    4. Backitup v1.8.5 0kB
    Backitup v1.8.5 0kB
    • O
      oFbEQnpoLKKl6mbY5e13 @oFbEQnpoLKKl6mbY5e13 last edited by
      Installation von JS-Controller 3.2.11, selber Fehler.
      Vor Installation:
      Gestartet...
      [DEBUG] [iobroker] - host.iobroker-d 12765 states saved
      [DEBUG] [iobroker] - host.iobroker-d 18332 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_01_28-19_31_42_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [clean] - done
      [DEBUG] [telegram] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [EXIT] 0
      # pwd
      /opt/iobroker/node_modules/iobroker.js-controller
      # ls -la
      drwxr-xr-x    2 iobroker iobroker   4096 Jan 28 19:31 tmp
      Nach der Installation:
      Gestartet...
      [ERROR] [iobroker] - Uncaught Rejection: Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup'
          at Object.mkdirSync (fs.js:841:3)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:300:32
          at processTicksAndRejections (internal/process/task_queues.js:97:5)
      [EXIT] 6
      # pwd
      # ls -la
      drwxr-xr-x    2 root     root       4096 Jan 28 19:39 tmp
      • O
        oFbEQnpoLKKl6mbY5e13 @oFbEQnpoLKKl6mbY5e13 last edited by oFbEQnpoLKKl6mbY5e13
        Ach so, es ist nur der "tmp"-Ordner, der danach auf root steht:
        # ls -la
        insgesamt 512
        drwxr-xr-x    6 iobroker iobroker   4096 Jan 28 19:40 .
        drwxrwxrwx 1172 iobroker iobroker  36864 Jan 28 19:39 ..
        -rw-r--r--    1 iobroker iobroker  84725 Okt 26  1985 CHANGELOG.md
        -rw-r--r--    1 iobroker iobroker    420 Okt 26  1985 compactgroupController.js
        drwxr-xr-x    2 iobroker iobroker   4096 Jan 28 19:38 conf
        -rw-r--r--    1 iobroker iobroker    158 Okt 26  1985 controller.js
        -rw-r--r--    1 iobroker iobroker   8341 Okt 26  1985 gulpfile.js
        -rw-r--r--    1 iobroker iobroker     74 Okt 26  1985 iob
        -rwxr-xr-x    1 iobroker iobroker     33 Okt 26  1985 iobroker.js
        -rw-r--r--    1 iobroker iobroker      5 Jan 28 19:40 iobroker.pid
        -rw-r--r--    1 iobroker iobroker  59436 Okt 26  1985 io-package.json
        drwxr-xr-x   10 iobroker iobroker   4096 Jan 28 19:38 lib
        -rw-r--r--    1 iobroker iobroker   1135 Okt 26  1985 LICENSE
        -rw-r--r--    1 iobroker iobroker 207604 Okt 26  1985 main.js
        drwxr-xr-x   50 iobroker iobroker   4096 Jan 28 19:38 node_modules
        -rw-r--r--    1 iobroker iobroker   6476 Jan 28 19:38 package.json
        -rw-rw-rw-    1 iobroker iobroker    156 Jan 28 19:42 pids.txt
        -rw-r--r--    1 iobroker iobroker  45055 Okt 26  1985 README.md
        -rw-r--r--    1 iobroker iobroker   5677 Okt 26  1985 reinstall.js
          Thomas Braun Most Active @oFbEQnpoLKKl6mbY5e13 last edited by Thomas Braun
          @ofbeqnpolkkl6mby5e13
          Da sind ja ACLs gesetzt. Schau mit
          gefacl /opt/iobroker/node_modules/iobroker.js-controller/tmp
          nach den vollständigen Rechten.
          Schreibrechte der Gruppe fehlen übrigens schon in deiner ersten Version.
          • O
            oFbEQnpoLKKl6mbY5e13 @Thomas Braun last edited by
            # getfacl /opt/iobroker/node_modules/iobroker.js-controller/tmp
            getfacl: Entferne führende '/' von absoluten Pfadnamen
            # file: opt/iobroker/node_modules/iobroker.js-controller/tmp
            # owner: root
            # group: root
            user::rwx
            group::r-x
            other::r-x
              Okay...
              Richtig sähe das so aus:
              pi@raspberrypi:/opt/iobroker/node_modules/iobroker.js-controller $ getfacl tmp/
              # file: tmp/
              # owner: iobroker
              # group: iobroker
              user::rwx
              group::r-x
              group:iobroker:rwx
              mask::rwx
              other::r-x
              default:user::rwx
              default:group::r-x
              default:group:iobroker:rwx
              default:mask::rwx
              default:other::r-x
              O F 2 Replies Last reply Reply Quote 0
              • O
                Okay.
                Ist schon komisch. Eigentlich ist es aber auch egal, denn nach iobroker fix geht es ja jedes Mal wieder. Und den JS-Controller aktualisiert man jetzt auch nicht alle Tage.
                • O
                  oFbEQnpoLKKl6mbY5e13 @fastfoot last edited by
                  @fastfoot
                  Ohne mit weiteren Logs zu langweilen. Mit "iobroker upgrade self" tritt der Fehler nicht auf. Vielen Dank!
                    fastfoot @oFbEQnpoLKKl6mbY5e13 last edited by
                    @ofbeqnpolkkl6mby5e13 sagte in Backitup v1.8.5 0kB:
                    @fastfoot
                    gut zu lesen! Meine Vermutung war ja dass man im Falle der npm installation ja nicht der user iobroker ist und sich deshalb die Berechtigungen des tmp Ordners ändern. So einfach ist es aber wohl nicht, denn in meinen Tests hatte ich den Ordner auch vor der Installation gelöscht und dennoch war er richtig mit iobroker:iobroker geflaggt, auch bei einer npm Installation. Gerade weil unsere Setups durch Container auf QNAP sehr ähnlich sind, hatte mich das verwundert
                    • O
                      @fastfoot
                      Ich verstehe auch nicht, weshalb ausschließlich der tmp-Ordner betroffen ist.
                      Ganz vielen Dank für deine Hilfe und Beharrlichkeit!
                      Auch danke an @thomas-braun, der trotz seiner Container-Abneigung noch mal geholfen hat!
                        fastfoot @Thomas Braun last edited by
                        @thomas-braun sagte in Backitup v1.8.5 0kB:
                        das hat mich jetzt doch mal interessiert, mit acl's kenne ich mich aber Null aus. Scheinbar liegt das nicht (nur) am Container, sondern auch daran dass die QNAP das generell nicht nutzt. Alle Angaben von getfacl sehen auch auf dem Host so aus wie von @oFbEQnpoLKKl6mbY5e13 gezeigt, die von dir gezeigten Zusatzangaben fehlen nicht nur bei den shared ordnern sondern auch in reinen Linux Ordnern wie /bin, /sbin etc. Die nutzen auch keine Standard Distro, uname -a sieht dann so aus: Linux qnapnas 4.14.24-qnap #1 SMP Thu Jan 7 01:26:20 CST 2021 x86_64 GNU/Linux
                          Thomas Braun Most Active @fastfoot last edited by
                          @fastfoot Auf welchem Dateisystem läuft denn das da?
                            fastfoot @Thomas Braun last edited by fastfoot
                            jetzt hast du mich erwischt 🙂
                            ein Eintrag aus dmesg lautet so. ist bei mir ein Raid5
                            EXT4-fs (sdd1): mounting ext3 file system using the ext4 subsystem
                            Thomas Braun O 2 Replies Last reply Reply Quote 0
                              @fastfoot Also ein erweitertes ext3. Keine Ahnung was da genau getrieben wird. Mit ACL bin ich aber auch nicht auf Du und Du. Aber es scheint da einen Zusammenhang zu geben.
                              • O
                                @fastfoot
                                Kann es an npm liegen?
                                # npm -v
                                6.14.11
                                  @fastfoot
                                  ich habe die 6.14.10, glaube aber nicht. Vielleicht finden die Entwickler ja noch die Ursache, wenn das häufiger auftritt. Aber jetzt läuft es ja, ich upgrade npm eigentlich auch immer recht zeitnah, habe aber viel mit meinen diversen Containern rumgespielt und ständig gewechselt, die buanet images kommen ja noch mit der .10 und ich habe noch nicht geupdated. Ist ja aber auch nicht soo wichtig normalerweise, man merkt im Normalfall ja keinen Unterschied
                                  4043
