      sigi234 Forum Testing Most Active @Zefau last edited by sigi234
      @zefau
      Hallo, beim bearbeiten von Jarvis meldet Web immer das:
      Edit:
      Kommt beim speichern und anwenden Button
      web.0	2021-01-18 23:17:07.420	warn	(12984) Empty pattern!
      web.0	2021-01-18 23:17:05.916	info	(12984) ==>Connected system.user.admin from ::1
      web.0	2021-01-18 23:17:05.729	info	(12984) <==Disconnect system.user.admin from ::1 jarvis
      web.0	2021-01-18 23:15:26.450	warn	(12984) Empty pattern!
      web.0	2021-01-18 23:15:25.046	info	(12984) ==>Connected system.user.admin from ::1
      web.0	2021-01-18 23:15:24.858	info	(12984) <==Disconnect system.user.admin from ::1 jarvis
      jarvis.0	2021-01-18 23:15:24.815	info	(15784) Backup styles..
      jarvis.0	2021-01-18 23:15:24.812	info	(15784) Backup devices..
      jarvis.0	2021-01-18 23:15:24.801	info	(15784) Backup layout..
      jarvis.0	2021-01-18 23:15:24.318	info	(15784) Backup settings..
      web.0	2021-01-18 23:13:21.911	warn	(12984) Empty pattern!
      web.0	2021-01-18 23:13:20.488	info	(12984) ==>Connected system.user.admin from ::1
      web.0	2021-01-18 23:13:20.211	info	(12984) <==Disconnect system.user.admin from ::1 jarvis
      jarvis.0	2021-01-18 23:13:20.121	info	(15784) Backup styles..
      jarvis.0	2021-01-18 23:13:20.117	info	(15784) Backup devices..
      jarvis.0	2021-01-18 23:13:20.104	info	(15784) Backup layout..
      jarvis.0	2021-01-18 23:13:19.547	info	(15784) Backup settings..
      web.0	2021-01-18 23:12:36.413	warn	(12984) Empty pattern!
      web.0	2021-01-18 23:12:34.846	info	(12984) ==>Connected system.user.admin from ::1
      web.0	2021-01-18 23:12:34.498	info	(12984) <==Disconnect system.user.admin from ::1 jarvis
      Platform: Windows
      RAM: 16 GB
      Node.js: v12.20.1
      NPM: 6.14.10
      JS Controler: 3.2.7
      Admin: 4.2.1
      Web: 3.2.3
      Socket.io: 3.1.4
      Script Engine: 4.10.8
      IOT: 1.8.8
      VIS: 1.3.6
      HM-Rega: 3.0.7
      HM-RPC: 1.14.31
      Jarvis: 2.2.0-beta.21
        A Former User @MCU last edited by A Former User
        @mcu vielen Dank, man - das war zu einfach 😉
        JayR 1 Reply Last reply Reply Quote 0
        • JayR
          JayR @Guest last edited by
          @Zefau : Ist es geplant, dass das Custom HTML Widgets auch auf onClick events reagiert? Momentan funktioniert das nicht
            A Former User @Zefau last edited by
            @zefau ja klar, gerne.
            leider kann ich den Absturz nicht mehr herstellen. Aus meiner Erinnerung heraus hatte ich bei Anzeigevariante so etwas geschrieben, im Verlauf von trial and error auch abweichende Texte.
            {"@CURRETDATE":"heute","":"später"}
              A Former User @Guest last edited by
              habe ein HM-LC-RGBW-WM LED Controller importiert.
              Das ist der Farbbalken, der hier gezeigt wird.
              Gültiger Bereich wär zwischen 0 (rot) und 200 (weiß). Lässt sicher der Balken entsprechend einstellen?
              • V
                voxid @Johannes Bauerstatter last edited by
                @johannes-bauerstatter
                Servus Johannes,
                Du gehst im IOBroker unter Adapter auf einen der letzen blauen Buttons im oberen Bereich: "Installieren aus eigenen URL".
                Dann bei "Adapter auswählen" "Jarvis (Zefau)" angeben. "installieren" und schwups, hast Du die letze Beta.
                Carsten
                • V
                  voxid @Johannes Bauerstatter last edited by voxid
                  @johannes-bauerstatter said in jarvis v2.1.0 - just another remarkable vis:
                  Hallo, kurz ne doofe Frage: Wie kann ich updaten oder neue Betas drüber installieren?
                  Servus Johannes,
                  Du gehst im IOBroker unter Adapter auf einen der letzten blauen Buttons im oberen Bereich: "Installieren aus eigenen URL".
                  Carsten
                  Johannes Bauerstatter 1 Reply Last reply Reply Quote 0
                    MCU @Zefau last edited by MCU
                    @zefau 2.2.0-beta.21
                    Iframe Scrollbalken auf Handy nicht bzw. kaum erkennbar:
                    Auf dem PC sieht es so aus:
                    https://github.com/Zefau/ioBroker.jarvis/issues/558
                    duczz created this issue in Zefau/ioBroker.jarvis
                    closed iframe #558
                    • Zefau
                      Zefau @JayR last edited by
                      @jayr sagte in jarvis v2.1.0 - just another remarkable vis:
                      Nein, was hast du denn vor?
                      • Zefau
                        Zefau @Guest last edited by
                        @muetzeheinrich sagte in jarvis v2.1.0 - just another remarkable vis:
                        Nein. Was ist denn 0-200 für ein Farbspektrum? 0-360 wäre korrekt.
                          @zefau das ist leider ein Alleinstellungsmerkmal bei diesem Controller.
                          wurde auch schon mal hier angesprochen , Lösung gab es aber IMHO nicht.
                          • Zefau
                            Dann in ioBroker einen eigenen Datenpunkt erstellen, der den jarvis Wert (hue oder hex) in das konviertert, was du brauchst (0-200).
                              @zefau iFrame mit iobroker.vis Zuordnung reagiert nicht mehr aus View-Wechsel (vis.0.control.command) changeView.
                              http://192.168.178.89:8082/vis/index.html?HOME#WOHNZIMMER bleibt bestehen.
                              Muss man da jetzt AktualisierungsIntervall >0 eintragen?
                              EDIT: View-Wechsel funktioniert mit 2.2.0-beta.22
                              Neues Thema zum iFrame:
                              Wenn das iFrame beim Laden der Seite nicht in der Fokus-Seite (Start bei #tab 0) steht, wird es falsch angezeigt(Seite ist #tab=tv-8):
                              Nachdem ich auf die Seite (#tab=tv-8) gehe und neu lade (F5), wird auch das iFrame richtig geladen:
                              • V
                                voxid last edited by voxid
                                Re: jarvis v2.1.0 - just another remarkable vis
                                Aktuelle Test Version 2.1.21
                                @Zefau
                                Servus,
                                ich verwende bei Media-Control spotify-premium. Bei der Auswahl der (hier: Boseboxen) werden nicht alle Devices, die in den Objekten des IOBrokers angeführt sind angezeigt. Irgendwie wurde bereits mal aktualisiert, da sich 1 Device geändert hat. Nach Neustart der Instanzen Spotify und Jarvis ändert sich nichts. Wir kann ich hier eine Aktualisierung anstupsen.
                                Carsten
                                sigi234 JayR 2 Replies Last reply Reply Quote 0
                                  sigi234 Forum Testing Most Active @voxid last edited by
                                  @voxid sagte in jarvis v2.1.0 - just another remarkable vis:
                                  Geräte importieren , neu einlesen und bei bereits hinzugefügte Geräte den entsprechenden Haken setzten.
                                  • JayR
                                    JayR @voxid last edited by
                                    @voxid said in jarvis v2.1.0 - just another remarkable vis:
                                    @Zefau
                                    Servus,
                                    Carsten
                                    Genau das Problem habe ich auch handelt sich anscheint um ein Bug
                                    Stephan Schleich 1 Reply Last reply Reply Quote 0
                                      sicadrip last edited by
                                      @jayr @voxid
                                      Was steht denn bei den fehlenden Geräten unter spotify-premium.0.devices.ID.isRestricted? Vielleicht lassen diese sich nicht über web-api steuern... das Problem habe ich auch mit Sonos-Geräten.
                                      • Johannes Bauerstatter
                                        Johannes Bauerstatter @voxid last edited by
                                        @voxid Vielen Dank für die Info
                                          kubi last edited by
                                          vielleicht kann mir einer auf die Sprünge helfen.
                                          Ich versuche Tuya Heizungsthermostate einzurichten alles klappt soweit bis auf die Einrichtung im Jarvis und zwar:
                                          Möchte ich im Jarvis den ECO Modus im Jarvis einbauen.
                                          Hat einer eventuell ähnliche Konfiguration und mir am besten wenn natürlich möglich mit Screenshots zeigen wie ich es einfach umsetzten könnte ?
                                          Ich bedanke mich schon mal vorab.
                                            Flopsi last edited by Flopsi
                                            Hat wer auch die Fibaro Shutter 2 im einsatz ? Wie habt ihr da die Steuerung gelöst ??
                                            Ich habe da verschiedene Probleme:
                                            Ich finde nur jeweils verschiedene Datenpunkte zum öffnen und schließ was dann so aussieht:
                                            Der Regler und dann die Punkte Öffnen/ Schließen
                                            Dann habe ich das Problem das 1 geschlossen ist und 99 offen die Skala aber von 0 bis 100 geht
                                            Ich hätte gerne die Button einzeln hoch runter
                                            Oder habe ich hier ein ganz falsche Denkweise ......
                                            Komisch ist auch wenn ich das so mache:
                                            Das nur der Button runter geht hoch passiert nix ......
                                            Datenpunkt ist so:
                                            316
                                            6126
                                            4115172
