    4. Test Adapter Vaillant multiMatic/senso und myVaillant
      michihorn @Tom Son last edited by
      @Tom-Son Der Erste Satz weißt auf zukünftige Weiterentwicklungen hin, kein To-Do
      Der zweite Satz weißt auf eine Photo-Voltaic Anlage hin, hast du eine?
      Tom Son 1 Reply Last reply Reply Quote 0
      • Tom Son
        Tom Son @michihorn last edited by
        @michihorn ah, ok... nein ich haben kein PV
        • MassiveAttack
          MassiveAttack last edited by
          Seit dem Update von js-controller bekomme ich den Adapter nicht mehr zum Laufen: (node: v12.20.1, js-controller: 3.2.7)
          host.RaspberryPi 2021-01-17 19:13:19.347 error instance system.adapter.vaillant.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          vaillant.0 2021-01-17 19:13:18.777 warn (14585) Terminated (UNCAUGHT_EXCEPTION): Without reason
          vaillant.0 2021-01-17 19:13:18.775 info (14585) terminating
          vaillant.0 2021-01-17 19:13:18.773 info (14585) cleaned everything up...
          vaillant.0 2021-01-17 19:13:18.730 error (14585) The state contains no properties! At least one property is expected!
          vaillant.0 2021-01-17 19:13:18.729 error at Traverse.forEach (/opt/iobroker/node_modules/traverse/index.js:50:18)
          vaillant.0 2021-01-17 19:13:18.729 error at walk (/opt/iobroker/node_modules/traverse/index.js:226:7)
          vaillant.0 2021-01-17 19:13:18.729 error at walker (/opt/iobroker/node_modules/traverse/index.js:203:13)
          vaillant.0 2021-01-17 19:13:18.729 error at forEach (/opt/iobroker/node_modules/traverse/index.js:298:31)
          vaillant.0 2021-01-17 19:13:18.729 error at Array.forEach (<anonymous>)
          vaillant.0 2021-01-17 19:13:18.729 error at /opt/iobroker/node_modules/traverse/index.js:208:29
          vaillant.0 2021-01-17 19:13:18.729 error at walker (/opt/iobroker/node_modules/traverse/index.js:190:22)
          vaillant.0 2021-01-17 19:13:18.729 error at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.vaillant/main.js:459:41)
          vaillant.0 2021-01-17 19:13:18.729 error at Vaillant.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5897:21)
          vaillant.0 2021-01-17 19:13:18.729 error at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5783:23)
          vaillant.0 2021-01-17 19:13:18.729 error (14585) Error: The state contains no properties! At least one property is expected!
          vaillant.0 2021-01-17 19:13:18.723 error (14585) unhandled promise rejection: The state contains no properties! At least one property is expected!
          vaillant.0 2021-01-17 19:13:18.721 error (14585) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
          • Meister Mopper
            Meister Mopper @MassiveAttack last edited by
            @massiveattack Bitte setze zukünftig den Code in </code tags>, dann wird es leserlich.
            3.2.7 ist noch beta, Du solltest ein issue beim js-controller aufmachen.
            • Tom Son
              Tom Son @Meister Mopper last edited by
              @meister-mopper Habe heute auch das update gemacht, wird ja vorgeschlagen 🙂 aber lt Post im Forum mit "has no existing Obeject..." sollte man das dem Entwickler melden
              bei mir rennt der Adapter zwar, bekomme aber diese Meldungen:
              vaillant.0	2021-01-17 19:22:29.430	warn	(57240) Terminated (UNCAUGHT_EXCEPTION): Without reason
              vaillant.0	2021-01-17 19:22:29.427	info	(57240) terminating
              vaillant.0	2021-01-17 19:22:29.425	info	(57240) cleaned everything up...
              vaillant.0	2021-01-17 19:22:29.398	error	(57240) The state contains no properties! At least one property is expected!
              vaillant.0	2021-01-17 19:22:29.398	error	(57240) Error: The state contains no properties! At least one property is expected! at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5783:23)
              vaillant.0	2021-01-17 19:22:29.395	error	(57240) unhandled promise rejection: The state contains no properties! At least one property is expected!
              vaillant.0	2021-01-17 19:22:29.393	error	(57240) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              vaillant.0	2021-01-17 19:22:09.172	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.dhw01.circulation.configuration.operationMode" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.165	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.dhw01.hotwater.configuration.temperature_setpoint" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.164	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.dhw01.hotwater.configuration.operation_mode" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.154	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.configuration.holidaymode.temperature_setpoint" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.153	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.configuration.holidaymode.end_date" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.152	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.configuration.holidaymode.start_date" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.151	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.configuration.holidaymode.active" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.151	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.configuration.eco_mode" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.150	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.configuration.quick_veto.setpoint_temperature" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.149	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.configuration.quick_veto.active" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.148	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.configuration.inside_temperature" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.147	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.configuration.active_function" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.147	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.configuration.enabled" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.145	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.configuration.name" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.137	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.heating.configuration.setpoint_temperature" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.136	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.heating.configuration.setback_temperature" has no existing object, this might lead to an error in future versions
              vaillant.0	2021-01-17 19:22:09.134	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.heating.configuration.mode" has no existing object, this might lead to an error in future versions
                tombox @Tom Son last edited by
                @tom-son Kannst du mal über github installieren und schauen ob die Warnungen weg sind
                • Tom Son
                  Tom Son @tombox last edited by
                  @tombox drüber installieren? oder vorher de und dann wieder installieren?
                    @tom-son Einfach drüber installieren und instanze neustarten
                    • Tom Son
                      @tombox OK, erledigt, sieht mal ruhig aus, auch mit Loglevel Info
                      • MassiveAttack
                        sorry fürs schlechte format 🙂
                        wenn ich den adapter mit npm install iobroker.vaillant neu installieren will, bekomme ich auch Fehler:
                        npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
                        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                        npm WARN pi No description
                        npm WARN pi No repository field.
                        npm WARN pi No README data
                        npm WARN pi No license field.
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.1 (node_modules/iobroker.js-controller/node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        + iobroker.vaillant@0.0.10
                        added 2 packages from 2 contributors and audited 1013 packages in 13.969s
                        10 packages are looking for funding
                          run `npm fund` for details
                        found 25 vulnerabilities (22 low, 3 high)
                          run `npm audit fix` to fix them, or `npm audit` for details
                        pi@192.168.0.10:~$ sudo npm install iobroker.vaillant
                        T Glasfaser 2 Replies Last reply Reply Quote 0
                          tombox @MassiveAttack last edited by
                          @massiveattack Ich sehe nur Warnungen, aber du bist im falschen Ordner. Du solltest nur über die admin oberfläche updaten oder über das github icon 41e15f8b-b168-4f01-8a65-325732e245fd-image.png
                          • Glasfaser
                            Glasfaser @MassiveAttack last edited by
                            @massiveattack
                            Hierrüber Installieren
                            MassiveAttack 1 Reply Last reply Reply Quote 0
                            • MassiveAttack
                              MassiveAttack @Glasfaser last edited by
                              @glasfaser
                              Besten Dank! Scheint nun stabil zu laufen, danke für die raschen Rückmeldungen 🙂
                              • MassiveAttack
                                MassiveAttack last edited by MassiveAttack
                                Es scheint zwar alles ok zu sein, doch ich bekomme leider keine aktuellen Werte rein. Letzte Wertänderung ist vor der Neuinstallation.
                                Mit der Vaillant App kommen aktuelle Werte, also die Serverseite passt. Wie ist das bei euch?
                                Glasfaser Tom Son 2 Replies Last reply Reply Quote 0
                                • Glasfaser
                                  @massiveattack sagte in Test Adapter Vaillant multiMatic v0.0.x:
                                  Stelle den Adapter mal auf die Log-Stufe DEBUG , und poste dann das Ergebniss hier .
                                  • MassiveAttack
                                    MassiveAttack @Glasfaser last edited by MassiveAttack
                                    @glasfaser
                                    deleted...
                                    Glasfaser T 2 Replies Last reply Reply Quote 0
                                    • Glasfaser
                                      @massiveattack
                                      Log ist für @tombox
                                      Setze den Log in Code-Tags </>
                                        @massiveattack Lösche bitte den log und schicke mir das per PN.
                                        • MassiveAttack
                                          @glasfaser
                                          sry, done 🙂
                                          • Tom Son
                                            Tom Son @MassiveAttack last edited by
                                            @massiveattack
                                            Habe gleiches Problem, seit dem update gestern kommen keine Werte mehr rein, habt ihr schon was gefunden? Neuesten Adapter habe ich via Github schon installiert...
                                            1.0k
                                            multimatic senso vaillan vr900 vr920
                                            92
                                            928
                                            286317
