    4. SMA Wechselrichter
    SMA Wechselrichter
    • Slowman
      Slowman last edited by
      Habe heute mal in dem Log eine Fehlermeldung vom SMA Speedwire. Habe bisher als Lösung nur gefunden, den JS-Controller neu zu installieren. Hat keinen Erfolg gebracht.
      2021-01-26 18:23:30.726 - info: sma-speedwire.0 (2087) starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.sma-speedwire, node: v12.20.1, js-controller: 3.2.11
      2021-01-26 18:23:41.768 - error: sma-speedwire.0 (2087) Timeout
      2021-01-26 18:23:41.774 - error: host.iobroker instance system.adapter.sma-speedwire.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2021-01-26 18:24:00.023 - info: host.iobroker instance system.adapter.sma-speedwire.0 started with pid 2111
      2021-01-26 18:24:00.783 - info: sma-speedwire.0 (2111) starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.sma-speedwire, node: v12.20.1, js-controller: 3.2.11
      2021-01-26 18:24:11.836 - error: sma-speedwire.0 (2111) Timeout
      2021-01-26 18:24:11.842 - error: host.iobroker instance system.adapter.sma-speedwire.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2021-01-26 18:24:30.019 - info: host.iobroker instance system.adapter.sma-speedwire.0 started with pid 2128
      2021-01-26 18:24:30.859 - info: sma-speedwire.0 (2128) starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.sma-speedwire, node: v12.20.1, js-controller: 3.2.11
      2021-01-26 18:24:41.897 - error: sma-speedwire.0 (2128) Timeout
      2021-01-26 18:24:41.904 - error: host.iobroker instance system.adapter.sma-speedwire.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2021-01-26 18:25:00.022 - info: host.iobroker instance system.adapter.sma-speedwire.0 started with pid 2153
      wendy2702 E 2 Replies Last reply Reply Quote 0
      • wendy2702
        wendy2702 @Slowman last edited by
        @slowman Wo hast du den Adapter her?
        • Slowman
          Von hier: https://github.com/Apollon77/iobroker.sma-speedwire
          • wendy2702
            @slowman Welche Werte hast du darüber bekommen und hast du dich als Benutzer oder Installateur angemeldet?
            Slowman 1 Reply Last reply Reply Quote 0
            • Slowman
              Slowman @wendy2702 last edited by
              @wendy2702
              Als Benutzer, es ging ja bis vor kurzen damit.
              • wendy2702
                wendy2702 @Slowman last edited by wendy2702
                @slowman Gerade mal schnell installiert.
                Ist das richtig das der per Cron alle paar Sekunden neu gestartet werden muss oder kann der permanent laufen?
                Unabhängig davon hat er meinen Wechselrichter falsch ausgelesen.
                Habe STP6000 aber im Objekt steht STP5000.
                Wenn ich zu Hause bin mal mit meinem zweiten testen.
                • Slowman
                  @wendy2702
                  Echt, so genau habe ich noch nicht geschaut, das er alle 30s neu startet (dachte er ruft die Daten ab) 😊
                  Bei mir steht nicht mal, was ich habe drin.
                  • wendy2702
                    @slowman hat sich denn vielleicht nur die IP vom WR geändert?
                    Ahja, bei mir hat er die Version 0.70 installiert. Du hast ja noch 0.66 laufen wie es aussieht, vielleicht macht das auch den Unterschied.
                    • Slowman
                      Slowman @wendy2702 last edited by Slowman
                      @wendy2702
                      Äh, wie geht denn das, habe den dir geschriebenen Link auch genommen.
                      Ne, auch die 7.0 installiert 2021-01-26 20.58.23 192.168.2.82 13566c855b19.png
                      Aber im Log, die 0.6.6, werde mal De- und Installieren.
                      • wendy2702
                        @slowman Vergiß das mit der Versionsnummer.
                        Hier steht 0.70:
                        Im Log aber:
                        Also liegt es nicht an der Version.
                        • Slowman
                          @wendy2702
                          Zu spät 😑 Bekommst du keine Fehlermeldung?
                          • wendy2702
                            @slowman Nein.
                            Es kommen halt aktuell ein paar wenige Daten weil die beiden WRs ja schlafen 🙂
                            Hast du das loggen mal auf Debug gestellt?
                            • Slowman
                              @wendy2702
                              Hmmm... da war ja noch was. 😊
                              Werde morgen schauen, wenn der WR wieder aufgewacht ist.
                              • wendy2702
                                @slowman Meine Schlafen ja auch, aber den Fehler habe ich trotzdem nicht.
                                • Slowman
                                  @wendy2702
                                  Ich werde mal eine Sicherung von gestern einspielen, da ich 2-3 neue Adapter installiert hatte. Vielleicht liegt ja was quer.
                                  Hmm... Problem muss woanders liegen, habe jetzt 3 ältere Sicherungen eingespielt.
                                  • Slowman
                                    Fehler liegt voraussichtlich am WR oder SMA2, es kommt am Montag jemand vorbei. Es gibt auch ein Kommunikationsproblem mit Sunnyportal
                                    • wendy2702
                                      @slowman aber mit SunnyExplorer kannst du ihn noch erreichen?
                                      Oder per Ping ?
                                      • Slowman
                                        @wendy2702
                                        Das habe ich im Anlagelogbuch --28.01.2021 00:24:04 STP 15000TL-30 301 Kommunikation gestört
                                        Mal abwarten, was der Techniker sagt.
                                        • Slowman
                                          So, Adapter funktioniert wieder. Der SMA 2.0 hat sich "aufgehängt", ein Reset hat den Fehler behoben.
                                          • wendy2702
                                            @slowman Meinst du mit SMA 2.0 den Homemanager oder einen Wechselrichter ?
                                            586
                                            160368
