    4. Zwave 0.4
    Zwave 0.4
    • Bluefox
      Bluefox last edited by
      @Patrick:
      ich schaffe es leider auch nicht den Adapter zu installieren
      bei mir kommt immer dieser Fehler
      ! C:\Program Files\IO BROKER\ioBroker>npm install https://github.com/ioBroker/ioBroker.zwave/tarball/master --production | iobroker.zwave@0.4.2 preinstall C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.zwave node preinstall.js ! win32 is currently not supported \ openzwave-shared@1.2.0 preinstall C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.zwave\node_modules\openzwave-shared node lib/install-ozw.js ! Installing Open Z-Wave Installing dependencies to C:\Users\rickfl\AppData\Local\Temp\ozwinstall-9bksiu4ygb9 npm WARN deprecated wrench@1.5.9: wrench.js is deprecated! You should check out fs-extra (https://github.com/jprichardson/node-fs-extra) for any operations you were using wrench for. Thanks for all the usage over the years. module.js:327 throw err; ^ ! Error: Cannot find module 'C:\Users\rickfl\AppData\Local\Temp\ozwinstall-9bksiu4ygb9/node_modules/request' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Module.module.exports (C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.zwave\node_modules\openzwave-shared\lib\install-ozw.js:165:13) at Object. <anonymous>(C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.zwave\node_modules\openzwave-shared\lib\install-ozw.js:220:12) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.load (module.js:343:32) at Function.Module._load (module.js:300:12) npm ERR! Windows_NT 10.0.10586 npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "https://github.com/ioBroker/ioBroker.zwave/tarball/master" "--production" npm ERR! node v4.6.1 npm ERR! npm v2.15.9 npm ERR! code ELIFECYCLE ! npm ERR! openzwave-shared@1.2.0 preinstall: `node lib/install-ozw.js` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the openzwave-shared@1.2.0 preinstall script 'node lib/install-ozw.js'. npm ERR! This is most likely a problem with the openzwave-shared package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node lib/install-ozw.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs openzwave-shared npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm ERR! npm owner ls openzwave-shared npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request: npm ERR! C:\Program Files\IO BROKER\ioBroker\npm-debug.log ! C:\Program Files\IO BROKER\ioBroker></anonymous> `
      Habe jetzt gerade versucht noch mal zwave zu installieren. Und das ging, allerdings nur als Administrator und ich habe vorher (auch als admin)
      npm install --global --production windows-build-tools
      installiert.
      Kannst du probieren. Ich habe natürlich noch VS2015 Express auf dem Rechner… aber es sollte auch ohne gehen.
      • Patrick
        Patrick last edited by
        @Bluefox:
        @Patrick:
        installiert.
        Kannst du probieren. Ich habe natürlich noch VS2015 Express auf dem Rechner… aber es sollte auch ohne gehen. `
        hab ich schon gemacht
        jetzt hängt es an
        gyp err stack error gyp failed with exit code 1
        npm install node-gyp
        das habe ich auch schon gemacht
          Christoph last edited by
          ich habe einen Z-Wave Lan Gateway (TCP/IP) am laufen. Wie kann ich das denn unter dem Z-Wave Adapter einbinden.
          Es ist ein Raspberry mit einem Razberry.z-wave Board, das ich auch noch für andere Zwecke nutze.
          lg Chris
          • Bluefox
            @AlCalzone:
            @Bluefox:
            Habe noch ein Problem gefunden. Wenn ich den Zwave-Adapter beende oder neu starte, während ich das Javascript-Tab offen habe, wird dieses neu geladen. Der integrierte Log für ein einzelnes Skript funktioniert danach nicht mehr, nur noch das Log-Tab. `
            Kann überhaupt nicht reproduzieren….
            Ich starte ioBroker neu, dann starte ein script:
            setInterval(function () {
              console.log('test');
            }, 2000);
            Dann schreibe in der console "iorboker zwave stop"… und die Meldungen kommen weiter.
            • Bluefox
              @Christoph:
              lg Chris `
              Habe noch nie darüber gehört. Wo kann man über den Info bekommen?
              • AlCalzone
                @Bluefox:
                @AlCalzone:
                @Bluefox:
                Habe noch ein Problem gefunden. Wenn ich den Zwave-Adapter beende oder neu starte, während ich das Javascript-Tab offen habe, wird dieses neu geladen. Der integrierte Log für ein einzelnes Skript funktioniert danach nicht mehr, nur noch das Log-Tab. Kann überhaupt nicht reproduzieren….
                Auch nicht den Teil, wo das Panel neu lädt? Habe noch viel experimentiert, die Meldungen kommen normalerweise doch wieder, aber das Panel wird immer 1x zurückgesetzt, sodass die früheren Logs verschwinden.
                • Bluefox
                  @AlCalzone:
                  sodass die früheren Logs verschwinden. `
                  Es ist so gedacht. Die Log Lasche liest die logs aus Datei und dann addiert nur dazu neue Log-Einträge.
                  Die ScriptLog addiert nur die neue Einträge.
                  • Bluefox
                    @Patrick:
                    @Bluefox:
                    npm cache clean
                    npm install node-gyp -g --force
                    Und das alles als Admin.
                    • Bluefox
                      @AlCalzone:
                      @Bluefox:
                      @AlCalzone:
                      @Bluefox:
                      Auch nicht den Teil, wo das Panel neu lädt? Habe noch viel experimentiert, die Meldungen kommen normalerweise doch wieder, aber das Panel wird immer 1x zurückgesetzt, sodass die früheren Logs verschwinden. `
                      http://forum.iobroker.net/viewtopic.php … 325#p41593
                      • AlCalzone
                        @OstfrieseUnterwegs:
                        Ich habe ja das Problem, dass alles, was über eine Drop-Down-Liste im Reiter 'Objekte' nicht gesetzt werden kann. `
                        @Bluefox: Ich habe dieses Problem jetzt auch. Schaue gleich mal in den Code ob ich das Problem finde.
                        • Patrick
                          @Bluefox:
                          @Patrick:
                          @Bluefox:
                          npm cache clean
                          Und das alles als Admin. `
                          habe jetzt noch mal das alte Backup aufgespielt und alles wie beschrieben gemacht
                          jetzt kommt ein anderes Fehler
                          ! C:\Users\rickfl>cd "C:\Program Files\IO BROKER\ioBroker"
                          ! C:\Program Files\IO BROKER\ioBroker>npm install https://github.com/ioBroker/ioBroker.zw … all/master --production --unsafe-perm --build-from-source
                          ! > iobroker.zwave@0.4.3 preinstall C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.zwave
                          ! > node lib/preinstall.js
                          ! > openzwave-shared@1.2.0 preinstall C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.zwave\node_modules\openzwave-shared
                          ! > node lib/install-ozw.js
                          ! Installing dependencies to C:\Users\rickfl\AppData\Local\Temp\ozwinstall-yeew830izfr
                          ! npm WARN deprecated wrench@1.5.9: wrench.js is deprecated! You should check out fs-extra (https://github.com/jprichardson/node-fs-extra) for any operations you were using wrench for. Thanks for all the usage over the years.
                          ! module.js:327
                          ! throw err;
                          ! Error: Cannot find module 'C:\Users\rickfl\AppData\Local\Temp\ozwinstall-yeew830izfr/node_modules/request'
                          ! at Function.Module._resolveFilename (module.js:325:15)
                          ! at Function.Module._load (module.js:276:25)
                          ! at Module.require (module.js:353:17)
                          ! at require (internal/module.js:12:17)
                          ! at Module.module.exports (C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.zwave\node_modules\openzwave-shared\lib\install-ozw.js:165:13)
                          ! at Object. <anonymous>(C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.zwave\node_modules\openzwave-shared\lib\install-ozw.js:220:12)
                          ! at Module._compile (module.js:409:26)
                          ! at Object.Module._extensions..js (module.js:416:10)
                          ! at Module.load (module.js:343:32)
                          ! at Function.Module._load (module.js:300:12)
                          ! npm ERR! Windows_NT 10.0.10586
                          ! npm ERR! argv "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "https://github.com/ioBroker/ioBroker.zw ... all/master" "--production" "--unsafe-perm" "--build-from-source"
                          ! npm ERR! node v4.6.1
                          ! npm ERR! npm v2.15.9
                          ! npm ERR! code ELIFECYCLE
                          ! npm ERR! openzwave-shared@1.2.0 preinstall: node lib/install-ozw.js
                          ! npm ERR! Exit status 1
                          ! npm ERR!
                          ! npm ERR! This is most likely a problem with the openzwave-shared package,
                          ! npm ERR! not with npm itself.
                          ! npm ERR! Tell the author that this fails on your system:
                          ! npm ERR! node lib/install-ozw.js
                          ! npm ERR! You can get information on how to open an issue for this project with:
                          ! npm ERR! npm bugs openzwave-shared
                          ! npm ERR! Or if that isn't available, you can get their info via:
                          ! npm ERR!
                          ! npm ERR! There is likely additional logging output above.
                          ! npm ERR! C:\Program Files\IO BROKER\ioBroker\npm-debug.log
                          • Bluefox
                            @AlCalzone:
                            Ich habe ja das Problem, dass alles, was über eine Drop-Down-Liste im Reiter 'Objekte' nicht gesetzt werden kann. @Bluefox: Ich habe dieses Problem jetzt auch. Schaue gleich mal in den Code ob ich das Problem finde.
                            Ich verstehe nicht mal um was es hier geht
                            • OstfrieseUnterwegs
                              OstfrieseUnterwegs last edited by
                              @Bluefox:
                              @AlCalzone:
                              Ich verstehe nicht mal um was es hier geht `
                              Schau mal in meinen Post 39 in diesem Thread. Punkt 2.
                              Gesendet von meinem ONEPLUS A3003 mit Tapatalk
                              • AlCalzone
                                @Bluefox:
                                @AlCalzone:
                                Dann eine kurze Erklärung gefolgt von der Problemlösung.
                                Bestimmte States werden im ioBroker-Admin per Dropdown gesetzt, siehe Beispiel:
                                ~~![](</s><URL url=)http://i.imgur.com/dw3gSY1.png" />
                                Einige davon funktionieren aber nicht, so kann ich z.B. im Aeotec ZW100 MultiSensor 6 nicht den Parameter "Command Options" auf "Binary Sensor Report" stellen, es geht immer wieder zurück auf "Basic Set (default)".
                                Das Problem liegt daran, dass bei der Erstellung der Objekte eine Liste an States angelegt wird, die in manchen Fällen falsch ist, da die States immer Nullbasiert angelegt werden (Zeile 689ff.).
                                 `stateObj.common.states = {};
                                                    for (var i = 0; i < valueId.values.length; i++) {
                                                        stateObj.common.states[i] = valueId.values[i];
                                                        if (valueId.values[i] === value) value = i;
                                Oft stimmt das, in manchen Fällen beginnen die Parameter aber an einem anderen Wert [https://github.com/OpenZWave/open-zwave/blob/master/config/aeotec/zw100.xml](https://github.com/OpenZWave/open-zwave/blob/master/config/aeotec/zw100.xml):
                                `~~[code]~~		 <value type="list" index="5" genre="config" label="Command Options" min="1" max="2" value="1" size="1"><help>Which commands to send when PIR motion sensor triggered
                                			OZW Ideal Value is Binary Sensor Report</help></value> [/code]`
                                ioBroker legt die States trotzdem mit [0] und [1] an. Es wird also der falsche Wert an zWave gemeldet.
                                Ich habe mir vorübergehend beholfen, indem ich den Index bei min beginnen lasse:
                                `~~[code]~~            		var offset = 0;
                                            		if (valueId.min !== undefined) {
                                            			offset = valueId.min;
                                                        if (valueId.values[i] === value) value = i + offset;
                                Vielleicht gibt es eine Möglichkeit, direkt die Werte aus der open-zwave Konfiguration zu übernehmen? Oder kommen die in ioBroker nicht an?[/i][/i][/i][/code][/i][/i][/i]
                                • Bluefox
                                  @AlCalzone:
                                  @Bluefox:
                                  @AlCalzone:
                                  @Bluefox: Ich habe dieses Problem jetzt auch. Schaue gleich mal in den Code ob ich das Problem finde. Ich verstehe nicht mal um was es hier geht
                                  Die kommen nicht an. Nur die Texte, z.B ["Off", "On"][/i][/i][/i][/code][/i][/i][/i]
                                  • AlCalzone
                                    @Bluefox:
                                    @AlCalzone:
                                    Vielleicht gibt es eine Möglichkeit, direkt die Werte aus der open-zwave Konfiguration zu übernehmen? Oder kommen die in ioBroker nicht an? Die kommen nicht an. Nur die Texte, z.B ["Off", "On"]
                                    Dann muss man wohl darauf vertrauen, dass es eine ununterbrochene Liste ist, die entweder bei 0 oder min beginnt. Und dass diese Information auch korrekt ist.
                                      @Bluefox:
                                      @Christoph:
                                      lg Chris Habe noch nie darüber gehört. Wo kann man über den Info bekommen?
                                      Ich habe einen Raspberry, der mit Razberry bestückt ist am laufen. Diesen kann ich dann über die IP-Adresse ansprechen.
                                      http://razberry.z-wave.me/
                                      • AlCalzone
                                        Du willst also die zwave-Geräte, die mit Raspi A ("Gateway") verbunden sind, in den zwave-Adapter von Raspi B einbinden?
                                        • Bluefox
                                          @Patrick:
                                          @Bluefox:
                                          @Patrick: `
                                          npm cache clean
                                          ! module.js:327
                                          ! throw err;
                                          ! npm ERR!
                                          ! npm ERR!
                                          Also es gibt tatsächlich das Problem mit Windows.
                                          Die Leute arbeiten dran, aber es gibt immer noch keine Lösung:
                                          https://github.com/felixrieseberg/windo … s/issues/9
                                          Workaround: Install Visual C++ projects support to Visual Studio 2015 (requires 3GB space).(C++ option aktivieren)
                                          • Patrick
                                            @Bluefox:
                                            @Patrick:
                                            @Bluefox:
                                            npm cache clean
                                            ! module.js:327
                                            ! throw err;
                                            ! npm ERR!
                                            ! npm ERR!
                                            Workaround: Install Visual C++ projects support to Visual Studio 2015 (requires 3GB space).(C++ option aktivieren) `
                                            dann warte ich mal ab
                                            31.7k
                                            79.8k
                                            142
                                            21342
