    4. IOBroker Anbindung an einen Kostal Plenticore
    • HAL
      HAL @joefarm last edited by HAL
      @joefarm Mich würde ein Adapter für BYD HVS interessieren. Bisher klappt damit nur das Windows Programm "Be Connect Plus-V1.4.exe" und abgespeckt die "Be Connect App". Es soll wohl auch mittels pearl Script gehen, aber auf meinem Tinkerboard kriege ich das nicht zum laufen .
      readBYD.pl
      #!/usr/bin/perl
      # readBYD.pl
      # This program reads some current values from a BYD HVS/HVM Premium Battery Box.
      # There is NO WARRANTY
      # If you find this program useful send me some greetings to forenandi73@kabelmail.de
      # redirect STDERR to nul (Windows) or /dev/null (UNIX) if you are not interested in the debugging output
      use strict;
      use IO::Socket;
      use Digest::CRC;
      # connect to BYD HVS/HVM Premium device, adjust PeerAddr to match your IP
      my $sock = IO::Socket::INET->new(PeerAddr => '192.168.178.78', PeerPort => '8080', Proto => 'tcp') or die;
      # commands to be sent to BYD
      my $tobyd1="\x01\x03\x00\x00\x00\x13\x04\x07";
      my $tobyd2="\x01\x03\x05\x00\x00\x19\x84\xcc";
      # unbuffer output on socket, stdout, stderr
      my $old=select($sock); $|=1;
      select(STDOUT);$|=1;
      select(STDERR);$|=1;
      select($old);
      # always read one byte from stream
      $/=\1;
      # create empty hash for results
      my %rh=();
      # send first command to BYD
      print $sock $tobyd1;
      print STDERR "Data1 sent!\n";
      # read 3 bytes
      my $b11=<$sock>;	# 0x01
      my $b12=<$sock>; 	# 0x03
      my $b13=<$sock>; 	# length of data
      my $dl1=ord($b13);	# data length
      printf STDERR "data length=%d\n",$dl1;
      # read payload
      my $pl1=$b13;
      for (my $i=0;$i<$dl1;$i++)
      	$pl1.=<$sock>;
      # read checksum bytes
      my $c11=<$sock>;	# checksum LSB
      my $c12=<$sock>;	# checksum MSB
      # get overall checksum from data
      my $crc1=ord($c12)*256 + ord($c11);
      # calculate checksum from actual data
      my $ctx1 = Digest::CRC->new(width=>16, init=>0x0284, xorout=>0x0000, refout=>1, poly=>0x8005, refin=>1, cont=>0);
      $ctx1->add($pl1);
      my $digest1=$ctx1->digest;
      printf STDERR "Payload length: %d, Checksum=%04X, Digest=%04X\n",length($pl1),$crc1,$digest1;
      if ($b11 ne "\x01" || $b12 ne "\x03" || $crc1 != $digest1)
      	die "illegal/unexpected data received";
      # print received bytes
      my $num1=0;
      for (my $i=0;$i<length($pl1);$i++)
      	my $c=substr($pl1,$i,1);
      	$num1++;
      	my $o=ord($c);
      	$c=".";
      	if ($o > 31 && $o < 127) { $c=chr($o); }
      	printf STDERR "%03d: %03d %02X %s\n",$num1,$o,$o,$c;
      # extract the values from the payload
      &getvals1(\%rh,$pl1);
      # send second command
      print $sock $tobyd2;
      print STDERR "Data2 sent!\n";
      # read 3 bytes from response
      my $b21=<$sock>;	#0x01
      my $b22=<$sock>; 	#0x03
      my $b23=<$sock>; 	# length of data
      my $dl2=ord($b23);	# data length
      printf STDERR "data length=%d\n",$dl2;
      # read the payload
      my $pl2=$b23;		# payload
      for (my $i=0;$i<$dl2;$i++)
      	$pl2.=<$sock>;
      my $c21=<$sock>;	# checksum LSB
      my $c22=<$sock>;	# checksum MSB
      my $crc2=ord($c22)*256 + ord($c21);
      # calculate checksum from actual payload
      my $ctx2 = Digest::CRC->new(width=>16, init=>0x0284, xorout=>0x0000, refout=>1, poly=>0x8005, refin=>1, cont=>0);
      $ctx2->add($pl2);
      my $digest2=$ctx2->digest;
      printf STDERR "Payload length: %d, Checksum=%04X, Digest=%04X\n",length($pl2),$crc2,$digest2;
      if ($b21 ne "\x01" || $b22 ne "\x03" || $crc2 != $digest2)
      # print payload bytes
      my $num2=0;
      for (my $i=0;$i<length($pl2);$i++)
      	my $c=substr($pl2,$i,1);
      	$num2++;
      	my $o=ord($c);
      	$c=".";
      	printf STDERR "%03d: %03d %02X %s\n",$num2,$o,$o,$c;
      &getvals2(\%rh,$pl2);
      # finally print the accumulated results
      foreach my $k (sort keys %rh)
      	printf STDOUT "%s = %s\n",$k,$rh{$k};
      $sock->close();
      print STDERR "End.\n";
      exit(0);
      sub getvals1
      	my $h=shift @_;
      	my $pl=shift @_;
      	$$h{SerialNo}=substr($pl,1,19);
      	$$h{"BMU-A"}=getvers(substr($pl,25,2));
      	$$h{"BMU-B"}=getvers(substr($pl,27,2));
      	$$h{BMS}=getvers(substr($pl,29,2));
      sub getvals2
      	my $h=shift @_;
      	my $pl=shift @_;
      	$$h{SoC}=getshort(substr($pl,1,2));
      	$$h{CellVhigh}=getshort(substr($pl,3,2))/100;
      	$$h{CellVlow}=getshort(substr($pl,5,2))/100;
      	$$h{SoH}=getshort(substr($pl,7,2));
      	$$h{Vbatt}=getshort(substr($pl,11,2))/100;
      	$$h{CellTempHigh}=getshort(substr($pl,13,2));
      	$$h{CellTempLow}=getshort(substr($pl,15,2));
      	$$h{Vout}=getshort(substr($pl,33,2))/100;
      	my $currval=getshort(substr($pl,9,2));
      	if ($currval < 32768)
      		$$h{Current}=$currval/10;
      	else
      		$$h{Current}=($currval-2**16)/10;
      sub getshort
      	my $v=shift @_;
      	return(
      		ord(substr($v,0,1))*256 + ord(substr($v,1,1))
      sub getvers
      	my $v=shift @_;
      	return(
      		ord(substr($v,0,1)) . "." .  ord(substr($v,1,1))
      J T 2 Replies Last reply Reply Quote 0
        joefarm @HAL last edited by
        @hal Mit dem HVS kann ich leider nicht helfen, da ich einen HV habe. Und bei der Adapterprogrammierung muss ich leider auch passen.
        Ich habs zumindest per Javascript und einen request geschafft, einzelne Werte aus der Statistik Info der BYD HV auszulesen, als Info, die @arteck noch nicht implementiert hat. Ging mir erst mal nur um Total Charge und Total Discharge Energy. Noch ziemlich rudimentär...
        var request = require("request");
        var username = "user";
        var pass = "user";
        var url = "http://" + username + ":" + pass + "@192.168.6.1/asp/StatisticInformation.asp";
        var cronStr = "3-58/5 * * * *"; // run every 5 minutes starting at 3
        createState('Solar.BydTotalChargeEnergy', 0,
                {type: 'number',unit: 'kWh',role: 'value', name: 'BydTotalChargeEnergy',desc: 'Byd Gesamte Ladeleistung'});
        createState('Solar.BydTotalDischargeEnergy', 0,
                {type: 'number',unit: 'kWh',role: 'value', name: 'BydTotalDischargeEnergy',desc: 'Byd Gesamte Entladeleistung'});
        createState('Solar.BydBatteryEfficiency', 0,
                {type: 'number',unit: '%',role: 'value', name: 'BydBatteryEfficiency',desc: 'Byd Batterieeffizienz'});
        function readBattStatistic() {
            request(url, function(err, state, body) {
                if (body) {
                    //console.log(body);
                    var match;
                    var myRegexp = /Charge Energy:[\s\S]+?>(\d{3,5}\.\d{1,3})[\s\S]+?Discharge Energy:[\s\S]+?(\d{3,5}\.\d{1,3})/m;
                    if ((match = body.match(myRegexp)) !== null) {
                        //console.log(match);
                        var charge = parseFloat(match[1]);
                        //console.log(charge);
                        setState('Solar.BydTotalChargeEnergy', charge, true);
                        var discharge = parseFloat(match[2]);
                        //console.log(discharge);
                        setState('Solar.BydTotalDischargeEnergy', discharge, true);
                        setState('Solar.BydBatteryEfficiency', discharge / charge * 100, true);
                    else console.log("not matched");
        schedule(cronStr, readBattStatistic);
        • Bostil
          Bostil last edited by
          hoffe hier auf Plenticore-Leidgenossen zu treffen, die auch gerne versch. Infos visualisieren möchten.
          Würde gerne in einer Wochenansicht (Mo - So) den Hausverbrauch + Erzeugung PV auf Tagesebene nachvollziehen können. Wenn möglich gerne als klassisches Säulendiagramm.
          Hat von euch jemand dies schon bewerkstelligt bekommen? Denke, dass @Scrounger material design bar chart von Hilfe sein könnte. Aber hier habe ich so meine Probleme dies zu über ein JSON zu realisieren.
          Jemand eine Idee?? DANKE.
          Das sind die Datensätze, die die Meisten kennen werden:
          StrathCole 1 Reply Last reply Reply Quote 0
          • StrathCole
            StrathCole @Bostil last edited by StrathCole
            @bostil Ich nutze Influxdb für die Sammlung (also statt history Adapter) und habe dann Grafana installiert, das auf Influx zugreift.
            Mein Graph sieht so aus:
            So sieht es dann mit der Einstellung 6 Monate aus
            Und so mit der von dir genannten Woche
            • StrathCole
              StrathCole @Diginix last edited by StrathCole
              @diginix
              Kannst du mal bitte folgendes testen:
              In der Datei /opt/iobroker/node_modules/iobroker.plenticore/node_modules/@strathcole/iob-lib/lib/iob-lib.js
              Zeile 111:
              delete objectStates[id];
              direkt dahinter noch eine Zeile einfügen:
              delete stateStates[id];
              Dann Adapter neu starten und nach dem nächsten Löschen der States (also Tageswechsel) den Logmodus wieder umstellen
              Danke.
              Diginix 1 Reply Last reply Reply Quote 1
              • Diginix
                Diginix @StrathCole last edited by
                @strathcole In Version 2.1.6 gibt es die Ordnerstruktur so nicht. Ich finde nicht mal eine Datei mit "delete objectStates[id];" unterhalb von /opt/iobroker/node_modules/iobroker.plenticore/
                Ich vermute dass es bei dieser Ver. noch in /opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js ist?
                • StrathCole
                  @diginix vielleicht hat er das iob-lib direkt im Hauptverzeichnis node_modules installiert. Sollte es schon länger geben.
                  • Diginix
                    @strathcole Stimmt, da liegt die Datei.
                    Sieht nun so aus. Den Loglevel aber erst morgen früh von error zurück nehmen?
                    • StrathCole
                      @diginix kannst du auch jetzt schon
                      Diginix 2 Replies Last reply Reply Quote 0
                      • Diginix
                        @strathcole Ok, erledigt. Ich werde berichten.
                        • Diginix
                          @strathcole Die Anpassung hat leider keine Besserung gebracht:
                          2021-02-04 07:48:47.262 - warn: plenticore.0 (1512441) State "plenticore.0.forecast.day1.power.1h.generated" has no existing object, this might lead to an error in future versions
                          Ich habe aber eben noch mal ein "adapter upload" gemacht und somit die Instanz neu gestartet. In den 10 Minuten seit dem sind keine Meldungen mehr gekommen.
                          • StrathCole
                            @diginix Hm, ich glaub aber auch die Meldungen kommen immer nur nach Mitternacht, wenn man nicht neu startet, oder? Nach einem Neustart müssten sie ja immer bis zum nächsten Tageswechsel weg sein?
                            • Diginix
                              @strathcole Das kann natürlich auch sein. Dann würde es morgen trotz der Anpassung wieder losgehen.
                              Ich dachte nur, dass die gepatchte javascript Datei vllt nicht direkt verarbeitet wird und deswegen hab ich das "upload" getriggert. Was aber eben auch den Neustart der Instanz bedeutet und dadurch nur vermeintlich Ruhe herrscht.
                              Fazit: Höchstwahrscheinlich hilft dieser Patch noch nicht. Genau wissen wir es aber erst morgen kurz vor 8 Uhr.
                              • StrathCole
                                @diginix Interessant ist allerdings: Ich habe gestern extra mal den jscontroller aus dem latest installiert, also 3.2 – und bei mir tritt es nicht auf, habe allerdings auch nicht ohne den Patch getestet.
                                • Diginix
                                  @strathcole Dann wäre die einzige Erklärung, dass der Patch eben bis zu "adapter upload" heute noch nicht wirklich gegriffen hat und erst morgen wirklich funktioniert. Mehr als Abwarten geht nun nicht. Außer ich manipuliere die Systemzeit.
                                  • StrathCole
                                    @diginix Ich hab einfach mal die neue 2.1.7 und das neue Lib veröffentlicht. Dann können wir sicher sein, dass er auch das richtige Lib nimmt. Bei mir gab es nämlich 4 Instanzen vom Lib in iobroker.
                                    • Diginix
                                      @strathcole Die iob-lib gab es bei mir nur einmal auf dem System und die Zeile 112 war gepatcht.
                                      Habe nun de 2.1.7 installiert und die iob-lib wurde neu erstellt, ist aber in Zeile 112 inhaltlich identisch zu der gepatchten von mir. Instanz läuft bisher ohne Logfehler. Wenn es morgen früh nicht ruhig bleibt, ist guter Rat teuer. 😉
                                      • Diginix
                                        @strathcole Leider auch mit 2.1.7 keine Besserung:
                                        2021-02-05 07:47:30.116  - warn: plenticore.0 (1622132) State "plenticore.0.forecast.day1.power.1h.generated" has no existing object, this might lead to an error in future versions
                                        • StrathCole
                                          @diginix Jetzt hab ich es bei mir auch endlich und kann auf Fehlersuche gehen.
                                          • Diginix
                                            @strathcole "Gut" aber merkwürdig dass es bei dir erst jetzt durchschlägt.
                                            lemonbiter 1 Reply Last reply Reply Quote 0
                                            1.2k
                                            1302
                                            444612
