Test Adapter shuttercontrol v2.0.x
@simatec said in Test Adapter shuttercontrol v1.1.x:
@tom-haase
Beobachte mal bitte beim fahren deines Rollladens bitte den State im fhem Adapter.
Ich hab das Gefühl, dass dieser nicht sofort den Wert setztbeim runterfahren:
2021.01.17 10:21:07 3 : Testname: SD_Keeloq_AC6000 set down 9 2021-01-17 10:21:07 ROLLO Friedhelm command: pct-100 2021-01-17 10:21:07 ROLLO Friedhelm desired_pct: 100 2021-01-17 10:21:07 ROLLO Friedhelm last_drive: drive-down 2021-01-17 10:21:07 ROLLO Friedhelm drive-down 2021-01-17 10:21:07 ROLLO Friedhelm drive-type: modul 2021-01-17 10:21:07 SD_Keeloq SD_Keeloq_AC6000 button: down 2021-01-17 10:21:07 SD_Keeloq SD_Keeloq_AC6000 channel: 9 2021-01-17 10:21:07 SD_Keeloq SD_Keeloq_AC6000 counter_send: 9686 2021-01-17 10:21:07 SD_Keeloq SD_Keeloq_AC6000 send down 2021-01-17 10:21:07 SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: down 2021-01-17 10:21:07 SD_Keeloq SD_Keeloq_AC6000 channel_control: no 2021.01.17 10:21:34 3 : Testname: SD_Keeloq_AC6000 set stop 9 2021-01-17 10:21:34 ROLLO Friedhelm pct: 100 2021-01-17 10:21:34 SD_Keeloq SD_Keeloq_AC6000 button: stop 2021-01-17 10:21:34 SD_Keeloq SD_Keeloq_AC6000 channel: 9 2021-01-17 10:21:34 SD_Keeloq SD_Keeloq_AC6000 counter_send: 9687 2021-01-17 10:21:34 SD_Keeloq SD_Keeloq_AC6000 send stop 2021-01-17 10:21:34 SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop 2021-01-17 10:21:34 SD_Keeloq SD_Keeloq_AC6000 channel_control: no 2021-01-17 10:21:34 ROLLO Friedhelm closedbeim hochfahren:
2021.01.17 10:22:39 3 : Testname: SD_Keeloq_AC6000 set up 9 2021-01-17 10:22:39 ROLLO Friedhelm command: pct-0 2021-01-17 10:22:39 ROLLO Friedhelm desired_pct: 0 2021-01-17 10:22:39 ROLLO Friedhelm last_drive: drive-up 2021-01-17 10:22:39 ROLLO Friedhelm drive-up 2021-01-17 10:22:39 ROLLO Friedhelm drive-type: modul 2021-01-17 10:22:39 SD_Keeloq SD_Keeloq_AC6000 button: up 2021-01-17 10:22:39 SD_Keeloq SD_Keeloq_AC6000 channel: 9 2021-01-17 10:22:39 SD_Keeloq SD_Keeloq_AC6000 counter_send: 9688 2021-01-17 10:22:39 SD_Keeloq SD_Keeloq_AC6000 send up 2021-01-17 10:22:39 SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: up 2021-01-17 10:22:39 SD_Keeloq SD_Keeloq_AC6000 channel_control: no 2021.01.17 10:23:08 3 : Testname: SD_Keeloq_AC6000 set stop 9 2021-01-17 10:23:08 ROLLO Friedhelm pct: 0 2021-01-17 10:23:08 SD_Keeloq SD_Keeloq_AC6000 button: stop 2021-01-17 10:23:08 SD_Keeloq SD_Keeloq_AC6000 channel: 9 2021-01-17 10:23:08 SD_Keeloq SD_Keeloq_AC6000 counter_send: 9689 2021-01-17 10:23:08 SD_Keeloq SD_Keeloq_AC6000 send stop 2021-01-17 10:23:08 SD_Keeloq SD_Keeloq_AC6000 LastAction_Channel_09: stop 2021-01-17 10:23:08 SD_Keeloq SD_Keeloq_AC6000 channel_control: no 2021-01-17 10:23:08 ROLLO Friedhelm openHabe den Fensterkontakt mal im geschlossenen (und auch mal geöffneten) Zustand geöffnet und geschlossen, zeigt aber leider keine Reaktion im FHEM Log
Der shuttercontrol Befehl (openSleep, closeSleep) wird ohne Zeitverzögerung sofort in FHEM angezeigt und auch direkt ausgeführt.
@FoxRo
Danke für das ausprobieren und deine Geduld -
@dirkhe said in Test Adapter shuttercontrol v1.1.x:
@foxro das ist nicht willkürlich, wenn man a == false abfragst, würde du zb. True zurückbekommen wenn a
Den Zustand false hat oder null oder undefined oder 0
Wenn du a === false abfragt bekommst du auch wirklich nur beim zustsnd false true zurückDanke für Dein Feedback. Ich bin da noch am lernen und bei den "truthy" Werten bin ich unterdessen bei Dir.
Bei einer Prüfung auf "falsy" bin ich noch echt verwirrt.
Einige einschlägige Foren widersprechen sich, wie man auf 'undefined' und 'null' prüfen soll.
Was ich im IoBroker auch schon erlebt habe ist:
if (typeof state != undefined && state != null => liefert false
if (typeof state !== undefined && state !== null => liefert true
Die Erklärung für dieses Verhalten habe ich bis heute noch nicht gefunden, wenn doch eigentlich beide das gleiche Resultat liefern sollten, ausser dass bei der ersten, wenn möglich, vorab eine allfällige Typ-Konvertierung durchgeführt wird.
.. deshalb ist das für mich aktuell schon ein wenig "willkürlich" um es etwas provokativ auszudrücken.
Vielleicht hast Du dazu eine gute Erklärung die mir etwas "Erleuchtung" bringt?
Viele Grüsse, RoliPS. Sorry, ist eigentlich Off-Topic hier.
@foxro typeof musst du mit Anführungszeichen abfragen, also typeof x === 'undefined'
https://developer.mozilla.org/de/docs/Web/JavaScript/Reference/Global_Objects/undefined
Sollten jetzt aber wirklich aufhören, hier den Thread zu sprengen -
Ab sofort steht die Version 1.1.3 auf Github und in kürze auch im latest zur Verfügung ...
Changelog
1.1.3 (2021-01-21)
- (simatec) small fix for objects
@michmein Dein Issue habe ich gesehen und ist registriert ...
Ab sofort steht die Version 1.1.4 auf Github und in kürze auch im latest zur Verfügung ...
Changelog
1.1.4 (2021-01-22)
- (simatec) BugFix Log
- (simatec) DEPENDENCIES updated
- (simatec) Dev-DEPENDENCIES updated
@simatec
habe auf die 1.1.4 aufgerüstet und auch alles andere auf den neuesten Stand gebracht. Leider keine Veränderung. Möchte aber trotzdem kurzfristig auf deinen shuttercontrol wechseln. Müsste ich leider die Fensterkontakte eben anders steuern. -
@tom-haase
In der Version 1.1.4 gibt es dort noch keine Änderungen. Die Änderungen beziehen sich aktuell auf den neuen js-controller.Soweit ich weiß, ist aber @FoxRo an den Anpassungen dran.
@tom-haaseSoweit ich weiß, ist aber @FoxRo an den Anpassungen dran.
Da muss ich euch beiden wohl eine schlechte Nachricht überbringen. Meine Anpassungen sind für eine kleine Erweiterung "einstellbares delay" für das Fenster auf/zu Verhalten geplant. Ich sehe im Moment keinen Einfluss meiner Modifikationen auf das Verhalten bei @Tom-Haase - Sorry tut mir leid.
Da ich nicht weiss, an was es bei Dir liegt, kann ich diesbezüglich auch keine Verbesserung vornehmen. (zumal mein "Pfusch Vorschlag" ebenfalls nichts gebracht hatte.)
Ich überlege mir noch, ob ich das Logging an dieser Stelle etwas verbessern könnte, damit wir mehr Rückmeldung bekommen. Mehr geht aktuell leider nicht.
@Tom-Haase : Wenn wir da einen Schritt weiterkommen wollen, sehe ich im Moment nur noch eine Remote Session (zb. Teamviewer), wo wir uns das mal gemeinsam anschauen können. Alles andere ist "Basteln" und wird Deine Geduld unnötig auf die Probe stellen.
Wie siehst du das?
Viele Grüsse, Roli -
@simatec sehr cool.
Doofe Frage aber funktioniert der Adapter auch mit den nachgerüsteten Bluetooth AM43 blind Drives ?
@foxro sagte in Test Adapter shuttercontrol v1.1.x:
Wie siehst du das?Hi Roli,
ja das wäre super, bin da auch zeitlich ganz flexibel. Gibt es hier PN oder was ähnliches?
Tom -
@tom-haase auf username klicken, dann biste im profil. rechts die 3 punkte: start new chat with ...
Hallo, ist es möglich, bestimmte Rollladen nur fahren zu lassen, wenn der Anwesenheitsstatus auf false bzw. der Urlaubsstatus auf true steht? Ich sehe vermutlich grade einfach den Wald vor lauter Bäumen nicht... danke!
danke für diesen tollen Adapter.
Ganz hab ich es jedoch noch nicht raus mit der Astro bzw. Sonnenschutzeinstellung.
Meine Fenster welche in Richtung "Süden" ausgerichtet sind sollen wie folgt gesteuert werden:
Fenster 1 (Hebeschiebetür) hat laut Kompass: 145°
Nun möchte ich, dass bei einer Sonnenhöhe (Elevation) 17 die Raffstore auf 30 runtergefahren werden.
Beendet soll das ganze werden, sobald "Golden Hour" ist.
Laut Doku:
Astro-Einstellungen
Beenden der Sonnenschutzfunktion mit Sonnenhöhe (Elevation):
Sobald die Sonne die hier eingestellte Höhe unterschreitet, endet die Beschattung durch Shuttercontrol.Sonnenhöhe (Elevation):
Unterschreitet die Elevation den in der individuellen Rollladeneinstellung eingestellten Wert wird der Rollläden gefahren.Jetzt hätte ich folgende Einstellungen erfasst:
Extra-Einstellungen:
Astro: 10In den Einstellungen zur Hebeschiebetür:
Jetzt wurde eben die Hebeschiebetür bei "Elevation" von 13 runtergefahren.
In meiner Logik hätte sie aber erst bei 17 runterfahren sollen auf 30 und am Abend zur Golden Hour wieder hoch.
Bitte um eure Hilfe was ich hier übersehe. Danke
@cuth längen und breitengrad ist in info genau eingetragen?
edit: sorry, auch in shuttercontrol? astroeinstellungen...
@da_woody
ich denke ich habe es.
Ich hatte zuviel +/- Bereich der Sonnenposition für den aktiven Sonnenschutz.
Da war der Wert 50 vorbefüllt.Ist jetzt zum Test auf +/-20.
@cuth oops, auf das hab ich gar nicht geachtet. naja, verwende das auch nicht...
ich halt die daumen... -
@da_woody
Test hat nun geklappt.Hab jetzt zusätzlich zu den Fenster welche eher in Richtung Süden ausgerichtet sind etwas anders gesteuert.
Und zwar: Wenn die Innentemperatur unter 25 Grad sind, mache nichts.
Die Temperatur greife ich mit einem Vaillant Adapter ab.
Ist 25 Grad erreicht und Elevation ist bei 17 und +/- 20 Grad, fahre runter auf beschattung.
Hoch dann wieder mit Golden Hour.Bin gespannt was passiert.
So: Es war soweit.
Die Rollo sind heruntergefahren, weil der Innentemp.Fühler 23,9 Grad angezeigt hatte und 25 Grad mit 5% Hysterese angestellt war.Soweit ist das ja korrekt.
Nun bleiben sie aber da wo sie sind.Liegt das daran, dass der Innentempfühler noch immer 23,9 Grad hat?
Die berechnete Elevation ist aktuell auf 6,2. Beendet soll der Sonnenschutz bei unterschreiten von 10.Frage: Damit die Rollo runterfährt wegen Raumtep. dann sollte ich Elevation rausnehmen oder?
@cuth puh, du stellst aber ganz schöne ansprüche...
tut mir leid, so tief hab ich nicht gebohrt... da bin ich raus.
