FHEM Adapter
@LausiD
ich hatte heute mit beiden Versionen experimentiert.Anbei Log & Screenshot von deiner Github-Version
fhem.0 2021-01-08 22:46:42.652 debug (9878) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU_Vorlauftemperatur_Waermeerzeuger 25.8 °C {"val":"25.8 °C","ack":true,"ts":1610142402650,"q":0,"from":"system.adapter.fhem.0","user":"system.us fhem.0 2021-01-08 22:46:42.649 debug (9878) [syncStates] update state: fhem.0.myHPSU.HPSU_Vorlauftemperatur_Waermeerzeuger = 27.1 °C > 25.8 °C fhem.0 2021-01-08 22:46:42.628 debug (9878) [stateChange] stateChange (in): fhem.0.info.Info.numberObjectsIOBin 191 {"val":191,"ack":true,"ts":1610142402624,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":16101126659 fhem.0 2021-01-08 22:46:42.625 debug (9878) [syncFunction] (sensor) fhem.0.myHPSU.state_boolean fhem.0 2021-01-08 22:46:42.623 debug (9878) [syncRoom] (HPSU) fhem.0.myHPSU fhem.0 2021-01-08 22:46:42.575 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Fluesterbetrieb_{quiet_mode} (state) - common fhem.0 2021-01-08 22:46:42.519 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Betriebsart_{mode_01} (state) - common fhem.0 2021-01-08 22:46:42.505 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~HK_Funktion_{hc_func} (state) - common fhem.0 2021-01-08 22:46:42.494 info (9878) unhandled event FHEM: ---- | HPSU myHPSU Info.Q: 0.133 kW > no sync - no fhemObjects >> jsonlist2 myHPSU fhem.0 2021-01-08 22:46:42.493 debug (9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 0.133 kW" fhem.0 2021-01-08 22:46:42.480 debug (9878) [stateChange] stateChange (in): fhem.0.info.Info.numberDevicesFHEMignored 4 {"val":4,"ack":true,"ts":1610142402476,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":160980120 fhem.0 2021-01-08 22:46:42.478 debug (9878) [syncObjects] update object: fhem.0.myHPSU (channel) - native fhem.0 2021-01-08 22:46:42.474 debug (9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] Funktion: sensor für fhem.0.myHPSU.state_boolean fhem.0 2021-01-08 22:46:42.472 debug (9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] check channel fhem.0.myHPSU | name: myHPSU | room: HPSU | role: undefined | fhem.0 2021-01-08 22:46:42.462 info (9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 25.8 °C > no sync - no fhemObjects >> jsonlist2 myHPSU fhem.0 2021-01-08 22:46:42.462 debug (9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 25.8 °C" fhem.0 2021-01-08 22:46:41.799 info (9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active > no sync - no fhemObjects >> jsonlist2 myHPSU fhem.0 2021-01-08 22:46:41.799 debug (9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active" fhem.0 2021-01-08 22:46:40.885 info (9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen > no sync - no fhemObjects >> jsonlist2 myHPSU fhem.0 2021-01-08 22:46:40.885 debug (9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen" fhem.0 2021-01-08 22:46:40.447 debug (9878) [syncStates] end fhem.0 2021-01-08 22:46:40.438 debug (9878) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU_Kaeltemitteltemperatur 27.5 °C {"val":"27.5 °C","ack":true,"ts":1610142400437,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin", fhem.0 2021-01-08 22:46:40.436 debug (9878) [syncStates] update state: fhem.0.myHPSU.HPSU_Kaeltemitteltemperatur = 27.7 °C > 27.5 °C fhem.0 2021-01-08 22:46:40.421 debug (9878) [stateChange] stateChange (in): fhem.0.info.Info.numberObjectsIOBin 191 {"val":191,"ack":true,"ts":1610142400419,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":16101126659 fhem.0 2021-01-08 22:46:40.420 debug (9878) [syncFunction] (sensor) fhem.0.myHPSU.state_boolean fhem.0 2021-01-08 22:46:40.418 debug (9878) [syncRoom] (HPSU) fhem.0.myHPSU fhem.0 2021-01-08 22:46:40.375 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Fluesterbetrieb_{quiet_mode} (state) - common fhem.0 2021-01-08 22:46:40.315 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Betriebsart_{mode_01} (state) - common fhem.0 2021-01-08 22:46:40.283 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~HK_Funktion_{hc_func} (state) - common fhem.0 2021-01-08 22:46:40.254 debug (9878) [stateChange] stateChange (in): fhem.0.info.Info.numberDevicesFHEMignored 4 {"val":4,"ack":true,"ts":1610142400248,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":160980120 fhem.0 2021-01-08 22:46:40.249 debug (9878) [syncObjects] update object: fhem.0.myHPSU (channel) - native fhem.0 2021-01-08 22:46:40.246 debug (9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] Funktion: sensor für fhem.0.myHPSU.state_boolean fhem.0 2021-01-08 22:46:40.242 debug (9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] check channel fhem.0.myHPSU | name: myHPSU | room: HPSU | role: undefined | fhem.0 2021-01-08 22:46:40.225 info (9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.ehs: 0 kWh > no sync - no fhemObjects >> jsonlist2 myHPSU fhem.0 2021-01-08 22:46:40.224 debug (9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh" fhem.0 2021-01-08 22:46:37.265 info (9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C > no sync - no fhemObjects >> jsonlist2 myHPSU fhem.0 2021-01-08 22:46:37.265 debug (9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C" fhem.0 2021-01-08 22:46:37.011 info (9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 27.5 °C > no sync - no fhemObjects >> jsonlist2 myHPSU fhem.0 2021-01-08 22:46:37.010 debug (9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 27.5 °C" fhem.0 2021-01-08 22:46:36.766 debug (9878) [syncStates] end fhem.0 2021-01-08 22:46:36.765 debug (9878) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 1.867 kW {"val":"1.867 kW","ack":true,"ts":1610142396762,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610142396762 fhem.0 2021-01-08 22:46:36.761 debug (9878) [syncStates] update state: fhem.0.myHPSU.Info_Q = 1.067 kW > 1.867 kW fhem.0 2021-01-08 22:46:36.758 debug (9878) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU_T_direkter_Heizkreis 26.1 °C {"val":"26.1 °C","ack":true,"ts":1610142396756,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin"," fhem.0 2021-01-08 22:46:36.755 debug (9878) [syncStates] update state: fhem.0.myHPSU.HPSU_T_direkter_Heizkreis = 27.9 °C > 26.1 °C fhem.0 2021-01-08 22:46:36.747 debug (9878) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU_Heizung_Ruecklauf 25.7 °C {"val":"25.7 °C","ack":true,"ts":1610142396745,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc" fhem.0 2021-01-08 22:46:36.743 debug (9878) [syncStates] update state: fhem.0.myHPSU.HPSU_Heizung_Ruecklauf = 26.3 °C > 25.7 °C fhem.0 2021-01-08 22:46:36.725 debug (9878) [stateChange] stateChange (in): fhem.0.info.Info.numberObjectsIOBin 191 {"val":191,"ack":true,"ts":1610142396721,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610112665 fhem.0 2021-01-08 22:46:36.723 debug (9878) [syncFunction] (sensor) fhem.0.myHPSU.state_boolean fhem.0 2021-01-08 22:46:36.720 debug (9878) [syncRoom] (HPSU) fhem.0.myHPSU fhem.0 2021-01-08 22:46:36.656 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Fluesterbetrieb_{quiet_mode} (state) - common fhem.0 2021-01-08 22:46:36.649 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Betriebsart_{mode_01} (state) - common fhem.0 2021-01-08 22:46:36.635 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~HK_Funktion_{hc_func} (state) - common fhem.0 2021-01-08 22:46:36.615 debug (9878) [stateChange] stateChange (in): fhem.0.info.Info.numberDevicesFHEMignored 4 {"val":4,"ack":true,"ts":1610142396599,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":16098012 fhem.0 2021-01-08 22:46:36.601 debug (9878) [syncObjects] update object: fhem.0.myHPSU (channel) - native fhem.0 2021-01-08 22:46:36.595 debug (9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] Funktion: sensor für fhem.0.myHPSU.state_boolean fhem.0 2021-01-08 22:46:36.591 debug (9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] check channel fhem.0.myHPSU | name: myHPSU | room: HPSU | role: undefined | fhem.0 2021-01-08 22:46:36.573 info (9878) unhandled event FHEM: ---- | HPSU myHPSU Info.Q: 1.867 kW > no sync - no fhemObjects >> jsonlist2 myHPSU fhem.0 2021-01-08 22:46:36.572 debug (9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 1.867 kW" fhem.0 2021-01-08 22:46:36.553 info (9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.Heizung_Ruecklauf: 25.7 °C > no sync - no fhemObjects >> jsonlist2 myHPSU fhem.0 2021-01-08 22:46:36.552 debug (9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 25.7 °C" fhem.0 2021-01-08 22:46:36.036 info (9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.T_direkter_Heizkreis: 26.1 °C > no sync - no fhemObjects >> jsonlist2 myHPSU fhem.0 2021-01-08 22:46:36.036 debug (9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 26.1 °C" fhem.0 2021-01-08 22:46:34.767 info (9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen > no sync - no fhemObjects >> jsonlist2 myHPSU fhem.0 2021-01-08 22:46:34.766 debug (9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen" fhem.0 2021-01-08 22:46:34.385 debug (9878) [syncStates] end fhem.0 2021-01-08 22:46:34.351 debug (9878) [stateChange] stateChange (in): fhem.0.info.Info.numberObjectsIOBin 191 {"val":191,"ack":true,"ts":1610142394345,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610112665 fhem.0 2021-01-08 22:46:34.348 debug (9878) [syncFunction] (sensor) fhem.0.myHPSU.state_boolean fhem.0 2021-01-08 22:46:34.345 debug (9878) [syncRoom] (HPSU) fhem.0.myHPSU fhem.0 2021-01-08 22:46:34.222 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Fluesterbetrieb_{quiet_mode} (state) - common fhem.0 2021-01-08 22:46:34.212 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Betriebsart_{mode_01} (state) - common fhem.0 2021-01-08 22:46:34.151 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~HK_Funktion_{hc_func} (state) - common fhem.0 2021-01-08 22:46:34.125 debug (9878) [stateChange] stateChange (in): fhem.0.info.Info.numberDevicesFHEMignored 4 {"val":4,"ack":true,"ts":1610142394119,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":16098012 fhem.0 2021-01-08 22:46:34.121 debug (9878) [syncObjects] update object: fhem.0.myHPSU (channel) - native fhem.0 2021-01-08 22:46:34.117 debug (9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] Funktion: sensor für fhem.0.myHPSU.state_boolean fhem.0 2021-01-08 22:46:34.113 debug (9878) [main] [eventFHEM] [processEvent] [parseEvent] [doJsonlist] [checkQueue] [processQueue] [requestMeta] [parseObjects] check channel fhem.0.myHPSU | name: myHPSU | room: HPSU | role: undefined | fhem.0 2021-01-08 22:46:34.096 info (9878) unhandled event FHEM: ---- | HPSU myHPSU HPSU.ehs: 0 kWh > no sync - no fhemObjects >> jsonlist2 myHPSU fhem.0 2021-01-08 22:46:34.095 debug (9878) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh" fhem.0 2021-01-08 22:46:32.242 debug (9878) [syncStates] end fhem.0 2021-01-08 22:46:32.241 debug (9878) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 1.067 kW {"val":"1.067 kW","ack":true,"ts":1610142392239,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610142392239 fhem.0 2021-01-08 22:46:32.238 debug (9878) [syncStates] update state: fhem.0.myHPSU.Info_Q = 2.934 kW > 1.067 kW fhem.0 2021-01-08 22:46:32.215 debug (9878) [syncFunction] (sensor) fhem.0.myHPSU.state_boolean fhem.0 2021-01-08 22:46:32.214 debug (9878) [stateChange] stateChange (in): fhem.0.info.Info.numberObjectsIOBin 191 {"val":191,"ack":true,"ts":1610142392213,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610112665 fhem.0 2021-01-08 22:46:32.212 debug (9878) [syncRoom] (HPSU) fhem.0.myHPSU fhem.0 2021-01-08 22:46:32.165 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Fluesterbetrieb_{quiet_mode} (state) - common fhem.0 2021-01-08 22:46:32.110 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~Betriebsart_{mode_01} (state) - common fhem.0 2021-01-08 22:46:32.095 debug (9878) [syncObjects] update object: fhem.0.myHPSU.HPSUVal~HK_Funktion_{hc_func} (state) - common fhem.0 2021-01-08 22:46:32.080 debug (9878) [stateChange] stateChange (in): fhem.0.info.Info.numberDevicesFHEMignored 4 {"val":4,"ack":true,"ts":1610142392076,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":16098012 fhem.0 2021-01-08 22:46:32.077 debug (9878) [syncObjects] update object: fhem.0.myHPSU (channel) - native -
@andi2055
Jetzt wird es langsam klar
Der Name von einem Reading wird beim Adapter Start von . auf _ geändert.
Kommt eine Wertänderung für dieses Reading wird aber nichts geändert.
Deshalb das jsonlist2 für alle Readings
Bisher noch nie von Readings mit . gehört. Kennt jemand noch Readings mit . im Name?
Egal kann ich am WE noch einbauen....
Gruß LausiD -
@LausiD
So, getestet!
Aktualisierung der Werte in ioBroker sehr sporadisch wie es sein soll.Aber die Datenpunkte haben sich wieder im Namen geändert, da bekomme ich immer einen Anfall, da da viel dranhängt wie VIS, Javascript, History, etc.
Ist immer ein Mega-Aufwand das wieder geradezubügeln. -
@LausiD
Bin gerade am Ändern.
Bitte so lassen wenn es ok für alle ist. -
@LausiD
funktioniert bei mir auch perfekt.
Danke dir!Anbei 1 Min Debug Log. Sieht aber denke ich gut aus.
2021-01-09 21:27:00.100 - debug: shuttercontrol.0 (2454) outsidetemperature changed: 0_userdata.0.Außen.Temperatur.Mean_15 Value: 0.7 2021-01-09 21:27:02.062 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen" 2021-01-09 21:27:02.063 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen 2021-01-09 21:27:04.249 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh" 2021-01-09 21:27:04.249 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh 2021-01-09 21:27:04.507 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1123 lh" 2021-01-09 21:27:04.508 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1123 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1123 lh 2021-01-09 21:27:05.220 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %" 2021-01-09 21:27:05.221 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 % 2021-01-09 21:27:05.478 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %" 2021-01-09 21:27:05.479 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 % 2021-01-09 21:27:06.604 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C" 2021-01-09 21:27:06.605 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C 2021-01-09 21:27:06.611 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C {"val":"29.3 °C","ack":true,"ts":1610224026607,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224026607} 2021-01-09 21:27:06.911 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.2 °C" 2021-01-09 21:27:06.912 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.2 °C 2021-01-09 21:27:07.513 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Wartezeit_BOH: 80 min" 2021-01-09 21:27:07.513 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Wartezeit_BOH: 80 min | reading > fhem.0.myHPSU.HPSU~Wartezeit_BOH 80 min 2021-01-09 21:27:08.020 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %" 2021-01-09 21:27:08.021 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 % 2021-01-09 21:27:08.782 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen" 2021-01-09 21:27:08.782 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen 2021-01-09 21:27:10.360 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 25.6 °C" 2021-01-09 21:27:10.362 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 25.6 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 25.6 °C 2021-01-09 21:27:10.367 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 25.6 °C {"val":"25.6 °C","ack":true,"ts":1610224030364,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224030364} 2021-01-09 21:27:10.389 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.705 kW" 2021-01-09 21:27:10.391 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.705 kW | reading > fhem.0.myHPSU.Info_Q 4.705 kW 2021-01-09 21:27:10.395 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.705 kW {"val":"4.705 kW","ack":true,"ts":1610224030392,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224030392} 2021-01-09 21:27:10.823 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C" 2021-01-09 21:27:10.824 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26 °C 2021-01-09 21:27:11.077 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C" 2021-01-09 21:27:11.078 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C 2021-01-09 21:27:11.081 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C {"val":"25.7 °C","ack":true,"ts":1610224031079,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224031079} 2021-01-09 21:27:11.331 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.TVBH: 29.3 °C" 2021-01-09 21:27:11.331 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.TVBH: 29.3 °C | reading > fhem.0.myHPSU.HPSU~TVBH 29.3 °C 2021-01-09 21:27:11.794 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh" 2021-01-09 21:27:11.795 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh 2021-01-09 21:27:14.902 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen" 2021-01-09 21:27:14.903 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen 2021-01-09 21:27:16.233 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_T_direkter_Heizkreis: 29.2 °C" 2021-01-09 21:27:16.234 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_T_direkter_Heizkreis: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Soll_T_direkter_Heizkreis 29.2 °C 2021-01-09 21:27:16.540 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_Vorlauftemperatur_Waermeerzeuger: 29.2 °C" 2021-01-09 21:27:16.541 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_Vorlauftemperatur_Waermeerzeuger: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Soll_Vorlauftemperatur_Waermeerzeuger 29.2 °C 2021-01-09 21:27:17.494 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh" 2021-01-09 21:27:17.495 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh 2021-01-09 21:27:17.748 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1146 lh" 2021-01-09 21:27:17.749 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1146 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1146 lh 2021-01-09 21:27:17.753 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Durchfluss 1146 lh {"val":"1146 lh","ack":true,"ts":1610224037751,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224037751} 2021-01-09 21:27:17.775 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.802 kW" 2021-01-09 21:27:17.776 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.802 kW | reading > fhem.0.myHPSU.Info_Q 4.802 kW 2021-01-09 21:27:17.781 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.802 kW {"val":"4.802 kW","ack":true,"ts":1610224037778,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224037778} 2021-01-09 21:27:18.411 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Betriebsart: Heizen" 2021-01-09 21:27:18.412 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Betriebsart Heizen 2021-01-09 21:27:18.665 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %" 2021-01-09 21:27:18.666 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 % 2021-01-09 21:27:18.940 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %" 2021-01-09 21:27:18.940 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 % 2021-01-09 21:27:19.732 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_Warmwasser: 43.4 °C" 2021-01-09 21:27:19.734 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_Warmwasser: 43.4 °C | reading > fhem.0.myHPSU.HPSU~T_Warmwasser 43.4 °C 2021-01-09 21:27:19.741 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_Warmwasser 43.4 °C {"val":"43.4 °C","ack":true,"ts":1610224039737,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224039737} 2021-01-09 21:27:20.256 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C" 2021-01-09 21:27:20.257 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C 2021-01-09 21:27:20.559 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.2 °C" 2021-01-09 21:27:20.562 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.2 °C 2021-01-09 21:27:20.907 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_Aussen: -0.2 °C" 2021-01-09 21:27:20.908 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_Aussen: -0.2 °C | reading > fhem.0.myHPSU.HPSU~T_Aussen -0.2 °C 2021-01-09 21:27:20.912 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_Aussen -0.2 °C {"val":"-0.2 °C","ack":true,"ts":1610224040909,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224040909} 2021-01-09 21:27:21.160 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.2 °C" 2021-01-09 21:27:21.161 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.2 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.2 °C 2021-01-09 21:27:21.169 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.2 °C {"val":"26.2 °C","ack":true,"ts":1610224041167,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224041167} 2021-01-09 21:27:21.189 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.001 kW" 2021-01-09 21:27:21.190 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.001 kW | reading > fhem.0.myHPSU.Info_Q 4.001 kW 2021-01-09 21:27:21.195 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.001 kW {"val":"4.001 kW","ack":true,"ts":1610224041192,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224041192} 2021-01-09 21:27:21.621 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 25.9 °C" 2021-01-09 21:27:21.622 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 25.9 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 25.9 °C 2021-01-09 21:27:21.626 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 25.9 °C {"val":"25.9 °C","ack":true,"ts":1610224041623,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224041623} 2021-01-09 21:27:21.874 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C" 2021-01-09 21:27:21.875 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C 2021-01-09 21:27:22.287 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %" 2021-01-09 21:27:22.288 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 % 2021-01-09 21:27:23.048 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen" 2021-01-09 21:27:23.049 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen 2021-01-09 21:27:23.967 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active" 2021-01-09 21:27:23.968 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active | reading > fhem.0.myHPSU.HPSU~Direkter_Heizkreis_Modus active 2021-01-09 21:27:24.884 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_T_Raum_1: 21 °C" 2021-01-09 21:27:24.885 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_T_Raum_1: 21 °C | reading > fhem.0.myHPSU.HPSU~Soll_T_Raum_1 21 °C 2021-01-09 21:27:25.142 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_Aussen_WP: -0.2 °C" 2021-01-09 21:27:25.143 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_Aussen_WP: -0.2 °C | reading > fhem.0.myHPSU.HPSU~T_Aussen_WP -0.2 °C 2021-01-09 21:27:25.147 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_Aussen_WP -0.2 °C {"val":"-0.2 °C","ack":true,"ts":1610224045145,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224045145} 2021-01-09 21:27:25.854 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh" 2021-01-09 21:27:25.854 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh 2021-01-09 21:27:28.545 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1168 lh" 2021-01-09 21:27:28.546 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1168 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1168 lh 2021-01-09 21:27:28.548 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Durchfluss 1168 lh {"val":"1168 lh","ack":true,"ts":1610224048546,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224048546} 2021-01-09 21:27:28.573 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.078 kW" 2021-01-09 21:27:28.573 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.078 kW | reading > fhem.0.myHPSU.Info_Q 4.078 kW 2021-01-09 21:27:28.579 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.078 kW {"val":"4.078 kW","ack":true,"ts":1610224048574,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224048574} 2021-01-09 21:27:29.157 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen" 2021-01-09 21:27:29.158 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen 2021-01-09 21:27:29.464 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %" 2021-01-09 21:27:29.465 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 % 2021-01-09 21:27:29.721 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %" 2021-01-09 21:27:29.722 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 % 2021-01-09 21:27:30.849 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C" 2021-01-09 21:27:30.850 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C 2021-01-09 21:27:31.216 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.3 °C" 2021-01-09 21:27:31.218 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.3 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.3 °C 2021-01-09 21:27:31.224 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.214 kW" 2021-01-09 21:27:31.225 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.214 kW | reading > fhem.0.myHPSU.Info_Q 4.214 kW 2021-01-09 21:27:31.228 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.3 °C {"val":"29.3 °C","ack":true,"ts":1610224051219,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224051219} 2021-01-09 21:27:31.230 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.214 kW {"val":"4.214 kW","ack":true,"ts":1610224051226,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224051226} 2021-01-09 21:27:31.605 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.1 °C" 2021-01-09 21:27:31.606 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.1 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.1 °C 2021-01-09 21:27:31.611 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.1 °C {"val":"26.1 °C","ack":true,"ts":1610224051607,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224051607} 2021-01-09 21:27:31.630 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.350 kW" 2021-01-09 21:27:31.631 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.350 kW | reading > fhem.0.myHPSU.Info_Q 4.350 kW 2021-01-09 21:27:31.633 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.350 kW {"val":"4.350 kW","ack":true,"ts":1610224051632,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224051632} 2021-01-09 21:27:32.061 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C" 2021-01-09 21:27:32.062 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26 °C 2021-01-09 21:27:32.066 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26 °C {"val":"26 °C","ack":true,"ts":1610224052064,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224052064} 2021-01-09 21:27:32.319 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C" 2021-01-09 21:27:32.319 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C 2021-01-09 21:27:32.724 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %" 2021-01-09 21:27:32.725 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 % 2021-01-09 21:27:33.031 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh" 2021-01-09 21:27:33.032 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh 2021-01-09 21:27:36.136 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen" 2021-01-09 21:27:36.137 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen 2021-01-09 21:27:38.330 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh" 2021-01-09 21:27:38.330 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh 2021-01-09 21:27:41.021 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1146 lh" 2021-01-09 21:27:41.022 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1146 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1146 lh 2021-01-09 21:27:41.024 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Durchfluss 1146 lh {"val":"1146 lh","ack":true,"ts":1610224061023,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224061023} 2021-01-09 21:27:41.049 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.268 kW" 2021-01-09 21:27:41.050 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.268 kW | reading > fhem.0.myHPSU.Info_Q 4.268 kW 2021-01-09 21:27:41.053 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.268 kW {"val":"4.268 kW","ack":true,"ts":1610224061051,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224061051} 2021-01-09 21:27:41.631 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen" 2021-01-09 21:27:41.632 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen 2021-01-09 21:27:41.935 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %" 2021-01-09 21:27:41.936 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 % 2021-01-09 21:27:42.192 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %" 2021-01-09 21:27:42.193 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 % 2021-01-09 21:27:43.319 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.2 °C" 2021-01-09 21:27:43.320 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.2 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.2 °C 2021-01-09 21:27:43.323 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.2 °C {"val":"29.2 °C","ack":true,"ts":1610224063321,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224063321} 2021-01-09 21:27:43.626 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.3 °C" 2021-01-09 21:27:43.627 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.3 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.3 °C 2021-01-09 21:27:44.020 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.1 °C" 2021-01-09 21:27:44.021 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.1 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.1 °C 2021-01-09 21:27:44.480 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C" 2021-01-09 21:27:44.480 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26 °C 2021-01-09 21:27:44.744 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C" 2021-01-09 21:27:44.747 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C 2021-01-09 21:27:44.990 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.TVBH: 29.2 °C" 2021-01-09 21:27:44.991 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.TVBH: 29.2 °C | reading > fhem.0.myHPSU.HPSU~TVBH 29.2 °C 2021-01-09 21:27:44.996 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~TVBH 29.2 °C {"val":"29.2 °C","ack":true,"ts":1610224064993,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224064993} 2021-01-09 21:27:45.346 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %" 2021-01-09 21:27:45.347 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 % 2021-01-09 21:27:45.651 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh" 2021-01-09 21:27:45.651 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh 2021-01-09 21:27:47.448 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_T_direkter_Heizkreis: 29.2 °C" 2021-01-09 21:27:47.448 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_T_direkter_Heizkreis: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Soll_T_direkter_Heizkreis 29.2 °C 2021-01-09 21:27:47.755 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_Vorlauftemperatur_Waermeerzeuger: 29.2 °C" 2021-01-09 21:27:47.755 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_Vorlauftemperatur_Waermeerzeuger: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Soll_Vorlauftemperatur_Waermeerzeuger 29.2 °C 2021-01-09 21:27:49.169 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen" 2021-01-09 21:27:49.170 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen 2021-01-09 21:27:49.918 - debug: fhem.0 (16732) [setAlive] start setAlive 300 sec 2021-01-09 21:27:49.923 - info: fhem.0 (16732) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360 2021-01-09 21:27:49.933 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "dummy fhem.0.alive on" 2021-01-09 21:27:49.933 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive true - start 2021-01-09 21:27:49.936 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive reset timer 2021-01-09 21:27:49.937 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610224069920,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069920} 2021-01-09 21:27:49.954 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Commands.resultFHEM {"val":"","ack":true,"ts":1610224069941,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069941} 2021-01-09 21:27:49.955 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Info.alive true {"val":true,"ack":true,"ts":1610224069942,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610223769942} 2021-01-09 21:27:49.955 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Debug.numberIn 144 {"val":144,"ack":true,"ts":1610224069942,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069942} 2021-01-09 21:27:49.960 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Debug.timeIn 5 {"val":5,"ack":true,"ts":1610224069943,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069943} 2021-01-09 21:27:49.961 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Debug.numberOut 0 {"val":0,"ack":true,"ts":1610224069944,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610131742427} 2021-01-09 21:27:49.962 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Debug.timeOut null {"val":null,"ack":true,"ts":1610224069944,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069944} 2021-01-09 21:27:49.967 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Commands.lastCommand set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610224069951,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069951} 2021-01-09 21:27:49.969 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM done {"val":"done","ack":true,"ts":1610224069957,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069957} 2021-01-09 21:27:51.359 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh" 2021-01-09 21:27:51.360 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh 2021-01-09 21:27:51.613 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1146 lh" 2021-01-09 21:27:51.614 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1146 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1146 lh 2021-01-09 21:27:52.328 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %" 2021-01-09 21:27:52.331 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 % 2021-01-09 21:27:52.581 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %" 2021-01-09 21:27:52.582 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 % 2021-01-09 21:27:53.450 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_T_Warmwasser: 46 °C" 2021-01-09 21:27:53.450 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_T_Warmwasser: 46 °C | reading > fhem.0.myHPSU.HPSU~Soll_T_Warmwasser 46 °C 2021-01-09 21:27:53.920 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C" 2021-01-09 21:27:53.921 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C 2021-01-09 21:27:53.924 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C {"val":"29.3 °C","ack":true,"ts":1610224073922,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224073922} 2021-01-09 21:27:54.223 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.4 °C" 2021-01-09 21:27:54.225 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.4 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.4 °C 2021-01-09 21:27:54.229 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.4 °C {"val":"29.4 °C","ack":true,"ts":1610224074227,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224074227} 2021-01-09 21:27:54.243 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.402 kW" 2021-01-09 21:27:54.244 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.402 kW | reading > fhem.0.myHPSU.Info_Q 4.402 kW 2021-01-09 21:27:54.248 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.402 kW {"val":"4.402 kW","ack":true,"ts":1610224074245,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224074245} 2021-01-09 21:27:54.624 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 26 °C" 2021-01-09 21:27:54.625 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 26 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26 °C 2021-01-09 21:27:54.629 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26 °C {"val":"26 °C","ack":true,"ts":1610224074627,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224074627} 2021-01-09 21:27:54.652 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.535 kW" 2021-01-09 21:27:54.653 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.535 kW | reading > fhem.0.myHPSU.Info_Q 4.535 kW 2021-01-09 21:27:54.657 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.535 kW {"val":"4.535 kW","ack":true,"ts":1610224074655,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224074655} 2021-01-09 21:27:55.083 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26.1 °C" 2021-01-09 21:27:55.084 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26.1 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26.1 °C 2021-01-09 21:27:55.087 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26.1 °C {"val":"26.1 °C","ack":true,"ts":1610224075085,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224075085} 2021-01-09 21:27:55.341 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C" 2021-01-09 21:27:55.342 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C 2021-01-09 21:27:55.747 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %" 2021-01-09 21:27:55.747 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 % 2021-01-09 21:27:56.513 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen" 2021-01-09 21:27:56.514 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen 2021-01-09 21:27:57.430 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active" 2021-01-09 21:27:57.431 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active | reading > fhem.0.myHPSU.HPSU~Direkter_Heizkreis_Modus activeSo sieht's aus
@andi2055 Ich bräuchte mal noch eure Hilfe. Soweit läuft der Adapter Top, ich bräuchte hier noch die Buttons in ioBroker, damit ich die Rollos zum fahren forcen kann, auch wenn das Rollo Device sagt der Rollo sei unten. Hier kann ich dennoch drücken und er fährt, falls er noch oben ist. Aber ich habe hier keine attr die ich adden könnte.
Fällt euch dazu was ein, wie ich das dennoch über ioB steuern kann, bräuchte das für die VIS ?
@d3ltoroxp
Mh wenn du den Befehl dafür kennst, kannst du zB im ioB über fhem.0.info.Commands.sendFHEM den Befehl eingeben.Gruß LausiD
seit ein paar Tagen habe ich beim HPSU Modul das Problem, dass sehr häufig in den Datenpunkten in ioBRoker statt dem eigentlichen Wert ganz kurz ein Punkt drin steht. Bei den anderen FHEM Modlen konnte ich das nicht beobachten.
Habt ihr das Problem auch?
@banis
Es gab ein Update beim FHEM HPSU Modul mit größeren Anpassungen.
Ich teste das auch gerade.
Kannst du überhaupt noch Werte verändern aus ioB heraus? Bspw. Heizkurve
Der Punkt stand in früheren Versionen bei mir in alles States, die zum Setzen der Werte vorhanden waren. Nun gibt es diese bei mir nicht mehr. Das wurde anscheinend zusammengelegt? -
@andi2055 Ich bin zwischenzeitlich wieder zurück auf die Modul Version 1.10
Ich konnt aber mit der 1.11 auch Werte schreiben. Bin mir jetzt aber nicht mehr ganz sicher wie ich das gemacht hab, ich glaube das ging in den Datenpunkten wo auch die Werte gelesen werden. Musst dort mal ausprobieren ob du dort auch schreiben kannst.Dadurch dass immer wieder ein . im Datenpunkt war, wurden meine Logs ziemlich voll. Dadurch hat sich dann mein history Adapter immer mal wieder verabschiedet. Deshalb bin ich beim HPSU Modul eine Version zurück gegangen
@andi2055
Kannst du mal von der neuen Version ein jsonlist2 aus FHEM oder RAW aus ioBroker zeigen? -
@lausid
anbei jsonlist2 der neuen FHEM HPSU Adapter Version 1.11Ich habe mich nun nochmal etwas damit beschäftigt:
Alle schreibbaren Werte waren bei mir nach dem Update nicht schreibbar. Das war mein Hauptproblem.
HPSU~Heizkurve (als Beispiel) stand bei mir nach dem Update auf Readonly. Wäre das bei Neuanlage (Instanz löschen und neu erstellen) auch schreibbar gewesen und wird nur nicht automatisch angepasst?
Ich habe alle schreibbaren Werte manuell auf WRITE gestellt und nun kann ich damit Werte auch setzen.
Funktioniert also grundsätzlich bei mir.Alle Werte, die nicht in Readings enthalten sind (Beispiel: HPSU~HZ_Unterstuetzung), enthalten bei mir einen ".". Ich kann die Werte ON/OFF aber auswählen und setzen. Soweit aus meiner Sicht ok.
@Banis dein Problem kann ich so nicht bestätigen. Das musst du bitte nochmal genauer erklären
{ "Name":"myHPSU", "PossibleSets":"Disconnect:noArg Connect:noArg ForceDHW:noArg Connect_MonitorMode:noArg HPSU.Kuehl_Soll_Korr_Parallel:slider,-5,0.1,5,1 HPSU.Spreizung_Mod_HZ:slider,2,1,20 HPSU.WW_Sperrzeit:slider,0,1,240 HPSU.Bivalenzfunktion:off,on HPSU.Funktion_EHS:slider,0,1,3 HPSU.HK_Funktion:Witterung,Fest HPSU.Heizkurve:slider,0,0.1,3,1 HPSU.HZ_Unterstuetzung:off,on HPSU.Max_WW_Ladezeit:slider,0,1,240 HPSU.Max_Leistung_Pumpe:slider,20,1,100 HPSU.Max_T_Vorlauf:slider,20,1,90 HPSU.Kuehlen_A_Temp_Max:slider,20,1,45 HPSU.Min_Leistung_Pumpe:slider,10,1,100 HPSU.Min_T_Vorlauf:slider,18,1,90 HPSU.Kuehlen_VL_Soll_Abs_Min:slider,5,1,25 HPSU.Betriebsart:Bereitschaft,Auto1,Auto2,Kuehlen,Heizen,Absenken,Sommer HPSU.Fluesterbetrieb:Aus,Ein,Nur_bei_Nacht HPSU.Kuehlen_A_Temp_Start:slider,15,1,45 HPSU.Schaltschwelle_AUX_TDHW:slider,20,1,85 HPSU.Soll_T_Warmwasser_1:slider,35,1,70 HPSU.Soll_T_Warmwasser_2:slider,35,1,70 HPSU.Soll_T_Warmwasser_3:slider,35,1,70 HPSU.Kuehlen_VL_Soll_Max:slider,5,1,25 HPSU.Kuehlen_VL_Soll_Start:slider,5,1,25 HPSU.T_Vorlauf_Tag:slider,20,1,90 HPSU.T_Vorlauf_Nacht:slider,20,1,90 HPSU.T_Frostschutz:-1,-10,-11,-12,-13,-14,-15,Aus,-2,-3,-4,-5,-6,-7,-8,-9,0,1,2,3,4,5 HPSU.Heizgrenze_Tag:slider,10,1,40 HPSU.Heizgrenze_Nacht:slider,10,1,40 HPSU.Soll_T_Raum_1:slider,5,0.5,40,1 HPSU.Soll_T_Raum_2:slider,5,0.5,40,1 HPSU.Soll_T_Raum_3:slider,5,0.5,40,1 HPSU.TDiff_WW_HZU:slider,2,1,15 HPSU.Wartezeit_BOH:slider,20,1,95 ", "PossibleAttrs":"alias comment:textField-long eventMap:textField-long group room suppressReading userReadings:textField-long verbose:0,1,2,3,4,5 AutoPoll:on,off AntiMixerSwing:on,off CheckDHWInterrupted:on,off DebugLog:on,onWithMsg,onDHW,off AntiContinousHeating:on,off RememberSetValues:on,off SuppressRetryWarnings:on,off event-aggregator event-min-interval event-on-change-reading event-on-update-reading oldreadings stateFormat:textField-long timestamp-on-change-reading cmdIcon devStateIcon:textField-long devStateStyle icon sortby webCmd webCmdLabel:textField-long widgetOverride userattr", "Internals": { "DEF": "/dev/ttyUSB0", "DeviceName": "/dev/ttyUSB0@38400", "ELM327_Version": "1.5", "ELMState": "Initialized", "FD": "8", "FUUID": "5ff83ab7-f33f-256f-ffb1-ea0f07c2844b852e", "JSON_Auto_poll": "47", "JSON_Writable": "100", "JSON_parameters": "156", "JSON_version": "3.6", "Module_Version": "1.11", "NAME": "myHPSU", "NR": "21", "PARTIAL": "", "STATE": "opened", "TYPE": "HPSU" }, "Readings": { "Comm.GetStatus": { "Value":"Ok", "Time":"2021-01-23 22:54:03" }, "Comm.ManStatus": { "Value":"Ok: (force) DHW still active (717)", "Time":"2021-01-19 11:04:07" }, "Comm.SetStatus": { "Value":"Ok: Heizkurve [heat_slope] successfully set to 0.4 (1011)", "Time":"2021-01-23 22:35:59" }, "HPSU.Aktive_Betriebsart": { "Value":"Standby", "Time":"2021-01-23 22:53:56" }, "HPSU.Betriebsart": { "Value":"Heizen", "Time":"2021-01-23 22:53:56" }, "HPSU.Direkter_Heizkreis_Modus": { "Value":"power-saving", "Time":"2021-01-23 22:53:57" }, "HPSU.Durchfluss": { "Value":"0 lh", "Time":"2021-01-23 22:53:52" }, "HPSU.EHS_fuer_Heizung": { "Value":"2245 kWh", "Time":"2021-01-23 22:49:35" }, "HPSU.EHS_fuer_WW": { "Value":"706 kWh", "Time":"2021-01-23 22:49:34" }, "HPSU.Energie_Heizung": { "Value":"4366 kWh", "Time":"2021-01-23 22:49:35" }, "HPSU.Energie_Kuehlung": { "Value":"1803 kWh", "Time":"2021-01-23 22:49:39" }, "HPSU.Energie_WW": { "Value":"6949 kWh", "Time":"2021-01-23 22:49:35" }, "HPSU.Energie_erzeugt_gesamt": { "Value":"12386 kWh", "Time":"2021-01-23 22:49:39" }, "HPSU.Fluesterbetrieb": { "Value":"Aus", "Time":"2021-01-23 22:45:35" }, "HPSU.Funktion_EHS": { "Value":"1", "Time":"2021-01-23 22:45:25" }, "HPSU.HK_Funktion": { "Value":"Witterung", "Time":"2021-01-23 22:45:25" }, "HPSU.Heizgrenze_Tag": { "Value":"21 °C", "Time":"2021-01-23 22:46:57" }, "HPSU.Heizkurve": { "Value":"0.4", "Time":"2021-01-23 22:46:01" }, "HPSU.Heizung_Ruecklauf": { "Value":"25.6 °C", "Time":"2021-01-23 22:53:55" }, "HPSU.Kaeltemitteltemperatur": { "Value":"25.1 °C", "Time":"2021-01-23 22:53:51" }, "HPSU.Kuehl_Soll_Korr_Parallel": { "Value":"0 °C", "Time":"2021-01-23 22:45:34" }, "HPSU.Kuehlen_A_Temp_Max": { "Value":"35 °C", "Time":"2021-01-23 22:45:26" }, "HPSU.Kuehlen_A_Temp_Start": { "Value":"22 °C", "Time":"2021-01-23 22:45:36" }, "HPSU.Kuehlen_VL_Soll_Abs_Min": { "Value":"16 °C", "Time":"2021-01-23 22:45:26" }, "HPSU.Kuehlen_VL_Soll_Max": { "Value":"10 °C", "Time":"2021-01-23 22:45:36" }, "HPSU.Kuehlen_VL_Soll_Start": { "Value":"18 °C", "Time":"2021-01-23 22:45:40" }, "HPSU.Laufzeit_Kompressor": { "Value":"7130 h", "Time":"2021-01-23 22:49:40" }, "HPSU.Laufzeit_UWPumpe": { "Value":"12397 h", "Time":"2021-01-23 22:49:40" }, "HPSU.Max_T_Vorlauf": { "Value":"45 °C", "Time":"2021-01-23 22:45:26" }, "HPSU.Min_T_Vorlauf": { "Value":"27 °C", "Time":"2021-01-23 22:45:26" }, "HPSU.Pos_Vent_3UVB1": { "Value":"100 %", "Time":"2021-01-23 22:53:52" }, "HPSU.Pos_Vent_3UV_DHW": { "Value":"0 %", "Time":"2021-01-23 22:54:03" }, "HPSU.Ruecklauftemperatur": { "Value":"24.6 °C", "Time":"2021-01-23 22:53:52" }, "HPSU.Soll_T_Raum_1": { "Value":"20.5 °C", "Time":"2021-01-23 22:53:36" }, "HPSU.Soll_T_Warmwasser": { "Value":"46 °C", "Time":"2021-01-23 22:53:23" }, "HPSU.Soll_T_Warmwasser_1": { "Value":"46 °C", "Time":"2021-01-14 07:53:11" }, "HPSU.Soll_T_direkter_Heizkreis": { "Value":"27.1 °C", "Time":"2021-01-23 22:53:51" }, "HPSU.Soll_Vorlauftemperatur_Waermeerzeuger": { "Value":"0 °C", "Time":"2021-01-23 22:53:39" }, "HPSU.TDiff_WW_HZU": { "Value":"5 °C", "Time":"2021-01-23 22:45:29" }, "HPSU.TVBH": { "Value":"37.8 °C", "Time":"2021-01-23 22:53:33" }, "HPSU.T_Aussen": { "Value":"4.5 °C", "Time":"2021-01-23 22:53:33" }, "HPSU.T_Aussen_WP": { "Value":"4.5 °C", "Time":"2021-01-23 22:53:36" }, "HPSU.T_Aussen_gemittelt": { "Value":"4.7 °C", "Time":"2021-01-23 22:52:21" }, "HPSU.T_Frostschutz": { "Value":"-10", "Time":"2021-01-23 22:53:54" }, "HPSU.T_Warmwasser": { "Value":"46.4 °C", "Time":"2021-01-23 22:53:57" }, "HPSU.T_direkter_Heizkreis": { "Value":"37.4 °C", "Time":"2021-01-23 22:53:54" }, "HPSU.UWPumpe": { "Value":"0 %", "Time":"2021-01-23 22:54:04" }, "HPSU.Vorlauftemperatur_Waermeerzeuger": { "Value":"30.8 °C", "Time":"2021-01-23 22:53:54" }, "HPSU.Wartezeit_BOH": { "Value":"80 min", "Time":"2021-01-23 22:52:37" }, "HPSU.Wasserdruck": { "Value":"1.566 bar", "Time":"2021-01-23 22:45:33" }, "HPSU.ehs": { "Value":"0 kWh", "Time":"2021-01-23 22:53:56" }, "Info.HeatCyclicErr": { "Value":"0", "Time":"2021-01-23 20:50:15" }, "Info.LastDefrostDHWShrink": { "Value":"0.599999999999994 °C", "Time":"2021-01-23 19:57:26" }, "Info.Q": { "Value":"0 kW", "Time":"2021-01-23 20:50:15" }, "state": { "Value":"opened", "Time":"2021-01-21 23:25:40" } }, "Attributes": { "AntiContinousHeating": "on", "AntiMixerSwing": "off", "AutoPoll": "on", "CheckDHWInterrupted": "on", "DebugLog": "on", "SuppressRetryWarnings": "on", "alias": "myHPSU", "room": "HPSU" } }, -
@andi2055
Auf was steht fhem.0.info.Configurations.autoRole bei dir?
Du kannst auch ein einzelnes Objekt löschen..zB HPSU~Heizkurve.....Adapter neu starten und Objekt wird wieder angelegt.
Instanz löschen und neuanlegen ist nie nötig!Gruß LausiD
@lausid
steht auf true.
An der Stelle habe ich auch noch nie was geändert
Aber Danke, ich weiß jetzt wie es geht
@andi2055 Ich hab eben nochmal auf die 1.11 upgedatet. Ist bei mir leider immer noch so. Es scheint so, also ob immer wenn vom FHEM Modul Werte an ioBroker übertragen werden, bei vielen Readings immer kurz ein Punkt gesetzt wird.
Dadurch habe ich permanet Zustandsänderungen, was die Performance des History-Adapters sehr verschlechtert.
Ich hab als Beispeil mal die Werte der Betriebsart in einem Zeitraum von knapp 2 Minuten dargestellt.
@banis
Hast du den FHEM Adapter über github aktualisiert?
Deine Beschreibung hört sich stark nach dem Problem in 1.5.3 an.Gruß LausiD
@lausid Hab jetzt nochmal über github aktualisiert. Aber eine neuere Version als die 1.5.3 bekomme ich nicht. Oder mache ich was falsch?
