    4. zigbee funktioniert nicht mehr
      mb78 @Asgothian last edited by
      @asgothian
      Hallo A.
      hier die aktuelle Log:
      2021-01-18 07:48:09.608 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
      2021-01-18 07:48:09.697 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 31991
      2021-01-18 07:48:09.702 - warn: zigbee.0 (16372) Got terminate signal. Checking desired PID: 0 vs own PID 16372
      2021-01-18 07:48:09.710 - info: zigbee.0 (16372) cleaned everything up...
      2021-01-18 07:48:09.715 - info: zigbee.0 (16372) Zigbee: disabling joining new devices.
      2021-01-18 07:48:09.717 - error: zigbee.0 (16372) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
      at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
      at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
      at Controller.databaseSave (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:219:45)
      at Controller. (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:200:18)
      at Generator.next ()
      at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
      at new Promise ()
      at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
      at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:199:16)
      at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:308:33))
      2021-01-18 07:48:09.718 - info: zigbee.0 (16372) terminating
      2021-01-18 07:48:09.720 - info: zigbee.0 (16372) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-01-18 07:48:09.721 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-01-18 07:48:09.721 - error: zigbee.0 (16372) unhandled promise rejection: Cannot read property 'getEntries' of null
      2021-01-18 07:48:09.724 - error: zigbee.0 (16372) TypeError: Cannot read property 'getEntries' of null
      at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55)
      at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:236:16)
      at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:252:31)
      at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:201:49)
      at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:120:43)
      at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:187:42)
      at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:304:20)
      at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:450:41)
      at Zigbee.emit (events.js:315:20)
      at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8270:22)
      2021-01-18 07:48:09.727 - warn: zigbee.0 (16372) Got terminate signal. Checking desired PID: 31991 vs own PID 16372
      2021-01-18 07:48:10.299 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2021-01-18 07:48:10.300 - info: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because desired by instance
      2021-01-18 07:48:11.751 - info: zigbee.0 (31991) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v13.14.0, js-controller: 3.1.6
      2021-01-18 07:48:11.887 - info: zigbee.0 (31991) Starting Zigbee npm ...
      2021-01-18 07:48:19.725 - error: zigbee.0 (31991) Failed to start Zigbee
      2021-01-18 07:48:19.728 - error: zigbee.0 (31991) Error: Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
      at ZStackAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)
      at Generator.throw ()
      at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
      2021-01-18 07:48:29.731 - info: zigbee.0 (31991) Try to reconnect. 1 attempts left
      2021-01-18 07:48:29.734 - info: zigbee.0 (31991) Starting Zigbee npm ...
      2021-01-18 07:48:49.450 - error: zigbee.0 (31991) Failed to start Zigbee
      2021-01-18 07:48:49.452 - error: zigbee.0 (31991) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
      2021-01-18 07:50:00.014 - warn: host.raspberrypi instance system.adapter.ical.0 already running with pid 31540
      • Asgothian
        Asgothian Developer @mb78 last edited by
        @mb78
        Danke für das Log. Leider ist es unbrauchbar. Es zeigt einen der vergeblichen Versuche des Admin den Zigbee-Adapter anzuhalten und neu zu starten.
        Bitte folge der Beschreibung die ich oben gepostet habe, damit wir ein sauberes Log eines "neuen" Startversuches bekommen.
        A.
          mb78 last edited by
          Also jede Zeile löschen in der das Wort zigbee nicht drin vorkommt löschen?
            mb78 last edited by
            Oder sind nur die mit Datum relevant?
            • Asgothian
              @mb78
              Zeilen die ähnlich sind wie die oben angegebene, nur das da statt zigbee.0 ein anderer Adapter steht sollten gelöscht werden.
              A.
                mb78 last edited by
                zigbee.0	2021-01-18 09:56:53.783	error	(17351) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStack
                zigbee.0	2021-01-18 09:56:53.781	error	(17351) Failed to start Zigbee
                zigbee.0	2021-01-18 09:56:34.060	info	(17351) Starting Zigbee npm ...
                zigbee.0	2021-01-18 09:56:34.058	info	(17351) Try to reconnect. 1 attempts left
                zigbee.0	2021-01-18 09:56:24.055	error	(17351) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStack
                zigbee.0	2021-01-18 09:56:24.052	error	(17351) Failed to start Zigbee
                zigbee.0	2021-01-18 09:56:04.221	info	(17351) Starting Zigbee npm ...
                zigbee.0	2021-01-18 09:56:04.116	info	(17351) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v13.14.0, js-controller: 3.1.6
                host.raspberrypi	2021-01-18 08:56:02.715	info	Do not restart adapter system.adapter.zigbee.0 because desired by instance
                Hier das neue Log. Diesmal kürzer...
                Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
                • Asgothian
                  @mb78
                  Dieses doch recht kurze Log deutet darauf hin das die Firmware auf dem Stick nicht mit dem ioBroker reden will. Ich gehe davon aus das ein erneutes Flashen der Firmware auf dem Stick helfen wird.
                  Alternativ kannst Du den Test noch einmal wiederholen, dabei aber
                  • vor dem Start den Zigbee-Adapter auf debug umstellen
                  • vor dem Start in den Einstellungen des Zigbee Adapters den Haken bei 'zigbee herdsman debug infos' setzen.
                  Damit wird der Adapter gleich deutlich auskunftsfreudiger.
                  A.
                    mb78 last edited by
                    Ok, hier nun mit debug info hoffentlich
                    zigbee.0	2021-01-18 17:42:04.401	error	(29684) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/a
                    zigbee.0	2021-01-18 17:42:04.399	error	(29684) Failed to start Zigbee
                    host.raspberrypi	2021-01-18 17:41:59.804	info	Restart adapter system.adapter.radar2.0 because enabled
                    host.raspberrypi	2021-01-18 17:41:59.804	info	instance system.adapter.radar2.0 terminated with code 0 (NO_ERROR)
                    radar2.0	2021-01-18 17:41:59.732	info	(30055) radar2 set to scan every 20 seconds and printers every 720 minutes.
                    radar2.0	2021-01-18 17:41:59.732	info	(30055) arp-scan will use the following interfaces: [ 'eth0', 'wlan0' ]
                    radar2.0	2021-01-18 17:41:59.731	info	(30055) Remove name end for host names: .fritz.box
                    radar2.0	2021-01-18 17:41:59.730	info	(30055) use known IP list: [ '1.1.1.1' ]
                    radar2.0	2021-01-18 17:41:59.729	info	(30055) use known BT list: [ '01:12:23:34:45:56' ]
                    radar2.0	2021-01-18 17:41:59.728	info	(30055) radar2 set to flag items away if they are not seen for 2 minutes
                    radar2.0	2021-01-18 17:41:59.728	warn	(30055) node-bluetooth not found!
                    radar2.0	2021-01-18 17:41:59.726	warn	(30055) Noble not available, Error: Error: The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/bluetooth_hci_socket.node'was compiled against a different Node.js versi
                    radar2.0	2021-01-18 17:41:59.593	info	(30055) Adapter disconnected and stopped with dostop(false) and callback(true)
                    radar2.0	2021-01-18 17:41:59.592	error	(30055) Error: bind EACCES 0.0.0.0:67 at dgram.js:338:20 at processTicksAndRejections (internal/process/task_queues.js:85:21)
                    radar2.0	2021-01-18 17:41:59.591	error	(30055) uncaught exception: bind EACCES 0.0.0.0:67
                    radar2.0	2021-01-18 17:41:59.478	info	(30055) net-ping not available! Will try to use normal ping!
                    radar2.0	2021-01-18 17:41:59.467	info	(30055) radar2 initialization started...
                    radar2.0	2021-01-18 17:41:58.974	warn	(30055) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                    radar2.0	2021-01-18 17:41:58.256	info	(30055) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.radar2, node: v12.20.1, js-controller: 3.1.6
                    host.raspberrypi	2021-01-18 17:41:56.709	info	instance system.adapter.radar2.0 started with pid 30055
                    zigbee.0	2021-01-18 17:41:44.666	info	(29684) Starting Zigbee npm ...
                    zigbee.0	2021-01-18 17:41:44.663	info	(29684) Try to reconnect. 1 attempts left
                    zigbee.0	2021-01-18 17:41:34.660	error	(29684) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/a
                    zigbee.0	2021-01-18 17:41:34.658	error	(29684) Failed to start Zigbee
                    host.raspberrypi	2021-01-18 17:41:26.674	info	Restart adapter system.adapter.radar2.0 because enabled
                    host.raspberrypi	2021-01-18 17:41:26.674	info	instance system.adapter.radar2.0 terminated with code 0 (NO_ERROR)
                    radar2.0	2021-01-18 17:41:26.613	info	(29804) radar2 set to scan every 20 seconds and printers every 720 minutes.
                    radar2.0	2021-01-18 17:41:26.613	info	(29804) arp-scan will use the following interfaces: [ 'eth0', 'wlan0' ]
                    radar2.0	2021-01-18 17:41:26.612	info	(29804) Remove name end for host names: .fritz.box
                    radar2.0	2021-01-18 17:41:26.611	info	(29804) use known IP list: [ '1.1.1.1' ]
                    radar2.0	2021-01-18 17:41:26.611	info	(29804) use known BT list: [ '01:12:23:34:45:56' ]
                    radar2.0	2021-01-18 17:41:26.610	info	(29804) radar2 set to flag items away if they are not seen for 2 minutes
                    radar2.0	2021-01-18 17:41:26.609	warn	(29804) node-bluetooth not found!
                    radar2.0	2021-01-18 17:41:26.608	warn	(29804) Noble not available, Error: Error: The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/bluetooth_hci_socket.node'was compiled against a different Node.js versi
                    radar2.0	2021-01-18 17:41:26.468	info	(29804) Adapter disconnected and stopped with dostop(false) and callback(true)
                    radar2.0	2021-01-18 17:41:26.467	error	(29804) Error: bind EACCES 0.0.0.0:67 at dgram.js:338:20 at processTicksAndRejections (internal/process/task_queues.js:85:21)
                    radar2.0	2021-01-18 17:41:26.466	error	(29804) uncaught exception: bind EACCES 0.0.0.0:67
                    radar2.0	2021-01-18 17:41:26.355	info	(29804) net-ping not available! Will try to use normal ping!
                    radar2.0	2021-01-18 17:41:26.347	info	(29804) radar2 initialization started...
                    radar2.0	2021-01-18 17:41:25.893	warn	(29804) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                    radar2.0	2021-01-18 17:41:25.297	info	(29804) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.radar2, node: v12.20.1, js-controller: 3.1.6
                    host.raspberrypi	2021-01-18 17:41:23.951	info	instance system.adapter.radar2.0 started with pid 29804
                    zigbee.0	2021-01
                    • Asgothian
                      @mb78
                      • das log ist aus der Admin Oberfläche kopiert, nicht als Text herunter geladen
                      • es sind nur 2 abgeschrittene Zeilen vom zigbee Adapter drin
                      • es ist nur ein „restart“ zu erkennen, kein „Start“
                      Bitte die Anleitung oben Schritt für Schritt befolgen und das Ergebnis posten.
                      A.
                        mb78 last edited by
                        ist das normal das der adapter wieder startet obwohl ich ihn anghalten habe?
                        host.raspberrypi	2021-01-20 17:49:15.356	info	instance system.adapter.radar2.0 started with pid 2016
                        host.raspberrypi	2021-01-20 17:48:45.307	info	Restart adapter system.adapter.radar2.0 because enabled
                        host.raspberrypi	2021-01-20 17:48:45.307	info	instance system.adapter.radar2.0 terminated with code 0 (NO_ERROR)
                        radar2.0	2021-01-20 17:48:45.258	info	(1747) radar2 set to scan every 20 seconds and printers every 720 minutes.
                        radar2.0	2021-01-20 17:48:45.257	info	(1747) arp-scan will use the following interfaces: [ 'eth0', 'wlan0' ]
                        radar2.0	2021-01-20 17:48:45.257	info	(1747) Remove name end for host names: .fritz.box
                        radar2.0	2021-01-20 17:48:45.256	info	(1747) use known IP list: [ '1.1.1.1' ]
                        radar2.0	2021-01-20 17:48:45.255	info	(1747) use known BT list: [ '01:12:23:34:45:56' ]
                        radar2.0	2021-01-20 17:48:45.254	info	(1747) radar2 set to flag items away if they are not seen for 2 minutes
                        radar2.0	2021-01-20 17:48:45.254	warn	(1747) node-bluetooth not found!
                        radar2.0	2021-01-20 17:48:45.252	warn	(1747) Noble not available, Error: Error: The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/bluetooth_hci_socket.node'was compiled against a different Node.js versio
                        radar2.0	2021-01-20 17:48:45.122	info	(1747) Adapter disconnected and stopped with dostop(false) and callback(true)
                        radar2.0	2021-01-20 17:48:45.121	error	(1747) Error: bind EACCES 0.0.0.0:67 at dgram.js:338:20 at processTicksAndRejections (internal/process/task_queues.js:85:21)
                        radar2.0	2021-01-20 17:48:45.120	error	(1747) uncaught exception: bind EACCES 0.0.0.0:67
                        radar2.0	2021-01-20 17:48:45.008	info	(1747) net-ping not available! Will try to use normal ping!
                        radar2.0	2021-01-20 17:48:44.999	info	(1747) radar2 initialization started...
                        radar2.0	2021-01-20 17:48:44.542	warn	(1747) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                        radar2.0	2021-01-20 17:48:43.908	info	(1747) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.radar2, node: v12.20.1, js-controller: 3.1.6
                        host.raspberrypi	2021-01-20 17:48:42.630	info	instance system.adapter.radar2.0 started with pid 1747
                        das kam nachdem ich adapter gestoppt und log gelöscht habe.
                          Thomas Braun Most Active @mb78 last edited by
                          @mb78 Ich seh da nur Meldungen vom radar2.
                          Und ja, das Ding ist ein 'Biest'.
                            mb78 last edited by
                            2021-01-20 17:09:44.372 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                            2021-01-20 17:09:44.418 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 10864
                            2021-01-20 17:09:46.110 - info: zigbee.0 (10864) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.1, js-controller: 3.1.6
                            2021-01-20 17:09:46.207 - info: zigbee.0 (10864) Starting Zigbee npm ...
                            2021-01-20 17:09:54.014 - error: zigbee.0 (10864) Failed to start Zigbee
                            2021-01-20 17:09:54.016 - error: zigbee.0 (10864) Error: Failed to connect to the adapter (Error: Cannot request when znp
                            2021-01-20 17:10:04.018 - info: zigbee.0 (10864) Try to reconnect. 1 attempts left
                            2021-01-20 17:10:04.020 - info: zigbee.0 (10864) Starting Zigbee npm ...
                            2021-01-20 17:10:11.699 - error: zigbee.0 (10864) Failed to start Zigbee
                            2021-01-20 17:10:11.700 - error: zigbee.0 (10864) Error: Failed to connect to the adapter (Error: Cannot request when znp
                            das is alles was im groben mit zigbee übrig geblieben ist
                              @mb78 Ist das Log komplett? Da fehlt doch was am Zeilenende.
                                mb78 last edited by
                                Da war bestimmt noch was.
                                Ich sollte ja nur das schicken, was mit zigbee zu tun hat
                                  Thomas Braun Most Active @mb78 last edited by Thomas Braun
                                  @mb78 sagte in zigbee funktioniert nicht mehr:
                                  Ich meine diese Zeile z. B.
                                  da fehlt doch was am Ende, vermute ich.
                                  ZNP = Zigbee Network Processor
                                  aber was genau tut dem weh?
                                  Vielleicht ziehst du auch mal (nur diesen Adapter!) auf Version 1.4.2. aus dem Beta-Verwahrort hoch. Da ist sehr viel passiert seit deiner 1.3.1
                                    mb78 last edited by
                                    Oh man eh. Das wird wieder ein Krampf. Wo bekomme ich das Update
                                      @mb78
                                      In den Einstellungen des Adapters den Verwahrort auf
                                      Beta/Latest stellen und dann das angebotene Update für zigbee reinschaufeln, danach den Verwahrort wieder auf 'default/stable' setzen.
                                        mb78 last edited by
                                        Is das unter Adapter zu finden? Oder Instanzen?
                                          @mb78
                                          Weder noch. Klick auf den Schraubenschlüssel. Gelb hinterlegt...
                                            mb78 last edited by mb78
                                            Bezieht sich das nicht auf alle. Adapter?Screenshot_20210120-201549_CM Browser.jpg
                                            5209
