    4. JSON zu Objekte
    JSON zu Objekte
      ente34 @Kellerassel75 last edited by
      @kellerassel75
      Na ja, hast Du verpasste Anrufe heute?
      Sonst Zeile 18:
      if (1 || el_date === date)
        Kellerassel75 @ente34 last edited by Kellerassel75
        16:17:09.144 error javascript.0 (12519) script.js.test compile failed: at script.js.test:45
        Sorry mein Fehler { vergessen!
        Nun schreibt er mir die ganze Tabelle nach javascript.0.telefon.missed_today.json!
        Im Log steht:
        javascript.0	2021-01-31 16:17:09.150	error	(12519) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2021-01-31 16:17:09.150	error	(12519) at runMicrotasks (<anonymous>)
        javascript.0	2021-01-31 16:17:09.150	error	(12519) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2021-01-31 16:17:09.149	error	(12519) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2021-01-31 16:17:09.149	error	(12519) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17
        javascript.0	2021-01-31 16:17:09.149	error	(12519) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
        javascript.0	2021-01-31 16:17:09.149	error	(12519) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
        javascript.0	2021-01-31 16:17:09.146	error	(12519) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
        javascript.0	2021-01-31 16:17:09.146	error	(12519) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
        javascript.0	2021-01-31 16:17:09.146	error	(12519) at Object.createScript (vm.js:261:10)
        javascript.0	2021-01-31 16:17:09.146	error	(12519) at new Script (vm.js:88:7)
        javascript.0	2021-01-31 16:17:09.145	error	(12519) SyntaxError: Missing catch or finally after try
        javascript.0	2021-01-31 16:17:09.145	error	(12519) ^
        javascript.0	2021-01-31 16:17:09.145	error	(12519) }
        javascript.0	2021-01-31 16:17:09.144	error	at script.js.test:45
        javascript.0	2021-01-31 16:17:09.144	error	(12519) script.js.test compile failed:
          @kellerassel75
          Schon klar, mein Script filtert ja die verpassten Anrufe heute aus. Mit der "1||" bekommst Du wieder alle, um zu kontrollieren, ob alles soweit funktioniert.
          Alternativ kannst Du Dich auch selbst anrufen (nicht abheben!).
            @ente34
            Gut! Er schreibt nun die Anrufe von heute! Das funktioniert!
            Aber ich wollte richtige Datenpunte - Zahlen nicht JSON!
            Also:
            Datenpunt letzter - caller
            Datenpunt letzter - date
            Datenpunt letzter - name
            Datenpunt vorletzter- caller
            Datenpunt vorletzter- date
            Datenpunt vorletzter- name
            Falko
            E paul53 2 Replies Last reply Reply Quote 0
              @kellerassel75
              wie bereits oben gesagt, in Zeile 19 hast Du das obj in der Hand ...
                paul53 @Kellerassel75 last edited by
                @kellerassel75 sagte: richtige Datenpunte - Zahlen nicht JSON!
                Du meinst Zeichenketten?
                @kellerassel75 sagte in JSON zu Objekte:
                Wieweit sollen sie zurück reichen?
                  Kellerassel75 @paul53 last edited by
                  Ich denke 4 Anrufe sollte reichen!
                    @kellerassel75 sagte: Solange nur ein Anruf ist:
                    Ist es wirklich so, dass es dann nur ein Objekt ohne Array-Klammern ist ?
                      Nein das habe ich so geändert!
                        @kellerassel75
                        Kannst Du es dann selber erweitern?
                        //Script zur Zerlegung der JSON Daten in einzelne Datenpunkte
                        //Idee: Chaot
                        // Umsetzung: paul53
                        var json = "tr-064.0.calllists.missed.json";
                        var Nummer = "javascript.0.Nummer";
                        var Datum = "javascript.0.Datum";
                        var Name = "javascript.0.Name";
                        const MaxAnrufe = 4;
                        on(json, function(dp) {
                           var obj = JSON.parse(dp.state.val);
                           const i_end = obj.length < MaxAnrufe ? obj.length : MaxAnrufe;
                           for (let i=0; i<i_end; i++) {
                               const o = obj[i];
                               console.warn(o);
                               const dp_nummer = Nummer+"_"+i;
                               console.warn(dp_nummer);
                               setState(dp_nummer,o.caller);
                        //    setState(Nummer, parseFloat(obj.caller));
                        //    setState(Datum, parseFloat(obj.date));
                        //    setState(Name, parseFloat(obj.name));
                        for (let i=0; i<MaxAnrufe; i++) {
                            createState(dp_nummer);
                          @ente34
                          Danke! Ich werde es Versuchen!
                            paul53 @Kellerassel75 last edited by paul53
                            @kellerassel75 sagte: 4 Anrufe sollte reichen!
                            Vorschlag (nicht getestet):
                            const idJson = "tr-064.0.calllists.missed.json";
                            const path = "0_userdata.0.Telefon.verpasst-";
                            if(!existsState(path + '0.Nummer')) {
                                for(let i = 0; i < 4; i++) {
                                    createState(path + i + '.Nummer', '', {type: 'string', name: 'Nummer', role: 'info'});
                                    createState(path + i + '.Datum', '', {type: 'string', name: 'Datum, Uhrzeit', role: 'info'});
                                    createState(path + i + '.Name', '', {type: 'string', name: 'Name', role: 'info'});
                            on(idJson, function(dp) {
                                let arr = JSON.parse(dp.state.val);
                                let anzahl = arr.length;
                                if(anzahl > 4) anzahl = 4;
                                for(let i = 0; i < anzahl; i++) {
                                    setState(path + i + '.Nummer', arr[i].caller, true);
                                    setState(path + i + '.Datum', arr[i].date, true);
                                    setState(path + i + '.Name', arr[i].name, true);
                            E K 2 Replies Last reply Reply Quote 0
                              ente34 @paul53 last edited by
                              Mir gefällt es ...
                                Danke passt!
                                Echt Super! Ich bin begeistert! Danke an alle!
                                Ich hätte nicht gedacht das ich so schnell Hilfe bekomme!
                                Ihr seid Super! Macht weiter so!
                                Ich werde hier noch viel lernen hoffe ich!
                                Falko
                                856
