    4. Javascript Fehler
    Javascript Fehler
      Elektroman last edited by
      Ok, Danke werde ich mal probieren
      Hier ist noch eine Fehlermeldung
      javascript.0 2016-11-17 20:02:02.411 error script.js.Flur.Flur+WC_BM compile failed: SyntaxError: Unexpected token ILLEGAL
        Moin Moin ,
        habe jetzt leider neue Fehler entdeckt, kann da jemand etwas mit anfangen?
        at exports._errnoException (util.js:907:11)
        javascript.0 2016-11-24 05:01:24.483 error Error: read ECONNRESET
        javascript.0 2016-11-24 05:01:24.482 error uncaught exception: read ECONNRESET
        javascript.0 2016-11-24 05:01:24.480 error at TCP.onread (net.js:557:26)
        javascript.0 2016-11-24 05:01:24.480 error at exports._errnoException (util.js:907:11)
        javascript.0 2016-11-24 05:01:24.480 error Error: read ECONNRESET
        javascript.0 2016-11-24 05:01:24.479 error uncaught exception: read ECONNRESET
        javascript.0 2016-11-24 05:01:24.477 error at TCP.onread (net.js:557:26)
        javascript.0 2016-11-24 05:01:24.477 error at exports._errnoException (util.js:907:11)
        javascript.0 2016-11-24 05:01:24.477 error Error: read ECONNRESET
        javascript.0 2016-11-24 05:01:24.477 error uncaught exception: read ECONNRESET
        javascript.0 2016-11-24 05:01:24.475 error at TCP.onread (net.js:557:26)
        javascript.0 2016-11-24 05:01:24.475 error at exports._errnoException (util.js:907:11)
        javascript.0 2016-11-24 05:01:24.475 error Error: read ECONNRESET
        javascript.0 2016-11-24 05:01:24.474 error uncaught exception: read ECONNRESET
        javascript.0 2016-11-24 05:01:24.471 error at TCP._onclose (net.js:486:12)
        javascript.0 2016-11-24 05:01:24.471 error at Socket.emit (events.js:169:7)
        javascript.0 2016-11-24 05:01:24.471 error at emitOne (events.js:82:20)
        javascript.0 2016-11-24 05:01:24.471 error at Socket.socketCloseListener (_http_client.js:245:23)
        javascript.0 2016-11-24 05:01:24.471 error at createHangUpError (_http_client.js:213:15)
        javascript.0 2016-11-24 05:01:24.471 error Error: socket hang up
        javascript.0 2016-11-24 05:01:24.468 error uncaught exception: socket hang up
        javascript.0 2016-11-24 05:01:24.463 error at TCP.onread (net.js:557:26)
        javascript.0 2016-11-24 05:01:24.463 error at exports._errnoException (util.js:907:11)
        javascript.0 2016-11-24 05:01:24.463 error Error: read ECONNRESET
        javascript.0 2016-11-24 05:01:24.462 error uncaught exception: read ECONNRESET
        [emoji856][emoji15][emoji851]
        • Bluefox
          Bluefox last edited by
          Das passiert wann? Der Fehler ist zu allgemein und kann passieren im Adapter selbst und auch in Skripten. Ich kenne doch deine Skripte nicht.
            Die Fehler kommen leider sehr sporadisch und ich kann leider keine Regelmäßigkeit festellen
              Moin Moin,
              Melde mich noch einmal verzweifelt [emoji15]
              Kann mir jemand generell mal erklären was das für eine Fehlermeldung ist ?
              Ich tappe noch komplett im Dunkeln.
              Was kann passieren das der Java Adapter neu starten muss ?
              Der Fehler kommt wie schon gesagt sehr sporadisch vor. Somit kann ich leider ein Ausschlussverfahren nicht durchführen
              Schon mal danke im Voraus
              Hier noch einmal was aktuelles als Fehlermeldung :
              host.raspberrypi 2016-11-27 08:13:50.249 error instance system.adapter.javascript.0 terminated with code 0 (OK)
              javascript.0 2016-11-27 08:13:50.223 error at TCP._onclose (net.js:486:12)
              javascript.0 2016-11-27 08:13:50.223 error at Socket.emit (events.js:169:7)
              javascript.0 2016-11-27 08:13:50.223 error at emitOne (events.js:82:20)
              javascript.0 2016-11-27 08:13:50.223 error at Socket.socketCloseListener (_http_client.js:245:23)
              javascript.0 2016-11-27 08:13:50.223 error at createHangUpError (_http_client.js:213:15)
              javascript.0 2016-11-27 08:13:50.223 error Error: socket hang up
              javascript.0 2016-11-27 08:13:50.221 error uncaught exception: socket hang up
              javascript.0 2016-11-27 08:13:50.215 error at TCP.onread (net.js:557:26)
              javascript.0 2016-11-27 08:13:50.215 error at exports._errnoException (util.js:907:11)
              javascript.0 2016-11-27 08:13:50.215 error Error: read ECONNRESET
              javascript.0 2016-11-27 08:13:50.214 error uncaught exception: read ECONNRESET
              javascript.0 2016-11-27 08:12:12.863 info script.js.Wohn-_und_Esszimmer.BeleuchtungGruppe.Küchenbeleuchtung_Abends: BM Küche
              • Bluefox
                @Elektroman:
                Moin Moin,
                javascript.0 2016-11-27 08:12:12.863 info script.js.Wohn-_und_Esszimmer.BeleuchtungGruppe.Küchenbeleuchtung_Abends: BM Küche `
                Jemand lehnt die TCP Verbindung ab. Verwendest du request?
                Da aber Adapter selbst mit dem js-controller auch über TCP kommuniziert. Das kann auch interne Kommunikation sein.
                  Moin,
                  super danke für die schnelle Antwort!
                  Ja habe ich.
                  Ich habe zwei Tablets die über Tasker und Home24 Mediaplayer aufgeweckt werden!
                  Und siehe da [emoji848][emoji15][emoji851] einer wacht nicht auf.
                  Das schaue ich mir gleich mal genauer an
                  Gibt es eine einfache Alternative für die Tablets ohne Root Zugriff (Samsung[emoji24])
                  • Bluefox
                    @Elektroman:
                    Moin,
                    Ja habe ich.
                    Gibt es eine einfache Alternative für die Tablets ohne Root Zugriff (Samsung[emoji24]) `
                    Probiere mal so was:
                    try {
                        request('http://blablba', function (err, resp, body) {
                        	// analyse answer
                        }).on('error', function (err) {
                    	     console.error('Cannot request');
                    } catch (e) {
                      Oh Sorry ich habe nicht erwähnt das ich bis auf SPS nicht richtig programmieren kann
                      Blockly ist ein Segen für mich
                        So es liegt schätze ich mal daran
                        Hallo Bluefox, ääää kann ich deine Verbesserung auch unter Blockly verwenden [emoji4]
                          Ich benötige ich für Tasker eigentlich nur " http://192:5000/Tasker=Display"
                          • Bluefox
                            Benutze custom function block:
                            <xml xmlns="http://www.w3.org/1999/xhtml"><block type="comment" id="p@J6Qs;ezefC/UNB~(AU" x="38" y="13"><field name="COMMENT">Call tasker</field>
                            <next><block type="procedures_callcustomnoreturn" id="E3!LuqJO(QOQ4no^8u//"><mutation name="Control tasker"></mutation></block></next></block>
                            <block type="procedures_defcustomnoreturn" id="XR^Exw|_Yz/_i!Y)h1FM" x="213" y="87"><mutation statements="false"></mutation>
                            <field name="NAME">Control tasker</field>
                            <field name="SCRIPT">dHJ5IHsNCiAgICByZXF1ZXN0KCdodHRwOi8vMTkyLi4uLi4uOjUwMDAvVGFza2VyPURpc3BsYXknKS5vbignZXJyb3InLCBmdW5jdGlvbiAoZXJyKSB7DQogICAgICAgIGNvbnNvbGUuZXJyb3IoJ0Nhbm5vdCByZXF1ZXN0Jyk7DQogICAgfSk7DQp9IGNhdGNoIChlKSB7DQogICBjb25zb2xlLmVycm9yKCdDYW5ub3QgcmVxdWVzdCcpOw0KfQ==</field>
                            <comment pinned="false" h="80" w="160">Describe this function...</comment></block></xml>
                              Auch wenn ich jetzt wie ein Blödi dastehe [emoji4][emoji856]
                              Ich kann da leider immer noch nichts mit anfangen
                              Custom function Block , Funktionen - JavaScript Funktion?
                              Und dann ?
                              Jetzt werden bestimmt viele sich fragen und sagen häää ist doch klar, der soll lieber die Finger davon lassen [emoji848]
                              Bis jetzt habe ich mich aber ganz gut durchgekämpft [emoji23]
                                @Elektroman:
                                Jetzt werden bestimmt viele sich fragen und sagen häää ist doch klar, `
                                Wäre möglich….
                                @Elektroman:
                                der soll lieber die Finger davon lassen `
                                Wieso?? Learning by doing!
                                Bluefox hat dir den notwendigen Block als xml gepostet.
                                Das musst du kopieren und in Blockly importieren (nach oben zeigender Pfeil neben "Blöcke Prüfen")
                                Rainer
                                  Hallo und vielen Dank Rainer,
                                  Jetzt komme ich der Sache schon näher, wie bekomme ich jetzt aber in den fertigen Block die richtige URL rein? Vor dem einfügen das Script bearbeiten?
                                  • Bluefox
                                    Anleitung 🙂
                                    BTW: Du kannst ruhig deine IP 192… Adressen posten die sind sowieso nicht von außen erreichbar.
                                      Super vielen Dank für eure Mühe
                                      Ich probiere das gleich aus
                                        Peinlich [emoji30][emoji848]
                                        Bei mir sieht das so aus
                                        ![](</s><URL url=)<link_text text="http://uploads.tapatalk-cdn.com/2016112 ... 8ab090.png">http://uploads.tapatalk-cdn.com/20161127/b1a317e1d63d2baccc760cf5098ab090.png</link_text>" />
                                          Da muss noch mehr sein!
                                          Hast du wirklich alles aus dem spoiler kopiert.
                                          Das sind insgesamt 3 Blöcke
                                          1 Kommentar
                                          1x den du gezeigt hast
                                          1x den den Bluefox gezeigt hat.
                                          Rainer
                                            Ja Bluefox du has ja recht
                                            Hier sind die zwei IPś
                                            http://192.168.168.139:50000/tasker=Display (Flur)
                                            http://192.168.168.129:50000/tasker=Display (Wohnzimmer)
                                            Ich komme heute Abend nicht mehr weiter
                                            Bis jetzt noch einmal vielen Dank für die Unterstützung [emoji106][emoji106][emoji106][emoji106][emoji106][emoji106][emoji122][emoji122]
                                            Ich glaube besser würde es noch klappen wenn ich direkt den Task auf Tasker auslösen könnte
                                            Und nicht den Umweg über home24 player gehen müsste
                                            Mit So eine Schnittstelle könnte ich mir so einiges anderes noch vorstellen
                                            Mit Tasker unter Android ist vieles möglich
                                            Tasker Adapter ? [emoji848][emoji15][emoji12]
                                            Gute Nacht
                                            4842
