    4. FHEM Adapter
    FHEM Adapter
    • LausiD
      LausiD @andi2055 last edited by
      @hg6806 @andi2055
      Falls die angelegten Objekte jetzt so aussehen können wir es so lassen.
      LausiD
        andi2055 @LausiD last edited by
        @LausiD
        funktioniert bei mir auch perfekt.
        Danke dir!
        Anbei 1 Min Debug Log. Sieht aber denke ich gut aus.
        2021-01-09 21:27:00.100 - debug: shuttercontrol.0 (2454) outsidetemperature changed: 0_userdata.0.Außen.Temperatur.Mean_15 Value: 0.7
        2021-01-09 21:27:02.062 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
        2021-01-09 21:27:02.063 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
        2021-01-09 21:27:04.249 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
        2021-01-09 21:27:04.249 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
        2021-01-09 21:27:04.507 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1123 lh"
        2021-01-09 21:27:04.508 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1123 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1123 lh
        2021-01-09 21:27:05.220 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %"
        2021-01-09 21:27:05.221 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 %
        2021-01-09 21:27:05.478 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %"
        2021-01-09 21:27:05.479 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 %
        2021-01-09 21:27:06.604 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C"
        2021-01-09 21:27:06.605 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C
        2021-01-09 21:27:06.611 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C {"val":"29.3 °C","ack":true,"ts":1610224026607,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224026607}
        2021-01-09 21:27:06.911 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.2 °C"
        2021-01-09 21:27:06.912 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.2 °C
        2021-01-09 21:27:07.513 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Wartezeit_BOH: 80 min"
        2021-01-09 21:27:07.513 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Wartezeit_BOH: 80 min | reading > fhem.0.myHPSU.HPSU~Wartezeit_BOH 80 min
        2021-01-09 21:27:08.020 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %"
        2021-01-09 21:27:08.021 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 %
        2021-01-09 21:27:08.782 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
        2021-01-09 21:27:08.782 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
        2021-01-09 21:27:10.360 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 25.6 °C"
        2021-01-09 21:27:10.362 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 25.6 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 25.6 °C
        2021-01-09 21:27:10.367 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 25.6 °C {"val":"25.6 °C","ack":true,"ts":1610224030364,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224030364}
        2021-01-09 21:27:10.389 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.705 kW"
        2021-01-09 21:27:10.391 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.705 kW | reading > fhem.0.myHPSU.Info_Q 4.705 kW
        2021-01-09 21:27:10.395 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.705 kW {"val":"4.705 kW","ack":true,"ts":1610224030392,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224030392}
        2021-01-09 21:27:10.823 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C"
        2021-01-09 21:27:10.824 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26 °C
        2021-01-09 21:27:11.077 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C"
        2021-01-09 21:27:11.078 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C
        2021-01-09 21:27:11.081 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C {"val":"25.7 °C","ack":true,"ts":1610224031079,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224031079}
        2021-01-09 21:27:11.331 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.TVBH: 29.3 °C"
        2021-01-09 21:27:11.331 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.TVBH: 29.3 °C | reading > fhem.0.myHPSU.HPSU~TVBH 29.3 °C
        2021-01-09 21:27:11.794 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
        2021-01-09 21:27:11.795 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
        2021-01-09 21:27:14.902 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
        2021-01-09 21:27:14.903 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
        2021-01-09 21:27:16.233 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_T_direkter_Heizkreis: 29.2 °C"
        2021-01-09 21:27:16.234 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_T_direkter_Heizkreis: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Soll_T_direkter_Heizkreis 29.2 °C
        2021-01-09 21:27:16.540 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_Vorlauftemperatur_Waermeerzeuger: 29.2 °C"
        2021-01-09 21:27:16.541 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_Vorlauftemperatur_Waermeerzeuger: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Soll_Vorlauftemperatur_Waermeerzeuger 29.2 °C
        2021-01-09 21:27:17.494 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
        2021-01-09 21:27:17.495 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
        2021-01-09 21:27:17.748 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1146 lh"
        2021-01-09 21:27:17.749 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1146 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1146 lh
        2021-01-09 21:27:17.753 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Durchfluss 1146 lh {"val":"1146 lh","ack":true,"ts":1610224037751,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224037751}
        2021-01-09 21:27:17.775 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.802 kW"
        2021-01-09 21:27:17.776 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.802 kW | reading > fhem.0.myHPSU.Info_Q 4.802 kW
        2021-01-09 21:27:17.781 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.802 kW {"val":"4.802 kW","ack":true,"ts":1610224037778,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224037778}
        2021-01-09 21:27:18.411 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Betriebsart: Heizen"
        2021-01-09 21:27:18.412 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Betriebsart Heizen
        2021-01-09 21:27:18.665 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %"
        2021-01-09 21:27:18.666 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 %
        2021-01-09 21:27:18.940 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %"
        2021-01-09 21:27:18.940 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 %
        2021-01-09 21:27:19.732 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_Warmwasser: 43.4 °C"
        2021-01-09 21:27:19.734 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_Warmwasser: 43.4 °C | reading > fhem.0.myHPSU.HPSU~T_Warmwasser 43.4 °C
        2021-01-09 21:27:19.741 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_Warmwasser 43.4 °C {"val":"43.4 °C","ack":true,"ts":1610224039737,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224039737}
        2021-01-09 21:27:20.256 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C"
        2021-01-09 21:27:20.257 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C
        2021-01-09 21:27:20.559 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.2 °C"
        2021-01-09 21:27:20.562 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.2 °C
        2021-01-09 21:27:20.907 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_Aussen: -0.2 °C"
        2021-01-09 21:27:20.908 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_Aussen: -0.2 °C | reading > fhem.0.myHPSU.HPSU~T_Aussen -0.2 °C
        2021-01-09 21:27:20.912 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_Aussen -0.2 °C {"val":"-0.2 °C","ack":true,"ts":1610224040909,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224040909}
        2021-01-09 21:27:21.160 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.2 °C"
        2021-01-09 21:27:21.161 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.2 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.2 °C
        2021-01-09 21:27:21.169 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.2 °C {"val":"26.2 °C","ack":true,"ts":1610224041167,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224041167}
        2021-01-09 21:27:21.189 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.001 kW"
        2021-01-09 21:27:21.190 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.001 kW | reading > fhem.0.myHPSU.Info_Q 4.001 kW
        2021-01-09 21:27:21.195 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.001 kW {"val":"4.001 kW","ack":true,"ts":1610224041192,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224041192}
        2021-01-09 21:27:21.621 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 25.9 °C"
        2021-01-09 21:27:21.622 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 25.9 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 25.9 °C
        2021-01-09 21:27:21.626 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 25.9 °C {"val":"25.9 °C","ack":true,"ts":1610224041623,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224041623}
        2021-01-09 21:27:21.874 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C"
        2021-01-09 21:27:21.875 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C
        2021-01-09 21:27:22.287 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %"
        2021-01-09 21:27:22.288 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 %
        2021-01-09 21:27:23.048 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
        2021-01-09 21:27:23.049 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
        2021-01-09 21:27:23.967 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active"
        2021-01-09 21:27:23.968 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active | reading > fhem.0.myHPSU.HPSU~Direkter_Heizkreis_Modus active
        2021-01-09 21:27:24.884 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_T_Raum_1: 21 °C"
        2021-01-09 21:27:24.885 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_T_Raum_1: 21 °C | reading > fhem.0.myHPSU.HPSU~Soll_T_Raum_1 21 °C
        2021-01-09 21:27:25.142 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_Aussen_WP: -0.2 °C"
        2021-01-09 21:27:25.143 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_Aussen_WP: -0.2 °C | reading > fhem.0.myHPSU.HPSU~T_Aussen_WP -0.2 °C
        2021-01-09 21:27:25.147 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_Aussen_WP -0.2 °C {"val":"-0.2 °C","ack":true,"ts":1610224045145,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224045145}
        2021-01-09 21:27:25.854 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
        2021-01-09 21:27:25.854 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
        2021-01-09 21:27:28.545 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1168 lh"
        2021-01-09 21:27:28.546 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1168 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1168 lh
        2021-01-09 21:27:28.548 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Durchfluss 1168 lh {"val":"1168 lh","ack":true,"ts":1610224048546,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224048546}
        2021-01-09 21:27:28.573 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.078 kW"
        2021-01-09 21:27:28.573 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.078 kW | reading > fhem.0.myHPSU.Info_Q 4.078 kW
        2021-01-09 21:27:28.579 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.078 kW {"val":"4.078 kW","ack":true,"ts":1610224048574,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224048574}
        2021-01-09 21:27:29.157 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
        2021-01-09 21:27:29.158 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
        2021-01-09 21:27:29.464 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %"
        2021-01-09 21:27:29.465 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 %
        2021-01-09 21:27:29.721 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %"
        2021-01-09 21:27:29.722 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 %
        2021-01-09 21:27:30.849 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C"
        2021-01-09 21:27:30.850 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C
        2021-01-09 21:27:31.216 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.3 °C"
        2021-01-09 21:27:31.218 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.3 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.3 °C
        2021-01-09 21:27:31.224 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.214 kW"
        2021-01-09 21:27:31.225 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.214 kW | reading > fhem.0.myHPSU.Info_Q 4.214 kW
        2021-01-09 21:27:31.228 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.3 °C {"val":"29.3 °C","ack":true,"ts":1610224051219,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224051219}
        2021-01-09 21:27:31.230 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.214 kW {"val":"4.214 kW","ack":true,"ts":1610224051226,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224051226}
        2021-01-09 21:27:31.605 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.1 °C"
        2021-01-09 21:27:31.606 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.1 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.1 °C
        2021-01-09 21:27:31.611 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.1 °C {"val":"26.1 °C","ack":true,"ts":1610224051607,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224051607}
        2021-01-09 21:27:31.630 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.350 kW"
        2021-01-09 21:27:31.631 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.350 kW | reading > fhem.0.myHPSU.Info_Q 4.350 kW
        2021-01-09 21:27:31.633 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.350 kW {"val":"4.350 kW","ack":true,"ts":1610224051632,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224051632}
        2021-01-09 21:27:32.061 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C"
        2021-01-09 21:27:32.062 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26 °C
        2021-01-09 21:27:32.066 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26 °C {"val":"26 °C","ack":true,"ts":1610224052064,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224052064}
        2021-01-09 21:27:32.319 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C"
        2021-01-09 21:27:32.319 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C
        2021-01-09 21:27:32.724 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %"
        2021-01-09 21:27:32.725 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 %
        2021-01-09 21:27:33.031 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
        2021-01-09 21:27:33.032 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
        2021-01-09 21:27:36.136 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
        2021-01-09 21:27:36.137 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
        2021-01-09 21:27:38.330 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
        2021-01-09 21:27:38.330 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
        2021-01-09 21:27:41.021 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1146 lh"
        2021-01-09 21:27:41.022 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1146 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1146 lh
        2021-01-09 21:27:41.024 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Durchfluss 1146 lh {"val":"1146 lh","ack":true,"ts":1610224061023,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224061023}
        2021-01-09 21:27:41.049 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.268 kW"
        2021-01-09 21:27:41.050 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.268 kW | reading > fhem.0.myHPSU.Info_Q 4.268 kW
        2021-01-09 21:27:41.053 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.268 kW {"val":"4.268 kW","ack":true,"ts":1610224061051,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224061051}
        2021-01-09 21:27:41.631 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
        2021-01-09 21:27:41.632 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
        2021-01-09 21:27:41.935 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %"
        2021-01-09 21:27:41.936 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 %
        2021-01-09 21:27:42.192 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %"
        2021-01-09 21:27:42.193 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 %
        2021-01-09 21:27:43.319 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.2 °C"
        2021-01-09 21:27:43.320 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.2 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.2 °C
        2021-01-09 21:27:43.323 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.2 °C {"val":"29.2 °C","ack":true,"ts":1610224063321,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224063321}
        2021-01-09 21:27:43.626 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.3 °C"
        2021-01-09 21:27:43.627 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.3 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.3 °C
        2021-01-09 21:27:44.020 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.1 °C"
        2021-01-09 21:27:44.021 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 26.1 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26.1 °C
        2021-01-09 21:27:44.480 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C"
        2021-01-09 21:27:44.480 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26 °C
        2021-01-09 21:27:44.744 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C"
        2021-01-09 21:27:44.747 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C
        2021-01-09 21:27:44.990 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.TVBH: 29.2 °C"
        2021-01-09 21:27:44.991 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.TVBH: 29.2 °C | reading > fhem.0.myHPSU.HPSU~TVBH 29.2 °C
        2021-01-09 21:27:44.996 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~TVBH 29.2 °C {"val":"29.2 °C","ack":true,"ts":1610224064993,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224064993}
        2021-01-09 21:27:45.346 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %"
        2021-01-09 21:27:45.347 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 %
        2021-01-09 21:27:45.651 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
        2021-01-09 21:27:45.651 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
        2021-01-09 21:27:47.448 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_T_direkter_Heizkreis: 29.2 °C"
        2021-01-09 21:27:47.448 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_T_direkter_Heizkreis: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Soll_T_direkter_Heizkreis 29.2 °C
        2021-01-09 21:27:47.755 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_Vorlauftemperatur_Waermeerzeuger: 29.2 °C"
        2021-01-09 21:27:47.755 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_Vorlauftemperatur_Waermeerzeuger: 29.2 °C | reading > fhem.0.myHPSU.HPSU~Soll_Vorlauftemperatur_Waermeerzeuger 29.2 °C
        2021-01-09 21:27:49.169 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
        2021-01-09 21:27:49.170 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
        2021-01-09 21:27:49.918 - debug: fhem.0 (16732) [setAlive] start setAlive 300 sec
        2021-01-09 21:27:49.923 - info: fhem.0 (16732) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
        2021-01-09 21:27:49.933 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "dummy fhem.0.alive on"
        2021-01-09 21:27:49.933 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive true - start
        2021-01-09 21:27:49.936 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive reset timer
        2021-01-09 21:27:49.937 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610224069920,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069920}
        2021-01-09 21:27:49.954 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Commands.resultFHEM {"val":"","ack":true,"ts":1610224069941,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069941}
        2021-01-09 21:27:49.955 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Info.alive true {"val":true,"ack":true,"ts":1610224069942,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610223769942}
        2021-01-09 21:27:49.955 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Debug.numberIn 144 {"val":144,"ack":true,"ts":1610224069942,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069942}
        2021-01-09 21:27:49.960 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Debug.timeIn 5 {"val":5,"ack":true,"ts":1610224069943,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069943}
        2021-01-09 21:27:49.961 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Debug.numberOut 0 {"val":0,"ack":true,"ts":1610224069944,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610131742427}
        2021-01-09 21:27:49.962 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Debug.timeOut null {"val":null,"ack":true,"ts":1610224069944,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069944}
        2021-01-09 21:27:49.967 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Commands.lastCommand set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1610224069951,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069951}
        2021-01-09 21:27:49.969 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM done {"val":"done","ack":true,"ts":1610224069957,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224069957}
        2021-01-09 21:27:51.359 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.ehs: 0 kWh"
        2021-01-09 21:27:51.360 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.ehs: 0 kWh | reading > fhem.0.myHPSU.HPSU~ehs 0 kWh
        2021-01-09 21:27:51.613 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Durchfluss: 1146 lh"
        2021-01-09 21:27:51.614 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Durchfluss: 1146 lh | reading > fhem.0.myHPSU.HPSU~Durchfluss 1146 lh
        2021-01-09 21:27:52.328 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 %"
        2021-01-09 21:27:52.331 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UV_DHW: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UV_DHW 0 %
        2021-01-09 21:27:52.581 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.UWPumpe: 50 %"
        2021-01-09 21:27:52.582 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.UWPumpe: 50 % | reading > fhem.0.myHPSU.HPSU~UWPumpe 50 %
        2021-01-09 21:27:53.450 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Soll_T_Warmwasser: 46 °C"
        2021-01-09 21:27:53.450 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Soll_T_Warmwasser: 46 °C | reading > fhem.0.myHPSU.HPSU~Soll_T_Warmwasser 46 °C
        2021-01-09 21:27:53.920 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C"
        2021-01-09 21:27:53.921 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.T_direkter_Heizkreis: 29.3 °C | reading > fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C
        2021-01-09 21:27:53.924 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~T_direkter_Heizkreis 29.3 °C {"val":"29.3 °C","ack":true,"ts":1610224073922,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224073922}
        2021-01-09 21:27:54.223 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.4 °C"
        2021-01-09 21:27:54.225 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Vorlauftemperatur_Waermeerzeuger: 29.4 °C | reading > fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.4 °C
        2021-01-09 21:27:54.229 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Vorlauftemperatur_Waermeerzeuger 29.4 °C {"val":"29.4 °C","ack":true,"ts":1610224074227,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224074227}
        2021-01-09 21:27:54.243 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.402 kW"
        2021-01-09 21:27:54.244 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.402 kW | reading > fhem.0.myHPSU.Info_Q 4.402 kW
        2021-01-09 21:27:54.248 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.402 kW {"val":"4.402 kW","ack":true,"ts":1610224074245,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224074245}
        2021-01-09 21:27:54.624 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Heizung_Ruecklauf: 26 °C"
        2021-01-09 21:27:54.625 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Heizung_Ruecklauf: 26 °C | reading > fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26 °C
        2021-01-09 21:27:54.629 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Heizung_Ruecklauf 26 °C {"val":"26 °C","ack":true,"ts":1610224074627,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224074627}
        2021-01-09 21:27:54.652 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU Info.Q: 4.535 kW"
        2021-01-09 21:27:54.653 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU Info.Q: 4.535 kW | reading > fhem.0.myHPSU.Info_Q 4.535 kW
        2021-01-09 21:27:54.657 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.Info_Q 4.535 kW {"val":"4.535 kW","ack":true,"ts":1610224074655,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224074655}
        2021-01-09 21:27:55.083 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26.1 °C"
        2021-01-09 21:27:55.084 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Kaeltemitteltemperatur: 26.1 °C | reading > fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26.1 °C
        2021-01-09 21:27:55.087 - debug: fhem.0 (16732) [stateChange] stateChange (in): fhem.0.myHPSU.HPSU~Kaeltemitteltemperatur 26.1 °C {"val":"26.1 °C","ack":true,"ts":1610224075085,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1610224075085}
        2021-01-09 21:27:55.341 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C"
        2021-01-09 21:27:55.342 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Ruecklauftemperatur: 25.7 °C | reading > fhem.0.myHPSU.HPSU~Ruecklauftemperatur 25.7 °C
        2021-01-09 21:27:55.747 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 %"
        2021-01-09 21:27:55.747 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Pos_Vent_3UVB1: 0 % | reading > fhem.0.myHPSU.HPSU~Pos_Vent_3UVB1 0 %
        2021-01-09 21:27:56.513 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen"
        2021-01-09 21:27:56.514 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Aktive_Betriebsart: Heizen | reading > fhem.0.myHPSU.HPSU~Aktive_Betriebsart Heizen
        2021-01-09 21:27:57.430 - debug: fhem.0 (16732) [main] [eventFHEM] eventFHEM(in): "HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active"
        2021-01-09 21:27:57.431 - debug: fhem.0 (16732) [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] event FHEM: myHPSU | HPSU myHPSU HPSU.Direkter_Heizkreis_Modus: active | reading > fhem.0.myHPSU.HPSU~Direkter_Heizkreis_Modus active
        So sieht's aus
        • D3ltoroxp
          D3ltoroxp @andi2055 last edited by
          @andi2055 Ich bräuchte mal noch eure Hilfe. Soweit läuft der Adapter Top, ich bräuchte hier noch die Buttons in ioBroker, damit ich die Rollos zum fahren forcen kann, auch wenn das Rollo Device sagt der Rollo sei unten. Hier kann ich dennoch drücken und er fährt, falls er noch oben ist. Aber ich habe hier keine attr die ich adden könnte.
          Fällt euch dazu was ein, wie ich das dennoch über ioB steuern kann, bräuchte das für die VIS ?
          LausiD 1 Reply Last reply Reply Quote 0
          • LausiD
            LausiD @D3ltoroxp last edited by
            @d3ltoroxp
            Mh wenn du den Befehl dafür kennst, kannst du zB im ioB über fhem.0.info.Commands.sendFHEM den Befehl eingeben.
            Gruß LausiD
              Banis @LausiD last edited by
              seit ein paar Tagen habe ich beim HPSU Modul das Problem, dass sehr häufig in den Datenpunkten in ioBRoker statt dem eigentlichen Wert ganz kurz ein Punkt drin steht. Bei den anderen FHEM Modlen konnte ich das nicht beobachten.
              Habt ihr das Problem auch?
                andi2055 @Banis last edited by
                @banis
                Es gab ein Update beim FHEM HPSU Modul mit größeren Anpassungen.
                Ich teste das auch gerade.
                Kannst du überhaupt noch Werte verändern aus ioB heraus? Bspw. Heizkurve
                Der Punkt stand in früheren Versionen bei mir in alles States, die zum Setzen der Werte vorhanden waren. Nun gibt es diese bei mir nicht mehr. Das wurde anscheinend zusammengelegt?
                B LausiD 2 Replies Last reply Reply Quote 0
                  Banis @andi2055 last edited by
                  @andi2055 Ich bin zwischenzeitlich wieder zurück auf die Modul Version 1.10
                  Ich konnt aber mit der 1.11 auch Werte schreiben. Bin mir jetzt aber nicht mehr ganz sicher wie ich das gemacht hab, ich glaube das ging in den Datenpunkten wo auch die Werte gelesen werden. Musst dort mal ausprobieren ob du dort auch schreiben kannst.
                  Dadurch dass immer wieder ein . im Datenpunkt war, wurden meine Logs ziemlich voll. Dadurch hat sich dann mein history Adapter immer mal wieder verabschiedet. Deshalb bin ich beim HPSU Modul eine Version zurück gegangen
                  • LausiD
                    @andi2055
                    Kannst du mal von der neuen Version ein jsonlist2 aus FHEM oder RAW aus ioBroker zeigen?
                      @lausid
                      anbei jsonlist2 der neuen FHEM HPSU Adapter Version 1.11
                      Ich habe mich nun nochmal etwas damit beschäftigt:
                      Alle schreibbaren Werte waren bei mir nach dem Update nicht schreibbar. Das war mein Hauptproblem.
                      HPSU~Heizkurve (als Beispiel) stand bei mir nach dem Update auf Readonly. Wäre das bei Neuanlage (Instanz löschen und neu erstellen) auch schreibbar gewesen und wird nur nicht automatisch angepasst?
                      Ich habe alle schreibbaren Werte manuell auf WRITE gestellt und nun kann ich damit Werte auch setzen.
                      Funktioniert also grundsätzlich bei mir.
                      Alle Werte, die nicht in Readings enthalten sind (Beispiel: HPSU~HZ_Unterstuetzung), enthalten bei mir einen ".". Ich kann die Werte ON/OFF aber auswählen und setzen. Soweit aus meiner Sicht ok.
                      @Banis dein Problem kann ich so nicht bestätigen. Das musst du bitte nochmal genauer erklären
                          "Name":"myHPSU",
                          "PossibleSets":"Disconnect:noArg Connect:noArg ForceDHW:noArg Connect_MonitorMode:noArg HPSU.Kuehl_Soll_Korr_Parallel:slider,-5,0.1,5,1 HPSU.Spreizung_Mod_HZ:slider,2,1,20 HPSU.WW_Sperrzeit:slider,0,1,240 HPSU.Bivalenzfunktion:off,on HPSU.Funktion_EHS:slider,0,1,3 HPSU.HK_Funktion:Witterung,Fest HPSU.Heizkurve:slider,0,0.1,3,1 HPSU.HZ_Unterstuetzung:off,on HPSU.Max_WW_Ladezeit:slider,0,1,240 HPSU.Max_Leistung_Pumpe:slider,20,1,100 HPSU.Max_T_Vorlauf:slider,20,1,90 HPSU.Kuehlen_A_Temp_Max:slider,20,1,45 HPSU.Min_Leistung_Pumpe:slider,10,1,100 HPSU.Min_T_Vorlauf:slider,18,1,90 HPSU.Kuehlen_VL_Soll_Abs_Min:slider,5,1,25 HPSU.Betriebsart:Bereitschaft,Auto1,Auto2,Kuehlen,Heizen,Absenken,Sommer HPSU.Fluesterbetrieb:Aus,Ein,Nur_bei_Nacht HPSU.Kuehlen_A_Temp_Start:slider,15,1,45 HPSU.Schaltschwelle_AUX_TDHW:slider,20,1,85 HPSU.Soll_T_Warmwasser_1:slider,35,1,70 HPSU.Soll_T_Warmwasser_2:slider,35,1,70 HPSU.Soll_T_Warmwasser_3:slider,35,1,70 HPSU.Kuehlen_VL_Soll_Max:slider,5,1,25 HPSU.Kuehlen_VL_Soll_Start:slider,5,1,25 HPSU.T_Vorlauf_Tag:slider,20,1,90 HPSU.T_Vorlauf_Nacht:slider,20,1,90 HPSU.T_Frostschutz:-1,-10,-11,-12,-13,-14,-15,Aus,-2,-3,-4,-5,-6,-7,-8,-9,0,1,2,3,4,5 HPSU.Heizgrenze_Tag:slider,10,1,40 HPSU.Heizgrenze_Nacht:slider,10,1,40 HPSU.Soll_T_Raum_1:slider,5,0.5,40,1 HPSU.Soll_T_Raum_2:slider,5,0.5,40,1 HPSU.Soll_T_Raum_3:slider,5,0.5,40,1 HPSU.TDiff_WW_HZU:slider,2,1,15 HPSU.Wartezeit_BOH:slider,20,1,95 ",
                          "PossibleAttrs":"alias comment:textField-long eventMap:textField-long group room suppressReading userReadings:textField-long verbose:0,1,2,3,4,5 AutoPoll:on,off AntiMixerSwing:on,off CheckDHWInterrupted:on,off DebugLog:on,onWithMsg,onDHW,off AntiContinousHeating:on,off RememberSetValues:on,off SuppressRetryWarnings:on,off event-aggregator event-min-interval event-on-change-reading event-on-update-reading oldreadings stateFormat:textField-long timestamp-on-change-reading cmdIcon devStateIcon:textField-long devStateStyle icon sortby webCmd webCmdLabel:textField-long widgetOverride userattr",
                          "Internals": {
                            "DEF": "/dev/ttyUSB0",
                            "DeviceName": "/dev/ttyUSB0@38400",
                            "ELM327_Version": "1.5",
                            "ELMState": "Initialized",
                            "FD": "8",
                            "FUUID": "5ff83ab7-f33f-256f-ffb1-ea0f07c2844b852e",
                            "JSON_Auto_poll": "47",
                            "JSON_Writable": "100",
                            "JSON_parameters": "156",
                            "JSON_version": "3.6",
                            "Module_Version": "1.11",
                            "NAME": "myHPSU",
                            "NR": "21",
                            "PARTIAL": "",
                            "STATE": "opened",
                            "TYPE": "HPSU"
                          "Readings": {
                            "Comm.GetStatus": { "Value":"Ok", "Time":"2021-01-23 22:54:03" },
                            "Comm.ManStatus": { "Value":"Ok: (force) DHW still active (717)", "Time":"2021-01-19 11:04:07" },
                            "Comm.SetStatus": { "Value":"Ok: Heizkurve [heat_slope] successfully set to 0.4 (1011)", "Time":"2021-01-23 22:35:59" },
                            "HPSU.Aktive_Betriebsart": { "Value":"Standby", "Time":"2021-01-23 22:53:56" },
                            "HPSU.Betriebsart": { "Value":"Heizen", "Time":"2021-01-23 22:53:56" },
                            "HPSU.Direkter_Heizkreis_Modus": { "Value":"power-saving", "Time":"2021-01-23 22:53:57" },
                            "HPSU.Durchfluss": { "Value":"0 lh", "Time":"2021-01-23 22:53:52" },
                            "HPSU.EHS_fuer_Heizung": { "Value":"2245 kWh", "Time":"2021-01-23 22:49:35" },
                            "HPSU.EHS_fuer_WW": { "Value":"706 kWh", "Time":"2021-01-23 22:49:34" },
                            "HPSU.Energie_Heizung": { "Value":"4366 kWh", "Time":"2021-01-23 22:49:35" },
                            "HPSU.Energie_Kuehlung": { "Value":"1803 kWh", "Time":"2021-01-23 22:49:39" },
                            "HPSU.Energie_WW": { "Value":"6949 kWh", "Time":"2021-01-23 22:49:35" },
                            "HPSU.Energie_erzeugt_gesamt": { "Value":"12386 kWh", "Time":"2021-01-23 22:49:39" },
                            "HPSU.Fluesterbetrieb": { "Value":"Aus", "Time":"2021-01-23 22:45:35" },
                            "HPSU.Funktion_EHS": { "Value":"1", "Time":"2021-01-23 22:45:25" },
                            "HPSU.HK_Funktion": { "Value":"Witterung", "Time":"2021-01-23 22:45:25" },
                            "HPSU.Heizgrenze_Tag": { "Value":"21 °C", "Time":"2021-01-23 22:46:57" },
                            "HPSU.Heizkurve": { "Value":"0.4", "Time":"2021-01-23 22:46:01" },
                            "HPSU.Heizung_Ruecklauf": { "Value":"25.6 °C", "Time":"2021-01-23 22:53:55" },
                            "HPSU.Kaeltemitteltemperatur": { "Value":"25.1 °C", "Time":"2021-01-23 22:53:51" },
                            "HPSU.Kuehl_Soll_Korr_Parallel": { "Value":"0 °C", "Time":"2021-01-23 22:45:34" },
                            "HPSU.Kuehlen_A_Temp_Max": { "Value":"35 °C", "Time":"2021-01-23 22:45:26" },
                            "HPSU.Kuehlen_A_Temp_Start": { "Value":"22 °C", "Time":"2021-01-23 22:45:36" },
                            "HPSU.Kuehlen_VL_Soll_Abs_Min": { "Value":"16 °C", "Time":"2021-01-23 22:45:26" },
                            "HPSU.Kuehlen_VL_Soll_Max": { "Value":"10 °C", "Time":"2021-01-23 22:45:36" },
                            "HPSU.Kuehlen_VL_Soll_Start": { "Value":"18 °C", "Time":"2021-01-23 22:45:40" },
                            "HPSU.Laufzeit_Kompressor": { "Value":"7130 h", "Time":"2021-01-23 22:49:40" },
                            "HPSU.Laufzeit_UWPumpe": { "Value":"12397 h", "Time":"2021-01-23 22:49:40" },
                            "HPSU.Max_T_Vorlauf": { "Value":"45 °C", "Time":"2021-01-23 22:45:26" },
                            "HPSU.Min_T_Vorlauf": { "Value":"27 °C", "Time":"2021-01-23 22:45:26" },
                            "HPSU.Pos_Vent_3UVB1": { "Value":"100 %", "Time":"2021-01-23 22:53:52" },
                            "HPSU.Pos_Vent_3UV_DHW": { "Value":"0 %", "Time":"2021-01-23 22:54:03" },
                            "HPSU.Ruecklauftemperatur": { "Value":"24.6 °C", "Time":"2021-01-23 22:53:52" },
                            "HPSU.Soll_T_Raum_1": { "Value":"20.5 °C", "Time":"2021-01-23 22:53:36" },
                            "HPSU.Soll_T_Warmwasser": { "Value":"46 °C", "Time":"2021-01-23 22:53:23" },
                            "HPSU.Soll_T_Warmwasser_1": { "Value":"46 °C", "Time":"2021-01-14 07:53:11" },
                            "HPSU.Soll_T_direkter_Heizkreis": { "Value":"27.1 °C", "Time":"2021-01-23 22:53:51" },
                            "HPSU.Soll_Vorlauftemperatur_Waermeerzeuger": { "Value":"0 °C", "Time":"2021-01-23 22:53:39" },
                            "HPSU.TDiff_WW_HZU": { "Value":"5 °C", "Time":"2021-01-23 22:45:29" },
                            "HPSU.TVBH": { "Value":"37.8 °C", "Time":"2021-01-23 22:53:33" },
                            "HPSU.T_Aussen": { "Value":"4.5 °C", "Time":"2021-01-23 22:53:33" },
                            "HPSU.T_Aussen_WP": { "Value":"4.5 °C", "Time":"2021-01-23 22:53:36" },
                            "HPSU.T_Aussen_gemittelt": { "Value":"4.7 °C", "Time":"2021-01-23 22:52:21" },
                            "HPSU.T_Frostschutz": { "Value":"-10", "Time":"2021-01-23 22:53:54" },
                            "HPSU.T_Warmwasser": { "Value":"46.4 °C", "Time":"2021-01-23 22:53:57" },
                            "HPSU.T_direkter_Heizkreis": { "Value":"37.4 °C", "Time":"2021-01-23 22:53:54" },
                            "HPSU.UWPumpe": { "Value":"0 %", "Time":"2021-01-23 22:54:04" },
                            "HPSU.Vorlauftemperatur_Waermeerzeuger": { "Value":"30.8 °C", "Time":"2021-01-23 22:53:54" },
                            "HPSU.Wartezeit_BOH": { "Value":"80 min", "Time":"2021-01-23 22:52:37" },
                            "HPSU.Wasserdruck": { "Value":"1.566 bar", "Time":"2021-01-23 22:45:33" },
                            "HPSU.ehs": { "Value":"0 kWh", "Time":"2021-01-23 22:53:56" },
                            "Info.HeatCyclicErr": { "Value":"0", "Time":"2021-01-23 20:50:15" },
                            "Info.LastDefrostDHWShrink": { "Value":"0.599999999999994 °C", "Time":"2021-01-23 19:57:26" },
                            "Info.Q": { "Value":"0 kW", "Time":"2021-01-23 20:50:15" },
                            "state": { "Value":"opened", "Time":"2021-01-21 23:25:40" }
                          "Attributes": {
                            "AntiContinousHeating": "on",
                            "AntiMixerSwing": "off",
                            "AutoPoll": "on",
                            "CheckDHWInterrupted": "on",
                            "DebugLog": "on",
                            "SuppressRetryWarnings": "on",
                            "alias": "myHPSU",
                            "room": "HPSU"
                      • LausiD
                        @andi2055
                        Auf was steht fhem.0.info.Configurations.autoRole bei dir?
                        Du kannst auch ein einzelnes Objekt löschen..zB HPSU~Heizkurve.....Adapter neu starten und Objekt wird wieder angelegt.
                        Instanz löschen und neuanlegen ist nie nötig!
                        Gruß LausiD
                          @lausid
                          steht auf true.
                          An der Stelle habe ich auch noch nie was geändert
                          Aber Danke, ich weiß jetzt wie es geht
                            Banis @andi2055 last edited by Banis
                            @andi2055 Ich hab eben nochmal auf die 1.11 upgedatet. Ist bei mir leider immer noch so. Es scheint so, also ob immer wenn vom FHEM Modul Werte an ioBroker übertragen werden, bei vielen Readings immer kurz ein Punkt gesetzt wird.
                            Dadurch habe ich permanet Zustandsänderungen, was die Performance des History-Adapters sehr verschlechtert.
                            Ich hab als Beispeil mal die Werte der Betriebsart in einem Zeitraum von knapp 2 Minuten dargestellt.
                            • LausiD
                              LausiD @Banis last edited by
                              @banis
                              Hast du den FHEM Adapter über github aktualisiert?
                              Deine Beschreibung hört sich stark nach dem Problem in 1.5.3 an.
                              Gruß LausiD
                                @lausid Hab jetzt nochmal über github aktualisiert. Aber eine neuere Version als die 1.5.3 bekomme ich nicht. Oder mache ich was falsch?
                                • LausiD
                                  @banis
                                  Version bleibt bei 1.5.3
                                  BuildDate ist 17.01.21 - wird beim Start Adapter angezeigt
                                    @lausid jetzt sieht es bei mir auch gut aus. Lag dann tatsächlich an dem Update.
                                    Vielen Dank für deine Hilfe
                                      TWART016 last edited by TWART016
                                      Ich übertrage alle Werte eines Gerätes von ioBroker zu FHEM. In FHEM wird ein Raum ioB_IN für jedes der Werte ein eigener dummy angelgt.
                                      1. Der Name des dummy ist immer der Pfad. Bei Tuya Geräten ist das eine ID, z.B. tuya.0.6423236140f520f6f20c.2. Könnte das Gerät in ioB oder FHEM umbenannt werden?
                                      2. allowedIOBin sagt, welche Geräte an FHEM gesendet werden. Alles was damit beginnt, wird übetragen. Trage ich nun das ein tuya.0.6423236140f520f6f20c.1 wird aber auch tuya.0.6423236140f520f6f20c.11 gesendet. Wie kann ich das verhindern?
                                      3. Bei dem Tuya Gerät werden insgesamt 13 dummys angelegt, jeweils mit dem attr group [ioB Device]. Ist es möglich nur ein dummy nazulegen und die ganzen Werte aus ioB als FHEM readings?
                                      4. Ich habe bei dem Tuya Gerät insgesamt 6 "Buttons" welche getrennt in FHEM geschalten werden soll. Ausgeführt werden soll diese Aktion in ioB. Wie mache das am besten?
                                      • LausiD
                                        LausiD @TWART016 last edited by LausiD
                                        @twart016 sagte in FHEM Adapter:
                                        1. Ich habe bei dem Tuya Gerät insgesamt 6 "Buttons" welche getrennt in FHEM geschalten werden soll. Ausgeführt werden soll diese Aktion in ioB. Wie mache das am besten?
                                        FHEM Raum ioB_System mit fhem.0.send2ioB kannst du Befehle an Iob senden.
                                        Name Objekt Taster + Leerzeichen+true
                                        Gruß LausiD
                                        • LausiD
                                          1. allowedIOBin sagt, welche Geräte an FHEM gesendet werden. Alles was damit beginnt, wird übetragen. Trage ich nun das ein tuya.0.6423236140f520f6f20c.1 wird aber auch tuya.0.6423236140f520f6f20c.11 gesendet. Wie kann ich das verhindern?
                                          Ein weiterer Punkt hinter tuya.0.xxxxxx.1. sollte die Lösung sein
                                          Gruß LausiD
                                            TWART016 @LausiD last edited by TWART016
                                            @lausid
                                            2:. Funktioniert leider nicht mit tuya.0.6423236140f520f6f20c.1.
                                            Es wird nichts angelegt
                                            1: Umbenennen geht nicht?
                                            3: Gibt es vllt die Möglichkeit die Werte in einem dummy anzulegen?
                                            81.1k
                                            adapter fhem
                                            82
                                            676
                                            193908
