    4. Betatester für Backitup 2.0.0 gesucht
    • simatec
      simatec Developer Most Active @da_Woody last edited by simatec
      @da_woody
      Nein da verstehst du etwas falsch. Remotezugriff für das Backup ist Port 8088 und nicht 8086.
      das eine hat mit dem anderen nix zu tun.
      Wenn bei dir der Port 8088 bereits belegt ist, dann musst du in der Influx conf auf deinem Server bind anpassen.
      bind <server-ip>:8088
      8088 musst du dir dann anpassen und in der Conf von Backitup muss dann dieser Port rein.
      Auf keinen Fall die 8086
      • simatec
        @da_woody
        https://docs.influxdata.com/influxdb/v1.8/administration/config/#bind-address-127-0-0-1-8088
        • da_Woody
          da_Woody @simatec last edited by da_Woody
          @simatec einfach zu dämlich...
          hab jetzt in der influxdb.conf den port geändert.
          ### Welcome to the InfluxDB configuration file.
          # The values in this file override the default values used by the system if
          # a config option is not specified. The commented out lines are the configuration
          # field and the default value used. Uncommenting a line and changing the value
          # will change the value used at runtime when the process is restarted.
          # Once every 24 hours InfluxDB will report usage data to usage.influxdata.com
          # The data includes a random ID, os, arch, version, the number of series and other
          # usage data. No data from user databases is ever transmitted.
          # Change this option to true to disable reporting.
          # reporting-disabled = false
          # Bind address to use for the RPC service for backup and restore.
          bind-address = "192.168.0.252:8088"
          ### [meta]
          in backitup auf 8088, ergebniss das selbe...
          [DEBUG] [influxDB] - Start InfluxDB Backup ...
          [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
          [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
          [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database Drassburg -host 192.168.0.252:8088 "/opt/iobroker/backups/influxDB_2021_02_03-21_53_17_backupiobroker"
          /bin/sh: 1: influxd: not found
          • simatec
            @da_woody
            Auf deinem iobroker System, von dem aus du das Backup startest, fehlt noch immer influxd
            Du muss da Influx laufen haben.
            Ohne User und Datenbanken. Einfach nur als Daemon
            da_Woody Negalein 2 Replies Last reply Reply Quote 0
            • da_Woody
              @simatec darum frug ich ja so dämlich:
              was, wie kann ich da nachschauen? eventuell installen, starten.
              penguin is not my buddy... 😄
              • simatec
                @da_woody
                https://docs.influxdata.com/influxdb/v1.8/introduction/install/#installing-influxdb-oss
                • Negalein
                  Negalein Global Moderator @simatec last edited by
                  @simatec sagte in Betatester für Backitup 2.0.0 gesucht:
                  bei mir dann quasi auch so?
                  influxDB: Error: Command failed: influxd backup -portable -database iobroker -host 10.0.1.22:8088 "/opt/iobroker/backups/influxDB_2021_02_03-23_01_33_Standard_backupiobroker"
                  Ich betreib ioBroker im Docker auf einer Synology.
                  Soll ich mich an in dieser Anleitung an Ubuntu oder Debian halten?
                  simatec D 2 Replies Last reply Reply Quote 0
                  • da_Woody
                    @simatec wenn ich mir das so durchlese und interpretiere muss ich auf der ioBroker VM
                    sudo apt-get update && sudo apt-get install influxdb
                    sudo systemctl unmask influxdb.service
                    sudo systemctl start influxdb
                    tun am sein und das is es?
                    • simatec
                      simatec Developer Most Active @Negalein last edited by
                      @negalein Bei Docker kann ich das leider nicht beantworten.
                      Aber sicher gibt es hier oder bei Google auch Anleitungen dafür
                        darkiop Most Active @Negalein last edited by
                        @negalein Das Docker image von @andre ? Das basiert auf Debian Buster.
                        Du könntest, über die ENV
                        PACKAGES
                        die InfluxDB im Container installieren - oder die InfluxDB in einen eigenen Container auslagern.
                        Mittels
                        nmap -p- <IP>
                        kannst du nach der Installation dann auch mal schauen welche Ports offen sind.
                        Negalein andre 2 Replies Last reply Reply Quote 0
                        • Negalein
                          Negalein Global Moderator @darkiop last edited by Negalein
                          @darkiop sagte in Betatester für Backitup 2.0.0 gesucht:
                          Influx läuft als eigener Container.
                          Wie bring ich das dann Backitup bei?
                          • andre
                            andre Developer @darkiop last edited by
                            Bitte nicht die InfluxDB im Container installieren... Macht es lieber nach dem "oder".
                            Ggf. muss im Container ein Dienst/ CLI installiert und konfiguriert werden, damit die "externe" Datenbank gesichert werden kann. Erfahrungswerte habe ich da zwar nicht, aber wenn die reine Installation z.B. eines CLI Tools per "PACKAGES" nicht reicht, kann man über die user defined startup scripts eigentlich alles für die Einrichtung scripten...
                            MfG,
                            André
                              @negalein sagte in Betatester für Backitup 2.0.0 gesucht:
                              IP + Port von der InfluxDB vom Container bzw. Dockerhost. Teste doch mal mit nmap was offen ist bzw. schau mal in deiner Container Config wie du die Ports gemappt hast bzw. in welchen Netz der Container läuft.
                              @andre sagte in Betatester für Backitup 2.0.0 gesucht:
                              Absolut ... ich hätte noch dazu schreiben sollen, dass das vor dem oder nicht dem Container Prinzip entspricht 🙂
                              • Negalein
                                IP + Port passen
                                Kenne jetzt den Fehler.
                                Backitup hat beim Update auf 2.0.0 den Port von 32543 auf den Standardport geändert. Ist mir erst jetzt aufgefallen.
                                • simatec
                                  @negalein
                                  Danke für den Hinweis. Schaue ich mir an und wird gefixt
                                  • da_Woody
                                    @simatec sorry, aber ich behirn es nicht wie ich ohne DB und user influx auf der ioBroker VM istallieren muss um influxd starten zu können...
                                    • simatec
                                      @da_woody
                                      In meinem geposteten Link stehen doch alle Befehle, um Influxdb zu installieren. Einfach Influx installieren und starten.
                                      • da_Woody
                                        • simatec
                                          @da_woody
                                          Geht doch 👍🏻
                                            Markus84 @simatec last edited by
                                            @simatec Hast du eigentlich geplant auch YAHKA zu backupen? Mein letzter Stand ist, das dort eine separate Datei gesichert werden muss, die nicht im ioBroker-Backup enthalten ist.
                                            293
                                            33480
