    4. IOBroker Anbindung an einen Kostal Plenticore
    • StrathCole
      StrathCole @lemonbiter last edited by StrathCole
      @lemonbiter Nein, du brauchst ein Objekt vom Type String (unescaped) und musst da dann die Objekt-ID javascript.0.vis.pv_hours eintragen. Und du musst es groß genug ziehen.
      Und dann im rechten Bereich noch den Reiter CSS öffnen und das hier einfügen:
      .vis-pv-hours > div {
          height: 100%;
      .vis-pv-hours > div > div {
          display: flex;
          flex-direction: column;
          flex-wrap: wrap;
          align-items: flex-start;
          height: 100%;
      .fc-hour-entry {
          display: flex;
          position: relative;
          justify-content: space-between;
          margin-bottom: 0.5rem;
          width: 45%;
      .fc-hour-entry:before {
          content: '}';
          position: absolute;
          left: 110px;
          bottom: -5px;
          font-size: 1.75rem;
      .fc-hour-entry:after {
          order: 2;
          content: '';
          border-bottom: dotted 2px #fff;
          flex-basis: 100%;
          flex-shrink: 1;
          margin-bottom: 7px;
      .fc-hour-entry > * {
          margin-left: 2rem;
      .fc-hour-entry > *:first-child {
          margin-left: 0;
      .fc-hour-entry > .fc-hour-time {
          flex-basis: 15%;
          flex-grow: 0;
          font-size: 1.5rem;
          white-space: nowrap;
          order: 1;
          margin-right: 15px;
      .fc-hour-entry > .fc-hour-time:after {
          content: ' Uhr';
      .fc-hour-entry > .fc-hour-forecast,
      .fc-hour-entry > .fc-hour-real {
          flex-basis: 35%;
          text-align: right;
          flex-grow: 0;
          flex-shrink: 0;
          font-size: 1.125rem;
          margin-top: 1.5rem;
          order: 3;
      .fc-hour-entry > .fc-hour-forecast {
          flex-basis: 25%;
          flex-shrink: 1;
          margin-left: 8px;
      .progress-bar {
          display: flex;
          height: 16px;
          background-image: linear-gradient(to right, #9a0000, #009000);
          border: solid 1px #fff;
      .progress-bar:after {
          content: '';
          display: block;
          background: #000;
          flex-basis: 100%;
          flex-shrink: 1;
          flex-grow: 1;
          max-width: 100%;
      .progress-bar > .progress {
          display: block;
          background: transparent;
          flex-shrink: 0;
          position: relative;
      .fc-hour-entry > .fc-hour-real > span.progress-label {
          position: absolute;
          right: 0;
          top: 1px;
          font-size: 0.875rem;
          font-weight: bold;
      lemonbiter 1 Reply Last reply Reply Quote 0
      • lemonbiter
        lemonbiter @StrathCole last edited by lemonbiter
        @strathcole
        Vielen lieben Dank.
        So sieht das nun aus....
        Ist vermutlich alles da, aber gut ablesen kann ich es nicht.
        Würdest Du mir netterweise mal einen Screen deiner VIS reinpacken?
        Viele Grüße
        Lem
        StrathCole 1 Reply Last reply Reply Quote 0
        • StrathCole
          @lemonbiter das ist schon richtig so. Ich habe nur den Hintergrund meiner ganzen Vis auf Schwarz.
            ansi70 @ak1 last edited by
            @ak1 Ich stehe aktuell vor dem gleichen Problem. Hat es hierzu eine Rückmeldung gegeben?
              ak1 @ansi70 last edited by
              @ansi70 said in IOBroker Anbindung an einen Kostal Plenticore:
              @ansi70 Was meinst Du genau?
              • lemonbiter
                @strathcole Vielen lieben dank. Es läuft. Finde die Lesbarkeit zwar nicht sooo... ideal, aber immerhin.
                Hast Du vielleicht auch noch einen netten Tipp zum zweiten Teil meiner Frage: Ich fände es supi wenn die Werte - umgeschrieben auf der echten Uhrzeit (also nicht der x nach Sonnenaufgang) in eine Sysvariable geschrieben würde... Dann könnte ich mir selbst eine Tabelle bauen...
                Wenn Du da nichts hast, was ich nutzen kann... kein Problem... Wenn doch: Jippieeijäh 🙂
                Lieben Gruß und Danke noch mal
                Lem
                  joefarm @Diginix last edited by joefarm
                  @diginix
                  Ich versuche seit einiger Zeit an die HV-Box zu kommen per web-interface, aber ich schaffe es nicht. Die Box ist in der Fritzbox zu sehen, aber wenn ich die IP der HV-Box eingebe, passiert ein redirect auf die Fritzbox, die beim mir dir 192.168.5.1 hat. Evtl. ist das Teil des Problems, weil über WLAN das auch die IP der HV-Box. Über WLAN komm ich nach dem Einschalten dran, aber nur direkt.
                  Auch eine statische Route 192.168.6.1 auf die IP der HV-Box hilft nicht.
                  Was mache ich falsch?
                  • Diginix
                    Diginix @joefarm last edited by Diginix
                    @joefarm Sicher dass du eine alte HV BYD hast und keine neuere HVS oder HVM?
                    Denn diese haben keine eigene WebUI mehr. Die kannst du imho nur noch mit Be Connect administrieren.
                      @diginix
                      Ja ganz sicher.
                      Wenn ich die HV-Box einschalte, kann ich mich an deren WLAN-Hotspot z.B. mit dem Ipad dranklemmen und dann über die Seite 192.168.5.1 einloggen. Da sehen ich alles. Nur hätte ich die Box gerne im LAN, wenn ich sie anstecke, bekommt sie auch eine eigene IP in der Fritzbox. Soweit so gut.
                      Ich hab die Box jetzt schon fast 2 Jahre, da gab es nur HV und nicht die neueren.
                      • Diginix
                        @joefarm Ja, bei dem Alter ist es sicher eine HV, wie bei mir.
                        Ich hab bei meiner auch einfach nur ein LAN Kabel zur Fritzbox gezogen und konnte dann mit der IP, die die Fritzbox vergeben habt, direkt auf die Oberfläche. Wenn das so bei dir nicht klappt, fällt mir gerade auch nichts weiter hilfreiches ein.
                          @diginix
                          Ok danke. Dachte ich mir fast. Noch eine Frage: wenn du die IP der HV-Box eingibst, passiert dann ein redirect auf die 192.168.5.1 oder bleibt es bei der IP der HV-Box?
                          T Diginix 2 Replies Last reply Reply Quote 0
                            tp1de @joefarm last edited by tp1de
                            @joefarm Ich habe verstanden, dass Du per WLAN auf die BYD HV-Box kommst. Hat der Router denn eine IP-Adresse aus dem DHCP Bereich für eth0 vergeben?
                            Bei mir sieht das unter Device Information so aus:
                            Ein redirect erfolgt bei der eigenen IP nicht.
                            • Diginix
                              @joefarm Bei Verbindung mit der FB hat meine BYD eine IP im Bereich meines Heimnetzes. Das ist nicht 192.168.5.x.
                              Und wenn ich diese aufrufen werde ich auch nicht weitergeleitet.
                              • Diginix
                                Diginix last edited by Diginix
                                @StrathCole Hast du zufällig die notwendigen Anpassungen deines Adapters für JS-Controller 3.2.x schon wahrgenommen?
                                2021-01-24 09:03:57.762 - warn: plenticore.0 (103948) State "plenticore.0.forecast.day1.power.1h.generated" has no existing object, this might lead to an error in future versions
                                2021-01-24 09:03:57.764 - warn: plenticore.0 (103948) State "plenticore.0.forecast.day1.power.1h.generated" has no existing object, this might lead to an error in future versions
                                2021-01-24 09:04:18.813 - warn: plenticore.0 (103948) State "plenticore.0.forecast.day1.power.2h.generated" has no existing object, this might lead to an error in future versions
                                2021-01-24 09:04:18.817 - warn: plenticore.0 (103948) State "plenticore.0.forecast.day1.power.2h.generated" has no existing object, this might lead to an error in future versions
                                Diese Zeilen habe ich heute schon 430 mal im Log und mit jeder neuen Stunde werden es wieder um die 300 mehr.
                                • StrathCole
                                  StrathCole @Diginix last edited by
                                  @diginix gesehen ja, aber noch keine Zeit gehabt, genauer anzuschauen. Dürfte auch eine umfangreichere Sache sein.
                                  • Diginix
                                    Diginix @StrathCole last edited by
                                    @strathcole Für den Moment müsste es ja helfen wenn ich in allen forcast ?h Ordnern leere generated Objete anlege oder?
                                    Werden die dann bei Datumswechsel wieder gelöscht?
                                    • StrathCole
                                      @diginix habe es nicht im Kopf, aber denke, dass sie gelöscht werden.
                                      • Diginix
                                        @strathcole Das wäre doch dann der Ansatz. Einfach alle Objekte die "erwartet" werden auch existent lassen und dann eben mit Wert 0/null.
                                        K.a. was man machen muss damit sie fehlen dürfen wenn nicht benötigt. Der JS-Controller bekommt ja anscheinend vom Adapter mit welche "angesprochen" werden.
                                        • StrathCole
                                          @diginix denke nicht. Vermute, dass es an irgendetwas anderem liegt. Muss ich näher untersuchen, kann aber noch nicht sagen, wann ich dazu komme. Im Moment ist Arbeitsstress hoch drei.
                                          Diginix lemonbiter 2 Replies Last reply Reply Quote 0
                                          • Diginix
                                            @strathcole Ok, na ich hab einfach mal den loglevel vom Adapter auf "error" gestellt, damit das Log nicht explodiert und ich eventuelle Probleme anderer Adapter überhaupt noch sehe.
                                            1302
                                            444875
