    4. Viessmann API
    Viessmann API
      walter12 @UncleSam last edited by walter12
      viessmannapi.0	2021-01-22 11:38:20.204	error	(13916) could not connect using email and password, check credentials!
      viessmannapi.0	2021-01-22 11:38:20.203	error	(13916) error connecting: {}
      viessmannapi.0	2021-01-22 11:38:19.970	info	(13916) ViessmannClient: initializing with pollIntervall 120000
      viessmannapi.0	2021-01-22 11:38:19.922	info	(13916) starting adapter...
      viessmannapi.0	2021-01-22 11:38:19.882	info	(13916) starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v12.20.1, js-controller: 3.1.6
      viessmannapi.0	2021-01-22 11:38:14.234	info	(13901) Got terminate signal TERMINATE_YOURSELF
      viessmannapi.0	2021-01-22 11:38:13.730	info	(13901) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      viessmannapi.0	2021-01-22 11:38:13.728	info	(13901) terminating
      viessmannapi.0	2021-01-22 11:38:13.724	info	(13901) Got terminate signal TERMINATE_YOURSELF
      viessmannapi.0	2021-01-22 11:37:57.780	error	(13901) could not connect using email and password, check credentials!
      viessmannapi.0	2021-01-22 11:37:57.779	error	(13901) error connecting: {}
      viessmannapi.0	2021-01-22 11:37:57.543	info	(13901) ViessmannClient: initializing with pollIntervall 120000
      viessmannapi.0	2021-01-22 11:37:57.466	info	(13901) starting adapter...
      viessmannapi.0	2021-01-22 11:37:57.426	info	(13901) starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v12.20.1, js-controller: 3.1.6
      viessmannapi.0	2021-01-22 11:31:16.462	info	(13754) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      viessmannapi.0	2021-01-22 11:31:16.459	info	(13754) terminating
      viessmannapi.0	2021-01-22 11:31:16.453	info	(13754) Got terminate signal TERMINATE_YOURSELF
      • wendy2702
        wendy2702 @walter12 last edited by
        @walter12
        Eigentlich steht es ja im log:
        Aber hast du die Instanz auf Debug umgestellt?
          walter12 @wendy2702 last edited by walter12
          C2C91409-D28E-4B33-BBB5-B7AF3EB55E88.png 0D4D9738-A8A8-40A5-B054-CD5546C8FBD9.png
          • wendy2702
            @walter12
            Stand er jetzt auf Debug oder hast du Ihn gerade auf Debug gestellt?
            Wenn gerade erst umgestellt, die Instanz neu starten und das log erneut posten.
              @wendy2702 !
              Ich hab es gerade nochmal neu installiert. Hier das eine Bild
              Das Debug stand vorher schon dort.
              viessmannapi.0	2021-01-22 12:59:09.115	debug	(14132) system.adapter.admin.0: logging true
              viessmannapi.0	2021-01-22 12:58:11.939	debug	(14132) system.adapter.admin.0: logging false
              viessmannapi.0	2021-01-22 12:57:50.705	error	(14132) could not connect using email and password, check credentials!
              viessmannapi.0	2021-01-22 12:57:50.703	error	(14132) error connecting: {"status":502}
              viessmannapi.0	2021-01-22 12:57:50.302	debug	(14132) OAuthClient: GET https://api.viessmann-platform.io/operational-data/installations/8114/gateways/7571381614636109/devices/0/features - payload undefined
              viessmannapi.0	2021-01-22 12:57:50.011	debug	(14132) OAuthClient: GET https://api.viessmann-platform.io/general-management/installations - payload undefined
              viessmannapi.0	2021-01-22 12:57:50.009	debug	(14132) ViessmannClient: requesting installation details during initialization
              viessmannapi.0	2021-01-22 12:57:49.848	debug	(14132) OAuthClient: requesting initial access token using authCode=O5wZiH6u7TWBliCJI0h9RiPZBL9O2MKUJtS5hQwhiYU
              viessmannapi.0	2021-01-22 12:57:49.478	debug	(14132) OAuthClient: requesting authorization code
              viessmannapi.0	2021-01-22 12:57:49.476	debug	(14132) OAuthClient: initializing client
              viessmannapi.0	2021-01-22 12:57:49.473	info	(14132) ViessmannClient: initializing with pollIntervall 120000
              viessmannapi.0	2021-01-22 12:57:49.379	info	(14132) starting adapter...
              viessmannapi.0	2021-01-22 12:57:49.331	info	(14132) starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v12.20.1, js-controller: 3.1.6
              viessmannapi.0	2021-01-22 12:57:49.011	debug	(14132) statesDB connected
              viessmannapi.0	2021-01-22 12:57:49.009	debug	(14132) States connected to redis: 127.0.0.1:9000
              viessmannapi.0	2021-01-22 12:57:48.997	debug	(14132) States create System PubSub Client
              viessmannapi.0	2021-01-22 12:57:48.992	debug	(14132) States create User PubSub Client
              viessmannapi.0	2021-01-22 12:57:48.980	debug	(14132) Redis States: Use Redis connection: 127.0.0.1:9000
              viessmannapi.0	2021-01-22 12:57:48.976	debug	(14132) objectDB connected
              viessmannapi.0	2021-01-22 12:57:48.965	debug	(14132) Objects connected to redis: 127.0.0.1:9001
              viessmannapi.0	2021-01-22 12:57:48.947	debug	(14132) Objects client initialize lua scripts
              viessmannapi.0	2021-01-22 12:57:48.945	debug	(14132) Objects create User PubSub Client
              viessmannapi.0	2021-01-22 12:57:48.943	debug	(14132) Objects create System PubSub Client
              viessmannapi.0	2021-01-22 12:57:48.937	debug	(14132) Objects client ready ... initialize now
              viessmannapi.0	2021-01-22 12:57:48.890	debug	(14132) Redis Objects: Use Redis connection: 127.0.0.1:9001
              wendy2702 2 Replies Last reply Reply Quote 0
              • wendy2702
                @walter12 sagte in Viessmann API:
                Schau mal hier:
                https://github.com/thovid/ioBroker.viessmannapi/issues/42
                FabianHM created this issue in thovid/ioBroker.viessmannapi
                closed error fetching features: Request failed with status 502 #42
                • wendy2702
                  @walter12
                  Wäre auch schön wenn du uns weiterhin auf dem laufenden halten würdest.
                    @wendy2702
                    Leider keine Änderungen trotz o.g. Link. 😞
                    Das Interessante ist, dass die Vissmann (orginal bei ioBroker) dabei funktioniert zumindest grün leuchtet
                    • wendy2702
                      @walter12 was meinst du mit Original Viessmann?
                        @wendy2702
                        ja.
                        Wegen der Viessmann API hab ich mich jetzt mit Viessmann in Verbindung gesetzt. Ich bin gespannt, ob Sie mir weiterhelfen können.
                        Antwort von Viessmann
                        Zudem ist die Viessmann-API noch nicht offiziell freigegeben.
                        Wenn der Kunde sich dafür interessiert, kann er sich gerne für unser Developer-Portal registrieren.
                        https://developer.viessmann.com/
                        Mit freu
                        • TRM
                          TRM last edited by TRM
                          Habe gerade von Viessmann eine wohl automatisierte Mail erhalten.
                          Zum 15.07.21 wird wohl die alte (bisher genutzte?!) API abgeschaltet. Bedeutet dies, dass der Adapter wohl somit bis in 4 Wochen (vorerst) ohne Funktion ist?
                          Hier die Mail:
                          "Eine Auswertung hat ergeben, dass Sie die Web Schnittstelle (API) zu den Viessmann IoT Services genutzt haben, um über eine 3rd-Party-Applikation auf Daten aus dem Viessmann Backend zuzugreifen. Wir wollten Sie darüber informieren, dass wir nun ein Developer Portal haben, das Sie für diesen Zweck nutzen können.
                          Das Developer Portal bietet sowohl für Entwickler als auch für Endanwender große Vorteile:
                          Einfaches Erstellen eines Accounts und Generieren eines neuen API-Schlüssels
                          Fortlaufender Zugriff auf Heizungsanlagendaten für die Entwicklung neuer Applikationen
                          Vollständige Dokumentation rund um unsere API, um Ihnen den Einstieg zu erleichtern
                          First-Level-Support zur Beantwortung aller Fragen, die Sie haben
                          Und vieles mehr in der Zukunft!
                          Wichtige Änderungen
                          Um unsere API auch in weiterhin stabil zu halten, müssen wir den Zugriff auf alle alten API-Schlüssel, die nicht über das Viessmann Developer Portal bezogen wurden, abschalten. Am 15. Juli 2021 wird daher der Zugriff auf alte API-Schlüssel nicht mehr möglich sein.
                          Was müssen Sie tun?
                          Wenn Sie einen alten API-Client verwenden, den Sie nicht über das Developer Portal erstellt haben und Sie sind ein:
                          Entwickler
                          Überprüfen Sie Ihr Plugin, um sicherzustellen, dass es mit dem Autorisierungsfluss funktioniert, der hier beschrieben wird https://developer.viessmann.com/de/doc/authentication. Jeder Benutzer benötigt seinen eigenen API-Schlüssel, um auf sein Gerät zuzugreifen. Das bedeutet, dass die gemeinsame Nutzung eines API-Schlüssels nicht mehr möglich ist und die Benutzer ihren eigenen API-Schlüssel haben müssen, um weiterhin auf Daten zugreifen zu können.
                          Einige Datenpunkte, die über den alten API-Client zugänglich waren, werden über den neuen API-Client nicht zugänglich sein. Überprüfen Sie daher unbedingt die Liste der verfügbaren Funktionen in der Dokumentation: https://developer.viessmann.com/de/doc/iot
                          Endbenutzer
                          Wenn Sie eine Anwendung eines Drittanbieters verwenden, um eine Verbindung zu Ihrem Heizgerät herzustellen, müssen Sie auf das Developer Portal gehen, um Ihren eigenen API-Schlüssel zu erstellen. Dies wird Ihr persönlicher Schlüssel sein, den Sie für den Zugriff auf Ihr Gerät verwenden müssen.
                          Sie können die Informationen zu den Änderungen auch in unserem Change Log finden, wo wir relevante Fragen und Antworten hinzufügen werden.
                          Wenn Sie unsicher sind, ob Sie davon betroffen sind, prüfen Sie zunächst, ob Sie mit Ihrem persönlichen Viessmann Konto auf die Web Schnittstelle zugreifen. Wenn Sie sich dann immer noch unsicher sind, können Sie uns gerne unter developer@viessmann.com erreichen.
                          Wir freuen uns über die rege Nachfrage nach der Nutzung unserer API. Wir möchten Sie einladen, Ihre Anwendungen weiterzuentwickeln. Bitte folgen Sie daher sorgfältig den hier enthaltenen Anweisungen.
                          Wenn Sie in der Zwischenzeit Fragen haben, können Sie uns gerne unter developer@viessmann.com kontaktieren]*.
                          • V
                            virFortis @TRM last edited by
                            @trm ich habe die E-Mail auch bekommen. Ich hoffe die Entwickler haben diese Info schon etwas früher bekommen und konnten hier eventuell vorsorgen. Oder es wird jetzt drum gehen den Adapter auf die neue APO umzuschreiben.
                            Man darf gespannt bleiben ob es dadurch sogar Neuerungen oder Verbesserungen geben wird.
                            TRM 1 Reply Last reply Reply Quote 0
                            • TRM
                              TRM @virFortis last edited by
                              @virfortis
                              Hoffe/Denke ich auch. Habe bei Github mal einen Issue eröffnet (auch wenn es nicht wirklich ein Fehler ist, aber denke ich essentiell).
                              Neue Features hoffe ich zwar, glaube aber eher nicht daran. Es liest sich ja leider sogar so, als ob einige Datenpunkte wegfallen könnten.
                              7057
