    4. Test : Wasserenthärtung judo i-soft plus Adapter
    • O
      oranggila @oranggila last edited by
      @oranggila Ich denke aber der Datenpunkt muss in Liter sein, nicht qm. Oder was meint ihr?
        arteck Developer Most Active @oranggila last edited by
        @oranggila du haswt den nicht nochmal installiert wie ich es gesagt habe..
        also hol das bitte nach
        • O
          oranggila @arteck last edited by
          @arteck Ok, bitteschön
          judoisoft.0	2021-01-09 18:51:46.607	debug	(32424) --> stateID judoisoft.0.WaterStop changed: false (ack = true)
          judoisoft.0	2021-01-09 18:51:46.603	debug	(32424) -> ValveState
          judoisoft.0	2021-01-09 18:51:44.780	debug	(32424) -> StandBy
          judoisoft.0	2021-01-09 18:51:43.057	debug	(32424) -> WaterYearly
          judoisoft.0	2021-01-09 18:51:43.056	debug	(32424) WaterYearly.12 -1 -1
          judoisoft.0	2021-01-09 18:51:43.056	debug	(32424) WaterYearly.11 -1 -1
          judoisoft.0	2021-01-09 18:51:43.055	debug	(32424) WaterYearly.10 -1 -1
          judoisoft.0	2021-01-09 18:51:43.055	debug	(32424) WaterYearly.09 -1 -1
          judoisoft.0	2021-01-09 18:51:43.055	debug	(32424) WaterYearly.08 -1 -1
          judoisoft.0	2021-01-09 18:51:43.054	debug	(32424) WaterYearly.07 -1 -1
          judoisoft.0	2021-01-09 18:51:43.054	debug	(32424) WaterYearly.06 -1 -1
          judoisoft.0	2021-01-09 18:51:43.054	debug	(32424) WaterYearly.05 -1 -1
          judoisoft.0	2021-01-09 18:51:43.053	debug	(32424) WaterYearly.04 -1 -1
          judoisoft.0	2021-01-09 18:51:43.053	debug	(32424) WaterYearly.03 -1 -1
          judoisoft.0	2021-01-09 18:51:43.053	debug	(32424) WaterYearly.02 -1 -1
          judoisoft.0	2021-01-09 18:51:43.052	debug	(32424) WaterYearly.01 1459 1459
          judoisoft.0	2021-01-09 18:51:41.201	debug	(32424) -> WaterTotaal 49247 31698
          judoisoft.0	2021-01-09 18:51:39.575	debug	(32424) -> Quantity
          judoisoft.0	2021-01-09 18:51:37.390	debug	(32424) -> FlowRate
          judoisoft.0	2021-01-09 18:51:35.356	debug	(32424) -> NaturalHardness
          judoisoft.0	2021-01-09 18:51:33.704	debug	(32424) -> WaterAverage
          judoisoft.0	2021-01-09 18:51:32.007	debug	(32424) -> SaltQuantity
          judoisoft.0	2021-01-09 18:51:29.312	debug	(32424) -> SaltRange
          judoisoft.0	2021-01-09 18:51:27.043	debug	(32424) --> stateID judoisoft.0.ResidualHardness changed: 6 (ack = true)
          judoisoft.0	2021-01-09 18:51:27.038	debug	(32424) -> ResidualHardness
          judoisoft.0	2021-01-09 18:51:25.111	debug	(32424) -> WaterCurrent
          judoisoft.0	2021-01-09 18:51:23.054	debug	(32424) get Consumption data
          judoisoft.0	2021-01-09 18:51:23.053	debug	(32424) get Information Static 3 {"command":"service date","data":"1594389063","group":"contract","msgnumber":"1","status":"ok","token":"f455af61e017e22599608dd442088b524843af4317ff1ff24e8ef2efa43d337
          judoisoft.0	2021-01-09 18:51:23.053	debug	(32424) get Information Static 2 {"command":"init date","data":"1594389063","group":"contract","msgnumber":"1","status":"ok","token":"f455af61e017e22599608dd442088b524843af4317ff1ff24e8ef2efa43d3373",
          judoisoft.0	2021-01-09 18:51:23.052	debug	(32424) get Information Static 1 {"command":"hardware version","data":"5.10","group":"version","msgnumber":"1","status":"ok","token":"f455af61e017e22599608dd442088b524843af4317ff1ff24e8ef2efa43d3373",
          judoisoft.0	2021-01-09 18:51:23.052	debug	(32424) get Information Static 0 {"command":"software version","data":"02.09.h","group":"version","msgnumber":"1","status":"ok","token":"f455af61e017e22599608dd442088b524843af4317ff1ff24e8ef2efa43d337
          judoisoft.0	2021-01-09 18:51:15.316	debug	(32424) get Information Static
          judoisoft.0	2021-01-09 18:51:15.316	debug	(32424) connect Result: {"group":"register","command":"connect","msgnumber":"1","token":"f455af61e017e22599608dd442088b524843af4317ff1ff24e8ef2efa43d3373","parameter":"i-soft plus","serial number":"1
          judoisoft.0	2021-01-09 18:51:14.994	debug	(32424) getSerialnumber : {"group":"register","command":"show","msgnumber":"2","token":"f455af61e017e22599608dd442088b524843af4317ff1ff24e8ef2efa43d3373","status":"ok","data":[{"wtuType":"i-soft plus
          judoisoft.0	2021-01-09 18:51:14.576	debug	(32424) getToken: {"group":"register","command":"login","msgnumber":"1","name":"login","user":"*","password":"*","role":"customer","status":"ok","token":"f455af61e017e22599608dd442088b524843a
          judoisoft.0	2021-01-09 18:51:13.895	debug	(32424) getURL: https://192.168.0.29:8124/?group=register&command=login&msgnumber=1&name=login&user=*
          judoisoft.0	2021-01-09 18:51:13.890	debug	(32424) create state
          judoisoft.0	2021-01-09 18:51:13.876	info	(32424) starting. Version 0.0.9 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v12.20.1, js-controller: 3.1.6
          judoisoft.0	2021-01-09 18:51:13.449	debug	(32424) statesDB connected
          judoisoft.0	2021-01-09 18:51:13.449	debug	(32424) States connected to redis: 0.0.0.0:9000
          judoisoft.0	2021-01-09 18:51:13.441	debug	(32424) States create System PubSub Client
          judoisoft.0	2021-01-09 18:51:13.440	debug	(32424) States create User PubSub Client
          judoisoft.0	2021-01-09 18:51:13.435	debug	(32424) Redis States: Use Redis connection: 0.0.0.0:9000
          judoisoft.0	2021-01-09 18:51:13.434	debug	(32424) objectDB connected
          judoisoft.0	2021-01-09 18:51:13.432	debug	(32424) Objects connected to redis: 0.0.0.0:9001
          judoisoft.0	2021-01-09 18:51:13.417	debug	(32424) Objects client initialize lua scripts
          judoisoft.0	2021-01-09 18:51:13.416	debug	(32424) Objects create User PubSub Client
          judoisoft.0	2021-01-09 18:51:13.416	debug	(32424) Objects create System PubSub Client
          judoisoft.0	2021-01-09 18:51:13.414	debug	(32424) Objects client ready ... initialize now
          judoisoft.0	2021-01-09 18:51:13.397	debug	(32424) Redis Objects: Use Redis connection: 0.0.0.0:9001
          judoisoft.0	2021-01-09 18:51:15.316	debug	(32424) connect Result: {"group":"register","command":"connect","msgnumber":"1","token":"f455af61e017e22599608dd442088b524843af4317ff1ff24e8ef2efa43d3373","parameter":"i-soft plus","serial number":"19
            @oranggila sagte in Test : Wasserenthärtung judo i-soft plus Adapter:
            jo jetzt musst du warten bis hier am ende eine 0 steht.. ich vermute die wird nicht übermittelt.
            • O
              @oranggila Aktualisierung stoppt täglich nachdem mein DSL-Router durchstartet 4:30 Uhr und läuft nicht mehr neu an. Was macht man da am besten, Neustart des Adapters danach einplanen?
                @oranggila kommt da was als fehler ?? den wir bewegen uns Lokal.. sollte nicht stören
                O 2 Replies Last reply Reply Quote 0
                • O
                  @arteck Muss ich beobachten. Im Log war nichts mehr zu sehen, als ich es bemerkt habe.
                  • O
                    @arteck In den Logs der vergangenen Tage ist nach 4:30 Uhr DSL-Router Restart kein Eintrag mehr von judoisoft, auch keine Fehlermeldung. Hat noch jemand dieses Verhalten oder eine Erklärung dafür? Ich würde jetzt halt täglich einen Neustart des Adapters nach 4:30 Uhr einplanen als Workaround.
                      mpenno @oranggila last edited by
                      @oranggila Bei mir läuft der Adapter ohne Probleme.
                      Ich hatte letztens das erste Mal ein Problem, was einen fehlerhaften Neustart des gesamten Docker-Containers mit sich zog. Die eigentliche Ursache konnte ich aber nicht ausmachen.
                      Ich hatte kürzlich einige Adapter aktualisiert, jetzt auch noch mal. In den Änderungshistorien habe ich was von "fix crash case" bei den Adaptern "Information tab" und "javascript" gelesen.
                      Soweit alles in Ordnung 🙂
                      Viele Grüße
                      • O
                        oranggila @mpenno last edited by
                        @mpenno Bei mir läuft er jetzt auch stabil. Ich starte den Adapter täglich 5:30 Uhr neu und habe Aktualisierung alle 2 min eingestellt. VIS ist auch schon ganz brauchbar:
                        Nur die Wasserhärte einstellen im Adapter fehlt noch, damit die Szenen funktionieren.
                        M S 2 Replies Last reply Reply Quote 0
                          @oranggila Schöne Visu!
                          Bei mir aktualisieren sich jetzt auch keine Werte mehr. Alle Daten sind vom 21.01. ca. 3:00 Uhr morgens, auch der Zetistempel vom "Connection Status = OK".
                          Das Log ist unauffällig.
                          Soll ich was bestimmtes Prüfen, was der Sache dienlich sein kein, bevor ich den Adapter neu starte?
                          Viele Grüße
                          Michael
                            mpenno @mpenno last edited by
                            Habe dann gestern aufgrund vom Aktualisieren einiger Pakete, darunter auch den js-controller, neugestartet. Das war gestern gegen 16:30 Uhr.
                            Heute aktualisieren sich wieder keine Daten. Stehen geblieben ist er gestern um 21:24 Uhr.
                            Wieder mit Connection-Status = OK.
                            Er denkt scheinbar immer noch, er sei verbunden. Adapterspezifische Log-Meldungen gibt es nicht.
                            Zur Info: Mein Judo iSoft ist mit einem Netzwerkkabel angebunden, nicht per WLAN.
                            Viele Grüße
                            Michael
                              arteck Developer Most Active @mpenno last edited by arteck
                              @mpenno hmm..
                              aktualisiere nochmal vom GIT und stell den adapter mal auf silly und beobachte die logs.. wo der aussteigt
                                mpenno @arteck last edited by
                                @arteck Ja OK, mache ich.
                                Ich habe mal kurz das Netzwerkkabel vom Judo iSoft für 10 Minuten abgezogen. Das scheint dem Adapter nicht zu interessieren (Abfrageintervall war Standard=300s). Er scheint wirklich fest zu "hängen".
                                Ich melde mich später.
                                Danke übrigens für Deinen Support!
                                Habt Ihr eine PayPal-Kasse?
                                  jetzt auch mit cloud Login
                                  leider musste ich die Einstellung wieder ausbauen da die Cloud nicht die funktionalität hergibt
                                    @arteck Kleiner Zwischenstand: mit der 1.0.1 läuft es schon seit über 24h.
                                      Neuer Zwischenstand: Ich musste den Test abbrechen, da meine Docker-Instanz instabil lief. Mein RAM wurde knapp, so dass ich erst einen neuen Speicherriegel für meine Synology bestellen musste. Ich hoffe, er wird am Samstag geliefert 🙂
                                      • O
                                        oranggila last edited by oranggila
                                        gelöscht
                                        • O
                                          oranggila @arteck last edited by oranggila
                                          @arteck said in Test : Wasserenthärtung judo i-soft plus Adapter:
                                          @oranggila ok klingt plausibel.. ich bau es ein
                                          check 0.0.6
                                          @arteck Ist das Einstellen der Wasserhärte schon eingebaut in der 1.0.1?
                                            @oranggila ja
                                            31.7k
                                            79.8k
                                            i-soft judo wasserenthärtung
                                            22
                                            216
                                            21798
