    4. [gelöst]Immax NEO SMART 07048L
    • Wszene
      Wszene last edited by Wszene
      Hallo Zusammen,
      Ich habe gerade mein System neu aufgesetzt
      Alles frisch nur den Zigbee Adapter installiert
      Nun wollte ich meine Zigbeegeräte neu anlernen
      Mit den Ikea und Aqara Sachen hat alles funktioniert
      Jetzt wollte ich meine Immax NEO SMART 07048L neu pairen und da bekomme ich bei allen nur dieses
      Log:
      zigbee.0	2021-01-16 21:10:27.757	info	(914) Zigbee: stop joining
      zigbee.0	2021-01-16 21:09:36.576	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:34.271	info	(914) DeviceConfigure successful 0xccccccfffeeab148 Plug-230V-ZB3.0
      zigbee.0	2021-01-16 21:09:33.878	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:33.877	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:33.876	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:33.278	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:33.276	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:33.275	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:32.669	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:31.696	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:31.670	info	(914) Configuring 0xccccccfffeeab148 Plug-230V-ZB3.0
      zigbee.0	2021-01-16 21:09:31.667	info	(914) Device '0xccccccfffeeab148' is supported, identified as: Immax NEO SMART plug (07048L)
      zigbee.0	2021-01-16 21:09:31.666	info	(914) Successfully interviewed '0xccccccfffeeab148', device has succesfully been paired
      zigbee.0	2021-01-16 21:09:31.269	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:30.869	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:30.466	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:30.067	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:29.564	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:29.062	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:28.661	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:28.263	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:27.871	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:27.868	error	(914) Device 0xccccccfffeeab148 "07048L" not described in statesMapping.
      zigbee.0	2021-01-16 21:09:26.057	info	(914) Starting interview of '0xccccccfffeeab148'
      zigbee.0	2021-01-16 21:09:24.969	info	(914) Zigbee: allowing new devices to join.
      zigbee.0	2021-01-16 21:08:32.160	info	(914) Zigbee started
      Es ist der gleiche Conbee 2Stick wie bei der Alten installation
      Kennt Jemand das Problem und hat eine Lösung für mich?
      Danke im Voraus
      Marcel
      • Asgothian
        Asgothian Developer @Wszene last edited by
        @wszene
        Welche Adapter Version hast du installiert?
        A
        Wszene 1 Reply Last reply Reply Quote 0
        • Wszene
          Wszene @Asgothian last edited by
          @asgothian
          Danke genau das war das Problem
          Ich war noch im Stable da ist die V. 1.3.1 drin in der latest ist die V 1.4.2 drin und mit der geht es
          conbee 2 neo smart zigbee
