    4. BackItUp für InfluxDB
    • FreunderNacht
      FreunderNacht @simatec last edited by
      @simatec
      Hab's geändert:
      ### Welcome to the InfluxDB configuration file.
      # The values in this file override the default values used by the system if
      # a config option is not specified. The commented out lines are the configuration
      # field and the default value used. Uncommenting a line and changing the value
      # will change the value used at runtime when the process is restarted.
      # Once every 24 hours InfluxDB will report usage data to usage.influxdata.com
      # The data includes a random ID, os, arch, version, the number of series and other
      # usage data. No data from user databases is ever transmitted.
      # Change this option to true to disable reporting.
      # reporting-disabled = false
      # Bind address to use for the RPC service for backup and restore.
      bind-address = "0.0.0.0:8088"
      ### [meta]
      ### Controls the parameters for the Raft consensus group that stores metadata
      ### about the InfluxDB cluster.
      [meta]
        # Where the metadata/raft database is stored
        dir = "/var/lib/influxdb/meta"
        # Automatically create a default retention policy when creating a database.
        # retention-autocreate = true
        # If log messages are printed for the meta service
        # logging-enabled = true
      ### [data]
      ### Controls where the actual shard data for InfluxDB lives and how it is
      ### flushed from the WAL. "dir" may need to be changed to a suitable place
      ### for your system, but the WAL settings are an advanced configuration. The
      ### defaults should work for most systems.
      Jetzt scheint es funktioniert zu haben:
      Gestartet...
      [DEBUG] [mount] - mount successfully completed
      [DEBUG] [mount] - done
      [DEBUG] [iobroker] - host.io-broker 4923 states saved
      [DEBUG] [iobroker] - host.io-broker 5695 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_01_04-21_31_08_Home_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [influxDB] - Start infulxDB Backup ...
      [DEBUG] [influxDB] - Created InfuxDB Backup dir
      [DEBUG] [influxDB] - exec: influxd backup -portable -database io-broker -host 192.168.2.97:8088 /opt/iobroker/backups/influxDB_2021_01_04-21_31_14_Home_backupiobroker
      [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_01_04-21_31_14_Home_backupiobroker.tar.gz
      [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
      [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
      [DEBUG] [influxDB] - done
      [DEBUG] [cifs] - done
      [DEBUG] [clean] - done
      [DEBUG] [telegram] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [DEBUG] [umount] - mount activ... umount in 60 Seconds!!
      [DEBUG] [umount] - umount successfully completed
      [DEBUG] [umount] - done
      [EXIT] 0
      Die Bind-Adresse auf der InfluxDB die ich (nur für das Backup) auf dem Server des IO Brokers installiert habe, habe ich wieder auskommentiert.
      @simatec
      Vielen Dank für deine Hilfe, das hat mir sehr geholfen.
      Freund der Nacht
      • smile
        smile last edited by
        Ich habe mich gerade riesig gefreut als ich gesehen hab dass influxDB Backup mit integriert ist. Großes Dankeschön dafür!
        Als ich bei mir das Backup machen wollte, konnte ich jedoch den Reiter influxDB nicht sehen.
        influxDB läuft bei mir auf dem gleichen System (Windows 10) zusammen mit dem iobroker.
        FreunderNacht 1 Reply Last reply Reply Quote 0
        • FreunderNacht
          FreunderNacht @smile last edited by
          @smile
          hast du die neuste Version des Adapters auf deinem System?
          Bei mir ist es die Version 1.8.3.
          Läuft allerdings unter Linux, könnte sein, das es da unterschiede gibt.
          Freund der Nacht
          smile 1 Reply Last reply Reply Quote 0
          • smile
            smile @FreunderNacht last edited by
            @FreunderNacht Oh, interessant, bei mir ist Version 1.7 drauf und die 1.8 steht mir auch nicht zur Installation zur Verfügung. Kann es daran liegen dass node und nom nicht auf dem neusten Stand sind? 10.17.0 und npm 6.11.3 Sowie Admin auf 3.7.8
            Ja könnte aber natürlich auch an dem Linux Unterschied liegen.
            • Glasfaser
              Glasfaser @smile last edited by
              @smile sagte in BackItUp für InfluxDB:
              Nö ... am Verwahrungsort im ioBroker.
              FreunderNacht 1 Reply Last reply Reply Quote 1
              • FreunderNacht
                FreunderNacht @Glasfaser last edited by
                @Glasfaser
                Stimmt, ich hatte vergessen, das ich die Version aus "latest" installiert hatte.
                Ich glaube aber oben in einem Post von @simatec gelesen zu haben, dass die Version 1.8.3 bald in den "stabel" kommt.
                • FreunderNacht
                  @simatec sagte in BackItUp für InfluxDB:
                  @Segway
                  Danke die kommt in den nächsten Wochen ins stable.
                  Pro Instanz von Backitup kann aktuell eine Datenbank von Influx gesichert werden
                  Jepp, da stehts.
                    DF612 last edited by
                    bei mir will der Restore der InfluxDB nicht klappen.
                    Influx ist in der Version 1.8.3 installiert und funktioniert auch.
                    Backitup läuft in Version 1.8.5
                    Wiederhergestellt werden soll eine ca. 140MB große Datenbank, welche auf einem NAS über FTP abgerufen wird. Die Datei wird auch im Wiederherstellen Menü gefunden und kann ausgewählt werden.
                    Sobald ich die Datei anklicke werde ich darauf hingewiesen, dass der IBroker neustarten wird und die kleine Uhr neben dem Datensatz verschwindet.
                    Ab diesem Punkt gibt es kein weiteres Feedback.
                    Nach ein paar Minuten lässt sich über die Konsole überprüfen, dass in InfluxDB die Datenbank und die Measurements angelegt wurden, allerdings sind in den Measurements keine Datenpunkte.
                    Im Log sehe ich ebenfalls nichts.
                    Hat jemand eine Idee wo hier das Problem liegen könnte?
                    • simatec
                      simatec Developer Most Active @DF612 last edited by
                      @df612
                      Versuche es bitte lokal zu restoren.
                        passuff @simatec last edited by passuff
                        @simatec
                        Folgende Konfig:
                        Server 1: iobroker
                        Server 2. influxdb mit datenbank (läuft seit Jahren)
                        Ich habe nun auf Server 1 influxdb nachinstalliert. Ich verstehe es zwar nicht, habe es aber dennoch einfach mal getan. Ich habe weder eine db noch einen Benutzer angelegt. Zusätzlich habe ich nun auf Server 2 ein bind auf 0.0.0.0:8088 eingerichtet. Vermutlich ergibt das alles keinen Sinn und der Grund warum das backup nicht funktioniert ist offensichtlich - ich verstehe hier leider nur Bahnhof:
                        influxDB: Error: Command failed: influxd backup -portable -database iobroker -host 192.168.1.10:8088 "/opt/iobroker/backups/influxDB_2021_02_01-11_02_37_backupiobroker"
                        2021/02/01 11:02:37 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (0)...
                        2021/02/01 11:02:39 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (1)...
                        2021/02/01 11:02:41 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (2)...
                        2021/02/01 11:02:43 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (3)...
                        2021/02/01 11:02:45 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (4)...
                        2021/02/01 11:02:47 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2s and retrying (5)...
                        2021/02/01 11:02:49 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 3.01s and retrying (6)...
                        2021/02/01 11:02:52 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 11.441s and retrying (7)...
                        2021/02/01 11:03:04 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 43.477s and retrying (8)...
                        2021/02/01 11:03:47 Download shard 0 failed dial tcp 192.168.1.10:8088: connect: connection refused.  Waiting 2m45.216s and retrying (9)...
                        backup: dial tcp 192.168.1.10:8088: connect: connection refused
                        Meine adapter settings zeigen auf die aktive db auf Server2.
                        simatec 2 Replies Last reply Reply Quote 0
                        • simatec
                          simatec Developer Most Active @passuff last edited by
                          @passuff sagte in BackItUp für InfluxDB:
                          Hast du Influx auf Server 2 mit "bind auf 0.0.0.0:8088" geändert?
                          Wurde im Anschluss an die Änderungen Influx auf Server 2 neugestartet?
                            beides korrekt.
                            • simatec
                              @passuff
                              Zeige mal bitte deine Config der Influx und deine IP-Adressen der Server
                                @simatec
                                Server 1 (iobroker; 192.168.1.19; influxdb ohne db/user/etc.)
                                Server 2 (influxdb; 192.168.1.10; bind 0.0.0.0:8088)
                                • simatec
                                  simatec Developer Most Active @passuff last edited by simatec
                                  Trage mal bitte als remote bind folgendes ein und starte im Anschluss influxdb oder besser dein komplettes System mal neu
                                  bind 192.168.1.10:8088
                                  Zeige hier mal bitte die influxdb.conf
                                  P 2 Replies Last reply Reply Quote 0
                                    @simatec
                                    welche influxdb.conf soll ich ändern bzw zeigen? Es gibt ja zwei:
                                    • Server 1 (ioboker + influxdb)
                                    • ListenpunktServer 2 (influxdb - aktive db)
                                    • simatec
                                      @passuff
                                      Nur die von Server 2. Server 1 ist egal ... Da wird nur die influxd zur Backupausführung benötigt
                                        Markus84 @simatec last edited by
                                        @simatec Ich habe leider auch einen Fehler beim backup der Influx-Datenbank und weiß nicht so recht wo ich anfangen muss den Fehler zu suchen:
                                        Started...
                                        [DEBUG] [iobroker] - host.iobroker 9481 states saved
                                        [DEBUG] [iobroker] - host.iobroker 10225 objects saved
                                        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_02_02-14_19_01_backupiobroker.tar.gz
                                        [DEBUG] [influxDB] - exec: influxd backup -portable -database iobroker -host 192.168.100.12:8088 /opt/iobroker/backups/influxDB_2021_02_02-14_19_19_backupiobroker
                                        [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker -host 192.168.100.12:8088 /opt/iobroker/backups/influxDB_2021_02_02-14_19_19_backupiobroker
                                        /bin/sh: 1: influxd: not found
                                        [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_02_02-14_19_01_backupiobroker.tar.gz...
                                        [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/influxDB_2021_02_02-14_19_19_backupiobroker.tar.gz" not found
                                        [DEBUG] [googledrive] - done
                                        [DEBUG] [pushover] - done
                                        [EXIT] 0
                                        Kannst du hier helfen?
                                        • simatec
                                          simatec Developer Most Active @Markus84 last edited by simatec
                                          @markus84
                                          Bitte mach ein Update auf die Version 1.8.5 oder auf die Github-Version 2.0.0-beta.2
                                          Des Weiteren muss Influx auf dem ioboker System laufen, wobei die Datenbank auf einem anderen Server liegen kann.
                                          In der Conf von Influx "bind auf 0.0.0.0:8088" anpassen
                                            @simatec Ich habe über Github die aktuelle Beta installiert. Leider erhalte ich die gleiche Fehlermeldung:
                                            Started iobroker ...
                                            [DEBUG] [iobroker] - host.iobroker 9475 states saved
                                            [DEBUG] [iobroker] - host.iobroker 10224 objects saved
                                            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_02_02-14_49_49_backupiobroker.tar.gz
                                            [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                            [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                            [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker -host 192.168.100.12:8088 "/opt/iobroker/backups/influxDB_2021_02_02-14_50_06_backupiobroker"
                                            [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_02_02-14_49_49_backupiobroker.tar.gz...
                                            [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/influxDB_2021_02_02-14_50_06_backupiobroker.tar.gz" not found
                                            [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                                            [EXIT] 0
                                            81.1k
                                            backitup influxdb
                                            32
                                            273
                                            51512
