    4. Test Adapter HeatingControl v2.12.x
    • Chaot
      Chaot @Rene_HM last edited by
      @rene_hm Wenn ich auf "Sensoren suchen " gehe kommt immer ein Fehler:
      host.ioBroker	2021-01-30 19:09:15.649	error	instance system.adapter.heatingcontrol.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.ioBroker	2021-01-30 19:09:15.649	error	Caught by controller[1]: at Object.message (/opt/iobroker/node_modules/iobroker.heatingcontrol/main.js:136:25)
      host.ioBroker	2021-01-30 19:09:15.649	error	Caught by controller[1]: at ListAddTempSensors (/opt/iobroker/node_modules/iobroker.heatingcontrol/main.js:548:39)
      host.ioBroker	2021-01-30 19:09:15.648	error	Caught by controller[1]: at Check4TempSensor (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/devicedetect.js:168:48)
      host.ioBroker	2021-01-30 19:09:15.647	error	Caught by controller[1]: TypeError: Cannot read property 'native' of null
      host.ioBroker	2021-01-30 19:09:15.646	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
      heatingcontrol.0	2021-01-30 19:09:14.938	warn	(17124) Terminated (UNCAUGHT_EXCEPTION): Without reason
      heatingcontrol.0	2021-01-30 19:09:14.876	error	(17124) Cannot read property 'native' of null
      heatingcontrol.0	2021-01-30 19:09:14.875	error	at Object.message (/opt/iobroker/node_modules/iobroker.heatingcontrol/main.js:136:25)
      heatingcontrol.0	2021-01-30 19:09:14.875	error	at ListAddTempSensors (/opt/iobroker/node_modules/iobroker.heatingcontrol/main.js:548:39)
      heatingcontrol.0	2021-01-30 19:09:14.875	error	at Check4TempSensor (/opt/iobroker/node_modules/iobroker.heatingcontrol/lib/devicedetect.js:168:48)
      heatingcontrol.0	2021-01-30 19:09:14.875	error	(17124) TypeError: Cannot read property 'native' of null
      heatingcontrol.0	2021-01-30 19:09:14.865	error	(17124) unhandled promise rejection: Cannot read property 'native' of null
      heatingcontrol.0	2021-01-30 19:09:14.858	error	(17124) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.ioBroker	2021-01-30 19:08:45.342	info	instance system.adapter.heatingcontrol.0 started with pid 17124
      Ebenfalls wenn ich auf Thermostate suchen gehe.
      • Dominik F.
        Dominik F. @Rene_HM last edited by
        @rene_hm
        Mir ist aufgefallen, dass wenn man den Button copyProfile drückt, die Profilparameter nicht übernommen werden. Ist das so gewollt?
        • Rene_HM
          Rene_HM Developer @Chaot last edited by
          @chaot sagte in Test Adapter HeatingControl v2.1.x:
          kannst du das ganze mal mit debug log zeigen? nur den Teil, nachdem du den Button drückst...
          • Rene_HM
            Rene_HM Developer @Dominik F. last edited by
            @dominik-f sagte in Test Adapter HeatingControl v2.1.x:
            Da sollte das aktuelle Profil in das nächste kopiert werden (also z.Bsp. von Profile 1 auf 2 ) inkl. aller Profildaten... was fehlt konkret bei dir?
            Dominik F. 1 Reply Last reply Reply Quote 0
            • Dominik F.
              Dominik F. @Rene_HM last edited by Dominik F.
              @rene_hm
              Alle Profilparameter.
              Edit:
              Mir ist gerade noch was aufgefallen. Hab in den Einstellungen einen Raum umbenannt und es wurde alles im vorhandenen Raum gelöscht und quasi ein neuer Raum erstellt. Da wäre es schön, wenn dies nicht passiert sondern nur der Raumname geändert werden könnte.
              • Rene_HM
                Rene_HM Developer @Dominik F. last edited by Rene_HM
                Das schaue ich mir für die 2.2.0 nochmal an, da kommen ja auch die buttons für die vis-Integration...
                Das ist nicht so einfach, da alles auf dem Namen der Datenpunkte beruht, die ja bekanntermassen den Raumnamen beinhalten. Man müsste also ein Umbenennen erkennen und vorhandene Datenpunkte kopieren. Da dieser use case eher selten auftritt würde ich mir diesen Aufwand gern sparen. Du darfst aber in github einen Feature-Request hinterlegen, vielleicht benötigen das doch noch andere user, was die Priorität evtl. erhöht...
                • V
                  vikk88 last edited by vikk88
                  Habe jetzt mal mit den Sensoren und den Offsets rumprobiert. Also ich habe Aqara Temperatursensoren, diese gebe ich dann bei zusätzliche Temperatursensoren an, richtig? Beim Thermostat gebe ich den Datenpunkt vom Thermostat an also den der die Temperatur misst. Im Wohnzimmer zeigt der Aqara 1,5 grad weniger an als am Thermostat. Ein offset wird auch erkannt, nur wird jetzt am Thermostat 21,5 anstatt 20 Grad eingestellt. Müsste nicht eigentlich 18,5 eingestellt werden da ich ja möchte das der Aqara 20 grad anzeigt. Also das Thermostat müsste ja eigentlich runter regeln weil es im Raum ja schon wärmer ist als die eingestellten 20 Grad.
                  Laut Profileinstellung sollen 20 Grad im Raum sein. Momentan sind es 22,7 laut Aqara Sensor und das Thermostat ist auf 21.5 eingestellt
                  Edit: Ich habe die Sensoreinstellungen mal vertauscht. Also den Aqara Sensor bei Objekt Id Aktuelle Temperatur und bei zusätzliche Temperatursensoren den Wert vom Thermostat eingetragen. Jetzt zeigt er mir Minus Presets an und regelt die Thermostate runter
                  • Rene_HM
                    Rene_HM Developer @vikk88 last edited by
                    @vikk88 nur damit ich es richtig verstehe:
                    • Soll-Temperatur laut Profil = 20 °C
                    • Ist-Temperatur am Thermostat = 21,2°C (?)
                    • Ist-Temperatur am zusätzlichen Sensor = 22,7°C
                    • Offset = +1,5°C
                    • ergibt Soll-Temperatur am Thermostat = 21,5°C
                    Laut meinem Programmcode wird aber berechnet:
                    TempDiff = (Ist-Temperatur am Thermostat) - (Ist-Temperatur am zusätzlichen Sensor)
                    also
                    TempDiff = 21,2°C - 22,7°C = -1,5°C
                    Das würde zu einer korrigierten Solltemperatur von
                    20°C - 1,5°C = 18,5°C
                    führen...
                    • V
                      vikk88 @Rene_HM last edited by vikk88
                      @rene_hm also der Aqara (zusätzlicher Sensor) zeigt immer weniger an 22 dann werden am Thermostat (Ist Temp. Thermostat) 23,3 angezeigt.
                      Jetzt habe die Sensoreinstellungen mal vertauscht. Also den Aqara Sensor bei Objekt Id Aktuelle Temperatur und bei zusätzliche Temperatursensoren den Wert vom Thermostat eingetragen. Jetzt zeigt er mir Minus Presets an und regelt die Thermostate runter.
                      Mal eine Frage. Wäre es nicht besser den Offset vom Thermostat selber zu verstellen anstatt eine andere Temperatur einzugeben. Also den errechneten Wert beim offset Datenpunkt eintragen und das Thermostat auf der geünschten Temperatur stehen zu lassen?
                      • Rene_HM
                        @vikk88 wegen
                        https://github.com/rg-engineering/ioBroker.heatingcontrol/issues/182
                        habe ich noch etwas umgebaut.
                        Bitte installiere die aktuelle Version von github und achte auf warn-Meldungen im log. Diese Meldungen dann bitte hier posten...
                        Denkra created this issue in rg-engineering/ioBroker.heatingcontrol
                        closed Temperatur Offset #182
                        • V
                          @rene_hm okay werde nachher mal gucken. Aber mein Grundgedanke war richtig ? Die Aqara Sensoren bei zusätzlichen Temperatursenoren eintragen? Weil momentan habe ich es umgekehrt und es scheint zu funktionieren.
                          • Rene_HM
                            @vikk88 sagte in Test Adapter HeatingControl v2.1.x:
                            ja, genau.
                            Beliar_666 1 Reply Last reply Reply Quote 0
                            • Beliar_666
                              Beliar_666 @Rene_HM last edited by Beliar_666
                              @rene_hm
                              2-3 kleine Fragen:
                              Ich habe 1 Profil für 3 Räume, bisher war das Profil 0, jetzt will der Adapter mitmal Profil 1 haben, kann ich die 3 Räume irgendwie komplett von Profil 0 zu Profil 1 kopieren? Und wenn ja, wie?
                              Bei Periods war es vorher von 0-4 nummeriert, jetzt auf einmal von 1-5?
                              Heisst jetzt also alle Räume neu eingeben?
                              • Rene_HM
                                Rene_HM Developer @Beliar_666 last edited by
                                @beliar_666 sagte in Test Adapter HeatingControl v2.1.x:
                                ja, bei Wechsel von Version 1.x zu 2.x ist das einmalig notwendig. Ab 2.x kann man die Profile als json speichern und wieder laden...
                                  FI_84 last edited by
                                  @Rene_HM
                                  Ich benötige ein zweites profil. Ist es jetzt möglich das 1. Profil komplett zu duplizieren?
                                  • N
                                    Nordischerjung @Rene_HM last edited by
                                    @rene_hm
                                    Moin,
                                    ich benutze nun auch die Version 2.1.0 und bekomme folgende Warnung obwohl die Soll Temp 12° am Thermostat (bei Fenster offen) eingestellt ist
                                    heatingcontrol.0	2021-02-02 11:12:03.778	warn	(14190) Schlafzimmer manual mode 12 but ignored
                                    heatingcontrol.0	2021-02-02 11:09:53.999	warn	(14190) Schlafzimmer manual mode 12 but ignored
                                    heatingcontrol.0	2021-02-02 11:07:25.094	warn	(14190) Schlafzimmer manual mode 12 but ignored
                                    • Rene_HM
                                      Rene_HM Developer @Nordischerjung last edited by
                                      @nordischerjung Die Meldung kannst du ignorieren, die war nur dafür da, dass ich die Stelle im code wieder finde...
                                      • N
                                        @rene_hm sagte in Test Adapter HeatingControl v2.1.x:
                                        Aha, ok danke
                                          Michi_Pi last edited by
                                          @Rene_HM Ich habe ein Problem mit einem Fensterkontakt. Im Schlafzimmer wird zwar erkannt wenn das Fenster geöffnet wird, allerdings wird die Temp. nicht runtergeregelt. Betrifft aber nur das eine Zimmer, bei den anderen geht es.
                                          Hier der Raum Schlafzimmer
                                          Hier mal ein Teil vom Log. Weiß nicht genau was du brauchst. Danke.
                                          heatingcontrol.0	2021-02-03 08:18:02.544	debug	(31007) Reaching SetStatusLog for Rooms.Schlafzimmer.StatusLog
                                          heatingcontrol.0	2021-02-03 08:18:02.543	debug	(31007) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.StatusLog {"val":" 03.02.2021 08:18:02 auto 17°C <br> 03.02.2021 08:17:36 starting 17°C <br> 03.02.2021 08:17:32 starting <br>","ack
                                          heatingcontrol.0	2021-02-03 08:18:02.350	debug	(31007) HandleStateChanges CurrentTimePeriod 2
                                          heatingcontrol.0	2021-02-03 08:18:02.349	debug	(31007) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.CurrentTimePeriod {"val":2,"ack":false,"ts":1612336682346,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin",
                                          heatingcontrol.0	2021-02-03 08:18:02.174	debug	(31007) UpdateDPs for Schlafzimmer auto
                                          heatingcontrol.0	2021-02-03 08:18:02.174	debug	(31007) HandleActors for Schlafzimmer auto
                                          heatingcontrol.0	2021-02-03 08:18:02.174	debug	(31007) Schlafzimmer nothing to do to for hm-rpc.1.00201A499795D0.1.SET_POINT_TEMPERATURE , target 17 is already set 17
                                          heatingcontrol.0	2021-02-03 08:18:02.167	debug	(31007) SetRoomTemperature started for Schlafzimmer target 17 with offset 0
                                          heatingcontrol.0	2021-02-03 08:18:02.165	debug	(31007) got {"val":5,"ack":true,"ts":1612336643480,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1612336643480}
                                          heatingcontrol.0	2021-02-03 08:18:02.120	debug	(31007) checking min temp with Rooms.Schlafzimmer.MinimumTemperature
                                          heatingcontrol.0	2021-02-03 08:18:02.120	debug	(31007) Schlafzimmer auto mode (incl. reduced): target 17
                                          heatingcontrol.0	2021-02-03 08:18:02.120	debug	(31007) Schlafzimmer auto mode: target 17
                                          heatingcontrol.0	2021-02-03 08:18:02.119	debug	(31007) CalculateRoomTemperature for Schlafzimmer auto
                                          heatingcontrol.0	2021-02-03 08:18:02.119	debug	(31007) ChangeStatus Profilepoint in Schlafzimmer just recalc
                                          heatingcontrol.0	2021-02-03 08:18:02.119	debug	(31007) Schlafzimmer ### ChangeStatus ProfilPoint to -99 in auto
                                          heatingcontrol.0	2021-02-03 08:18:02.069	debug	(31007) Reaching SetStatusLog for Rooms.Schlafzimmer.StatusLog
                                          heatingcontrol.0	2021-02-03 08:17:59.061	info	(31007) start calculate current profile point for profile type 2 (Mo-Fr / Sa - Su)
                                          heatingcontrol.0	2021-02-03 08:17:59.010	debug	(31007) Reaching SetStatusLog for Rooms.Schlafzimmer.StatusLog
                                          heatingcontrol.0	2021-02-03 08:17:59.010	debug	(31007) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.StatusLog {"val":" 03.02.2021 08:17:36 starting 17°C <br> 03.02.2021 08:17:32 starting <br>","ack":false,"ts":1612336679006,"q":0,"f
                                          heatingcontrol.0	2021-02-03 08:17:58.879	debug	(31007) AddStatusToLog skip Schlafzimmer starting 17°C
                                          heatingcontrol.0	2021-02-03 08:17:58.791	debug	(31007) HandleStateChanges CurrentTimePeriod 2
                                          heatingcontrol.0	2021-02-03 08:17:58.791	debug	(31007) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.CurrentTimePeriod {"val":2,"ack":false,"ts":1612336678787,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin",
                                          heatingcontrol.0	2021-02-03 08:17:58.609	debug	(31007) UpdateDPs for Schlafzimmer starting
                                          heatingcontrol.0	2021-02-03 08:17:58.609	debug	(31007) ChangeStatus Profilepoint in Schlafzimmer just recalc
                                          heatingcontrol.0	2021-02-03 08:17:58.609	debug	(31007) Schlafzimmer ### ChangeStatus ProfilPoint to -99 in starting
                                          heatingcontrol.0	2021-02-03 08:17:58.608	debug	(31007) Schlafzimmer found profile point at Period 2 08:00 with 17
                                          heatingcontrol.0	2021-02-03 08:17:58.474	info	(31007) start calculate current profile point for profile type 2 (Mo-Fr / Sa - Su)
                                          heatingcontrol.0	2021-02-03 08:17:58.467	debug	(31007) Reaching SetStatusLog for Rooms.Schlafzimmer.StatusLog
                                          heatingcontrol.0	2021-02-03 08:17:55.381	debug	(31007) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.StatusLog {"val":" 03.02.2021 08:17:36 starting 17°C <br> 03.02.2021 08:17:32 starting <br>","ack":false,"ts":1612336675376,"q":0,"f
                                          heatingcontrol.0	2021-02-03 08:17:55.249	debug	(31007) AddStatusToLog skip Schlafzimmer starting 17°C
                                          heatingcontrol.0	2021-02-03 08:17:55.156	debug	(31007) HandleStateChanges CurrentTimePeriod -1
                                          heatingcontrol.0	2021-02-03 08:17:55.155	debug	(31007) ### handle state change heatingcontrol.0.Rooms.Schlafzimmer.CurrentTimePeriod {"val":-1,"ack":false,"ts":1612336675152,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin"
                                          heatingcontrol.0	2021-02-03 08:17:54.943	debug	(31007) UpdateDPs for Schlafzimmer starting
                                          heatingcontrol.0	2021-02-03 08:17:54.943	debug	(31007) Schlafzimmer ### ChangeStatus PublicHolidyToday to false in starting
                                          heatingcontrol.0	2021-02-03 08:17:54.892	debug	(31007) Reaching SetStatusLog for Rooms.Schlafzimmer.StatusLog
                                          heatingcontrol.0	2021-02-03 08:17:29.372	debug	(31007) subscribe Rooms.Gang.StatusLog
                                          heatingcontrol.0	2021-02-03 08:17:29.372	debug	(31007) subscribe Rooms.Gang.WindowIsOpen
                                          heatingcontrol.0	2021-02-03 08:17:29.371	debug	(31007) subscribe Rooms.Gästezimmer.StatusLog
                                          heatingcontrol.0	2021-02-03 08:17:29.371	debug	(31007) subscribe Rooms.Gästezimmer.WindowIsOpen
                                          heatingcontrol.0	2021-02-03 08:17:29.371	debug	(31007) subscribe Rooms.Schlafzimmer.StatusLog
                                          heatingcontrol.0	2021-02-03 08:17:29.370	debug	(31007) subscribe Rooms.Schlafzimmer.WindowIsOpen
                                          heatingcontrol.0	2021-02-03 08:17:29.370	debug	(31007) subscribe Rooms.Wohnzimmer.StatusLog
                                          heatingcontrol.0	2021-02-03 08:17:29.370	debug	(31007) subscribe Rooms.Wohnzimmer.WindowIsOpen
                                          heatingcontrol.0	2021-02-03 08:17:29.369	debug	(31007) subscribe Rooms.Büro.StatusLog
                                          heatingcontrol.0	2021-02-03 08:17:29.369	debug	(31007) subscribe Rooms.Büro.WindowIsOpen
                                          heatingcontrol.0	2021-02-03 08:17:29.369	debug	(31007) subscribe Rooms.Küche.StatusLog
                                          heatingcontrol.0	2021-02-03 08:17:29.368	debug	(31007) subscribe Rooms.Küche.WindowIsOpen
                                          heatingcontrol.0	2021-02-03 08:17:29.368	debug	(31007) subscribe Rooms.Bad.StatusLog
                                          heatingcontrol.0	2021-02-03 08:17:29.368	debug	(31007) subscribe Rooms.Bad.WindowIsOpen
                                          heatingcontrol.0	2021-02-03 08:17:29.367	debug	(31007) Set trigger
                                          heatingcontrol.0	2021-02-03 08:17:29.366	debug	(31007) CreateCurrentTimePeriodTrigger done
                                          heatingcontrol.0	2021-02-03 08:17:29.366	debug	(31007) reaching CreateCurrentTimePeriodTrigger - Oldroom= none ChoosenRoom= Schlafzimmer
                                          heatingcontrol.0	2021-02-03 08:17:29.365	debug	(31007) CreateCurrentTimePeriodTrigger called
                                          heatingcontrol.0	2021-02-03 08:17:29.365	debug	(31007) SetTempDecreaseModeValueLists done
                                          heatingcontrol.0	2021-02-03 08:17:28.979	debug	(31007) SetTempDecreaseModeValueLists called
                                          heatingcontrol.0	2021-02-03 08:17:28.978	debug	(31007) CreateWindowStatesTable done
                                          heatingcontrol.0	2021-02-03 08:17:28.886	debug	(31007) CreateWindowStatesTable called
                                          heatingcontrol.0	2021-02-03 08:17:28.886	debug	(31007) InitWindowStates done
                                          heatingcontrol.0	2021-02-03 08:17:28.885	debug	(31007) windowstate Gang {"val":false,"ack":true,"ts":1612336644814,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1612336644814} timestamp 3 Feb 2021 08:17:24 false
                                          heatingcontrol.0	2021-02-03 08:17:28.874	debug	(31007) windowstate Gästezimmer {"val":false,"ack":true,"ts":1612336643991,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1612336643991} timestamp 3 Feb 2021 08:17:23
                                          heatingcontrol.0	2021-02-03 08:17:28.869	debug	(31007) windowstate Schlafzimmer {"val":false,"ack":true,"ts":1612336643151,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1612336643151} timestamp 3 Feb 2021 08:17:23
                                          heatingcontrol.0	2021-02-03 08:17:28.828	debug	(31007) windowstate Wohnzimmer {"val":false,"ack":true,"ts":1612336642250,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1612336642250} timestamp 3 Feb 2021 08:17:22 f
                                          heatingcontrol.0	2021-02-03 08:17:28.826	debug	(31007) windowstate Büro {"val":false,"ack":true,"ts":1612336641045,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1612336641045} timestamp 3 Feb 2021 08:17:21 false
                                          heatingcontrol.0	2021-02-03 08:17:28.785	debug	(31007) windowstate Küche {"val":false,"ack":true,"ts":1612336640198,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1612336640198} timestamp 3 Feb 2021 08:17:20 false
                                          heatingcontrol.0	2021-02-03 08:17:28.783	debug	(31007) windowstate Bad {"val":false,"ack":true,"ts":1612336639346,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1612336639346} timestamp 3 Feb 2021 08:17:19 false
                                          heatingcontrol.0	2021-02-03 08:17:28.740	debug	(31007) InitWindowStates called
                                          heatingcontrol.0	2021-02-03 08:13:58.567	info	(30812) calculate current profile point for all rooms
                                          heatingcontrol.0	2021-02-03 08:13:58.565	info	(30812) checking external states done
                                          heatingcontrol.0	2021-02-03 08:13:40.964	info	(30812) checking external states
                                          heatingcontrol.0	2021-02-03 08:13:38.238	info	(30812) check all active sensors
                                          heatingcontrol.0	2021-02-03 08:13:38.140	warn	(30812) could not read Rooms.Schlafzimmer.TemperatureOffset
                                          heatingcontrol.0	2021-02-03 08:13:36.643	error	(30812) SetStatusLog: could not read Rooms.Schlafzimmer.StatusLog
                                          heatingcontrol.0	2021-02-03 08:13:36.237	error	(30812) SetStatusLog: could not read Rooms.Schlafzimmer.StatusLog
                                          heatingcontrol.0	2021-02-03 08:13:35.838	error	(30812) SetStatusLog: could not read Rooms.Schlafzimmer.StatusLog
                                          heatingcontrol.0	2021-02-03 08:13:35.477	error	(30812) SetStatusLog: could not read Rooms.Schlafzimmer.StatusLog
                                          heatingcontrol.0	2021-02-03 08:13:35.104	info	(30812) start statemachine
                                          heatingcontrol.0	2021-02-03 08:13:35.103	error	(30812) exception in SetVis [TypeError: Cannot read property 'val' of null]
                                          N Rene_HM 2 Replies Last reply Reply Quote 0
                                          • N
                                            Nordischerjung @Michi_Pi last edited by
                                            @michi_pi
                                            Moin,
                                            hast du den Sensor aktiviert in der Einstellung? Welche Temperatur hast du eingetragen?
                                            heating
                                            236
                                            3158
                                            1847274
