    4. JavaScript
    5. Skript MiHome Error
    Skript MiHome Error
    • Jonas 0
      Jonas 0 last edited by
      ich möchte folgendes Skript in ioBroker nutzen:
      https://github.com/Pittini/iobroker-nodemihome
      System Infos:
      DebianGNU auf i3-3110M, 64-bit, 4GB RAM
      Node v.10.23.2
      NPM v.7.5.2
      Scriptengine v.4.8.4
      Dies zeigt der LOG an:
      javascript.0	2021-02-04 18:18:48.488	error	(1224) at process._tickCallback (internal/process/next_tick.js:68:7)
      javascript.0	2021-02-04 18:18:48.488	error	(1224) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      javascript.0	2021-02-04 18:18:48.488	error	(1224) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      javascript.0	2021-02-04 18:18:48.487	error	(1224) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17)
      javascript.0	2021-02-04 18:18:48.487	error	(1224) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1238:17)
      javascript.0	2021-02-04 18:18:48.487	error	(1224) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17)
      javascript.0	2021-02-04 18:18:48.487	error	(1224) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1621:37)
      javascript.0	2021-02-04 18:18:48.487	error	(1224) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1383:28)
      javascript.0	2021-02-04 18:18:48.487	error	(1224) at Object.createScript (vm.js:277:10)
      javascript.0	2021-02-04 18:18:48.487	error	(1224) at new Script (vm.js:83:7)
      javascript.0	2021-02-04 18:18:48.486	error	(1224) SyntaxError: Unexpected string
      javascript.0	2021-02-04 18:18:48.486	error	(1224) ^^^^^^^^^^^^^
      javascript.0	2021-02-04 18:18:48.486	error	(1224) const mihome = require'node-mihome';
      javascript.0	2021-02-04 18:18:48.486	error	at script.js.node-mihome:2
      javascript.0	2021-02-04 18:18:48.486	error	(1224) script.js.node-mihome compile failed:
      Danke!!!
      Problemmeldung: (https://github.com/Pittini/iobroker-nodemihome/issues/9)
      jonaschuba created this issue in Pittini/iobroker-nodemihome
      closed Module Error #9
      Thomas Braun paul53 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Jonas 0 last edited by
        @jonas-0 sagte in Skript MiHome Error:
        NPM v.7.5.2
        Sorgt für Trouble. Besser npm@6 verwenden.
        Insbesondere wenn node10 verwendet wird.
        (Was ich am Rande auf node12 heben würde)
        Jonas 0 1 Reply Last reply Reply Quote 0
          paul53 @Jonas 0 last edited by paul53
          @jonas-0 sagte: const mihome = require'node-mihome';
          Richtig:
          const mihome = require('node-mihome');
          Jonas 0 ? 2 Replies Last reply Reply Quote 0
          • Jonas 0
            Jonas 0 @Thomas Braun last edited by
            Ist jetzt auf 6, trotzdem gleicher Fehler.
            • Jonas 0
              Jonas 0 @paul53 last edited by
              Ist geändert:
              javascript.0	2021-02-04 19:21:33.232	error	(1448) at Script.runInContext (vm.js:133:20)
              javascript.0	2021-02-04 19:21:33.232	error	(1448) at script.js.node-mihome:842:3
              javascript.0	2021-02-04 19:21:33.232	error	(1448) at script.js.node-mihome:64:1
              javascript.0	2021-02-04 19:21:33.232	error	(1448) at Init (script.js.node-mihome:570:12)
              javascript.0	2021-02-04 19:21:33.232	error	(1448) script.js.node-mihome: TypeError: Cannot read property 'miioProtocol' of undefined
                A Former User @paul53 last edited by
                Das steht schon richtig im Script auf Git.. 🙂 aber @Jonas-0 vielleicht bei Copy+Paste was schief gelaufen?
                Hast du node-mihome auch im Adapter eingetragen, damit es installiert wird?
                Und deine Node-Installation mal gerade gezogen?
                NPM7 vermurkst recht viel...
                • Jonas 0
                  Jonas 0 @Guest last edited by
                  @ilovegym
                  Habs nochmal neu reinkopiert und nur user und Passwort eingetragen.
                  node-mihome steht auch im Script Adapter.
                  @ilovegym said in Skript MiHome Error:
                  Was meinst du damit?
                  • Jonas 0
                    Jonas 0 @Jonas 0 last edited by Jonas 0
                    Danach immer noch gleicher Log:
                    javascript.0	2021-02-04 19:26:30.545	error	(1448) at Script.runInContext (vm.js:133:20)
                    javascript.0	2021-02-04 19:26:30.544	error	(1448) at script.js.node-mihome:844:3
                    javascript.0	2021-02-04 19:26:30.544	error	(1448) at script.js.node-mihome:66:1
                    javascript.0	2021-02-04 19:26:30.544	error	(1448) at Init (script.js.node-mihome:572:12)
                    javascript.0	2021-02-04 19:26:30.544	error	(1448) script.js.node-mihome: TypeError: Cannot read property 'miioProtocol' of undefined
                      A Former User @Jonas 0 last edited by
                      Das hier vom netten Kollegen @Thomas-Braun , richtig? 🙂 Node gerade ziehen
                      Jonas 0 1 Reply Last reply Reply Quote 1
                      • Jonas 0
                        @ilovegym Hat geklappt. Läuft! Danke euch allen!
                          @jonas-0
                          Was spuckt denn
                          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                          nun aus?
                          611
