    4. Test Eventlist Adapter
    • O
      Oli @Bluefox last edited by
      @Bluefox
      Sorry, soviel Aufwand wollte ich nicht verursachen, aber danke, dass du es umgesetzt hast.
      • Ruud2019
        Ruud2019 @Bluefox last edited by
        @Bluefox
        Seit dem Update auf die aktuelle Version hängt sich der Adapter bei mir bei jeder Statusänderung auf.
        eventlist.0	2020-12-11 10:11:39.788	error	at /opt/iobroker/node_modules/iobroker.eventlist/main.js:621:21
        eventlist.0	2020-12-11 10:11:39.788	error	at new Promise (<anonymous>)
        eventlist.0	2020-12-11 10:11:39.788	error	at /opt/iobroker/node_modules/iobroker.eventlist/main.js:686:24
        eventlist.0	2020-12-11 10:11:39.788	error	at formatEvent (/opt/iobroker/node_modules/iobroker.eventlist/main.js:355:47)
        eventlist.0	2020-12-11 10:11:39.788	error	(26925) TypeError: Cannot read property 'replace' of undefined
        eventlist.0	2020-12-11 10:11:39.788	error	(26925) unhandled promise rejection: Cannot read property 'replace' of undefined
        Unhandled	2020-12-11 10:11:39.788	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        eventlist.0	2020-12-11 10:11:39.772	error	at /opt/iobroker/node_modules/iobroker.eventlist/main.js:621:21
        eventlist.0	2020-12-11 10:11:39.772	error	at new Promise (<anonymous>)
        eventlist.0	2020-12-11 10:11:39.772	error	at /opt/iobroker/node_modules/iobroker.eventlist/main.js:686:24
        eventlist.0	2020-12-11 10:11:39.772	error	at formatEvent (/opt/iobroker/node_modules/iobroker.eventlist/main.js:355:47)
        eventlist.0	2020-12-11 10:11:39.772	error	(26925) TypeError: Cannot read property 'replace' of undefined
        eventlist.0	2020-12-11 10:11:39.772	error	(26925) unhandled promise rejection: Cannot read property 'replace' of undefined
        Unhandled	2020-12-11 10:11:39.771	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        eventlist.0	2020-12-11 10:11:39.660	error	at /opt/iobroker/node_modules/iobroker.eventlist/main.js:621:21
        eventlist.0	2020-12-11 10:11:39.660	error	at new Promise (<anonymous>)
        eventlist.0	2020-12-11 10:11:39.660	error	at /opt/iobroker/node_modules/iobroker.eventlist/main.js:686:24
        eventlist.0	2020-12-11 10:11:39.660	error	at formatEvent (/opt/iobroker/node_modules/iobroker.eventlist/main.js:355:47)
        eventlist.0	2020-12-11 10:11:39.660	error	(26925) TypeError: Cannot read property 'replace' of undefined
        eventlist.0	2020-12-11 10:11:39.660	error	(26925) unhandled promise rejection: Cannot read property 'replace' of undefined
        Unhandled	2020-12-11 10:11:39.660	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        Habe den Adapter schon mehrfach neu installiert und auch alle Zustände entfernt.
          Helmex @Ruud2019 last edited by
          Hallo. Nach der Installation kommt folgender LOG:
          startInstance system.adapter.eventlist.0: required adapter "vis" not found!
          Was mache ich falsch? Grüße
            sigi234 Forum Testing Most Active @Helmex last edited by
            @Helmex sagte in Test Eventlist Adapter:
            Vis Adapter installieren
              Helmex @sigi234 last edited by
              @sigi234
              Sorry aber ich bin noch Anfänger.
              Suche ich nach vis werden etliche Adapter angezeigt.
              Welchen soll ich nehmen?
                sigi234 Forum Testing Most Active @Helmex last edited by sigi234
                @sigi234
                https://www.iobroker.net/#de/documentation/viz/vis.md
                Man braucht eine Lizenz um vis zu nutzen.
                vis ist kostenlos für private Nutzung. Nur für kommerzielle Gebrauch muss man für eine Lizenz bezahlen.
                Man kann eine Lizenz auf iobroker.net nach der Registrierung bekommen.
                  @sigi234
                  Super. Alles grün
                  Editiere ich nun Werte in den Objekten müßten diese doch
                  protokoliert werden?
                  Leider keine Anzeige.
                    Ein Ereignis muss auch eintreten.
                    Wie schaut deine Ereignisliste aus im Adapter?
                      @sigi234
                      Leer. Allerdings habe ich hier auch nur eine Lampe und einen
                      Schalter von Ikea. Fange gerade erst an...
                      Komischerweise bekomme ich den Schalter zwar angelernt
                      aber nicht zum schalten. Ich denke mein Problem liegt woanders und habe derzeit
                      einfach keine Ereignisse.
                        mane444 last edited by
                        Hi, ich finde das einen Super Adapter.
                        Ich hab auch den Adapter LinkedDevices am laufen. Werden bool DPs mit dem Adapter LinkedDevices gelinkt dann werden diese vom Eventlist Adapter nicht mehr als bool erkannt.
                        Ich weiß beide Adapter sind im Test, aber vielleicht hilfts ja bei der Weiterentwicklung.
                        • Namrenner
                          Namrenner last edited by
                          Super Adapter, ist es möglich auch Ereignis in Vis unter Headers einzufügen, möchte ohne Ereignis in Vis arbeiten, da ich nur per Farbe (Zeit) anzeigen möchte, danke.
                            mike1976 @sigi234 last edited by mike1976
                            @sigi234 hi,
                            denke bin zu doof dafür, wo bitte bzw wie hinterlegst du die farben?
                            okay Farben denke ich habe ich gefunden, in vis ungerade und gerade hintergrund.
                            Bleiben noch die:
                            die eigenen texte ?
                            • siggi85
                              siggi85 last edited by
                              Kann man alle Events des aktuellen Tages in einer rudimentären Art (Zeitstempel und Ereignis pro Zeile) in einem Datenpunkte speichern? Ich habe bisher eine Liste, die ich mir bei Bedarf komplett per Telegramm ausgeben lasse (also nicht einzelne Ereignisse, sondern die ganze Liste auf einmal). Der JSON Datenpunkt eignet sich da leider noch so gut für.
                              Ansonsten mega Adapter! Habe noch nicht viel getestet, aber genau sowas als Adapter wollte ich auch schon lange haben. 👍
                              • Namrenner
                                leider ist noch ein Bug,
                                unter Ereignisliste, macht man ein Filter rein, dort möchte ich alle Ereignisse löschen von den eingestellten Filter, aber löscht alle Ereignisse von allen.
                                Wäre schön die zu reparieren.
                                • TheBam
                                  TheBam last edited by
                                  @namrenner
                                  bitte ein issue auf github erstellen
                                    sunshineh @TheBam last edited by
                                    Hallo, ich habe die EventList installiert, doch leider taucht sie unter Instanzen nicht auf.
                                    Wenn ich nun auf die VIS-Oberfläche gehe, kann ich zwar ein Eventlist-Widget auf den Screen ziehen, aber unter "Filter-IDs" nur einen Wert eintragen. Wie kann ich mehrere Werte in einer Liste eintragen
                                      crunchip Forum Testing Most Active @sunshineh last edited by
                                      @sunshineh sagte in Test Eventlist Adapter:
                                      von Git installiert? dann musst du die Instanz manuell hinzufügen
                                        marsmännchen last edited by
                                        Wenn ich einen Status zur Ereignisliste hinzufügen will dann werden bei mir die Objekt-Id`s nicht geladen.
                                        Hab ich was vergessen? Oder mache ich etwas falsch?
                                        Es dreht sich nur ewig der Kreis.
                                        Wenn ich dann auf Abbrechen gehe kann ich ihn per Copy&Paste von den Objekten rüber kopieren.
                                        Und bei "Default Messenger Settings" das selbe Problem.
                                        Admin: 4.2.2
                                        Node.js: v12.21.0
                                        NPM: 6.14.11
                                        JS controller: 3.2.16
                                        Gruß Patrick
                                          sigi234 Forum Testing Most Active @marsmännchen last edited by
                                          @marsmännchen
                                          Was kommt bei F12 ?
                                            marsmännchen @sigi234 last edited by marsmännchen
                                            @sigi234
                                            uiui, jetzt wirds interessant...
                                            was genau davon willst du wissen.
                                            Hier mal ein Screenshot von F12.events5.JPG192.168.1.195-1628374454730.log
                                            31.7k
                                            79.8k
                                            eventlist test
                                            33
                                            97
                                            11488
