    4. [SourceAnalytix 0.4.8-Final] Released !
      PrinzEisenherz1 @Kueppert last edited by
      also bei mir sind mit dem JS-controller 3.2.6-1 und SA alpha13 die warnings nicht weg.
      das Log füllt sich mit
      sourceanalytix.0	2021-01-15 22:30:31.071	warn	(1384) State "sourceanalytix.0.javascript__0__Energiezaehler__Gaszaehler__HM-ES-TX-WM_MEQ0704462:1__Zaehlerstand-aktuell__Zaehlerstand.currentYear.consumed.2021.05_currentYear" has no existing object,
      sourceanalytix.0	2021-01-15 22:30:23.988	warn	(1384) State "sourceanalytix.0.javascript__0__Energiezaehler__Stromzaehler__Stromzaehler__Zaehlerstand-aktuell__Zaehlerstand.currentYear.consumed.2021.05_currentYear" has no existing object, this migh
      sourceanalytix.0	2021-01-15 22:30:05.885	warn	(1384) State "sourceanalytix.0.shelly__0__SHDM-2#D8BFC019F246#1__lights__Energy.currentYear.consumed.2021.05_currentYear" has no existing object, this might lead to an error in future versions
      sourceanalytix.0	2021-01-15 22:29:27.947	warn	(1384) State "sourceanalytix.0.javascript__0__Energiezaehler__Wasserzaehler__HM-ES-TX-WM_NEQ0864200:1__Zaehlerstand-aktuell__Zaehlerstand.currentYear.consumed.2021.05_currentYear" has no existing obje
      sourceanalytix.0	2021-01-15 22:29:21.858	warn	(1384) State "sourceanalytix.0.javascript__0__Energiezaehler__Stromzaehler__Stromzaehler__Zaehlerstand-aktuell__Zaehlerstand.currentYear.consumed.2021.05_currentYear" has no existing object, this migh
      sourceanalytix.0	2021-01-15 22:29:04.675	warn	(1384) State "sourceanalytix.0.shelly__0__SHDM-2#D8BFC019F246#1__lights__Energy.currentYear.consumed.2021.05_currentYear" has no existing object, this might lead to an error in future versions
      sourceanalytix.0	2021-01-15 22:28:19.843	warn	(1384) State "sourceanalytix.0.javascript__0__Energiezaehler__Stromzaehler__Stromzaehler__Zaehlerstand-aktuell__Zaehlerstand.currentYear.consumed.2021.05_currentYear" has no existing object, this migh
      sourceanalytix.0	2021-01-15 22:28:03.341	warn	(1384) State "sourceanalytix.0.shelly__0__SHDM-2#D8BFC019F246#1__lights__Energy.currentYear.consumed.2021.05_currentYear" has no existing object, this might lead to an error in future versions
      sourceanalytix.0	2021-01-15 22:28:00.623	warn	(1384) State "sourceanalytix.0.javascript__0__Energiezaehler__Gaszaehler__HM-ES-TX-WM_MEQ0704462:1__Zaehlerstand-aktuell__Zaehlerstand.currentYear.consumed.2021.05_currentYear" has no existing object,
      sourceanalytix.0	2021-01-15 22:27:30.095	warn	(1384) State "sourceanalytix.0.shelly__0__SHDM-2#D8BFC019F246#1__lights__Energy.currentYear.consumed.2021.05_currentYear" has no existing object, this might lead to an error in future versions
      sourceanalytix.0	2021-01-15 22:27:27.373	warn	(1384) State "sourceanalytix.0.javascript__0__Energiezaehler__Stromzaehler__Stromzaehler__Zaehlerstand-aktuell__Zaehlerstand.currentYear.consumed.2021.05_currentYear" has no existing object, this migh
      sourceanalytix.0	2021-01-15 22:27:21.102	warn	(1384) State "sourceanalytix.0.javascript__0__Energiezaehler__Wasserzaehler__HM-ES-TX-WM_NEQ0864200:1__Zaehlerstand-aktuell__Zaehlerstand.currentYear.consumed.2021.05_currentYear" has no existing obje
      • Dutchman
        Dutchman Developer Most Active Administrators @PrinzEisenherz1 last edited by
        @prinzeisenherz1 said in [SourceAnalytix 0.4.8-RC.1] Stable version announcement:
        zie mal bitte neu von git 🙂
          PrinzEisenherz1 @Dutchman last edited by
          @dutchman moment, bin gerade dabei
            PrinzEisenherz1 @PrinzEisenherz1 last edited by PrinzEisenherz1
            jetzt habe ich folgendes im log
            sourceanalytix.0	2021-01-15 22:58:28.127	warn	(4003) [onObjectChange - update] No stateDetails found for javascript.0.Energiezaehler.Gaszaehler.HM-ES-TX-WM_MEQ0704462:1.Zaehlerstand-aktuell.Zaehlerstand, cancel initialisation
            sourceanalytix.0	2021-01-15 22:58:16.380	warn	(4003) [onObjectChange - update] No stateDetails found for javascript.0.Energiezaehler.Gaszaehler.HM-ES-TX-WM_MEQ0704462:1.Zaehlerstand-aktuell.Zaehlerstand, cancel initialisation
            sourceanalytix.0	2021-01-15 22:58:09.836	warn	(4003) [onObjectChange - update] No stateDetails found for javascript.0.Energiezaehler.Gaszaehler.HM-ES-TX-WM_MEQ0704462:1.Zaehlerstand-aktuell.Zaehlerstand, cancel initialisation
            auch werden etliche objekte nicht mehr aktualisiert. Auch fehlen jetzt einige.
            K Dutchman 2 Replies Last reply Reply Quote 0
              Kueppert @PrinzEisenherz1 last edited by Kueppert
              @prinzeisenherz1 hm, komisch, previous day klappt bei mir (bei 2 Objekten geprüft). Ich fahre den neuen JS-Controller...unbd SA Alpha 13.
              Einen DP mit MeterReadings habe ich allerdings nicht
              • Dutchman
                bist du dir sicher ?
                A) Previous wird um 00.00 nachts geschrieben nicht kontinuierlich (wie den, ist ja wert von gestern/vorigen Monat usw :))
                B) Was fehlt ?
                Der log Eintrag muss ich noch ran, ist ein irreführender Fehler..... Ist aber ne WARN kein ERROR also nix wichtiges momentan auf den Systemen wo ich die log Einträge bekomme läuft aus auch mit der Warnung durch.
                  Michi_Pi last edited by
                  @Dutchman habe eben gerade bewusst den Energy vom Shelly zurückgesetzt um zu sehen ob richtigt gezählt wird.
                  Leider hat SA jetzt nicht wieder von 0 angefangen sondern war ein negativer Wert.
                  Aktuell hab ich 1,4W
                    "type": "state",
                    "common": {
                      "name": "Strom",
                      "type": "number",
                      "role": "value.power",
                      "unit": "Wh",
                      "read": true,
                      "write": false,
                      "def": 0,
                      "custom": {
                        "linkeddevices.0": {
                          "enabled": true,
                          "parentId": "shelly.0.SHSW-PM#68C63AFB6135#1.Relay0.Energy",
                          "parentType": "number",
                          "isLinked": true
                        "sourceanalytix.0": {
                          "enabled": true,
                          "alias": "Strom Schlafzimmer Zentral",
                          "selectedPrice": "ElectricityDay",
                          "selectedUnit": "Wh",
                          "costs": true,
                          "consumption": true,
                          "meter_values": true,
                          "start_day": 2.5437600000000002,
                          "start_week": 0,
                          "start_month": 0,
                          "start_quarter": 0,
                          "start_year": 0,
                          "valueAtDeviceReset": 2.50341,
                          "valueAtDeviceInit": 0,
                          "cumulativeValue": 2.5437600000000002
                      "icon": "linkeddevices_small.png",
                      "desc": "Created by linkeddevices"
                    "native": {},
                    "from": "system.adapter.sourceanalytix.0",
                    "user": "system.user.admin",
                    "ts": 1610751600399,
                    "_id": "linkeddevices.0.Schlafzimmer.Strom.Energy",
                    "acl": {
                      "object": 1636,
                      "state": 1636,
                      "owner": "system.user.admin",
                  SA zeigt jedoch einen negativen Wert
                  • Dutchman
                    Dutchman Developer Most Active Administrators @Michi_Pi last edited by
                    @michi_pi said in [SourceAnalytix 0.4.8-RC.1] Stable version announcement:
                    welche version von SA ist das ? dieser wert gehört nicht ins raw object "cumulativeValue": 2.5437600000000002
                      Michi_Pi @Dutchman last edited by
                      @dutchman die alpha 13.
                      Also auf 0 setzen ? Oder komplett raus löschen?
                      • Dutchman
                        wie ist sieht dein state "cumulatedReading" aus was steht da drin ?
                          @dutchman die sieht gut aus. Hat den normalen Wert
                          • Dutchman
                            uh ... ich kapiere es so nicht koennen wir mal bitte anydesk machen ich muss mal tiefer schauen ...
                            Habe hier auf DC mit 8 usern dieses scenario durchgespielt und alles laeuft, wuerde gerne mal bei ir drauf schauen bitte
                            Dutch
                              @dutchman said in [SourceAnalytix 0.4.8-RC.1] Stable version announcement:
                              anydesk
                              habe ich nicht, dauert es lang zum einrichten?
                              • Dutchman
                                eh ja, runterladen ... installieren. ... nummer an mir geben ... 1min 20 sek abhaenig von deiner internet Leitung 😁
                                Ich brauchte dan mal so 5-10 min umm par Sachen nach zu schauen
                                  @dutchman PN
                                  • Dutchman
                                    Ich hatte wohl Tomaten auf den äugen, cum wert > startwert das geht natürlich nicht 🙂
                                      @dutchman ich mache später mal eine Auflistung der States die nicht aktualisiert werden.
                                      Muss bloß warten bis meine Frau weg ist und die Kinder versorgt sind 😁
                                      Dutchman 1 Reply Last reply Reply Quote 1
                                      • Dutchman
                                        Dutchman Developer Most Active Administrators @PrinzEisenherz1 last edited by Dutchman
                                        ### 0.4.8-alpha.15 (2021-01-16)
                                        * (Dutchman) change default log-level to info
                                        * (Dutchman) Bugfix : quarters.1 has no existing object                <<<< JS-Controller 3.2.x fix
                                        * (Dutchman) Bugfix : 05_currentYear has no existing object            <<<< JS-Controller 3.2.x fix
                                        * (Dutchman) Bugfix : Caught sentry error : Alias xxxxx has no target
                                        * (Dutchman) Bugfix : Incorrect warn message if configuration for objects is changed
                                          bjoernson last edited by bjoernson
                                          Hello, nach dem Update bekomme ich nun für meine Fritz Dect Geräte die folgende Meldung.
                                          sourceanalytix.0	2021-01-16 13:39:43.012	error	(23626) Input value for fritzdect.0.DECT200_11657010.energy, type = string but should be a number, cannot handle calculation
                                          sourceanalytix.0	2021-01-16 13:39:14.602	error	(19334) Input value for fritzdect.0.DECT200_11657503.energy, type = string but should be a number, cannot handle calculation
                                          Bisher hatte es aber problemlos mit den Fritz Dect Geräten funktioniert. Zumal der Typ auch Number ist und nicht String. Hab sonst noch eine Mess-Steckdose per Deconz eingebunden, diese funktioniert hier weiterhin problemlos.
                                          • Dutchman
                                            Dutchman Developer Most Active Administrators @bjoernson last edited by
                                            @bjoernson said in [SourceAnalytix 0.4.8-RC.1] Stable version announcement:
                                            neh der Type ist string, zeig mal das raw object von dem state bitte
                                            2302
                                            1132285
