    4. Blink Camera System
    Blink Camera System
    • I
      IceD112 @Pischleuder last edited by
      @Pischleuder
      Ich hab echt keine Ahnung was ich falsch mache...😖
      Frohe Weihnachten euch allen 🌲 🌨
      JayR 1 Reply Last reply Reply Quote 0
      • JayR
        JayR @IceD112 last edited by
        blink4home.0	2021-01-07 15:30:37.514	warn	(11932) Terminated (UNCAUGHT_EXCEPTION): Without reason
        blink4home.0	2021-01-07 15:30:36.509	error	at internal/main/run_main_module.js:17:47
        blink4home.0	2021-01-07 15:30:36.509	error	at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
        blink4home.0	2021-01-07 15:30:36.509	error	at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        blink4home.0	2021-01-07 15:30:36.509	error	at Module.load (internal/modules/cjs/loader.js:863:32)
        blink4home.0	2021-01-07 15:30:36.509	error	at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        blink4home.0	2021-01-07 15:30:36.509	error	at Module._compile (internal/modules/cjs/loader.js:999:30)
        blink4home.0	2021-01-07 15:30:36.509	error	at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.blink4home/main.js:235:2)
        blink4home.0	2021-01-07 15:30:36.509	error	at new Blink4home (/opt/iobroker/node_modules/iobroker.blink4home/main.js:24:12)
        blink4home.0	2021-01-07 15:30:36.509	error	(11932) TypeError: Cannot read property 'debug' of undefined
        blink4home.0	2021-01-07 15:30:36.505	error	(11932) uncaught exception: Cannot read property 'debug' of undefined
        blink4home.0	2021-01-07 15:30:02.943	warn	(11898) Terminated (UNCAUGHT_EXCEPTION): Without reason
        blink4home.0	2021-01-07 15:30:01.941	error	at internal/main/run_main_module.js:17:47
        blink4home.0	2021-01-07 15:30:01.941	error	at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
        blink4home.0	2021-01-07 15:30:01.941	error	at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        blink4home.0	2021-01-07 15:30:01.941	error	at Module.load (internal/modules/cjs/loader.js:863:32)
        blink4home.0	2021-01-07 15:30:01.941	error	at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        blink4home.0	2021-01-07 15:30:01.941	error	at Module._compile (internal/modules/cjs/loader.js:999:30)
        blink4home.0	2021-01-07 15:30:01.941	error	at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.blink4home/main.js:235:2)
        blink4home.0	2021-01-07 15:30:01.941	error	at new Blink4home (/opt/iobroker/node_modules/iobroker.blink4home/main.js:24:12)
        blink4home.0	2021-01-07 15:30:01.941	error	(11898) TypeError: Cannot read property 'debug' of undefined
        blink4home.0	2021-01-07 15:30:01.937	error	(11898) uncaught exception: Cannot read property 'debug' of undefined
        blink4home.0	2021-01-07 15:29:29.661	info	(11831) starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.blink4home, node: v12.20.0, js-controller: 3.1.6
        blink4home.0	2021-01-07 15:29:29.583	warn	(11831) Terminated (UNCAUGHT_EXCEPTION): Without reason
        Ich bekomme folgenden Fehler hat jemand eine Idee?
          Pischleuder @JayR last edited by
          @JayR
          Blink4home funktioniert noch nicht, seitdem die Verschlüsselungsmethode geändert wurde.
          Albert K 1 Reply Last reply Reply Quote 0
          • Albert K
            Albert K @Pischleuder last edited by
            Nur zur Info:
            Seit kurzem (Dank sei @apollon77 !!! ) kann man das Blink System über den Alexa2 Adapter und den textCommand Befehl steuern. Ich verwende nur aktivieren/deaktivieren in einem Blockly und das klappt ganz gut.
            Slowman 1 Reply Last reply Reply Quote 0
            • Slowman
              Slowman @Albert K last edited by
              @albert-k
              Ich brauche dies hier nicht zu installieren mehr? Bin davor immer zurück geschreckt, dies hier durchzuführen. Kannst du mal da ein Beispiel zeigen, wie es jetzt gesteuert wird.
              • Albert K
                Albert K @Slowman last edited by Albert K
                @slowman
                In den geschwärzten Bereich kommt die PIN zum deaktivieren rein (zB "eins zwei drei vier")
                Alexa fordert zwar bei der Deaktivierung zur Eingabe des Pins auf, was man aber nicht beantworten muss
                I D4RKKN1GHT84 2 Replies Last reply Reply Quote 1
                • I
                  IceD112 @Albert K last edited by
                  @albert-k
                  Wo im Alexa Adapter finde ich denn den entsprechenden State?
                  Interpretiere ich dein Blockly richtig, dass du deine Kamera mit Sprache de- und aktivierst? Anstelle dessen kann ich ja auch einen An- und Abwesenheitsstate nehmen?
                  • Albert K
                    Albert K @IceD112 last edited by
                    @iced112
                    • Bei jedem Echo Gerät unter Commands, textCommand
                    • Als Trigger kannst Du natürlich einen Anwesenheits Status nehmen. Ich habs in meinem Blockly nur schnell auf ein VIS Schaltelement gelegt zum testen
                    • steuern geht allerdings nur über Spracheingabe bei Blink. deshalb ist der neue textCommand Befehl ja so toll, das löst mir einige Probleme die ich mit Alexa hatte.
                    • I
                      @albert-k
                      Verstehe ich dass dann korrekt, dass wenn der Trigger (welcher auch immer) aktiviert wird, aktiviert sich die Kamera über den textCommand?
                      Welcher Befehl muss denn genau enthalten sein? "sag Bllink ... aktivieren"?
                      • Albert K
                        @iced112
                        • Richtig
                        • genau so wie es in meinem Blockly steht, wobei "Aussenkameras" der Name meines Blink Systems ist (das muss also entsprechend dem System Namen in Deiner Blink App oder der Alexa App angepasst werden)
                        Die möglichen Sprachbefehle kann man auch im Alexa Blink Skill nachsehen.
                        • I
                          @albert-k
                          Ei, dann werde ich morgen mal ne Blockly basteln...
                          Ähm. der Name vom Blinksystem? Du meinst den Namen der jeweiligen Kamera oder der des Sync-Moduls? Der Kamera nehme ich an?
                          • Albert K
                            @iced112
                            In meinem Blockly schalte ich das System, also alle Kameras die mit dem Sync Modul verbunden sind. Einzeln geht aber glaube ich auch. Musst Du im Skill nachsehen.
                            I 2 Replies Last reply Reply Quote 0
                            • I
                              @albert-k
                              Prima,,, ich werde berichten...
                              • I
                                @albert-k
                                Aktivieren nach Anwesenheit funktioniert prima.
                                Blockly ist, bis auf den Trigger identisch mit deinem. Danke für den Tipp. Jetzt mache ich noch die Zeitsteuerung.
                                Plan ist, wie weiter oben im Beitrag schon mal erwähnt, dass trotz Anwesenheit true, ab 23 Uhr das System wieder aktiviert werden soll.
                                Das mache ich ja am besten im selben Blockly. Wie könnte dann der weitere Aufbau aussehen? Bin da leider noch nicht tief genug drin um von alleine drauf zu kommen
                                  <block type="on_ext" id="]#+6zkIh:u;)}kYFH/F=" x="-812" y="-512">
                                    <value name="OID0">
                                      <shadow type="field_oid" id="O8C-SG3qcTRSy.t:x@~I">
                                        <field name="oid">tr-064.0.devices.Davids-iPhone.active</field>
                                      <block type="controls_if" id="2wEz;@;p_Og*M0V07obY">
                                          <block type="logic_compare" id="GX#c*l+e;{tAo)i*5x:|">
                                            <field name="OP">EQ</field>
                                              <block type="get_value" id="k1TEs6QDMnrf(17?vT8d">
                                                <field name="OID">tr-064.0.devices.Davids-iPhone.active</field>
                                              <block type="logic_boolean" id="f|J3PMU5d%F:4%;|K]A1">
                                          <block type="control" id="Ulvg6{XK}A]WX`z{jd80">
                                            <field name="OID">alexa2.0.Echo-Devices.G2A0P3077474013G.Commands.textCommand</field>
                                              <block type="text" id="J+dODeY8}2HH?nY}PUWa">
                                                <field name="TEXT">sag Blink Home aktivieren</field>
                                        <value name="IF1">
                                          <block type="logic_compare" id="t]a8Eh+Po!bhl|Vxi_-W">
                                              <block type="get_value" id="VUN+TzR,j=bjo6%)U8i1">
                                              <block type="logic_boolean" id="E.M2m97+r}0}9RvwfCz0">
                                        <statement name="DO1">
                                          <block type="control" id="B,|l9lBGr~F3Qgosc#^}">
                                              <block type="text" id="*[.hxHC/$8@G;`|Ti0i0">
                                                <field name="TEXT">sag Blink deaktiviere Home</field>
                                              <block type="control" id=")vgm[xBB[N:o8sFeJ9E)">
                                                <field name="DELAY_MS">5</field>
                                                  <block type="text" id="tz[al}l37R(Py1x2+*,5">
                                                    <field name="TEXT">3619</field>
                                Andere Frage noch zum "Aktiv-Status der Kamera. Ich habe sonst nirgends eine Info im Adapter, ob das System läuft oder nicht? Als Status würde ich das auch gerne in der VIS anzeigen lassen...
                                • D4RKKN1GHT84
                                  D4RKKN1GHT84 @Albert K last edited by
                                  @albert-k Danke für den Tipp! Endlich kann man mal weg von IFTTT um die Blink Module zu steuern! Bin ganz begeistert das ich auf diesen Post gestoßen bin aber eine Sache bekomme ich leider nicht hin 😞 Habe das Script exakt nach dem von Dir gebaut und aktivieren klappt ohne Probleme aber das System wird nicht deaktiviert. Habe auch den PIN Block drin wie du aber klappt nicht. Bastel schon seit 2 Stunden rum.....hat jemand einen Tipp?? Bei PIN kommt halt z.B. 3457 rein richtig? geht bei mir mit PIN nicht und auch ohne nicht 😞
                                  • Albert K
                                    Albert K @IceD112 last edited by Albert K
                                    @iced112
                                    • am einfachsten einen festen Zeitplan in der Blink App eintragen 😊 . Hab ich bei mir auch so.
                                    • Da ja keine Verbindung zum Blink System besteht welche eine Rückmeldung geben kann, kannst Du das nur simulieren. Ich habe dazu ja einen eigenen Datenpunkt "Virtueller_Schalter_Blink" angelegt. Den verwende ich in der VIS. Das Blockly das meine anderen Kameras und BWMs anhand des Anwesenheits Status scharf schaltet, schaltet praktisch nur diesen Datenpunkt.
                                    • Albert K
                                      Albert K @D4RKKN1GHT84 last edited by
                                      @d4rkkn1ght84
                                      Hast Du denn die 5 Sekunden Verzögerung in dem zweiten "steuere.." Block bei der deaktivierung?
                                      D4RKKN1GHT84 1 Reply Last reply Reply Quote 0
                                      • I
                                        @albert-k
                                        Ja, ok, aber wenn er in der Blinkapp den Zeitplan schaltet, dann müsst er doch... ah, ne, mein Trigger ändert sich ja nicht. Aaaaber, die Zeitsteuerung bezieht sich doch auf die Kamera und nicht auf das system. Wenn das System offline ist, kann die Kamera denn dann überhaupt aktiviert werden...😕
                                        • D4RKKN1GHT84
                                          @albert-k jap habe ich genau so... hab dann den text auch mal direkt in die Command Zeile bei dem Alexa Adapter eingegeben um auszuschließen das es am Blockly liegt. Also erst sage Blink deaktiviere Aussenbereich und dann nach 5 Sekunden noch 2584
                                          So ist es doch auch bei dir oder? Vor der PIN steht ja kein Text oder? Laut Alexa Skill soll ja meine PIN lautet #### sagen....
                                          I Albert K 2 Replies Last reply Reply Quote 0
                                          • I
                                            IceD112 @D4RKKN1GHT84 last edited by
                                            @d4rkkn1ght84 Wie alt ist dein PIN denn, ich glaub der ist nur vier wochen aktive, oder?
                                            blink xt camera
                                            63
                                            406
                                            116745
