    4. Zigbee Adapter startet nicht
      Thomas Braun Most Active @Letty last edited by
      @letty Deinstallier den Adapter mal und dann zeig mal das Log von der Re-Installation. Da läuft glaube ich von vorneherein schon was krumm.
        Letty @Thomas Braun last edited by
        anbei das Log von der Re-Installation
        host.raspberrypi	2021-01-21 20:25:24.655	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.raspberrypi	2021-01-21 20:25:24.654	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.raspberrypi	2021-01-21 20:25:24.654	error	Caught by controller[0]: }
        host.raspberrypi	2021-01-21 20:25:24.653	error	Caught by controller[0]: ]
        host.raspberrypi	2021-01-21 20:25:24.653	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
        host.raspberrypi	2021-01-21 20:25:24.653	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js',
        host.raspberrypi	2021-01-21 20:25:24.652	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/serialPortUtils.js',
        host.raspberrypi	2021-01-21 20:25:24.652	error	Caught by controller[0]: requireStack: [
        host.raspberrypi	2021-01-21 20:25:24.651	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.raspberrypi	2021-01-21 20:25:24.651	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19) {
        host.raspberrypi	2021-01-21 20:25:24.650	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
        host.raspberrypi	2021-01-21 20:25:24.650	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
        host.raspberrypi	2021-01-21 20:25:24.650	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
        host.raspberrypi	2021-01-21 20:25:24.649	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
        host.raspberrypi	2021-01-21 20:25:24.649	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/serialPortUtils.js:15:38)
        host.raspberrypi	2021-01-21 20:25:24.649	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
        host.raspberrypi	2021-01-21 20:25:24.648	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19)
        host.raspberrypi	2021-01-21 20:25:24.648	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:841:27)
        host.raspberrypi	2021-01-21 20:25:24.648	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
        host.raspberrypi	2021-01-21 20:25:24.647	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
        host.raspberrypi	2021-01-21 20:25:24.647	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js
        host.raspberrypi	2021-01-21 20:25:24.647	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/serialPortUtils.js
        host.raspberrypi	2021-01-21 20:25:24.646	error	Caught by controller[0]: Require stack:
        host.raspberrypi	2021-01-21 20:25:24.646	error	Caught by controller[0]: Error: Cannot find module 'serialport'
        host.raspberrypi	2021-01-21 20:25:24.645	error	Caught by controller[0]: ^
        host.raspberrypi	2021-01-21 20:25:24.645	error	Caught by controller[0]: throw err;
        host.raspberrypi	2021-01-21 20:25:24.644	error	Caught by controller[0]: internal/modules/cjs/loader.js:968
        host.raspberrypi	2021-01-21 20:25:23.885	info	instance system.adapter.zigbee.0 started with pid 22111
        host.raspberrypi	2021-01-21 20:24:53.827	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.raspberrypi	2021-01-21 20:24:53.827	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.raspberrypi	2021-01-21 20:24:53.827	error	Caught by controller[0]: }
        host.raspberrypi	2021-01-21 20:24:53.826	error	Caught by controller[0]: ]
        host.raspberrypi	2021-01-21 20:24:53.826	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
        host.raspberrypi	2021-01-21 20:24:53.826	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js',
        host.raspberrypi	2021-01-21 20:24:53.826	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/serialPortUtils.js',
        host.raspberrypi	2021-01-21 20:24:53.826	error	Caught by controller[0]: requireStack: [
        host.raspberrypi	2021-01-21 20:24:53.826	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.raspberrypi	2021-01-21 20:24:53.825	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19) {
        host.raspberrypi	2021-01-21 20:24:53.825	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
        host.raspberrypi	2021-01-21 20:24:53.825	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
        host.raspberrypi	2021-01-21 20:24:53.825	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
        host.raspberrypi	2021-01-21 20:24:53.825	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
        host.raspberrypi	2021-01-21 20:24:53.825	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/serialPortUtils.js:15:38)
        host.raspberrypi	2021-01-21 20:24:53.824	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
        host.raspberrypi	2021-01-21 20:24:53.824	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19)
        host.raspberrypi	2021-01-21 20:24:53.824	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:841:27)
        host.raspberrypi	2021-01-21 20:24:53.824	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
        host.raspberrypi	2021-01-21 20:24:53.824	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
        host.raspberrypi	2021-01-21 20:24:53.824	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js
        host.raspberrypi	2021-01-21 20:24:53.823	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/serialPortUtils.js
        host.raspberrypi	2021-01-21 20:24:53.823	error	Caught by controller[0]: Require stack:
        host.raspberrypi	2021-01-21 20:24:53.823	error	Caught by controller[0]: Error: Cannot find module 'serialport'
        host.raspberrypi	2021-01-21 20:24:53.823	error	Caught by controller[0]: ^
        host.raspberrypi	2021-01-21 20:24:53.822	error	Caught by controller[0]: throw err;
        host.raspberrypi	2021-01-21 20:24:53.822	error	Caught by controller[0]: internal/modules/cjs/loader.js:968
        host.raspberrypi	2021-01-21 20:24:53.104	info	instance system.adapter.zigbee.0 started with pid 21421
        host.raspberrypi	2021-01-21 20:24:51.602	info	iobroker exit 0
        host.raspberrypi	2021-01-21 20:24:50.066	info	iobroker host.raspberrypi object system.adapter.zigbee.0 created
        host.raspberrypi	2021-01-21 20:24:50.020	info	iobroker host.raspberrypi Set default value of zigbee.0.info.connection: false
        host.raspberrypi	2021-01-21 20:24:49.993	info	iobroker host.raspberrypi Set default value of zigbee.0.info.pairingMode: false
        host.raspberrypi	2021-01-21 20:24:49.966	info	iobroker host.raspberrypi Set default value of zigbee.0.info.pairingCountdown: 0
        host.raspberrypi	2021-01-21 20:24:49.939	info	iobroker host.raspberrypi Set default value of zigbee.0.info.pairingMessage:
        host.raspberrypi	2021-01-21 20:24:49.911	info	iobroker host.raspberrypi Set default value of zigbee.0.info.groups:
        host.raspberrypi	2021-01-21 20:24:49.881	info	iobroker host.raspberrypi object system.adapter.zigbee.0.alive created
        host.raspberrypi	2021-01-21 20:24:49.848	info	iobroker host.raspberrypi object system.adapter.zigbee.0.connected created
        host.raspberrypi	2021-01-21 20:24:49.815	info	iobroker host.raspberrypi object system.adapter.zigbee.0.compactMode created
        host.raspberrypi	2021-01-21 20:24:49.781	info	iobroker host.raspberrypi object system.adapter.zigbee.0.cpu created
        host.raspberrypi	2021-01-21 20:24:49.747	info	iobroker host.raspberrypi object system.adapter.zigbee.0.cputime created
        host.raspberrypi	2021-01-21 20:24:49.713	info	iobroker host.raspberrypi object system.adapter.zigbee.0.memHeapUsed created
        host.raspberrypi	2021-01-21 20:24:49.680	info	iobroker host.raspberrypi object system.adapter.zigbee.0.memHeapTotal created
        host.raspberrypi	2021-01-21 20:24:49.646	info	iobroker host.raspberrypi object system.adapter.zigbee.0.memRss created
        host.raspberrypi	2021-01-21 20:24:49.613	info	iobroker host.raspberrypi object system.adapter.zigbee.0.uptime created
        host.raspberrypi	2021-01-21 20:24:49.579	info	iobroker host.raspberrypi object system.adapter.zigbee.0.inputCount created
        host.raspberrypi	2021-01-21 20:24:49.546	info	iobroker host.raspberrypi object system.adapter.zigbee.0.outputCount created
        host.raspberrypi	2021-01-21 20:24:49.511	info	iobroker host.raspberrypi object system.adapter.zigbee.0.eventLoopLag created
        host.raspberrypi	2021-01-21 20:24:49.477	info	iobroker host.raspberrypi object system.adapter.zigbee.0.sigKill created
        host.raspberrypi	2021-01-21 20:24:49.444	info	iobroker host.raspberrypi object system.adapter.zigbee.0.logLevel created
        host.raspberrypi	2021-01-21 20:24:49.406	info	iobroker host.raspberrypi object zigbee.0.info created
        host.raspberrypi	2021-01-21 20:24:49.375	info	iobroker host.raspberrypi object zigbee.0.info.connection created
        host.raspberrypi	2021-01-21 20:24:49.343	info	iobroker host.raspberrypi object zigbee.0.info.pairingMode created
        host.raspberrypi	2021-01-21 20:24:49.310	info	iobroker host.raspberrypi object zigbee.0.info.pairingCountdown created
        host.raspberrypi	2021-01-21 20:24:49.277	info	iobroker host.raspberrypi object zigbee.0.info.pairingMessage created
        host.raspberrypi	2021-01-21 20:24:49.241	info	iobroker host.raspberrypi object zigbee.0.info.groups created
        host.raspberrypi	2021-01-21 20:24:49.228	info	iobroker host.raspberrypi create instance zigbee
        host.raspberrypi	2021-01-21 20:24:49.170	info	iobroker host.raspberrypi object system.adapter.zigbee created/updated
        host.raspberrypi	2021-01-21 20:24:49.085	info	iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
        host.raspberrypi	2021-01-21 20:24:49.018	info	iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
        host.raspberrypi	2021-01-21 20:24:48.959	info	iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
        host.raspberrypi	2021-01-21 20:24:48.900	info	iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
        host.raspberrypi	2021-01-21 20:24:48.842	info	iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
        host.raspberrypi	2021-01-21 20:24:48.783	info	iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
        host.raspberrypi	2021-01-21 20:24:48.724	info	iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
        host.raspberrypi	2021-01-21 20:24:48.664	info	iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
        host.raspberrypi	2021-01-21 20:24:48.602	info	iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
        host.raspberrypi	2021-01-21 20:24:48.540	info	iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
        host.raspberrypi	2021-01-21 20:24:48.476	info	iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
        host.raspberrypi	2021-01-21 20:24:48.409	info	iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
        host.raspberrypi	2021-01-21 20:24:48.343	info	iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
        host.raspberrypi	2021-01-21 20:24:48.273	info	iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
        host.raspberrypi	2021-01-21 20:24:48.204	info	iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
        host.raspberrypi	2021-01-21 20:24:48.141	info	iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
        host.raspberrypi	2021-01-21 20:24:48.072	info	iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
        host.raspberrypi	2021-01-21 20:24:48.011	info	iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
        host.raspberrypi	2021-01-21 20:24:47.948	info	iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
        host.raspberrypi	2021-01-21 20:24:47.885	info	iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06104A.png img/HG06104A.png image/png
        host.raspberrypi	2021-01-21 20:24:47.822	info	iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06106C.png img/HG06106C.png image/png
        host.raspberrypi	2021-01-21 20:24:47.217	info	iobroker exit 0
        host.raspberrypi	2021-01-21 20:24:47.186	info	iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/SGMHM-I1.png img/SGMHM-I1.png image/png
        host.raspberrypi	2021-01-21 20:24:46.584	info	iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZWLD-100.png img/ZWLD-100.png image/png
        host.raspberrypi	2021-01-21 20:24:46.179	info	iobroker Adapter "vis" updated
        host.raspberrypi	2021-01-21 20:24:46.177	info	stopInstance system.adapter.vis.0 (force=false, process=true)
        host.raspberrypi	2021-01-21 20:24:46.132	info	iobroker Update "system.adapter.vis.0"
        host.raspberrypi	2021-01-21 20:24:45.894	info	iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_902010_29.png img/bitron_902010_29.png image/png
        host.raspberrypi	2021-01-21 20:24:45.874	info	iobroker upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
        host.raspberrypi	2021-01-21 20:24:45.803	info	iobroker upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
        host.raspberrypi	2021-01-21 20:24:45.731	info	iobroker upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
        host.raspberrypi	2021-01-21 20:24:45.660	info	iobroker upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
        host.raspberrypi	2021-01-21 20:24:45.588	info	iobroker upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
        host.raspberrypi	2021-01-21 20:24:45.517	info	iobroker upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
        host.raspberrypi	2021-01-21 20:24:45.443	info	iobroker upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
        host.raspberrypi	2021-01-21 20:24:45.361	info	iobroker upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
        host.raspberrypi	2021-01-21 20:24:40.361	info	iobroker upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
        host.raspberrypi	2021-01-21 20:24:34.418	info	iobroker upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
        host.raspberrypi	2021-01-21 20:24:34.349	info	iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln2.png img/ctrl_ln2.png image/png
        host.raspberrypi	2021-01-21 20:24:34.244	info	iobroker upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
        host.raspberrypi	2021-01-21 20:24:34.161	info	iobroker upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
        host.raspberrypi	2021-01-21 20:24:34.064	info	iobroker upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
        host.raspberrypi	2021-01-21 20:24:33.869	info	iobroker upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
        host.raspberrypi	2021-01-21 20:24:33.525	info	iobroker upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
        host.raspberrypi	2021-01-21 20:24:33.284	info	iobroker upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
        host.raspberrypi	2021-01-21 20:24:32.955	info	iobroker upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
        host.raspberrypi	2021-01-21 20:24:32.704	info	iobroker upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
        host.raspberrypi	2021-01-21 20:24:32.502	info	iobroker upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
        host.raspberrypi	2021-01-21 20:24:32.433	info	iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/edp_redy_plug.png img/edp_redy_plug.png image/png
        host.raspberrypi	2021-01-21 20:24:32.425	info	iobroker upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
        host.raspberrypi	2021-01-21 20:24:32.355	info	iobroker upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
        host.raspberrypi	2021-01-21 20:24:31.656	info	iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/flspp3.png img/flspp3.png image/png
        host.raspberrypi	2021-01-21 20:24:31.173	info	iobroker upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
        host.raspberrypi	2021-01-21 20:24:22.779	info	iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_stripe.png img/gledopto_stripe.png image/png
        host.raspberrypi	2021-01-21 20:24:22.691	info	iobroker upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
        host.raspberrypi	2021-01-21 20:24:22.046	info	iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue_outdoor_motion.png img/hue_outdoor_motion.png image/png
        host.raspberrypi	2021-01-21 20:24:21.905	info	iobroker upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
        host.raspberrypi	2021-01-21 20:24:20.193	info	iobroker upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
        host.raspberrypi	2021-01-21 20:24:19.434	info	iobroker upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
        host.raspberrypi	2021-01-21 20:24:17.854	info	iobroker upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
        host.raspberrypi	2021-01-21 20:24:06.779	info	iobroker upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/index.html index.html text/html
        host.raspberrypi	2021-01-21 20:24:03.365	info	iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lightify-driver.png img/lightify-driver.png image/png
        host.raspberrypi	2021-01-21 20:24:03.202	info	iobroker upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/delete.png js/fm/icon/actions/delete.png image/png
        host.raspberrypi	2021-01-21 20:23:43.389	info	iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_LTC015.png img/philips_hue_LTC015.png image/png
        host.raspberrypi	2021-01-21 20:23:42.935	info	iobroker upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditInspect.js js/visEditInspect.js application/javascript
        host.raspberrypi	2021-01-21 20:23:35.824	info	iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smarthomepty_plug.png img/smarthomepty_plug.png image/png
        host.raspberrypi	2021-01-21 20:23:35.561	info	iobroker upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.ba-resize.min.js lib/js/jquery.ba-resize.min.js application/javascript
        host.raspberrypi	2021-01-21 20:23:31.395	info	iobroker host.raspberrypi install adapter zigbee
        host.raspberrypi	2021-01-21 20:23:24.146	info	iobroker upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/bars.html widgets/bars.html text/html
        host.raspberrypi	2021-01-21 20:23:19.907	info	iobroker upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/js/table.js widgets/basic/js/table.js application/javascript
        host.raspberrypi	2021-01-21 20:23:03.376	info	iobroker upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/fancyswitch/img/ibutton-slider-giva-original.png widgets/fancyswitch/img/ibutton-slider-giva-original.png image/png
        host.raspberrypi	2021-01-21 20:22:57.475	info	iobroker upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/google-fonts/fonts/Open_Sans_Condensed/OpenSans-CondLight.ttf widgets/google-fonts/fonts/Open_Sans_Condensed/OpenSans-Con
        host.raspberrypi	2021-01-21 20:22:50.182	info	iobroker upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/css/hqwidgetsButtons.css widgets/hqwidgets/css/hqwidgetsButtons.css text/css
        host.raspberrypi	2021-01-21 20:22:42.610	info	iobroker NPM version: 6.14.6npm install iobroker.zigbee@1.4.2 --loglevel error --prefix "/opt/iobroker" (System call)
        host.raspberrypi	2021-01-21 20:22:42.476	info	iobroker upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_door.svg widgets/jqui-mfd/img/fts_door.svg image/svg+xml
        host.raspberrypi	2021-01-21 20:22:39.187	info	iobroker add zigbee --host raspberrypi
          @letty
          Prüf mal deine node-Installation:
          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs && who -r
            pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs && who -r
            /usr/bin/nodejs
            v12.18.3
            /usr/local/bin/node
            v12.18.3
            /usr/local/bin/npm
            6.14.6
            nodejs:
              Installed: 12.18.3-1nodesource1
              Candidate: 12.20.1-1nodesource1
              Version table:
                 12.20.1-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
             *** 12.18.3-1nodesource1 100
                    100 /var/lib/dpkg/status
                 10.23.1~dfsg-1~deb10u1 500
                     run-level 5  2021-01-19 20:49
              Thomas Braun Most Active @Letty last edited by Thomas Braun
              @letty
              Der Klassiker:
              nodeJS falsch installiert.
              Hier geht es weiter:
              https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
              Und den RunLevel würde ich auch auf 3 stellen.
                Vielen Dank das hat soweit geklappt der Zigbee Adapter läuft jetz richtig.
                Komisch ist nur das sonst kein Adapter Probleme hatte.
                Jetzt habe ich nur das Problem das ich für die npm Versions abfrage sudo brauche oder ist das egal ?
                /usr/bin/nodejs
                v12.20.1
                /usr/bin/node
                v12.20.1
                /usr/bin/npm
                Illegal option --
                -bash: Usage:: command not found
                pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && sudo npm -v && apt policy nodejs && who -r
                /usr/bin/nodejs
                v12.20.1
                /usr/bin/node
                v12.20.1
                /usr/bin/npm
                6.14.10
                nodejs:
                  Installed: 12.20.1-1nodesource1
                  Version table:
                 *** 12.20.1-1nodesource1 500
                         run-level 3  2021-01-22 19:29
                  @letty
                  Ja, das sieht jetzt gut aus.
                  Inklusive RunLevel 3. Sehr gut.
                  npm muss man auch ohne sudo aufrufen können:
                  pi@raspberrypi:~ $ npm -v
                  6.14.10
                    ja zuvor ging es aber jetz bekomme ich die Meldung.
                    Ich muss dazu sagen das ich aber nicht komplett deiner Anleitung gefolgt bin sonder es über das script (curl -sLf https://iobroker.net/install.sh | bash -) gelöst habe evtl komm das daher ?
                    Illegal option --
                      @letty
                      Keine Ahnung was du da nun gemacht hast.
                      Wenn du eigenen Kram machst, wunder dich auch nicht wenn das Resultat dann 'eigen' ist.
                      Mit dem curl ziehst du eine Installation des ioBrokers an Land.
                        @letty
                        Schau mal in deine ~/.bashrc rein.
                        Da müsste am Ende sowas drin stehen:
                        # Forces npm to run as iobroker when inside the iobroker installation dir
                        source ~/.iobroker/npm_command_fix
                          Ja das steht drin.
                          Aber es läuft auch alles und es sind auch keine Fehler im Log.
                          494
