    4. Test Adapter BLE v0.12.x
      Thomas Braun Most Active @hg6806 last edited by
      @hg6806
      Nochmal
      dmesg
      Und bitte keine Screenshots von Texten.
      • hg6806
        hg6806 Most Active @Thomas Braun last edited by
        dmesg
        [    0.000000] Booting Linux on physical CPU 0x0
        [    0.000000] Linux version 5.4.83-v7l+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1379 SMP Mon Dec 14 13:11:54 GMT 2020
        [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
        [    0.000000] CPU: div instructions available: patching division code
        [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
        [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
        [    0.000000] Memory policy: Data cache writealloc
        [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
        [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
        [    0.000000] On node 0 totalpages: 504576
        [    0.000000]   DMA zone: 2304 pages used for memmap
        [    0.000000]   DMA zone: 0 pages reserved
        [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
        [    0.000000]   HighMem zone: 307968 pages, LIFO batch:63
        [    0.000000] percpu: Embedded 20 pages/cpu s49804 r8192 d23924 u81920
        [    0.000000] pcpu-alloc: s49804 r8192 d23924 u81920 alloc=20*4096
        [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
        [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 502272
        [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:0A:73:B1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=d9dc38a3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
        [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
        [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
        [    0.000000] software IO TLB: mapped [mem 0x19400000-0x1d400000] (64MB)
        [    0.000000] Memory: 1646772K/2018304K available (10240K kernel code, 739K rwdata, 2816K rodata, 2048K init, 854K bss, 109388K reserved, 262144K cma-reserved, 1231872K highmem)
        [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        [    0.000000] ftrace: allocating 31115 entries in 61 pages
        [    0.000000] rcu: Hierarchical RCU implementation.
        [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
        [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
        [    0.000000] GIC: Using split EOI/Deactivate mode
        [    0.000000] random: get_random_bytes called from start_kernel+0x344/0x518 with crng_init=0
        [    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
        [    0.000022] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
        [    0.000097] bcm2835: system timer (irq = 17)
        [    0.000742] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
        [    0.000758] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
        [    0.000773] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
        [    0.000786] Switching to timer-based delay loop, resolution 18ns
        [    0.001022] Console: colour dummy device 80x30
        [    0.001055] printk: console [tty1] enabled
        [    0.001106] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
        [    0.001127] pid_max: default: 32768 minimum: 301
        [    0.001275] LSM: Security Framework initializing
        [    0.001467] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [    0.001490] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [    0.002834] Disabling memory control group subsystem
        [    0.002957] CPU: Testing write buffer coherency: ok
        [    0.003464] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        [    0.004370] Setting up static identity map for 0x200000 - 0x20003c
        [    0.004575] rcu: Hierarchical SRCU implementation.
        [    0.005252] smp: Bringing up secondary CPUs ...
        [    0.006429] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
        [    0.007750] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
        [    0.009009] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
        [    0.009168] smp: Brought up 1 node, 4 CPUs
        [    0.009185] SMP: Total of 4 processors activated (432.00 BogoMIPS).
        [    0.009198] CPU: All CPU(s) started in HYP mode.
        [    0.009211] CPU: Virtualization extensions available.
        [    0.010019] devtmpfs: initialized
        [    0.023906] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
        [    0.024164] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [    0.024192] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
        [    0.030996] pinctrl core: initialized pinctrl subsystem
        [    0.031976] NET: Registered protocol family 16
        [    0.035869] DMA: preallocated 1024 KiB pool for atomic coherent allocations
        [    0.036446] audit: initializing netlink subsys (disabled)
        [    0.036719] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
        [    0.037832] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
        [    0.037846] hw-breakpoint: maximum watchpoint size is 8 bytes.
        [    0.038166] Serial: AMBA PL011 UART driver
        [    0.041687] bcm2835-mbox fe00b880.mailbox: mailbox enabled
        [    0.060815] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-01-08 14:31, variant start
        [    0.070830] raspberrypi-firmware soc:firmware: Firmware hash is 194a85abd768c7334bbadc3f1911c10a7d18ed14
        [    0.125918] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
        [    0.129789] vgaarb: loaded
        [    0.130258] SCSI subsystem initialized
        [    0.130493] usbcore: registered new interface driver usbfs
        [    0.130562] usbcore: registered new interface driver hub
        [    0.130684] usbcore: registered new device driver usb
        [    0.131048] usb_phy_generic phy: phy supply vcc not found, using dummy regulator
        [    0.132850] clocksource: Switched to clocksource arch_sys_counter
        [    0.891524] VFS: Disk quotas dquot_6.6.0
        [    0.891625] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
        [    0.891799] FS-Cache: Loaded
        [    0.891992] CacheFiles: Loaded
        [    0.902238] thermal_sys: Registered thermal governor 'step_wise'
        [    0.902616] NET: Registered protocol family 2
        [    0.903527] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
        [    0.903557] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
        [    0.903619] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
        [    0.903690] TCP: Hash tables configured (established 8192 bind 8192)
        [    0.903838] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
        [    0.903871] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
        [    0.904120] NET: Registered protocol family 1
        [    0.904847] RPC: Registered named UNIX socket transport module.
        [    0.904860] RPC: Registered udp transport module.
        [    0.904873] RPC: Registered tcp transport module.
        [    0.904885] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [    0.904907] PCI: CLS 0 bytes, default 64
        [    0.906810] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
        [    0.909048] Initialise system trusted keyrings
        [    0.909282] workingset: timestamp_bits=14 max_order=19 bucket_order=5
        [    0.920350] FS-Cache: Netfs 'nfs' registered for caching
        [    0.921074] NFS: Registering the id_resolver key type
        [    0.921124] Key type id_resolver registered
        [    0.921137] Key type id_legacy registered
        [    0.921160] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        [    0.922256] Key type asymmetric registered
        [    0.922270] Asymmetric key parser 'x509' registered
        [    0.922459] bounce: pool size: 64 pages
        [    0.922508] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
        [    0.922753] io scheduler mq-deadline registered
        [    0.922768] io scheduler kyber registered
        [    0.926784] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
        [    0.926808] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
        [    0.926879] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
        [    0.926950] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x007fffffff -> 0x0400000000
        [    0.984997] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
        [    0.985317] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
        [    0.985336] pci_bus 0000:00: root bus resource [bus 00-ff]
        [    0.985356] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
        [    0.985414] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
        [    0.985682] pci 0000:00:00.0: PME# supported from D0 D3hot
        [    0.988930] PCI: bus0: Fast back to back transfers disabled
        [    0.989161] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
        [    0.989309] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
        [    0.989742] pci 0000:01:00.0: PME# supported from D0 D3cold
        [    0.993011] PCI: bus1: Fast back to back transfers disabled
        [    0.993072] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
        [    0.993095] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
        [    0.993177] pci 0000:00:00.0: PCI bridge to [bus 01]
        [    0.993201] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
        [    0.993515] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
        [    0.993770] pcieport 0000:00:00.0: PME: Signaling with IRQ 55
        [    0.994180] pcieport 0000:00:00.0: AER: enabled with IRQ 55
        [    0.994518] pci 0000:01:00.0: enabling device (0140 -> 0142)
        [    1.001453] iproc-rng200 fe104000.rng: hwrng registered
        [    1.001800] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
        [    1.002463] vc-sm: Videocore shared memory driver
        [    1.003083] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
        [    1.015357] brd: module loaded
        [    1.027840] loop: module loaded
        [    1.029235] Loading iSCSI transport class v2.0-870.
        [    1.031207] libphy: Fixed MDIO Bus: probed
        [    1.031826] bcmgenet fd580000.ethernet: failed to get enet clock
        [    1.031845] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
        [    1.031869] bcmgenet fd580000.ethernet: failed to get enet-wol clock
        [    1.031890] bcmgenet fd580000.ethernet: failed to get enet-eee clock
        [    1.031918] bcmgenet: Skipping UMAC reset
        [    1.042892] libphy: bcmgenet MII bus: probed
        [    1.133045] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
        [    1.134179] usbcore: registered new interface driver r8152
        [    1.134245] usbcore: registered new interface driver lan78xx
        [    1.134305] usbcore: registered new interface driver smsc95xx
        [    1.134798] xhci_hcd 0000:01:00.0: xHCI Host Controller
        [    1.134832] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
        [    1.138147] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000003000000890
        [    1.139469] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
        [    1.139487] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [    1.139503] usb usb1: Product: xHCI Host Controller
        [    1.139518] usb usb1: Manufacturer: Linux 5.4.83-v7l+ xhci-hcd
        [    1.139533] usb usb1: SerialNumber: 0000:01:00.0
        [    1.140142] hub 1-0:1.0: USB hub found
        [    1.140238] hub 1-0:1.0: 1 port detected
        [    1.140767] xhci_hcd 0000:01:00.0: xHCI Host Controller
        [    1.140792] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
        [    1.140816] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
        [    1.141304] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
        [    1.141322] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [    1.141337] usb usb2: Product: xHCI Host Controller
        [    1.141352] usb usb2: Manufacturer: Linux 5.4.83-v7l+ xhci-hcd
        [    1.141366] usb usb2: SerialNumber: 0000:01:00.0
        [    1.141973] hub 2-0:1.0: USB hub found
        [    1.142054] hub 2-0:1.0: 4 ports detected
        [    1.143477] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
        [    1.143766] dwc_otg: FIQ enabled
        [    1.143779] dwc_otg: NAK holdoff enabled
        [    1.143792] dwc_otg: FIQ split-transaction FSM enabled
        [    1.143819] Module dwc_common_port init
        [    1.144277] usbcore: registered new interface driver uas
        [    1.144385] usbcore: registered new interface driver usb-storage
        [    1.144579] mousedev: PS/2 mouse device common for all mice
        [    1.146437] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
        [    1.149868] sdhci: Secure Digital Host Controller Interface driver
        [    1.149881] sdhci: Copyright(c) Pierre Ossman
        [    1.150508] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
        [    1.151112] sdhci-pltfm: SDHCI platform and OF driver helper
        [    1.155096] ledtrig-cpu: registered to indicate activity on CPUs
        [    1.155408] hidraw: raw HID events driver (C) Jiri Kosina
        [    1.155591] usbcore: registered new interface driver usbhid
        [    1.155603] usbhid: USB HID core driver
        [    1.156642] vchiq: vchiq_init_state: slot_zero = (ptrval)
        [    1.158585] [vc_sm_connected_init]: start
        [    1.167403] [vc_sm_connected_init]: end - returning 0
        [    1.169652] Initializing XFRM netlink socket
        [    1.169690] NET: Registered protocol family 17
        [    1.169817] Key type dns_resolver registered
        [    1.170221] Registering SWP/SWPB emulation handler
        [    1.170533] registered taskstats version 1
        [    1.170553] Loading compiled-in X.509 certificates
        [    1.171102] Key type ._fscrypt registered
        [    1.171116] Key type .fscrypt registered
        [    1.182012] uart-pl011 fe201000.serial: cts_event_workaround enabled
        [    1.182084] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
        [    1.188317] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
        [    1.189291] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
        [    1.189307] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
        [    1.239261] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
        [    1.240931] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    1.242601] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    1.246454] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
        [    1.248143] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    1.256533] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
        [    1.259555] of_cfs_init
        [    1.259674] of_cfs_init: OK
        [    1.260772] Waiting for root device PARTUUID=d9dc38a3-02...
        [    1.294299] random: fast init done
        [    1.319257] mmc1: new high speed SDIO card at address 0001
        [    1.502889] usb 1-1: new high-speed USB device number 2 using xhci_hcd
        [    1.685482] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
        [    1.685500] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        [    1.685517] usb 1-1: Product: USB2.0 Hub
        [    1.687163] hub 1-1:1.0: USB hub found
        [    1.687508] hub 1-1:1.0: 4 ports detected
        [    1.833250] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
        [    1.870285] usb 2-2: New USB device found, idVendor=2109, idProduct=0715, bcdDevice= 1.48
        [    1.870303] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [    1.870319] usb 2-2: Product: VLI Product String
        [    1.870334] usb 2-2: Manufacturer: VLI Manufacture String
        [    1.870349] usb 2-2: SerialNumber: ABCDEFA74566
        [    1.892424] scsi host0: uas
        [    1.894316] scsi 0:0:0:0: Direct-Access     Samsung  SSD 850 EVO      EMT2 PQ: 0 ANSI: 6
        [    1.897758] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
        [    1.897957] sd 0:0:0:0: [sda] Write Protect is off
        [    1.897975] sd 0:0:0:0: [sda] Mode Sense: 2f 00 00 00
        [    1.898334] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
        [    1.899143] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
        [    1.904652]  sda: sda1 sda2
        [    1.908912] sd 0:0:0:0: [sda] Attached SCSI disk
        [    1.924707] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        [    1.924782] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [    1.925183] devtmpfs: mounted
        [    1.933846] Freeing unused kernel memory: 2048K
        [    1.963164] Run /sbin/init as init process
        [    2.012921] usb 1-1.1: new high-speed USB device number 3 using xhci_hcd
        [    2.143397] usb 1-1.1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
        [    2.143415] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        [    2.143431] usb 1-1.1: Product: USB 2.0 Hub
        [    2.145322] hub 1-1.1:1.0: USB hub found
        [    2.145425] hub 1-1.1:1.0: 4 ports detected
        [    2.154917] systemd[1]: System time before build time, advancing clock.
        [    2.209945] NET: Registered protocol family 10
        [    2.211304] Segment Routing with IPv6
        [    2.234075] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
        [    2.234850] systemd[1]: Detected architecture arm.
        [    2.242907] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
        [    2.307863] systemd[1]: Set hostname to <raspberrypi>.
        [    2.380104] usb 1-1.3: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
        [    2.380124] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [    2.380141] usb 1-1.3: Product: CP2104 USB to UART Bridge Controller
        [    2.380160] usb 1-1.3: Manufacturer: Silicon Labs
        [    2.380175] usb 1-1.3: SerialNumber: 01304FAE
        [    2.582913] usb 1-1.1.1: new full-speed USB device number 5 using xhci_hcd
        [    2.817033] usb 1-1.1.1: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=88.91
        [    2.817053] usb 1-1.1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
        [    2.817069] usb 1-1.1.1: Product: USB1.1-A
        [    2.912910] usb 1-1.4: new full-speed USB device number 6 using xhci_hcd
        [    2.944329] random: systemd: uninitialized urandom read (16 bytes read)
        [    2.954331] random: systemd: uninitialized urandom read (16 bytes read)
        [    2.955376] systemd[1]: Listening on Journal Socket.
        [    2.957348] random: systemd: uninitialized urandom read (16 bytes read)
        [    2.964713] systemd[1]: Starting Load Kernel Modules...
        [    2.971691] systemd[1]: Mounting Kernel Debug File System...
        [    2.973904] systemd[1]: Created slice User and Session Slice.
        [    2.980545] systemd[1]: Starting Create list of required static device nodes for the current kernel...
        [    2.988250] systemd[1]: Starting Restore / save the current clock...
        [    2.989154] systemd[1]: Listening on initctl Compatibility Named Pipe.
        [    3.034418] i2c /dev entries driver
        [    3.050070] usb 1-1.4: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
        [    3.050089] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [    3.050106] usb 1-1.4: Product: CP2104 USB to UART Bridge Controller
        [    3.050121] usb 1-1.4: Manufacturer: Silicon Labs
        [    3.050136] usb 1-1.4: SerialNumber: 01304FAA
        [    3.242939] usb 1-1.1.2: new full-speed USB device number 7 using xhci_hcd
        [    3.479762] usb 1-1.1.2: New USB device found, idVendor=0451, idProduct=16c8, bcdDevice= 1.00
        [    3.479791] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        [    3.479808] usb 1-1.1.2: Product: CC2538 USB CDC
        [    3.479824] usb 1-1.1.2: Manufacturer: Texas Instruments
        [    3.604893] EXT4-fs (sda2): re-mounted. Opts: (null)
        [    3.724012] systemd-journald[110]: Received request to flush runtime journal from PID 1
        [    4.054210] usbcore: registered new interface driver usbserial_generic
        [    4.054316] usbserial: USB Serial support registered for generic
        [    4.057206] usbcore: registered new interface driver cp210x
        [    4.057287] usbserial: USB Serial support registered for cp210x
        [    4.057455] cp210x 1-1.3:1.0: cp210x converter detected
        [    4.093152] usb 1-1.3: cp210x converter now attached to ttyUSB0
        [    4.093468] cp210x 1-1.4:1.0: cp210x converter detected
        [    4.100436] usb 1-1.4: cp210x converter now attached to ttyUSB1
        [    4.281227] cdc_acm 1-1.1.2:1.0: ttyACM0: USB ACM device
        [    4.288516] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.290531] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
        [    4.290552] [vc_sm_connected_init]: start
        [    4.297276] usbcore: registered new interface driver cdc_acm
        [    4.297314] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
        [    4.299761] [vc_sm_connected_init]: installed successfully
        [    4.300969] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.304919] mc: Linux media interface: v0.10
        [    4.308281] bcm2835_audio bcm2835_audio: card created with 8 channels
        [    4.353482] videodev: Linux video capture interface: v2.00
        [    4.368886] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.371572] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.378119] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.382161] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.391801] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.395171] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
        [    4.395830] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
        [    4.396252] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
        [    4.396560] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
        [    4.396588] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
        [    4.396610] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
        [    4.396631] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
        [    4.396651] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
        [    4.396848] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
        [    4.413919] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
        [    4.413963] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
        [    4.458324] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
        [    4.458365] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
        [    4.478691] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
        [    4.482972] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
        [    4.486843] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
        [    4.488886] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
        [    4.490968] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
        [    4.491010] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
        [    4.660623] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        [    4.660765] [drm] No displays found. Consider forcing hotplug if HDMI is attached
        [    4.660882] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
        [    4.660907] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
        [    4.660919] [drm] No driver support for vblank timestamp query.
        [    4.660932] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
        [    4.663386] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
        [    4.709517] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
        [    4.794102] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [    4.826528] brcmfmac: F1 signature read @0x18000000=0x15264345
        [    4.836495] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [    4.836967] usbcore: registered new interface driver brcmfmac
        [    4.846142] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
        [    4.863824] sd 0:0:0:0: Attached scsi generic sg0 type 0
        [    5.091434] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [    5.101117] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
        [    5.129699] Bluetooth: Core ver 2.22
        [    5.129780] NET: Registered protocol family 31
        [    5.129794] Bluetooth: HCI device and connection manager initialized
        [    5.129819] Bluetooth: HCI socket layer initialized
        [    5.129841] Bluetooth: L2CAP socket layer initialized
        [    5.129872] Bluetooth: SCO socket layer initialized
        [    5.204430] usbcore: registered new interface driver btusb
        [    7.818381] random: crng init done
        [    7.818394] random: 7 urandom warning(s) missed due to ratelimiting
        [    8.174371] 8021q: 802.1Q VLAN Support v1.8
        [    8.353971] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
        [    8.353995] Bluetooth: BNEP filters: protocol multicast
        [    8.354037] Bluetooth: BNEP socket layer initialized
        [    8.493026] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
        [    8.527280] debugfs: File 'dut_mode' in directory 'hci0' already present!
        [    8.773850] bcmgenet: Skipping UMAC reset
        [    8.779812] bcmgenet fd580000.ethernet: configuring instance for external RGMII
        [    8.780335] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
        [    8.780354] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [    9.630539] broken atomic modeset userspace detected, disabling atomic
        [   10.043083] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
        [   10.250587] broken atomic modeset userspace detected, disabling atomic
        [   11.285087] broken atomic modeset userspace detected, disabling atomic
        [   11.867525] broken atomic modeset userspace detected, disabling atomic
        [   12.930630] broken atomic modeset userspace detected, disabling atomic
        [   13.541574] broken atomic modeset userspace detected, disabling atomic
        [   14.569388] broken atomic modeset userspace detected, disabling atomic
        [   15.168726] broken atomic modeset userspace detected, disabling atomic
        [   16.212496] broken atomic modeset userspace detected, disabling atomic
        [   16.867607] broken atomic modeset userspace detected, disabling atomic
        [   16.892991] warning: process `colord-sane' used the deprecated sysctl system call with 8.1.2.
        [  696.820506] usb 1-1.1.4: new full-speed USB device number 8 using xhci_hcd
        [ 1531.561163] usb 1-1.1.4: new full-speed USB device number 9 using xhci_hcd
        [ 2076.677034] usb 1-1.1.4: new full-speed USB device number 10 using xhci_hcd
        [ 2299.670649] usb 1-1.1.4: new full-speed USB device number 11 using xhci_hcd
        [ 2299.901786] usb 1-1.1.4: device descriptor read/all, error -32
        [ 2400.302119] usb 1-1.1.4: new full-speed USB device number 13 using xhci_hcd
        [ 2400.542728] usb 1-1.1.4: New USB device found, idVendor=03eb, idProduct=204b, bcdDevice= 0.00
        [ 2400.542746] usb 1-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        [ 2400.542761] usb 1-1.1.4: Product: CUL868
        [ 2400.542774] usb 1-1.1.4: Manufacturer: SHA
        [ 2400.556411] cdc_acm 1-1.1.4:1.0: ttyACM1: USB ACM device
        [ 2403.743435] usb 1-1.1.4: USB disconnect, device number 13
        [ 2646.605441] usb 1-1.1.4: new full-speed USB device number 14 using xhci_hcd
        [ 2646.846017] usb 1-1.1.4: New USB device found, idVendor=03eb, idProduct=204b, bcdDevice= 0.00
        [ 2646.846037] usb 1-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        [ 2646.846054] usb 1-1.1.4: Product: CUL868
        [ 2646.846070] usb 1-1.1.4: Manufacturer: SHA
        [ 2646.850943] cdc_acm 1-1.1.4:1.0: ttyACM1: USB ACM device
        [ 2646.979231] usb 1-1.1.4: USB disconnect, device number 14
        [ 2841.547888] usb 1-1.1.4: new full-speed USB device number 15 using xhci_hcd
        [ 2841.758218] usb 1-1.1.4: Device not responding to setup address.
        [ 2841.978040] usb 1-1.1.4: Device not responding to setup address.
        [ 2842.197910] usb 1-1.1.4: device not accepting address 15, error -71
        [ 2907.508671] usb 1-1.1.4: new full-speed USB device number 17 using xhci_hcd
        [ 2907.749315] usb 1-1.1.4: New USB device found, idVendor=03eb, idProduct=204b, bcdDevice= 0.00
        [ 2907.749336] usb 1-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        [ 2907.749352] usb 1-1.1.4: Product: CUL868
        [ 2907.749368] usb 1-1.1.4: Manufacturer: SHA
        [ 2907.756249] cdc_acm 1-1.1.4:1.0: ttyACM1: USB ACM device
        [ 2907.881769] usb 1-1.1.4: USB disconnect, device number 17
        [ 3147.411508] usb 1-1.1.4: new full-speed USB device number 18 using xhci_hcd
        [ 3147.651982] usb 1-1.1.4: New USB device found, idVendor=03eb, idProduct=204b, bcdDevice= 0.00
        [ 3147.651991] usb 1-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        [ 3147.651998] usb 1-1.1.4: Product: CUL868
        [ 3147.652004] usb 1-1.1.4: Manufacturer: SHA
        [ 3147.654695] cdc_acm 1-1.1.4:1.0: ttyACM1: USB ACM device
        [ 3148.045242] usb 1-1.1.4: USB disconnect, device number 18
        [ 3426.504658] usb 1-1.1.4: new full-speed USB device number 19 using xhci_hcd
        [ 3832.109140] usb 1-1.1.4: new full-speed USB device number 20 using xhci_hcd
        [ 3832.349684] usb 1-1.1.4: New USB device found, idVendor=03eb, idProduct=204b, bcdDevice= 0.00
        [ 3832.349704] usb 1-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        [ 3832.349721] usb 1-1.1.4: Product: CUL868
        [ 3832.349737] usb 1-1.1.4: Manufacturer: SHA
        [ 3832.356628] cdc_acm 1-1.1.4:1.0: ttyACM1: USB ACM device
        [ 3832.946428] usb 1-1.1.4: USB disconnect, device number 20
          @hg6806
          who -r
          Wenn da RL5 kommt, stell auf RunLevel3 um.
          • hg6806
            hg6806 Most Active @Thomas Braun last edited by hg6806
            @thomas-braun sagte in Test Adapter BLE v0.12.x:
            who -r
            War auf 5 und habe auf 3 umgestellt.
            Der Rest ist unverändert.
             dmesg
            [    0.000098] bcm2835: system timer (irq = 17)
            [    0.000743] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
            [    0.000759] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
            [    0.000776] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
            [    0.000788] Switching to timer-based delay loop, resolution 18ns
            [    0.001025] Console: colour dummy device 80x30
            [    0.001057] printk: console [tty1] enabled
            [    0.001109] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
            [    0.001130] pid_max: default: 32768 minimum: 301
            [    0.001278] LSM: Security Framework initializing
            [    0.001471] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
            [    0.001494] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
            [    0.002840] Disabling memory control group subsystem
            [    0.002962] CPU: Testing write buffer coherency: ok
            [    0.003462] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
            [    0.004368] Setting up static identity map for 0x200000 - 0x20003c
            [    0.004574] rcu: Hierarchical SRCU implementation.
            [    0.006432] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
            [    0.007756] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
            [    0.009014] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
            [    0.009173] smp: Brought up 1 node, 4 CPUs
            [    0.009190] SMP: Total of 4 processors activated (432.00 BogoMIPS).
            [    0.009203] CPU: All CPU(s) started in HYP mode.
            [    0.009216] CPU: Virtualization extensions available.
            [    0.010032] devtmpfs: initialized
            [    0.023905] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
            [    0.024165] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
            [    0.024193] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
            [    0.030995] pinctrl core: initialized pinctrl subsystem
            [    0.031973] NET: Registered protocol family 16
            [    0.035864] DMA: preallocated 1024 KiB pool for atomic coherent allocations
            [    0.036434] audit: initializing netlink subsys (disabled)
            [    0.036696] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
            [    0.037811] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
            [    0.037826] hw-breakpoint: maximum watchpoint size is 8 bytes.
            [    0.038141] Serial: AMBA PL011 UART driver
            [    0.041656] bcm2835-mbox fe00b880.mailbox: mailbox enabled
            [    0.060811] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-01-08 14:31, variant start
            [    0.070826] raspberrypi-firmware soc:firmware: Firmware hash is 194a85abd768c7334bbadc3f1911c10a7d18ed14
            [    0.125902] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
            [    0.129775] vgaarb: loaded
            [    0.130241] SCSI subsystem initialized
            [    0.130476] usbcore: registered new interface driver usbfs
            [    0.130545] usbcore: registered new interface driver hub
            [    0.130668] usbcore: registered new device driver usb
            [    0.131025] usb_phy_generic phy: phy supply vcc not found, using dummy regulator
            [    0.132828] clocksource: Switched to clocksource arch_sys_counter
            [    0.891488] VFS: Disk quotas dquot_6.6.0
            [    0.891587] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
            [    0.891763] FS-Cache: Loaded
            [    0.891955] CacheFiles: Loaded
            [    0.902208] thermal_sys: Registered thermal governor 'step_wise'
            [    0.902587] NET: Registered protocol family 2
            [    0.903502] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
            [    0.903533] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
            [    0.903595] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
            [    0.903666] TCP: Hash tables configured (established 8192 bind 8192)
            [    0.903815] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
            [    0.903847] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
            [    0.904098] NET: Registered protocol family 1
            [    0.904821] RPC: Registered named UNIX socket transport module.
            [    0.904834] RPC: Registered udp transport module.
            [    0.904847] RPC: Registered tcp transport module.
            [    0.904860] RPC: Registered tcp NFSv4.1 backchannel transport module.
            [    0.904881] PCI: CLS 0 bytes, default 64
            [    0.906787] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
            [    0.909014] Initialise system trusted keyrings
            [    0.909243] workingset: timestamp_bits=14 max_order=19 bucket_order=5
            [    0.920274] FS-Cache: Netfs 'nfs' registered for caching
            [    0.921000] NFS: Registering the id_resolver key type
            [    0.921043] Key type id_resolver registered
            [    0.921056] Key type id_legacy registered
            [    0.921079] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
            [    0.922178] Key type asymmetric registered
            [    0.922192] Asymmetric key parser 'x509' registered
            [    0.922381] bounce: pool size: 64 pages
            [    0.922430] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
            [    0.922674] io scheduler mq-deadline registered
            [    0.922689] io scheduler kyber registered
            [    0.926704] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
            [    0.926729] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
            [    0.926801] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
            [    0.926872] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x007fffffff -> 0x0400000000
            [    0.984973] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
            [    0.985296] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
            [    0.985315] pci_bus 0000:00: root bus resource [bus 00-ff]
            [    0.985335] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
            [    0.985393] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
            [    0.985664] pci 0000:00:00.0: PME# supported from D0 D3hot
            [    0.988918] PCI: bus0: Fast back to back transfers disabled
            [    0.989149] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
            [    0.989297] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
            [    0.989730] pci 0000:01:00.0: PME# supported from D0 D3cold
            [    0.993009] PCI: bus1: Fast back to back transfers disabled
            [    0.993070] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
            [    0.993093] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
            [    0.993175] pci 0000:00:00.0: PCI bridge to [bus 01]
            [    0.993200] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
            [    0.993514] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
            [    0.993769] pcieport 0000:00:00.0: PME: Signaling with IRQ 55
            [    0.994179] pcieport 0000:00:00.0: AER: enabled with IRQ 55
            [    1.001452] iproc-rng200 fe104000.rng: hwrng registered
            [    1.001799] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
            [    1.002466] vc-sm: Videocore shared memory driver
            [    1.003087] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
            [    1.015352] brd: module loaded
            [    1.027846] loop: module loaded
            [    1.029241] Loading iSCSI transport class v2.0-870.
            [    1.031236] libphy: Fixed MDIO Bus: probed
            [    1.031853] bcmgenet fd580000.ethernet: failed to get enet clock
            [    1.031873] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
            [    1.031896] bcmgenet fd580000.ethernet: failed to get enet-wol clock
            [    1.031917] bcmgenet fd580000.ethernet: failed to get enet-eee clock
            [    1.031945] bcmgenet: Skipping UMAC reset
            [    1.042909] libphy: bcmgenet MII bus: probed
            [    1.133022] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
            [    1.134148] usbcore: registered new interface driver r8152
            [    1.134214] usbcore: registered new interface driver lan78xx
            [    1.134273] usbcore: registered new interface driver smsc95xx
            [    1.134763] xhci_hcd 0000:01:00.0: xHCI Host Controller
            [    1.134798] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
            [    1.138118] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000003000000890
            [    1.139434] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
            [    1.139452] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
            [    1.139468] usb usb1: Product: xHCI Host Controller
            [    1.139484] usb usb1: Manufacturer: Linux 5.4.83-v7l+ xhci-hcd
            [    1.139499] usb usb1: SerialNumber: 0000:01:00.0
            [    1.140113] hub 1-0:1.0: USB hub found
            [    1.140209] hub 1-0:1.0: 1 port detected
            [    1.140739] xhci_hcd 0000:01:00.0: xHCI Host Controller
            [    1.140764] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
            [    1.140788] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
            [    1.141274] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
            [    1.141291] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
            [    1.141306] usb usb2: Product: xHCI Host Controller
            [    1.141322] usb usb2: Manufacturer: Linux 5.4.83-v7l+ xhci-hcd
            [    1.141337] usb usb2: SerialNumber: 0000:01:00.0
            [    1.141947] hub 2-0:1.0: USB hub found
            [    1.142045] hub 2-0:1.0: 4 ports detected
            [    1.143489] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
            [    1.143778] dwc_otg: FIQ enabled
            [    1.143791] dwc_otg: NAK holdoff enabled
            [    1.143803] dwc_otg: FIQ split-transaction FSM enabled
            [    1.143831] Module dwc_common_port init
            [    1.144288] usbcore: registered new interface driver uas
            [    1.144394] usbcore: registered new interface driver usb-storage
            [    1.144588] mousedev: PS/2 mouse device common for all mice
            [    1.146448] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
            [    1.149884] sdhci: Secure Digital Host Controller Interface driver
            [    1.149897] sdhci: Copyright(c) Pierre Ossman
            [    1.150521] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
            [    1.151126] sdhci-pltfm: SDHCI platform and OF driver helper
            [    1.155105] ledtrig-cpu: registered to indicate activity on CPUs
            [    1.155415] hidraw: raw HID events driver (C) Jiri Kosina
            [    1.155595] usbcore: registered new interface driver usbhid
            [    1.155607] usbhid: USB HID core driver
            [    1.156648] vchiq: vchiq_init_state: slot_zero = (ptrval)
            [    1.158589] [vc_sm_connected_init]: start
            [    1.167392] [vc_sm_connected_init]: end - returning 0
            [    1.169645] Initializing XFRM netlink socket
            [    1.169683] NET: Registered protocol family 17
            [    1.169810] Key type dns_resolver registered
            [    1.170216] Registering SWP/SWPB emulation handler
            [    1.170528] registered taskstats version 1
            [    1.170548] Loading compiled-in X.509 certificates
            [    1.171096] Key type ._fscrypt registered
            [    1.171110] Key type .fscrypt registered
            [    1.181963] uart-pl011 fe201000.serial: cts_event_workaround enabled
            [    1.182035] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
            [    1.188230] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
            [    1.189205] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
            [    1.189221] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
            [    1.238528] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
            [    1.240198] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
            [    1.241867] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
            [    1.245739] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
            [    1.247425] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
            [    1.255273] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
            [    1.258341] of_cfs_init
            [    1.258458] of_cfs_init: OK
            [    1.259542] Waiting for root device PARTUUID=d9dc38a3-02...
            [    1.293425] random: fast init done
            [    1.318311] mmc1: new high speed SDIO card at address 0001
            [    1.502866] usb 1-1: new high-speed USB device number 2 using xhci_hcd
            [    1.685526] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
            [    1.685545] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
            [    1.685561] usb 1-1: Product: USB2.0 Hub
            [    1.687309] hub 1-1:1.0: USB hub found
            [    1.687627] hub 1-1:1.0: 4 ports detected
            [    1.833228] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
            [    1.870209] usb 2-2: New USB device found, idVendor=2109, idProduct=0715, bcdDevice= 1.48
            [    1.870226] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
            [    1.870241] usb 2-2: Product: VLI Product String
            [    1.870256] usb 2-2: Manufacturer: VLI Manufacture String
            [    1.870271] usb 2-2: SerialNumber: ABCDEFA74566
            [    1.892408] scsi host0: uas
            [    1.894289] scsi 0:0:0:0: Direct-Access     Samsung  SSD 850 EVO      EMT2 PQ: 0 ANSI: 6
            [    1.897748] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
            [    1.897945] sd 0:0:0:0: [sda] Write Protect is off
            [    1.897964] sd 0:0:0:0: [sda] Mode Sense: 2f 00 00 00
            [    1.898329] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
            [    1.899133] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
            [    1.903401]  sda: sda1 sda2
            [    1.907619] sd 0:0:0:0: [sda] Attached SCSI disk
            [    1.924762] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
            [    1.924838] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
            [    1.925244] devtmpfs: mounted
            [    1.933907] Freeing unused kernel memory: 2048K
            [    1.973138] Run /sbin/init as init process
            [    2.012891] usb 1-1.1: new high-speed USB device number 3 using xhci_hcd
            [    2.137670] systemd[1]: System time before build time, advancing clock.
            [    2.143411] usb 1-1.1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
            [    2.143430] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
            [    2.143446] usb 1-1.1: Product: USB 2.0 Hub
            [    2.145081] hub 1-1.1:1.0: USB hub found
            [    2.145166] hub 1-1.1:1.0: 4 ports detected
            [    2.193535] NET: Registered protocol family 10
            [    2.194852] Segment Routing with IPv6
            [    2.217392] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
            [    2.218190] systemd[1]: Detected architecture arm.
            [    2.242874] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
            [    2.257982] systemd[1]: Set hostname to <raspberrypi>.
            [    2.379952] usb 1-1.3: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
            [    2.379986] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
            [    2.380008] usb 1-1.3: Product: CP2104 USB to UART Bridge Controller
            [    2.380024] usb 1-1.3: Manufacturer: Silicon Labs
            [    2.380039] usb 1-1.3: SerialNumber: 01304FAE
            [    2.572889] usb 1-1.1.1: new full-speed USB device number 5 using xhci_hcd
            [    2.807118] usb 1-1.1.1: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=88.91
            [    2.807138] usb 1-1.1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
            [    2.807155] usb 1-1.1.1: Product: USB1.1-A
            [    2.902736] random: systemd: uninitialized urandom read (16 bytes read)
            [    2.902948] usb 1-1.4: new full-speed USB device number 6 using xhci_hcd
            [    2.913737] random: systemd: uninitialized urandom read (16 bytes read)
            [    2.914480] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
            [    2.914751] random: systemd: uninitialized urandom read (16 bytes read)
            [    2.915417] systemd[1]: Listening on fsck to fsckd communication Socket.
            [    2.916421] systemd[1]: Listening on Journal Audit Socket.
            [    2.916814] systemd[1]: Listening on initctl Compatibility Named Pipe.
            [    2.917452] systemd[1]: Listening on udev Kernel Socket.
            [    2.920623] systemd[1]: Created slice system-systemd\x2dfsck.slice.
            [    2.921352] systemd[1]: Listening on udev Control Socket.
            [    3.040035] usb 1-1.4: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
            [    3.040055] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
            [    3.040072] usb 1-1.4: Product: CP2104 USB to UART Bridge Controller
            [    3.040087] usb 1-1.4: Manufacturer: Silicon Labs
            [    3.040102] usb 1-1.4: SerialNumber: 01304FAA
            [    3.045617] i2c /dev entries driver
            [    3.232895] usb 1-1.1.2: new full-speed USB device number 7 using xhci_hcd
            [    3.470121] usb 1-1.1.2: New USB device found, idVendor=0451, idProduct=16c8, bcdDevice= 1.00
            [    3.470143] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
            [    3.470159] usb 1-1.1.2: Product: CC2538 USB CDC
            [    3.470187] usb 1-1.1.2: Manufacturer: Texas Instruments
            [    3.549602] EXT4-fs (sda2): re-mounted. Opts: (null)
            [    3.644873] systemd-journald[111]: Received request to flush runtime journal from PID 1
            [    4.121573] usbcore: registered new interface driver usbserial_generic
            [    4.121645] usbserial: USB Serial support registered for generic
            [    4.138521] usbcore: registered new interface driver cp210x
            [    4.138602] usbserial: USB Serial support registered for cp210x
            [    4.138782] cp210x 1-1.3:1.0: cp210x converter detected
            [    4.150494] usb 1-1.3: cp210x converter now attached to ttyUSB0
            [    4.150818] cp210x 1-1.4:1.0: cp210x converter detected
            [    4.170647] usb 1-1.4: cp210x converter now attached to ttyUSB1
            [    4.188465] mc: Linux media interface: v0.10
            [    4.216298] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
            [    4.218251] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
            [    4.218925] videodev: Linux video capture interface: v2.00
            [    4.221018] bcm2835_audio bcm2835_audio: card created with 8 channels
            [    4.226811] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
            [    4.226834] [vc_sm_connected_init]: start
            [    4.232463] [vc_sm_connected_init]: installed successfully
            [    4.254119] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
            [    4.267524] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
            [    4.271756] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
            [    4.276116] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
            [    4.281929] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
            [    4.292342] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
            [    4.297379] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
            [    4.298656] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
            [    4.298688] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
            [    4.298718] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
            [    4.298741] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
            [    4.298761] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
            [    4.298906] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
            [    4.298943] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
            [    4.299416] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
            [    4.310006] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
            [    4.310080] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
            [    4.321410] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
            [    4.321465] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
            [    4.445437] [drm] No displays found. Consider forcing hotplug if HDMI is attached
            [    4.445557] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
            [    4.445580] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
            [    4.445593] [drm] No driver support for vblank timestamp query.
            [    4.445605] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
            [    4.461590] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
            [    4.463827] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
            [    4.474628] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
            [    4.475191] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
            [    4.475625] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
            [    4.515969] cfg80211: Loading compiled-in X.509 certificates for regulatory database
            [    4.521801] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
            [    4.646122] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
            [    4.714230] brcmfmac: F1 signature read @0x18000000=0x15264345
            [    4.728258] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
            [    4.729168] usbcore: registered new interface driver brcmfmac
            [    4.736837] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
            [    4.876841] sd 0:0:0:0: Attached scsi generic sg0 type 0
            [    4.940734] Bluetooth: Core ver 2.22
            [    4.940827] NET: Registered protocol family 31
            [    4.940841] Bluetooth: HCI device and connection manager initialized
            [    4.940880] Bluetooth: HCI socket layer initialized
            [    4.940902] Bluetooth: L2CAP socket layer initialized
            [    4.940944] Bluetooth: SCO socket layer initialized
            [    4.957276] usbcore: registered new interface driver btusb
            [    4.976475] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
            [    4.989318] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
            [    5.395238] cdc_acm 1-1.1.2:1.0: ttyACM0: USB ACM device
            [    5.413126] usbcore: registered new interface driver cdc_acm
            [    5.413142] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
            [    7.609209] random: crng init done
            [    7.609220] random: 7 urandom warning(s) missed due to ratelimiting
            [    8.093930] 8021q: 802.1Q VLAN Support v1.8
            [    8.302323] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
            [    8.302339] Bluetooth: BNEP filters: protocol multicast
            [    8.302365] Bluetooth: BNEP socket layer initialized
            [    8.463063] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
            [    8.483223] debugfs: File 'dut_mode' in directory 'hci0' already present!
            [    8.710039] bcmgenet: Skipping UMAC reset
            [    8.720482] bcmgenet fd580000.ethernet: configuring instance for external RGMII
            [    8.721166] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
            [    8.721196] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
            [    9.634821] broken atomic modeset userspace detected, disabling atomic
            [    9.813266] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
            [   10.265027] broken atomic modeset userspace detected, disabling atomic
            [   11.300211] broken atomic modeset userspace detected, disabling atomic
            [   11.881663] broken atomic modeset userspace detected, disabling atomic
            [   12.936100] broken atomic modeset userspace detected, disabling atomic
            [   13.555871] broken atomic modeset userspace detected, disabling atomic
            [   14.603794] broken atomic modeset userspace detected, disabling atomic
            [   15.195568] broken atomic modeset userspace detected, disabling atomic
            [   16.235337] broken atomic modeset userspace detected, disabling atomic
            [   16.832726] broken atomic modeset userspace detected, disabling atomic
            [   19.971533] warning: process `colord-sane' used the deprecated sysctl system call with 8.1.2.
            [   31.832899] vcc-sd: disabling
              @hg6806 Hast du da VNC laufen?
              Das Bluetooth-Ding ist ein separater Stick oder das onboard BT vom Pi?
              • hg6806
                Ja, VNC ist aktiviert.
                BT ist onboard.
                  @hg6806 Dann mach VNC aus. Unnötiger Kram.
                  Per SSH auf die Kiste drauf!
                    Thomas Braun Most Active @hg6806 last edited by Thomas Braun
                    @hg6806 Ich seh ja gerade erst, dass du da als root rumhampelst.
                    Dann bin ich auch raus. Keine Lust auf so ein verfummeltes System.
                    [Edit:] In welcher 'Anleitung' steht eigentlich drin:
                    Wir aktivieren VNC, aktivieren den eigentlich deaktivierten root-Login und melden uns dann als root an?
                    • hg6806
                      hg6806 Most Active last edited by
                      Ich habe jetzt einen TI CC2540 Stick an USB (überHub) angesteckt.
                      Der meldet sich wie folgt:
                      lrwxrwxrwx 1 root root  13 Feb  1 09:43 usb-Texas_Instruments_TI_CC2540_USB_CDC_53556628146843420340-if00 -> ../../ttyACM1
                      Ich kann aber nur HCI auswählen aber kein (com?)-Port.
                        Jan1 @hg6806 last edited by
                        @hg6806
                        Und für was willst denn auch noch zusätzlich den COM Port, wenn im Adapter nur nach HCI verlangt wird?
                        • hg6806
                          hg6806 Most Active @Jan1 last edited by
                          @jan1
                          Wegen dem externen 2540 Stick der steht halt nur auf ACM1 und nicht auf HCI
                            Jan1 @hg6806 last edited by Jan1
                            @hg6806
                            dann mach doch mal das was der Adapter sagt und gebe
                            hciconfig
                            in der Konsole ein, dann dürften zwei BT Geräte gefunden werden, das interne und das externe. So gibts dem Adapter an, welches er verwenden soll. Wozu dann noch ein COM Port nach dem der Adapter nicht fragt?
                            • hg6806
                              @jan1
                              Hatte ich, es wird eben nur ein HCI device angegeben
                              hciconfig
                              hci0:   Type: Primary  Bus: USB
                                      BD Address: 00:1A:7D:DA:71:11  ACL MTU: 679:9  SCO MTU: 48:16
                                      DOWN
                                      RX bytes:1148 acl:0 sco:0 events:60 errors:0
                                      TX bytes:736 acl:0 sco:0 commands:60 errors:0
                                @hg6806
                                Na da hast ja schon Dein Grund warum es nicht geht. Dein BT Dienst ist down.
                                Das muss so aussehen:
                                jan@Beelink:~$ hciconfig
                                        BD Address: F4:D1:08:43:46:D9  ACL MTU: 1021:5  SCO MTU: 96:6
                                        UP RUNNING
                                        RX bytes:163928 acl:0 sco:0 events:5041 errors:0
                                        TX bytes:46157 acl:0 sco:0 commands:1080 errors:0
                                  crunchip Forum Testing Most Active @Jan1 last edited by crunchip
                                  @jan1 das ist schon die ganze Zeit so, hatte ich schon vor 18 Stunden schon danach gefragt
                                  Ausserdem, wenn ein externer Stick dazu kommt, müsste ebenfalls hci1 erscheinen
                                    Jan1 @crunchip last edited by Jan1
                                    @crunchip
                                    und hat er geantwortet?
                                    Ich lese nur so am Rande mit und wundere mich, dass das schon so lange geht.
                                    Ich hatte ja auch schon das Vergnügen wegen dem gelben BLE Adapter mich etwas mehr mit der Materie beschäftigen zu dürfen. Da fragst Google nach Debian BT und es kommen gleich ein paar Seiten, die sehr genau beschreiben, wie man das prüft und löst.
                                    Bei mir wars ja der selbe Mist wie bei Dir, stromfrei warten und neu starten, geht. Hatte ich heute morgen gerade mal wieder 😉
                                    Wenn der Dienst nicht läuft, kann er BT Dongel über USB anstecken so viel er will, die werden nicht funktionieren
                                    • hg6806
                                      Ja, hatte ich in #40 gepostet.
                                        @hg6806
                                        hast dann auch schon mal
                                        sudo service bluetooth start
                                        gemacht?
                                        Da steht einiges was man tun könnte.
                                          Fox1985 last edited by Fox1985
                                          Hallo miteinander,
                                          ich habe mir zwei Xiaomi Rauchmelder gekauft.
                                          Die 2 Gen. funkt per BLE.
                                          Kann der Rauchmelder auch noch hinzugefügt werden?
                                          Viele Grüße
                                          • AlCalzone
                                            AlCalzone Developer @Fox1985 last edited by
                                            @fox1985 Zeig mal den vollständigen Wert von fe95. Dann kann ich eventuell was dazu sagen.
                                            31.7k
                                            79.8k
                                            adapter test ble bluetooth noble
                                            17
                                            79
                                            8566
