    5. Blockly optimieren -Tabelle erstellen
      liv-in-sky @Wszene last edited by
      @wszene (sorry hat etwas gedauert - blockly muss ich erst wieder lernen 😞 - mache schleifen und so eigentlich nur in js)
      die "umdrehung"
      teste mal das, da stimmt die reihenfolge:
      <block xmlns="https://developers.google.com/blockly/xml" type="controls_for" id="JNNaZlB+?Z04HOx2Gu(?" x="-216.0943603515625" y="12.84906005859375">
       <field name="VAR" id="UrdtKDQ=Ky.^B@eAuwIJ">i</field>
       <value name="FROM">
         <shadow type="math_number" id="WrG3EpK=zNPCy+mYu[+@">
           <field name="NUM">0</field>
         <block type="math_number" id="G9ch35ui-=)nUvTqVCOT">
       <value name="TO">
         <shadow type="math_number" id="_/06^]%/`/nYCqXnIr%]">
           <field name="NUM">10</field>
         <block type="math_arithmetic" id="3_Kfs9BtIWPdu;w[c{KZ">
             <shadow type="math_number" id="NQ%A+vSNxHXGUM,]d78|">
               <field name="NUM">1</field>
             <block type="lists_length" id="h+EEOFLY?/C$y6;7liOQ">
                 <block type="variables_get" id="{QW1kH)96}J?c@l:ZX@N">
                   <field name="VAR" id="y)eN7.8HDTNy:0QIRpvu">namen</field>
             <shadow type="math_number" id="_2$*hu8I]a*4FLcXDq6P">
             <block type="math_number" id="PQG~7f)%K=+n8FY@nTNg">
       <value name="BY">
         <shadow type="math_number" id="7;%P*{n!b.1Xz)aAfk#m">
         <block type="math_number" id="3ZVDn%UWJCgghp=ke5_$">
       <statement name="DO">
         <block type="lists_setIndex" id="-zUiNM(}BsoQ].Hu.|mx">
           <mutation at="true"></mutation>
           <field name="MODE">SET</field>
           <value name="LIST">
             <block type="variables_get" id="Q0Hct8=ken4m!!W]js)U">
               <field name="VAR" id="}K$K4dup~Vnv!`[}vnQy">Liste</field>
           <value name="AT">
             <block type="math_arithmetic" id="XfsC3YCPWv`.2L,?[}DO">
               <field name="OP">ADD</field>
                 <shadow type="math_number">
                 <block type="variables_get" id="yff.r|]h@7J[7mVX9qps">
                 <block type="math_number" id="};+tby,HZtiP=yo4B?T$">
           <value name="TO">
             <block type="lists_create_with" id="6a@[p]s)BEL%k0#L3dY#">
               <mutation items="4"></mutation>
               <value name="ADD0">
                 <block type="lists_getIndex" id="WP?9V`Ax1s6W9F7SQ4w,">
                     <block type="variables_get" id="+qq.av],CDOw9trIdImN">
                   <value name="AT">
                     <block type="math_arithmetic" id="(omAgkYl:o0+@,=9lJ4J">
                         <block type="variables_get" id="VB.*bdT*60.t/HnVu[Ki">
                         <block type="math_number" id="olC0vHqztBHOI{|z,)If">
               <value name="ADD1">
                 <block type="get_value_var" id="HveQcZt3Hj-Jpk=([FCZ">
                   <value name="OID">
                     <shadow type="text" id="etr=A:avqF6}d)}k(k~a">
                       <field name="TEXT"></field>
                     <block type="lists_getIndex" id="mI2YYTmqK(F9_f9=AWYC">
                         <block type="variables_get" id="|TY^+rk;})ed^N$#p_pd">
                           <field name="VAR" id="I@+oLMb^;SY|ctFo/=gF">datenpunkte</field>
                       <value name="AT">
                         <block type="math_arithmetic" id="E9y(38IsNTv%(r0::LIY">
                             <block type="variables_get" id="-gW3MQMvL%r`!D=x=qFw">
                             <block type="math_number" id="`.v0F+9G9phaAEwHws,:">
               <value name="ADD2">
                 <block type="lists_getIndex" id="H^@q`G[tG:Y3:ZT$X8xz">
                     <block type="variables_get" id="X(Z@($Xrq#KDw~M_5$9e">
                   <value name="AT">
                     <block type="math_arithmetic" id="F[tF)M{Gh)R62FpWSzDY">
                         <block type="variables_get" id="Y(6lEzjTe7qwF`wT7m=V">
                         <block type="math_number" id="z1r`}S%8e6G$KZjz)SXi">
               <value name="ADD3">
                 <block type="lists_getIndex" id="-6`3u0]GG+3z}}OFm2s@">
                     <block type="variables_get" id="Q4av1{lCW1;0F:eUJvP#">
                       <field name="VAR" id="zg5`*,uA4%`Fg5L@=CAI">schaltbar</field>
                   <value name="AT">
                     <block type="math_arithmetic" id="Z73k;}AOC;8+G/qSIat}">
                         <block type="variables_get" id="{.#7[BqG#yjpydkt1F^{">
                         <block type="math_number" id="w~6-dt0bLnsDygL*/Teb">
      Wszene 1 Reply Last reply Reply Quote 0
      • Wszene
        Wszene @liv-in-sky last edited by
        @liv-in-sky
        Kein Problem
        Du bist ja nicht nur für mich da
        Wenn ich "füge als" mit "setzte als" tusche dann nimmt er mir die Zeile Esstisch weg
          @wszene
          hast du alles ausgetauscht die "i+1" sind wichtig
          • Wszene
            @liv-in-sky
            so habe ich das gemacht?
            Habe ich da etwas übersehen?
              @wszene
              ja - in der liste fehlt setze i+1
              • Wszene
                @liv-in-sky
                Ahhhhhhh
                genau das war es
                Jetzt ist es richtig
                Ich sollte vielleicht doch erstmal vom Bildschirm weg damit die Konzentration wieder da ist
                  @wszene sehr gut - gute nachrichten bevor es in die träumewelt geht
                  kannst du bitte deine lampen und steckdosen bilder hier posten - hätte ich gerne
                  und wenn das ganze fertig ist, vielleicht ein bild von der vis mit den tabellen posten ?
                  • Wszene
                    Wszene @liv-in-sky last edited by Wszene
                    @liv-in-sky
                    Aber sicher doch
                    hier erstmal die Icons
                    ws-icons.zip
                    Die VIS wird leider noch etwas dauern
                    Da ist noch viel zu tun
                    Wenn die Startseite fertig ist (denke das könnte spätestens Dienstag sein) werde ich diese mal hier posten
                    EDIT:
                    Ich sehe gerade das mit Dienstag ist sehr sportlich
                    Ich muss leider erstmal in deinem Script die hart reingeschriebenen Style-Werte rauspicken
                    Problem ist das ich unterschiedliche VIS nutzen und diese unterschiedliche Größen und Farben haben daher muss ich CSS-Klassen einfügen um diese dann direkt im Projekt anzusprechen
                    liv-in-sky 1 Reply Last reply Reply Quote 1
                      @wszene
                      moin - ein kleiner schönheitsfehler - die lampen sind nicht 100% untereinander angeordnet
                      im script zeile 140 und 141 ganz am ende das leerzeichen löschen -. dann paßt es
                      Wszene 1 Reply Last reply Reply Quote 1
                      • Wszene
                        @liv-in-sky
                        Ich habe jetzt dein Script soweit verpfuscht das der Output so aussieht
                        <table class="ws_tabelle_lampen">
                          <tr bgcolor="#151515">
                            <td class="ws_tabelle_lampen_name" align=left>&ensp;Esstisch&ensp;</td>
                            <td align=center>&ensp;<button style="border:none; background-color:transparent; value=" toggle" onclick="setOnDblClickCustom('alias.0.01_Stube.01_Schalter.Schalter-Esstisch')"><img src=/vis.0/WS-Icons/Lampen/bulb-on.png height="35"
                                  width="35"></button>&ensp;</td>
                          </tr>
                          <tr bgcolor="#000000">
                            <td class="ws_tabelle_lampen_name" align=left>&ensp;Sofatisch&ensp;</td>
                            <td align=center>&ensp;<button style="border:none; background-color:transparent; value=" toggle" onclick="setOnDblClickCustom('alias.0.01_Stube.01_Schalter.Schalter-Sofatisch')"><img src=/vis.0/WS-Icons/Lampen/bulb-off.png height="35"
                          </tr>
                            <td class="ws_tabelle_lampen_name" align=left>&ensp;Stehlampe klein&ensp;</td>
                            <td align=center>&ensp;<img src=/vis.0/WS-Icons/Lampen/bulb-off.png height="35" width="35">&ensp;</td>
                          </tr>
                            <td class="ws_tabelle_lampen_name" align=left>&ensp;Stehlampe groß&ensp;</td>
                          </tr>
                            <td class="ws_tabelle_lampen_name" align=left>&ensp;Schlafzimmer-Lampe&ensp;</td>
                            <td align=center>&ensp;<button style="border:none; background-color:transparent; value=" toggle" onclick="setOnDblClickCustom('alias.0.02_Schlafzimmer.01_Schalter.Schalter-Schlafzimmerlampe')"><img src=/vis.0/WS-Icons/Lampen/bulb-off.png
                                  height="35" width="35"></button>&ensp;</td>
                          </tr>
                            <td class="ws_tabelle_lampen_name" align=left>&ensp;Abstellkammer-Lampe&ensp;</td>
                          </tr>
                        </table>
                        <script>
                          function setOnDblClickCustom(myvalue) {
                            var Self = this;
                            var objID = myvalue;
                            Self.servConn.getStates(objID, (error, states) => {
                              console.log(states);
                              Self.servConn.setState(objID, !states[objID].val);
                        </script>
                        Was ich leider nicht finde (da fehlt mir sie Erfahrung) sind die "bgcolor" und die ganzen Lehrzeichen
                        Ich hätte es gern das der Output so aussieht
                          <tr class="ws_zeile1_bgcolor">
                          </tr>
                          <tr class="ws_zeile2_bgcolor">
                          </tr>
                          </tr>
                          </tr>
                          </tr>
                          </tr>
                        </table>
                        <script>
                            var Self = this;
                        </script>
                        Ideal wäre noch wenn die "img" eine Class bekommen könnten dann könnte ich deren Größe auch in jedem Projekt via CSS anpassen
                        Hier nochmal das Script wie es jetzt bei mir aussieht
                        //@liv-in-sky 2020  4.2.-18:42
                        //HIER WIRD PFAD UND FILENAME DEFINIERT
                        const path = "/htmlexamplesetting.html";                   //FIlenamen definieren
                        const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                        let   braucheEinFile=false;                          // bei true wird ein file geschrieben
                        let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                        //let dpVIS="controll-own.0.AAATEST.TestHTML"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                        const farbeSchalterON="lightblue"               // farbe des schalters für ON
                        const farbeSchalterOFF="grey"               // farbe des schalters für OFF
                        //let mySchedule=" */20 * * * * * ";                       //jede minute
                        //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 2
                        var htmlFeld1='Standort';       var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
                        var htmlFeld2='Status';         var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                        //hier werden die styles für die tabelle definiert
                        //ÜBERSCHRIFT ÜBER TABELLE
                        let   htmlUberschrift=false;                           // mit Überschrift über der tabelle
                        let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                        const htmlFeldUeber='Batterie Zustand Sensoren';              // Überschrift und Signature
                        const htmlFarbUber="black";                         // Farbe der Überschrift
                        const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                        const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                        //MEHRERE TABELLEN NEBENEINANDER
                        let   mehrfachTabelle=1;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                        const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
                        const farbetrennungsLinie="white";
                        const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                        const htmlFarbTableColorUber="#000000";               // Überschrift in der tabelle - der einzelnen Spalten
                        //ÜBERSCHRIFT SPALTEN
                        const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                        const LinieUnterUeberschrift="3";                   // Linie nur unter Spaltenüberschrift -
                        const farbeLinieUnterUeberschrift="white";
                        const groesseUeberschrift=16;
                        const UeberschriftStyle="normal"                     // möglich "bold"
                        //GANZE TABELLE
                        let abstandZelle="1";
                        let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                        let farbeGeradeZeilen="#151515";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                        let weite="100%";                                     //Weite der Tabelle
                        let zentriert=true;                                   //ganze tabelle zentriert
                        const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                        const htmlSchriftart="Play-Regular";
                        //const htmlSchriftgroesse="22px";
                        //FELDER UND RAHMEN
                        let   UeberschriftSpalten=false;                // ein- oder ausblenden der spatlen-überschriften
                        const htmlFarbFelderschrift="#BDBDBD";                  // SchriftFarbe der Felder
                        const htmlFarbFelderschrift2="#D8D8D8";                 // SchriftFarbe der Felder für jede 2te Tabelle
                        const htmlFarbTableColorGradient1="#CDD163";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                        const htmlFarbTableColorGradient2="#CDD163";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                        const htmlFarbTableBorderColor="acaa20";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                        let htmlRahmenLinien="all";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                        const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                        // HIER NICHTS  ÄNDERN
                        let borderHelpBottum;
                        let borderHelpRight;
                        let htmlcenterHelp;
                        let htmlcenterHelp2;
                        if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                        if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                        if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                        if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                        zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                        zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                        const htmlZentriert=''
                        const htmlStart=    "";
                        //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                        const htmlTabStyle= "<table class=\""+tabelleClass+"\">";
                        const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\" style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
                        const htmlTabUeber3="</tr>";
                        const buttonScript =  '<script> function setOnDblClickCustom( myvalue ) {	var Self = this; var objID = myvalue;	Self.servConn.getStates(objID, (error, states) => {  console.log(states);  Self.servConn.setState(objID, !states[objID].val); }); } </script>'
                        ////NICHTS ÄNDERN  - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 2
                        var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td>";
                        var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                                          "&ensp;</td>";
                        var htmlOut="";
                        var mix;
                        var counter;
                        var val1;  var val0;
                        var htmlTabUeber="";
                        function writeHTML(){
                        htmlOut="";
                        counter=-1;
                        htmlTabUeber="";
                        switch (mehrfachTabelle) {
                          case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                          case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                          case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
                          case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                        if (!UeberschriftSpalten) {htmlTabUeber=""}
                        //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                        //---------alle valx werte müssen von euch bestimmt werden - val0,val1 !!!---------------------------------------------------------------------
                        for (var x=0;x<myList.length;x++){
                            counter++;
                            if(myList[x][1]!=null){
                                                  val0  = myList[x][0];
                                                  val1  = myList[x][1]
                          // log(val0)
                                        let valButton=myList[x][2]
                                        if (myList[x][3]){
                                        val1 ? val1="<button style\=\"border:none\; background-color\:transparent\; value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+"<img src="+symbolSwitchON +" height=\""+symbolHoehe+"\" width=\""+symbolBreite+"\">"+"</button>":
                                                 val1="<button style\=\"border:none\; background-color\:transparent\; value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+"<img src="+symbolSwitchOFF +" height=\""+symbolHoehe+"\" width=\""+symbolBreite+"\">"+"</button>";
                                        } else{
                                           val1 ? val1="<img src="+symbolSwitchON +" height=\""+symbolHoehe+"\" width=\""+symbolBreite+"\">"  :
                                                  val1="<img src="+symbolSwitchOFF +" height=\""+symbolHoehe+"\" width=\""+symbolBreite+"\">"
                                               //   if (val1==false) {val1="❌"} else{val1="✅"}
                                                 tabelleBind()
                                                  }; //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                        } tabelleFinish();
                            // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                        } // function ende
                        //MAIN:
                        writeHTML();
                        function tabelleBind(){
                                case 1:  if(counter%2==0)         {   htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td class=\""+tabelleClassSpalte1+"\" align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td></tr>"; break;  } else
        {   htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td class=\""+tabelleClassSpalte1+"\" align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td></tr>"; break;  }
                                case 2:  if(counter%4==0){
                                         if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\" ><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                                           ";\"align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td>"; }
                                                      else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+
                                                            htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td></tr>";} break;
                                }else{
                                         if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td style=\" border-right: "+trennungsLinie+
                                                           "px solid "+farbetrennungsLinie+";\" align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td>"; }
                                                      else {htmlOut = htmlOut+"<td  align="+Feld1lAlign+" style=\" color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+
                                                         " style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td></tr>";} break;}
                                case 3: if(counter%2==0)   {
                                        if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+
                                                      else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+
        " style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td></tr>";}
        } break; }else{
                                        if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+
        } break;  }
                                case 4: //counter=counter+8
                                if(counter%8==0)   {
                                         if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+
                                                          else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+
        " style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td>";}
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+
        Feld2lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"; color:"+htmlFarbFelderschrift2+
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "
        +farbetrennungsLinie+";\" align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td>";}}
        } break;}else{
                                         if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+
        +Feld2lAlign+" style=\" color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td></tr>";}
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+
        }  break;   }
                            } //switch ende
                        function tabelleFinish() {
                                case 1:    break;
                                case 2:    if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                           break;
                                case 3:    if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                           if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/,  '</td><td>test&ensp;</td><td>&ensp;</td></tr>');
                                           if(counter%3==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                           break;
                                case 4:    if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                           if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                           if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                           if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                           break; }
                                 var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                              var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                               if (!htmlSignature) htmlUnter="";
                                 //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                  var htmlOutVIS="";
                                //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                                   if (htmlUberschrift)
                                       { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript ;
                                     } else {
                                      zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript;
                         // log("bin raus aus tabelleBind");
                                  if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                        var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                        var htmlEnd="</table>"+htmlUnter+"</div></body>";
                        //mit oder ohne überschrift - zentriert oder links
                        htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd + buttonScript: htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd+ buttonScript;
                        //log(htmlOut);
                        Ich wäre dir sehr Dankbar wenn du dir das nochmal ansehen könntest
                        PS:
                        Wie kann ich hier im Forum eigentlich den Spoiler-Tag nutzen
                        Glasfaser liv-in-sky 3 Replies Last reply Reply Quote 0
                        • Glasfaser
                          Glasfaser @Wszene last edited by
                          @wszene sagte in Blockly optimieren -Tabelle erstellen:
                          PS:
                          oder
                            @wszene
                            eine css klasse für image wäre möglich - aber reicht dir weite und höhe nicht aus? was brauchst du noch ?
                            die tableclass hast du als variable eingefügt - diese aber nie deklariert - aber eigentlich braucht man bei diesen tabellen keine klassen definieren , sondern man stellt ein, was man braucht
                            lass und nochmal anydesken - im moment ist mir völlig unklar, was du eigentlich einstellen möchtest - werden wir schon hinbekommen
                              @wszene
                              oh - ich glaube, ich habe etwas vergessen zu posten - daher kannst du nicht wissen, dass du die bilder verändern kannst
                              mein blockly sieht so aus:
                              ganzes blockly als import zum rauskopieren:
                               <variables>
                                 <variable id="U3ge^B{?p,jfAdCjS^R`">myList</variable>
                                 <variable id="%bp]2~EOjnEkDJX$NYKl">symbolSwitchOFF</variable>
                                 <variable id="UrdtKDQ=Ky.^B@eAuwIJ">i</variable>
                                 <variable id="8a-KbCQJUo$]XfcjLaz,">symbolSwitchON</variable>
                                 <variable id="sJ5]JS8[cNqh9%*Ncrso">bildgroesseBreit</variable>
                                 <variable id="I@+oLMb^;SY|ctFo/=gF">datenpunkte</variable>
                                 <variable id="y)eN7.8HDTNy:0QIRpvu">namen</variable>
                                 <variable id="_lOTy#(65qHkTUC-#qv-">bildgroesseHoch</variable>
                                 <variable id="j!r]d|0)OZ`?7?E5+uc,">dpVIS</variable>
                                 <variable id="zg5`*,uA4%`Fg5L@=CAI">schaltbar</variable>
                                 <variable id="}K$K4dup~Vnv!`[}vnQy">Liste</variable>
                                 <variable id="Z=?7wCQ1-49/,bxoE1#|">counter</variable>
                               </variables>
                               <block type="comment" id="[j=,#tJ/I,.*8^Z3Wzs{" x="-237" y="-662">
                                 <field name="COMMENT">images - speicherort in vis</field>
                                   <block type="variables_set" id="~?/2.OORH76[^b$|2(5R">
                                     <field name="VAR" id="%bp]2~EOjnEkDJX$NYKl">symbolSwitchOFF</field>
                                       <block type="text" id="3bPoXd(8*3scn9U;eE@/">
                                         <field name="TEXT">/vis.0/armin/img/bulb-off.png</field>
                                       <block type="variables_set" id="uXbCEVuXS=h+,,EVEHwY">
                                         <field name="VAR" id="8a-KbCQJUo$]XfcjLaz,">symbolSwitchON</field>
                                           <block type="text" id="%srfTYVdD%f}KeATVB(a">
                                             <field name="TEXT">/vis.0/armin/img/bulb-on.png</field>
                                           <block type="variables_set" id="5Jd+nCw{/0S8ZXm^lw[c">
                                             <field name="VAR" id="sJ5]JS8[cNqh9%*Ncrso">bildgroesseBreit</field>
                                               <block type="math_number" id="Q=0a1hd-^LWLgqgiNaGD">
                                                 <field name="NUM">40</field>
                                               <block type="variables_set" id=":=cNBc1~N::48F5P5Q7Z">
                                                 <field name="VAR" id="_lOTy#(65qHkTUC-#qv-">bildgroesseHoch</field>
                                                   <block type="math_number" id="Je;:%9eTu14ub:1{hve*">
                                                     <field name="NUM">45</field>
                                                   <block type="comment" id="xcpOj.{NS!eYll{PHKR*">
                                                     <field name="COMMENT">tabelle - speicherort</field>
                                                       <block type="variables_set" id=":esye3=24O%w1CSt1}0H">
                                                         <field name="VAR" id="j!r]d|0)OZ`?7?E5+uc,">dpVIS</field>
                                                           <block type="text" id="n{gM;m:9Bopp9FhtB2$Q">
                                                             <field name="TEXT">controll-own.0.AAATEST.TestHTML</field>
                                                           <block type="comment" id=".$=_}0|2u$~bQ?mpEmWQ">
                                                             <field name="COMMENT">namen rechte spalte</field>
                                                               <block type="comment" id="XdqJd0}0:IV.@B%SPJ,l">
        <field name="COMMENT">anzahl namen und datenpunkte müssn GLEICH sein!!!!</field>
        <block type="variables_set" id="%,}7!+#]4L;%k~3~$U`j">
        <block type="lists_create_with" id="3v;AGsHBw|Ity4%0%LBm">
        <value name="ADD0">
        <block type="text" id="bquXlWOyq%x)l~Kd)#!$">
        <field name="TEXT">Sonoff 1</field>
        <value name="ADD1">
        <block type="text" id="kM.VWCCP(2KFbJzRuLZ}">
        <field name="TEXT">Sonoff 17</field>
        <value name="ADD2">
        <block type="text" id="AI[54NK3pOd_V.qP8;*#">
        <field name="TEXT">Sonoff 16 - nur Bild</field>
        <block type="comment" id="y*eI7Z{I[{FGyQ@.T0W:">
        <field name="COMMENT">zu prüfende datenpunkte</field>
        <block type="variables_set" id="T?^D@#slt^U_c38k?Qf$">
        <block type="lists_create_with" id="~vT)*f@e74d7nmI~aku}">
        <value name="ADD0">
        <block type="field_oid" id=":5hC4z,DJzE{mD!gGfxv">
        <field name="oid">sonoff.1.Sonoff1.POWER1</field>
        <value name="ADD1">
        <block type="field_oid" id="J%gkw).sCndBA`url,w2">
        <field name="oid">sonoff.0.Sonoff17.POWER</field>
        <value name="ADD2">
        <block type="field_oid" id="em_^Z$R~84*%,Q:upd*g">
        <field name="oid">sonoff.0.Sonoff16.POWER</field>
        <block type="comment" id="y7bQkqCW4$J4.)r@8m0;">
        <field name="COMMENT">schaltbar ja oder nein</field>
        <block type="variables_set" id="`t^uKi@b)1@^b/dZ+7JU">
        <block type="lists_create_with" id="A:wP[,~5zpo$qCxtYka(">
        <value name="ADD0">
        <block type="logic_boolean" id="1-FJmRW,V{X:!MvV[MY^">
        <value name="ADD1">
        <block type="logic_boolean" id="g68n+RpF=_:+Tmr)U9ng">
        <value name="ADD2">
        <block type="logic_boolean" id="Ychmk6yl=No2OTW}]NDK">
        <block type="on_ext" id="6rVl-%ae1[BpvH+7]z0b">
        <value name="OID0">
        <shadow type="field_oid" id="E1e;zY}}83B2UCtTz8hx">
        <block type="variables_get" id="Zf!Yc?uOmKG#K{Uu9S8b">
        <block type="variables_set" id="sWqJxa.MyY?*y-S}mHPz">
        <block type="lists_create_with" id="s1KG8o;:gtQ6DjJt@w9I">
        <block type="variables_set" id="R6exgi+-F7xoKVW/[NE.">
        <field name="VAR" id="Z=?7wCQ1-49/,bxoE1#|">counter</field>
        <block type="math_number" id="AHHG~c/mltPLQ?]Ik;5M">
        <field name="NUM">-1</field>
        <block type="controls_for" id="JNNaZlB+?Z04HOx2Gu(?">
        <value name="FROM">
        <value name="TO">
        <value name="BY">
        <value name="LIST">
        <value name="AT">
        <value name="TO">
        <value name="ADD0">
        <value name="AT">
        <value name="ADD1">
        <value name="OID">
        <value name="AT">
        <value name="ADD2">
        <value name="AT">
        <value name="ADD3">
        <value name="AT">
        <block type="debug" id="bx6Y8-8%U,x}ZR}zDMCw" disabled="true">
        <value name="TEXT">
        <shadow type="text" id="!yx$lDKS!DgZlryJ)%{j">
        <block type="variables_get" id="IL]^hG54Ej,lhuXqBi2=">
        <block type="procedures_callcustomnoreturn" id="1tTT@y+3fd)eq*EKO%`c">
        <mutation name="tabelleMit3Werten">
        <arg name="myList"></arg>
        </mutation>
        <value name="ARG0">
        <block type="variables_get" id="T3wm-=*hL+H$*f^H0[J9">
                               <block type="procedures_defcustomnoreturn" id="d+PXd6N1nBTxz}gaM@Co" x="463" y="-263">
                                 <mutation statements="false">
                                   <arg name="myList" varid="U3ge^B{?p,jfAdCjS^R`"></arg>
                                 </mutation>
                                 <field name="NAME">tabelleMit3Werten</field>
                                 <field name="SCRIPT">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</field>
                               <block type="math_arithmetic" id=";();%c,XdRtp2qG0fnLn" disabled="true" x="938" y="212">
                                   <block type="variables_get" id="c7_hG$]VNtu*W)j{rgV8">
                                   <shadow type="math_number" id="{kQj+Wg[(_hvMjNH41/3">
                               <block type="debug" id="hd*A({[CriUUg1PfZ.0:" disabled="true" x="662" y="662">
                                 <value name="TEXT">
                                   <shadow type="text">
                                   <block type="text_join" id="6qbWj3lR`EWRgS!bsU)9">
                                     <mutation items="7"></mutation>
                                     <value name="ADD0">
                                       <block type="lists_getIndex" id="q:v0yB%TMb@@O,|TFsEf">
                                           <block type="variables_get" id="B:q#r-vO?e(nH(1,fUYi">
                                         <value name="AT">
                                           <block type="math_arithmetic" id=".7}^relhMv#+5EB5NUyG">
                                               <block type="variables_get" id="-@Q*,CArwb`sh]coX8-Y">
                                               <block type="math_number" id="z%fF-%P{6I8[cGa52tbl">
                                     <value name="ADD1">
                                       <block type="text" id="RrGQLg*bYNx$Cf?)q3?J">
                                         <field name="TEXT"> ----- </field>
                                     <value name="ADD2">
                                       <block type="get_value_var" id="M9T/ynSkYF@HaETT`Eyb">
                                         <value name="OID">
                                           <block type="lists_getIndex" id="F5;,(y46L0.8pYYWe*c-">
                                               <block type="variables_get" id="I}*T6VQ~YZnMNd(_M.uH">
                                             <value name="AT">
                                               <block type="math_arithmetic" id="L)rbTRmd$K%0,`Y;4DLo">
                                                   <block type="variables_get" id="uPj?[ad+{7oD0{t`Lxv-">
                                                   <block type="math_number" id="f:{KISSaq]Ms1F=DX-B6">
                                     <value name="ADD3">
                                       <block type="text" id="n:4!e7wTM!$HN0hpCp/n">
                                     <value name="ADD4">
                                       <block type="math_arithmetic" id="c9YOyDRjFHhj+$zn|K^!">
                                           <block type="variables_get" id="{NJKRZr|GLmf6/D?m+@C">
                                           <block type="math_number" id="H}tXNgxHiGvJHfU_]M$q">
                                     <value name="ADD5">
                                       <block type="text" id="sW#4hSQ|E4.~+C55epV8">
                                     <value name="ADD6">
                                       <block type="lists_getIndex" id="d=Eh$X`d=;k+k*D%Get%">
                                           <block type="variables_get" id="34.ai58K,*d7%VYw~?$6">
                                         <value name="AT">
                                           <block type="math_arithmetic" id="+{$m3XaTRK$WCae==Z]3">
                                               <block type="variables_get" id="$%nO:HvF@,@vV[G2E@p8">
                                               <block type="math_number" id="YsoKj[uAxE8XG~7P)Y_]">
                              • Wszene
                                @liv-in-sky
                                Doch das hast du bei mir schon mit eingebaut
                                Das problem ist das ich da die Größe fix eingebe
                                Das heist überall wo ich die Tabelle dann einfüge habe ich den gleichen Wert
                                Da ich aber unterschiedliche Projekte für unterschiedliche Geräte habe ist das nicht so gut
                                z.B. auf dem iPad habe ich eine Icongröße von 45x45
                                und auf dem Smartphone nur 30x30
                                Daher die Frage mit den Klassen
                                  liv-in-sky @Wszene last edited by
                                  @wszene wie siehts aus mit einer session - ist schneller und einfacher
                                  Wszene 2 Replies Last reply Reply Quote 1
                                  • Wszene
                                    @liv-in-sky
                                    Können wir machen gebe mir mal bitte noch 15min
                                    • Wszene
                                      @liv-in-sky
                                      Danke nochmal für deine Hilfe
                                      Hier wie besprochen der Export und die CSS-Klassen
                                       <variables>
                                         <variable id="X{YCwT6)UO~XY`Vc}2I4">anlegen_in</variable>
                                         <variable id="Sj=PG`7sdz;!7%*c;rMl">Tabelle - Name</variable>
                                         <variable id="0q#2a)[a+^d21Zhdi^sp">myList</variable>
                                         <variable id="2GY!!q}efSWeJut|}*g?">tabelleClass</variable>
                                         <variable id="$RIK(0f);.l=!pQfVAU#">Tabelle - Lampen</variable>
                                         <variable type="timeout" id="start">start</variable>
                                         <variable id="vFTZ1]BURtyw_?,7vv7]">Tabelle - Wert</variable>
                                         <variable id="zc}]z)HcoRF!Stu%L,1O">tabelleClassSpalte1</variable>
                                         <variable id="QZuXR_Vj:|w~;Y^wh/80">dpVIS</variable>
                                         <variable id="uY@Vk|3N|Db%n1]s5r65">schaltbar</variable>
                                         <variable id="$SQ+1P}hh0i}dM)i!l8Y">tabelleClassZeile1</variable>
                                         <variable id="0$3)d1XO~32nM)5=R_{E">tabelleClassZeile2</variable>
                                         <variable id="@XCmXlbJ|}uQfG*Yj}BT">tabelleClassIcon</variable>
                                         <variable id=";]3e-T$pq}QNAxDl__@;">Liste</variable>
                                         <variable id="[+@foafRz`m~/)FhPq0`">symbolSwitchOFF</variable>
                                         <variable id="xEf:=c;06LZR_EPM?]P@">counter</variable>
                                         <variable id="f`-]]z,}lIr/=i8^XP#h">symbolSwitchON</variable>
                                         <variable id="N8]TG{K`UGkh#8BWL|E)">symbolBreite</variable>
                                         <variable id="wan~:25GYo--e@M0rsmr">i</variable>
                                         <variable id="u,X-cS9u7+2)_f!kviiD">symbolHoehe</variable>
                                       </variables>
                                       <block type="procedures_defcustomnoreturn" id="D:0E=~0D8*EFnn8f|sd." x="37" y="-487">
                                         <mutation statements="false"></mutation>
                                         <field name="NAME">Datenpunkte_erstellen</field>
                                         <field name="SCRIPT">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</field>
                                         <comment pinned="false" h="80" w="160">Datenpunkte erstellen</comment>
                                       <block type="procedures_defnoreturn" id="|r?w}:z)r=!T3O=4ydx]" collapsed="true" x="762" y="-487">
                                         <field name="NAME">main</field>
                                         <statement name="STACK">
                                           <block type="variables_set" id=".gQp2+8;_3/q8_Uwr:F/">
                                             <field name="VAR" id="$RIK(0f);.l=!pQfVAU#">Tabelle - Lampen</field>
                                               <block type="text_join" id="]$B5QV^ydMJ7Ox*Vk,L(">
                                                 <value name="ADD0">
                                                   <block type="variables_get" id="z$A`(VFvUcL{CgqQKX]4">
                                                     <field name="VAR" id="X{YCwT6)UO~XY`Vc}2I4">anlegen_in</field>
                                                 <value name="ADD1">
                                                   <block type="text" id="An4U,bq[qbV=TJY^y+9l">
                                                     <field name="TEXT">0_userdata.0.002_nurVIS.03_Tabellen.Tabelle-Lampen</field>
                                               <block type="variables_set" id="C5HWo|yi`(1D-VroN~CI">
                                                 <field name="VAR" id="QZuXR_Vj:|w~;Y^wh/80">dpVIS</field>
                                                   <block type="text" id="jE]@{6x/=YXCcP(*}MB_">
                                                   <block type="on_ext" id="j5{Mnb?|Oo@L~6(UbSAv">
                                                     <value name="OID0">
                                                       <shadow type="field_oid" id="FL;tv}CJCem$Z^9KD@Op">
                                                       <block type="variables_get" id="Ni|HL}{c56c/QzL#ge42">
                                                         <field name="VAR" id="vFTZ1]BURtyw_?,7vv7]">Tabelle - Wert</field>
                                                       <block type="debug" id="X0vTv0:.XY]1I6tzL9q@">
                                                         <value name="TEXT">
                                                           <shadow type="text" id="RJ?8[!3;Q~FS8lAtLdeR">
                                                             <field name="TEXT">geschaltet</field>
                                                           <block type="variables_set" id="83N;r#%qTAdY9GgSNs^F">
                                                             <field name="VAR" id=";]3e-T$pq}QNAxDl__@;">Liste</field>
                                                               <block type="lists_create_with" id="4U^kzE{Hs(]pnBMC??q|">
                                                               <block type="variables_set" id="*~@+.cU.1SMX$3YFQEMy">
        <field name="VAR" id="xEf:=c;06LZR_EPM?]P@">counter</field>
        <block type="math_number" id="GaEH[gm^fOE=a@gYSg@t">
        <block type="debug" id="0q`R4fr%LknOMj$3V$u@">
        <value name="TEXT">
        <shadow type="text" id="TaX2W/t-$WBf@8b04TWs">
        <block type="lists_length" id="m,n=M/w=A+o?=9%4uy~@">
        <block type="variables_get" id="pA5HL%Bq}t=XiPi,$TkX">
        <field name="VAR" id="Sj=PG`7sdz;!7%*c;rMl">Tabelle - Name</field>
        <block type="controls_for" id="y*t(t$H=O/`gkA]e{f]N">
        <field name="VAR" id="wan~:25GYo--e@M0rsmr">i</field>
        <value name="FROM">
        <shadow type="math_number" id="OSgU2MY;^D/[!kGW:d|L">
        <field name="NUM">1</field>
        <block type="math_number" id="{.jK(G4;-B#Wp-{i_~;8">
        <field name="NUM">0</field>
        <value name="TO">
        <shadow type="math_number" id="yP97$mYMiincLzghyD]w">
        <field name="NUM">10</field>
        <block type="math_arithmetic" id="(xxz~IVSoXGHB,isG3S~">
        <shadow type="math_number" id="`d,k5Qn$m.Uf_;4i+y]:">
        <block type="lists_length" id="#|sN^hF5G+sr]seg.U^:">
        <block type="variables_get" id="?C(i`!-9hz%|ghSq;5m6">
        <shadow type="math_number" id="_/.VYy0t$[G=yegaPe]4">
        <block type="math_number" id="!_6P=,aB)p+dU5}d!x2,">
        <value name="BY">
        <shadow type="math_number" id="OySf9m]U]b[ImluOB#gC">
        <block type="math_number" id="7ytVjDF?/?6OeV}x24mQ">
        <statement name="DO">
        <block type="debug" id=":8ICawg@-2]p/l}oHZph">
        <value name="TEXT">
        <shadow type="text" id="8?~*3=^0D^hO{s,pGCXE">
        <block type="get_value_var" id="SfY)vB]wkc]`bQu;UBzD">
        <value name="OID">
        <field name="TEXT"></field>
        <block type="lists_getIndex" id="F{|T^UXS*aC?kou33~VB">
        <block type="variables_get" id="tn?iJ?HNP[KJG}{]9?v2">
        <value name="AT">
        <block type="math_arithmetic" id="#KU;iM?RVn,D|)Av$ze/">
        <field name="OP">ADD</field>
        <shadow type="math_number">
        <block type="variables_get" id="Um9ElR!rBcQ2})$(,f!S">
        <block type="math_number" id="s0vbhz);SdvuUd:a#[4x">
        <block type="lists_setIndex" id="7cHhu-{x}5HAucBz}OME">
        <mutation at="true"></mutation>
        <field name="MODE">SET</field>
        <value name="LIST">
        <block type="variables_get" id="$jGQP+47^7]ZUgfroqAH">
        <value name="AT">
        <block type="math_arithmetic" id="[b-)#Lj:KzVU.g^vH)nX">
        <block type="variables_get" id="sbR4`Q$D:.e06oMl4!0K">
        <block type="math_number" id="8Xn*B:/R/T]Qhr:m~??$">
        <value name="TO">
        <block type="lists_create_with" id="{@ebK;o3Gklz{FqwS:$4">
        <mutation items="4"></mutation>
        <value name="ADD0">
        <block type="lists_getIndex" id="Yv1b/Rs0|MHe~KT=@g6K">
        <block type="variables_get" id="WC6k:N-L(kLDBK=VzUp^">
        <value name="AT">
        <block type="math_arithmetic" id="cFkZochi|Z(~gj`U!Z$1">
        <shadow type="math_number" id="xx9p?#FxT!_uDOTe7mNk">
        <block type="variables_get" id="~ww5Z8a+vfPD69Fjq)8s">
        <shadow type="math_number" id="c1,#}X|F46YsFcC_Tk!;">
        <block type="math_number" id="Q?tk_~D~a*]S,lI#TiZx">
        <value name="ADD1">
        <block type="get_value_var" id="[%)g^C8XgS{pO{#tb!X{">
        <value name="OID">
        <shadow type="text" id="@I^i5M4[MKS7D,YqmG`{">
        <block type="lists_getIndex" id="{`NI)0^^8n{Z7^@AA~qN">
        <block type="variables_get" id="*oemeJw6LT8Nh!2CkT?#">
        <value name="AT">
        <block type="math_arithmetic" id="DepAp4o{CEN`rP42Eyk9">
        <block type="variables_get" id="Tj/=~@4drS6mm~an?;V{">
        <block type="math_number" id="kU(m?T`BSR,4Iv`Q!w#;">
        <value name="ADD2">
        <block type="lists_getIndex" id="X.iFvPi}P2*EIsnO^{u%">
        <block type="variables_get" id="ScyNh|x,2=1a~=6NT4=Z">
        <value name="AT">
        <block type="math_arithmetic" id="mqSsuKI+G%J,+W7CKvIZ">
        <block type="variables_get" id="[kugO)TQm=/,n8{zd,Cb">
        <block type="math_number" id="DOQ!`A,Rrd+b_b?0JDPR">
        <value name="ADD3">
        <block type="lists_getIndex" id=",;1K;!QM5c#eZ`ajEegW">
        <block type="variables_get" id="ge0oPgG/7df}^#-X2CMH">
        <field name="VAR" id="uY@Vk|3N|Db%n1]s5r65">schaltbar</field>
        <value name="AT">
        <block type="math_arithmetic" id="v(3{5ly@?+FidzF_#wet">
        <block type="variables_get" id="mcqO0S9cj)`r#7k2DjFr">
        <block type="math_number" id="yc^b5/3L*,P+0k-n^vQz">
        <block type="debug" id="fgbQNnE,HDdl5m{Og$~L">
        <value name="TEXT">
        <block type="variables_get" id="fAG([Lz!V$1PS5fDxtU]">
        <block type="procedures_callcustomnoreturn" id="nOV9gWJMT2K)YWW~F$5f">
        </mutation>
        <value name="ARG0">
        <block type="variables_get" id="H,0ylQ7zL6lG%zxB]}_*">
                                       <block type="variables_set" id=";?fMsQ~nMP,W:*R,z,hL" x="37" y="-437">
                                           <block type="text" id="TZDVFCHb+7p4,v#~lC!*">
                                             <field name="TEXT">0_userdata.0</field>
                                           <block type="timeouts_settimeout" id="8FQd(trxfKDt`(FG0(?=">
                                             <field name="NAME">start</field>
                                             <field name="DELAY">1000</field>
                                             <field name="UNIT">ms</field>
                                               <block type="procedures_callcustomnoreturn" id="}{A#y;jy-Pl_)n6[of`b">
                                                 <mutation name="Datenpunkte_erstellen"></mutation>
                                       <block type="variables_set" id="}WiBpiZ0_%C:a^gG0Q#n" x="663" y="-437">
                                           <block type="lists_create_with" id="|/LJ3+{[jEYU,^h}Z:pg">
                                             <mutation items="6"></mutation>
                                             <value name="ADD0">
                                               <block type="text" id="A=3U~Wx+!2j@I21Dk?!^">
                                                 <field name="TEXT">Esstisch</field>
                                             <value name="ADD1">
                                               <block type="text" id="*Km]#h%{YG3Z65mghZ+9">
                                                 <field name="TEXT">Sofatisch</field>
                                             <value name="ADD2">
                                               <block type="text" id="y7Jgr#UXpq@uQXn5Hosq">
                                                 <field name="TEXT">Stehlampe klein</field>
                                             <value name="ADD3">
                                               <block type="text" id="pm)@d}6J`zZy+bXNH@H$">
                                                 <field name="TEXT">Stehlampe groß</field>
                                             <value name="ADD4">
                                               <block type="text" id=".;1X=-;h$![-QQg$Ws}.">
                                                 <field name="TEXT">Schlafzimmer-Lampe</field>
                                             <value name="ADD5">
                                               <block type="text" id="zR]5Osz[~k`X0`Ysg7at">
                                                 <field name="TEXT">Abstellkammer-Lampe</field>
                                           <block type="variables_set" id="y2?]c9}3]*k*C),|U;{F">
                                               <block type="lists_create_with" id="1e{,vWUl,1O@][+qJ:L6">
                                                 <value name="ADD0">
                                                   <block type="field_oid" id="bX4qya?A8Y_3Om5J.bxY">
                                                     <field name="oid">alias.0.01_Stube.01_Schalter.Schalter-Esstisch</field>
                                                 <value name="ADD1">
                                                   <block type="field_oid" id="4mkxL8p:7o[j8ZsC-2ah">
                                                     <field name="oid">alias.0.01_Stube.01_Schalter.Schalter-Sofatisch</field>
                                                 <value name="ADD2">
                                                   <block type="field_oid" id="i:o,,cQ(d(#M`)2@gzF]">
                                                     <field name="oid">alias.0.03_Flur-Kammer.03_Lampen.Lampe_Kammer_Wert</field>
                                                 <value name="ADD3">
                                                   <block type="field_oid" id="rJWml9-eq;)/t##LN*y]">
                                                 <value name="ADD4">
                                                   <block type="field_oid" id="8F6}0M/F!k6S+)kBf9:p">
                                                     <field name="oid">alias.0.02_Schlafzimmer.01_Schalter.Schalter-Schlafzimmerlampe</field>
                                                 <value name="ADD5">
                                                   <block type="field_oid" id="$._9Le1ae@9*gS%i.Lx]">
                                               <block type="variables_set" id=".U=[Cr|/iP:B^mnE}#A#">
                                                   <block type="lists_create_with" id="wD-C;G9y2Ug`PWKUH(ky">
                                                     <value name="ADD0">
                                                       <block type="logic_boolean" id="04IQde8Vg/|TT?Gw9;p;">
                                                     <value name="ADD1">
                                                       <block type="logic_boolean" id="RmD:CGK^B}e8P@^nv`8g">
                                                     <value name="ADD2">
                                                       <block type="logic_boolean" id="/;Dc[y*A#EE}0CAEOLjV">
                                                     <value name="ADD3">
                                                       <block type="logic_boolean" id="*[GG,|,[dY%ek({;LnsX">
                                                     <value name="ADD4">
                                                       <block type="logic_boolean" id="dwwh`.gmm@lC~_Su,doE">
                                                     <value name="ADD5">
                                                       <block type="logic_boolean" id="0?i/$;+{3=f.8n29T+G^">
                                       <block type="procedures_defcustomnoreturn" id="d+PXd6N1nBTxz}gaM@Co" x="37" y="-312">
                                           <arg name="myList" varid="0q#2a)[a+^d21Zhdi^sp"></arg>
                                         </mutation>
                                         <field name="SCRIPT">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</field>
                                       <block type="variables_set" id="q.Wv.Mg#DuGWoRHZKg6B" x="37" y="-262">
                                         <field name="VAR" id="2GY!!q}efSWeJut|}*g?">tabelleClass</field>
                                           <block type="text" id="{3,N1cRWmzqXfkY)j#3~">
                                             <field name="TEXT">ws_tabelle_lampen</field>
                                           <block type="variables_set" id="^-ql]EH.:?,JtTZ*EJEQ">
                                             <field name="VAR" id="zc}]z)HcoRF!Stu%L,1O">tabelleClassSpalte1</field>
                                               <block type="text" id="mBlW|GZOtd%B+B9FC3VY">
                                                 <field name="TEXT">ws_tabelle_lampen_name</field>
                                               <block type="variables_set" id="CU#j/],[Z-liJ8Dki:IS">
                                                 <field name="VAR" id="$SQ+1P}hh0i}dM)i!l8Y">tabelleClassZeile1</field>
                                                   <block type="text" id="|1*x$5KGnPCOpEw%g2_=">
                                                     <field name="TEXT">ws_tabelle_zeile1</field>
                                                   <block type="variables_set" id="Bl?JT_QPz{MPE/.f*Y#V">
                                                     <field name="VAR" id="0$3)d1XO~32nM)5=R_{E">tabelleClassZeile2</field>
                                                       <block type="text" id="F#^twe+8_N=7,p1v0Fwu">
                                                         <field name="TEXT">ws_tabelle_zeile2</field>
                                                       <block type="variables_set" id="6M0l#R(W?S~DV%3pIWF)">
                                                         <field name="VAR" id="@XCmXlbJ|}uQfG*Yj}BT">tabelleClassIcon</field>
                                                           <block type="text" id="R=A,kBgJ`qPak{V0lUMk">
                                                             <field name="TEXT">ws_tabelle_icon</field>
                                                           <block type="variables_set" id="y5W4f8slFT+@4+/T?d=A">
                                                             <field name="VAR" id="[+@foafRz`m~/)FhPq0`">symbolSwitchOFF</field>
                                                               <block type="text" id="UfmI|9f%z43Z%c6B.qz_">
        <field name="TEXT">/vis.0/WS-Icons/Lampen/bulb-off.png</field>
                                                               <block type="variables_set" id="`(bYDvCf@Hp9C+ZCb:ab">
        <field name="VAR" id="f`-]]z,}lIr/=i8^XP#h">symbolSwitchON</field>
        <block type="text" id="h4JJKGiY(hcotD(Yl3i%">
        <field name="TEXT">/vis.0/WS-Icons/Lampen/bulb-on.png</field>
        <block type="variables_set" id="o49kS_e$fcW9;rA(aT5$">
        <field name="VAR" id="N8]TG{K`UGkh#8BWL|E)">symbolBreite</field>
        <block type="math_number" id="eKi.X5,+wui1bvHQvHHl">
        <field name="NUM">35</field>
        <block type="variables_set" id="Hv[c4#O+gucBahk)X.l*">
        <field name="VAR" id="u,X-cS9u7+2)_f!kviiD">symbolHoehe</field>
        <block type="math_number" id="o,Sj,y{+**.O6wZ/M/KK">
        <block type="variables_set" id="S;%s,:Tt/KOgz{W,:lTc">
        <block type="text" id="6sN0p?[P0:$-Jm]cFPVG">
                                      table.ws_tabelle_lampen {
                                        width: 100%;
                                        border-collapse: collapse;
                                        border-width: 1px;
                                        border-color: #ACAA20;
                                        border-style: solid;
                                        color: #C2C2C2;
                                      table.ws_tabelle_lampen td {
                                        border-width: 1px;
                                        padding: 1px;
                                      table.ws_tabelle_lampen .ws_tabelle_lampen_name {
                                          width: 85%;
                                      table.ws_tabelle_lampen .ws_tabelle_zeile1 {
                                          background-color: #ff0000;
                                      table.ws_tabelle_lampen .ws_tabelle_zeile2 {
                                          background-color: blue;
                                      table.ws_tabelle_lampen .ws_tabelle_icon {
                                          width: 35px;
                                          height: 35px;
                                      blockly template
                                      4393
