    4. BackItUp für InfluxDB
    • simatec
      simatec Developer Most Active @passuff last edited by
      @passuff
      Nur die von Server 2. Server 1 ist egal ... Da wird nur die influxd zur Backupausführung benötigt
        Markus84 @simatec last edited by
        @simatec Ich habe leider auch einen Fehler beim backup der Influx-Datenbank und weiß nicht so recht wo ich anfangen muss den Fehler zu suchen:
        Started...
        [DEBUG] [iobroker] - host.iobroker 9481 states saved
        [DEBUG] [iobroker] - host.iobroker 10225 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_02_02-14_19_01_backupiobroker.tar.gz
        [DEBUG] [iobroker] - done
        [DEBUG] [influxDB] - Start infulxDB Backup ...
        [DEBUG] [influxDB] - Created InfuxDB Backup dir
        [DEBUG] [influxDB] - exec: influxd backup -portable -database iobroker -host 192.168.100.12:8088 /opt/iobroker/backups/influxDB_2021_02_02-14_19_19_backupiobroker
        [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
        [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
        [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker -host 192.168.100.12:8088 /opt/iobroker/backups/influxDB_2021_02_02-14_19_19_backupiobroker
        /bin/sh: 1: influxd: not found
        [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_02_02-14_19_01_backupiobroker.tar.gz...
        [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/influxDB_2021_02_02-14_19_19_backupiobroker.tar.gz" not found
        [DEBUG] [googledrive] - done
        [DEBUG] [clean] - done
        [DEBUG] [pushover] - done
        [DEBUG] [historyHTML] - new history html values created
        [DEBUG] [historyHTML] - done
        [DEBUG] [historyJSON] - new history json values created
        [DEBUG] [historyJSON] - done
        [EXIT] 0
        Kannst du hier helfen?
        • simatec
          simatec Developer Most Active @Markus84 last edited by simatec
          @markus84
          Bitte mach ein Update auf die Version 1.8.5 oder auf die Github-Version 2.0.0-beta.2
          Des Weiteren muss Influx auf dem ioboker System laufen, wobei die Datenbank auf einem anderen Server liegen kann.
          In der Conf von Influx "bind auf 0.0.0.0:8088" anpassen
            @simatec Ich habe über Github die aktuelle Beta installiert. Leider erhalte ich die gleiche Fehlermeldung:
            Started iobroker ...
            [DEBUG] [iobroker] - host.iobroker 9475 states saved
            [DEBUG] [iobroker] - host.iobroker 10224 objects saved
            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_02_02-14_49_49_backupiobroker.tar.gz
            [DEBUG] [influxDB] - Start InfluxDB Backup ...
            [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
            [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker -host 192.168.100.12:8088 "/opt/iobroker/backups/influxDB_2021_02_02-14_50_06_backupiobroker"
            [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_02_02-14_49_49_backupiobroker.tar.gz...
            [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/influxDB_2021_02_02-14_50_06_backupiobroker.tar.gz" not found
            [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
            [EXIT] 0
            • simatec
              @markus84 sagte in BackItUp für InfluxDB:
              Du musst Influx auf deinem iobroker System installiert haben.
              In der influxdb.conf auf deinem Influx-Server muss in den Remote-Einstellungen dann folgendes geändert werden
              bind <IP des Servers>:8088
              oder
              bind 0.0.0.0:8088
              Im Anschluss Influx neustarten
                @simatec Danke, das probiere ich gleich mal aus. Hätte ich das irgendwo in der Anleitung finden können? Ich hab gerade mal geschaut, aber nur den Issue#390 zu diesem Thema auf Github gefunden.
                Meine Frage zielt darauf ab, ob ich einfach nur Influx installieren muss oder ob das auch in irgendeiner Form laufen muss (was ja wiederum Ressourcen benötigt). Nur das Installieren kostet ja nur ein paar MB Speicherplatz und ist nicht tragisch...
                Insofern aber noch der Hinweis, dass der Fehler nicht im log steht (wo ich mich eigentlich drauf verlassen hätte) und auch nicht im Datenpunkt backitup.0.history.iobrokerSuccess als false ausgegeben wird. Letzteres verstehe ich noch, da es ja nicht das ioBroker-Backup an sich betrifft. Könnte man für die weiteren Backup-Optionen (Grafana, Influx, etc.) entsprechende Datenpunkte unter history anlegen, um die Backups zu überwachen? Ist diesbezüglich etwas geplant?
                • simatec
                  @markus84
                  Die Doku wird aktuell von mir für Version 2.0.0 überarbeitet. Dort wird dann auch alles zu Influx stehen
                    @simatec Super, ich frag nur nicht gerne, wenn ich es auch einfach hätte selbst irgendwo lesen können...
                    Noch eine Frage/Hinweis: Der "Backup now" button ist unter dem Reiter ioBroker. Ist das noch logisch, da ja weit mehr als der ioBroker mit diesem button geupdatet werden kann?
                    • simatec
                      @markus84
                      Guter Gedanke .. Ich überlege mir da mal etwas
                        @simatec
                        Leider erhalte ich noch Fehlermeldungen im Log. Influx ist auf dem ioBroker RPI installiert, das Binding ist eingetragen in der influxdb.conf auf meinem Grafana/Influxdb RPI. Neu gestartet habe ich auch.
                        Bezüglich Grafana: Trotz Fehlermeldung wurde ein Grafana Backup gespeichert. Ob es sich restoren lassen würde habe ich allerdings nicht getestet.
                        [DEBUG] [iobroker] - host.iobroker 9480 states saved
                        [DEBUG] [iobroker] - host.iobroker 10222 objects saved
                        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_02_03-05_31_29_backupiobroker.tar.gz
                        [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker -host 192.168.100.12:8088 "/opt/iobroker/backups/influxDB_2021_02_03-05_31_47_backupiobroker"
                        2021/02/03 05:31:47 Download shard 0 failed dial tcp 192.168.100.12:8088: connect: connection refused.  Waiting 2s and retrying (0)...
                        2021/02/03 05:31:49 Download shard 0 failed dial tcp 192.168.100.12:8088: connect: connection refused.  Waiting 2s and retrying (1)...
                        2021/02/03 05:31:51 Download shard 0 failed dial tcp 192.168.100.12:8088: connect: connection refused.  Waiting 2s and retrying (2)...
                        2021/02/03 05:31:53 Download shard 0 failed dial tcp 192.168.100.12:8088: connect: connection refused.  Waiting 2s and retrying (3)...
                        2021/02/03 05:31:55 Download shard 0 failed dial tcp 192.168.100.12:8088: connect: connection refused.  Waiting 2s and retrying (4)...
                        2021/02/03 05:31:57 Download shard 0 failed dial tcp 192.168.100.12:8088: connect: connection refused.  Waiting 2s and retrying (5)...
                        2021/02/03 05:31:59 Download shard 0 failed dial tcp 192.168.100.12:8088: connect: connection refused.  Waiting 3.01s and retrying (6)...
                        2021/02/03 05:32:02 Download shard 0 failed dial tcp 192.168.100.12:8088: connect: connection refused.  Waiting 11.441s and retrying (7)...
                        2021/02/03 05:32:13 Download shard 0 failed dial tcp 192.168.100.12:8088: connect: connection refused.  Waiting 43.477s and retrying (8)...
                        2021/02/03 05:32:57 Download shard 0 failed dial tcp 192.168.100.12:8088: connect: connection refused.  Waiting 2m45.216s and retrying (9)...
                        backup: dial tcp 192.168.100.12:8088: connect: connection refused
                        [DEBUG] [grafana] - Start Grafana Backup ...
                        [DEBUG] [grafana] - Created grafana_tmp directory
                        [DEBUG] [grafana] - Created dashboard directory
                        [DEBUG] [grafana] - Created dashboards_manually_restore directory
                        [DEBUG] [grafana] - Created datasource directory
                        [DEBUG] [grafana] - start Grafana request ...
                        [DEBUG] [grafana] - Grafana is available ... Status: 200
                        [DEBUG] [grafana] - Error on Grafana Dashoard Request: Error: Request failed with status code 401
                        [DEBUG] [grafana] - start Grafana backup compress ...
                        [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2021_02_03-05_35_43_backupiobroker.tar.gz
                        [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                        [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                        [DEBUG] [grafana] - done
                        [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_02_03-05_31_29_backupiobroker.tar.gz...
                        [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/influxDB_2021_02_03-05_31_47_backupiobroker.tar.gz" not found
                        [DEBUG] [googledrive] - Google Drive: Copy grafana_2021_02_03-05_35_43_backupiobroker.tar.gz...
                        [EXIT] 0
                        • simatec
                          @markus84
                          Zeige mal bitte deine influxdb.conf
                          Hast du Influx nach Änderung der bind neugestartet?
                          Zu Grafana. Hast du einen API-Key in Grafana erzeugt und diesen auch in Backitup eingetragen?
                          Stimmen deine Grafana User-Daten?
                          Zeige mal bitte den Inhalt des Grafana Backups. Einfach mal mit 7Zip entpacken
                            @simatec
                            Hat sich erledigt. Nach einem Neustart aller Systeme geht es. Der Adapter war schon immer klasse aber jetzt ist er nahezu perfekt!
                            • MassiveAttack
                              MassiveAttack last edited by
                              remote backup aufs nas funktioniert für iobroker & grafana. für die influxdb bekomme ich aber einen fehler:
                              [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker -host 192.168.0.80:8086 "/opt/iobroker/backups/influxDB_2021_02_03-10_57_37_backupiobroker"
                              Zur Info, die influx läuft bei mir als container direkt am nas, der iobroker aber am pi
                              simatec F 2 Replies Last reply Reply Quote 0
                                passuff @simatec last edited by
                                @simatec sagte in BackItUp für InfluxDB:
                                @passuff sagte in BackItUp für InfluxDB:
                                192.168.1.10; bind 0.0.0.0:8088
                                Trage mal bitte als remote bind folgendes ein und starte im Anschluss influxdb oder besser dein komplettes System mal neu
                                bind 192.168.1.10:8088
                                Zeige hier mal bitte die influxdb.conf
                                So funktioniert es perfekt. Danke Dir! 🙂
                                • simatec
                                  simatec Developer Most Active @MassiveAttack last edited by
                                  @massiveattack
                                  Bitte die Anleitung beachten ...
                                  https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md#InfluxDB-Backup
                                  MassiveAttack FreunderNacht 2 Replies Last reply Reply Quote 1
                                  • MassiveAttack
                                    MassiveAttack @simatec last edited by
                                    @simatec
                                    danke, genau das habe ich gesucht.
                                    wie kann ich den influx daemon am pi installieren? brauche ich dazu wirkich die ganze instanz? sprich sudo apt install influxdb
                                    • simatec
                                      @massiveattack
                                      Soweit ich weiß, gibt es da keinen anderen Weg. Allerdings ist die Auslastung au meinen Testsystemen minimal, da keine Datenbanken laufen.
                                      MassiveAttack 1 Reply Last reply Reply Quote 0
                                      • MassiveAttack
                                        @simatec
                                        danke, werde ich mal testen.
                                        besten dank 🙂
                                        • FreunderNacht
                                          FreunderNacht @simatec last edited by
                                          @simatec
                                          Hallo simatec,
                                          eine kurze Frage, bei der Anleitung für das Grafana Backup steht:
                                          "Um ein Grafana-Backup erstellen zu können, wird der Benutzername und das Passwort des Grafana-Servers benötigt."
                                          Ist das Passwort und Benutzer des eigentlichen Servers gemeint, oder nur von Grafana selbst.
                                          Welche Rechte benötigen der Benutzer, root?
                                          Vielen Dank
                                          MfG
                                          Freund der Nacht
                                          MassiveAttack simatec 2 Replies Last reply Reply Quote 0
                                          • MassiveAttack
                                            MassiveAttack @FreunderNacht last edited by
                                            @freundernacht
                                            ja, credentials vom grafana service, habe bei mir meinen admin account genommen.
                                            außerdem brauchst du einen von dir generierten api key (kannst du unter configuration - api keys) erstellen. zB: role admin, expires 10y
                                            FreunderNacht 1 Reply Last reply Reply Quote 1
                                            81.1k
                                            backitup influxdb
                                            32
                                            273
                                            51508
