    5. [Gelöst] Aqara OPPLE ( 6 Tasten )
      paul53 @acem last edited by paul53
      @acem sagte:
      für alle 3 Rollos den Code Datei hochladen
      Nur für 1 Rollo: Erstelle besser 3 gleiche Skripte, die sich nur in den Datenpunkt-Zuweisungen unterscheiden.
      Ich denke (habe selbst keine Rollos), dass man auch den Datenpunkt "WORKING" auswerten kann:
       <block type="on_ext" id="o:qjiuF~}nHI8lK*vi?v" x="-112" y="37">
         <field name="CONDITION">gt</field>
         <value name="OID0">
           <shadow type="field_oid" id="QGeY$;M9!5)9d,@h=EqD">
           <block type="controls_if" id="Zq*6ZdI*Wgxjf4x{BDr^">
               <block type="get_value" id="mV^Y;=Sn4pe*hYVwsW+=">
                 <field name="OID">ID auswählen</field>
               <block type="comment" id="@2Z:hu2+O}v*|Br4o=H1">
                 <field name="COMMENT">STOP</field>
                   <block type="control" id="te_y*PZd)4tOsKDGyIQO">
                       <block type="logic_boolean" id="C|p1--AVAOW2l.m|B#zg">
             <value name="IF1">
               <block type="logic_compare" id=",Po6zL,{6U|(I3/qOT*f">
                 <field name="OP">GT</field>
                   <block type="get_value" id="]iSe_Yo^l}bb2;YU39`Q">
                   <block type="math_number" id="Uxy@vvKPnTdWmK~}-^Y6">
                     <field name="NUM">0</field>
             <statement name="DO1">
               <block type="control" id="3t/,-4XTu_OGvb]vNM`N">
                   <block type="math_number" id="a=r_u+iG7/{LN=I-W0TV">
           <block type="on_ext" id="q$zeQ?G=^:]fvR$1mqT}">
             <value name="OID0">
               <shadow type="field_oid" id="w;[jH?o5j3D@SJ[th*B}">
               <block type="controls_if" id="FmoIsPm8Koh*~!0.G}Ly">
                   <block type="get_value" id="KhTa;iI@,kCT``6]yUmU">
                   <block type="comment" id="FZc0*I)iZVC9OP(rb-=]">
                       <block type="control" id="aht^Gmxa2#l{Cj.F=tcG">
                           <block type="logic_boolean" id="Dr}%akT.-7,Ys*qtra=h">
                 <value name="IF1">
                   <block type="logic_compare" id="xQ[R:$/?Cxa;)D}Q)Lv$">
                     <field name="OP">LT</field>
                       <block type="get_value" id="/b7YuV1idXT,v]6q,D[!">
                       <block type="math_number" id="x(-s7g44OD!1E-eE.,z=">
                         <field name="NUM">100</field>
                   <block type="control" id="N4#gW=r]eOX;4BtCLho`">
                       <block type="math_number" id=":Xlpnf-|We`VD4*:!#fb">
       <block type="comment" id="3^iID,d2k:8DT^gav2:C" x="188" y="88">
         <field name="COMMENT">WORKING</field>
       <block type="comment" id="F$@csF+M{ZFzKL,LcJ,C" x="187" y="387">
      A 2 Replies Last reply Reply Quote 0
        acem @paul53 last edited by
        @paul53 ich bin jetzt etwas verwirrt
        wekchen Script jetzt nehmen den hier?
        oder
          acem @paul53 last edited by acem
          @paul53 sagte in Aqara OPPLE ( 6 Tasten ):
          @acem sagte:
             <value name="OID0">
                 <value name="IF1">
                 <value name="OID0">
                     <value name="IF1">
          diesen hier nehmen?
          Und bei Datenpunkt dann LEVEL nehmen beim stoppen der Rollos?
            @acem sagte:
            diesen hier nehmen?
            Ja.
            @acem sagte:
            Zum Stoppen den Datenpunkt "STOP" nehmen. Zum prüfen auf > 0 bzw. < 100 und zum Fahren den Datenpunkt "LEVEL" nehmen.
              so sieht es dann aus, ist das so korrekt?, Funktionert noch nicht! habe ich etwas übersehen? bzw. Etwas vergessen?
                  <value name="OID0">
                      <field name="oid">zigbee.0.04cf8cdf3c797db7.button_1_click</field>
                          <field name="OID">zigbee.0.04cf8cdf3c797db7.button_1_click</field>
                              <field name="OID">hm-rpc.1.OEQ0984789.1.STOP</field>
                      <value name="IF1">
                              <field name="OID">hm-rpc.1.OEQ0984789.1.LEVEL</field>
                      <value name="OID0">
                          <field name="oid">zigbee.0.04cf8cdf3c797db7.button_2_click</field>
                              <field name="OID">zigbee.0.04cf8cdf3c797db7.button_2_click</field>
                          <value name="IF1">
                <block type="comment" id="F$@csF+M{ZFzKL,LcJ,C" x="163" y="363">
                @acem sagte:
                Nein. Wozu habe ich wohl den Kommentar "WORKING" über die ID gesetzt ?
                   <value name="OID0">
                         <block type="get_value_var" id="LttFi5rjtj!**-7*e8V(">
                           <value name="OID">
                             <shadow type="text" id="=Ay:(0.aj-$Z#BPA-[Wk">
                               <field name="TEXT">hm-rpc.1.OEQ0984789.1.WORKING</field>
                       <value name="IF1">
                       <value name="OID0">
                             <block type="get_value_var" id="a7#irb}{hQIfPcL*[vg~">
                               <value name="OID">
                                 <shadow type="text" id="9`2xZVOf]:C4A/JeY]3D">
                           <value name="IF1">
                  @paul53 jetzt funktioniert es
                  Danke vielmals 🙂 😉
                    Stoni last edited by
                    @acem Über welchen Adapter hast Du den Opple 6-fach eingebunden?
                    Ich habe ihn gerade über den Deconz Adapter eingebunden, bei mir erscheint aber nur eine Taste. Dafür brauche ich mir keinen 6-fach Schalter kaufen...
                    VG Stoni
                      Frank579 @Stoni last edited by
                      @stoni
                      Das hatte ich am Anfang auch, du musst mal jede Taste drücken auch die Doppel und dreifach Klicks. Der Datenpunkt würde bei mir erst angelegt wenn ich alles einmal betätigt habe ....
                        Stoni @Frank579 last edited by
                        @frank579 Danke für die Rückmeldung. Hatte zwischenzeitlich mal die Conbee FW auf den neuesten Stand gebracht und im Netz ein wenig recherchiert. Jetzt läufts...
                        938
