    4. Ical mehrere Instanzen -> nur bestimmte Termine
      liv-in-sky @Karel Puhli last edited by liv-in-sky
      @karel-puhli
      @karel-puhli
      bitte die fehler und solche art von posts in code tag
      siehe: https://forum.iobroker.net/post/553912
      könnte da was beim kopieren schief gegangen sein
      schaut dann so aus:
      javascript.0 2021-01-14 09:59:53.624 error (1734) at process._tickCallback (internal/process/next_tick.js:68:7)
      javascript.0 2021-01-14 09:59:53.624 error (1734) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      javascript.0 2021-01-14 09:59:53.624 error (1734) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      javascript.0 2021-01-14 09:59:53.623 error (1734) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33)
      javascript.0 2021-01-14 09:59:53.623 error (1734) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1219:17)
      javascript.0 2021-01-14 09:59:53.623 error (1734) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1681:17)
      javascript.0 2021-01-14 09:59:53.622 error (1734) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1587:37)
      javascript.0 2021-01-14 09:59:53.622 error (1734) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1364:28)
      javascript.0 2021-01-14 09:59:53.622 error (1734) at Object.createScript (vm.js:277:10)
      javascript.0 2021-01-14 09:59:53.622 error (1734) at new Script (vm.js:83:7)
      javascript.0 2021-01-14 09:59:53.621 error (1734) SyntaxError: Unexpected end of input
      javascript.0 2021-01-14 09:59:53.621 error (1734) log('registered ' + __engine.__subscriptions + ' subscription' + (__engine.__subscriptions === 1 ? '' : 's' ) + ' and ' + __engine.__schedules + ' schedule' + (__engine.__schedules === 1 ? ''
      javascript.0 2021-01-14 09:59:53.620 error at script.js.Test.JavaScript.icalTabellen:71
      javascript.0 2021-01-14 09:59:53.620 error (1734) script.js.Test.JavaScript.icalTabellen compile failed:
      Karel Puhli 1 Reply Last reply Reply Quote 0
      • Karel Puhli
        Karel Puhli @liv-in-sky last edited by
        @liv-in-sky
        Das war definitiv ein Kopierfehler... 🙄
        Jetzt passt auch alles mit den Terminen! 👍 👍 👍
        Ich befasse mich mal jetzt ausführlich mit dem Skript!
        Und sage vielen Dank dafür! Top!!! 🙂
          @karel-puhli gerne - bei fragen einfach posten
          N 1 Reply Last reply Reply Quote 1
          • N
            nousefor82 @liv-in-sky last edited by nousefor82
            @liv-in-sky
            Servus und Danke für das Script.
            • N
              nousefor82 @nousefor82 last edited by nousefor82
              @liv-in-sky
              Guten Morgen,
              ich habe einen "Fehler"?
              Gestern stand unter NextGanzTägig: Morgen "balbal"
              Heute steht im gleichen Feld: Noch 1 Tag "blabla".
              Wäre es möglich, dass dann hier steht Heute, bzw. im Running-DP?
              Gerade gesehen, das Skript ja das, was es vom ical-bekommt.
              Und nach dem ical mir die Geburtstage (ganztägige Serientermine) über 2 Tage anzeigt, kommt es zu dieser unglücklichen Formulierung.
              @liv-in-sky : Kannst du im Skript einbauen, dass wenn da steht "Noch 1 Tag" umwandelt in "Heute"?
                liv-in-sky @nousefor82 last edited by
                @nousefor82
                muss ertmal nachdenken - dieses teilscript wurde ja hier rausgenommen - https://forum.iobroker.net/post/553690 in dem script brauche ich unbedingt dieses setting in ical:
                das "ersetze datum mit worten" darf nicht angklickt sein
                ich habe ein neues script im post oben drin - dort sollte mit dem "setting des bildes" das heute und morgen funktionieren
                @Karel-Puhli
                beim kopieren des scripts die settings (auch schedule) wieder angleichen!
                • Karel Puhli
                  Karel Puhli @liv-in-sky last edited by Karel Puhli
                  @liv-in-sky said in Ical mehrere Instanzen -> nur bestimmte Termine:
                  komisch, habe es bei mir angeklickt... es wird trotzdem korrekt angezeigt. Bezieht sich das nur auf einen der 3 Datenpunkte?
                    @karel-puhli
                    habe es mit der einstellung bei dem script hier nicht getestet - aber es wäre schon möglich - ich suche ja nach einem bestimmten format und ersetze dann. wenn das format nicht gefunden wird, bleibt der text unverändert und heute bzw morgen wird angezeigt
                    ich wollte nur einen standard für die beiden scripte haben - damit gehe ich auf nummer sicher, wenn jmd mal einen fehler hat. damit kann ich sicherstellen., dass der user die selben daten bekommt wie ich. ändert sich da mal was, kann ich das script umschreiben.
                      @karel-puhli
                      hi - ich mußt bei meinem anderen script (https://forum.iobroker.net/post/562178) noch etwas korrigieren , was auch dein script betrifft
                      habe es in den post kopiert - vielleicht kannst du bei gelegenheit testen
                      • Karel Puhli
                        @liv-in-sky
                        Hi! Oben im Spoiler ist jetzt ein aktuelleres Skript?
                        Grüße!
                          @karel-puhli
                          ja - hier: https://forum.iobroker.net/post/557333
                          Karel Puhli 2 Replies Last reply Reply Quote 1
                          • Karel Puhli
                            @liv-in-sky
                            Ich teste und sage bescheid. Was hast du denn geändert?
                            Danke und beste Grüße!
                              @karel-puhli es geht um die anzeige bzw um das erkennen . was der nächste termin ist. der ical adapter hat eine eigenwillige art zu zeigen, welche art der termin ist
                              wenn z.b. ein ganztagestermin heute ist, steht nur ein datum. ist ein ganz tagestermin in einen der folgenden tagen, steht dort: termin 01:00-00:00 und das datum des folgetages.
                              das habe ich versucht besser zu filtern, weil bei bestimmten konstellationen, falsche termine in den datenpunkten stand
                              Karel Puhli N 2 Replies Last reply Reply Quote 1
                              • Karel Puhli
                                @liv-in-sky
                                Bis dato läuft alles tacko! 👍
                                • N
                                  @liv-in-sky
                                  seit 1-2 Wochen hängt irgendwas.
                                  Und zwar zeigt er mir immer noch im Datenpunkt
                                  TerminNextGanzerTag
                                  einen Geburtstag an, der schon längst vorbei ist.
                                  Am Script habe ich nichts verändert.
                                  Kannst du dir einen Reim drauf machen?
                                  VG,
                                  Jörg
                                    @nousefor82
                                    hast du den ical adapter upgedatet ?
                                    • N
                                      @liv-in-sky
                                      Ist auf dem neusten Stand!
                                        @nousefor82 dann gibt es ein problem - da der ical neue datenpunkt struktur hat
                                        teste mal
                                        ersetze diese zeile
                                        mit dieser - wie im bild gezeigt
                                        let myDpInput=JSON.parse((getState(dpTSJson[i]).val));
                                        • N
                                          @liv-in-sky
                                          keine Änderung 😕
                                            @nousefor82 welcher version hat der ical-adapter
                                            how-to vis
                                            9040
