    4. [SourceAnalytix 0.4.8-Final] Released !
    • Dutchman
      Dutchman Developer Most Active Administrators @MartyBr last edited by
      @martybr
      danke ! welchen wert hat der state jetzt und welchen wert hat kumulative reading fuer diesen ?
        MartyBr @MartyBr last edited by
        @Dutchman
        Hier auch der zweite Zähler. Beide liefen bis zur Alpha 15 ohne Probleme.
          "type": "state",
          "common": {
            "name": "1-0:1_8_1.value",
            "type": "number",
            "read": true,
            "unit": "kWh",
            "role": "value",
            "write": false,
            "custom": {
              "sourceanalytix.0": {
                "enabled": true,
                "alias": "",
                "state_type": "kWh_heatpomp",
                "state_unit": "kWh",
                "costs": true,
                "consumption": true,
                "meter_values": true,
                "start_day": 6283.2,
                "start_week": 6283.2,
                "start_month": 6014.3,
                "start_quarter": 6014.3,
                "start_year": 6014.3,
                "selectedPrice": "Heatpump",
                "selectedUnit": "automatisch",
                "currentValue": 6197.9,
                "valueAtDeviceReset": 0,
                "valueAtDeviceInit": 6295.2,
                "cumulativeValue": 6283.2
              "statistics.0": {
                "enabled": true,
                "logName": "",
                "count": false,
                "sumCount": false,
                "timeCount": false,
                "fiveMin": false,
                "groupFactor": 1,
                "impUnit": "",
                "impUnitPerImpulse": "",
                "sumIgnoreMinus": true,
                "sumDelta": true,
                "avg": true,
                "sumGroup": "Energie",
                "minmax": true
              "influxdb.0": {
                "enabled": true,
                "changesOnly": true,
                "debounce": "1000",
                "retention": 0,
                "changesRelogInterval": "300",
                "changesMinDelta": 0,
                "storageType": "",
                "aliasId": "Heizungsstrom"
            "alias": {
              "id": "smartmeter.0.1-0:1_8_1.value"
          "from": "system.adapter.sourceanalytix.0",
          "user": "system.user.admin",
          "ts": 1610977165257,
          "_id": "alias.0.Verbrauch.Strom.HWR.Stromzaehler-Heizung",
          "acl": {
            "object": 1636,
            "state": 1636,
            "owner": "system.user.admin",
          "native": {}
        • Dutchman
          @martybr
          bitte von beiden states den jetzigen wert und wert ii cumulativeReading
            MartyBr @Dutchman last edited by
            @dutchman
            Haushaltsstrom:
            Wert: 16477.562 kWh
            culumativeReading: 16477.391 kWh
            Wärmepumpe:
            Wert: 6295.3 kWh
            culumativeReading: 6295.1 kWh
            M Dutchman 2 Replies Last reply Reply Quote 0
              @Dutchman
              • Dutchman
                @martybr sagte in [SourceAnalytix 0.4.8-RC.1] Stable version announcement:
                @dutchman
                Haushaltsstrom:
                Wert: 16477.562 kWh
                Wärmepumpe:
                Wert: 6295.3 kWh
                hmmm welche version hast du da gerade drauf, just to be sure .... ?
                  @dutchman
                  Die neue Alpha 17. Die sollte ja den Fehler bei Reset um 0:00 Uhr beheben. Die Alpha 15 lief einwandfrei.
                    Kueppert last edited by
                    @dutchman Update auf Alpha 17 - System ausgelastet. Kill vom SA via Putty brachte keine Entlastung. ioBroker neu gestartet via Putty, dann schnell in die Weboberfläche und SA pausiert. Hab daher nur ein kurzes Log vom Adapter:
                    sourceanalytix.0	2021-01-18 15:17:03.045	error	(8112) Connection is closed.
                    sourceanalytix.0	2021-01-18 15:17:03.044	error	at TCP.<anonymous> (net.js:672:12)
                    sourceanalytix.0	2021-01-18 15:17:03.044	error	at Socket.EventEmitter.emit (domain.js:482:12)
                    sourceanalytix.0	2021-01-18 15:17:03.044	error	at Socket.emit (events.js:310:20)
                    sourceanalytix.0	2021-01-18 15:17:03.044	error	at Object.onceWrapper (events.js:417:26)
                    sourceanalytix.0	2021-01-18 15:17:03.044	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:146:20)
                    sourceanalytix.0	2021-01-18 15:17:03.044	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:179:25)
                    sourceanalytix.0	2021-01-18 15:17:03.044	error	(8112) Error: Connection is closed.
                    sourceanalytix.0	2021-01-18 15:17:03.034	error	(8112) unhandled promise rejection: Connection is closed.
                    sourceanalytix.0	2021-01-18 15:17:03.033	error	(8112) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    • Dutchman
                      Dutchman Developer Most Active Administrators @Dutchman last edited by
                      hmm ok er liest den kumulierten wert nicht richtig aus, auf dem state steht 16477.391 aber im object 16465.65
                      @Kueppert
                      danke, ich ziehe 17 aus dem verkehr.... WTF hier lief es local ich gehe mall was essen, kopf freimachen und troubleshooten
                      Danke fuer euer feedback und sorry fuer die system auslastung 😕
                        Kueppert @Dutchman last edited by
                        @dutchman ach, kein Problem. Wenn ich schon nix programmieren kann, stehe ich gern mit meiner Maschine zum Testen parat 😉
                        • Dutchman
                          Dutchman Developer Most Active Administrators @Kueppert last edited by
                          @kueppert sagte in [SourceAnalytix 0.4.8-RC.1] Stable version announcement:
                          danke dafuer .... ich mache mal bissl quaity time mit den kids danach ist der kopf wieder frei fuer solche Sachen....
                          Das lustige ist... da steht ein super harter return und if das diese situation nicht auftreten kan aber trotzdem passiert es ... pff
                          M Dutchman 2 Replies Last reply Reply Quote 1
                            @dutchman
                            Kannst du die Alpha 15 freigeben? Oder wie kann ich diese Version installieren?
                            • Dutchman
                              Dutchman Developer Most Active Administrators @Dutchman last edited by Dutchman
                              @MartyBr @Kueppert
                              ein so kleiner fehlleer mit so grosser Auswirkung !
                              mal bitte neu von git !
                              wen das klappt release ich sofort alpha-18
                              euer reset value war 0, logisch ist ja ein geraet was weiterzahlt aber so wird das ne endlose schleife natuerlich
                                A Former User @Dutchman last edited by
                                @dutchman
                                gerade 15:29 die alpha 17 installiert und mein log läuft auch voll.
                                • Dutchman
                                  Dutchman Developer Most Active Administrators @Guest last edited by
                                  @pete0815 sagte in [SourceAnalytix 0.4.8-RC.1] Stable version announcement:
                                  @dutchman
                                  bitte neu von git ziehen
                                    @dutchman
                                    Es wird noch die 17 angezeigt.
                                    • Dutchman
                                      Dutchman Developer Most Active Administrators @MartyBr last edited by Dutchman
                                      @dutchman
                                      egal, neu von git gezogen ?
                                      Edit : habe git geaendert, wen richtig installiert muss er im admin version 0.4.8-alpha.18r1 anzeigen !
                                      ? M 3 Replies Last reply Reply Quote 0
                                        A Former User @Dutchman last edited by A Former User
                                        @dutchman
                                        alpha 18 rc1 installiert. der Log läuft leider bei mir voll:
                                        urceanalytix.0	2021-01-18 15:36:45.184	error	(872) [calculationHandler] unforeseen situation for javascript.0.scriptEnabled.PV.PVerbrauch, please send this to developer | reading : 42.01233146897248 | calcvalues : {"cumulativeValue":42.011408182
                                        sourceanalytix.0	2021-01-18 15:36:45.180	error	(872) [calculationHandler] unforeseen situation for javascript.0.scriptEnabled.PV.PEinspeisung, please send this to developer | reading : 9.75394079044438 | calcvalues : {"cumulativeValue":9.753940790
                                        sourceanalytix.0	2021-01-18 15:36:43.281	error	(872) [calculationHandler] unforeseen situation for mqtt.0.ESP_Gefrierschrank.TempRegler.Virtual_Energy_Power, please send this to developer | reading : 2.0797978180555563 | calcvalues : {"cumulativeV
                                        sourceanalytix.0	2021-01-18 15:36:42.598	error	(872) [calculationHandler] unforeseen situation for shelly.0.SHPLG2-1#DB45A0#1.Relay0.Power, please send this to developer | reading : 0.9643398749833328 | calcvalues : {"cumulativeValue":0.9643398749
                                        sourceanalytix.0	2021-01-18 15:36:41.371	error	(872) [calculationHandler] unforeseen situation for shelly.0.SHPLG-S#7AEA8C#1.Relay0.Power, please send this to developer | reading : 2.1127807195222212 | calcvalues : {"cumulativeValue":2.11278071952
                                        sourceanalytix.0	2021-01-18 15:36:40.741	error	(872) [calculationHandler] unforeseen situation for shelly.0.SHPLG-S#267CF7#1.Relay0.Power, please send this to developer | reading : 1.515550924363889 | calcvalues : {"cumulativeValue":1.515550924363
                                        sourceanalytix.0	2021-01-18 15:36:39.968	error	(872) [calculationHandler] unforeseen situation for javascript.0.scriptEnabled.PV.WRPACges, please send this to developer | reading : 18.078552390833305 | calcvalues : {"cumulativeValue":18.0785523908
                                        sourceanalytix.0	2021-01-18 15:36:39.205	error	(872) [calculationHandler] unforeseen situation for javascript.0.scriptEnabled.PV.PVerbrauch, please send this to developer | reading : 42.01140818272248 | calcvalues : {"cumulativeValue":42.011408182
                                        sourceanalytix.0	2021-01-18 15:36:38.341	error	(872) [calculationHandler] unforeseen situation for javascript.0.scriptEnabled.PV.PEinspeisung, please send this to dev
                                          @dutchman
                                          hier die Debug-Ausgabe:
                                          Log1.txt
                                            Michi_Pi last edited by
                                            @Dutchman Mal kurz eine Frage,
                                            der cumulativeValue sollte doch die Summe aus valueDeviceReset + valueDeviceInit sein oder?
                                            2302
                                            1137380
