    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      tombox last edited by
      @pfried
      iobroker fix
      Aber du solltest vorrangig über die admin oberfläche adapter installieren
      Eine Neuinstallation hilft bei token errors nicht
      pfried 1 Reply Last reply Reply Quote 0
      • pfried
        pfried @tombox last edited by pfried
        @tombox Nach Ausführung von Iobroker fix:
        $ ./iobroker add vw-connect  --host RaspberryPi-Office
        host.RaspberryPi-Office install adapter vw-connect
        npm install --loglevel error --production (System call) in "/node_modules/iobroker.vw-connect"
        npm
         ERR! code EACCESnpm ERR! syscall accessnpm ERR! path /node_modules/iobroker.vw-connectnpm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, access '/node_modules/iobroker.vw-connect'npm ERR!  [Error: EACCES: permission denied, access '/node_modules/iobroker.vw-connect'] {npm ERR!   errno: -13,npm ERR!   code: 'EACCES',npm ERR!   syscall: 'access',npm ERR!   path: '/node_modules/iobroker.vw-connect'npm ERR! }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
        npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-02-04T10_20_58_945Z-debug.log
        Cannot install iobroker.vw-connect: 243
        ERROR: process exited with code 25
        EDIT: Changing the directory iobroker.vw-connect to 777 helped. Thx!
        Nun steht im LOG:
        host.RaspberryPi-Office	2021-02-04 14:14:17.527	info	instance system.adapter.vw-connect.0 started with pid 16629
        host.RaspberryPi-Office	2021-02-04 14:13:47.488	info	Restart adapter system.adapter.vw-connect.0 because enabled
        host.RaspberryPi-Office	2021-02-04 14:13:47.487	error	instance system.adapter.vw-connect.0 terminated with code 10 (CANNOT_FIND_ADAPTER_DIR)
        host.RaspberryPi-Office	2021-02-04 14:13:47.179	info	instance system.adapter.vw-connect.0 started with pid 13521
        host.RaspberryPi-Office	2021-02-04 14:13:44.721	info	Restart adapter system.adapter.vw-connect.0 because enabled
        host.RaspberryPi-Office	2021-02-04 14:13:44.720	error	instance system.adapter.vw-connect.0 terminated with code 10 (CANNOT_FIND_ADAPTER_DIR)
        host.RaspberryPi-Office	2021-02-04 14:13:44.426	info	instance system.adapter.vw-connect.0 started with pid 13285
          aba320 @pfried last edited by
          @pfried @tombox hallo also das mit dem Logüberfüllen kann ich in der 0026 bei meinem Skoda bestätigen.
          host.raspberrypiiobroker	2021-02-04 11:38:57.382	info	instance system.adapter.vw-connect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          vw-connect.0	2021-02-04 11:38:57.151	error	(8807) Failed relogin
          vw-connect.0	2021-02-04 11:38:57.151	error	(8807) {"code":"ECONNRESET"}
          vw-connect.0	2021-02-04 11:38:57.151	error	(8807) Error: socket hang up
          vw-connect.0	2021-02-04 11:38:57.150	error	(8807) Failed in first login step
          vw-connect.0	2021-02-04 11:38:56.801	info	(8807) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          vw-connect.0	2021-02-04 11:38:56.799	info	(8807) terminating
          vw-connect.0	2021-02-04 11:38:56.798	info	(8807) cleaned everything up...
          vw-connect.0	2021-02-04 11:38:56.796	info	(8807) Got terminate signal TERMINATE_YOURSELF
          host.raspberrypiiobroker	2021-02-04 11:38:56.780	info	stopInstance system.adapter.vw-connect.0 send kill signal
          host.raspberrypiiobroker	2021-02-04 11:38:56.777	info	stopInstance system.adapter.vw-connect.0 (force=false, process=true)
          host.raspberrypiiobroker	2021-02-04 11:38:56.774	info	"system.adapter.vw-connect.0" disabled
          vw-connect.0	2021-02-04 11:38:56.589	error	(8807) Relogin
          vw-connect.0	2021-02-04 11:38:56.589	error	(8807) 400
          vw-connect.0	2021-02-04 11:38:56.589	error	(8807) {"error":"invalid_grant","error_description":"Signature of id token (or refresh token) is invalid or token is expired"}
          vw-connect.0	2021-02-04 11:38:56.589	error	(8807) VwToken
          vw-connect.0	2021-02-04 11:38:56.589	error	(8807) Failing to refresh token.
          vw-connect.0	2021-02-04 11:38:56.507	error	(8807) Relogin
          vw-connect.0	2021-02-04 11:38:56.507	error	(8807) 400
          vw-connect.0	2021-02-04 11:38:56.507	error	(8807) {"error":"invalid_grant","error_description":"Signature of id token (or refresh token) is invalid or token is expired"}
          vw-connect.0	2021-02-04 11:38:56.507	error	(8807) VwToken
          vw-connect.0	2021-02-04 11:38:56.506	error	(8807) Failing to refresh token.
          vw-connect.0	2021-02-04 11:38:55.275	error	(8807) Failed relogin
          vw-connect.0	2021-02-04 11:38:55.275	error	(8807) {"code":"ECONNRESET"}
          vw-connect.0	2021-02-04 11:38:55.275	error	(8807) Error: socket hang up
          vw-connect.0	2021-02-04 11:38:55.275	error	(8807) Failed in first login step
          vw-connect.0	2021-02-04 11:38:53.964	error	(8807) Failed relogin
          vw-connect.0	2021-02-04 11:38:53.963	error	(8807) Error: socket hang up
          vw-connect.0	2021-02-04 11:38:53.963	error	(8807) Failed to get token
          vw-connect.0	2021-02-04 11:38:53.692	error	(8807) Failed relogin
          vw-connect.0	2021-02-04 11:38:53.692	error	(8807) {"code":"ECONNRESET"}
          vw-connect.0	2021-02-04 11:38:53.692	error	(8807) Error: socket hang up
          vw-connect.0	2021-02-04 11:38:53.692	error	(8807) Failed in first login step
          vw-connect.0	2021-02-04 11:38:53.434	error	(8807) Failed relogin
          vw-connect.0	2021-02-04 11:38:53.433	error	(8807) {"code":"ECONNRESET"}
          vw-connect.0	2021-02-04 11:38:53.433	error	(8807) Error: socket hang up
          vw-connect.0	2021-02-04 11:38:53.433	error	(8807) Failed in first login step
          vw-connect.0	2021-02-04 11:38:53.429	error	(8807) Failed relogin
          vw-connect.0	2021-02-04 11:38:53.429	error	(8807) {"code":"ECONNRESET"}
          vw-connect.0	2021-02-04 11:38:53.429	error	(8807) Error: socket hang up
          vw-connect.0	2021-02-04 11:38:53.428	error	(8807) Failed in first login step
          vw-connect.0	2021-02-04 11:38:52.168	error	(8807) Failed relogin
          vw-connect.0	2021-02-04 11:38:52.167	error	(8807) Error: socket hang up
          vw-connect.0	2021-02-04 11:38:52.167	error	(8807) Failed to get token
          vw-connect.0	2021-02-04 11:38:52.161	error	(8807) Failed relogin
          vw-connect.0	2021-02-04 11:38:52.160	error	(8807) {"code":"ECONNRESET"}
          vw-connect.0	2021-02-04 11:38:52.160	error	(8807) Error: socket hang up
          vw-connect.0	2021-02-04 11:38:52.160	error	(8807) Failed in first login step
          vw-connect.0	2021-02-04 11:38:51.995	error	(8807) Relogin
          vw-connect.0	2021-02-04 11:38:51.995	error	(8807) 400
          vw-connect.0	2021-02-04 11:38:51.995	error	(8807) {"error":"invalid_grant","error_description":"Signature of id token (or refresh token) is invalid or token is expired"}
          vw-connect.0	2021-02-04 11:38:51.995	error	(8807) VwToken
          vw-connect.0	2021-02-04 11:38:51.994	error	(8807) Failing to refresh token.
          vw-connect.0	2021-02-04 11:38:51.673	error	(8807) Failed relogin
          vw-connect.0	2021-02-04 11:38:51.672	error	(8807) {"code":"ECONNRESET"}
          vw-connect.0	2021-02-04 11:38:51.672	error	(8807) Error: socket hang up
          vw-connect.0	2021-02-04 11:38:51.672	error	(8807) Failed in first login step
          vw-connect.0	2021-02-04 11:38:51.637	error	(8807) Relogin
          vw-connect.0	2021-02-04 11:38:51.637	error	(8807) 400
          vw-connect.0	2021-02-04 11:38:51.637	error	(8807) {"error":"invalid_grant","error_description":"Signature of id token (or refresh token) is invalid or token is expired"}
          vw-connect.0	2021-02-04 11:38:51.637	error	(8807) VwToken
          vw-connect.0	2021-02-04 11:38:51.637	error	(8807) Failing to refresh token.
          vw-connect.0	2021-02-04 11:38:51.517	error	(8807) Relogin
          vw-connect.0	2021-02-04 11:38:51.517	error	(8807) 400
          vw-connect.0	2021-02-04 11:38:51.517	error	(8807) {"error":"invalid_grant","error_description":"Signature of id token (or refresh token) is invalid or token is expired"}
          vw-connect.0	2021-02-04 11:38:51.517	error	(8807) VwToken
          vw-connect.0	2021-02-04 11:38:51.517	error	(8807) Failing to refresh token.
          das ging noch viel länger würde aber den Post sprengen.
          ich bin dann wieder zur 0023 zurück. da sind wieder nur alle 54 Minuten die folgen 2 Zeiler. übrigens die 54 Minuten bleiben, egal welche abrufzeit man einstellt( selbst bei 77 erfolgt nach 54 Min der Fehler).
          Adaptereinstellungen wurden nicht verändert. update 77 min erzwungen 0 und trip steht auf kurz.( fehler das bei alle nur die cyclic kommen hatte ich schon gepostet.)
          vw-connect.0	2021-02-04 17:09:13.149	error	(5468) 400
          vw-connect.0	2021-02-04 17:09:13.148	error	(5468) Failing to refresh token.
          vw-connect.0	2021-02-04 16:15:13.121	error	(5468) 400
          vw-connect.0	2021-02-04 16:15:13.120	error	(5468) Failing to refresh token.
          vw-connect.0	2021-02-04 15:21:13.117	error	(5468) 400
          vw-connect.0	2021-02-04 15:21:13.115	error	(5468) Failing to refresh token.
          vw-connect.0	2021-02-04 14:27:13.153	error	(5468) 400
          vw-connect.0	2021-02-04 14:27:13.147	error	(5468) Failing to refresh token.
          vw-connect.0	2021-02-04 13:33:13.173	error	(5468) 400
          vw-connect.0	2021-02-04 13:33:13.171	error	(5468) Failing to refresh token.
          • pfried
            pfried @aba320 last edited by
            @aba320 Wie bist Du auf 0.23 zurückgegangen? Bitte um Deine Hilfe!! Liebe Grüße Paul
            Glasfaser A 2 Replies Last reply Reply Quote 0
            • Glasfaser
              Glasfaser @pfried last edited by
              @pfried
              https://forum.iobroker.net/topic/26438/test-adapter-vw-connect-v0-0-x-für-vw-we-connect-id/671
              • pfried
                pfried @Glasfaser last edited by
                @glasfaser Diesen Button habe ich nicht, auch nicht im Expert Modus .....
                  aba320 @pfried last edited by aba320
                  @pfried in den adaptern die Expertenansicht aktivieren (2 männlein symbol von rechts) muß rot sein. dann im adapter rechts unten das + dann findes dur die vorhergehenden versionen.
                  • pfried
                    pfried @aba320 last edited by pfried
                    @aba320 Wie gesagt, diesen Button habe ich leider auch im Expert Modus nicht ...
                    EDIT: Habe den IObroker angehalten, IOBroker fix ausgeführt, jetzt sehe ich den Button wieder ... danke
                      @pfried hatte sich überschnitten aber das Kreuz hab ich im expert moduns schon ewig.
                        @pfried das ist gut dann mal auf 0023 die 0025 hat bei mir nicht gefunzt.
                        • pfried
                          @aba320 Der Connector geht auf Grün und er liest Daten! Super!
                          Hat die Meldung im Log was zu bedeuten?
                          vw-connect.0	2021-02-04 18:38:33.601	error	(29157) get vehicle data Failed
                          vw-connect.0	2021-02-04 18:38:33.600	error	(29157) TypeError: Cannot convert undefined or null to object
                          vw-connect.0	2021-02-04 18:38:27.104	info	(29157) starting. Version 0.0.23 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.20.1, js-controller: 3.1.6
                            @pfried natürlich bedeutet das was. aber da bin ich kein experte. wie gesagt der adapter wirft bei mir schon seit etlichen versionen alle 54 Minuten einen Fehler(2 Zeiler im log) aus. aber die Probleme finde ich in diesem frühen Stadium des Adapters als normal.des wegen arbeite ich im experten modus um zurück zu können. beobachte mal wie oft die Fehler kommen.
                            Edit: alles io solange der reale Skoda nicht alle 54 minuten stehen bleibt......
                            • pfried
                              @aba320 Nur zur Bestätigung, bei mir sind es auch 54 Minuten ....
                                @pfried na das wird @tombox sicher weiterhelfen. ich habe ihm auf seine Anfrage hin meinen Zugang zum Testen mitgeteilt. mal sehen was kommt.
                                  tombox @aba320 last edited by
                                  @aba320 @pfried
                                  Bitte mal via github installieren und schauen ob das Problem weg ist
                                  A 3 Replies Last reply Reply Quote 0
                                    aba320 @tombox last edited by
                                    @tombox ok mach ich gleich mal
                                      @tombox hab dir infos in chat gesendet
                                        @tombox hallo also das logvollschreiben scheint erledigt. es lauft jetzt mehr als 12 Stunden (nacht) ohne die Meldungen. auch der 54 Minuten Fehler ist nicht mehr da. Danke für die Arbeiten!
                                        E pfried 2 Replies Last reply Reply Quote 0
                                          emptykai @aba320 last edited by
                                          Kann mir jemand sagen wieso ich nicht soviele Informationen auslesen kann?
                                          (siehe Screenshot)
                                          Kann mein Fahrzeug dann ggf. die Fenster nicht auslesen etc.? Oder wodran könnte das liegen.
                                          • Glasfaser
                                            Glasfaser @emptykai last edited by
                                            @emptykai
                                            Das sind Remote ( Steuerdatenpunkte ) , daß heißt alles das was du über die App Steuern kannst, kannst du ( fast alles ) auch über diese Datenpunkte steuern .
                                            Die Datenpunkte für den Fensterzustand befinden sich hier :
                                            Beispiel:
                                            "34STATE_LEFT_FRONT_WINDOW", 33, "0x0301050001"); // 0x030105FFFF.0x0301050001, window1 - front/left
                                            Siehe Github
                                            1.2k
                                            81.1k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            398
                                            3090
                                            1600912
