    4. Betatester für Backitup 2.0.0 gesucht
    • da_Woody
      da_Woody @simatec last edited by da_Woody
      @simatec einfach zu dämlich...
      hab jetzt in der influxdb.conf den port geändert.
      ### Welcome to the InfluxDB configuration file.
      # The values in this file override the default values used by the system if
      # a config option is not specified. The commented out lines are the configuration
      # field and the default value used. Uncommenting a line and changing the value
      # will change the value used at runtime when the process is restarted.
      # Once every 24 hours InfluxDB will report usage data to usage.influxdata.com
      # The data includes a random ID, os, arch, version, the number of series and other
      # usage data. No data from user databases is ever transmitted.
      # Change this option to true to disable reporting.
      # reporting-disabled = false
      # Bind address to use for the RPC service for backup and restore.
      bind-address = "192.168.0.252:8088"
      ### [meta]
      in backitup auf 8088, ergebniss das selbe...
      [DEBUG] [influxDB] - Start InfluxDB Backup ...
      [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
      [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
      [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
      [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database Drassburg -host 192.168.0.252:8088 "/opt/iobroker/backups/influxDB_2021_02_03-21_53_17_backupiobroker"
      /bin/sh: 1: influxd: not found
      • simatec
        simatec Developer Most Active @da_Woody last edited by
        @da_woody
        Auf deinem iobroker System, von dem aus du das Backup startest, fehlt noch immer influxd
        Du muss da Influx laufen haben.
        Ohne User und Datenbanken. Einfach nur als Daemon
        da_Woody Negalein 2 Replies Last reply Reply Quote 0
        • da_Woody
          @simatec darum frug ich ja so dämlich:
          was, wie kann ich da nachschauen? eventuell installen, starten.
          penguin is not my buddy... 😄
          • simatec
            @da_woody
            https://docs.influxdata.com/influxdb/v1.8/introduction/install/#installing-influxdb-oss
            • Negalein
              Negalein Global Moderator @simatec last edited by
              @simatec sagte in Betatester für Backitup 2.0.0 gesucht:
              bei mir dann quasi auch so?
              influxDB: Error: Command failed: influxd backup -portable -database iobroker -host 10.0.1.22:8088 "/opt/iobroker/backups/influxDB_2021_02_03-23_01_33_Standard_backupiobroker"
              Ich betreib ioBroker im Docker auf einer Synology.
              Soll ich mich an in dieser Anleitung an Ubuntu oder Debian halten?
              simatec D 2 Replies Last reply Reply Quote 0
              • da_Woody
                @simatec wenn ich mir das so durchlese und interpretiere muss ich auf der ioBroker VM
                sudo apt-get update && sudo apt-get install influxdb
                sudo systemctl unmask influxdb.service
                sudo systemctl start influxdb
                tun am sein und das is es?
                • simatec
                  simatec Developer Most Active @Negalein last edited by
                  @negalein Bei Docker kann ich das leider nicht beantworten.
                  Aber sicher gibt es hier oder bei Google auch Anleitungen dafür
                    darkiop Most Active @Negalein last edited by
                    @negalein Das Docker image von @andre ? Das basiert auf Debian Buster.
                    Du könntest, über die ENV
                    PACKAGES
                    die InfluxDB im Container installieren - oder die InfluxDB in einen eigenen Container auslagern.
                    Mittels
                    nmap -p- <IP>
                    kannst du nach der Installation dann auch mal schauen welche Ports offen sind.
                    Negalein andre 2 Replies Last reply Reply Quote 0
                    • Negalein
                      Negalein Global Moderator @darkiop last edited by Negalein
                      @darkiop sagte in Betatester für Backitup 2.0.0 gesucht:
                      Influx läuft als eigener Container.
                      Wie bring ich das dann Backitup bei?
                      • andre
                        andre Developer @darkiop last edited by
                        Bitte nicht die InfluxDB im Container installieren... Macht es lieber nach dem "oder".
                        Ggf. muss im Container ein Dienst/ CLI installiert und konfiguriert werden, damit die "externe" Datenbank gesichert werden kann. Erfahrungswerte habe ich da zwar nicht, aber wenn die reine Installation z.B. eines CLI Tools per "PACKAGES" nicht reicht, kann man über die user defined startup scripts eigentlich alles für die Einrichtung scripten...
                        MfG,
                        André
                          @negalein sagte in Betatester für Backitup 2.0.0 gesucht:
                          IP + Port von der InfluxDB vom Container bzw. Dockerhost. Teste doch mal mit nmap was offen ist bzw. schau mal in deiner Container Config wie du die Ports gemappt hast bzw. in welchen Netz der Container läuft.
                          @andre sagte in Betatester für Backitup 2.0.0 gesucht:
                          Absolut ... ich hätte noch dazu schreiben sollen, dass das vor dem oder nicht dem Container Prinzip entspricht 🙂
                          • Negalein
                            IP + Port passen
                            Kenne jetzt den Fehler.
                            Backitup hat beim Update auf 2.0.0 den Port von 32543 auf den Standardport geändert. Ist mir erst jetzt aufgefallen.
                            • simatec
                              @negalein
                              Danke für den Hinweis. Schaue ich mir an und wird gefixt
                              • da_Woody
                                @simatec sorry, aber ich behirn es nicht wie ich ohne DB und user influx auf der ioBroker VM istallieren muss um influxd starten zu können...
                                • simatec
                                  @da_woody
                                  In meinem geposteten Link stehen doch alle Befehle, um Influxdb zu installieren. Einfach Influx installieren und starten.
                                  • da_Woody
                                    • simatec
                                      @da_woody
                                      Geht doch 👍🏻
                                        Markus84 @simatec last edited by
                                        @simatec Hast du eigentlich geplant auch YAHKA zu backupen? Mein letzter Stand ist, das dort eine separate Datei gesichert werden muss, die nicht im ioBroker-Backup enthalten ist.
                                        • simatec
                                          simatec Developer Most Active @Markus84 last edited by
                                          @markus84
                                          Ich glaube da gibt es bereits ein Issue.
                                          Muss ich mir mal anschauen.
                                            @simatec Für deconz gibt es einen Issue. Wenn du das integrieren könntest, wäre natürlich auch super. Soll ich dir einen Issue anlegen für YAHKA? Ich habe keinen auf Github gefunden.
                                            293
                                            33480
