArtTouchT2 POWER","id":"⚫"},{"name":"MCU344MhzRain POWER","id":"⚫"},{"name":"MCUTasmotaTemp POWER","id":"⚪"},{"name":"Pow Room TV POWER","id":"⚪"},{"name":"ShellyWC POWER","id":"⚫"},{"name":"Sonoff11 POWER","id":"⚪"},{"name":"Sonoff12 POWER","id":"⚫"},{"name":"Sonoff14 POWER","id":"⚫"},{"name":"Sonoff15 POWER","id":"⚪"},{"name":"Sonoff16 POWER","id":"⚫"},{"name":"Sonoff17 POWER","id":"⚪"},{"name":"Sonoff18 POWER","id":"⚫"},{"name":"Sonoff3 POWER","id":"⚫"},{"name":"Sonoff6neu POWER","id":"⚪"},{"name":"Sonoff7 POWER","id":"⚪"},{"name":"Sonoff8 POWER","id":"⚫"},{"name":"SonoffBridge POWER","id":"⚪"},{"name":"SonoffMini1 POWER","id":"⚫"},{"name":"SonoffMini2 POWER","id":"⚪"},{"name":"SonoffMini3 POWER","id":"⚪"},{"name":"SonoffMini4 POWER","id":"⚫"},{"name":"SonoffPow1 POWER","id":"⚫"},{"name":"SonoffPow2 POWER","id":"⚪"},{"name":"SonoffPow3 POWER","id":"⚫"},{"name":"SonoffPow5Desk POWER","id":"⚪"},{"name":"SonoffS26 POWER","id":"⚪"},{"name":"USBSwitch1 POWER","id":"⚪"},{"name":"USBSwitch2 POWER","id":"⚫"},{"name":"USBSwitch3 POWER","id":"⚪"},{"name":"USBSwitch4 POWER","id":"⚫"},{"name":"USBSwitch5 POWER","id":"⚪"},{"name":"USBSwitch6 POWER","id":"⚪"},{"name":"USBSwitch7 POWER","id":"⚫"},{"name":"USBSwitch8 POWER","id":"⚪"},{"name":"USBSwitch9 POWER","id":"⚫"},{"name":"WIFISocket1 POWER","id":"⚪"},{"name":"WemosHausTemperatur POWER","id":"⚫"},{"name":"WemosTasmotaMov1 POWER","id":"⚫"}]
       <variables>
         <variable id="Fwt*3`3ScyT(qDt?gf(T">ObjectID</variable>
         <variable id="V2M7szHj0grpg_E~L6Y:">Liste</variable>
         <variable id="K@h0-NY5VaI|@t!5/iJh">Wert</variable>
         <variable id="y$E$s)SL1AaL_Wwl$Jw.">myList</variable>
         <variable id="2TXuU=:-J^z#1tz2?m+)">test</variable>
         <variable id="Z=?7wCQ1-49/,bxoE1#|">counter</variable>
         <variable id="uraW(G+9^E9Lr!q;.Md?">i</variable>
         <variable id="W6/l[G~B{Zwv5)Rz4siZ">anzahl_oben</variable>
         <variable id="Sk[;o=!/U_$I6Wr,/;!b">anzahl_unten</variable>
       </variables>
       <block type="procedures_defcustomreturn" id="]lQM=r`L^2M}s^@n(USH" x="-1312" y="-1962">
         <mutation statements="false">
           <arg name="ObjectID" varid="Fwt*3`3ScyT(qDt?gf(T"></arg>
         </mutation>
         <field name="NAME">Name</field>
         <field name="SCRIPT">bGV0IG5hbWUgPSBnZXRPYmplY3QoT2JqZWN0SUQpLmNvbW1vbi5uYW1lLnN1YnN0cmluZygxMik7Cm5hbWUgPSBuYW1lLnJlcGxhY2UoJ1N0YXR1cyBvYmVyZSBQb3NpdGlvbicsICdvYmVuJyk7Ci8vbmFtZSA9IG5hbWUucmVwbGFjZSgnU3RhdHVzIHVudGVyZSBQb3NpdGlvbicsICd1bnRlbicpOwpyZXR1cm4gbmFtZTsKLy9yZXR1cm4gIjxiPiIrbmFtZSsiPC9iPiI7</field>
       <block type="procedures_defcustomreturn" id="!t;U0AgoNU@W*^{W;)1~" x="-1313" y="-1913">
           <arg name="Liste" varid="V2M7szHj0grpg_E~L6Y:"></arg>
           <arg name="Wert" varid="K@h0-NY5VaI|@t!5/iJh"></arg>
         </mutation>
         <field name="NAME">Multisort</field>
         <field name="SCRIPT">dmFyIFdlcnQgPSBXZXJ0IC0gMTsgCkxpc3RlLnNvcnQoZnVuY3Rpb24oYSwgYil7CiAgICByZXR1cm4gYltXZXJ0XSAtIGFbV2VydF07Cn0pOwpyZXR1cm4gTGlzdGU7</field>
       <block type="procedures_defcustomnoreturn" id="d+PXd6N1nBTxz}gaM@Co" x="-1312" y="-1862">
           <arg name="myList" varid="y$E$s)SL1AaL_Wwl$Jw."></arg>
         </mutation>
         <field name="NAME">tabelleMit3Werten</field>
         <field name="SCRIPT">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</field>
       <block type="variables_set" id="M*e-%li=rNRAKW!{S*Fi" disabled="true" x="-1287" y="-1761">
         <field name="VAR" id="2TXuU=:-J^z#1tz2?m+)">test</field>
           <block type="convert_json2object" id="HodxuAjF0Dakr,,xDdpw">
               <block type="text" id="s=LJUvclbq%Wb6B;E/^k">
                 <field name="TEXT">[["WC Status untere Position",false],["WC oben",true],["Schlafzimmer Fenster Status untere Position",false],["Schlafzimmer Fenster oben",true],["Schlafzimmer Balkontüre Status untere Position",false],["Schlafzimmer Balkontüre oben",true],["Kinderzimmer Lea Status untere Position",false],["Kinderzimmer Lea oben",true],["Kinderzimmer Antonia Status untere Position",false],["Kinderzimmer Antonia oben",true],["Gästezimmer Status untere Position",true],["Gästezimmer oben",false],["Jonas Fenster Status untere Position",false],["Jonas Fenster oben",true],["Wohnzimmer Fenster Status untere Position",false],["Wohnzimmer Fenster oben",true],["Wohnzimmer Balkontüre Status untere Position",false],["Wohnzimmer Balkontüre oben",true],["WC Fenster Status untere Position",false],["WC Fenster oben",true],["Küche Fenster Status untere Position",false],["Küche Fenster oben",true]]</field>
           <block type="schedule" id="Cqz)^1L5B-*_#wudd;?i">
             <field name="SCHEDULE">*/20 * * * * *</field>
               <block type="variables_set" id="sWqJxa.MyY?*y-S}mHPz">
                 <field name="VAR" id="V2M7szHj0grpg_E~L6Y:">Liste</field>
                   <block type="lists_create_with" id="s1KG8o;:gtQ6DjJt@w9I">
                   <block type="variables_set" id="R6exgi+-F7xoKVW/[NE.">
                     <field name="VAR" id="Z=?7wCQ1-49/,bxoE1#|">counter</field>
                       <block type="math_number" id="AHHG~c/mltPLQ?]Ik;5M">
                         <field name="NUM">-1</field>
                       <block type="controls_forEach" id="~PaFX`X@5n{TM9K^{Jw6">
                         <field name="VAR" id="uraW(G+9^E9Lr!q;.Md?">i</field>
                         <value name="LIST">
                           <block type="selector" id="xQ^Q5{h5V@5PLI+YO@i.">
                             <field name="TEXT">sonoff.0.*.POWER</field>
                         <statement name="DO">
                           <block type="debug" id="XZDv+4g$1.=ljXu_70B*" disabled="true">
                             <field name="Severity">warn</field>
                             <value name="TEXT">
                               <shadow type="text">
                               <block type="variables_get" id="WiV$3M9_AvyO[2zGP3_e">
                               <block type="controls_if" id="BpYF0w{plR^$Bj;f$G-X">
                                   <block type="logic_compare" id=":U;pkPjDX!X*x`]J^[=f">
                                     <field name="OP">GT</field>
                                       <block type="text_indexOf" id="dQ?$f$~34KAwRQzHZy2v">
                                         <field name="END">FIRST</field>
                                           <block type="variables_get" id="YN=/IOiNU1e/z47W_hYO">
                                         <value name="FIND">
                                           <shadow type="text" id="YJ_ZaIlitzIz0lbSIy]Z">
                                             <field name="TEXT">sonoff</field>
                                       <block type="math_number" id="(4uegeXx!R!5`x./Zrpy">
                                         <field name="NUM">0</field>
                                   <block type="math_change" id=";nI|WSdj!-!_]9^hXce=">
                                     <field name="VAR" id="W6/l[G~B{Zwv5)Rz4siZ">anzahl_oben</field>
                                     <value name="DELTA">
                                       <shadow type="math_number" id="7NsDd4.5wRJiN$ohzcPz">
                                         <field name="NUM">1</field>
                                       <block type="procedures_callcustomnoreturn" id="7(!wl+gy1z~l4.6UX*QE">
                                         <mutation name="etwas tun"></mutation>
                                 <value name="IF1">
                                   <block type="logic_compare" id=",#NtYtMgV}/:2E1_hNrG">
                                       <block type="text_indexOf" id="Yg}H-~{a7x8)+qu:9M|/">
                                           <block type="variables_get" id="8;*NmuJL+=2ZjdGLV@w*">
                                         <value name="FIND">
                                           <shadow type="text" id="NE#zvIT-6LZjV3/;?~mp">
                                       <block type="math_number" id="J(GT5p9jH?jE][E#[[@;">
                                 <statement name="DO1">
                                   <block type="math_change" id=":_uor[5yVl8xBU+`cMV;">
                                     <field name="VAR" id="Sk[;o=!/U_$I6Wr,/;!b">anzahl_unten</field>
                                       <shadow type="math_number" id="ieNW@ocv}L*#oj8$X~P1">
                                       <block type="procedures_callcustomnoreturn" id=";=/Mf4O*gPD.e3=$W%6*">
                           <block type="procedures_callcustomnoreturn" id="1tTT@y+3fd)eq*EKO%`c" disabled="true">
                             <mutation name="tabelleMit3Werten">
                               <arg name="myList"></arg>
                             </mutation>
                             <value name="ARG0">
                               <block type="variables_get" id="T3wm-=*hL+H$*f^H0[J9">
                               <block type="control" id="?B@5=?PqH6v*6zKv6fcp">
                                 <field name="OID">0_userdata.0.quorleTesr</field>
                                   <block type="convert_object2json" id="qbFE#Dr-U2bJkWET{;3/">
                                     <field name="PRETTIFY">FALSE</field>
                                       <block type="variables_get" id="f6)^4$,h523yANg6}Xp7">
                                   <block type="debug" id="Xar6oL7+k!M:2n0atyZt">
                                     <value name="TEXT">
                                       <shadow type="text" id="E(2nqnZZxAhV95m0d7U|">
                                       <block type="variables_get" id="JVA=ISb(J?rC5aZV)=i?">
       <block type="procedures_defcustomnoreturn" id="i*1!AZb|niUFaXh*t{,x" x="-612" y="-1337">
         <mutation statements="false"></mutation>
         <field name="NAME">etwas tun</field>
         <field name="SCRIPT">Z2V0U3RhdGUoaSkudmFsID8gbXlTdGF0ZT0i4pqqIiA6IG15U3RhdGU9IuKaqyINCg0KTGlzdGUucHVzaCh7DQogICAgDQogICJuYW1lIiAgOiBnZXRPYmplY3QoaSkuY29tbW9uLm5hbWUgLA0KICAgImlkIiA6ICBteVN0YXRlDQogICAgIA0KICAgIA0KfSkNCg0KIA==</field>
      schau mal, ob du das zum laufen bekommst und anschliessend schauen wir uns das mit den bildern an
      • Q
        quorle @liv-in-sky last edited by
        @liv-in-sky
        Soweit funktioniert das. Es wird alles angezeigt, we bei dir.
        Jetzt kommt das große ABER..
        Die Namen werden nicht "beschnitten".
        Habe dazu mal einen Teil meines alten Scriptes integriert. Aber dann wird alles doppelt in den Datenpunkt geschrieben.
        Hier das aktuelle Script von mir:
         <variables>
         </variables>
           </mutation>
           </mutation>
           </mutation>
                           <value name="LIST">
                               <field name="TEXT">*_Position(functions=blinds)</field>
                               <value name="TEXT">
                                           <value name="FIND">
                                               <field name="TEXT">obere</field>
                                             <block type="lists_setIndex" id="V%X2]!(FWN#b!Icp,vEn">
                                               <mutation at="true"></mutation>
                                               <value name="LIST">
                                                 <block type="variables_get" id="d@?Y!wCwVm2J;5#}l@|s">
                                               <value name="AT">
                                                 <block type="variables_get" id="I{J?cUEic):/$hl^3n{K">
                                               <value name="TO">
                                                 <block type="lists_create_with" id="/zCL;!FCpeJcaTRNromK">
                                                   <value name="ADD0">
                                                     <block type="procedures_callcustomreturn" id="Qf=s6+J.KB`I0omt2dx-" inline="true">
                                                       <mutation name="Name">
                                                         <arg name="ObjectID"></arg>
                                                       </mutation>
                                                       <value name="ARG0">
                                                         <block type="variables_get" id="7`$xI^f!0)3kG%TM66sA">
                                                   <value name="ADD1">
                                                     <block type="get_value_var" id="~#Cp6j.d%w8Wx2-Fr,Xd" disabled="true">
                                                       <value name="OID">
                                                         <shadow xmlns="http://www.w3.org/1999/xhtml" type="text">
                                                           <field name="TEXT"></field>
                                                         <block type="variables_get" id="G,BvC-qYrP^?;J`$oD`G">
                                   <value name="IF1">
                                           <value name="FIND">
                                               <field name="TEXT">untere</field>
                                             <block type="lists_setIndex" id="3`60`J~EA:*j}OOf+Z*c">
                                               <value name="LIST">
                                                 <block type="variables_get" id="Q|]yh,v=L+mdd_rKMQdY">
                                               <value name="AT">
                                                 <block type="variables_get" id="iyFeezsq|O~{G,#T^e=-">
                                               <value name="TO">
                                                 <block type="lists_create_with" id="XbB!.OI/O0-lQFTag=P`">
                                                   <value name="ADD0">
                                                     <block type="procedures_callcustomreturn" id="Z_doi2a.Vs634-ZCc8|6" inline="true">
                                                       </mutation>
                                                       <value name="ARG0">
                                                         <block type="variables_get" id="fA)(tvzda:,Du0s;bs-#">
                                                   <value name="ADD1">
                                                     <block type="get_value_var" id="NZ3R^x0{NE3}p43(4,SN" disabled="true">
                                                       <value name="OID">
                                                         <block type="variables_get" id="L,4oOHhVa[Gw1ak,Jb-6">
                               </mutation>
                               <value name="ARG0">
                                   <field name="OID">javascript.0.test.Test_gemischt</field>
                                       <value name="TEXT">
         <block type="procedures_defcustomnoreturn" id="i*1!AZb|niUFaXh*t{,x" x="-1038" y="-987">
           <field name="SCRIPT">LyoNCmdldFN0YXRlKGkpLnZhbCA/IG15U3RhdGU9IuKaqiIgOiBteVN0YXRlPSLimqsiDQoNCkxpc3RlLnB1c2goew0KICAgIA0KICAibmFtZSIgIDogZ2V0T2JqZWN0KGkpLmNvbW1vbi5uYW1lICwNCiAgICJpZCIgOiAgbXlTdGF0ZQ0KICAgICANCiAgICANCn0pDQoqLw0KZ2V0U3RhdGUoTGlzdGUpLnZhbCA/IG15U3RhdGU9IuKaqiIgOiBteVN0YXRlPSLimqsiDQoNCkxpc3RlLnB1c2goew0KICAgIA0KICAibmFtZSIgIDogZ2V0T2JqZWN0KGkpLmNvbW1vbi5uYW1lICwNCiAgICJpZCIgOiAgbXlTdGF0ZQ0KICAgICANCiAgICANCn0p</field>
          paul53 @quorle last edited by paul53
          @quorle sagte:
          Das ist so, wenn die "Beschneidung" kommentiert statt ausgeführt wird.
           <variables>
             <variable id="b}H-_F*/x2|@|0rgQRj4">name</variable>
             <variable id="Xr|U9NUFQ3h_|LWx`q=}">val</variable>
           </variables>
           <block type="procedures_defcustomreturn" id="]lQM=r`L^2M}s^@n(USH" x="-1288" y="-1963">
             </mutation>
             <field name="SCRIPT">bGV0IG5hbWUgPSBnZXRPYmplY3QoT2JqZWN0SUQpLmNvbW1vbi5uYW1lLnN1YnN0cmluZygxMik7Cm5hbWUgPSBuYW1lLnJlcGxhY2UoJ1N0YXR1cyBvYmVyZSBQb3NpdGlvbicsICdvYmVuJyk7Cm5hbWUgPSBuYW1lLnJlcGxhY2UoJ1N0YXR1cyB1bnRlcmUgUG9zaXRpb24nLCAndW50ZW4nKTsKcmV0dXJuIG5hbWU7Ci8vcmV0dXJuICI8Yj4iK25hbWUrIjwvYj4iOw==</field>
           <block type="procedures_defcustomreturn" id="!t;U0AgoNU@W*^{W;)1~" x="-1287" y="-1913">
             </mutation>
           <block type="procedures_defcustomnoreturn" id="d+PXd6N1nBTxz}gaM@Co" x="-1288" y="-1863">
             </mutation>
           <block type="procedures_defcustomreturn" id="~gc!/U0;qHT9WPouBUd!" x="-1288" y="-1813">
               <arg name="name" varid="b}H-_F*/x2|@|0rgQRj4"></arg>
               <arg name="val" varid="Xr|U9NUFQ3h_|LWx`q=}"></arg>
             </mutation>
             <field name="NAME">makeObject</field>
             <field name="SCRIPT">dmFsID8gbXlTdGF0ZT0i4pqqIiA6IG15U3RhdGU9IuKaqyINCnJldHVybiB7DQogICJOYW1lIiAgOiBuYW1lLA0KICAiaWQiIDogIG15U3RhdGUNCn0NCg==</field>
                             <value name="LIST">
                                 <value name="TEXT">
                                             <value name="FIND">
                                             <value name="LIST">
                                             <value name="AT">
                                             <value name="TO">
                                               <block type="procedures_callcustomreturn" id=".u,OC{h)!~ny,rq;p]*A">
                                                 <mutation name="makeObject">
                                                   <arg name="name"></arg>
                                                   <arg name="val"></arg>
                                                 </mutation>
                                                 <value name="ARG0">
                                                     </mutation>
                                                     <value name="ARG0">
                                                 <value name="ARG1">
                                                   <block type="get_value_var" id="~#Cp6j.d%w8Wx2-Fr,Xd">
                                                     <value name="OID">
                                     <value name="IF1">
                                             <value name="FIND">
                                             <value name="LIST">
                                             <value name="AT">
                                             <value name="TO">
                                               <block type="procedures_callcustomreturn" id="T[?EZb0T:H3$$WU0[k|i">
                                                 </mutation>
                                                 <value name="ARG0">
                                                   <block type="procedures_callcustomreturn" id=".SJfkc3t.+4tT@c];cRU" inline="true">
                                                     </mutation>
                                                     <value name="ARG0">
                                                       <block type="variables_get" id="?:@WG?jtw^=P`W=WAEzC">
                                                 <value name="ARG1">
                                                   <block type="get_value_var" id="n%maeL^P[e4i3X}fc{(z">
                                                     <value name="OID">
                                                       <block type="variables_get" id="4[PfG:ci+TtP4p/qT$||">
                                 </mutation>
                                 <value name="ARG0">
                                         <value name="TEXT">
            liv-in-sky @paul53 last edited by
            also wenn ich die variable 'name' benutze, bekomme ich als resultat den scriptnamen
            getState(i).val ? myState="⚪" : myState="⚫"
            Liste.push({
              "Name"  : name, //getObject(i).common.name ,
               "ID" :  myState
            @quorle was meinst du mit beschnitten - was soll da eigentlich stehen
              paul53 @liv-in-sky last edited by
              @liv-in-sky sagte:
              Ja, die Variable name ist im Javascript-Adapter vordefiniert und liefert den Script name.
                den braucht er wahrscheinlich nicht - ich kann ihm nur den object namen anbieten - ich habe das "beschnitten" nicht verstanden - deine function mit ausgabe werten ist natürlich eleganter.
                  paul53 @liv-in-sky last edited by paul53
                  @liv-in-sky sagte:
                  Die Funktion Name(ObjectID) gibt einen verkürzten Namen zurück.
                  let name = getObject(ObjectID).common.name.substring(12);
                  name = name.replace('Status obere Position', 'oben');
                  name = name.replace('Status untere Position', 'unten');
                  return name;
                    @paul53 achso. es soll ein name gekürzt werden
                    das kann natürlih eingebaut werden - habe ich wohl in seinem alten script übersehen
                    • Q
                      Sorry, hatte die Tage einiges anderes zu erledigen.
                      Also mit "Beschneiden" meinte ich das ersetzen des Namens:
                      Beispiel:
                      Ist Zustand: Schlafzimmer Balkontüre Status untere Position
                      Soll Zustand:
                        @quorle
                        wenn das was mit den zusätzlichen bildern zu tun hat, kannst du das auh noch einbauen - also ein bild für oben und eines für unten. man könnte auch noch danach sortieren .
                        • Q
                          @liv-in-sky
                          Also Aktuell sieht das Script so aus:
                           <variables>
                           </variables>
                             </mutation>
                             <field name="SCRIPT">bGV0IG5hbWUgPSBnZXRPYmplY3QoT2JqZWN0SUQpLmNvbW1vbi5uYW1lLnN1YnN0cmluZygxMik7Cm5hbWUgPSBuYW1lLnJlcGxhY2UoJ1N0YXR1cyBvYmVyZSBQb3NpdGlvbicsICdvYmVuJyk7Cm5hbWUgPSBuYW1lLnJlcGxhY2UoJ1N0YXR1cyB1bnRlcmUgUG9zaXRpb24nLCAndW50ZW4nKTsKcmV0dXJuIG5hbWU7Cg==</field>
                             </mutation>
                             </mutation>
                                             <value name="LIST">
                                                 <value name="TEXT">
                                                             <value name="FIND">
        <value name="LIST">
        <value name="AT">
        <value name="TO">
        <value name="ADD0">
        </mutation>
        <value name="ARG0">
        <value name="ADD1">
        <value name="OID">
                                                     <value name="IF1">
                                                             <value name="FIND">
        <value name="LIST">
        <value name="AT">
        <value name="TO">
        <value name="ADD0">
        </mutation>
        <value name="ARG0">
        <value name="ADD1">
        <value name="OID">
                                                 </mutation>
                                                 <value name="ARG0">
                                                         <value name="TEXT">
                          Und als Ausgabe wird folgendes ausgegeben:
                          Der obere Teil ist die Ausgabe von @paul53 , so sollte der Text eigentlich lauten.
                          Der untere Teil ist von dir. Klar, die schwarzen Punkte kann man dann eventuell weglassen und mit der JSON-Tabelle direkt in VIS Arbeiten?
                            @quorle
                            Versuche es mal hiermit:
                             <variables>
                               <variable id="}dJI#n7D?(yn(S7IZetS">Liste</variable>
                               <variable id="fe!@@dhB{4wJ~YaxWG%C">i</variable>
                             </variables>
                             <block type="procedures_defcustomreturn" id="!t;U0AgoNU@W*^{W;)1~" x="-1288" y="-1812">
                                 <arg name="Liste" varid="}dJI#n7D?(yn(S7IZetS"></arg>
                               </mutation>
                                       <field name="VAR" id="}dJI#n7D?(yn(S7IZetS">Liste</field>
                                             <block type="variables_set" id="**}`+OgV6}BW5TBMd{`s">
                                                 <block type="math_number" id="u(R`,V@+GYc(yI=W0rOU">
                                                   <field name="VAR" id="fe!@@dhB{4wJ~YaxWG%C">i</field>
                                                   <value name="LIST">
                                                       <value name="TEXT">
        <value name="FIND">
        <value name="LIST">
        <value name="AT">
        <value name="TO">
        </mutation>
        <value name="ARG0">
                                                           <value name="IF1">
        <value name="FIND">
        <value name="LIST">
        <value name="AT">
        <value name="TO">
        </mutation>
        <value name="ARG0">
                                                           <value name="TEXT">
                             <block type="procedures_defcustomreturn" id="]lQM=r`L^2M}s^@n(USH" x="-988" y="-1638">
                               </mutation>
                               <field name="SCRIPT">bGV0IG15U3RhdGU7CmdldFN0YXRlKE9iamVjdElEKS52YWwgPyBteVN0YXRlPSLimqoiIDogbXlTdGF0ZT0i4pqrIgpsZXQgbmFtZSA9IGdldE9iamVjdChPYmplY3RJRCkuY29tbW9uLm5hbWUuc3Vic3RyaW5nKDEyKTsKbmFtZSA9IG5hbWUucmVwbGFjZSgnU3RhdHVzIG9iZXJlIFBvc2l0aW9uJywgJ29iZW4nKTsKbmFtZSA9IG5hbWUucmVwbGFjZSgnU3RhdHVzIHVudGVyZSBQb3NpdGlvbicsICd1bnRlbicpOwpyZXR1cm4geyAgICAKICAgICJOYW1lIjogbmFtZSwKICAgICJTdGF0dXMiOiBteVN0YXRlCn0=</field>
                            • Q
                              @paul53 :
                              Soweit so gut, die Ausgabe der Namen Passt nun einwandfrei. Danke für deine Hilfe.
                              @liv-in-sky :
                              Wie würde ich jetzt in die Tabellen ein PNG Bild bekommen?
                              Benutze noch dein Widget, was du hier gepostet hast.
                              Aber wenn ich im Widget Spalte 1 als Image deklariere, verschwindet der Text.
                                @quorle
                                poste mal die daten, die jetzt da sind - dann kann ich die importieren und ansehen
                                • Q
                                  @liv-in-sky
                                   <variables>
                                     <variable id="X^G~Pk/;SH@G?XbLq.{o">ObjectID</variable>
                                   </variables>
                                   <block type="procedures_defcustomreturn" id="]lQM=r`L^2M}s^@n(USH" x="-1212" y="-1863">
                                       <arg name="ObjectID" varid="X^G~Pk/;SH@G?XbLq.{o"></arg>
                                     </mutation>
                                     </mutation>
                                                         <value name="LIST">
                                                             <value name="TEXT">
        <value name="FIND">
        <value name="LIST">
        <value name="AT">
        <value name="TO">
        </mutation>
        <value name="ARG0">
        <value name="IF1">
        <value name="FIND">
        <value name="LIST">
        <value name="AT">
        <value name="TO">
        </mutation>
        <value name="ARG0">
        <field name="PRETTIFY">TRUE</field>
        <value name="TEXT">
                                  Ausgabe in den State:
                                  [{"tpl":"i-vis-jsontable","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","iTblRowLimit":"100","iTableRefreshRate":"0","iColCount":"3","iColShow1":"true","iTblCellFormat1":"normal","iTblCellImageSize1":"59","iTblTextAlign1":"left","iOpacityAll":"1","iTblRowEvenColor":"#333333","iTblRowUnevenColor":"#38739f","iTblHeaderColor":"#333333","iRowSpacing":"3.1","iTblRowEvenTextColor":"#ffffff","iTblRowUnevenTextColor":"#ffffff","iTblHeaderTextColor":"#ffffff","iBorderSize":"2","iBorderStyleLeft":"none","iBorderStyleRight":"none","iBorderStyleUp":"none","iBorderStyleDown":"none","iBorderColor":"#38739f","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"javascript.0.test.Test_gemischt","iHorScroll":true,"iColShow2":"true","iTblCellFormat2":"normal","iTblCellImageSize2":"200","iTblTextAlign2":"center","iBorderRemoveDouble":false,"iColShow3":"true","iTblCellFormat3":"image","iTblCellImageSize3":"200","iTblTextAlign3":"right","iColWidth3":"50","iColWidth2":"50","iColWidth1":"50","iTblCellBooleanCheckbox1":"false","iTblCellBooleanColorFalse1":"#ff0000","iTblCellBooleanColorTrue1":"#00ff00","iTblCellNumberDecimals1":"2","iTblCellNumberDecimalSeperator1":".","iTblCellNumberThousandSeperator1":",","iTblCellBooleanCheckbox2":"false","iTblCellBooleanColorFalse2":"#ff0000","iTblCellBooleanColorTrue2":"#00ff00","iTblCellNumberDecimals2":"2","iTblCellNumberDecimalSeperator2":".","iTblCellNumberThousandSeperator2":",","iTblCellBooleanCheckbox3":false,"iTblCellBooleanColorFalse3":"#ff0000","iTblCellBooleanColorTrue3":"#00ff00","iTblCellNumberDecimals3":"2","iTblCellNumberDecimalSeperator3":".","iTblCellNumberThousandSeperator3":",","iTblCellPlaceholder1":"","iColAttr2":"Status","iColAttr3":"","iColAttr1":"Name","iColShow4":true,"iTblCellFormat4":"normal","iTblCellImageSize4":"200","iTblCellBooleanCheckbox4":"false","iTblCellBooleanColorFalse4":"#ff0000","iTblCellBooleanColorTrue4":"#00ff00","iTblCellNumberDecimals4":"2","iTblCellNumberDecimalSeperator4":".","iTblCellNumberThousandSeperator4":",","iTblTextAlign4":"left","iTblShowHead":true,"iVertScroll":true,"iTblCellPlaceholder3":"","iColName3":"","iColName2":"","iTblCellPlaceholder2":""},"style":{"left":"463px","top":"27px","width":"948px","height":"343px","font-size":"large","overflow-y":"scroll"},"widgetSet":"vis-inventwo"}]
                                    @quorle di daten bitte aus dem log rauskopieren und posten
                                    es sind aber keine bilder zu sehen - der schwarze und weiße punkt ist ein emiji und daher ein text
                                      @quorle
                                      was sollen die bilder eigentlich anzeigen bzw wie aussehen ?
                                      • Q
                                        @liv-in-sky
                                        Ja die schwarzen Punkte sind Emojis und werden in der JS-Funktion Name gebildet ( eingefügt ).
                                        Es sollten Bilder ( png ) sein, die man in der VIS dann einbinden kann. Die Bilder stammen von Inventwo. Einmal "Rollo offen", wenn der Status Rollo offen ist und ein geschlossen.
                                        17.1.2021, 16:04:00.005	[warn ]: javascript.0 (3043) script.js.common.TEST-Scripte.Skript_2: [{'Name':'WC unten','Status':'⚫'},{'Name':'WC oben','Status':'⚪'},{'Name':'Schlafzimmer Fenster unten','Status':'⚫'},{'Name':'Schlafzimmer Fenster oben','Status':'⚪'},{'Name':'Schlafzimmer Balkontüre unten','Status':'⚫'},{'Name':'Schlafzimmer Balkontüre oben','Status':'⚪'},{'Name':'Kinderzimmer Lea unten','Status':'⚫'},{'Name':'Kinderzimmer Lea oben','Status':'⚪'},{'Name':'Kinderzimmer Antonia unten','Status':'⚫'},{'Name':'Kinderzimmer Antonia oben','Status':'⚪'},{'Name':'Gästezimmer unten','Status':'⚫'},{'Name':'Gästezimmer oben','Status':'⚪'},{'Name':'Jonas Fenster unten','Status':'⚫'},{'Name':'Jonas Fenster oben','Status':'⚪'},{'Name':'Wohnzimmer Fenster unten','Status':'⚫'},{'Name':'Wohnzimmer Fenster oben','Status':'⚪'},{'Name':'Wohnzimmer Balkontüre unten','Status':'⚫'},{'Name':'Wohnzimmer Balkontüre oben','Status':'⚪'},{'Name':'WC Fenster unten','Status':'⚫'},{'Name':'WC Fenster oben','Status':'⚪'},{'Name':'Küche Fenster unten','Status':'⚫'},{'Name':'Küche Fenster oben','Status':'⚪'}]
                                          @quorle
                                          hier werden die emojis gesetzt - ich nehme an, hier willst du bilder haben
                                          wenn du die bilder in der vis im darin enthaltenen dateimanager sehen kannst,
                                          beispiel mit bild:
                                          • Q
                                            @liv-in-sky
                                            Habe das einmal eingefügt,
                                            jedoch kommt bei mir dann nur der Link:
                                            2112
