    4. Hilfe beim Auslesen eines Wertes (iCal)
      skorpil last edited by
      So, lieber Pix,
      alle Tests habe ich durchgeführt. Ergebnis: meine Variante läuft (nachdem Du mich auf die Spur gebracht hast). Deine NICHT. Folgende Fehlermeldungen kommen bei Deiner Variante im Log:
      ` > ReferenceError: 2016-03-03 17:12:56 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      ReferenceError: 2016-03-03 17:12:56 error at Socket.StatesInMemClient.client.on.connectionTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
      ReferenceError: 2016-03-03 17:12:56 error at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1969:80)
      ReferenceError: 2016-03-03 17:12:56 error at Object.utils.adapter.stateChange (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:215:17)
      ReferenceError: 2016-03-03 17:12:56 error at checkPatterns (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:524:17)
      ReferenceError: 2016-03-03 17:12:56 error at getObjectEnums (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2415:17)
      ReferenceError: 2016-03-03 17:12:56 error at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:528:48
      ReferenceError: 2016-03-03 17:12:56 error at Object.subs.callback (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1190:48)
      ReferenceError: 2016-03-03 17:12:56 error at Object. (script.js.Pix_OPTIMIERT_Kueche_Ansage_mit_Variable_u__Geburtstag:93:51)
      ReferenceError: 2016-03-03 17:12:56 error at ermitteleAnsagedatum (script.js.Pix_OPTIMIERT_Kueche_Ansage_mit_Variable_u__Geburtstag:45:23)
      ReferenceError: 2016-03-03 17:12:56 error sekunde is not defined
      message 2016-03-03 17:12:56 error hm-rega.0.38101 [object Object] sekunde is not defined
      ReferenceError: 2016-03-03 17:12:26 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      ReferenceError: 2016-03-03 17:12:26 error at Socket.StatesInMemClient.client.on.connectionTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
      ReferenceError: 2016-03-03 17:12:26 error at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1969:80)
      ReferenceError: 2016-03-03 17:12:26 error at Object.utils.adapter.stateChange (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:215:17)
      ReferenceError: 2016-03-03 17:12:26 error at checkPatterns (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:524:17)
      ReferenceError: 2016-03-03 17:12:26 error at getObjectEnums (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2415:17)
      ReferenceError: 2016-03-03 17:12:26 error at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:528:48
      ReferenceError: 2016-03-03 17:12:26 error at Object.subs.callback (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1190:48)
      ReferenceError: 2016-03-03 17:12:26 error at Object. (script.js.Pix_OPTIMIERT_Kueche_Ansage_mit_Variable_u__Geburtstag:93:51)
      ReferenceError: 2016-03-03 17:12:26 error at ermitteleAnsagedatum (script.js.Pix_OPTIMIERT_Kueche_Ansage_mit_Variable_u__Geburtstag:45:23)
      ReferenceError: 2016-03-03 17:12:26 error sekunde is not defined `
      Bei MEINER Variante lag es a) an der falschen Zuordnung des Sayit Adapters (z.B. bei der Lautstärke Einstellung). Vor allem aber an der falschen If Bedingung. Jetzt steht da
      if (data.newState.val === true) {
              setState (tts,
      und vorher war da
      setState (idSayIt
      also nicht korrekt definiert.
      Jetzt zu Deiner Optimierung. Hier weiß ich noch nicht, wo ich ansetzen soll, um die Fehler zu finden. Sekunde ist nicht definiert? Und ganz viele kryptische weitere Fehlermeldungen…
        pix last edited by
        @skorpil:
        Und dann habe ich "UNSER" Script eigentlich nur eingefügt `
        du brauchst das Skript nicht einzufügen. Speichere es separat ab. Denn das Objekt, in dem die Geburtstage stehen, steht doch systemweit zur Verfügung. Ds kannst du auch in deinem alten Skript einlesen.
        var geburtstag = getState('javascript.0.Kalernderereignis.heute').val;
        Sorry, wenn deine homematic Systemvariable "Sayit" n Tripper hat. Ist da ansteckend? :lol:
        @skorpil:
        es könnte mit den SayIt Adaptern zusammnehängen. Von denen habe ich insgesamt 4 in Betrieb, ` Das ist recht ungewöhnlich, das hättest du ja mal vorher sagen können.
        Nun zum Fehlerlog:
        Das stimmt. Nimm mal die Zeile
         'Sekunde'   : sekunde
        aus der Funktion ermitteleAnsagedatum heraus und lösche das Komma am Ende der Zeile davor.
        @skorpil:
        Und ganz viele kryptische weitere Fehlermeldungen… `
        Wenn du die nicht postest, hilft es nicht
          pix last edited by
          Ich brauche (noch) keine Entwicklungsumgebung. Bluefox Javascript Adapter ist super. Schau dir mal Version 2 an.
          Pix
            Ich hatte die Fehlermeldungen gepostet:
            Werde das Thema mit dem Komma gleich mal korrigieren und neu testen.
            Daß die Scripte systemweit zur Verfügung stehen und eingebunden werden können, wusste ich nicht. Großartig!
            Mit dem Tripper stehe ich auf dem Schlauch. 😄 😄 hatte ich was von Tripper geschrieben. Falls ja, ich versichere, dieser Tripper ist nicht ansteckend.
            Um das Komma in der Funktion ermitteleAndagedatum kümmere ich mich nach dem Abendessen…dann teste ich und melde mich.
            Das mit den vier Sayit Adaptern: Grund ist, das jeder Adapter eine anderes Sonos Gerät anspricht. Damit kann ich dann unterschiedliche Ansagen in unterschiedlichen Räumen platzieren...
              Abendessen fertig 😄
              Nach der von Dir vorgeschlagenen Korrektur der "Sekunden" läuft das Script fein. Und zur zur Info hier das log:
              ` > javascript.0 2016-03-03 20:09:58 info javascript.0 script.js.Pix_OPTIMIERT_Kueche_Ansage_mit_Variable_u__Geburtstag: Trigger: false
              javascript.0 2016-03-03 20:09:58 info javascript.0 script.js.Pix_OPTIMIERT_Kueche_Ansage_mit_Variable_u__Geburtstag: heute keine Geburtstage
              javascript.0 2016-03-03 20:09:58 info javascript.0 script.js.Pix_OPTIMIERT_Kueche_Ansage_mit_Variable_u__Geburtstag: Wetter: Teils Wolkig
              javascript.0 2016-03-03 20:09:58 info javascript.0 script.js.Pix_OPTIMIERT_Kueche_Ansage_mit_Variable_u__Geburtstag: Temp 1.6
              sonos.0 2016-03-03 20:09:46 info sonos.0 Restore state: volume - 40, mute: false, uri: x-file-cifs://192.168.0.76/musik/sound/2.mp3
              sonos.0 2016-03-03 20:09:29 info sonos.0 Play on sonos[RINCON_000E5825101001400]: http://192.168.0.80:8082/state/sayit.2.tts.mp3, Volume: 40
              sonos.0 2016-03-03 20:09:29 info sonos.0 try to control id sonos.0.root.192_168_0_32.tts with {"val":"40;http://192.168.0.80:8082/state/sayit.2. … :145667480
              sayit.2 2016-03-03 20:09:29 info sayit.2 Copied file '/opt/iobroker/node_modules/iobroker.sayit/say.mp3' to '/opt/iobroker/cache/96e81de5ce2d7032bb64be832b9dcafd.mp3'
              sayit.2 2016-03-03 20:09:29 info sayit.2 Set "sonos.0.root.192_168_0_32.tts: 40;http://192.168.0.80:8082/state/sayit.2.tts.mp3
              sayit.2 2016-03-03 20:09:28 info sayit.2 saying: Guten Morgen, heute ist Donnerstag der 3te März 2016. Es ist20 Uhr und 9 Minuten. Die Aussentemperatur beträgt 1,6 Grad. Wetter Bedingungen,Teils Wolkig . Heute haben Geburtstag: heu
              javascript.0 2016-03-03 20:09:28 info javascript.0 script.js.Pix_OPTIMIERT_Kueche_Ansage_mit_Variable_u__Geburtstag: Trigger: true
              javascript.0 2016-03-03 20:09:28 info javascript.0 script.js.Pix_OPTIMIERT_Kueche_Ansage_mit_Variable_u__Geburtstag: heute keine Geburtstage
              javascript.0 2016-03-03 20:09:28 info javascript.0 script.js.Pix_OPTIMIERT_Kueche_Ansage_mit_Variable_u__Geburtstag: Wetter: Teils Wolkig
              javascript.0 2016-03-03 20:09:28 info javascript.0 script.js.Pix_OPTIMIERT_Kueche_Ansage_mit_Variable_u__Geburtstag: Temp 1.6
              javascript.0 2016-03-03 20:09:28 info javascript.0 script.js.Pix_OPTIMIERT_Kueche_Ansage_mit_Variable_u__Geburtstag: Temp 1.6 `
              Nochmals vielen, vielen Dank.
              PS: Ab Samstag bin ich für eine Woche auf Geschäftsreise in den USA und ab 14.3. wieder da. Also nicht wundern, wenn ich mich nicht melde.
                @pix:
                Pix `
                Version 2? Ich habe aktuell die 1.2.0 laufen. Mein Problem ist z.B. das Fehlen einer Suchfunktion usw. Wo gibt es die Version 2.0??? Guthub?
                PPS: habe sie gefunden. Aber wie lädt man die?
                  pix last edited by
                  So:
                  http://forum.iobroker.com/viewtopic.php … 10&p=20277
                  oder im Admin Reiter "Adapter" links oben dere 3. Knopf "installieren aus eigener URL" dort
                  https://github.com/ioBroker/ioBroker.javascript/tarball/master
                  reinkopieren und starten.
                  Pix
                    Hallo Pix,
                    ich muss mich doch nochmal zu unserem Script melden. Es läuft zwar täglich durch, aber die Geburtstagsansage funktioniert nicht durchgehend. Jetzt hatte ich den Fall, dass Montag ein Name angesagt wurde, der sich dann täglich wiederholt. Also, Dienstag gab es keinen Geburtstag und der Name vom Montag wurde weiterhin angesagt. Auch am Mittwoch. Eigentlich hätte dann "niemand" gesagt werden müssen. Irgendwie habe ich das Gefühl, dass nicht immer neue Werte eingelesen werden, obwohl ich via iCal jede Nacht einmal mit "57 1 * * *" den Kalender abfrage. Hier nochmal das Script, das ich benutze
                    `// Test mit Variable;
                    // Besser ist es, gleich die VARIABLE SayIt hier abzufragen.
                    var idSayVar = "hm-rega.0.38101";
                    // Definition Sayit für "3" = Kueche;
                    var idSayIt =            "sayit.3.tts.text";
                    var lautstaerke = 40;
                    // Quellen
                    var idWetter =           "hm-rega.0.29954";
                    var idTemperatursensor = "hm-rpc.0.LEQ0177463.1.TEMPERATURE"; /*Temperatursensor:1.TEMPERATURE*/
                    var idGeburtstage =      "javascript.0.Kalenderereignisse.heute";
                    function ermitteleAnsagedatum () {
                        //Wochentag ermitteln
                        var d = new Date ();
                        var w = new Array("Sonntag","Montag","Dienstag","Mittwoch","Donnerstag","Freitag","Samstag");
                        var wochentag = w[d.getDay()];
                        //Tagesdatum ermitteln
                        var tag = d.getDate();
                        //Monat ermitteln
                        var month = new Array("Januar","Februar","März","April","Mai","Juni","Juli","August","September","Oktober","November","Dezember");
                        var monat = month[d.getMonth()];
                        //Jahr ermitteln
                        var jahr = d.getFullYear();
                        //Stunde ermitteln
                        var stunde = d.getHours();
                        //Minute ermitteln
                        var minute = d.getMinutes();
                        return { // zurückgeben
                            'Jahr'      : jahr,
                            'Monat'     : monat,
                            'Tag'       : tag,
                            'Wochentag' : wochentag,
                            'Stunde'    : stunde,
                            'Minute'    : minute
                    function ermitteleWetter () { // Wetterbedingungen
                        var wetterdaten = getState(idWetter).val;
                        log('Wetter: ' + wetterdaten);
                        return(wetterdaten);
                    function ermitteleAnsageTemperatur () {
                        // Die Außentemperatur ist xx. Das Wetter heute ist xx
                        // Einfache Temperaturansage mit SayIt.
                        // Variante 1 mittels splitten der Temperatur, damit die Ansage nicht
                        // "Es sind 18 Punkt 2 Grad " sagt.
                        var temperatursensor = getState(idTemperatursensor).val;
                        var temp_string = temperatursensor.toString();
                        log('Temp  ' + temp_string);
                        var temp_array = [];
                        temp_array = temp_string.split(".");
                        // Fange leere Nachkommastellen ab. Das passiert, wenn die Temperatur z. B. 18.0 ist.
                        // Es wird dann nur "18" gelesen.
                        if (!temp_array[1]) {
                            temp_array[1] = "0";
                            log("Die Nach-Kommastelle in temp_array[1] war nicht vorhanden und wird nun fest auf 0 gesetzt.");
                        return{
                            'Ganzzahl'      : temp_array[0],
                            'Nachkommazahl' : temp_array[1]
                    function ermitteleGeburtstage () {
                        var geburtstage = getState(idGeburtstage).val;
                        if (geburtstage.length < 2) { // wenn der Inhalt des Objektes "idGeburtstage" weniger als 2 Zeichen lang ist (also praktisch leer), dann ...
                            geburtstage = 'niemand'; // oder "niemand", "keiner"
                        log(geburtstage);
                        return (geburtstage);
                    // Trigger für Ansage
                    on(idSayVar, function (data) {
                        var ansagetext = "Guten Morgen, heute ist " + ermitteleAnsagedatum().Wochentag + " der " + ermitteleAnsagedatum().Tag + "te " + ermitteleAnsagedatum().Monat + ' ' + ermitteleAnsagedatum().Jahr
                                + ". Es ist" + ermitteleAnsagedatum().Stunde + "  Uhr und " + ermitteleAnsagedatum().Minute + "  Minuten."
                                + " Die Aussentemperatur beträgt " + ermitteleAnsageTemperatur().Ganzzahl + "," + ermitteleAnsageTemperatur().Nachkommazahl + " Grad."
                                + " Wetter Bedingungen," + ermitteleWetter() +" ."
                                + " Heute haben Geburtstag: "+ ermitteleGeburtstage() +" .";
                        log('Trigger: ' + data.state.val);
                        if (data.state.val === true) {
                            setState(idSayIt, lautstaerke + ";" + ansagetext);  // hier also ("40;Guten Morgen ...")
                    /* Kalenderevent auswerten ----> nur Geburtstage
                    sucht im iCal Adapter nach events (heute)
                    auf Anfrage von Skorpil im Forum erstellt.
                    http://forum.iobroker.de/viewtopic.php?f=21&t=2347&p=20627&sid=524f9dda2f313d3cbb183941df61fc38#p20627
                    27.02.2016 erstellt von Pix
                    02.03.2016 Anpassung und Aufbereitung für Sprachausgabe
                    //Datum als String ermitteln;
                    function ermitteleDatum() {
                        var d= new Date();
                            var day = new Array("00","01","02","03","04","05","06","07","06","09","10","11","12","13","14","15","16","17","18","19","20","21","22","23","24","25","26","27","28","29","30","31");
                            var t = day[d.getDate().toString()];
                        //Monat ermitteln
                            var month = new Array("01","02","03","04","05","06","07","08","09","10","11","12");
                            var m = month[d.getMonth().toString()];
                        //Jahr ermitteln
                            var j = d.getFullYear().toString();
                        var datum= t+"."+m+"."+j+" ";
                        //log("datum:   " + datum);
                        return (datum);
                    createState('Kalenderereignisse.heute', '', {
                        name: 'Events von heute',
                        type: 'string'
                    var idListe =  'Kalenderereignisse.heute';
                    function pruefeKalender() {
                        var inhalt = getState('ical.0.data.table').val;
                        var heute = ermitteleDatum();
                        try{
                            var ereignisse = JSON.stringify(inhalt, null, 2); // Ausgabe als String
                            //log(ereignisse);
                            var ereignisheute = '', // Liste (kommasepariert)
                                ereignisheute_zeilen = ''; // Liste (mit Zeilenumbruch, zB für Anzeige in VIS)
                            for(var i = 0; i <inhalt.length; i++)/{/alle/events/durchgehen/if/(/(inhalt[i].date.indexof(heute)/!="-1)" ||/(inhalt[i].date.indexof('heute')/)/strings/datum/oder/relatives/(nicht/nicht)/gefunden/var/ereignis="inhalt[i].event;" komma/im/namen/ersetzen="">0) ? ', ' : '';
                                    ereignisheute = ereignisheute + komma + ereignis;
                                    ereignisheute = ereignisheute.replace('Geburtstag von ', ''); // "Geburtstag von " löschen
                            // Aufbereitung für die Ansage (falls vorhanden, wird letztes Komma durch und ersetzt)
                            var lastkomma = ereignisheute.lastIndexOf(','); // letztes Komma in der Reihe
                            if (lastkomma != -1) {
                               var vorn = ereignisheute.slice(0,lastkomma-1);
                               var hinten = ereignisheute.slice(lastkomma+1, ereignisheute.length);
                               ereignisheute = vorn + ' und' + hinten;
                            // Ende Aufbereitung für die Ansage
                            setState(idListe, ereignisheute);
                            log('Geburtstage: ' + ereignisheute);
                        } catch (fehler_try) {
                            log('Fehler beim Kalenderevent einlesen ' + fehler_try);
                    // bei Aktualisierung des Kalenders
                    on ({id:'ical.0.events.Geburtstag', change: 'any'}, function(data) {
                        pruefeKalender();
                    //bei Skriptstart
                    pruefeKalender();</inhalt.length;>`
                    Kannst Du mir helfen? Hast Du eine Idee, woran das liegen könnte?
                    Liebe Grüße
                    Bernd[/i][/i][/i]
                      pix last edited by
                      Hallo Bernd,
                      nur ganz kurz:
                      Klappt es denn, wenn du das Skript neu startest?
                      Dann könntest du die Funktion pruefeKalender jeden Tag eine/zwei Minuten nach dem Erneuern des Kalenders starten?
                      schedule("58,59 1 * * *", prufeKalender);
                      Pix
                        Lieber Pix,
                        Danke für Deine rasche Antwort.
                        Du scheinst da den richtigen Riecher zu haben. Gestern Abend habe ich das Skript manuell neu gestartet und dann kam heute auch die richtige Ansage.
                        Ich werde Deinen Hinweis gerne prüfen. Meine Frage: wo müsste ich denn Deinen Code schedule unterbringen? Im Skript am Ende? Oder in einem neuen Skript? Du weißt, ich bin ja nicht so der Java Profi….
                        Danke für die Hilfe,
                        Bernd
                          Lieber Pix,
                          nochmal ich. 😄
                          Ich habe jetzt am Ende des Skripts, nach "bei Skriptstart" noch " jede Nacht um 02:00" ausführen" ergänzt. Ist das dort richtig? Oder gehört der schedule Ausdruck in ein gesondertes Java Skript?
                          //bei Skriptstart
                          pruefeKalender();
                          //und jede Nacht um 02:00 ausführem
                          schedule("0 2 * * *", pruefeKalender);
                          Im log steht jetzt
                          javascript-0 2016-11-24 16:49:33.953 info script.js.Pix_OPTIMIERT_(Kueche)__Ansage_mit_Variable_u__Geburtstag: registered 2 subscriptions and 2 schedules
                          javascript-0 2016-11-24 16:49:33.945 info script.js.Pix_OPTIMIERT_(Kueche)__Ansage_mit_Variable_u__Geburtstag: Geburtstage:
                          javascript-0 2016-11-24 16:49:33.828 info Start javascript script.js.Pix_OPTIMIERT_(Kueche)__Ansage_mit_Variable_u__Geburtstag
                          Was bedeutet "registered 2 subscriptions and 2 schedules"?
                          Noch ein Hinweis resp. Frage: Du hast in Deinem schedule Ausdruck "58,59 1 * * *" also 58,59 angegeben. Was ist der Hintergrund?
                          Und, Du hast "prufeKalender" gepostet. Ich denke, es sollte "pruefeKalender" heissen.
                          Bitte noch einmal um kurzes feedback! Und ich werde morgen berichten, was passiert ist.
                          Liebe Grüße,
                          Bernd
                            Feedback:
                            Mit der Ergänzung des schedule Befehl wie oben beschrieben, scheint es zu funktionieren. Offenbar muss die pruefeKalender Funktion nach vorliegen neuer Werte in iCal neu gestartet werden, um diese einzulesen.
                            Ich werde das Verhalten weiter im "Regekbetrieb" 😄 beobachten und mich ggf. wieder melden.
                            Danke für die Unterstützung.
                              pix last edited by
                              Hallo Bernd,
                              wen dem wirklich so ist, dann kann man später im Skript den Start der Funktion an die Aktivierung des iCal Adapters koppeln. Denn natürlich kann man mit Javascript abfragen, wann und ob ein anderer Adapter gestartet wurde. Lass es mal ein paar (Geburts-)Tage so laufen, wie es gerade ist.
                              Pix
                                Lieber "Guru" Pix 😄 ,
                                Danke für den Tip. Wie Du sagst, ich schaue mir das jetzt im Regelbetrieb an.
                                Aaaaaber, mich würde sehr interessieren, wie die das Programm aussähe, um den iCal abzufragen. Bin neugierig!
                                Liebe Grüße
                                Bernd
                                  eagleye last edited by
                                  ich würde gerne bei einer meiner ical Instanzen (ical.0) nur die heutigen Termine anzeigen lassen im VIS. Unabhängig ob es Müll oder Geburtstage sind, sondern einfach ALLE Termine die NUR am heutigen Tag anstehen. Habe insgesamt 4 ical Instanzen, die unterschiedliche Kalender anzeigen. Es geht aber um die ical.0 Instanz welche im Vis als "Termine heute" ausgegeben wird. Ich schaffe es nicht über den adapter nur den heutigen Tag dort anzuzeigen.
                                  In diesen Thread habe ich ähnlich Ansätze gefunden. Weiß aber nicht welche das richtige für mich wäre, da es hier zusätzlich um Geburtstag un Sayit geht, was ich nicht bräuchte.
                                  Kann mir jemand helfen?
                                  Danke im Voraus.
                                  • Homer.J.
                                    Homer.J. last edited by
                                    Gib in der Instanz 1 Tag ein und aktualisiere den Adapter mal dann müsste es gehen.
                                      Das habe ich schon probiert.
                                      Dann zeigt er genau an, was auf dem Bild ist.
                                      Die Termine für heute UND für Morgen (was ja "1" ja ist).
                                      "0" eingeben stattdessen brachte auch nicht das ersehnte.
                                      Verstehe nicht warum man nicht im Adapter nur die heutigen Tage einstellen kann. 😞
                                      6867
