    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    • Glasfaser
      Glasfaser last edited by
      @wszene said in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
      Ich bekomme jetzt verdammt viele Telegrams
      Nimm das :
       <variables>
         <variable id="$ZBG[fEIeDUoMc{ekk0/">sperre</variable>
       </variables>
       <block type="variables_set" id="@r$S6|53Lf^0!A`830mY" x="38" y="38">
         <field name="VAR" id="$ZBG[fEIeDUoMc{ekk0/">sperre</field>
           <block type="logic_boolean" id="A(URtf8zPanx0N_tk}FI">
           <block type="on" id="}ZWON=|p^MkmJ,t;Ap!s">
             <field name="OID">0_userdata.0.1</field>
               <block type="controls_if" id="w=%`ceyfS!J-,|8wzey=">
                   <block type="logic_operation" id="pY@4UwU%iWFRrT5*]o7G">
                     <field name="OP">AND</field>
                       <block type="logic_compare" id="GT{^i}l+r*[@AC~phuua">
                         <field name="OP">GTE</field>
                           <block type="on_source" id="2i}B._Ao**P{xtuc)0RI">
                           <block type="math_number" id="8qi:NO(LFv@}rT%@j5%}">
                             <field name="NUM">1</field>
                       <block type="logic_compare" id="E-jEsb@oM@h7Z^xhuIMi">
                         <field name="OP">EQ</field>
                           <block type="variables_get" id="n3ZbxZpr~uaaW]Gubt.W">
                           <block type="logic_boolean" id="zf)OZe*6~Oqnj^whmW;B">
                   <block type="variables_set" id="8oR4HfM?9T{va4@4QKDS">
                       <block type="logic_boolean" id="oW9;zQH2T2:[#m]T[kVa">
                       <block type="telegram" id="|){3Af,jNedzEwOJHER+">
                         <field name="INSTANCE">.4</field>
                         <field name="LOG"></field>
                         <value name="MESSAGE">
                           <shadow type="text" id="KKV2~AWrAtL]kgg*o(?$">
                             <field name="TEXT">an</field>
                 <value name="IF1">
                   <block type="logic_operation" id=":)HRy=h%s-pB=GQDdA{B">
                       <block type="logic_compare" id="*2=1[f8*{)J%mxg3Pzb|">
                         <field name="OP">LT</field>
                           <block type="on_source" id="RQ_auc-o-ZPNHl60k]^Y">
                           <block type="math_number" id="6VM?nZ8jDgdtX~V@tBp=">
                       <block type="logic_compare" id="x0)Cj$@EHlj7w*(6h1mF">
                           <block type="variables_get" id="cp{E)9ngNElflcok06V!">
                           <block type="logic_boolean" id=".P_eTp,k:VASHWHwX@!l">
                 <statement name="DO1">
                   <block type="variables_set" id="^9pP@/8Ws!Mpds3oa.Og">
                       <block type="logic_boolean" id="Xrq9Ph8Q}S]]q_v54}4]">
                       <block type="telegram" id="`vI[nCh/lt{IX4p/fIYg">
                           <shadow type="text" id="~fM,TqT#){`|eAhf+Iwk">
                             <field name="TEXT">aus</field>
      Wszene 1 Reply Last reply Reply Quote 0
      • Wszene
        Wszene @Glasfaser last edited by
        @glasfaser
        Danke dir das sieht gut aus aber ich habe da mal noch eine Frage
        Was ist Sperre?
        Muss ich da noch etwas anlegen?
        • Glasfaser
          Glasfaser @Wszene last edited by
          @wszene
          Es wird eine Variable genutzt , Sie wird beim Triggern deines Datenpunktes bei true (Telegram Heizung an) einmalig gesetzt .
          Bei dem wiederholten triggern was bei dir ist ,wird halt die Funktion nicht mehr ausgeführt (Telegram senden Heizung an) , da die Variable auf false gesetzt ist ......
          du kannst es so importieren , es wird alles automatisch angelegt .
            Datensammler @tombox last edited by
            @tombox
            vielen Dank für die Integration des SEAT-Portals!
            Ich habe den Adapter von guthub installiert, Version 0.0.23
            Funktioniert auch prinzipiell (für SEAT Mii electric) aber ich bekomme nach einger Zeit folgende Fehler:
            vw-connect.1	2021-01-15 10:10:10.095	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.brand:{"val":"Seat","ack":true,"ts":1610701810074,"q":0,"from":"system.adapter.vw-connect.1","user":"system.use
            vw-connect.1	2021-01-15 10:10:10.089	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.requestId:{"val":"MSG-IVWB2193-1610701808811-71805-SES","ack":true,"ts":1610701810071,"q":0,"from":"system.adap
            vw-connect.1	2021-01-15 10:10:10.078	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.systemId:{"val":"XID_APP_SEAT","ack":true,"ts":1610701810069,"q":0,"from":"system.adapter.vw-connect.1","user":
            vw-connect.1	2021-01-15 10:10:10.050	debug	(24236) {"vehicleDataDetail":{"systemId":"XID_APP_SEAT","requestId":"MSG-IVWB2193-1610701808811-71805-SES","brand":"Seat","country":"DE","vin":"XXXXXXXXXXXXXXXXXX","isConnect":true,"isConnectSorglosRea
            vw-connect.1	2021-01-15 10:10:09.565	error	(24236) status update Failed
            vw-connect.1	2021-01-15 10:10:09.564	error	(24236) 429
            vw-connect.1	2021-01-15 10:10:08.945	debug	(24236) {"homeRegion":{"baseUri":{"systemId":"ICTO-10487","content":"https://mal-1a.prd.ece.vwg-connect.com/api"}}}
            vw-connect.1	2021-01-15 10:10:08.892	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.preferredLanguage:{"val":"de","ack":true,"ts":1610701808428,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin
            vw-connect.1	2021-01-15 10:10:08.889	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.phoneNumbers:{"val":[{"uuid":"xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx","type":"PHONE_CONTACT_TYPE:MOBILE_GENERAL","number":"+000000
            vw-connect.1	2021-01-15 10:10:08.886	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.businessIdentifierValue:{"val":"0ibPp05UQA6sC7pPflbY5MHnz8B","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-conne
            vw-connect.1	2021-01-15 10:10:08.883	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.businessIdentifierType:{"val":"BUSINESS_IDENTIFIER_TYPE:MBB_ID","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-co
            vw-connect.1	2021-01-15 10:10:08.880	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.nickname:{"val":"Muckii","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc
            vw-connect.1	2021-01-15 10:10:08.878	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.salutation:{"val":"SALUTATION:MRS","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.
            vw-connect.1	2021-01-15 10:10:08.875	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.lastName:{"val":"XXXXXXXXXXX","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin
            vw-connect.1	2021-01-15 10:10:08.872	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.firstName:{"val":"XXXXXX","ack":true,"ts":1610701808426,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","l
            vw-connect.1	2021-01-15 10:10:08.605	debug	(24236) getHomeRegion
            vw-connect.1	2021-01-15 10:10:08.601	debug	(24236) {"userVehicles":{"vehicle":["XXXXXXXXXXXXXXXXXX"]}}
            vw-connect.1	2021-01-15 10:10:08.301	debug	(24236) "{\"firstName\":\"XXXXXX\",\"lastName\":\"XXXXXXXXXXX\",\"salutation\":\"SALUTATION:MRS\",\"nickname\":\"Muckii\",\"businessIdentifierType\":\"BUSINESS_IDENTIFIER_TYPE:MBB_ID\",\"businessIdent
            vw-connect.1	2021-01-15 10:10:07.870	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.info.connection:{"val":true,"ack":true,"ts":1610701807866,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc":1610
            vw-connect.1	2021-01-15 10:10:07.858	debug	(24236) getData
            vw-connect.1	2021-01-15 10:10:07.856	debug	(24236) Login successful
            vw-connect.1	2021-01-15 10:10:07.254	debug	(24236) Error: Invalid protocol: seatconnect:
            vw-connect.1	2021-01-15 10:10:06.503	debug	(24236) {"date":"Fri, 15 Jan 2021 09:10:06 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en-US","expires":"0","loc
            vw-connect.1	2021-01-15 10:10:06.503	debug	(24236) ""
            vw-connect.1	2021-01-15 10:10:06.069	debug	(24236) parsePasswordForm
            vw-connect.1	2021-01-15 10:10:05.562	debug	(24236) parseEmailForm
            vw-connect.1	2021-01-15 10:10:04.606	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.info.connection:{"val":false,"ack":true,"ts":1610701804595,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc":161
            vw-connect.1	2021-01-15 10:10:04.603	silly	(24236) States system redis pmessage system.adapter.vw-connect.1.logLevel/system.adapter.vw-connect.1.logLevel:{"val":"silly","ack":true,"ts":1610701804577,"q":0,"from":"system.adapter.vw-connect.1","
            Es sind auch noch andere Meldungen, an die komme ich gerade aber nicht und werde diese posten, wenn diese nochmal auftauchen.
            Die Daten werden dann auch scheinbar nicht aktualisiert.
            Hast Du da einen Tip für mich?
            @fuchs1978: läuft es bei Dir ohne Probleme?
            D T 2 Replies Last reply Reply Quote 0
              aba320 @tombox last edited by aba320
              @tombox Hallo hab gestern spät abend nochmal auf 23 via git update durchgeführt. es kommen alle 54 Minuten die Fehlermeldungen:
              vw-connect.0	2021-01-15 10:33:07.091	info	(5958) starting. Version 0.0.23 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.20.1, js-controller: 3.1.6
              host.raspberrypiiobroker	2021-01-15 10:33:03.199	info	instance system.adapter.vw-connect.0 started with pid 5958
              host.raspberrypiiobroker	2021-01-15 10:33:00.681	info	instance system.adapter.vw-connect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              vw-connect.0	2021-01-15 10:33:00.092	info	(23070) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              vw-connect.0	2021-01-15 10:33:00.090	info	(23070) terminating
              vw-connect.0	2021-01-15 10:33:00.089	info	(23070) cleaned everything up...
              vw-connect.0	2021-01-15 10:33:00.088	info	(23070) Got terminate signal TERMINATE_YOURSELF
              host.raspberrypiiobroker	2021-01-15 10:33:00.079	info	stopInstance system.adapter.vw-connect.0 send kill signal
              host.raspberrypiiobroker	2021-01-15 10:33:00.073	info	stopInstance system.adapter.vw-connect.0 (force=false, process=true)
              host.raspberrypiiobroker	2021-01-15 10:32:29.739	info	Update repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
              host.raspberrypiiobroker	2021-01-15 10:30:20.788	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
              ical.1	2021-01-15 10:30:20.264	info	(3530) Terminated (NO_ERROR): Without reason
              host.raspberrypiiobroker	2021-01-15 10:30:17.142	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              host.raspberrypiiobroker	2021-01-15 10:30:15.847	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              ical.1	2021-01-15 10:30:15.204	info	(3530) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
              ical.1	2021-01-15 10:30:14.690	info	(3530) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.20.1, js-controller: 3.1.6
              host.raspberrypiiobroker	2021-01-15 10:30:12.334	info	instance system.adapter.ical.1 started with pid 3530
              host.raspberrypiiobroker	2021-01-15 10:30:10.074	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
              host.raspberrypiiobroker	2021-01-15 10:30:08.091	info	instance system.adapter.dwd.1 started with pid 3514
              host.raspberrypiiobroker	2021-01-15 10:30:04.066	info	instance system.adapter.dwd.0 started with pid 3353
              host.raspberrypiiobroker	2021-01-15 10:30:00.041	info	instance system.adapter.daswetter.0 started with pid 3334
              vw-connect.0	2021-01-15 10:29:34.142	error	(23070) Failed relogin
              vw-connect.0	2021-01-15 10:29:34.141	error	(23070) Error: Invalid protocol: skodaconnect:
              vw-connect.0	2021-01-15 10:29:34.139	error	(23070) Failed in first login step
              vw-connect.0	2021-01-15 10:29:33.047	error	(23070) Relogin
              vw-connect.0	2021-01-15 10:29:33.046	error	(23070) 400
              vw-connect.0	2021-01-15 10:29:33.046	error	(23070) {"errorCode":"REQUEST_DATA_INVALID","description":"invalid brand or token audience"}
              vw-connect.0	2021-01-15 10:29:33.035	error	(23070) VwToken
              host.raspberrypiiobroker	2021-01-15 10:15:16.285	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
              host.raspberrypiiobroker	2021-01-15 10:15:12.761	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              host.raspberrypiiobroker	2021-01-15 10:15:09.351	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              host.raspberrypiiobroker	2021-01-15 10:15:08.135	info	instance system.adapter.daswetter.0 started with pid 22655
              host.raspberrypiiobroker	2021-01-15 10:15:04.086	info	instance system.adapter.dwd.0 started with pid 22640
              host.raspberrypiiobroker	2021-01-15 10:15:00.040	info	instance system.adapter.dwd.1 started with pid 22620
              host.raspberrypiiobroker	2021-01-15 10:00:21.104	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
              ical.1	2021-01-15 10:00:20.584	info	(10006) Terminated (NO_ERROR): Without reason
              host.raspberrypiiobroker	2021-01-15 10:00:15.932	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              ical.1	2021-01-15 10:00:15.531	info	(10006) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
              ical.1	2021-01-15 10:00:15.084	info	(10006) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.20.1, js-controller: 3.1.6
              host.raspberrypiiobroker	2021-01-15 10:00:14.986	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              host.raspberrypiiobroker	2021-01-15 10:00:12.462	info	instance system.adapter.ical.1 started with pid 10006
              host.raspberrypiiobroker	2021-01-15 10:00:08.856	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
              host.raspberrypiiobroker	2021-01-15 10:00:08.091	info	instance system.adapter.dwd.1 started with pid 9844
              host.raspberrypiiobroker	2021-01-15 10:00:04.067	info	instance system.adapter.dwd.0 started with pid 9825
              host.raspberrypiiobroker	2021-01-15 10:00:00.043	info	instance system.adapter.daswetter.0 started with pid 9810
              mqtt.0	2021-01-15 09:52:57.972	info	(1355) Client [MqttClient] connection closed: closed
              mqtt.0	2021-01-15 09:52:57.788	info	(1355) Client [MqttClient] connected with secret 1610700777784_5720
              host.raspberrypiiobroker	2021-01-15 09:45:15.974	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
              host.raspberrypiiobroker	2021-01-15 09:45:12.952	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              host.raspberrypiiobroker	2021-01-15 09:45:10.869	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              host.raspberrypiiobroker	2021-01-15 09:45:08.131	info	instance system.adapter.daswetter.0 started with pid 29210
              host.raspberrypiiobroker	2021-01-15 09:45:04.078	info	instance system.adapter.dwd.0 started with pid 29191
              host.raspberrypiiobroker	2021-01-15 09:45:00.038	info	instance system.adapter.dwd.1 started with pid 29029
              vw-connect.0	2021-01-15 09:35:34.117	error	(23070) Failed relogin
              vw-connect.0	2021-01-15 09:35:34.115	error	(23070) Error: Invalid protocol: skodaconnect:
              vw-connect.0	2021-01-15 09:35:34.114	error	(23070) Failed in first login step
              vw-connect.0	2021-01-15 09:35:33.055	error	(23070) Relogin
              vw-connect.0	2021-01-15 09:35:33.054	error	(23070) 400
              vw-connect.0	2021-01-15 09:35:33.054	error	(23070) {"errorCode":"REQUEST_DATA_INVALID","description":"invalid brand or token audience"}
              vw-connect.0	2021-01-15 09:35:33.046	error	(23070) VwToken
              adaptereinstellungen wurden nicht geändert und sind:
              Typ Skoda
              Update 7 Minuten
              Spin eingegeben
              Update erzwingen 0
              Fahrdaten alle und alle
              auch schon bei vorgängerversionen kamen alle 54 Minuten Fehler aber es waren nur 2 Zeilen.
              in objekten werden neben destination, position, remote, status nur die cyclic tripdata erstellt ,
              wenn der adapter umgestellt wird kommen auch entsprechen die Lang oder kurz Tripwerte.
                Datensammler @Datensammler last edited by
                @datensammler said in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                Ich kann meinen vorherigen Beitrag leider nicht bearbeiten, daher hier die Ergänzung der Fehlermeldungen:
                host.iobroker	2021-01-15 12:30:23.154	info	instance system.adapter.vw-connect.1 terminated with code 0 (NO_ERROR)
                vw-connect.1	2021-01-15 12:30:22.604	error	(24696) unhandled promise rejection: undefined
                vw-connect.1	2021-01-15 12:30:22.603	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                vw-connect.1	2021-01-15 12:30:22.601	error	(24696) Error: Invalid protocol: seatconnect:
                vw-connect.1	2021-01-15 12:30:22.601	error	(24696) Failed in first login step
                vw-connect.1	2021-01-15 12:30:21.444	error	(24696) Relogin
                vw-connect.1	2021-01-15 12:30:21.443	error	(24696) 400
                vw-connect.1	2021-01-15 12:30:21.443	error	(24696) {"errorCode":"REQUEST_DATA_INVALID","description":"invalid brand or token audience"}
                vw-connect.1	2021-01-15 12:30:21.438	error	(24696) VwToken
                vw-connect.1	2021-01-15 11:36:22.913	error	(24696) status update Failed
                vw-connect.1	2021-01-15 11:36:22.911	error	(24696) 429
                host.iobroker	2021-01-15 11:36:15.075	info	instance system.adapter.vw-connect.1 started with pid 24696
                  tombox @Datensammler last edited by
                  @datensammler
                  Fehler 429 wurden zuviele Requests gesendet. Du musst das Auto einmal starten
                    mtbsteve @tombox last edited by
                    @tombox funktioniert! Danke!!
                    • Tranquility76
                      Tranquility76 last edited by
                      vielleicht habe ich es bei der Länge des Threads überlesen - wurde schon mal was Richtung Wallbox VW ID Charger Connect/Pro versucht?
                      Das Ding ist auch über die We Connect ID App mit eingebunden, müsste also auch über den Adapter hier erreichbar sein.
                        tombox @Tranquility76 last edited by
                        @tranquility76 probier mal die aktuellste version
                          jhg @tombox last edited by
                          @tombox Welche Funktionalitäten wurden denn für WeCharge implementiert?
                          Ist das nur für das Laden zuhause gedacht.
                          Verstehe es gerade nicht.
                          T M 2 Replies Last reply Reply Quote 0
                            tombox @jhg last edited by
                            @jhg Alles was in der App We connect ID zum we charge angezeigt wird. die stop funktionalität wurde noch nicht eingebaut
                              mtbsteve @jhg last edited by
                              @jhg unter wecharge.chargeandpay findest du deine WeCharge Tarifdetails und die Ladehistorie an öffentlichen Stationen und unter wechagre.homecharging alle Elli Wallbox Parameter sowie die Ladehistorie an deiner Elli Box.
                                jhg @mtbsteve last edited by
                                @mtbsteve @tombox Danke euch beiden. Da ich bisher noch nicht mit WeCharge geladen habe, ist nichts ersichtlich.
                                  turtle1987 last edited by
                                  Ich habe den Adapter heute installiert. Leider werden nur die Ladevorgänge bis zum 8.1.2021 geladen und nicht die aus dem Zeitraum davor. Kann man das irgendwie beeinflussen?
                                  Hat jemand einen guten Tipp, wie ich die Daten aus den Ladevorgängen in ein CSV geschrieben bekomme?
                                    tombox @turtle1987 last edited by
                                    @turtle1987 der Adapter kann nur das anzeigen was die App bereitstellen. Ich könnte die rohe JSON ausgeben wenn das was bringt
                                      turtle1987 @tombox last edited by turtle1987
                                      @tombox die App ist in der Lage auch Daten darzustellen, die weiter in der Vergangenheit liegen. Allerdings werden diese scheinbar erst abgerufen, wenn man ganz nach unten gescrollt hat. Mir scheint, als wird initial ein gewisser Zeitraum abgerufen, wenn man mehr will, muss das explizit angefordert werden.
                                      Zum Logging: Ich bin noch Neuling was ioBroker angeht. Mit dem History Adapter kann ich nach meinem Verständnis bestimmte fixe Werte loggen. Für wecharge entsteht aber mit jedem Ladevorgang ein neuer Eintrag. Da weiß ich noch nicht, wie ich das weg schreiben könnte.
                                        Bei mir werden die wecharge Daten für homecharge erst ab dem 22.11.2020 ausgelesen, die Werte zwischen dem 29.10. und 21.11. fehlen. Die Ladevorgänge unter chargeandpay sind bei mir komplett ab dem 30.10. bis heute im iobroker. Kann es sein, dass der Adapter nur eine begtrenzte Anzahl von Ladevorgängen liest?
                                          Momo1982 @mtbsteve last edited by
                                          Nachdem mein neues Auto endlich angekommen ist, wollte ich es ganz euphorisch in IoBroker implementieren. Jedoch hielt die Freude nur eine sehr begrenzte Zeit. Bei mir mag der Adapter erst gar nicht arbeiten...
                                          Da ich nicht unbedingt der erfahrenste User bin, was IoBroker angeht, die Frage an euch: könnte mir da jemand weiter helfen?
                                          Alle drei Indikatoren leuchten rot. Im Log ist leider gar nichts drin, warum, wieso, weshalb der Adapter nicht das tut, was er machen soll... Node ist in V12 installiert.
                                          Ich warte erstmal auf eure Rückmeldungen.
                                          Schönen Abend euch!
                                            tombox @Momo1982 last edited by
                                            @momo1982 welcher Fehler wird im log angezeigt
                                            81.1k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            398
                                            3090
                                            1601079
