    4. Test Adapter Vaillant multiMatic/senso und myVaillant
    • Meister Mopper
      Meister Mopper @MassiveAttack last edited by
      @massiveattack Bitte setze zukünftig den Code in </code tags>, dann wird es leserlich.
      3.2.7 ist noch beta, Du solltest ein issue beim js-controller aufmachen.
      Tom Son 1 Reply Last reply Reply Quote 0
      • Tom Son
        Tom Son @Meister Mopper last edited by
        @meister-mopper Habe heute auch das update gemacht, wird ja vorgeschlagen 🙂 aber lt Post im Forum mit "has no existing Obeject..." sollte man das dem Entwickler melden
        bei mir rennt der Adapter zwar, bekomme aber diese Meldungen:
        vaillant.0	2021-01-17 19:22:29.430	warn	(57240) Terminated (UNCAUGHT_EXCEPTION): Without reason
        vaillant.0	2021-01-17 19:22:29.427	info	(57240) terminating
        vaillant.0	2021-01-17 19:22:29.425	info	(57240) cleaned everything up...
        vaillant.0	2021-01-17 19:22:29.398	error	(57240) The state contains no properties! At least one property is expected!
        vaillant.0	2021-01-17 19:22:29.398	error	(57240) Error: The state contains no properties! At least one property is expected! at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5783:23)
        vaillant.0	2021-01-17 19:22:29.395	error	(57240) unhandled promise rejection: The state contains no properties! At least one property is expected!
        vaillant.0	2021-01-17 19:22:29.393	error	(57240) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        vaillant.0	2021-01-17 19:22:09.172	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.dhw01.circulation.configuration.operationMode" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.165	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.dhw01.hotwater.configuration.temperature_setpoint" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.164	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.dhw01.hotwater.configuration.operation_mode" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.154	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.configuration.holidaymode.temperature_setpoint" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.153	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.configuration.holidaymode.end_date" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.152	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.configuration.holidaymode.start_date" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.151	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.configuration.holidaymode.active" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.151	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.configuration.eco_mode" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.150	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.configuration.quick_veto.setpoint_temperature" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.149	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.configuration.quick_veto.active" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.148	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.configuration.inside_temperature" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.147	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.configuration.active_function" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.147	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.configuration.enabled" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.145	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.configuration.name" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.137	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.heating.configuration.setpoint_temperature" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.136	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.heating.configuration.setback_temperature" has no existing object, this might lead to an error in future versions
        vaillant.0	2021-01-17 19:22:09.134	warn	(57240) State "vaillant.0.21xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxN1.systemcontrol.zones01.heating.configuration.mode" has no existing object, this might lead to an error in future versions
          tombox @Tom Son last edited by
          @tom-son Kannst du mal über github installieren und schauen ob die Warnungen weg sind
          • Tom Son
            Tom Son @tombox last edited by
            @tombox drüber installieren? oder vorher de und dann wieder installieren?
              @tom-son Einfach drüber installieren und instanze neustarten
              • Tom Son
                @tombox OK, erledigt, sieht mal ruhig aus, auch mit Loglevel Info
                • MassiveAttack
                  sorry fürs schlechte format 🙂
                  wenn ich den adapter mit npm install iobroker.vaillant neu installieren will, bekomme ich auch Fehler:
                  npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                  npm WARN pi No description
                  npm WARN pi No repository field.
                  npm WARN pi No README data
                  npm WARN pi No license field.
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.1 (node_modules/iobroker.js-controller/node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  + iobroker.vaillant@0.0.10
                  added 2 packages from 2 contributors and audited 1013 packages in 13.969s
                  10 packages are looking for funding
                    run `npm fund` for details
                  found 25 vulnerabilities (22 low, 3 high)
                    run `npm audit fix` to fix them, or `npm audit` for details
                  pi@192.168.0.10:~$ sudo npm install iobroker.vaillant
                  T Glasfaser 2 Replies Last reply Reply Quote 0
                    tombox @MassiveAttack last edited by
                    @massiveattack Ich sehe nur Warnungen, aber du bist im falschen Ordner. Du solltest nur über die admin oberfläche updaten oder über das github icon 41e15f8b-b168-4f01-8a65-325732e245fd-image.png
                    • Glasfaser
                      Glasfaser @MassiveAttack last edited by
                      @massiveattack
                      Hierrüber Installieren
                      MassiveAttack 1 Reply Last reply Reply Quote 0
                      • MassiveAttack
                        MassiveAttack @Glasfaser last edited by
                        @glasfaser
                        Besten Dank! Scheint nun stabil zu laufen, danke für die raschen Rückmeldungen 🙂
                        • MassiveAttack
                          MassiveAttack last edited by MassiveAttack
                          Es scheint zwar alles ok zu sein, doch ich bekomme leider keine aktuellen Werte rein. Letzte Wertänderung ist vor der Neuinstallation.
                          Mit der Vaillant App kommen aktuelle Werte, also die Serverseite passt. Wie ist das bei euch?
                          Glasfaser Tom Son 2 Replies Last reply Reply Quote 0
                          • Glasfaser
                            @massiveattack sagte in Test Adapter Vaillant multiMatic v0.0.x:
                            Stelle den Adapter mal auf die Log-Stufe DEBUG , und poste dann das Ergebniss hier .
                            • MassiveAttack
                              MassiveAttack @Glasfaser last edited by MassiveAttack
                              @glasfaser
                              deleted...
                              Glasfaser T 2 Replies Last reply Reply Quote 0
                              • Glasfaser
                                @massiveattack
                                Log ist für @tombox
                                Setze den Log in Code-Tags </>
                                  @massiveattack Lösche bitte den log und schicke mir das per PN.
                                  • MassiveAttack
                                    @glasfaser
                                    sry, done 🙂
                                    • Tom Son
                                      Tom Son @MassiveAttack last edited by
                                      @massiveattack
                                      Habe gleiches Problem, seit dem update gestern kommen keine Werte mehr rein, habt ihr schon was gefunden? Neuesten Adapter habe ich via Github schon installiert...
                                        @tom-son Habe das problem gefunden und behoben
                                        MassiveAttack Tom Son 2 Replies Last reply Reply Quote 0
                                        • MassiveAttack
                                          MassiveAttack @tombox last edited by
                                          @tombox
                                          super, danke dir, läuft wieder alles 🙂
                                          • Tom Son
                                            @tombox OK, super... was ist zu tun? Adapter wieder von Github drüber installieren?
                                            1.0k
                                            multimatic senso vaillan vr900 vr920
                                            92
                                            928
                                            296580
