    4. Test Adapter mihome-vacuum v2.0.x
      Thomas Braun Most Active @bjoegibbard last edited by
      @bjoegibbard Nicht unbedingt.
      Kannst du aber mal nachinstallieren.
      Und ich würde node auf Stand bringen.
      sudo apt update
      sudo apt dist-upgrade
      sudo reboot
      (Wenn es schon sauber installiert war...)
        bjoegibbard @Thomas Braun last edited by
        danke, habe alles ausgeführt. Aber leider keine Besserung.
          @bjoegibbard
          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          cd /opt/iobroker
          npm cache clean --force
          npm install authenticate-pam
            bjoegibbard @Thomas Braun last edited by bjoegibbard
            /usr/bin/nodejs
            v12.20.1
            /usr/bin/node
            v12.20.1
            /usr/bin/npm
            6.14.10
            nodejs:
              Installiert:           12.20.1-1nodesource1
              Installationskandidat: 12.20.1-1nodesource1
              Versionstabelle:
             *** 12.20.1-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                    100 /var/lib/dpkg/status
                 10.23.1~dfsg-1~deb10u1 500
            /opt/iobroker $ npm cache clean --force
            npm WARN using --force I sure hope you know what you are doing.
            > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
            > node-gyp rebuild
            make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
              CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
            In file included from ../authenticate_pam.cc:23:
            ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
            ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                 , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
            ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
            ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
             keCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
            ../../nan/nan.h:1026:46: note: declared here
               NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
            ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             al<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
            In file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8-internal.h:14,
                             from /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:27,
                             from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67,
                             from ../../nan/nan.h:56,
            /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:3553:51: note: declared here
               V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
            /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
               declarator __attribute__((deprecated(message)))
            ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
                serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
            In file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67,
            /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’
               int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
            /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
            ../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
            ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
                remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
            ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
              username->WriteUtf8(m->username, sizeof(m->username) - 1);
            ../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
              password->WriteUtf8(m->password, sizeof(m->password) - 1);
            ../authenticate_pam.cc: At global scope:
            ../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void
             void init(Handle<Object> exports) {
            ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
            ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’
                       rand_r
            ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
            ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
            In file included from ../../nan/nan.h:56,
            ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope
             NODE_MODULE(authenticate_pam, init);
            /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:737:36: note: in definition of macro ‘NODE_MODULE_X’
                   (node::addon_register_func) (regfunc),                          \
            ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
            ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’
            make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
            make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
            gyp ERR! build error
            gyp ERR! stack Error: `make` failed with exit code: 2
            gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
            gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
            gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
            gyp ERR! System Linux 5.4.83-v7l+
            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
            gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
            gyp ERR! node -v v12.20.1
            gyp ERR! node-gyp -v v5.1.0
            gyp ERR! not ok
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.1 (node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/chokidar/node_modules/fsevents):
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zigbee-herdsman/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! authenticate-pam@1.0.2 install: `node-gyp rebuild`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the authenticate-pam@1.0.2 install script.
            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            npm ERR!     /home/iobroker/.npm/_logs/2021-01-24T16_44_12_411Z-debug.log
            pi@raspberrypi4-iob:/opt/iobroker $
            da ist wieder dieser doofe gyp ERR! -.-
              Thomas Braun Most Active @bjoegibbard last edited by Thomas Braun
              @bjoegibbard
              authenticate_pam
              Keine Ahnung. Vielleicht baut das Modul nicht mehr gegen aktuelle node-Versionen. Das ist ja schon über ein Jahr nicht mehr angefasst worden.
              Welcher Adapter braucht das Ding eigentlich?
              npm list authenticate-pam
              Dürfte der terminal-Adapter sein. Braucht eh keiner.
              iobroker del terminal
              cd /opt/iobroker
              Danach sollte Ruhe von der Seite sein.
              N 1 Reply Last reply Reply Quote 1
              • N
                nu_81 @Thomas Braun last edited by nu_81
                Hatte lange Zeit ein ioBroker (mit altem Stand ohne Updates einzuspielen) auf einem Igel laufen
                mit dem ich meinen S50 per Szene gesteuert habe.
                Konkret hatte ich eine Szene "MAP_EG_Laden" erstellt.
                Hierin wurde per SSH auf dem Roborock die Map Dateien getauscht und anschließend kurz gestartet und pausiert um die Karten auch wirklich zu laden.
                Diese Szene habe ich dann vor jede andere Szene gepackt um dann die einzelnen Zonen anzufahren:
                Das hat auch immer zuverlässig funktioniert.
                Habe nun auf einen Raspberry mit aktueller Version gewechselt und da klappt es leider nicht mehr.
                Immer wieder erscheint die Meldung
                "should trigger cleaning all , but is currently active(5). Add to queue"
                Der S50 reagiert dann auch überhaupt nicht, wenn ich z.B. Start auf true setze.
                Muss ich z.B. den Pause Befehl manuell wieder auf false setzten um z.B. die Zonenreinigung zu starten?
                Manchmal funktioniert es wieder wenn ich vor den Befehlen den "Home" Befehl mit rein nehme.
                Es scheint eine neue Funktion der Queue zu geben, die ich hier scheinbar falsch bediene.
                Das hier funktioniert z.B. manchmal:
                Hier noch der obere Teil im aufgeklappten Zustand:
                Aber auch hier kommt manchmal die Meldung mit der Queue.
                Habe auch schon mal versucht "clearQueue" auf true zwischendurch einzusetzen. Aber auch das hilft nicht.
                Leider verstehe ich da das Konzept der Queue auch nicht so recht.
                Kann man die Queue Funktion irgendwie abschalten?
                Wie kann ich die Queue eventuell löschen um den S50 zu "befreien" sodass er wieder Befehle annimmt?
                Wie sollte ich hier am besten vorgehen um es wieder wie vorher zum laufen zu bekommen?
                Gruß Nu
                  dirkhe Developer @nu_81 last edited by
                  @nu_81 die queue ist dafür da, dass du einfach mehrere Räume starten kannst unser die dann nacheinander abarbeitet.
                  Wenn er nicht startet hat er eher verbindindungsprobleme. Sobald er wieder verbunden ist, sollte er starten.
                  • N
                    nu_81 @dirkhe last edited by
                    Glaube nicht dass es Verbindungsprobleme sind.
                    Er reagiert z.B. überhaupt nicht auf start, gibt stattdessen die Meldung ins Log.
                    Auf z.B. auf Home oder "Wo bist du" reagiert er sofort.
                      @nu_81 dann stell den adapter mal auf debug und poste das Log hier.
                        Sweatchuck @dirkhe last edited by
                        kurze Frage...
                        Meine beiden Robrock (S5 und S6) wollen ein Firmware-Update durchführen.
                        Von Version 3.5.8_2076 auf 3.5.8_2652 beim S6 bzw. 3.5.7_002008 auf 3.5.8_002034.
                        Da momentan aber alles super funktioniert will ich nicht einfach ein Update fahren und deshalb mal nachfragen ob jemand von euch Erfahrungen dies bzgl. hat. Angeblich handelt es sich dabei nur ein Bugfix?!
                        Beste Grüße
                        • JackDaniel
                          JackDaniel last edited by
                          keine probleme hier
                            A Former User @Sweatchuck last edited by
                            @sweatchuck
                            nee, meine 4 auch, mach doch mal, dann wissen wir ja, obs dann noch geht.. 🙂
                              A Former User @JackDaniel last edited by
                              @jackdaniel mit Adapter Version ..??
                              • JackDaniel
                                bei mir läuft die 2.2.4
                                  Snapergy last edited by Snapergy
                                  Puh, bin gerade echt am verzweifeln. Ich habe nichts weiter gemacht (zumindest nicht, dass ich wüsste), aber die Map lädt nicht mehr und es kommt immer folgender Fehler:
                                  answer map_slot is currently not supported!
                                  Was kann ich machen?
                                  EDIT: Hab die Lösung gefunden. Für alle, die das gleiche Problem haben:
                                  https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/119
                                  Lag am Update von NodeJS...
                                  root01 created this issue in iobroker-community-adapters/ioBroker.mihome-vacuum
                                  closed no MAP after update Nodejs 10->12 #119
                                    Schwabe last edited by Schwabe
                                    DANKE erstmal für diesen tollen Adapter und die kontinuierliche Arbeit daran.
                                    Wegen einem bevorstehenden Wechsel von einem ASUS TinkerBoard S auf ein Windows10 Ubunto-System habe ich aktuell 2 Versionen von dem Adapter laufen.
                                    Auf dem TinkerBoard S habe ich die Version 1.1.5 installiert und kann nicht auf die Version 2.1.1 updaten. Das Update wird stets mit einem Fehler beendet und der Adpater ist dann auch aus der VIS verschwunden. Ansonsten läuft diese Version zu meiner vollen Zufriedenheit.
                                    Mein Hauptproblem ist jedoch das der Adapter auf dem Ubuntu in der Version 2.1.1 bei "Gelb" bleibt. Ich kann zwar den Server (Germany) abfragen und den S6 übernehmen, doch der Adapter bleibt "Gelb".
                                    Die Konfigurationen sind gleich, wie auf den Screenshots zu sehen.
                                    Ich freue mich über jede Hilfe.
                                    Der LOG von dem Ubuntu-System ist folgender:
                                    2021-02-18 14:02:03.591 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                    2021-02-18 14:02:03.593 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                    2021-02-18 14:02:03.594 - info: mihome-vacuum.0 (915) Got terminate signal TERMINATE_YOURSELF
                                    2021-02-18 14:02:03.595 - info: mihome-vacuum.0 (915) terminating
                                    2021-02-18 14:02:03.595 - info: mihome-vacuum.0 (915) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2021-02-18 14:02:04.111 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2021-02-18 14:02:06.615 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 1020
                                    2021-02-18 14:02:07.105 - info: mihome-vacuum.0 (1020) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                    2021-02-18 14:02:07.146 - info: mihome-vacuum.0 (1020) Expert mode enabled, states created
                                    2021-02-18 14:02:07.146 - info: mihome-vacuum.0 (1020) Create state clean_home for controlling by cloud adapter
                                    2021-02-18 14:02:07.671 - info: mihome-vacuum.0 (1020) set nächster Timer: Nicht verfügbar
                                    2021-02-18 14:02:08.330 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2021-02-18 14:03:09.810 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2021-02-18 14:04:11.431 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2021-02-18 14:05:00.020 - info: host.Server instance system.adapter.dwd.0 started with pid 1035
                                    2021-02-18 14:05:00.580 - info: dwd.0 (1035) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.2, js-controller: 3.1.6
                                    2021-02-18 14:05:00.940 - info: dwd.0 (1035) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2021-02-18 14:05:01.450 - info: host.Server instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2021-02-18 14:05:13.192 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2021-02-18 14:06:14.647 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2021-02-18 14:07:16.150 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2021-02-18 14:08:01.090 - info: hm-rpc.0 (536) xmlrpc <- listDevices ["hm-rpc.0"]
                                    2021-02-18 14:08:01.117 - info: hm-rpc.0 (536) xmlrpc -> 0 devices
                                    2021-02-18 14:08:01.223 - info: hm-rpc.0 (536) xmlrpc <- newDevices 170
                                    2021-02-18 14:08:01.246 - info: hm-rpc.0 (536) new HMIP devices/channels after filter: 0
                                    2021-02-18 14:08:17.620 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2021-02-18 14:09:19.121 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2021-02-18 14:10:00.023 - info: host.Server instance system.adapter.dwd.0 started with pid 1050
                                    2021-02-18 14:10:00.597 - info: dwd.0 (1050) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.2, js-controller: 3.1.6
                                    2021-02-18 14:10:00.983 - info: dwd.0 (1050) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2021-02-18 14:10:01.493 - info: host.Server instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2021-02-18 14:10:20.475 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2021-02-18 14:11:22.013 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2021-02-18 14:11:55.186 - info: host.Server "system.adapter.mihome-vacuum.0" disabled
                                    2021-02-18 14:11:55.188 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                    2021-02-18 14:11:55.188 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                    2021-02-18 14:11:55.190 - info: mihome-vacuum.0 (1020) Got terminate signal TERMINATE_YOURSELF
                                    2021-02-18 14:11:55.191 - info: mihome-vacuum.0 (1020) terminating
                                    2021-02-18 14:11:55.191 - info: mihome-vacuum.0 (1020) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2021-02-18 14:11:55.707 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2021-02-18 14:11:57.923 - info: host.Server "system.adapter.mihome-vacuum.0" enabled
                                    2021-02-18 14:11:57.941 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 1065
                                    2021-02-18 14:11:58.436 - info: mihome-vacuum.0 (1065) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                    2021-02-18 14:11:58.478 - info: mihome-vacuum.0 (1065) Expert mode enabled, states created
                                    2021-02-18 14:11:58.478 - info: mihome-vacuum.0 (1065) Create state clean_home for controlling by cloud adapter
                                    2021-02-18 14:11:59.004 - info: mihome-vacuum.0 (1065) set nächster Timer: Nicht verfügbar
                                    2021-02-18 14:12:00.045 - info: host.Server instance system.adapter.weatherunderground.1 started with pid 1080
                                    2021-02-18 14:12:00.519 - info: weatherunderground.1 (1080) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.20.2, js-controller: 3.1.6
                                    2021-02-18 14:12:03.888 - info: weatherunderground.1 (1080) Terminated (NO_ERROR): Without reason
                                    2021-02-18 14:12:04.068 - info: host.Server instance system.adapter.weatherunderground.0 started with pid 1095
                                    2021-02-18 14:12:04.393 - info: host.Server instance system.adapter.weatherunderground.1 terminated with code 0 (NO_ERROR)
                                    2021-02-18 14:12:04.544 - info: weatherunderground.0 (1095) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.20.2, js-controller: 3.1.6
                                    2021-02-18 14:12:08.195 - info: weatherunderground.0 (1095) Terminated (NO_ERROR): Without reason
                                    2021-02-18 14:12:08.705 - info: host.Server instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                                    • haselchen
                                      haselchen Most Active @Schwabe last edited by
                                      @schwabe
                                      Ich kann nur raten, aber im rechten Screenshot steht für V1 und S5 und Du hast einen S6.....
                                        Schwabe @haselchen last edited by
                                        @haselchen das mit dem S6 ist mir klar, doch der Adapter läuft ja, lässt sich nur nicht updaten.
                                        Wichtiger wäre mir jedoch den Ubuntu ans laufen zu bekommen, der andere wird eh irgendwann abgeschaltet.
                                        • haselchen
                                          haselchen Most Active @Schwabe last edited by haselchen
                                          @schwabe
                                          Pragmatische Lösung , wenn es geht, die 1.1.5 auf Ubuntu installieren?
                                          Das war die letzte Version, mit der dein Sauger funktionierte?
                                          Edit:
                                          Laufen beide Adapter gleichzeitig? (Tinker und Ubuntu?)
                                          Oder hast du mal das WIFI resettet, dass der Token nicht mehr stimmt?
                                            Schwabe @haselchen last edited by Schwabe
                                            @haselchen danke für den Tipp, ich musste zwar erstmal auf den 2.0.7 zurück um überhaupt den 1.1.5 angezeigt zu bekommen, doch hat es endgültig geklappt. Leider ist das Problem damit nicht gelöst, der Adapter bleibt "gelb"
                                            Ja aktuell laufen beide ioBroker und somit auch beide Adapter gleichzeitig. Doch auch die vorübergehende Deaktiverung des ThinkerBoardS Adapters bringt beim Ubuntu keine Besserung. Der Token muss noch stimmen, sonst könnte der ThinkerBoardS Adapter nicht funktionieren und ich würde über die Server Suche einen den Neuen finden, oder?
                                            Hier dazu mein letzter Log:
                                            2021-02-18 19:23:00.831 - info: mihome-vacuum.0 (3441) Got terminate signal TERMINATE_YOURSELF
                                            2021-02-18 19:23:00.831 - info: mihome-vacuum.0 (3441) terminating
                                            2021-02-18 19:23:00.832 - info: mihome-vacuum.0 (3441) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            2021-02-18 19:23:01.347 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2021-02-18 19:23:03.854 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3456
                                            2021-02-18 19:23:04.287 - warn: mihome-vacuum.0 (3456) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                            2021-02-18 19:23:04.288 - warn: mihome-vacuum.0 (3456) This object will not be created in future versions. Please report this to the developer.
                                            2021-02-18 19:23:04.351 - info: mihome-vacuum.0 (3456) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                            2021-02-18 19:23:04.370 - info: mihome-vacuum.0 (3456) Expert mode disabled, states deleted
                                            2021-02-18 19:23:04.371 - info: mihome-vacuum.0 (3456) Cloud control disabled
                                            2021-02-18 19:23:04.375 - info: mihome-vacuum.0 (3456) Disconnect
                                            2021-02-18 19:23:04.900 - info: mihome-vacuum.0 (3456) set nächster Timer: Nicht verfügbar
                                            2021-02-18 19:23:20.469 - info: host.Server iobroker upgrade mihome-vacuum@1.1.5
                                            2021-02-18 19:23:21.486 - info: host.Server iobroker Update mihome-vacuum from @2.0.7 to @1.1.5
                                            2021-02-18 19:23:21.674 - info: host.Server iobroker NPM version: 6.14.11
                                            2021-02-18 19:23:21.675 - info: host.Server iobroker npm install iobroker.mihome-vacuum@1.1.5 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                            2021-02-18 19:23:23.918 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                            2021-02-18 19:23:24.376 - info: mihome-vacuum.0 (3456) Disconnect
                                            2021-02-18 19:23:25.458 - info: host.Server iobroker upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                                            2021-02-18 19:23:25.491 - info: host.Server iobroker Update "system.adapter.mihome-vacuum.0"
                                            2021-02-18 19:23:25.497 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                            2021-02-18 19:23:25.499 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                            2021-02-18 19:23:25.499 - info: mihome-vacuum.0 (3456) Got terminate signal TERMINATE_YOURSELF
                                            2021-02-18 19:23:25.500 - info: mihome-vacuum.0 (3456) terminating
                                            2021-02-18 19:23:25.500 - info: mihome-vacuum.0 (3456) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            2021-02-18 19:23:25.551 - info: host.Server iobroker upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                                            2021-02-18 19:23:25.605 - info: host.Server iobroker upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                                            2021-02-18 19:23:25.667 - info: host.Server iobroker upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                                            2021-02-18 19:23:25.730 - info: host.Server iobroker upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                                            2021-02-18 19:23:25.783 - info: host.Server iobroker Adapter "mihome-vacuum" updated
                                            2021-02-18 19:23:26.009 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2021-02-18 19:23:26.793 - info: host.Server iobroker exit 0
                                            2021-02-18 19:23:28.517 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3502
                                            2021-02-18 19:23:28.836 - warn: mihome-vacuum.0 (3502) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                            2021-02-18 19:23:28.836 - warn: mihome-vacuum.0 (3502) This object will not be created in future versions. Please report this to the developer.
                                            2021-02-18 19:23:28.908 - info: mihome-vacuum.0 (3502) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                            2021-02-18 19:23:28.925 - info: mihome-vacuum.0 (3502) Expert mode disabled, states deleded
                                            2021-02-18 19:23:28.925 - info: mihome-vacuum.0 (3502) Cloud control disabled
                                            2021-02-18 19:23:36.444 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                            2021-02-18 19:23:36.445 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                            2021-02-18 19:23:36.447 - info: mihome-vacuum.0 (3502) Got terminate signal TERMINATE_YOURSELF
                                            2021-02-18 19:23:36.448 - info: mihome-vacuum.0 (3502) terminating
                                            2021-02-18 19:23:36.449 - info: mihome-vacuum.0 (3502) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            2021-02-18 19:23:36.960 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2021-02-18 19:23:39.469 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3517
                                            2021-02-18 19:23:39.775 - warn: mihome-vacuum.0 (3517) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                            2021-02-18 19:23:39.776 - warn: mihome-vacuum.0 (3517) This object will not be created in future versions. Please report this to the developer.
                                            2021-02-18 19:23:39.845 - info: mihome-vacuum.0 (3517) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                            2021-02-18 19:23:39.863 - info: mihome-vacuum.0 (3517) Expert mode disabled, states deleded
                                            2021-02-18 19:23:39.863 - info: mihome-vacuum.0 (3517) Cloud control disabled
                                            2021-02-18 19:23:44.595 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                            2021-02-18 19:23:44.595 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                            2021-02-18 19:23:44.596 - info: mihome-vacuum.0 (3517) Got terminate signal TERMINATE_YOURSELF
                                            2021-02-18 19:23:44.597 - info: mihome-vacuum.0 (3517) terminating
                                            2021-02-18 19:23:44.597 - info: mihome-vacuum.0 (3517) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            2021-02-18 19:23:45.109 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2021-02-18 19:23:47.618 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3532
                                            2021-02-18 19:23:47.922 - warn: mihome-vacuum.0 (3532) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                            2021-02-18 19:23:47.922 - warn: mihome-vacuum.0 (3532) This object will not be created in future versions. Please report this to the developer.
                                            2021-02-18 19:23:47.982 - info: mihome-vacuum.0 (3532) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                            2021-02-18 19:23:47.999 - info: mihome-vacuum.0 (3532) Expert mode enabled, states created
                                            2021-02-18 19:23:48.000 - info: mihome-vacuum.0 (3532) Cloud control disabled
                                            2021-02-18 19:23:52.233 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                            2021-02-18 19:23:52.234 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                            2021-02-18 19:23:52.235 - info: mihome-vacuum.0 (3532) Got terminate signal TERMINATE_YOURSELF
                                            2021-02-18 19:23:52.235 - info: mihome-vacuum.0 (3532) terminating
                                            2021-02-18 19:23:52.236 - info: mihome-vacuum.0 (3532) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            2021-02-18 19:23:52.747 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2021-02-18 19:23:55.258 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3547
                                            2021-02-18 19:23:55.563 - warn: mihome-vacuum.0 (3547) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                            2021-02-18 19:23:55.563 - warn: mihome-vacuum.0 (3547) This object will not be created in future versions. Please report this to the developer.
                                            2021-02-18 19:23:55.626 - info: mihome-vacuum.0 (3547) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                            2021-02-18 19:23:55.644 - info: mihome-vacuum.0 (3547) Expert mode enabled, states created
                                            2021-02-18 19:23:55.644 - info: mihome-vacuum.0 (3547) Cloud control disabled
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            445476
