    4. FHEM Adapter
    FHEM Adapter
    • LausiD
      LausiD @andi2055 last edited by
      @andi2055
      Danke für die Infos.
      Welche Version hat der FHEM Adapter bei dir?
      Deine oder die github Version?
        andi2055 @LausiD last edited by
        @LausiD
        ich hatte heute mit beiden Versionen experimentiert.
        Anbei Log & Screenshot von deiner Github-Version
        fhem.0	2021-01-08 22:46:42.652	debug	(9878) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU_Vorlauftemperatur_Waermeerzeuger 25.8 °C {"val":"25.8 °C","ack":true,"ts":1610142402650,"q":0,"from":"system.adapter.fhem.0","user":"system.us
        fhem.0	2021-01-08 22:46:42.649	debug	(9878) [syncStates] update state: fhem.0.myHPSU.HPSU_Vorlauftemperatur_Waermeerzeuger = 27.1 °C > 25.8 °C
        fhem.0	2021-01-08 22:46:42.628	debug	(9878) [stateChange] stateChange (in): fhem.0.info.Info.numberObjectsIOBin 191 {"val":191,"ack":true,"ts":1610142402624,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":16101126659
        fhem.0	2021-01-08 22:46:42.625	debug	(9878) [syncFunction] (sensor) fhem.0.myHPSU.state_boolean
        fhem.0	2021-01-08 22:46:42.623	debug	(9878) [syncRoom] (HPSU) fhem.0.myHPSU
        fhem.0	2021-01-08 22:46:42.575	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Fluesterbetrieb_{quiet_mode} (state) - common
        fhem.0	2021-01-08 22:46:42.519	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Betriebsart_{mode_01} (state) - common
        fhem.0	2021-01-08 22:46:42.505	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~HK_Funktion_{hc_func} (state) - common
        fhem.0	2021-01-08 22:46:42.494	info	(9878) unhandled event FHEM: ---- | HPSU myHPSU Info.Q: 0.133 kW > no sync - no fhemObjects >> jsonlist2 myHPSU
        fhem.0	2021-01-08 22:46:42.493	debug	(9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 0.133 kW"
        fhem.0	2021-01-08 22:46:42.480	debug	(9878) [stateChange] stateChange (in): fhem.0.info.Info.numberDevicesFHEMignored 4 {"val":4,"ack":true,"ts":1610142402476,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":160980120
        fhem.0	2021-01-08 22:46:42.478	debug	(9878) [syncObjects] update object: fhem.0.myHPSU (channel) - native
        fhem.0	2021-01-08 22:46:42.474	debug	(9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] Funktion: sensor für fhem.0.myHPSU.state_boolean
        fhem.0	2021-01-08 22:46:42.472	debug	(9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] check channel fhem.0.myHPSU | name: myHPSU | room: HPSU | role: undefined |
        fhem.0	2021-01-08 22:46:42.462	info	(9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 25.8 °C > no sync - no fhemObjects >> jsonlist2 myHPSU
        fhem.0	2021-01-08 22:46:42.462	debug	(9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 25.8 °C"
        fhem.0	2021-01-08 22:46:41.799	info	(9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active > no sync - no fhemObjects >> jsonlist2 myHPSU
        fhem.0	2021-01-08 22:46:41.799	debug	(9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active"
        fhem.0	2021-01-08 22:46:40.885	info	(9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen > no sync - no fhemObjects >> jsonlist2 myHPSU
        fhem.0	2021-01-08 22:46:40.885	debug	(9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
        fhem.0	2021-01-08 22:46:40.447	debug	(9878) [syncStates] end
        fhem.0	2021-01-08 22:46:40.438	debug	(9878) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU_Kaeltemitteltemperatur 27.5 °C {"val":"27.5 °C","ack":true,"ts":1610142400437,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin",
        fhem.0	2021-01-08 22:46:40.436	debug	(9878) [syncStates] update state: fhem.0.myHPSU.HPSU_Kaeltemitteltemperatur = 27.7 °C > 27.5 °C
        fhem.0	2021-01-08 22:46:40.421	debug	(9878) [stateChange] stateChange (in): fhem.0.info.Info.numberObjectsIOBin 191 {"val":191,"ack":true,"ts":1610142400419,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":16101126659
        fhem.0	2021-01-08 22:46:40.420	debug	(9878) [syncFunction] (sensor) fhem.0.myHPSU.state_boolean
        fhem.0	2021-01-08 22:46:40.418	debug	(9878) [syncRoom] (HPSU) fhem.0.myHPSU
        fhem.0	2021-01-08 22:46:40.375	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Fluesterbetrieb_{quiet_mode} (state) - common
        fhem.0	2021-01-08 22:46:40.315	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Betriebsart_{mode_01} (state) - common
        fhem.0	2021-01-08 22:46:40.283	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~HK_Funktion_{hc_func} (state) - common
        fhem.0	2021-01-08 22:46:40.254	debug	(9878) [stateChange] stateChange (in): fhem.0.info.Info.numberDevicesFHEMignored 4 {"val":4,"ack":true,"ts":1610142400248,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":160980120
        fhem.0	2021-01-08 22:46:40.249	debug	(9878) [syncObjects] update object: fhem.0.myHPSU (channel) - native
        fhem.0	2021-01-08 22:46:40.246	debug	(9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] Funktion: sensor für fhem.0.myHPSU.state_boolean
        fhem.0	2021-01-08 22:46:40.242	debug	(9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] check channel fhem.0.myHPSU | name: myHPSU | room: HPSU | role: undefined |
        fhem.0	2021-01-08 22:46:40.225	info	(9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.ehs: 0 kWh > no sync - no fhemObjects >> jsonlist2 myHPSU
        fhem.0	2021-01-08 22:46:40.224	debug	(9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
        fhem.0	2021-01-08 22:46:37.265	info	(9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C > no sync - no fhemObjects >> jsonlist2 myHPSU
        fhem.0	2021-01-08 22:46:37.265	debug	(9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C"
        fhem.0	2021-01-08 22:46:37.011	info	(9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 27.5 °C > no sync - no fhemObjects >> jsonlist2 myHPSU
        fhem.0	2021-01-08 22:46:37.010	debug	(9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 27.5 °C"
        fhem.0	2021-01-08 22:46:36.766	debug	(9878) [syncStates] end
        fhem.0	2021-01-08 22:46:36.765	debug	(9878) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 1.867 kW {"val":"1.867 kW","ack":true,"ts":1610142396762,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610142396762
        fhem.0	2021-01-08 22:46:36.761	debug	(9878) [syncStates] update state: fhem.0.myHPSU.Info_Q = 1.067 kW > 1.867 kW
        fhem.0	2021-01-08 22:46:36.758	debug	(9878) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU_T_direkter_Heizkreis 26.1 °C {"val":"26.1 °C","ack":true,"ts":1610142396756,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","
        fhem.0	2021-01-08 22:46:36.755	debug	(9878) [syncStates] update state: fhem.0.myHPSU.HPSU_T_direkter_Heizkreis = 27.9 °C > 26.1 °C
        fhem.0	2021-01-08 22:46:36.747	debug	(9878) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU_Heizung_Ruecklauf 25.7 °C {"val":"25.7 °C","ack":true,"ts":1610142396745,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc"
        fhem.0	2021-01-08 22:46:36.743	debug	(9878) [syncStates] update state: fhem.0.myHPSU.HPSU_Heizung_Ruecklauf = 26.3 °C > 25.7 °C
        fhem.0	2021-01-08 22:46:36.725	debug	(9878) [stateChange] stateChange (in): fhem.0.info.Info.numberObjectsIOBin 191 {"val":191,"ack":true,"ts":1610142396721,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610112665
        fhem.0	2021-01-08 22:46:36.723	debug	(9878) [syncFunction] (sensor) fhem.0.myHPSU.state_boolean
        fhem.0	2021-01-08 22:46:36.720	debug	(9878) [syncRoom] (HPSU) fhem.0.myHPSU
        fhem.0	2021-01-08 22:46:36.656	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Fluesterbetrieb_{quiet_mode} (state) - common
        fhem.0	2021-01-08 22:46:36.649	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Betriebsart_{mode_01} (state) - common
        fhem.0	2021-01-08 22:46:36.635	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~HK_Funktion_{hc_func} (state) - common
        fhem.0	2021-01-08 22:46:36.615	debug	(9878) [stateChange] stateChange (in): fhem.0.info.Info.numberDevicesFHEMignored 4 {"val":4,"ack":true,"ts":1610142396599,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":16098012
        fhem.0	2021-01-08 22:46:36.601	debug	(9878) [syncObjects] update object: fhem.0.myHPSU (channel) - native
        fhem.0	2021-01-08 22:46:36.595	debug	(9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] Funktion: sensor für fhem.0.myHPSU.state_boolean
        fhem.0	2021-01-08 22:46:36.591	debug	(9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] check channel fhem.0.myHPSU | name: myHPSU | room: HPSU | role: undefined |
        fhem.0	2021-01-08 22:46:36.573	info	(9878) unhandled event FHEM: ---- | HPSU myHPSU Info.Q: 1.867 kW > no sync - no fhemObjects >> jsonlist2 myHPSU
        fhem.0	2021-01-08 22:46:36.572	debug	(9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 1.867 kW"
        fhem.0	2021-01-08 22:46:36.553	info	(9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.Heizung_Ruecklauf: 25.7 °C > no sync - no fhemObjects >> jsonlist2 myHPSU
        fhem.0	2021-01-08 22:46:36.552	debug	(9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 25.7 °C"
        fhem.0	2021-01-08 22:46:36.036	info	(9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.T_direkter_Heizkreis: 26.1 °C > no sync - no fhemObjects >> jsonlist2 myHPSU
        fhem.0	2021-01-08 22:46:36.036	debug	(9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 26.1 °C"
        fhem.0	2021-01-08 22:46:34.767	info	(9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen > no sync - no fhemObjects >> jsonlist2 myHPSU
        fhem.0	2021-01-08 22:46:34.766	debug	(9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
        fhem.0	2021-01-08 22:46:34.385	debug	(9878) [syncStates] end
        fhem.0	2021-01-08 22:46:34.351	debug	(9878) [stateChange] stateChange (in): fhem.0.info.Info.numberObjectsIOBin 191 {"val":191,"ack":true,"ts":1610142394345,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610112665
        fhem.0	2021-01-08 22:46:34.348	debug	(9878) [syncFunction] (sensor) fhem.0.myHPSU.state_boolean
        fhem.0	2021-01-08 22:46:34.345	debug	(9878) [syncRoom] (HPSU) fhem.0.myHPSU
        fhem.0	2021-01-08 22:46:34.222	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Fluesterbetrieb_{quiet_mode} (state) - common
        fhem.0	2021-01-08 22:46:34.212	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Betriebsart_{mode_01} (state) - common
        fhem.0	2021-01-08 22:46:34.151	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~HK_Funktion_{hc_func} (state) - common
        fhem.0	2021-01-08 22:46:34.125	debug	(9878) [stateChange] stateChange (in): fhem.0.info.Info.numberDevicesFHEMignored 4 {"val":4,"ack":true,"ts":1610142394119,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":16098012
        fhem.0	2021-01-08 22:46:34.121	debug	(9878) [syncObjects] update object: fhem.0.myHPSU (channel) - native
        fhem.0	2021-01-08 22:46:34.117	debug	(9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] Funktion: sensor für fhem.0.myHPSU.state_boolean
        fhem.0	2021-01-08 22:46:34.113	debug	(9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] check channel fhem.0.myHPSU | name: myHPSU | room: HPSU | role: undefined |
        fhem.0	2021-01-08 22:46:34.096	info	(9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.ehs: 0 kWh > no sync - no fhemObjects >> jsonlist2 myHPSU
        fhem.0	2021-01-08 22:46:34.095	debug	(9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
        fhem.0	2021-01-08 22:46:32.242	debug	(9878) [syncStates] end
        fhem.0	2021-01-08 22:46:32.241	debug	(9878) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 1.067 kW {"val":"1.067 kW","ack":true,"ts":1610142392239,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610142392239
        fhem.0	2021-01-08 22:46:32.238	debug	(9878) [syncStates] update state: fhem.0.myHPSU.Info_Q = 2.934 kW > 1.067 kW
        fhem.0	2021-01-08 22:46:32.215	debug	(9878) [syncFunction] (sensor) fhem.0.myHPSU.state_boolean
        fhem.0	2021-01-08 22:46:32.214	debug	(9878) [stateChange] stateChange (in): fhem.0.info.Info.numberObjectsIOBin 191 {"val":191,"ack":true,"ts":1610142392213,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610112665
        fhem.0	2021-01-08 22:46:32.212	debug	(9878) [syncRoom] (HPSU) fhem.0.myHPSU
        fhem.0	2021-01-08 22:46:32.165	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Fluesterbetrieb_{quiet_mode} (state) - common
        fhem.0	2021-01-08 22:46:32.110	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Betriebsart_{mode_01} (state) - common
        fhem.0	2021-01-08 22:46:32.095	debug	(9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~HK_Funktion_{hc_func} (state) - common
        fhem.0	2021-01-08 22:46:32.080	debug	(9878) [stateChange] stateChange (in): fhem.0.info.Info.numberDevicesFHEMignored 4 {"val":4,"ack":true,"ts":1610142392076,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":16098012
        fhem.0	2021-01-08 22:46:32.077	debug	(9878) [syncObjects] update object: fhem.0.myHPSU (channel) - native
        LausiD 1 Reply Last reply Reply Quote 0
        • LausiD
          @andi2055
          Jetzt wird es langsam klar 🙂
          Der Name von einem Reading wird beim Adapter Start von . auf _ geändert.
          Kommt eine Wertänderung für dieses Reading wird aber nichts geändert.
          Deshalb das jsonlist2 für alle Readings 😞
          Bisher noch nie von Readings mit . gehört. Kennt jemand noch Readings mit . im Name?
          Egal kann ich am WE noch einbauen....
          Gruß LausiD
          • LausiD
            LausiD @LausiD last edited by
            @andi2055 @hg6806
            So jetzt mal bitte nochmal mit update von github prüfen.
            Danke und Gruß
            LausiD
            • hg6806
              hg6806 Most Active @LausiD last edited by
              @LausiD
              So, getestet!
              Aktualisierung der Werte in ioBroker sehr sporadisch wie es sein soll.
              Aber die Datenpunkte haben sich wieder im Namen geändert, da bekomme ich immer einen Anfall, da da viel dranhängt wie VIS, Javascript, History, etc.
              Ist immer ein Mega-Aufwand das wieder geradezubügeln.
              • LausiD
                LausiD @hg6806 last edited by LausiD
                @hg6806
                Danke für die Rückmeldung 🙂
                Die Datenpunkte sollten wie in der Version von @andi2055 sein. Also aus . wird ~. aus[ wird { und aus ] wird }.
                Ok in meiner letzen Version wurde aus . ein _ 😞
                Finde ich aber besser, da bisher schon aus . auch ein _ wurde.
                Was meinst du?
                • hg6806
                  @LausiD
                  Bin gerade am Ändern.
                  Bitte so lassen wenn es ok für alle ist.
                  • LausiD
                    @hg6806 @andi2055
                    Falls die angelegten Objekte jetzt so aussehen können wir es so lassen.
                    LausiD
                      @LausiD
                      funktioniert bei mir auch perfekt.
                      Danke dir!
                      Anbei 1 Min Debug Log. Sieht aber denke ich gut aus.
                      2021-01-09 21:27:00.100 - debug: shuttercontrol.0 (2454) outsidetemperature changed: 0_userdata.0.Außen.Temperatur.Mean_15 Value: 0.7
                      2021-01-09 21:27:02.062 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
                      2021-01-09 21:27:02.063 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
                      2021-01-09 21:27:04.249 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
                      2021-01-09 21:27:04.249 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
                      2021-01-09 21:27:04.507 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1123 lh"
                      2021-01-09 21:27:04.508 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1123 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1123 lh
                      2021-01-09 21:27:05.220 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %"
                      2021-01-09 21:27:05.221 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 %
                      2021-01-09 21:27:05.478 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %"
                      2021-01-09 21:27:05.479 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 %
                      2021-01-09 21:27:06.604 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C"
                      2021-01-09 21:27:06.605 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C
                      2021-01-09 21:27:06.611 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C {"val":"29.3 °C","ack":true,"ts":1610224026607,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224026607}
                      2021-01-09 21:27:06.911 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.2 °C"
                      2021-01-09 21:27:06.912 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.2 °C
                      2021-01-09 21:27:07.513 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Wartezeit_BOH: 80 min"
                      2021-01-09 21:27:07.513 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Wartezeit_BOH: 80 min | reading > fhem.0.myHPSU.HPSU~Wartezeit_BOH 80 min
                      2021-01-09 21:27:08.020 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %"
                      2021-01-09 21:27:08.021 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 %
                      2021-01-09 21:27:08.782 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
                      2021-01-09 21:27:08.782 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
                      2021-01-09 21:27:10.360 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 25.6 °C"
                      2021-01-09 21:27:10.362 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 25.6 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 25.6 °C
                      2021-01-09 21:27:10.367 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 25.6 °C {"val":"25.6 °C","ack":true,"ts":1610224030364,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224030364}
                      2021-01-09 21:27:10.389 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.705 kW"
                      2021-01-09 21:27:10.391 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.705 kW | reading > fhem.0.myHPSU.Info_Q 4.705 kW
                      2021-01-09 21:27:10.395 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.705 kW {"val":"4.705 kW","ack":true,"ts":1610224030392,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224030392}
                      2021-01-09 21:27:10.823 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C"
                      2021-01-09 21:27:10.824 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26 °C
                      2021-01-09 21:27:11.077 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C"
                      2021-01-09 21:27:11.078 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C
                      2021-01-09 21:27:11.081 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C {"val":"25.7 °C","ack":true,"ts":1610224031079,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224031079}
                      2021-01-09 21:27:11.331 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.TVBH: 29.3 °C"
                      2021-01-09 21:27:11.331 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.TVBH: 29.3 °C | reading > fhem.0.myHPSU.HPSU~TVBH 29.3 °C
                      2021-01-09 21:27:11.794 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
                      2021-01-09 21:27:11.795 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
                      2021-01-09 21:27:14.902 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
                      2021-01-09 21:27:14.903 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
                      2021-01-09 21:27:16.233 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_T_direkter_Heizkreis: 29.2 °C"
                      2021-01-09 21:27:16.234 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_T_direkter_Heizkreis: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Soll_T_direkter_Heizkreis 29.2 °C
                      2021-01-09 21:27:16.540 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_Vorlauftemperatur_Waermeerzeuger: 29.2 °C"
                      2021-01-09 21:27:16.541 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_Vorlauftemperatur_Waermeerzeuger: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Soll_Vorlauftemperatur_Waermeerzeuger 29.2 °C
                      2021-01-09 21:27:17.494 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
                      2021-01-09 21:27:17.495 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
                      2021-01-09 21:27:17.748 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1146 lh"
                      2021-01-09 21:27:17.749 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1146 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1146 lh
                      2021-01-09 21:27:17.753 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Durchfluss 1146 lh {"val":"1146 lh","ack":true,"ts":1610224037751,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224037751}
                      2021-01-09 21:27:17.775 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.802 kW"
                      2021-01-09 21:27:17.776 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.802 kW | reading > fhem.0.myHPSU.Info_Q 4.802 kW
                      2021-01-09 21:27:17.781 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.802 kW {"val":"4.802 kW","ack":true,"ts":1610224037778,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224037778}
                      2021-01-09 21:27:18.411 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Betriebsart: Heizen"
                      2021-01-09 21:27:18.412 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Betriebsart Heizen
                      2021-01-09 21:27:18.665 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %"
                      2021-01-09 21:27:18.666 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 %
                      2021-01-09 21:27:18.940 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %"
                      2021-01-09 21:27:18.940 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 %
                      2021-01-09 21:27:19.732 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_Warmwasser: 43.4 °C"
                      2021-01-09 21:27:19.734 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_Warmwasser: 43.4 °C | reading > fhem.0.myHPSU.HPSU~T_Warmwasser 43.4 °C
                      2021-01-09 21:27:19.741 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_Warmwasser 43.4 °C {"val":"43.4 °C","ack":true,"ts":1610224039737,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224039737}
                      2021-01-09 21:27:20.256 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C"
                      2021-01-09 21:27:20.257 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C
                      2021-01-09 21:27:20.559 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.2 °C"
                      2021-01-09 21:27:20.562 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.2 °C
                      2021-01-09 21:27:20.907 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_Aussen: -0.2 °C"
                      2021-01-09 21:27:20.908 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_Aussen: -0.2 °C | reading > fhem.0.myHPSU.HPSU~T_Aussen -0.2 °C
                      2021-01-09 21:27:20.912 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_Aussen -0.2 °C {"val":"-0.2 °C","ack":true,"ts":1610224040909,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224040909}
                      2021-01-09 21:27:21.160 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.2 °C"
                      2021-01-09 21:27:21.161 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.2 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.2 °C
                      2021-01-09 21:27:21.169 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.2 °C {"val":"26.2 °C","ack":true,"ts":1610224041167,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224041167}
                      2021-01-09 21:27:21.189 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.001 kW"
                      2021-01-09 21:27:21.190 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.001 kW | reading > fhem.0.myHPSU.Info_Q 4.001 kW
                      2021-01-09 21:27:21.195 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.001 kW {"val":"4.001 kW","ack":true,"ts":1610224041192,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224041192}
                      2021-01-09 21:27:21.621 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 25.9 °C"
                      2021-01-09 21:27:21.622 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 25.9 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 25.9 °C
                      2021-01-09 21:27:21.626 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 25.9 °C {"val":"25.9 °C","ack":true,"ts":1610224041623,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224041623}
                      2021-01-09 21:27:21.874 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C"
                      2021-01-09 21:27:21.875 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C
                      2021-01-09 21:27:22.287 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %"
                      2021-01-09 21:27:22.288 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 %
                      2021-01-09 21:27:23.048 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
                      2021-01-09 21:27:23.049 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
                      2021-01-09 21:27:23.967 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active"
                      2021-01-09 21:27:23.968 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active | reading > fhem.0.myHPSU.HPSU~Direkter_Heizkreis_Modus active
                      2021-01-09 21:27:24.884 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_T_Raum_1: 21 °C"
                      2021-01-09 21:27:24.885 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_T_Raum_1: 21 °C | reading > fhem.0.myHPSU.HPSU~Soll_T_Raum_1 21 °C
                      2021-01-09 21:27:25.142 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_Aussen_WP: -0.2 °C"
                      2021-01-09 21:27:25.143 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_Aussen_WP: -0.2 °C | reading > fhem.0.myHPSU.HPSU~T_Aussen_WP -0.2 °C
                      2021-01-09 21:27:25.147 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_Aussen_WP -0.2 °C {"val":"-0.2 °C","ack":true,"ts":1610224045145,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224045145}
                      2021-01-09 21:27:25.854 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
                      2021-01-09 21:27:25.854 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
                      2021-01-09 21:27:28.545 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1168 lh"
                      2021-01-09 21:27:28.546 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1168 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1168 lh
                      2021-01-09 21:27:28.548 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Durchfluss 1168 lh {"val":"1168 lh","ack":true,"ts":1610224048546,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224048546}
                      2021-01-09 21:27:28.573 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.078 kW"
                      2021-01-09 21:27:28.573 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.078 kW | reading > fhem.0.myHPSU.Info_Q 4.078 kW
                      2021-01-09 21:27:28.579 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.078 kW {"val":"4.078 kW","ack":true,"ts":1610224048574,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224048574}
                      2021-01-09 21:27:29.157 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
                      2021-01-09 21:27:29.158 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
                      2021-01-09 21:27:29.464 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %"
                      2021-01-09 21:27:29.465 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 %
                      2021-01-09 21:27:29.721 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %"
                      2021-01-09 21:27:29.722 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 %
                      2021-01-09 21:27:30.849 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C"
                      2021-01-09 21:27:30.850 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C
                      2021-01-09 21:27:31.216 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.3 °C"
                      2021-01-09 21:27:31.218 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.3 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.3 °C
                      2021-01-09 21:27:31.224 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.214 kW"
                      2021-01-09 21:27:31.225 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.214 kW | reading > fhem.0.myHPSU.Info_Q 4.214 kW
                      2021-01-09 21:27:31.228 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.3 °C {"val":"29.3 °C","ack":true,"ts":1610224051219,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224051219}
                      2021-01-09 21:27:31.230 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.214 kW {"val":"4.214 kW","ack":true,"ts":1610224051226,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224051226}
                      2021-01-09 21:27:31.605 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.1 °C"
                      2021-01-09 21:27:31.606 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.1 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.1 °C
                      2021-01-09 21:27:31.611 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.1 °C {"val":"26.1 °C","ack":true,"ts":1610224051607,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224051607}
                      2021-01-09 21:27:31.630 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.350 kW"
                      2021-01-09 21:27:31.631 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.350 kW | reading > fhem.0.myHPSU.Info_Q 4.350 kW
                      2021-01-09 21:27:31.633 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.350 kW {"val":"4.350 kW","ack":true,"ts":1610224051632,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224051632}
                      2021-01-09 21:27:32.061 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C"
                      2021-01-09 21:27:32.062 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26 °C
                      2021-01-09 21:27:32.066 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26 °C {"val":"26 °C","ack":true,"ts":1610224052064,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224052064}
                      2021-01-09 21:27:32.319 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C"
                      2021-01-09 21:27:32.319 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C
                      2021-01-09 21:27:32.724 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %"
                      2021-01-09 21:27:32.725 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 %
                      2021-01-09 21:27:33.031 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
                      2021-01-09 21:27:33.032 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
                      2021-01-09 21:27:36.136 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
                      2021-01-09 21:27:36.137 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
                      2021-01-09 21:27:38.330 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
                      2021-01-09 21:27:38.330 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
                      2021-01-09 21:27:41.021 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1146 lh"
                      2021-01-09 21:27:41.022 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1146 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1146 lh
                      2021-01-09 21:27:41.024 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Durchfluss 1146 lh {"val":"1146 lh","ack":true,"ts":1610224061023,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224061023}
                      2021-01-09 21:27:41.049 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.268 kW"
                      2021-01-09 21:27:41.050 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.268 kW | reading > fhem.0.myHPSU.Info_Q 4.268 kW
                      2021-01-09 21:27:41.053 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.268 kW {"val":"4.268 kW","ack":true,"ts":1610224061051,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224061051}
                      2021-01-09 21:27:41.631 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
                      2021-01-09 21:27:41.632 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
                      2021-01-09 21:27:41.935 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %"
                      2021-01-09 21:27:41.936 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 %
                      2021-01-09 21:27:42.192 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %"
                      2021-01-09 21:27:42.193 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 %
                      2021-01-09 21:27:43.319 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.2 °C"
                      2021-01-09 21:27:43.320 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.2 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.2 °C
                      2021-01-09 21:27:43.323 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.2 °C {"val":"29.2 °C","ack":true,"ts":1610224063321,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224063321}
                      2021-01-09 21:27:43.626 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.3 °C"
                      2021-01-09 21:27:43.627 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.3 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.3 °C
                      2021-01-09 21:27:44.020 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.1 °C"
                      2021-01-09 21:27:44.021 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.1 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.1 °C
                      2021-01-09 21:27:44.480 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C"
                      2021-01-09 21:27:44.480 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26 °C
                      2021-01-09 21:27:44.744 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C"
                      2021-01-09 21:27:44.747 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C
                      2021-01-09 21:27:44.990 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.TVBH: 29.2 °C"
                      2021-01-09 21:27:44.991 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.TVBH: 29.2 °C | reading > fhem.0.myHPSU.HPSU~TVBH 29.2 °C
                      2021-01-09 21:27:44.996 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~TVBH 29.2 °C {"val":"29.2 °C","ack":true,"ts":1610224064993,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224064993}
                      2021-01-09 21:27:45.346 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %"
                      2021-01-09 21:27:45.347 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 %
                      2021-01-09 21:27:45.651 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
                      2021-01-09 21:27:45.651 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
                      2021-01-09 21:27:47.448 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_T_direkter_Heizkreis: 29.2 °C"
                      2021-01-09 21:27:47.448 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_T_direkter_Heizkreis: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Soll_T_direkter_Heizkreis 29.2 °C
                      2021-01-09 21:27:47.755 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_Vorlauftemperatur_Waermeerzeuger: 29.2 °C"
                      2021-01-09 21:27:47.755 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_Vorlauftemperatur_Waermeerzeuger: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Soll_Vorlauftemperatur_Waermeerzeuger 29.2 °C
                      2021-01-09 21:27:49.169 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
                      2021-01-09 21:27:49.170 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
                      2021-01-09 21:27:49.918 - debug: fhem.0 (16732) [setAlive] start setAlive 300 sec
                      2021-01-09 21:27:49.923 - info: fhem.0 (16732) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                      2021-01-09 21:27:49.933 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "dummy fhem.0.alive on"
                      2021-01-09 21:27:49.933 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive true - start
                      2021-01-09 21:27:49.936 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive reset timer
                      2021-01-09 21:27:49.937 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610224069920,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069920}
                      2021-01-09 21:27:49.954 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Commands.resultFHEM {"val":"","ack":true,"ts":1610224069941,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069941}
                      2021-01-09 21:27:49.955 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Info.alive true {"val":true,"ack":true,"ts":1610224069942,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610223769942}
                      2021-01-09 21:27:49.955 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Debug.numberIn 144 {"val":144,"ack":true,"ts":1610224069942,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069942}
                      2021-01-09 21:27:49.960 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Debug.timeIn 5 {"val":5,"ack":true,"ts":1610224069943,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069943}
                      2021-01-09 21:27:49.961 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Debug.numberOut 0 {"val":0,"ack":true,"ts":1610224069944,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610131742427}
                      2021-01-09 21:27:49.962 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Debug.timeOut null {"val":null,"ack":true,"ts":1610224069944,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069944}
                      2021-01-09 21:27:49.967 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Commands.lastCommand set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610224069951,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069951}
                      2021-01-09 21:27:49.969 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM done {"val":"done","ack":true,"ts":1610224069957,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069957}
                      2021-01-09 21:27:51.359 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
                      2021-01-09 21:27:51.360 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
                      2021-01-09 21:27:51.613 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1146 lh"
                      2021-01-09 21:27:51.614 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1146 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1146 lh
                      2021-01-09 21:27:52.328 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %"
                      2021-01-09 21:27:52.331 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 %
                      2021-01-09 21:27:52.581 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %"
                      2021-01-09 21:27:52.582 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 %
                      2021-01-09 21:27:53.450 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_T_Warmwasser: 46 °C"
                      2021-01-09 21:27:53.450 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_T_Warmwasser: 46 °C | reading > fhem.0.myHPSU.HPSU~Soll_T_Warmwasser 46 °C
                      2021-01-09 21:27:53.920 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C"
                      2021-01-09 21:27:53.921 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C
                      2021-01-09 21:27:53.924 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C {"val":"29.3 °C","ack":true,"ts":1610224073922,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224073922}
                      2021-01-09 21:27:54.223 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.4 °C"
                      2021-01-09 21:27:54.225 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.4 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.4 °C
                      2021-01-09 21:27:54.229 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.4 °C {"val":"29.4 °C","ack":true,"ts":1610224074227,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224074227}
                      2021-01-09 21:27:54.243 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.402 kW"
                      2021-01-09 21:27:54.244 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.402 kW | reading > fhem.0.myHPSU.Info_Q 4.402 kW
                      2021-01-09 21:27:54.248 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.402 kW {"val":"4.402 kW","ack":true,"ts":1610224074245,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224074245}
                      2021-01-09 21:27:54.624 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 26 °C"
                      2021-01-09 21:27:54.625 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 26 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26 °C
                      2021-01-09 21:27:54.629 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26 °C {"val":"26 °C","ack":true,"ts":1610224074627,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224074627}
                      2021-01-09 21:27:54.652 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.535 kW"
                      2021-01-09 21:27:54.653 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.535 kW | reading > fhem.0.myHPSU.Info_Q 4.535 kW
                      2021-01-09 21:27:54.657 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.535 kW {"val":"4.535 kW","ack":true,"ts":1610224074655,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224074655}
                      2021-01-09 21:27:55.083 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26.1 °C"
                      2021-01-09 21:27:55.084 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26.1 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26.1 °C
                      2021-01-09 21:27:55.087 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26.1 °C {"val":"26.1 °C","ack":true,"ts":1610224075085,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224075085}
                      2021-01-09 21:27:55.341 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C"
                      2021-01-09 21:27:55.342 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C
                      2021-01-09 21:27:55.747 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %"
                      2021-01-09 21:27:55.747 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 %
                      2021-01-09 21:27:56.513 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
                      2021-01-09 21:27:56.514 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
                      2021-01-09 21:27:57.430 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active"
                      2021-01-09 21:27:57.431 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active | reading > fhem.0.myHPSU.HPSU~Direkter_Heizkreis_Modus active
                      So sieht's aus
                      • D3ltoroxp
                        D3ltoroxp @andi2055 last edited by
                        @andi2055 Ich bräuchte mal noch eure Hilfe. Soweit läuft der Adapter Top, ich bräuchte hier noch die Buttons in ioBroker, damit ich die Rollos zum fahren forcen kann, auch wenn das Rollo Device sagt der Rollo sei unten. Hier kann ich dennoch drücken und er fährt, falls er noch oben ist. Aber ich habe hier keine attr die ich adden könnte.
                        Fällt euch dazu was ein, wie ich das dennoch über ioB steuern kann, bräuchte das für die VIS ?
                        • LausiD
                          LausiD @D3ltoroxp last edited by
                          @d3ltoroxp
                          Mh wenn du den Befehl dafür kennst, kannst du zB im ioB über fhem.0.info.Commands.sendFHEM den Befehl eingeben.
                          Gruß LausiD
                            Banis @LausiD last edited by
                            seit ein paar Tagen habe ich beim HPSU Modul das Problem, dass sehr häufig in den Datenpunkten in ioBRoker statt dem eigentlichen Wert ganz kurz ein Punkt drin steht. Bei den anderen FHEM Modlen konnte ich das nicht beobachten.
                            Habt ihr das Problem auch?
                              andi2055 @Banis last edited by
                              @banis
                              Es gab ein Update beim FHEM HPSU Modul mit größeren Anpassungen.
                              Ich teste das auch gerade.
                              Kannst du überhaupt noch Werte verändern aus ioB heraus? Bspw. Heizkurve
                              Der Punkt stand in früheren Versionen bei mir in alles States, die zum Setzen der Werte vorhanden waren. Nun gibt es diese bei mir nicht mehr. Das wurde anscheinend zusammengelegt?
                              B LausiD 2 Replies Last reply Reply Quote 0
                                Banis @andi2055 last edited by
                                @andi2055 Ich bin zwischenzeitlich wieder zurück auf die Modul Version 1.10
                                Ich konnt aber mit der 1.11 auch Werte schreiben. Bin mir jetzt aber nicht mehr ganz sicher wie ich das gemacht hab, ich glaube das ging in den Datenpunkten wo auch die Werte gelesen werden. Musst dort mal ausprobieren ob du dort auch schreiben kannst.
                                Dadurch dass immer wieder ein . im Datenpunkt war, wurden meine Logs ziemlich voll. Dadurch hat sich dann mein history Adapter immer mal wieder verabschiedet. Deshalb bin ich beim HPSU Modul eine Version zurück gegangen
                                • LausiD
                                  @andi2055
                                  Kannst du mal von der neuen Version ein jsonlist2 aus FHEM oder RAW aus ioBroker zeigen?
                                    @lausid
                                    anbei jsonlist2 der neuen FHEM HPSU Adapter Version 1.11
                                    Ich habe mich nun nochmal etwas damit beschäftigt:
                                    Alle schreibbaren Werte waren bei mir nach dem Update nicht schreibbar. Das war mein Hauptproblem.
                                    HPSU~Heizkurve (als Beispiel) stand bei mir nach dem Update auf Readonly. Wäre das bei Neuanlage (Instanz löschen und neu erstellen) auch schreibbar gewesen und wird nur nicht automatisch angepasst?
                                    Ich habe alle schreibbaren Werte manuell auf WRITE gestellt und nun kann ich damit Werte auch setzen.
                                    Funktioniert also grundsätzlich bei mir.
                                    Alle Werte, die nicht in Readings enthalten sind (Beispiel: HPSU~HZ_Unterstuetzung), enthalten bei mir einen ".". Ich kann die Werte ON/OFF aber auswählen und setzen. Soweit aus meiner Sicht ok.
                                    @Banis dein Problem kann ich so nicht bestätigen. Das musst du bitte nochmal genauer erklären
                                        "Name":"myHPSU",
                                        "PossibleSets":"Disconnect:noArg Connect:noArg ForceDHW:noArg Connect_MonitorMode:noArg HPSU.Kuehl_Soll_Korr_Parallel:slider,-5,0.1,5,1 HPSU.Spreizung_Mod_HZ:slider,2,1,20 HPSU.WW_Sperrzeit:slider,0,1,240 HPSU.Bivalenzfunktion:off,on HPSU.Funktion_EHS:slider,0,1,3 HPSU.HK_Funktion:Witterung,Fest HPSU.Heizkurve:slider,0,0.1,3,1 HPSU.HZ_Unterstuetzung:off,on HPSU.Max_WW_Ladezeit:slider,0,1,240 HPSU.Max_Leistung_Pumpe:slider,20,1,100 HPSU.Max_T_Vorlauf:slider,20,1,90 HPSU.Kuehlen_A_Temp_Max:slider,20,1,45 HPSU.Min_Leistung_Pumpe:slider,10,1,100 HPSU.Min_T_Vorlauf:slider,18,1,90 HPSU.Kuehlen_VL_Soll_Abs_Min:slider,5,1,25 HPSU.Betriebsart:Bereitschaft,Auto1,Auto2,Kuehlen,Heizen,Absenken,Sommer HPSU.Fluesterbetrieb:Aus,Ein,Nur_bei_Nacht HPSU.Kuehlen_A_Temp_Start:slider,15,1,45 HPSU.Schaltschwelle_AUX_TDHW:slider,20,1,85 HPSU.Soll_T_Warmwasser_1:slider,35,1,70 HPSU.Soll_T_Warmwasser_2:slider,35,1,70 HPSU.Soll_T_Warmwasser_3:slider,35,1,70 HPSU.Kuehlen_VL_Soll_Max:slider,5,1,25 HPSU.Kuehlen_VL_Soll_Start:slider,5,1,25 HPSU.T_Vorlauf_Tag:slider,20,1,90 HPSU.T_Vorlauf_Nacht:slider,20,1,90 HPSU.T_Frostschutz:-1,-10,-11,-12,-13,-14,-15,Aus,-2,-3,-4,-5,-6,-7,-8,-9,0,1,2,3,4,5 HPSU.Heizgrenze_Tag:slider,10,1,40 HPSU.Heizgrenze_Nacht:slider,10,1,40 HPSU.Soll_T_Raum_1:slider,5,0.5,40,1 HPSU.Soll_T_Raum_2:slider,5,0.5,40,1 HPSU.Soll_T_Raum_3:slider,5,0.5,40,1 HPSU.TDiff_WW_HZU:slider,2,1,15 HPSU.Wartezeit_BOH:slider,20,1,95 ",
                                        "PossibleAttrs":"alias comment:textField-long eventMap:textField-long group room suppressReading userReadings:textField-long verbose:0,1,2,3,4,5 AutoPoll:on,off AntiMixerSwing:on,off CheckDHWInterrupted:on,off DebugLog:on,onWithMsg,onDHW,off AntiContinousHeating:on,off RememberSetValues:on,off SuppressRetryWarnings:on,off event-aggregator event-min-interval event-on-change-reading event-on-update-reading oldreadings stateFormat:textField-long timestamp-on-change-reading cmdIcon devStateIcon:textField-long devStateStyle icon sortby webCmd webCmdLabel:textField-long widgetOverride userattr",
                                        "Internals": {
                                          "DEF": "/dev/ttyUSB0",
                                          "DeviceName": "/dev/ttyUSB0@38400",
                                          "ELM327_Version": "1.5",
                                          "ELMState": "Initialized",
                                          "FD": "8",
                                          "FUUID": "5ff83ab7-f33f-256f-ffb1-ea0f07c2844b852e",
                                          "JSON_Auto_poll": "47",
                                          "JSON_Writable": "100",
                                          "JSON_parameters": "156",
                                          "JSON_version": "3.6",
                                          "Module_Version": "1.11",
                                          "NAME": "myHPSU",
                                          "NR": "21",
                                          "PARTIAL": "",
                                          "STATE": "opened",
                                          "TYPE": "HPSU"
                                        "Readings": {
                                          "Comm.GetStatus": { "Value":"Ok", "Time":"2021-01-23 22:54:03" },
                                          "Comm.ManStatus": { "Value":"Ok: (force) DHW still active (717)", "Time":"2021-01-19 11:04:07" },
                                          "Comm.SetStatus": { "Value":"Ok: Heizkurve [heat_slope] successfully set to 0.4 (1011)", "Time":"2021-01-23 22:35:59" },
                                          "HPSU.Aktive_Betriebsart": { "Value":"Standby", "Time":"2021-01-23 22:53:56" },
                                          "HPSU.Betriebsart": { "Value":"Heizen", "Time":"2021-01-23 22:53:56" },
                                          "HPSU.Direkter_Heizkreis_Modus": { "Value":"power-saving", "Time":"2021-01-23 22:53:57" },
                                          "HPSU.Durchfluss": { "Value":"0 lh", "Time":"2021-01-23 22:53:52" },
                                          "HPSU.EHS_fuer_Heizung": { "Value":"2245 kWh", "Time":"2021-01-23 22:49:35" },
                                          "HPSU.EHS_fuer_WW": { "Value":"706 kWh", "Time":"2021-01-23 22:49:34" },
                                          "HPSU.Energie_Heizung": { "Value":"4366 kWh", "Time":"2021-01-23 22:49:35" },
                                          "HPSU.Energie_Kuehlung": { "Value":"1803 kWh", "Time":"2021-01-23 22:49:39" },
                                          "HPSU.Energie_WW": { "Value":"6949 kWh", "Time":"2021-01-23 22:49:35" },
                                          "HPSU.Energie_erzeugt_gesamt": { "Value":"12386 kWh", "Time":"2021-01-23 22:49:39" },
                                          "HPSU.Fluesterbetrieb": { "Value":"Aus", "Time":"2021-01-23 22:45:35" },
                                          "HPSU.Funktion_EHS": { "Value":"1", "Time":"2021-01-23 22:45:25" },
                                          "HPSU.HK_Funktion": { "Value":"Witterung", "Time":"2021-01-23 22:45:25" },
                                          "HPSU.Heizgrenze_Tag": { "Value":"21 °C", "Time":"2021-01-23 22:46:57" },
                                          "HPSU.Heizkurve": { "Value":"0.4", "Time":"2021-01-23 22:46:01" },
                                          "HPSU.Heizung_Ruecklauf": { "Value":"25.6 °C", "Time":"2021-01-23 22:53:55" },
                                          "HPSU.Kaeltemitteltemperatur": { "Value":"25.1 °C", "Time":"2021-01-23 22:53:51" },
                                          "HPSU.Kuehl_Soll_Korr_Parallel": { "Value":"0 °C", "Time":"2021-01-23 22:45:34" },
                                          "HPSU.Kuehlen_A_Temp_Max": { "Value":"35 °C", "Time":"2021-01-23 22:45:26" },
                                          "HPSU.Kuehlen_A_Temp_Start": { "Value":"22 °C", "Time":"2021-01-23 22:45:36" },
                                          "HPSU.Kuehlen_VL_Soll_Abs_Min": { "Value":"16 °C", "Time":"2021-01-23 22:45:26" },
                                          "HPSU.Kuehlen_VL_Soll_Max": { "Value":"10 °C", "Time":"2021-01-23 22:45:36" },
                                          "HPSU.Kuehlen_VL_Soll_Start": { "Value":"18 °C", "Time":"2021-01-23 22:45:40" },
                                          "HPSU.Laufzeit_Kompressor": { "Value":"7130 h", "Time":"2021-01-23 22:49:40" },
                                          "HPSU.Laufzeit_UWPumpe": { "Value":"12397 h", "Time":"2021-01-23 22:49:40" },
                                          "HPSU.Max_T_Vorlauf": { "Value":"45 °C", "Time":"2021-01-23 22:45:26" },
                                          "HPSU.Min_T_Vorlauf": { "Value":"27 °C", "Time":"2021-01-23 22:45:26" },
                                          "HPSU.Pos_Vent_3UVB1": { "Value":"100 %", "Time":"2021-01-23 22:53:52" },
                                          "HPSU.Pos_Vent_3UV_DHW": { "Value":"0 %", "Time":"2021-01-23 22:54:03" },
                                          "HPSU.Ruecklauftemperatur": { "Value":"24.6 °C", "Time":"2021-01-23 22:53:52" },
                                          "HPSU.Soll_T_Raum_1": { "Value":"20.5 °C", "Time":"2021-01-23 22:53:36" },
                                          "HPSU.Soll_T_Warmwasser": { "Value":"46 °C", "Time":"2021-01-23 22:53:23" },
                                          "HPSU.Soll_T_Warmwasser_1": { "Value":"46 °C", "Time":"2021-01-14 07:53:11" },
                                          "HPSU.Soll_T_direkter_Heizkreis": { "Value":"27.1 °C", "Time":"2021-01-23 22:53:51" },
                                          "HPSU.Soll_Vorlauftemperatur_Waermeerzeuger": { "Value":"0 °C", "Time":"2021-01-23 22:53:39" },
                                          "HPSU.TDiff_WW_HZU": { "Value":"5 °C", "Time":"2021-01-23 22:45:29" },
                                          "HPSU.TVBH": { "Value":"37.8 °C", "Time":"2021-01-23 22:53:33" },
                                          "HPSU.T_Aussen": { "Value":"4.5 °C", "Time":"2021-01-23 22:53:33" },
                                          "HPSU.T_Aussen_WP": { "Value":"4.5 °C", "Time":"2021-01-23 22:53:36" },
                                          "HPSU.T_Aussen_gemittelt": { "Value":"4.7 °C", "Time":"2021-01-23 22:52:21" },
                                          "HPSU.T_Frostschutz": { "Value":"-10", "Time":"2021-01-23 22:53:54" },
                                          "HPSU.T_Warmwasser": { "Value":"46.4 °C", "Time":"2021-01-23 22:53:57" },
                                          "HPSU.T_direkter_Heizkreis": { "Value":"37.4 °C", "Time":"2021-01-23 22:53:54" },
                                          "HPSU.UWPumpe": { "Value":"0 %", "Time":"2021-01-23 22:54:04" },
                                          "HPSU.Vorlauftemperatur_Waermeerzeuger": { "Value":"30.8 °C", "Time":"2021-01-23 22:53:54" },
                                          "HPSU.Wartezeit_BOH": { "Value":"80 min", "Time":"2021-01-23 22:52:37" },
                                          "HPSU.Wasserdruck": { "Value":"1.566 bar", "Time":"2021-01-23 22:45:33" },
                                          "HPSU.ehs": { "Value":"0 kWh", "Time":"2021-01-23 22:53:56" },
                                          "Info.HeatCyclicErr": { "Value":"0", "Time":"2021-01-23 20:50:15" },
                                          "Info.LastDefrostDHWShrink": { "Value":"0.599999999999994 °C", "Time":"2021-01-23 19:57:26" },
                                          "Info.Q": { "Value":"0 kW", "Time":"2021-01-23 20:50:15" },
                                          "state": { "Value":"opened", "Time":"2021-01-21 23:25:40" }
                                        "Attributes": {
                                          "AntiContinousHeating": "on",
                                          "AntiMixerSwing": "off",
                                          "AutoPoll": "on",
                                          "CheckDHWInterrupted": "on",
                                          "DebugLog": "on",
                                          "SuppressRetryWarnings": "on",
                                          "alias": "myHPSU",
                                          "room": "HPSU"
                                    • LausiD
                                      LausiD @andi2055 last edited by
                                      @andi2055
                                      Auf was steht fhem.0.info.Configurations.autoRole bei dir?
                                      Du kannst auch ein einzelnes Objekt löschen..zB HPSU~Heizkurve.....Adapter neu starten und Objekt wird wieder angelegt.
                                      Instanz löschen und neuanlegen ist nie nötig!
                                      Gruß LausiD
                                        andi2055 @LausiD last edited by
                                        @lausid
                                        steht auf true.
                                        An der Stelle habe ich auch noch nie was geändert
                                        Aber Danke, ich weiß jetzt wie es geht
                                          Banis @andi2055 last edited by Banis
                                          @andi2055 Ich hab eben nochmal auf die 1.11 upgedatet. Ist bei mir leider immer noch so. Es scheint so, also ob immer wenn vom FHEM Modul Werte an ioBroker übertragen werden, bei vielen Readings immer kurz ein Punkt gesetzt wird.
                                          Dadurch habe ich permanet Zustandsänderungen, was die Performance des History-Adapters sehr verschlechtert.
                                          Ich hab als Beispeil mal die Werte der Betriebsart in einem Zeitraum von knapp 2 Minuten dargestellt.
                                          • LausiD
                                            LausiD @Banis last edited by
                                            @banis
                                            Hast du den FHEM Adapter über github aktualisiert?
                                            Deine Beschreibung hört sich stark nach dem Problem in 1.5.3 an.
                                            Gruß LausiD
                                            81.1k
                                            adapter fhem
                                            82
                                            676
                                            193967
