    4. SMA Energy Meter in Echtzeit auslesen
      fuchs1978 last edited by
      Nun den SMA-em-Adapter von 0.5.3 auf 0.5.6. Sonnst alles beim alten
        Sneak-L8 last edited by
        Komisch, mir wird der sma-em 0.5.3 immer noch als aktuell gemeldet ...
          Ich hba gestern auch auf 0.5.6 gewechselt (ist halt nicht die stable Version). Die schmiert aber regelmäßig ab:
          2019-11-02 10:16:20.713  - info: host.ioBroker-RasPi instance system.adapter.sma-em.0 started with pid 12455
          2019-11-02 10:16:21.040  - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.sma-em/main.js:156
          2019-11-02 10:16:21.041  - error: Caught by controller[0]:                         var val = Number(((highbyte << 32n) + lowbyte));
          2019-11-02 10:16:21.042  - error: Caught by controller[0]:                                                        ^^
          2019-11-02 10:16:21.042  - error: Caught by controller[0]: SyntaxError: Invalid or unexpected token
          2019-11-02 10:16:21.042  - error: Caught by controller[0]:     at createScript (vm.js:80:10)
          2019-11-02 10:16:21.042  - error: Caught by controller[0]:     at Object.runInThisContext (vm.js:139:10)
          2019-11-02 10:16:21.042  - error: Caught by controller[0]:     at Module._compile (module.js:617:28)
          2019-11-02 10:16:21.043  - error: Caught by controller[0]:     at Object.Module._extensions..js (module.js:664:10)
          2019-11-02 10:16:21.043  - error: Caught by controller[0]:     at Module.load (module.js:566:32)
          2019-11-02 10:16:21.043  - error: Caught by controller[0]:     at tryModuleLoad (module.js:506:12)
          2019-11-02 10:16:21.043  - error: Caught by controller[0]:     at Function.Module._load (module.js:498:3)
          2019-11-02 10:16:21.043  - error: Caught by controller[0]:     at Function.Module.runMain (module.js:694:10)
          2019-11-02 10:16:21.044  - error: Caught by controller[0]:     at startup (bootstrap_node.js:204:16)
          2019-11-02 10:16:21.044  - error: Caught by controller[0]:     at bootstrap_node.js:625:3
          2019-11-02 10:16:21.044  - error: host.ioBroker-RasPi instance system.adapter.sma-em.0 terminated with code 1 ()
          2019-11-02 10:16:21.044  - info: host.ioBroker-RasPi Restart adapter system.adapter.sma-em.0 because enabled
          Ich bin jetzt erstmal wieder zurück auf 0.5.3
            Snuupy last edited by
            Hallo zusammen, ich habe mir vor einigen Monaten nach den Vorlagen von Marco in Node-Red ein Skript geschrieben, welches die Broadcast-Nachricht des Energy-Meters in seine Bestandteile zerlegt und die einzelnen Werte in eine InfluxDB schreibt, die ich dann per Grafana auslesen kann. Das hat bis letzte Nacht um kurz vor 2 super geklappt - seit dem speise ich ca. 650MW ein, und beziehe auch ebensoviel, diesen Werten möchte ich erstmal nicht glauben.
            Das sind aber tatsächlich die Werte, die aus dem Energymeter kommen. ich habe schon einen Neustart durchgeführt, das hat aber keine Änderung gebracht. Kann es sein, dass sich die Broadcastnachricht geändert hat, vielleicht durch ein automatisches Firmwareupdate? Das kann ich mir eigentlich nicht vorstellen, eine andere Erklärung habe ich aber nicht dafür.
            Hat jemand anderes eine Idee?
              Sneak-L8 @Sneak-L8 last edited by
              @Sneak-L8 sagte in SMA Energy Meter in Echtzeit auslesen:
              Ich hab gestern auch auf 0.5.6 gewechselt (ist halt nicht die stable Version). Die schmiert aber regelmäßig ab:
              Das Problem liegt an node-js v8. Damit ist der Adapter nicht umwandelbar. Hatte den Adapter schon geforkt und eine Anpassung als Pull Request gesendet. Jetzt habe ich ihn wieder zurückgezogen, denn mit node-js v10 funktioniert meine Änderung nicht.
              Also:
              node-js v8 -> alte Version 0.5.3 nehmen
              node-js v10 -> neuste Version möglich
                Trefzy last edited by
                Hallo Zusammen
                ich nutze seit 3 Monaten den IOBroker und möchte nun diesen Adapter installieren. Von der Installation aus Github "https://github.com/iobroker-community-adapters/ioBroker.sma-em.git" wird abgeraten. Gibt es den Adapter in einem offiziellen Repository?
                Ich habe natürlich versucht über die Url den Adapter zu installieren....da passiert aber gar nix. Nicht mal ne Fehlermeldung. Kann mir hier jemand weiter helfen?
                @Marcolotti: da dein NodeRed Skript Werte liefert ist meine 2te Frage ob man damit auch weitere Werte des SHM2.0 abfragen kann.
                ich brauche
                • Netzeinspeisung aktuell
                • Netzeinspeisung Tag
                • Netzbezug aktuell
                • Netzbezug Tag
                • Hausverbrauch aktuell
                • Hausverbrauch Tag
                • Batterieladung aktuell
                • Batterieentladung aktuell
                • Batterie Füllstand in %
                Wäre für jedes Feedback froh
                Slowman 1 Reply Last reply Reply Quote 0
                • Slowman
                  Slowman @Trefzy last edited by
                  @trefzy
                  Taucht der SMA EM in der Adapteransicht auf? Hast du eine Instanz erstellt? Warum soll man den Adapter von DutchmanNL nicht nehmen?
                  Nimm mal den Link: https://github.com/iobroker-community-adapters/ioBroker.sma-em
                  und schaue dir dazu mal SMA Speedwire an, Link:https://github.com/AttackStrawbery/ioBroker.sma-speedwire
                    @slowman Hab es nun hinbekommen. Adapter taucht nicht in der Übersicht auf und abraten steht ja im allgemeinen Fenster wenn man manuelle Pakete installieren möchte. Da ich kein Profi bin hat mich das abgeschreckt.
                    Fehler war das ich im Reiter "Github" installiert habe und nicht unter "beliebig". Weiter hat der NodeRed Adapter die Verbindung blockiert. Den brauchts ja jetzt nicht mehr.
                    Danke für die Hilfe
                      walter12 @Trefzy last edited by
                      @trefzy said in SMA Energy Meter in Echtzeit auslesen:
                      Danke für die Hilfe
                      Darf ich fragen, wie du es hin bekommen hast ?
                      Ich hab die ganz aktuelle IoBroken Version und die aktuelle SMA EM Version. Die Installation hat soweit geklappt, blos jetzt bekomme ich unter Instanzen den Fehler Verbindung zum sma-em: falsch (Gelb Icon)
                      Was mach ich falsch ? In den LOGs selbst ist kein Fehler drin.
                        Trefzy @walter12 last edited by
                        @walter12
                        das war bei mir auch so....Fehler war, wie ich oben schon geschrieben habe, dass mein NodeRed Adapter mit dem Skript aus dem Anfang des Threads noch aktiv war und die Kommunikation gestört hat. Nach der Deinstallation und einem Neustart hat er sich sofort verbunden. Habe ein SHM2.0 und ein Energiemeter im Einsatz. beides wird in einem separaten Ordner angezeigt.
                        Mehr kann ich dazu nicht sagen. sorry
                        85
                        26341
