    4. Upgrade zigbee immer error
    • Asgothian
      Asgothian Developer @chucky666 last edited by
      @chucky666
      • Welche Node Version hast du ?
      • wenn du auf /opt/iobroker ein 'npm list dissolve' machst, was kommt da ?
      A.
      chucky666 1 Reply Last reply Reply Quote 0
      • chucky666
        chucky666 @Asgothian last edited by
        @asgothian
        Node ist 12.19.0
        iobroker@1.0.0 /opt/iobroker
        └─┬ iobroker.zigbee@0.10.3
          └─┬ zigbee-shepherd@0.3.0
            └─┬ zcl-packet@0.2.4
              └─┬ dissolve-chunks@1.3.0
                └── dissolve@0.3.3
        • Asgothian
          @chucky666
          versuch mal bitte ein npm remove dissolve
          danach ein npm remove zigbee-shepherd
          • chucky666
            @asgothian
            Beides gemacht , er hat auch jedemenge entfernt .
            Aber der zigbee Adapter lässt sich immer noch nicht entfernen
            Delete adapter "zigbee"
            host.iobroker Counted 1 instances of zigbee
            host.iobroker Counted 1 meta of zigbee
            host.iobroker Counted 1 adapter for zigbee
            host.iobroker Counted 1 channels of zigbee
            host.iobroker Counted 5 states of zigbee
            host.iobroker Counted 13 states of system.adapter.zigbee
            host.iobroker Counted 5 states (io.zigbee.*) from states
            host.iobroker Counted 3 states (system.adapter.zigbee.*) from states
            host.iobroker file zigbee.admin deleted
            host.iobroker object zigbee.admin deletedhost.iobroker Deleting 22 object(s).
            host.iobroker Deleting 8 state(s).
            npm uninstall iobroker.zigbee --error --prefix "/opt/iobroker" (System call)
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/package.json'
            npm ERR! code ENOTSUP
            npm
            ERR! notsup Unsupported engine for dissolve@0.3.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.19.0","npm":"6.14.8"})
            npm
            ERR! notsup Not compatible with your version of node/npm: dissolve@0.3.3npm
            ERR!
             notsup Not compatible with your version of node/npm: dissolve@0.3.3npm ERR!
            notsup
             Required: {"node":"~0.10.0"}npm ERR!
             notsup
             Actual:   {"npm":"6.14.8","node":"12.19.0"}
            npm
             ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-01-21T14_34_49_269Z-debug.log
            ERROR: Error deleting adapter zigbee from disk: Error: host.iobroker: Cannot uninstall iobroker.zigbee: 1
            ERROR: You might have to delete it yourself!
            process exited with code 0
            • Asgothian
              @chucky666 hast du sicher gestellt das er auch beide Bibliotheken entfernt hat (npm list zigbee-sherpherd und npm list dissolve) ?
              Ansonten ganz rabiat npm remove iobroker.zigbee.
              A.
              chucky666 2 Replies Last reply Reply Quote 0
              • chucky666
                @asgothian ja er hat bei beiden etwas entfernt .
                Wenn ich den anderen Befehl mache , funktioniert mein Conbee Stick mit dem denoz Adapter noch ?
                • chucky666
                  @asgothian ich war mutig , aber hat glaube ich nichts gebracht
                  npm ERR! notsup Unsupported engine for dissolve@0.3.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.19.0","npm":"6.14.8"})
                  npm ERR! notsup Not compatible with your version of node/npm: dissolve@0.3.3
                  npm ERR! notsup Required: {"node":"~0.10.0"}
                  npm ERR! notsup Actual:   {"npm":"6.14.8","node":"12.19.0"}
                  UncleSam 1 Reply Last reply Reply Quote 0
                  • UncleSam
                    UncleSam Developer @chucky666 last edited by
                    @chucky666 Irgendetwas wurde wohl nicht entfernt. Was gibt ein erneutes npm list dissolve?
                    Bevor du irgendetwas an den NPM Paketen (von zigbee) rumschraubst, bitte zumindest den Adapter beenden - besser den Adapter nochmals löschen (wie du es ja schon mal gemacht hast).
                    • chucky666
                      chucky666 @UncleSam last edited by
                      @unclesam sagte in Upgrade zigbee immer error:
                      npm list dissolve
                              └── dissolve@0.3.3
                      • UncleSam
                        UncleSam Developer @chucky666 last edited by UncleSam
                        @chucky666 Also nochmals von vorne:
                        • Instanz und Adapter aus ioBroker löschen
                        • npm remove dissolve
                        • npm remove zigbee-shepherd
                        • npm remove iobroker.zigbee
                        • Dann schauen, was noch da ist: npm list dissolve
                        Und bitte den kompletten Output (mit Kommando-Prompt) hier posten.
                        • chucky666
                          npm list dissolve
                          Danke erstmal für eure Hilfe
                          Linux iobroker 4.9.0-8-amd64 #1 SMP Debian 4.9.110-3+deb9u6 (2018-10-08) x86_64
                          The programs included with the Debian GNU/Linux system are free software;
                          the exact distribution terms for each program are described in the
                          individual files in /usr/share/doc/*/copyright.
                          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                          permitted by applicable law.
                          Last login: Thu Jan 21 16:09:00 2021 from 192.168.178.112
                          root@iobroker:~# cd /opt/iobroker
                          root@iobroker:/opt/iobroker# npm remove dissolve
                          > serialport@6.2.2 install /opt/iobroker/node_modules/cc-znp/node_modules/serialport
                          > prebuild-install || node-gyp rebuild
                          prebuild-install WARN install No prebuilt binaries found (target=12.19.0 runtime=node arch=x64 platform=linux)
                          make: Verzeichnis „/opt/iobroker/node_modules/cc-znp/node_modules/serialport/build“ wird betreten
                            CXX(target) Release/obj.target/serialport/src/serialport.o
                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’
                             v8::String::Utf8Value path(info[0]->ToString());
                          In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67:0,
                                           from ../../../../nan/nan.h:54,
                                           from ../src/./serialport.h:6,
                                           from ../src/serialport.cpp:1:
                          /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2668:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
                             V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
                          /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 provided
                          In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8-internal.h:14:0,
                                           from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:27,
                                           from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,
                          /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2684:31: note: candidate: v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const
                                           Local<String> ToString(Isolate* isolate) const);
                          /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
                             declarator __attribute__((deprecated(message)))
                          /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided
                          ../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’
                             v8::Local<v8::Object> options = info[1]->ToObject();
                          /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2672:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const
                             V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
                          /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 provided
                          /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2686:31: note: candidate: v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const
                                           Local<Object> ToObject(Isolate* isolate) const);
                          /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided
                          ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
                          ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                             data->callback.Call(2, argv);
                          In file included from ../src/./serialport.h:6:0,
                          ../../../../nan/nan.h:1740:3: note: declared here
                             Call(int argc, v8::Local<v8::Value> argv[]) const {
                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’
                          ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
                          ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                             data->callback.Call(1, argv);
                          ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
                          ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                          ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
                          ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’
                          ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
                          ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                          ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
                          ../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                               results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
                          /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:3499:22: note: declared here
                                           bool Set(Local<Value> key, Local<Value> value));
                          ../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                               results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
                          ../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                               results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
                          ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                          ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
                          ../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                               results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
                          ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                          ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
                          ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                          ../src/serialport.cpp: At global scope:
                          ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
                             void init(v8::Handle<v8::Object> target) {
                          ../src/serialport.cpp:460:13: error: ‘Handle’ is not a member of ‘v8’
                          ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
                          ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
                          In file included from ../../../../nan/nan.h:54:0,
                          ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
                           NODE_MODULE(serialport, init);
                          /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:727:36: note: in definition of macro ‘NODE_MODULE_X’
                                 (node::addon_register_func) (regfunc),                          \
                          ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
                          serialport.target.mk:114: die Regel für Ziel „Release/obj.target/serialport/src/serialport.o“ scheiterte
                          make: *** [Release/obj.target/serialport/src/serialport.o] Fehler 1
                          make: Verzeichnis „/opt/iobroker/node_modules/cc-znp/node_modules/serialport/build“ wird verlassen
                          gyp ERR! build error
                          gyp ERR! stack Error: `make` failed with exit code: 2
                          gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                          gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
                          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                          gyp ERR! System Linux 4.9.0-8-amd64
                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                          gyp ERR! cwd /opt/iobroker/node_modules/cc-znp/node_modules/serialport
                          gyp ERR! node -v v12.19.0
                          gyp ERR! node-gyp -v v5.1.0
                          gyp ERR! not ok
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 (node_modules/cc-znp/node_modules/serialport):
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                          added 20 packages from 15 contributors in 24.688s
                          105 packages are looking for funding
                            run `npm fund` for details
                          root@iobroker:/opt/iobroker# npm remove zigbee-shepherd
                          npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
                          removed 20 packages in 19.565s
                          root@iobroker:/opt/iobroker# npm remove iobroker.zigbee
                          npm ERR!     /home/iobroker/.npm/_logs/2021-01-21T15_28_09_865Z-debug.log
                          root@iobroker:/opt/iobroker# npm list dissolve
                                  └── dissolve@0.3.3
                          UncleSam Thomas Braun 2 Replies Last reply Reply Quote 0
                          • UncleSam
                            UncleSam Developer last edited by
                            @Asgothian Bin ich doof oder was? Man sagt dem, er solle es löschen und er will es gleich wieder installieren. Könnte das noch ein Rechte-Problem im node_modules Ordner sein?
                            • Asgothian
                              Asgothian Developer @UncleSam last edited by
                              @unclesam
                              Denkbar.. sicher bin ich nicht
                              • UncleSam
                                @chucky666 Mit dem Risiko, einen riesigen Output zu generieren, kannst du mal ls -la /opt/iobroker/node_modules machen?
                                  Thomas Braun Most Active @chucky666 last edited by
                                  @chucky666 sagte in Upgrade zigbee immer error
                                  root@iobroker
                                  sollte man ja auch vermeiden. Kompilieren als root ist halt ein No-Go.
                                  • UncleSam
                                    UncleSam Developer @Thomas Braun last edited by
                                    @thomas-braun Einverstanden, aber weshalb will der bei einem npm remove etwas kompilieren... ich hätte erwartet, dass der nur entfernt und nichts hinzufügt.
                                      Thomas Braun Most Active @UncleSam last edited by
                                      @unclesam @chucky666
                                      npm greift immer 'liegengebliebene' Dinge auf, bis es erfolgreich erledigt wurde. Offenbar hängt da das serialport-Modul quer und wird immer wieder angefasst.
                                      Ich würde vielleicht mal den groben Besen versuchen:
                                      npm cache clean --force
                                      Natürlich als einfacher user, nicht als root.
                                      • chucky666
                                        chucky666 @Thomas Braun last edited by
                                        @thomas-braun sagte in Upgrade zigbee immer error:
                                        I sure hope you know what you are doing.
                                        Das spuckt er dann aus
                                        • chucky666
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:26 bignumber.js
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jan 21 15:23 .bin
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 binary-extensions
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 bindings
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 bl
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jun 17  2020 blob
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Feb 16  2019 block-stream
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 bluebird
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 bluetooth-hci-socket
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Nov 22  2019 body-parser
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 bonjour-hap
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 boolbase
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 bower
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 boxen
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 bplist-parser
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 brace-expansion
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 braces
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:17 browser-process-hrtime
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jan  9  2020 browser-serialport
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 buffer
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-alloc
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-alloc-unsafe
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Apr 27  2019 buffer-equal
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-equal-constant-time
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-fill
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 buffer-from
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 bufferhelper
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep 14  2018 buffer-shims
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Feb 16  2019 builtins
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 busboy
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 bytes
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:22 bytesish
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 cacheable-lookup
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 cacheable-request
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jun 24  2019 cache-base
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 callback-stream
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 call-bind
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 callsite
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 callsites
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 camelcase
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 camelcase-keys
                                          drwxrwxrwx+    8 iobroker iobroker  4096 Okt 27 13:17 canvas
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 capitalize
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 caseless
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Jan 21 15:23 cc-znp
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 cert-info
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Apr  7  2019 chai
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jun 24  2019 chalk
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 chardet
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 charenc
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 check-error
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:45 cheerio
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Apr 27  2019 chip.avr.avr109
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 chokidar
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 chownr
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 ci-info
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 class-utils
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 clean-stack
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 cli
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 cli-boxes
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 cli-cursor
                                          drwxrwxrwx+    7 iobroker iobroker  4096 Aug 31  2018 cliff
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 cli-truncate
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 cliui
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 cli-width
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 cloneextend
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 clone-response
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 cluster-key-slot
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 co
                                          drwxrwxr-x+    6 iobroker iobroker  4096 Okt 27 12:44 coap
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 coap-packet
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jan 28  2020 code-point-at
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 coffee-compiler
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 coffee-script
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 collection-visit
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 color
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 color-convert
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 color-name
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Dez  5  2019 colors
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 colorspace
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 color-string
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 color-support
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 combined-stream
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jan  9  2020 commander
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 commist
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 component-bind
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jun 17  2020 component-emitter
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 component-inherit
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 concat-map
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jun 30  2020 concat-stream
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 concentrate
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 configstore
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 connect-flash
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 console-control-strings
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 content-disposition
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 content-type
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 cookie
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:01 cookie-parser
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 cookie-signature
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 copy-descriptor
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 copy-props
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 copy-to
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 core-util-is
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 cosmiconfig
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Feb 16  2019 create-react-app
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:44 cron
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 cron-parser
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 cross-spawn
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 crypt
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez 11  2018 crypto-js
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 crypto-random-string
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 cssom
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:45 css-select
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 cssstyle
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 css-what
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Jul 20  2019 curve25519-n
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 cycle
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 d
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 @dabh
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 daemonize2
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 dashdash
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 data-uri-to-buffer
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 data-urls
                                          drwxrwxrwx+  158 iobroker iobroker  4096 Dez 12  2018 date-fns
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 dateformat
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 debounce
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 debug
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 decache
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 decamelize
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 decamelize-keys
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jan 15 04:52 decimal.js
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 decode-uri-component
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 decompress-response
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 deep-clone
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 deep-eql
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 deep-equal
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 deep-extend
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jun  6  2019 deep-is
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 default-compare
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 default-user-agent
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 defer-to-connect
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 define-properties
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 define-property
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 degenerator
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 del
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 delayed-stream
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 delegates
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 denque
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 depd
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 destroy
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 detect-file
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 detect-libc
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Sep 14  2018 dev-null
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 dgram
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 dicer
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 digest-header
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 dir-glob
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Dez  5  2019 diskusage
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 dissolve
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 dissolve-chunks
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 dns-packet
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 domelementtype
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 domexception
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:45 domhandler
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 dom-serializer
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:45 domutils
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2018 dotenv
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 dot-prop
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Okt 11  2018 dropbox-v2-api
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 duplexer
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Feb 16  2019 duplexer2
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 duplexer3
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 duplexify
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 each-props
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 ecc-jsbn
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 ecdsa-sig-formatter
                                          drwxrwxrwx+   13 iobroker iobroker  4096 Okt 27 13:17 echarts
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Jul 20  2019 eckles
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Sep 14  2018 ed25519-hap
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 ee-first
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 elegant-spinner
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jan 28  2020 emoji-regex
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 enabled
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 encodeurl
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 end-of-stream
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jun 17  2020 engine.io
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jun 17  2020 engine.io-client
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jun 17  2020 engine.io-parser
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:45 entities
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Feb 16  2019 envinfo
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 error-ex
                                          drwxrwxr-x+   17 iobroker iobroker  4096 Okt 27 12:44 es5-ext
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 es6-iterator
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:44 es6-map
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Sep 24  2019 es6-promise
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 es6-promisify
                                          drwxrwxr-x+    7 iobroker iobroker  4096 Okt 27 12:44 es6-set
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:44 es6-symbol
                                          drwxrwxr-x+   13 iobroker iobroker  4096 Jul  1  2020 es-abstract
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 escape-goat
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 escape-html
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 escape-string-regexp
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 escodegen
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 es-get-iterator
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 esprima
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 es-to-primitive
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 estraverse
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 esutils
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 etag
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 event-emitter
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jun 24  2019 eventemitter3
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 event-stream
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 event-target-shim
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 execa
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 expand-brackets
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 expand-template
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 expand-tilde
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Nov 22  2019 express
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 express-fileupload
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:01 express-session
                                          drwxrwxr-x+   13 iobroker iobroker  4096 Okt 27 12:44 ext
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 extend
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 extend-shallow
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 external-editor
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 extglob
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 extract-zip
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 extsprintf
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 eyes
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 fancy-log
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fast-deep-equal
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Dez  8 11:27 fast-glob
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 fast-json-stable-stringify
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 fast-levenshtein
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Dez  8 11:27 fastq
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 fast-safe-stringify
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 fastseries
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 fast-srp-hap
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 fast-text-encoding
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 fd-slicer
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 fecha
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 figures
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jan 28  2020 file-stream-rotator
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 file-type
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 file-uri-to-path
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 fill-range
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 finalhandler
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 find-up
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 findup-sync
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 fined
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 flagged-respawn
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 fn.name
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 follow-redirects
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jan 15 04:52 foreach
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 forever-agent
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 for-in
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 form-data
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 formstream
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 for-own
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 forwarded
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fragment-cache
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Mai 29  2019 @frankjoke
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fresh
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 from
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fs-constants
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 fs-extra
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jan 28  2020 fs-minipass
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 fs.realpath
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Feb 16  2019 fstream
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Feb 16  2019 fstream-ignore
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Okt 11  2018 ftp
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 function-bind
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jan 15 04:52 futoin-hkdf
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 gauge
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 gaxios
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:26 gcp-metadata
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 get-caller-file
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 get-func-name
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 get-intrinsic
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 getpass
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 get-stream
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 get-uri
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 get-value
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 github-from-package
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 github-url-from-git
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 glob
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 global-dirs
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 global-modules
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 global-prefix
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 globby
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 glob-parent
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 glob-stream
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 glogg
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 glossy
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 googleapis
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Sep 24  2019 googleapis-common
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Sep 24  2019 google-auth-library
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:26 google-p12-pem
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 got
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 graceful-fs
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 greenlock
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 greenlock-store-fs
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Sep 24  2019 gtoken
                                          drwxrwxr-x+    6 iobroker iobroker  4096 Okt 27 12:44 gulp-cli
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 gulplog
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 hap-nodejs
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 hard-rejection
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Apr 30  2020 @harmonyhub
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Apr 30  2020 harmonyhubws
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 har-schema
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 har-validator
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 has
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 has-ansi
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jun 17  2020 has-binary2
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 has-cors
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 has-flag
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 hasha
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Mai 30  2019 has-symbols
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 has-unicode
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 has-value
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 has-values
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 has-yarn
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Apr 12  2020 help-me
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez 12  2018 hoek
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jan 15 04:52 @homebridge
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 homedir-polyfill
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 hosted-git-info
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 html-encoding-sniffer
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:45 htmlparser2
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 http-cache-semantics
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 http-errors
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Dez  7 10:35 http-proxy
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 http-proxy-middleware
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 http-proxy-response-rewrite
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 https
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 http-signature
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 https-proxy-agent
                                          drwxrwxr-x+    8 iobroker iobroker  4096 Mai  9  2020 hue-emu
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 humanize-ms
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 human-signals
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Feb 16  2019 hyperquest
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 i
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Nov 22  2019 iconv-lite
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 ieee754
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 ignore
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez 12 09:04 ignore-walk
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 immediate
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 import-fresh
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 import-lazy
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  8 11:27 import-local
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 imurmurhash
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 indent-string
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 indexof
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 inflight
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 inherits
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 ini
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 inquirer
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 inquirer-autosubmit-prompt
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 intel-hex
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 interpret
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 invert-kv
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:04 @iobroker
                                          drwxrwxr-x+    8 iobroker iobroker  4096 Okt 27 13:01 iobroker.admin
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Jan 17 14:40 iobroker.alexa2
                                          drwxrwxrwx+    7 iobroker iobroker  4096 Dez  7 11:47 iobroker.backitup
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.broadlink
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 iobroker.broadlink2
                                          drwxrwxrwx+    7 iobroker iobroker  4096 Dez 12 09:05 iobroker.cloud
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:22 iobroker.daswetter
                                          drwxrwxrwx+    7 iobroker iobroker  4096 Okt 27 13:13 iobroker.deconz
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 iobroker.discovery
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Jan 12 13:14 iobroker.dwd
                                          drwxrwxr-x+    6 iobroker iobroker  4096 Jul 24 10:11 iobroker.fb-checkpresence
                                          drwxrwxrwx+    9 iobroker iobroker  4096 Jan 15 04:53 iobroker.flot
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:19 iobroker.fullybrowser
                                          drwxrwxr-x+    8 iobroker iobroker  4096 Okt 27 12:44 iobroker.fully-tablet-control
                                          drwxrwxr-x+    8 iobroker iobroker  4096 Mai  1  2020 iobroker.habpanel
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Apr 30  2020 iobroker.harmony
                                          drwxrwxrwx+    8 iobroker iobroker  4096 Okt 27 13:25 iobroker.history
                                          drwxrwxr-x+    8 iobroker iobroker  4096 Mai  9  2020 iobroker.hueemu
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:16 iobroker.ical
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.icons-icons8
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 iobroker.icons-mfd-png
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 iobroker.icons-mfd-svg
                                          drwxrwxr-x+    7 iobroker iobroker  4096 Jun 28  2020 iobroker.info
                                          drwxrwxrwx+    8 iobroker iobroker  4096 Dez 12 09:05 iobroker.iot
                                          drwxrwxrwx+    7 iobroker iobroker  4096 Okt 27 13:21 iobroker.javascript
                                          drwxrwxr-x+    7 iobroker iobroker  4096 Okt 29 04:00 iobroker.js-controller
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Apr  7  2019 iobroker.milight
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Jun  6  2019 iobroker.milight-smart-light
                                          drwxrwxrwx+    7 iobroker iobroker  4096 Okt 27 13:27 iobroker.mobile
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 iobroker.objects-redis
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Aug 17 16:22 iobroker.onvif
                                          drwxrwxr-x+    6 iobroker iobroker  4096 Jul  1  2020 iobroker.openligadb
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Sep  7  2018 iobroker.phantomjs
                                          drwxrwxr-x+    6 iobroker iobroker  4096 Jul 27 14:35 iobroker.pi-hole
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.radar
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Jul  1  2020 iobroker.radar2
                                          drwxrwxr-x+    6 iobroker iobroker  4096 Mär 19  2020 iobroker.rflink
                                          drwxrwxrwx+    8 iobroker iobroker  4096 Okt 27 13:19 iobroker.shelly
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Okt 27 13:20 iobroker.simple-api
                                          drwxrwxr-x+    7 iobroker iobroker  4096 Okt 27 12:45 iobroker.smartcontrol
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Aug 19 13:54 iobroker.smartgarden
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:10 iobroker.socketio
                                          drwxrwxr-x+    6 iobroker iobroker  4096 Apr 12  2020 iobroker.sonoff
                                          drwxrwxr-x+    7 iobroker iobroker  4096 Jul  1  2020 iobroker.telegram
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Dez  9 10:37 iobroker.text2command
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Nov 24 16:16 iobroker.tr-064
                                          drwxrwxrwx+    8 iobroker iobroker  4096 Dez 27 10:44 iobroker.trashschedule
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez 11  2018 iobroker.type-detector
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Apr 15  2019 iobroker.viessmannapi
                                          drwxrwxrwx+    8 iobroker iobroker  4096 Okt 27 13:11 iobroker.vis
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-bars
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-canvas-gauges
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Dez  8 11:25 iobroker.vis-colorpicker
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-fancyswitch
                                          drwxrwxrwx+    7 iobroker iobroker  4096 Okt 18  2019 iobroker.vis-history
                                          drwxrwxrwx+    7 iobroker iobroker  4096 Dez  7 11:29 iobroker.vis-hqwidgets
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Okt 27 13:23 iobroker.vis-icontwo
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Dez  8 11:27 iobroker.vis-inventwo
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-jqui-mfd
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Nov 22  2019 iobroker.vis-justgage
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-metro
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Dez  8 17:19 iobroker.vis-players
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 iobroker.vis-timeandweather
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jan  9  2020 iobroker.vis-weather
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:13 iobroker.web
                                          drwxrwxr-x+    8 iobroker iobroker  4096 Jul  1  2020 iobroker.xs1
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 iobroker.yahka
                                          drwxrwxrwx+    9 iobroker iobroker  4096 Nov 25  2019 iobroker.zigbee
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 ioredis
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 ip
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 ipaddr.js
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jun  6  2019 ip-regex
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 is
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jun  6  2019 is2
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-absolute
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-accessor-descriptor
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-arguments
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 isarray
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 is-arrayish
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-bigint
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 is-binary-path
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-boolean-object
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2019 is-buffer
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 is-callable
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-ci
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-data-descriptor
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 is-date-object
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-descriptor
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-docker
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Dez 12  2018 isemail
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 isexe
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-extendable
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-extglob
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 is-fullwidth-code-point
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-generator-function
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jun 24  2019 is-glob
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 is-installed-globally
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-map
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-nan
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-negated-glob
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-negative-zero
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-npm
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 is-number
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-number-object
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-obj
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 isobject
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-observable
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-path-cwd
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-path-in-cwd
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-path-inside
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-plain-obj
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-plain-object
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:17 is-potential-custom-element-name
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-promise
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 is-regex
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-relative
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-scoped
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-set
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 isstream
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-stream
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-string
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 issue-regex
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 is-symbol
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 is-typedarray
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Jan 15 04:52 is-typed-array
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-unc-path
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jun  6  2019 is-url
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 is-url-superb
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 is-utf8
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Apr 27  2019 isval
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-weakmap
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 is-weakset
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 is-windows
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 is-wsl
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 is-yarn-global
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez 12  2018 joi
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jun 15  2020 @jpgorganizer
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 jsbn
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 jsdom
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:21 jsonata
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:26 json-bigint
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 json-buffer
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 jsonfile
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 json-parse-better-errors
                                          drwxrwxrwx+    9 iobroker iobroker  4096 Aug 31  2018 json-schema
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 json-schema-traverse
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 10  2019 json-stable-stringify-without-jsonify
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 json-stringify-safe
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 jsonwebtoken
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 jsprim
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 js-tokens
                                          drwxrwxr-x+    6 iobroker iobroker  4096 Okt 27 13:04 jszip
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 jwa
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 jws
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 kew
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 keypairs
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 keyv
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 kind-of
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 klaw
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 kuler
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 latest-version
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 lcid
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Jul 20  2019 le-acme-core
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 le-challenge-fs
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 le-sni-auto
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 le-store-certbot
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 leven
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 levn
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 lie
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 liftoff
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 lines-and-columns
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 listr
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 listr-input
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 listr-silent-renderer
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 listr-update-renderer
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 listr-verbose-renderer
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 loadavg-windows
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 load-json-file
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 locate-path
                                          drwxrwxrwx+    3 iobroker iobroker 20480 Aug 31  2018 lodash
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 lodash.defaults
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 lodash.flatten
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 lodash.get
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.includes
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isboolean
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isinteger
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isnumber
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isplainobject
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.isstring
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 lodash.once
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:17 lodash.sortby
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 lodash.zip
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 logform
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Okt 27 13:19 loglevel
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 log-symbols
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 log-update
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 long-timeout
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 lowercase-keys
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jan  9  2020 lru-cache
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jan  9  2020 lru_map
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Mär  2  2019 luxon
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 macaddress
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 make-dir
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 make-iterator
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 map-age-cleaner
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 map-cache
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 map-obj
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 map-stream
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 map-visit
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 12:44 matchdep
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 md5
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 mdns-discovery
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 media-typer
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 mem
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 meow
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 merge2
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 merge-descriptors
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 merge-stream
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 methods
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 micromatch
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:26 mime
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 mime-db
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 mime-types
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 mimic-fn
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 mimic-response
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 minimatch
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 minimist
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 minimist-options
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 min-indent
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 minipass
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 minizlib
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 mixin-deep
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 mkdirp
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 mkdirp-classic
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Jul 20  2019 moment
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 moment-timezone
                                          drwxrwxrwx+   10 iobroker iobroker  4096 Dez 11  2018 mqtt
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Apr 12  2020 mqtt-connection
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Apr 12  2020 mqtt-packet
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 ms
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jan 15 04:52 multicast-dns
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep 14  2018 multicast-dns-service-types
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 mute-stdout
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 mute-stream
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 mz
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 nan
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 nanomatch
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 napi-build-utils
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Mai 29  2019 napi-thread-safe-callback
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 ncp
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jun 24  2019 nearest-color
                                          drwxrwxrwx+    8 iobroker iobroker  4096 Dez 12 09:04 needle
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Aug 31  2018 netmask
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Mai 29  2019 net-ping
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 new-github-release-url
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 next-tick
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 nimble
                                          drwxrwxrwx+    7 iobroker iobroker  4096 Aug 31  2018 noble
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Mär 19  2020 node-abi
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Mai 29  2019 node-addon-api
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Mai 29  2019 node-arp
                                          drwxrwxrwx+    7 iobroker iobroker  4096 Mai 30  2019 node-bluetooth
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 node.extend
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:26 node-fetch
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Dez  5  2019 node-forge
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Mär  2  2019 node-ical
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Dez  8 11:27 @nodelib
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Jun  6  2019 node-milight-promise
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 node-mndp
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Sep 14  2018 node-persist
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Dez  5  2019 node-pre-gyp
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 12:44 node-rest-client
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 node-schedule
                                          drwxrwxr-x+    9 iobroker iobroker  4096 Jul  1  2020 node-ssdp
                                          drwxrwxrwx+    7 iobroker iobroker  4096 Aug 31  2018 node-telegram-bot-api
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Feb 11  2019 node-wol
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 noop-logger
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Dez 12 09:04 nopt
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 normalize-package-data
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 normalize-path
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 normalize-url
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Dez  8 11:27 np
                                          drwxrwxr-x+    9 iobroker iobroker  4096 Jan  9  2020 npm
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez 12 09:04 npm-bundled
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 npmlog
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 npm-name
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Dez 12 09:04 npm-normalize-package-bin
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez 12 09:04 npm-packlist
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 npm-run-path
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:45 nth-check
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jan 28  2020 number-is-nan
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 nwsapi
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 oauth-sign
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 object-assign
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jan  9  2020 object.assign
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 object-component
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 object-copy
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 object.defaults
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 object-hash
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 object-inspect
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 object-is
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Mai 30  2019 object-keys
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 object.map
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 object.pick
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 object-visit
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 once
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 onetime
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 13:04 one-time
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 on-finished
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 on-headers
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 onvif
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 open
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 optionator
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 ordered-read-streams
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 org-regex
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 osenv
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 os-homedir
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 os-locale
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 os-name
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 os-tmpdir
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 osx-release
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 ow
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 package-json
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 pac-proxy-agent
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 pac-resolver
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 pako
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 parent-module
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:45 parse5
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 parse-filepath
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 parse-json
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 parse-node-version
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 parse-passwd
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 parseqs
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 parseuri
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 parseurl
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 pascalcase
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:01 passport
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 passport-local
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 passport.socketio
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 passport-strategy
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 path-dirname
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 path-exists
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 path-is-absolute
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 path-is-inside
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 path-key
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 path-parse
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 path-root
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 path-root-regex
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 path-to-regexp
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 path-type
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 pathval
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 pause
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 pause-stream
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 p-cancelable
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-defer
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 pend
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 performance-now
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 p-event
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-finally
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Sep  6  2018 phantomjs-prebuilt
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 picomatch
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 pidusage
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 pify
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 ping
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 pinkie
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 pinkie-promise
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-is-promise
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 pkg-dir
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 pkginfo
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-limit
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-locate
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-map
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-memoize
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 posix-character-classes
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mär 19  2020 prebuild-install
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 prelude-ls
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 prepend-http
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 pretty-hrtime
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jun 24  2019 process-nextick-args
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 progress
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 promise-object
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 promise-retryer
                                          drwxrwxrwx+    7 iobroker iobroker  4096 Aug 31  2018 prompt
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 proxy-addr
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 proxy-agent
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 proxy-from-env
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 psl
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-timeout
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 p-try
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 pump
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 pumpify
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 punycode
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 pupa
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 pyconf
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 q
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 qs
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 querystring
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 quick-lru
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 random-bytes
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 range-parser
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Jul 20  2019 rasha
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 raw-body
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Mai 29  2019 raw-socket
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 rc
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 read
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jul 20  2019 readable-stream
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 readdirp
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 readline-sync
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 read-pkg
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 read-pkg-up
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 rechoir
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 redent
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 redis-commands
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 redis-errors
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 redis-parser
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 regex-not
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 regexp.prototype.flags
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 registry-auth-token
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 registry-url
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 reinterval
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 remove-trailing-separator
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 repeat-element
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 repeat-string
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 replace-homedir
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 request
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep  6  2018 request-progress
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 request-promise
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 request-promise-core
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez 12  2018 request-promise-native
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 require-directory
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 require-main-filename
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 requires-port
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Mai  1  2020 resolve
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  8 11:27 resolve-cwd
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 resolve-dir
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 resolve-from
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 resolve-url
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 respjs
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 responselike
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 restore-cursor
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 ret
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  8 11:27 reusify
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 revalidator
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 rimraf
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Mai  1  2020 @root
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Mär  2  2019 rrule
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Jul 20  2019 rsa-compat
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 run-async
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 run-parallel
                                          drwxrwxr-x+   20 iobroker iobroker  4096 Mai  1  2020 rxjs
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 safe-buffer
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 safer-buffer
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 safe-regex
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 safe-replace
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 @samverschueren
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 sax
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Okt 27 13:17 saxes
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 scoped-regex
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Mai  9  2020 selfsigned
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Apr 30  2020 semaphore
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 semver
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 semver-diff
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 semver-greatest-satisfied-range
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 send
                                          drwxrwxr-x+   11 iobroker iobroker  4096 Dez  7 10:35 @sentry
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Mär 19  2020 serialport
                                          drwxrwxr-x+   12 iobroker iobroker  4096 Mär 19  2020 @serialport
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 serve-static
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 set-blocking
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jul 20  2019 set-immediate-shim
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 setprototypeof
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 set-value
                                          drwxrwxr-x+    8 iobroker iobroker  4096 Aug  8 03:31 sharp
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 shebang-command
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 shebang-regex
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 12:44 shelly-iot
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 side-channel
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 signal-exit
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 simple-concat
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mär 19  2020 simple-get
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Dez 12  2018 simple-oauth2
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 simple-swizzle
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 @sindresorhus
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 slash
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 slice-ansi
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 smart-buffer
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 snapdragon
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 snapdragon-node
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 snapdragon-util
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jun 17  2020 socket.io
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jun 17  2020 socket.io-adapter
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Jun 17  2020 socket.io-client
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jun 17  2020 socket.io-parser
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Aug  8 03:31 socks
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 socks-proxy-agent
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Mai 30  2019 socksv5
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 sorted-array-functions
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 source-map
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 source-map-resolve
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 source-map-support
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 source-map-url
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 sparkles
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 spdx-correct
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 spdx-exceptions
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 spdx-expression-parse
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 spdx-license-ids
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Dez  5  2019 split
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 split2
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 split-string
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 sshpk
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 stack-trace
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 standard-as-callback
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 static-extend
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 statuses
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 stealthy-require
                                          drwxrwxr-x+    7 iobroker iobroker  4096 Jan  9  2020 stk500
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Mär 19  2020 stk500-v2
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 stream-combiner
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 streamifier
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 streamsearch
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 stream-shift
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 string_decoder
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 string.prototype.trimend
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 string.prototype.trimstart
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jan 28  2020 string-width
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jan 28  2020 strip-ansi
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 strip-bom
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 strip-final-newline
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 strip-indent
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 strip-json-comments
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 suncalc2
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep 24  2018 supports-color
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 supports-hyperlinks
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 sver-compat
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 symbol-observable
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 symbol-tree
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep 24  2019 systeminformation
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 @szmarczak
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Okt 27 13:04 tar
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 tar-fs
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 11  2018 targz
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Feb 16  2019 tar-pack
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Apr 11  2020 tar-stream
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 tcp-ping
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jun  6  2019 tcp-port-used
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 terminal-link
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 term-size
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 text-hex
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 thenify
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 thenify-all
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 throttleit
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 through
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 through2
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 through2-filter
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 thunkify
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jan 15 04:52 thunky
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 time-stamp
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Feb 16  2019 tmp
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 to-absolute-glob
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 to-array
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 to-buffer
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jun 24  2019 toidentifier
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 to-object-path
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez 12  2018 topo
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jul  1  2020 to-readable-stream
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 to-regex
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 to-regex-range
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 tough-cookie
                                          drwxr-xr-x+    4 iobroker iobroker  4096 Okt 27 13:17 tr46
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Jun  6  2019 tree-kill
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 trim-newlines
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez  5  2019 triple-beam
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 tr-O64
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jan  9  2020 tslib
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 tunnel-agent
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 tweetnacl
                                          drwxrwxr-x+   26 iobroker iobroker  4096 Okt 27 12:44 type
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 type-check
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 typedarray
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 typedarray-to-buffer
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 type-detect
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 type-fest
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Nov 22  2019 type-is
                                          drwxrwxrwx+   26 iobroker iobroker  4096 Jan 17 14:40 @types
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Apr  7  2019 typescript
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Dez 22  2018 typescript-optional
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Feb 16  2019 uid-number
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 uid-safe
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 unc-path-regex
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Okt 27 13:19 underscore
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 unescape
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 union-value
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Apr 12  2020 unique-stream
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 unique-string
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 universalify
                                          drwxrwxr-x+    6 iobroker iobroker  4096 Jan 28  2020 unix-dgram
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 unpi
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 unpipe
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 unset-value
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 update-notifier
                                          drwxrwxr-x+    6 iobroker iobroker  4096 Mär 19  2020 uri-js
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 urix
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Aug  8 03:31 urllib
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 url-parse-lax
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Sep 24  2019 url-template
                                          drwxrwxrwx+    6 iobroker iobroker  4096 Jul 20  2019 ursa-optional
                                          drwxrwxrwx+    8 iobroker iobroker  4096 Aug 31  2018 usb
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 use
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Sep 14  2018 util
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 util-deprecate
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Aug 31  2018 utile
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 utility
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 utils-merge
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Aug 31  2018 uuid
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Okt 27 12:44 v8flags
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 validate-npm-package-license
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Feb 16  2019 validate-npm-package-name
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 vary
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 verror
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Dez 12  2018 viessmann-api-client
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 vinyl-sourcemaps-apply
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jun 24  2019 virtual-device-sdk
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:21 virtual-tsc
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Apr  7  2019 vm2
                                          drwxr-xr-x+    3 iobroker iobroker  4096 Okt 27 13:17 w3c-hr-time
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 w3c-xmlserializer
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Apr  7  2019 wake_on_lan
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Jul 20  2019 weak-daemon
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 webidl-conversions
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Apr 12  2020 websocket-stream
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 whatwg-encoding
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 whatwg-mimetype
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 whatwg-url
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Aug 31  2018 which
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 which-boxed-primitive
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 15 04:52 which-collection
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 which-module
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 which-pm-runs
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Jan 15 04:52 which-typed-array
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Mär 19  2020 wide-align
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 widest-line
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Aug  8 03:31 win-release
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 winston
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Okt 27 13:04 winston-daily-rotate-file
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Mai  1  2020 winston-syslog
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 winston-transport
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Aug  8 03:31 word-wrap
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 wrap-ansi
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 wrappy
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 write-file-atomic
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Apr 12  2020 ws
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 xdg-basedir
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Jul  1  2020 xml2js
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Jun 14  2020 xml2json-light
                                          drwxrwxr-x+    4 iobroker iobroker  4096 Jul  1  2020 xmlbuilder
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Okt 27 13:17 xmlchars
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Jun 17  2020 xmlhttprequest-ssl
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 27 13:17 xml-name-validator
                                          drwxrwxrwx+    3 iobroker iobroker  4096 Okt 11  2018 xregexp
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Nov 22  2019 xtend
                                          drwxrwxr-x+    2 iobroker iobroker  4096 Mai  1  2020 y18n
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  5  2019 yallist
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Jul  1  2020 yaml
                                          drwxrwxr-x+    5 iobroker iobroker  4096 Okt 27 13:04 yargs
                                          drwxrwxr-x+    3 iobroker iobroker  4096 Mai  1  2020 yargs-parser
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Sep  6  2018 yauzl
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Aug 31  2018 yeast
                                          drwxrwxrwx+    2 iobroker iobroker  4096 Dez  8 11:27 yocto-queue
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 21 15:19 zcl-packet
                                          drwxrwxrwx+    4 iobroker iobroker  4096 Jan 22 06:27 zigbee-shepherd
                                          drwxrwxrwx+    5 iobroker iobroker  4096 Dez 10  2018 zigbee-shepherd-converters
                                          drwxrwxrwx+    7 iobroker iobroker  4096 Okt 27 13:17 zrender
                                          jens@iobroker:/root$
                                          • UncleSam
                                            UncleSam Developer last edited by
                                            Wenn in den nächsten Stunden nicht noch jemand mit einer guten Lösung kommt, würde ich vorschlagen: Backup machen, ioBroker Verzeichnis löschen, ioBroker neu installieren und Backup restoren
                                            chucky666 2 Replies Last reply Reply Quote 0
                                            zigbee
                                            1741
